BTHQ21603V-FSTF-LED WHITE WC
    BATRON
    BATRON - BTHQ21603V-FSTF-LED WHITE WC - Alphanumeric LCD, 16 x 2, Black on White, 5V, Parallel, Engl...
BTHQ21603V-FSTF-LED WHITE WC 数据手册
Jan/2002 BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 1/16 Available from Midas Components LTD Telephone Number: +44(0) 1493 602602 Website: www.midascomponents.co.uk Email: sales@midascomponents.co.uk DOCUMENT NUMBER AND REVISION VL-FS-BTHQ 21603VSS-02 REV.A (BTHQ 21603V-FSTF-LED05W(1 DIE)-CONN.) DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 2/16 DOCUMENT REVISION HISTORY 1: DOCUMENT DATE DESCRIPTION REVISION FROM TO A 2002.01.11 First Release CHANGED BY PHILIP CHENG DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 CHECKED BY Z.B.HE www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 3/16 CONTENTS Page No. 1. GENERAL DESCRIPTION 4 2. MECHANICAL SPECIFICATIONS 4 3. INTERFACE 6 4. 4.1 4.2 ABSOLUTE MAXIMUM RATINGS ELECTRICAL MAXIMUM RATINGS (Ta=25°C) ENVIRONMENTAL CONDITION 7 7 7 5. 5.1 5.2 5.3 5.4 ELECTRICAL SPECIFICATIONS TYPICAL ELECTRICAL CHARACTERISTICS TIMING SPECIFICATIONS TIMING DIAGRAM OF VDD AGAINST V0 CORRESPONDENCE BETWEEN CHARACTER CODES AND CHARACTER PATTERNS (NOVATEK STANDARD NT3881D-01) 8 8 9 11 12 6. APPENDIX 13 SIGNALS DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 4/16 Specification of LCD Module Type Item No.: BTHQ 21603VSS-02 1. General Description • • • • • 16 characters (5x8 dots) x 2 lines FSTN Positive Black & White Transflective Dot Matrix LCD module. Viewing Angle: 6 O’clock direction. Driving scheme: 1/16 Duty, 1/5 bias. ‘NOVATEK’ NT3881DH-01/AI (Die form) LCD Controller and Driver or equivalent. ’SAMSUNG’ KS0065B-PCC (Die form) 40-Channel Segment/Common Driver for Dot Matrix LCD or equivalent. • • Connector: 16 pins ZIF SMD connector (CON-IL-402). White LED05 backlight. 2. Mechanical Specifications The mechanical detail is shown in Fig. 1 and summarized in Table 1 below. Parameter Outline dimensions Effective viewing area Active area Display format Character size Character spacing Character pitch Dot size Dot spacing Dot pitch Weight: Table 1 Specifications 53.0(W) x 20.0(H) x 8.5 MAX.(D) (Excluded connector) 36.0(W) x 10.0(H) 34.10(W) x 7.40(H) 16 characters x 2 lines 1.85(W) x 3.15(H) (5 x 8 dots) 0.30(W) x 1.10(H) 2.15(W) x 4.25(H) 0.358(W) x 0.381(H) 0.015(W) x 0.015(H) 0.373(W) x 0.396(H) TBD DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 Unit mm mm mm mm mm mm mm mm mm grams www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 5/16 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 6/16 3. Interface signals Table 2 Pin No. 1 2 3 4 Symbol VSS VDD V0 RS 5 R/W 6 E 7 8 9 10 11 12 13 14 15 16 DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 LED(+) LED(-) Description Ground(0V). Power supply for logic (+5V) Power supply for LCD driver Register Select Input: “High” for Data register (for read and write) ”Low” for Instruction register (for write), Busy flag, address counter (for read) Read/Write signal: ” High” for Read mode. “Low” for Write mode. Enable. Start signal for data read /write. Data input/output (LSB) Data input/output Data input/output Data input/output Data input/output Data input/output Data input/output Data input/output (MSB) Anode of LED backlight Cathode of LED backlight DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 7/16 4. Absolute Maximum Ratings 4.1 Electrical Maximum Ratings(Ta = 25 ºC) Table 3 Parameter Symbol Min. Max. Power Supply voltage (Logic) VDD - VSS -0.3 +7.0 Power Supply voltage (LCD drive) VLCD=VDD – V0 -0.3 +13.5 Input voltage Vin -0.3 VDD +0.3 Note: The modules may be destroyed if they are used beyond the absolute maximum ratings. All voltage values are referenced to VSS = 0V. 4.2 Unit V V V Environmental Condition Table 4 Item Ambient Temperature Humidity Vibration (IEC 68-2-6) cells must be mounted on a suitable connector Shock (IEC 68-2-27) Half-sine pulse shape Operating Storage Temperature Temperature (Topr) (Tstg) Min. Max. Min. Max. 0°C +50°C -10°C +60°C 95% max. RH for Ta ≤ 40°C < 95% RH for Ta > 40°C Frequency: 10 ∼ 55 Hz Amplitude: 0.75 mm Duration: 20 cycles in each direction. Pulse duration : 11 ms Peak acceleration: 981 m/s2 = 100g Number of shocks : 3 shocks in 3 mutually perpendicular axes. Remark Dry no condensation 3 directions 3 directions DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 8/16 5. Electrical Specifications 5.1 Typical Electrical Characteristics At Ta = 25 °C, VDD = 5V± ±5%, VSS=0V. Table 5 Parameter Supply voltage (Logic) Supply voltage (LCD) Input signal voltage 1 for E,DB0-DB7,R/W,RS. Input signal voltage 2 for OSC1. Supply Current (Logic & LCD) Supply Current (LCD) Supply voltage of white LED05 backlight Symbol VDD-VSS VLCD =VDD-V0 VIH1 VIL1 VIH2 VIL2 IDD I0 VLED Conditions VDD =5.0V, Note1. ”H” level ” L” level ” H” level ” L” level Character mode, Note 1 Checker board mode, Note 1 Character mode, Note 1 Checker board mode, Note 1 Forward current =20mA Min. 4.75 4.1 Typ. 5.0 4.6 Max. 5.25 5.1 Unit V V 2.2 -0.3 VDD -1.0 VSS - 1.1 VDD 0.8 VDD 1.0 1.6 V V V V mA - 1.5 2.5 mA - 0.2 0.3 mA - 0.2 0.3 mA 3.1 3.4 3.7 V Number of LED dies =1 Note (1) : There is tolerance in optimum LCD driving voltage during production and it will be within the specified range. DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 9/16 5.2 Timing Specifications At Ta = 0 °C To +50 °C , VDD = +5V±5%, VSS = 0V. Refer to Fig. 2, the bus timing diagram for write mode. Table 6 Parameter Enable cycle time Enable ”High” level pulse width Enable rise time Enable fall time RS, R/W set-up time RS, R/W address hold time Data output delay Data hold time Symbol tCYCE tWHE tRE tFE tAS tAH tDS tDHR Min. 500 300 60 100 10 100 10 Max. 25 25 - Unit ns ns ns ns ns - ns ns ns Max. 25 25 - Unit ns ns ns ns ns 190 - ns ns ns Remarks 8-bit operation mode 4-bit operation mode Refer to Fig. 3, the bus timing diagram for read mode . Table 7 Parameter Enable cycle time Enable ”High” level pulse width Enable rise time Enable fall time RS, R/W set-up time RS, R/W address hold time Read data output delay Read data hold time Symbol tCYCE tWHE tRE tFE tAS tAH tRD tDHR Min. 500 300 60 100 10 20 Remarks 8-bit operation mode 4-bit operation mode DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 10/16 Figure 2: Bus write operation sequence (Writing data from MPU to NT3881). Figure 3: Bus read operation sequence (Reading out data from NT3881 to MPU). DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 11/16 5.3 Timing Diagram of VDD against V0. Power on sequence shall meet the requirement of Figure 4, the timing diagram of VDD against V0. VDD 95% LOGIC SUPPLY VOLTAGE 0V 50ms(typical) OV LCD SUPPLY VOLTAGE V0 Figure 4: Timing diagram of VDD against V0. DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 12/16 5.4 Correspondence between Character Codes and Character Patterns (NOVATEK Standard NT3881D-01) DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 13/16 6. APPENDIX DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 14/16 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 15/16 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BT 21603V-FSTF-LED05W(1 DIE)-HQ-CONN. 16/16 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de
BTHQ21603V-FSTF-LED WHITE WC 价格&库存
很抱歉,暂时无法提供与“BTHQ21603V-FSTF-LED WHITE WC”相匹配的价格&库存,您可以联系我们找货
