BTHQ42005VSS-STF-LED04
    OTHER
BTHQ42005VSS-STF-LED04 数据手册
Aug/2002 BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 1/12 Available from Midas Components LTD Telephone Number: +44(0) 1493 602602 Website: www.midascomponents.co.uk Email: sales@midascomponents.co.uk DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 2/12 DOCUMENT DOCUMENT REVISION FROM TO A REVISION DATE 2002.07.08 HISTORY 1: DESCRIPTION First Release. CHANGED BY CHECKED BY PHILIP CHENG M.Y.LU DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 3/12 CONTENTS Page No. 1. GENERAL DESCRIPTION 4 2. MECHANICAL SPECIFICATIONS 4 3. INTERFACE 6 4. 4.1 4.2 ABSOLUTE MAXIMUM RATINGS ELECTRICAL MAXIMUM RATINGS (Ta=25°C) ENVIRONMENTAL CONDITION 7 7 7 5. 5.1 5.2 5.3 ELECTRICAL SPECIFICATIONS TYPICAL ELECTRICAL CHARACTERISTICS TIMING SPECIFICATIONS TIMING DIAGRAM OF VDD AGAINST V0 8 8 9 11 6. CHARACTER GENERATOR ROM(KS0066U-10B) 12 SIGNALS DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 4/12 Specification of LCD Module Type Item No.: BTHQ 42005VSS-02 1. General Description • • • • • • 2. 20 characters (5 x 8 dots) x 4 lines STN Positive G-Yellow Transflective LCD Character Module. Viewing Angle: 6 O’clock direction. Driving duty: 1/16 Duty, 1/5 bias. ‘SAMSUNG’ KS0066UP-10BCC (Die form) LCD Controller & Driver or equivalent. ‘SAMSUNG’ KS0065B-PCC (Die form) LCD Segment Drivers or equivalent. Yellow-green LED04 backlight. Mechanical Specifications The mechanical detail is shown in Fig. 1 and summarized in Table 1 below. Table 1 Parameter Outline dimensions Effective viewing area Active area Display format Character size Character spacing Character pitch Dot size Dot spacing Dot pitch Weight Specifications 98.0(W) x 60.0(H) x 14.0 MAX.(D) 76.0(W) x 25.2(H) 70.35(W) x 20.74(H) 20 characters x 4 lines 2.90(W) x 4.697(H) (5 x 8 dots) 0.65(W) x 0.65(H) 3.55(W) x 5.347(H) 0.568(W) x 0.574(H) 0.015(W) x 0.015(H) 0.583(W) x 0.589(H) Approx. 71 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 Unit mm mm mm mm mm mm mm mm mm grams www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 5/12 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 6/12 3. Interface signals Table 2 Pin No. 1 2 3 4 Symbol VSS VDD V0 RS 5 R/W 6 E 7 8 9 10 11 12 13 14 15 or A 16 or K DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 LED(+) LED(-) Description Ground (0V). Power supply for logic (+5.0V). Power supply for LCD driver. Register Select Input: ”High’ for Data register (for read and write). ”Low” for Instruction register (for write), Busy flag, address counter (for read). Read/Write signal: ‘High’ for Read mode. ‘Low’ for Write mode. Enable. Start signal for data read /write. Data input/output (LSB) Data input/output Data input/output Data input/output Data input/output Data input/output Data input/output Data input/output (MSB) Anode of LED Backlight Cathode of LED Backlight DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 7/12 4. Absolute Maximum Ratings 4.1 Electrical Maximum Ratings(Ta = 25 ºC) Table 3 Parameter Symbol Min. Max. Unit Power Supply voltage (Logic) VDD-VSS -0.3 +7.0 V Power Supply voltage VLCD -0.3 +15.0 V (LCD drive) =VDD-V0 Input voltage Vin -0.3 VDD+0.3 V Note: The modules may be destroyed if they are used beyond the absolute maximum ratings. All voltage values are referenced to VSS = 0V. 4.2 Environmental Condition Table 4 Item Ambient Temperature Humidity Vibration (IEC 68-2-6) cells must be mounted on a suitable connector Shock (IEC 68-2-27) Half-sine pulse shape Operating Storage Temperature Temperature (Tstg) (Topr) Min. Max. Min. Max. -5°C +50°C -20°C +60°C 95% max. RH for Ta ≤ 40°C < 95% RH for Ta > 40°C Frequency: 10 ∼ 55 Hz Amplitude: 0.75 mm Duration: 20 cycles in each direction. Pulse duration : 11 ms Peak acceleration: 981 m/s2 = 100g Number of shocks : 3 shocks in 3 mutually perpendicular axes. Remark Dry no condensation 3 directions 3 directions DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 8/12 5. Electrical Specifications 5.1 Typical Electrical Characteristics At Ta = 25 °C, VDD = 5V±5%, VSS=0V. Table 5 Parameter Supply voltage (Logic) Supply voltage (LCD) Input signal voltage for E,DB0-DB7,R/W,RS. Supply Current (Logic & LCD) Supply Current (LCD) Supply voltage of yellow-green LED04 backlight Symbol VDD -VSS VLCD =VDD –V0 VIH VIL IDD I0 VLED Conditions VDD = 5V, Note (1) ”H” level ” L” level Character mode, VDD=5V, Note 1 Checker board mode, VDD=5V, Note 1 Character mode, VDD=5V, Note 1 Checker board mode, VDD=5V, Note 1 Forward current =240mA Min. 4.75 4.1 Typ. 5.0 4.5 Max. 5.25 4.9 Unit V V 2.2 -0.3 - 1.0 VDD 0.6 1.5 V V mA - 1.2 1.8 mA - 0.2 0.3 mA - 0.2 0.3 mA 3.9 4.1 4.3 V Number of LED dies =2x24 =48. Note (1) : There is tolerance in optimum LCD driving voltage during production and it will be within the specified range. DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 9/12 5.2 Timing Specifications At Ta = -5 °C To +50 °C , VDD = +5V±5%, VSS = 0V. Refer to Fig. 2, the bus timing diagram for write mode. Table 6 Parameter E Cycle Time E Rise/Fall Time E Pulse Width(high, low) R/W and RS Setup Time R/W and RS Hold Time Data Set-up Time Data Hold Time Symbol tc tR,tF tW tSU1 tH1 tSU2 tH2 Min. 500 230 40 10 80 10 Max. 20 - Unit ns ns ns ns ns ns ns Max. 20 120 - Unit ns ns ns ns ns ns ns Refer to Fig. 3, the bus timing diagram for read mode. Table 7 Parameter E Cycle Time E Rise/Fall Time E Pulse Width(high, low) R/W and RS Setup Time R/W and RS Hold Time Data Output Delay Time Data Hold Time Symbol tc tR,tF tW tSU tH tD tDH Min. 500 230 40 10 5 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 10/12 Figure 2: Write Mode Timing Diagram Figure 3: Read Mode Timing Diagram DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 11/12 5.3 Timing Diagram of VDD Against V0. Power on sequence shall meet the requirement of Figure 4, the timing diagram of VDD against V0. VDD 95% LOGIC SUPPLY VOLTAGE V0 0V 50ms(typical) 0V LCD SUPPLY VOLTAGE Figure 4: Timing Diagram of VDD Against V0. DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de BATRON BTHQ 42005VSS-STF-LED04Y.G.HK 12/12 6. Character Generator ROM(KS0066U-10B) DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de
BTHQ42005VSS-STF-LED04 价格&库存
很抱歉,暂时无法提供与“BTHQ42005VSS-STF-LED04”相匹配的价格&库存,您可以联系我们找货
