ESD3V3D5B
Bidirectional TVS Diode
Features
Ultra low leakage: nA level
Operating voltage: 3.3V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 9A (8/20μs)
RoHS Compliant
Dimensions SOD-523
Pin Configuration
Applications
Computer Interfaces Protection
Microprocessors Protection
Serial and Parallel Ports Protection
Control Signal Lines Protection
Power lines on PCB Protection
Latchup Protection
Mechanical Characteristics
Package: SOD-523
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:3,000pcs
Reel Size:7 inch
Device Marking:eB
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
90
VESD
± 30
Unit
W
Kv
± 30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev 2.0 : 01.06.2020
1/4
www.leiditech.com
ESD3V3D5B
Electrical Characteristics(TA=25°C unless otherwise specified)
Symbol
Parameter
VRWM
Reverse Working Peak Voltage
VBR
Reverse Breakdown Voltage
IR
Reverse Leakage Current
VC
Conditions
IT = 1mA
Min
Typ
Max
Unit
3.3
V
V
3.5
VRWM = 3.3V
0.01
µA
Clamping Voltage
IPP = 1 A (8/20µs)
6
V
VC
Clamping Voltage
IPP = 9 A (8/20µs)
8
V
CJ
Capacitance
VR = 0V, f = 1MHz
2/4
10.3
pF
www.leiditech.com
ESD3V3D5B
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
30
25
10
5
16
12
8
4
2
1
VR—Reverse Voltage(V)
2
3
4
5
6
7
8
9
10 11
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
Voltage (V)
Junction Capacitance vs. Reverse Voltage
-20
60
80
100
Time (nS)
IEC61000−4−2 Pulse Waveform
120
120
100
100
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
Peak Pulse Power vs. Pulse Time
80
60
40
50
75
100
125
150
60
40
-20
Ambient Temperature_Ta(℃)
60
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
80
3/4
www.leiditech.com
ESD3V3D5B
SOD-523 Package Outline & Dimensions
Millimeters
Inches
Symbol
Soldering Footprint
Min.
Nom.
Max.
Min.
Nom.
Max.
A
1.10
1.20
1.30
0.043
0.047
0.051
B
0.70
0.80
0.90
0.028
0.032
0.035
C
0.50
0.60
0.70
0.020
0.024
0.028
D
0.25
0.30
0.35
0.010
0.012
0.014
J
0.07
0.14
0.20
0.0028
0.0055
0.0079
K
0.15
0.20
0.25
0.006
0.008
0.010
L
1.50
1.60
1.70
0.059
0.063
0.067
Symbol
Millimeters
Inches
E
1.40
0.0547
F
0.40
0.0157
G
0.40
0.0157
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ESD3V3D5B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39431
- 100+0.30975
- 300+0.26741
