ESD5451N-2
ESD5451N-2
    LEIDITECH(雷卯电子)
    DFN1006-2
    特性:超小封装:1.0×0.6×0.5mm。 超低电容:典型值15pF。 超低泄漏:nA级别。 低工作电压:5V。 低钳位电压。 2引脚无铅封装。应用:手机及配件。 个人数字助理
ESD5451N-2 数据手册
ESD5451N-2 1-Line Bi-directional TVS Diode Features ● Ultra small package: 1.0x0.6x0.5mm ● Ultra low capacitance: 15pF typical ● Ultra low leakage: nA level ● Low operating voltage: 5V ● Low clamping voltage ● 2-pin leadless package ● ● Dimensions DFN1006 Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 6A (8/20μs) Pin Configuration RoHS Compliant Applications ● ● ● ● ● ● ● ● Cellular Handsets and Accessories Personal Digital Assistants Notebooks and Handhelds Portable Instrumentation Digital Cameras Peripherals Audio Players Keypads, Side Keys, LCD Displays Mechanical Characteristics ● Package: DFN1006 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:10,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol Value Ppp 80 VESD ±30 Unit W Kv ±30 Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com ESD5451N-2 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ESD5451N-2 Rev : 01.06.2018 Device Marking VRWM (V) VBR (V) IT (mA) B2 5 6 1 VC @1A 7.5 2/4 (Max) 12.5 (@A) 6 IR μA (Max) C (Pf) (Typ.) 0.5 15 www.leiditech.com ESD5451N-2 Typical Performance Characteristics (TA=25°C unless otherwise Specified) 20 Vc-Clamping Voltage(V) CJ-Junction Capacitance (pF) 16 14 12 10 8 6 4 2 15 10 5 0 0 0 1 2 3 4 0 5 VR—Reverse Voltage(V) 1 2 3 4 5 6 7 Ipp-Peak Pulse Current(A) Clamping Voltage vs. Peak Pulse Current Junction Capacitance vs. Reverse Voltage 10 Voltage (V) Peak Power_Ppp(kW) 100 1 0.1 -20 0.01 0.1 1 10 0 20 100 120 120 100 100 80 60 40 20 0 50 75 100 125 150 100 80 60 40 20 0 -20 -20 Ambient Temperature_Ta(℃) 0 20 40 60 T-Time(us) 8 X 20us Pulse Waveform Power Derating Curve Rev : 01.06.2018 80 IEC61000−4−2 Pulse Waveform Ipp-Peak Pulse Current-%of Ipp % of Rated Power Peak Pulse Power vs. Pulse Time 25 60 Time (nS) Pulse Duration_tp(uS) 0 40 3/4 www.leiditech.com ESD5451N-2 DFN1006 Package Outline Drawing h h - b E - A A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM e D DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 L A Bottom View A1 c e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern ╋ Y3 SYM Y1 Y2 Z ╋ DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
ESD5451N-2 价格&库存
很抱歉,暂时无法提供与“ESD5451N-2”相匹配的价格&库存,您可以联系我们找货
