GBLC12CI
1-Line Low Capacitance Bi-directional TVS Diode
Features
350W peak pulse power (8/20μs)
Ultra low capacitance: 1.0 pF typical
Dimensions SOD-323
Ultra low leakage: nA leel
Low clamping voltage
Protects one power line or data line
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
Pin Configuration
Applications
USB Ports
SIM Ports
Smart Phones
Wireless Systems
Set-top box and digital TV
Digital video interface (DVI)
Ethernet 10/100/1000 Base T
Mechanical Characteristics
Package: SOD-323
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Quantity per reel: 3,000pcs
Reel size: 7 inch
Device Marking: DC
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
Value
Unit
350
W
±30
VESD
KV
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-45 to +85
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.07.2021
1/3
www.leiditech.com
GBLC12CI
Electrical Characteristics(TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
Breakdown Voltage
Test Condition
Min
Typ
VRWM
Max Unit
12.0
VBR
IT = 1mA
V
13.3
V
Reverse Leakage Current
IR
VRWM = 12 V
0.2
µA
Clamping Voltage
VC
IPP = 1A (8 x 20µs pulse)
18
V
Clamping Voltage
VC
IPP = 12A (8 x 20µs pulse)
29
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
1
pF
Characteristic Curves
1
Voltage (V)
Peak Power_Ppp(kW)
10
0.1
-20
0.01
0.1
1.0
10.0
Pulse Duration_tp(uS)
100
100
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
120
80
60
40
75
100
125
150
60
80
100
80
60
40
-20
Ambient Temperature_Ta(℃)
60
T-Time(us)
Power Derating Curve
Rev : 01.07.2021
40
IEC61000−4−2 Pulse Waveform
120
25
Time (nS)
Peak Pulse Power vs. Pulse Time
8 X 20us Pulse Waveform
2/3
www.leiditech.com
GBLC12CI
SOD-323 Package Outline Drawing
DIMENSIONS
SYM
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
A
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
Suggested Land Pattern
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.07.2021
3/3
www.leiditech.com
很抱歉,暂时无法提供与“GBLC12CI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.62651
- 50+0.49164
- 150+0.42416
- 500+0.37361
- 3000+0.31629
- 6000+0.29605
