CPDQT5V0-HF
CPDQT5V0-HF
    LEIDITECH(雷卯电子)
    DFN1006
    1线双向瞬态电压抑制二极管
CPDQT5V0-HF 数据手册
CPDQT5V0-HF 1-Line Bi-directional TVS Diode Features ● Ultra low leakage: nA level ● Low operating voltage: 5V ● Low clamping voltage ● 2-pin leadless package ● ● Dimensions DFN1006 Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 10A (8/20μs) RoHS Compliant Pin Configuration Applications ● ● ● ● ● ● ● ● Cellular Handsets and Accessories Personal Digital Assistants Notebooks and Handhelds Portable Instrumentation Digital Cameras Peripherals Audio Players Keypads, Side Keys, LCD Displays Mechanical Characteristics ● Package: DFN1006 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:10,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol Ppp VESD Value Unit 120 W ±30 Kv ±30 Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com CPDQT5V0-HF Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number CPDQT5V0-HF Rev : 01.06.2018 Device Marking VRWM (V) LB 5 VBR (V) 5.7 IT (mA) VC @1A 1 10 2/4 (Max) 15 (@A) 10 IR μA (Max) C (Pf) (Typ.) 0.1 12 www.leiditech.com CPDQT5V0-HF Typical Performance Characteristics (TA=25°C unless otherwise Specified) Waveform Parameters: tr=8us td=20us Peak Pulse Power-PPK(KW) PP 10 110 100 90 80 70 60 50 40 30 20 10 0 td=IPP/2 0 5 10 15 20 25 0.1 0.01 0.1 30 1 10 100 1000 Pulse Duration-tp(us) Time (us) Non-Repetitive Peak Pulse Power vs. Pulse Time Pulse Waveform % of Rated Power or Ipp 1 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature-TA Power Derating Curve Rev : 01.06.2018 3/4 www.leiditech.com CPDQT5V0-HF DFN1006 Package Outline Drawing D Millimeters b DIM Max A 0.40 0.50 A1 0.00 0.05 D 0.55 0.65 E 0.95 1.05 b 0.45 0.55 b ID PIN 1 L1 L e E L L1 Min 1 脚标识 0.65TYP A1 A e L 0.60mm L1 0.2 0.32 0.05REF 0.85mm 0.55mm Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
