ESDALC6V1W5
Low Capacitance Q uad Array for ESD Protection
Features
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±25kV
Dimensions SOT-353
– IEC61000-4-5 (Lightning) 6A (8/20μs)
RoHS Compliant
Pin Configuration
Applications
Computers
Printers
Communication systems
Cellular phones handsets and accessories
Wireline and wireless telephone sets
Set top boxes
Mechanical Characteristics
Package: SOT-353
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:3,000pcs
Reel Size:7inch
Device Marking: WE
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Symbol
Peak Pulse Power (8/20µs)
Ppp
Value
Unit
150
W
±30
ESD per IEC 61000−4−2 (Air)
VESD
Kv
±25
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-40 to +125
Storage Temperature Range
TSTJ
-40 to +125
Rev : 01.06.2018
1/4
www.leiditech.com
ESDALC6V1W5
Electrical Characteristics(TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol Test Condition
Min
VRWM
VBR
Typ
Max
5
IT = 1mA
6.1
6.7
Unit
V
7.2
V
1
µA
Reverse Leakage Current
IR
VRWM = 5V
Clamping Voltage
VC
IPP = 1A (8 x 20 μs pulse)
10
15
V
Clamping Voltage
VC
IPP = 6A (8 x 20 μs pulse)
13.5
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
Rev : 01.06.2018
2/4
90
pF
www.leiditech.com
ESDALC6V1W5
Characteristic Curves
100
tr
90
100
10
NOTE: Non−Repetitive Surge.
PEAK VALUE IRSM @ 8 ms
PULSE WIDTH (tP) IS DEFINED
AS THAT POINT WHERE THE
PEAK CURRENT DECAY = 8 ms
80
% OF PEAK PULSE CURRENT
Ppk , PEAK SURGE POWER (WATTS)
1000
70
60
HALF VALUE IRSM/2@20US
50
40
30
tP
1
1
10
100
t, TIME (ms)
80
80
TYPICAL CAPACITANCE (pF)
1 MHz FREQUENCY
PEAK PULSE DERATING IN % OF PEAK POWER
OR CURRENT @ TA = 25 ° C
100
90
70
60
50
40
30
25
50
75
100
125
150
175
60
50
40
30
3.0
2.0
4.0
5.0
BIAS VOLTAGE (VOLTS)
Figure 3. Pulse Derating Curve
Figure 4. Capacitance
1.0
100
Ipp, PEAK PULSE CURRENT (AMPS)
IF , FORWARD CURRENT (A)
80
70
TA, AMBIENT TEMPERATURE (°C)
0.1
0.01
0.001
60
Figure 2. 8 x 20 ms Pulse Waveform
100
t, TIME (ms)
Figure 1. Pulse Width
Rev : 01.06.2018
0.7
0.8
0.9
1.0
1.1
1.2
10
2.5 ms SQUARE WAVE
1.0
10
15
VF, FORWARD VOLTAGE (VOLTS)
VC, CLAMPING VOLTAGE (VOLTS)
Figure 5. Forward Voltage
Figure 6. Clamping Voltage versus Peak
Pulse Current (Reverse Direction)
3/4
30
www.leiditech.com
ESDALC6V1W5
SOT-353 Package Outline & Dimensions
Inches
Symbol
Min.
Nom. Max. Min. Nom. Max.
A
0.031 0.037 0.043 0.80 0.95 1.10
A1
0.000 0.002 0.004 0.00 0.05 0.10
A3
0.08 REF
0.2 REF
b
0.004 0.008 0.012 0.10 0.21 0.30
C
0.004 0.005 0.010 0.10 0.14 0.25
D
0.070 0.078 0.086 1.80 2.00 2.20
E
0.045 0.049 0.053 1.15 1.25 1.35
e
Soldering Footprint
Millimeters
0.026 BSC
0.65 BSC
L
0.004 0.008 0.012 0.10 0.20 0.30
HE
0.078 0.082 0.086 2.00 2.10 2.20
Symbol
Inches
Millimeters
C
0.0748
1.9
G
0.055
1.40
P
0.025
0.65
P1
0.051
1.30
X
0.0157
0.40
Y
0.019
0.50
Z
0.0945
2.4
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2018
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ESDALC6V1W5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.60331
- 50+0.48015
- 150+0.41856
- 500+0.37237
- 3000+0.32001
- 6000+0.30156
