CESD5V0J4
CESD5V0J4
    LEIDITECH(雷卯电子)
    SOT-353-5(SC-70-5)
    ESD 5V截止
CESD5V0J4 数据手册
CESD5V0J4 Low Capacitance Q uad Array for ESD Protection Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±25kV Dimensions SOT-353 – IEC61000-4-5 (Lightning) 6A (8/20μs) RoHS Compliant Pin Configuration Applications ● Computers ● Printers ● Communication systems ● Cellular phones handsets and accessories ● Wireline and wireless telephone sets ● Set top boxes Mechanical Characteristics ● Package: SOT-353 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch ● Device Marking: WE Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 150 W ±30 VESD Kv ±25 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -40 to +125 ℃ Storage Temperature Range TSTJ -40 to +125 ℃ Rev : 01.06.2018 1/4 www.leiditech.com CESD5V0J4 Electrical Characteristics(TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Test Condition Min VRWM VBR Typ Max 5 6.1 IT = 1mA 6.7 Unit V 7.2 V 1 µA Reverse Leakage Current IR VRWM = 5V Clamping Voltage VC IPP = 1A (8 x 20 μs pulse) 10 15 V Clamping Voltage VC IPP = 6A (8 x 20 μs pulse) 13.5 20 V Junction Capacitance CJ VR = 0V, f = 1MHz Rev : 01.06.2018 2/4 90 pF www.leiditech.com CESD5V0J4 Characteristic Curves 100 tr 90 100 10 NOTE: Non−Repetitive Surge. PEAK VALUE IRSM @ 8 ms PULSE WIDTH (tP) IS DEFINED AS THAT POINT WHERE THE PEAK CURRENT DECAY = 8 ms 80 % OF PEAK PULSE CURRENT Ppk , PEAK SURGE POWER (WATTS) 1000 70 60 HALF VALUE IRSM/2@20US 50 40 30 tP 20 10 1 1 10 100 0 1000 t, TIME (ms) 0 90 80 80 TYPICAL CAPACITANCE (pF) 1 MHz FREQUENCY PEAK PULSE DERATING IN % OF PEAK POWER OR CURRENT @ TA = 25 ° C 100 90 70 60 50 40 30 20 10 25 50 75 100 125 150 175 60 50 40 30 20 10 0 200 0 1.0 3.0 2.0 4.0 5.0 BIAS VOLTAGE (VOLTS) Figure 3. Pulse Derating Curve Figure 4. Capacitance 1.0 100 Ipp, PEAK PULSE CURRENT (AMPS) IF , FORWARD CURRENT (A) 80 70 TA, AMBIENT TEMPERATURE (°C) 0.1 0.01 0.001 60 Figure 2. 8 x 20 ms Pulse Waveform 100 0 40 t, TIME (ms) Figure 1. Pulse Width 0 20 0.6 Rev : 01.06.2018 0.7 0.8 0.9 1.0 1.1 1.2 10 2.5 ms SQUARE WAVE 1.0 0 5.0 10 15 20 25 VF, FORWARD VOLTAGE (VOLTS) VC, CLAMPING VOLTAGE (VOLTS) Figure 5. Forward Voltage Figure 6. Clamping Voltage versus Peak Pulse Current (Reverse Direction) 3/4 30 www.leiditech.com CESD5V0J4 SOT-353 Package Outline & Dimensions Inches Symbol Min. Nom. Max. Min. Nom. Max. A 0.031 0.037 0.043 0.80 0.95 1.10 A1 0.000 0.002 0.004 0.00 0.05 0.10 A3 0.08 REF 0.2 REF b 0.004 0.008 0.012 0.10 0.21 0.30 C 0.004 0.005 0.010 0.10 0.14 0.25 D 0.070 0.078 0.086 1.80 2.00 2.20 E 0.045 0.049 0.053 1.15 1.25 1.35 e Soldering Footprint Millimeters 0.026 BSC 0.65 BSC L 0.004 0.008 0.012 0.10 0.20 0.30 HE 0.078 0.082 0.086 2.00 2.10 2.20 Symbol Inches Millimeters C 0.0748 1.9 G 0.055 1.40 P 0.025 0.65 P1 0.051 1.30 X 0.0157 0.40 Y 0.019 0.50 Z 0.0945 2.4 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
CESD5V0J4 价格&库存
很抱歉,暂时无法提供与“CESD5V0J4”相匹配的价格&库存,您可以联系我们找货
