FDD3672
N-Channel Enhancement Mode MOSFET
Description
The FDD3672 uses advanced trench technology
to provide excellent RDS(ON), low gate charge and
operation with gate voltages as low as 4.5V.
This device is suitable for use as a
Battery protection or in other Switching application.
General Features
VDS = 100V ID =50A
RDS(ON) < 28mΩ@ VGS=10V
Application
Battery protection
Load switch
Uninterruptible power supply
Package Marking and Ordering Information
Product ID
FDD3672
Pack
Marking
Qty(PCS)
TO-252
AP50N10D
2500
Absolute Maximum Ratings (TC=25℃unless otherwise noted)
Symbol
Parameter
Limit
Unit
VDS
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
±20
V
Drain Current-Continuous
50
A
Drain Current-Continuous(TC=100℃)
21
A
IDM
Pulsed Drain Current
70
A
PD
Maximum Power Dissipation
85
W
Derating factor
0.57
W/℃
Single pulse avalanche energy (Note 5)
256
mJ
-55 To 175
1.8
℃/W
ID
ID (100℃)
EAS
TJ,TSTG
RθJC
Rev 2.0 : 12.01.2019
Operating Junction and Storage Temperature Range
Thermal Resistance, Junction-to-Case (Note 2)
1/5
www.leiditech.com
FDD3672
Electrical Characteristics (TC=25℃unless otherwise noted)
Symbol
Parameter
Condition
Min
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
100
IDSS
Zero Gate Voltage Drain Current
VDS=100V,VGS=0V
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1
RDS(ON)
Drain-Source On-State
Resistance
VGS=10V, ID=20A
RDS(ON)
Resistance
VGS=4.5V, ID=10A
gFS
Forward Transconductance
VDS=5V,ID=10A
Clss
Input Capacitance
Coss
Output Capacitance
Max
Unit
V
1
μA
±100
nA
3
V
24
28
mΩ
28
30
mΩ
15
S
2000
PF
300
PF
Crss
Reverse Transfer Capacitance
250
PF
td(on)
Turn-on Delay Time
7
nS
tr
Turn-on Rise Time
7
nS
td(off)
Turn-Off Delay Time
29
nS
tf
Turn-Off Fall Time
7
nS
Qg
Total Gate Charge
39
nC
Qgs
Gate-Source Charge
8
nC
12
nC
VDS=25V,VGS=0V,
F=1.0MHz
VDD=50V,RL=5Ω
VGS=10V,RGEN=3Ω
VDS=50V,ID=10A,
VGS=10V
Typ
Qgd
Gate-Drain Charge
VSD
Diode Forward Voltage (Note 3)
VGS=0V,IS=20A
1.2
V
IS
Diode Forward Current (Note 2)
30
A
trr
Reverse Recovery Time
32
nS
Qrr
Reverse Recovery Charge
TJ = 25°C, IF = 10A
di/dt = 100A/μs(Note3)
53
nC
ton
Forward Turn-On Time
Intrinsic turn-on time is negligible (turn-on is dominated by
LS+LD)
Notes:
1、Repetitive Rating: Pulse width limited by maximum junction temperature.
2、Surface Mounted on FR4 Board, t ≤ 10 sec.
3、Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4、Guaranteed by design, not subject to production
5、EAS Condition : Tj=25℃,VDD=50V,VG=10V,L=0.5mH,Rg=25Ω, IAS=32A
2/5
www.leiditech.com
FDD3672
Typical Electrical and Thermal Characteristics (Curves)
Vds Drain-Source Voltage (V)
TJ-Junction Temperature(℃)
Figure 1 Output Characteristics
Figure 4 Rdson-JunctionTemperature
Vgs Gate-Source Voltage (V)
Qg Gate Charge (nC)
Figure 2 Transfer Characteristics
Figure 5 Gate Charge
ID- Drain Current (A)
Vsd Source-Drain Voltage (V)
Figure 3 Rdson- Drain Current
Figure 6 Source- Drain Diode Forward
3/5
www.leiditech.com
FDD3672
TJ-Junction Temperature (℃)
Figure 7 Capacitance vs Vds
Figure 9 Power De-rating
Figure 8 Safe Operation Area
Figure 10ID Current- Junction Temperature
Square Wave Pluse Duration(sec)
Figure 11 Normalized Maximum Transient Thermal Impedance
4/5
www.leiditech.com
FDD3672
Package Mechanical Data TO-252-3L
E
A
B2
Dimensions
Ref.
C2
H
D
L
V1
C
B
G
V1
V2
A2
V1
E1
Typ.
Min.
Typ.
Max.
A
2.10
2.50
0.083
0.098
B
0.66
0.86
0.026
0.034
B2
5.18
5.48
0.202
0.216
C
0.40
0.60
0.016
0.024
C2
0.44
0.58
0.017
0.023
D
5.90
6.30
0.232
E
6.40
E1
4.63
0.248
0.209REF
5.30REF
6.80
0.252
0.268
0.182
G
4.47
4.67
0.176
0.184
H
9.50
10.70
0.374
0.421
L
1.09
1.21
0.043
0.048
L2
1.35
1.65
0.053
0.065
7°
V1
L2
Inches
Max.
A2
D1
DETAIL A
D1
Millimeters
Min.
7°
0°
V2
6°
0°
6°
DETAIL A
TO-252
Reel Spectification-TO-252
B
P0
P2
Ref.
t1
A
A
D1
B0
F
W
Dimensions
T
E
D
K0
P1
A0
B
5°
Φ3
29
A A
B B
Φ13
Millimeters
Inches
Min.
Typ.
Max.
Min.
Typ.
Max.
W
15.90
16.00
16.10
0.626
0.630
0.634
E
1.65
1.75
1.85
0.065
0.069
0.073
F
7.40
7.50
7.60
0.291
0.295
0.299
D0
1.40
1.50
1.60
0.055
0.059
0.063
D1
1.40
1.50
1.60
0.055
0.059
0.063
P0
3.90
4.00
4.10
0.154
0.157
0.161
0.319
P1
7.90
8.00
8.10
0.311
0.315
P2
1.90
2.00
2.10
0.075
0.079
0.083
A0
6.85
6.90
7.00
0.270
0.271
0.276
B0
10.45
10.50
10.60
0.411
0.413
0.417
K0
2.68
2.78
2.88
0.105
0.109
0.113
T
0.24
t1
0.10
10P0
39.80
0.27
0.009
0.011
0.004
40.00
40.20
1.567
1.575
1.583
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
5/5
www.leiditech.com
很抱歉,暂时无法提供与“FDD3672”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.24640
- 100+2.07360
- 500+1.98720
- 1000+1.93536
- 2000+1.90080
