AZ4012-01F
AZ4012-01F
    LEIDITECH(雷卯电子)
    DFN1006
    双向 TVS 二极管
AZ4012-01F 数据手册
AZ4012-01F BIDIRECTIONAL TVS DIODE Features ● Protects one data or power line ● Ultra low leakage: nA level ● Operating voltage: 12V ● Low clamping voltage Dimensions DFN1006 Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 8A (8/20μs) ● RoHS Compliant Applications ● Cellular Handsets and Accessories ● Personal Digital Assistants ● Notebooks and Handhelds ● Portable Instrumentation ● Digital Cameras ● Peripherals ● Audio Players Pin Configuration Mechanical Characteristics ● Package: DFN1006 ● Case Material: “Green” Molding Compound. ● Moisture Sensitivity: Level 3 per J-STD-020 ● Terminal Connections: See Diagram Below ● Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 150 VESD ± 30 Unit W Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +150 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev 3.0 : 04.01.2021 1/4 www.leiditech.com AZ4012-01F Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A AF 12 14 1 - AZ4012-01F Rev 3.0 2.0 : 04.01.2021 12.01.2019 2/4 (Max) 19 (@A) 8 IR μA (Max) C (Pf) (Typ.) 0.2 8 www.leiditech.com AZ4012-01F Typical Performance Characteristics (TA=25°C unless otherwise Specified) Fig.1 Pulse Waveform-ESD(IEC61000-4-2) Fig.2 Transmission Line Pulse (TLP) Fig.4 Fig.3Capacitance vs. Reveres voltage Rev 3.0 : 04.01.2021 3/4 IV Curve( forward voltage) www.leiditech.com AZ4012-01F DFN1006 PACKAGE OUTLINE & DIMENSIONS Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.350 0.450 0.014 0.018 D 0.550 0.650 0.022 0.026 E 0.950 1.050 0.037 0.041 D1 0.420 0.520 0.017 0.020 E1 0.550 0.650 0.022 0.026 L 0.270 0.370 0.011 0.015 L1 0.000 0.100 0.000 0.004 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev 3.0 : 04.01.2021 4/4 www.leiditech.com
AZ4012-01F 价格&库存
很抱歉,暂时无法提供与“AZ4012-01F”相匹配的价格&库存,您可以联系我们找货
AZ4012-01F
  • 10+0.13652
  • 100+0.12053
  • 300+0.11254
  • 1000+0.10655
  • 5000+0.10179
  • 10000+0.09936
库存:9539
