AZ5A23-01F
AZ5A23-01F
    LEIDITECH(雷卯电子)
    DFN0603
    ESD 3.3V截止
AZ5A23-01F 数据手册
AZ5A23-01F LOW CAPACITANCE TVS DIODE ARRAY Features  Ultra small package: 0.6x0.3x0.3mm  low capacitance  Protects one data or power line  Ultra low leakage: nA level  Operating voltage: 3.3V  Low clamping voltage  2-Pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV Dimensions DFN0603 0.6 0.3 - 0.3 – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 16A (8/20μs)  RoHS Compliant Pin Configuration Applications  Cellular Handsets and Accessories  Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  Audio Players  Keypads, Side Keys, USB 2.0, LCD Displays Mechanical Characteristics  Package: DFN0603-2 (0.6x0.3x0.3mm)  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 168 W ±30 Kv VESD ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2019 1/7 www.leiditech.com AZ5A23-01F Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number AZ5A23-01F Rev : 01.06.2019 Device Marking E VRWM (V) VBR (V) IT (mA) 3.3 3.8 1 VC @1A - 2/7 (Max) 10.5 (@A) 16 IR μA (Max) C (Pf) (Typ.) 0.1 15 www.leiditech.com AZ5A23-01F Typical Performance Characteristics (TA=25°C unless otherwise Specified) Figure 1. 8 x 20μs Waveform Figure 2. Power Derating Curve Figure 3. Clamping Voltage vs. Peak Pulse Current (tp=8/20μs) 3/7 Rev : 01.06.2019 www.leiditech.com AZ5A23-01F Figure 4. Typic Breakdown Voltage vs. Temperature Figure 5. Typic Reverse Current vs. Temperature Rev : 01.06.2019 4/7 www.leiditech.com AZ5A23-01F Figure 6. Typic Capacitance vs. Reverse Voltage Rev : 01.06.2019 5/7 www.leiditech.com AZ5A23-01F Figure 7. Transmission Line Pulse (TLP) Transmission Line Pulse (TLP) is a measurement technique used in the Electrostatic Discharge (ESD) arena to characterize performance attributes of devices under ESD stresses. TLP is able to obtain current versus voltage (I−V) curves in which each data point is obtained with a 100 ns long pulse, with currents up to 40 A. TLP was first used in the ESD field to study human body model (HBM) in integrated circuits, but it is an equally valid tool in the field of system level ESD. The applicability of TLP to system level ESD is illustrated in Figure 1, which compares an 8 kV IEC 61000−4−2 current waveform with TLP current pulses of 8 and 16 A. The current levels and time duration for the pulses are similar and the initial rise time for the TLP pulse is comparable to the rise time of the IEC 61000−4−2’s initial current spike. This application note will give a basic introduction to TLP measurements and explain the datasheet parameters extracted from TLP for SDI Technology’s protection products. Comparison Between 8 kV IEC 61000−4−2 and 8 A and 16 A TLP Waveforms Comparison of a CurrentWaveform of IEC 61000−4−2with TLP Pulses at 8 and 16 A. The IEC 61000−4−2 ESD waveforms is true to the Standard and is shown here as captured on an oscilloscope. The points A, B, and C show the points on the aveforms specified in IEC 61000−4−2. Transmission Line Pulse (TLP) Version. Rev : 01.06.2019 6/7 www.leiditech.com AZ5A23-01F DFN0603 Package Outline Drawing DIMENSIONS e D h SYM h MIN NOM MAX A 0.230 0.330 A1 0.000 0.020 0.050 b 0.215 0.245 0.275 c 0.120 0.150 0.180 D 0.550 0.600 0.650 - b E - MILLIMETERS L A Bottom View A1 c e 0.355 BSC E 0.250 L 0.160 h 0.300 0.350 0.190 0.220 0.079 BSC Suggested Land Pattern SYM ╋ Y3 MILLIMETERS INCHES X 0.30 0.012 Y1 0.25 0.010 Y2 0.15 0.006 Y3 0.40 0.016 Z 0.65 0.026 Y1 Y2 Z ╋ DIMENSIONS X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2019 7/7 www.leiditech.com
AZ5A23-01F 价格&库存
很抱歉,暂时无法提供与“AZ5A23-01F”相匹配的价格&库存,您可以联系我们找货
AZ5A23-01F
    • 12000+0.23100
    库存:50000
