CDSOD323-T12C
CDSOD323-T12C
    LEIDITECH(雷卯电子)
    SOD-323
    ESD 12V截止
CDSOD323-T12C 数据手册
CDSOD323-T12C 1-Line Low Capacitance Bi-directional TVS Diode Features ● 350W peak pulse power (8/20μs) ● Ultra low capacitance: 1.0 pF typical ● ● ● ● ● Dimensions SOD-323 Ultra low leakage: nA leel Low clamping voltage Protects one power line or data line Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) RoHS Compliant Pin Configuration Applications ● ● ● ● ● ● ● USB Ports SIM Ports Smart Phones Wireless Systems Set-top box and digital TV Digital video interface (DVI) Ethernet 10/100/1000 Base T Mechanical Characteristics ● ● ● ● ● ● ● ● Package: SOD-323 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Quantity per reel: 3,000pcs Reel size: 7 inch Device Marking: DC Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 350 W ±30 VESD KV ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -45 to +85 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.07.2021 1/3 www.leiditech.com CDSOD323-T12C Electrical Characteristics(TA=25°C unless otherwise specified) Parameter Symbol Reverse Working Voltage Breakdown Voltage Test Condition Min Typ VRWM Max Unit 12.0 VBR IT = 1mA V 13.3 V Reverse Leakage Current IR VRWM = 12 V 0.2 µA Clamping Voltage VC IPP = 1A (8 x 20µs pulse) 18 V Clamping Voltage VC IPP = 12A (8 x 20µs pulse) 29 V Junction Capacitance CJ VR = 0V, f = 1MHz 1 pF Characteristic Curves 1 Voltage (V) Peak Power_Ppp(kW) 10 0.1 -20 0.01 0.1 1.0 10.0 Pulse Duration_tp(uS) 100 100 Ipp-Peak Pulse Current-%of Ipp % of Rated Power 120 80 60 40 20 0 50 75 100 125 150 60 80 100 80 60 40 20 0 -20 -20 Ambient Temperature_Ta(℃) 0 20 40 60 T-Time(us) Power Derating Curve Rev : 01.07.2021 40 IEC61000−4−2 Pulse Waveform 120 25 20 Time (nS) Peak Pulse Power vs. Pulse Time 0 0 100.0 8 X 20us Pulse Waveform 2/3 www.leiditech.com CDSOD323-T12C SOD-323 Package Outline Drawing DIMENSIONS SYM MILLIMETERS INCHES MIN MAX MIN MAX A 1.50 1.80 0.060 0.071 B 1.20 1.40 0.045 0.054 C 2.30 2.70 0.090 0.107 D - 1.10 - 0.043 E 0.30 0.40 0.012 0.016 F 0.10 0.25 0.004 0.010 H - 0.10 - 0.004 Suggested Land Pattern SYM DIMENSIONS MILLIMETERS INCHES A 3.15 0.120 B 0.80 0.031 C 0.80 0.031 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.07.2021 3/3 www.leiditech.com
CDSOD323-T12C 价格&库存
很抱歉,暂时无法提供与“CDSOD323-T12C”相匹配的价格&库存,您可以联系我们找货
