BXRC-30S4001-C-72
BXRC-30S4001-C-72
    BRIDGELUX
BXRC-30S4001-C-72 数据手册
® Bridgelux Gen 7 Vero18 Thrive™ Array Product Data Sheet DS327 1 | | | | | | BXRC-27S 30S 35S 40S 50S 57S 65S Vero® Thrive Introduction Bridgelux Thrive™ combines unique chip, phosphor and packaging technology to closely match the spectra of natural light over the visible wavelength range. Thrive can be used in constant color point luminaires to bring full spectrum natural light indoors or in tunable white luminaires to incorporate circadian elements that may impact human well-being. The high fidelity spectral output of Thrive creates stunning environments with excellent color rendering and outstanding TM30 metrics. Thrive is available in both SMD components and LED arrays to enable a broad range of lighting applications including retail, hospitality, office, education, architectural, museums, healthcare and residential lighting. Features Benefits • Engineered spectrum to closely match natural light • Full consistent spectrum with fewer spectral spikes • CRI >95, R1-R15 >90, high Rf and Rg values • Natural and vivid color rendering • High efficacy full spectrum solution • Greater energy savings, lower utility costs • No violet chip augmentation • Economical, high efficiency solution • Hot color targeted • Uniform and consistent white light at application conditions • Form factor consistent with existing Bridgelux COB arrays • Broad product platform availability (SMDs and COBs) • Ease of design and rapid go-to-market • Enables greater design flexibility and platform color consistency Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 European Product Registry for Energy Labeling 4 Performance at Commonly Used Drive Currents 5 Spectrum Characteristics 6 Electrical Characteristics 9 Absolute Maximum Ratings 10 Eye Safety 11 Product Bin Definitions 12 Performance Curves 13 Typical Radiation Pattern 14 Mechanical Dimensions 15 Packaging and Labeling 16 Design Resources 18 Precautions 18 Disclaimers 18 About Bridgelux 19 1 Product Feature Map Vero 18 is the second largest form factor in the Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero Series family of products. 2D Bar code provides full manufacturing traceability Thermally isolated solder pads reduce manufacturing cycle time and complexity Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Optics location/mounting features Mounting holes Radial die configuration improves lumen density and beam control Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Molex Pico-EZmate™ connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux COB arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 S 4001 – C – 7 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen 7 Array Configuration 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Flux Indicator 4001 = 4000 lm Minimum CRI S = Thrive 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tc= 25°C) CRI Nominal Drive Current3 (mA) Typical Vf (V) 2700 95 1170 34.4 3000 95 1170 34.4 Nominal CCT1 (K) BXRC-27S4001-C-7x BXRC-30S4001-C-7x Part Number1,6 2 Typical Pulsed Flux4,5,6,7 Tc = 25ºC (lm) Minimum Pulsed Flux6,7,8 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) 4226 3719 40.2 105 75.85 2.07 4508 3967 40.2 112 79.77 2.16 BXRC-35S4001-C-7x 3500 95 1170 34.4 5009 4408 40.2 125 80.93 2.17 BXRC-40S4001-C-7x 4000 95 1170 34.4 5231 4603 40.2 130 80.88 2.15 BXRC-50S4001-C-7x 5000 95 1170 34.4 5461 4806 40.2 136 85.76 2.26 BXRC-57S4001-C-7x 5700 95 1170 34.4 5508 4847 40.2 137 87.34 2.29 BXRC-65S4001-C-7x 6500 95 1170 34.4 5368 4724 40.2 134 85.58 2.23 Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) Table 2: Selection Guide, Stabilized DC Test Performance (Tc= 85°C)4,5,6 CRI Nominal Drive Current3 (mA) Typical Vf (V) Typical DC Flux4,5,6,7 Tc = 85ºC (lm) Minimum DC Flux6,7,8,9 Tc = 85ºC (lm) Typical Power (W) 2700 95 1170 33.7 3846 3384 39.4 98 69.03 1.92 3000 95 1170 33.7 4102 3610 39.4 104 72.59 2.00 Nominal CCT1 (K) BXRC-27S4001-C-7x BXRC-30S4001-C-7x Part Number 1,6 2 BXRC-35S4001-C-7x 3500 95 1170 33.7 4558 4011 39.4 116 73.64 2.02 BXRC-40S4001-C-7x 4000 95 1170 33.7 4760 4189 39.4 121 73.58 2.00 BXRC-50S4001-C-7x 5000 95 1170 33.7 4970 4373 39.4 126 78.04 2.10 BXRC-57S4001-C-7x 5700 95 1170 33.7 5012 4411 39.4 127 79.48 2.12 BXRC-65S4001-C-7x 6500 95 1170 33.7 4885 4299 39.4 124 77.88 2.07 Notes for Table 1 & 2: 1. Product CCT is hot targeted at Tj= 85°C. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are minimums. Bridgelux maintains a ± 3 tolerance on CRI values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 European Product Registry for Energy Labeling The European Product Registry for Energy Labeling (EPREL) is defined in the EU Regulation 2017/1369 to provide important energy efficiency information to consumers. Together with Energy Labeling Regulation ELR (EU) 2019/2015 which was amended by regulation (EU) 2021/340 for energy labelling of light sources, manufacturers are required to declare an energy class based on key technical specifications from each of their product and register it in an open data base managed by EPREL It is now a legal requirement for a vendor of light sources to upload information about their products into the EPREL database before placing these products on the market in the EU. Table 3 below provides a list of part numbers that are in compliance with ELR and are currently listed in the EPREL database. At Bridgelux, we are fully committed to supplying products that are compliant with pertinent laws, rules, and obligation imposed by relevant government bodies including the European Energy Labeling regulation. Customers can use these products with full confidence for any projects that fall under the ELR. Table 3: Part numbers registered in European Product Registry for Energy Labeling PART NUMBER1 CCT (K) CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database BXRC-27S4001-C-73 2700 97 460 30.6 1385 14.1 98 F 871237 https://eprel.ec.europa.eu/qr/871237 BXRC-30S4001-C-73 3000 97 650 31.2 2062 20.3 102 F 871583 https://eprel.ec.europa.eu/qr/871583 BXRC-35S4001-C-73 3500 97 820 31.7 2691 26.0 104 F 871738 https://eprel.ec.europa.eu/qr/871738 BXRC-40S4001-C-73 4000 97 900 31.9 2986 28.7 104 F 871992 https://eprel.ec.europa.eu/qr/871992 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 4 Performance at Commonly Used Drive Currents Vero Thrive LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero Thrive LED Arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 11 and the flux vs. current characteristics shown in Figure 12. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number BXRC-27S4001-C-73 BXRC-30S4001-C-73 BXRC-35S4001-C-73 BXRC-40S4001-C-73 BXRC-50S4001-C-73 BXRC-57S4001-C-73 BXRC-65S4001-C-73 CRI 95 95 95 95 95 95 95 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 33.2 18.8 2196 2024 117 780 33.6 26.2 2889 2655 110 1170 34.4 40.2 4226 3846 105 1755 35.6 61.8 6095 5470 99 2340 36.6 83.5 7876 5971 94 585 33.2 18.8 2343 2159 125 780 33.6 26.2 3082 2832 118 1170 34.4 40.2 4508 4102 112 105 1755 35.6 61.8 6501 5835 2340 36.6 83.5 8401 6369 101 585 33.2 18.8 2603 2399 138 780 33.6 26.2 3425 3147 131 1170 34.4 40.2 5009 4558 125 117 1755 35.6 61.8 7224 6484 2340 36.6 83.5 9335 7077 112 585 33.2 18.8 2718 2505 145 780 33.6 26.2 3576 3286 136 1170 34.4 40.2 5231 4760 130 122 1755 35.6 61.8 7543 6770 2340 36.6 83.5 9748 7390 117 585 33.2 18.8 2838 2616 151 780 33.6 26.2 3734 3431 143 1170 34.4 40.2 5461 4970 136 127 1755 35.6 61.8 7876 7069 2340 36.6 83.5 10178 7716 122 585 33.2 18.8 2862 2638 152 780 33.6 26.2 3766 3460 144 1170 1755 2340 34.4 35.6 36.6 40.2 61.8 83.5 5508 7943 10265 5012 7129 7782 137 129 123 585 33.2 18.8 2790 2571 148 780 33.6 26.2 3670 3372 140 1170 34.4 40.2 5368 4885 134 1755 35.6 61.8 7742 6948 125 2340 36.6 83.5 10004 7584 120 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Spectrum Characteristics Table 5: Typical Color Rendering Index and TM-30 Values at, Tc=85°C Nominal CCT1 Rf Rg R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 2700K 95 103 97 99 94 94 97 98 97 98 99 97 91 98 98 95 98 3000K 95 104 98 99 93 94 97 98 96 96 97 96 92 95 98 95 97 3500K 95 98 98 98 97 98 98 98 98 97 93 97 97 95 98 97 98 4000K 97 100 99 99 97 99 99 99 99 98 94 97 99 96 99 98 98 5000K 97 100 98 99 98 98 98 98 99 98 95 98 98 98 98 98 97 5700K 94 98 98 98 97 95 98 97 96 95 92 97 96 96 98 98 97 6500K 95 98 98 98 97 96 98 98 96 96 93 97 96 97 98 98 97 Note for Table 5: 1. Bridgelux maintains a tolerance of ± 3 on Color Rendering Index R1-R15 measurements and TM-30 measurements. 2. The data shown in the table above is for reference only.  Specific values from R1 to R15 will vary for each production run. Figure 1: 2700K Thrive TM-30 Graphs Figure 2: 3000K Thrive TM-30 Graphs Figure 3: 3500K Thrive TM-30 Graphs 6 Spectrum Characteristics Figure 4: 4000K Thrive TM-30 Graphs Figure 5: 5000K Thrive TM-30 Graphs Figure 6: 5700K Thrive TM30 Graphs Figure 7: 6500K Thrive TM-30 Graphs 7 Spectrum Characteristics Figure 8: Typical Color Spectrum 100% 2700K 3000K 3500K 4000K 100% 80% Relative Radiant Power(%) Relative Radiant Power (%) 120% 60% 40% 20% 0% 5000K 5700K 6500K 80% 60% 40% 20% 0% 380 430 480 530 580 630 680 730 780 350 400 Wavelength (nm) 450 500 550 600 650 700 750 800 Wavelength(nm) Note for Figure 8: 1. Color spectra measured at nominal current for Tj = 85°C. Table 6: Typical ASD Values at Tc = 85°C. Nominal CCT1 ASD 2700K 10% 3000K 9% 3500K 8% 4000K 8% 5000K 9% 5700K 9% 6500K 8% Figure 9: SPD Comparison Spectral Matching to Natural Light The lighting market is in the early stages of adoption of human-centric lighting (HCL). HCL encompasses the effects of lighting on the physical and emotional health and well-being of people. Throughout evolution, the human visual system has evolved under the natural light of sun and fire. These light sources have standardized industry spectral power definitions that describe the state of natural light. However, conventional metrics such as CCT, CRI, and TM-30 fail to adequately quantify the naturalness, or closeness of these light sources to the standardized natural spectra. Due to a lack of an industry standard metric to quantitatively measure the naturalness of a light source, Bridgelux has pioneered a new metric that takes the guesswork out of comparing LED light sources to natural light. Average Spectral Difference, or ASD, is calculated by measuring the absolute difference between two spectra at discrete wavelengths. These values are averaged across a wavelength range derived from the photopic response curve, or V(λ); a luminous efficiency function describing the average spectral sensitivity of human perception of brightness. The range of 425nm to 690nm was selected to remove the tails of the V(λ) gaussian distribution below 1% of the peak value at 555nm, covering 99.9% of the area under the photopic response curve. Natural light is defined following the approach of IES TM-30; black body curves for light sources of ≤4000K and the CIE standard illuminant D for light sources of ≥ 5000K. Natural light has an ASD of 0%; lower ASD values indicate a closer match to natural light. Thrive is engineered to provide the closest match to natural light available using proprietary chip, phosphor and packaging technology, resulting in an ASD between 8% to 10% for all CCTs. By comparison, standard 80, 90, and 98 CRI light sources have ASD values that are 100% to 300% larger than Thrive. To learn more about the ASD metric, please contact your Bridgelux sales representative. 8 Electrical Characteristics Table 7: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number Drive Current (mA) Minimum BXRC-xxx4001-C-7x Typical Maximum Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 1170 32.2 34.4 37.4 -14.5 0.11 31.1 38.4 2340 34.2 36.6 39.8 -14.5 0.13 33.5 41.2 Notes for Table 7: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 9 Absolute Maximum Ratings Table 8: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds Maximum Drive Current3 2340mA Maximum Peak Pulsed Drive Current4 3340mA Maximum Reverse Voltage5 -60V Notes for Table 8: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN31: Handling and Assembly of Vero, Vero SE and Vesta SE LED Modules. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 10 Eye Safety Table 9: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx4001-C-7x CCT1,4 Drive Current 4 (mA) 2700K/3000K 4000K 5000K2 6500K3 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG1 RG2 RG2 Notes for Table 9: 1. Eye safety classification for the use of Bridgelux Vero Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 3. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 4. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 11 Product Bin Definitions Table 10: 2-, 3- and 4-step MacAdam Ellipse Color Bin Definitions Center Point Degree 2-step 3-step 4-step CCT x y Φ(°) a b a b a b 2700K 0.4570 0.4120 53.700 0.00540 0.00280 0.0081 0.0042 N/A N/A 3000K 0.4333 0.4048 53.217 0.00556 0.00272 0.0083 0.0041 N/A N/A 4000K 0.3828 0.3819 53.717 0.00626 0.00268 0.0094 0.0040 N/A N/A 5000K 0.3454 0.3586 59.617 N/A N/A 0.0082 0.0035 0.0110 0.0047 5700K 0.3308 0.3464 59.060 N/A N/A 0.0074 0.0032 0.0099 0.0042 6500K 0.3149 0.3334 58.567 N/A N/A 0.0066 0.0028 0.0090 0.0038 Notes for Table 10: 1. Color binning at Tc=85°C 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Figure 10: C.I.E. 1931 Chromaticity Diagram (Color targeted at Tc=85°C) 0.44 0.39 3 SDCM 4 SDCM 2 SDCM 0.38 2700K 3 SDCM 0.42 3000K 0.37 3500K 5000K 0.36 0.4 5700K 0.35 Y Y 4000K 0.38 6500K 0.34 0.33 0.36 0.32 0.34 0.36 0.31 0.39 0.42 0.45 X 0.48 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 0.37 X 12 Performance Curves Figure 12: Vero18C Typical Relative Flux vs. Current (Tc=25°C) Figure 11: Vero18C Drive Current vs. Voltage (Tc=25°C) 2500 200% 250% 2000 160% 200% Relative Luminus Relative Luminous FluxFlux Current (mA) 180% 1500 100% 100% 1000 500 0 140% 150% 120% 80% 60% 50% 40% 20% 0% 33 34 35 36 0% 37 Forward Voltage (V) 0 100 500 400 700 1000 1000 1500 1300 2000 1600 2500 1900 Forward Current (mA) 3000 2200 3500 2500 Forward Current (mA) Figure 13: Typical DC Flux vs. Case Temperature Figure 14: Typical ccx Shift vs. Case Temperature 105% 0.0030 100% 0.0020 95% 0.0010 Neutral White Cool White ccx Shift Relative Luminus Flux Warm White 90% Warm White Neutral White Cool White 85% 80% 0 25 0.0000 -0.0010 -0.0020 50 75 100 0 Case Temperature (°C) 25 50 75 Case Temperature (°C) 100 Figure 15: Typical ccy Shift vs. Case Temperature 0.000 Notes for Figures 13-15: -0.001 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. ccy Shift 2. Characteristics shown for warm white based on 3000K Thrive -0.002 3. Characteristics shown for neutral white based on 4000K Thrive 4. Characteristics shown for cool white based on 5700K Thrive -0.003 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Warm White -0.004 Neutral White Cool White -0.005 0 25 50 75 100 125 Case Temperature (°C) 13 Typical Radiation Pattern Figure 16: Typical Spatial Radiation Pattern Notes for Figure 16: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 17: Typical Polar Radiation Pattern 14 Mechanical Dimensions Figure 18: Drawing for Vero 18 LED Array Notes for Figure 18: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 15 Packaging and Labeling Figure 19: Drawing for Vero 18 Packaging Tray Notes for Figure 19: 1. Dimensions are in millimeters. 2. Drawing is not to scale. 16 Packaging and Labeling Figure 20: Vero Series Packaging and Labeling Notes for Figure 20: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 21: Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number Internal Bridgelux use only. 17 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 18 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/bridgelux-inc-_2 youtube.com/user/Bridgelux WeChat ID: BridgeluxInChina 46410 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. Thrive is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 Vero18 Thrive Array Product Data Sheet DS327 Rev. A (03/2022) 19
BXRC-30S4001-C-72 价格&库存
很抱歉,暂时无法提供与“BXRC-30S4001-C-72”相匹配的价格&库存,您可以联系我们找货
