BXRC-50C2000-C-24
BXRC-50C2000-C-24
    BRIDGELUX(普瑞)
    LED ARRAY 2000LM COOL WHITE COB
BXRC-50C2000-C-24 数据手册
Bridgelux Vero 13 Array Series ® ® Product Data Sheet DS31 BXRC-27x2000 | 30x2000 | 35x2000 | 40x2000 | 50x2000 Vero Introduction Vero represents a revolutionary advancement in chip on board (COB) light source technology and innovation. Vero LED light sources simplify luminaire design and manufacturing processes, improve light quality, and define a platform for future functionality integration. Vero is available in four different light emitting surface (LES) configurations and has been engineered to reliably operate over a broad current range, enabling new degrees of flexibility in luminaire design optimization. Vero arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero includes an on board connector port to enable solder free electrical interconnect and simple easy to use mounting features to enable plug-and-play installation. Features • Efficacy of 130 lm/W typical • Vero 13 lumen output performance ranges from 600 to 4,301 lumens • Broad range of CCT options from 2700K to 5000K • CRI options include; minimum 70, 80, and 90 • 2 and 3 SDCM color control for 2700K-4000K CCT • Reliable operation at up to 2X nominal drive current • Radial die pattern and improved lumen density • Thermally isolated solder pads • Onboard connector port • Top side part number markings Benefits • Broad application coverage for interior and exterior lighting • Flexibility for application driven lighting design requirements • High quality true color reproduction • Uniform consistent white light • Flexibility in design optimization • Improved optical control • Enhanced ease of use and manufacturability • Solderless connectivity enables plug & play installation and field upgradability • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 4 Electrical Characteristics 6 Absolute Maximum Ratings 7 Performance Curves 8 Typical Radiation Pattern 11 Typical Color Spectrum 12 Mechanical Dimensions 13 Color Binning Information 14 Packaging 15 Design Resources 17 Precautions 17 Disclaimers 17 About Bridgelux 18 1 Product Feature Map Vero 13 is the second smallest form factor in the Vero family of the next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero family of products. 2D Bar code provides full manufacturing traceability Thermally isolated solder pads reduce manufacturing cycle time and complexity Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Optics location/mounting features Correlates to the true case temperature on the back surface of the LED array Mounting holes Radial die configuration improves lumen density and beam control Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Molex Pico-EZmate™ connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 2000 – C – 23 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K CCT Bin Options 22 = 2 SDCM 23 = 3 SDCM 24 = 4 SDCM Array Configuration Minimum CRI C = 70 CRI E = 80 CRI G = 90 CRI Flux Indicator 2000 = 2000lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E2000-C-2X 2700 80 500 2039 1935 32.3 16.2 126 BXRC-27G2000-C-2X 2700 90 500 1696 1576 32.3 16.2 105 BXRC-30E2000-C-2X 3000 80 500 2133 1947 32.3 16.2 132 BXRC-30G2000-C-2X 3000 90 500 1785 1605 32.3 16.2 111 BXRC-35E2000-C-2X 3500 80 500 2187 2000 32.3 16.2 135 BXRC-35G2000-C-2X 3500 90 500 1868 1776 32.3 16.2 116 BXRC-40E2000-C-2X 4000 80 500 2262 2114 32.3 16.2 140 BXRC-40G2000-C-2X 4000 90 500 1928 1786 32.3 16.2 119 BXRC-50C2000-C-24 5000 70 500 2394 2245 32.3 16.2 148 BXRC-50E2000-C-24 5000 80 500 2252 2114 32.3 16.2 139 BXRC-50G2000-C-24 5000 90 500 2015 1809 32.3 16.2 125 Minimum DC Flux10 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 8,9 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux Tc = 85ºC (lm) BXRC-27E2000-C-2X 2700 80 500 1867 1772 31.3 15.6 119 BXRC-27G2000-C-2X 2700 90 500 1492 1387 31.3 15.6 95 BXRC-30E2000-C-2X 3000 80 500 1921 1754 31.3 15.6 123 BXRC-30G2000-C-2X 3000 90 500 1571 1412 31.3 15.6 100 BXRC-35E2000-C-2X 3500 80 500 1981 1811 31.3 15.6 127 BXRC-35G2000-C-2X 3500 90 500 1644 1563 31.3 15.6 105 BXRC-40E2000-C-2X 4000 80 500 2040 1907 31.3 15.6 130 BXRC-40G2000-C-2X 4000 90 500 1697 1572 31.3 15.6 108 BXRC-50C2000-C-24 5000 70 500 2107 1976 31.3 15.6 135 BXRC-50E2000-C-24 5000 80 500 1982 1860 31.3 15.6 127 BXRC-50G2000-C-24 5000 90 500 1773 1592 31.3 15.6 113 Notes for Tables 1 & 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 10. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 1 and the flux vs. current characteristics shown in Figure 2. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRC-27E2000-C-2x BXRC-27G2000-C-2x BXRC-30E2000-C-2x BXRC-30G2000-C-2x BXRC-35E2000-C-2x BXRC-35G2000-C-2x CRI 80 90 80 90 80 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 30.2 5.3 781 715 148 350 31.4 11.0 1488 1361 135 500 32.3 16.2 2039 1867 126 700 33.4 23.4 2705 2484 116 1050 35.1 36.9 3663 3382 99 175 30.2 5.3 650 572 123 350 31.4 11.0 1237 1088 113 500 32.3 16.2 1696 1492 105 700 33.4 23.4 2250 1985 96 1050 35.1 36.9 3047 2703 83 175 30.2 5.3 817 736 155 350 31.4 11.0 1556 1400 142 500 32.3 16.2 2133 1921 132 700 33.4 23.4 2830 2556 121 1050 35.1 36.9 3832 3480 104 175 30.2 5.3 684 602 129 350 31.4 11.0 1302 1145 119 500 32.3 16.2 1785 1571 111 700 33.4 23.4 2368 2090 101 1050 35.1 36.9 3207 2845 87 175 30.2 5.3 838 759 159 350 31.4 11.0 1596 1444 145 500 32.3 16.2 2187 1981 135 700 33.4 23.4 2902 2635 124 1050 35.1 36.9 3929 3587 107 175 30.2 5.3 716 630 135 350 31.4 11.0 1363 1198 124 500 32.3 16.2 1868 1644 116 700 33.4 23.4 2479 2187 106 1050 35.1 36.9 3356 2977 91 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRC-40E2000-C-2x BXRC-40G2000-C-2x BXRC-50C2000-C-24 BXRC-50E2000-C-24 BXRC-50G2000-C-24 CRI 80 90 70 80 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 30.2 5.3 867 781 164 350 31.4 11.0 1650 1487 150 500 32.3 16.2 2262 2040 140 700 33.4 23.4 3001 2714 128 1050 35.1 36.9 4064 3695 110 175 30.2 5.3 739 650 140 350 31.4 11.0 1407 1237 128 500 32.3 16.2 1928 1697 119 700 33.4 23.4 2558 2257 109 1050 35.1 36.9 3464 3073 94 175 30.2 5.3 917 807 174 350 31.4 11.0 1747 1536 159 500 32.3 16.2 2394 2107 148 700 33.4 23.4 3176 2803 136 1050 35.1 36.9 4301 3816 117 175 30.2 5.3 863 759 163 350 31.4 11.0 1643 1444 150 500 32.3 16.2 2252 1982 139 700 33.4 23.4 2988 2636 128 1050 35.1 36.9 4046 3589 110 175 30.2 5.3 772 679 146 350 31.4 11.0 1470 1292 134 500 32.3 16.2 2015 1773 125 700 33.4 23.4 2674 2359 114 1050 35.1 36.9 3620 3212 98 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Minimum Typical Maximum 500 29.9 32.3 34.7 -17 1050 32.0 35.1 37.9 -17 Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.22 28.5 35.8 0.28 30.6 39.0 BXRC-xxx2000-C-2x Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 6 Absolute Maximum Ratings Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 350°C or lower for a maximum of 10 seconds Maximum Drive Current3,4,5 1050mA Maximum Peak Pulsed Drive Current6 1500mA Maximum Reverse Voltage7 -55V Notes for Table 5: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN31: Assembly Considerations for Bridgelux Vero LED Arrays. 3. DC Forward Current for LM-80 is the maximum drive current for which LM-80 data is currently available. 4. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these arrays. Contact your Bridgelux sales representatives for LM-80 report. 5. Arrays may be driven at higher currents however lumen maintenance may be reduced. 6. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 7. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 7 Performance Curves Figure 1: Drive Current vs. Voltage (Tj = Tc = 25°C) Figure 2: Typical Relative Luminous Flux vs. Current (Tj = Tc = 25°C) Note for Figure 2: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 8 Performance Curves Figure 3: Typical DC Flux vs. Case Temperature Figure 4: Typical DC ccy Shift vs. Case Temperature Notes for Figures 3-4: 1. 2. 3. 4. Characteristics shown for warm white based on 3000K and 80 CRI. Characteristics shown for neutral white based on 4000K and 80 CRI. Characteristics shown for cool white based on 5000K and 70 CRI. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 9 Performance Curves Figure 5: Typical DC ccx Shift vs. Case Temperature Notes for Figure 5: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 10 Typical Radiation Pattern Figure 6: Typical Spatial Radiation Pattern Note for Figure 6: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 7: Typical Polar Radiation Pattern 11 Typical Color Spectrum Figure 8: Typical Color Spectrum Note for Figure 8: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 12 Mechanical Dimensions Figure 9: Drawing for Vero 13 LED Array Notes for Figure 9: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 13 Color Binning Information Figure 10: Graph of Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 6: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 23 (3SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 22 (2SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 11: Graph of Cool White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5600K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) 24 (4SDCM) (4801K - 5282K) (5475K - 5830K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) 14 Packaging and Labeling Figure 12: Drawing for Vero 13 Packaging Tray Notes for Figure 12: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 15 Packaging and Labeling Figure 13: Vero Series Packaging and Labeling Notes for Figure 13: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 14: Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number Internal Bridgelux use only. 16 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vero LED arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. Vero LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 17 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux WeChat ID: BridgeluxInChina 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8410 www.bridgelux.com © 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vero 13 Array Series Product Data Sheet DS31 Rev. L (06/2016) 18
BXRC-50C2000-C-24 价格&库存
很抱歉,暂时无法提供与“BXRC-50C2000-C-24”相匹配的价格&库存,您可以联系我们找货
