BXEB-L0560F-30G2000-S-C3
    BRIDGELUX(普瑞)
BXEB-L0560F-30G2000-S-C3 数据手册
Bridgelux EB Series™ Gen 3 F90 ® Product Data Sheet DS13x Lengths: 140mm, 280mm, 560mm, 1120mm CRI: 90 CCTs: 2700K, 3000K, 3500K, 4000K, 5000K Product Feature Map Bridgelux EB Series Gen 3 modules are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The linear products incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the EB Series family of products. Multiple case temperature measurement points Label containing part number and lot codes is attached on the front of the module where shown Re-usable connector Designed to comply with global safety standards for creepage and clearance distances Zhaga compatible mounting holes Product Nomenclature The part number designation for Bridgelux EB Series Gen 3 F90 is explained as follows: 1 2 3 4 - 5 6 7 8 9 10 - 11 12 13 14 15 16 - 17 – 18 BXEB – L0280F – 30 G 1000 – S – C3 Product Family Nominal Dimensions L= Linear 0140 = 140 mm 0280 = 280 mm 0560 = 560 mm 1120 = 1120 mm F= F90 LED Module Version C = Gen 3 3 = 3 SDCM LED Type Nominal CCT 27 = 2700 K 30 = 3000 K 35 = 3500 K 40 = 4000 K 50 = 5000 K Minimum CRI G = 90 Flux Indicator 0500 = 500 lm 1000 = 1000 lm 2000 = 2000 lm 4000 = 4000 lm 2 Product Selection Guide Table 1: Product Performance (Tc = 45° C) Part Number Nominal 1 CCT (K) Typical Flux2,3 CRI Tc = 45º C (lm) Nominal Drive Current (mA) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXEB-L0140F-27G0500-S-C3 2700 90 495 165 BXEB-L0140F-30G0500-S-C3 3000 90 501 167 BXEB-L0140F-35G0500-S-C3 3500 90 504 BXEB-L0140F-40G0500-S-C3 4000 90 516 172 BXEB-L0140F-50G0500-S-C3 5000 90 516 172 BXEB-L0280F-27G1000-S-C3 2700 90 990 165 BXEB-L0280F-30G1000-S-C3 3000 90 1002 167 BXEB-L0280F-35G1000-S-C3 3500 90 1008 BXEB-L0280F-40G1000-S-C3 4000 90 1032 BXEB-L0280F-50G1000-S-C3 5000 90 1032 172 BXEB-L0560F-27G2000-S-C3 2700 90 1964 165 BXEB-L0560F-30G2000-S-C3 3000 90 1987 167 BXEB-L0560F-35G2000-S-C3 3500 90 1999 BXEB-L0560F-40G2000-S-C3 4000 90 2047 172 BXEB-L0560F-50G2000-S-C3 5000 90 2047 172 BXEB-L1120F-27G4000-S-C3 2700 90 3927 165 BXEB-L1120F-30G4000-S-C3 3000 90 3975 167 BXEB-L1120F-35G4000-S-C3 3500 90 3998 BXEB-L1120F-40G4000-S-C3 4000 90 4093 172 BXEB-L1120F-50G4000-S-C3 5000 90 4093 172 3.0 87 277 68 154 6.0 616 168 172 38.5 308 168 11.9 23.8 168 168 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. Data is at nominal test current where temperature of center case temperature point Tc= 45° C. 3. Bridgelux maintains a ± 7% tolerance on flux data. 3 Electrical Characteristics Table 2: Electrical Characteristics Forward Voltage Part Number Drive Current (mA) Minimum Typical Maximum BXEB-L0140F-xxx0500-S-C3 77 38.0 38.5 39.0 BXEB-L0280F-xxx1000-S-C3 154 38.0 38.5 39.0 BXEB-L0560F-xxx2000-S-C3 308 38.0 38.5 39.0 BXEB-L1120F-xxx4000-S-C3 616 38.0 38.5 39.0 Tc2 = 45º C (V) 1, 2,3 Notes for Table 2: 1. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a tolerance of ± 0.1 V on forward voltage data. 3. This product has been designed and manufactured per IEC 62031:2014. The working voltage designated for the insulation is 60 V d.c. The maximum allowable voltage across the module must be determined in the end product application. 4. Typical coefficient of forward voltage tolerance is ± 0.1 mV for nominal current. 5. Vf min hot and max cold values are provided as reference only and are not guaranteed. These values are provided to aid in driver design and selection over the operating range of the product. 4 Absolute Maximum Ratings Table 3: Maximum Ratings Parameter Maximum Rating Storage Temperature -40°C to +85°C Operating Case Temperature2 (Tc) 85°C Soldering Temperature 350°C or lower for a maximum of 5 seconds Maximum Reverse Voltage Modules are not designed to be driven in reverse bias Maximum Drive Current BXEB-L0140F-xxx0500-S-C3 BXEB-L0280F-xxx1000-S-C3 BXEB-L0560F-xxx2000-S-C3 BXEB-L1140F-xxx4000-S-C3 154mA 308mA 616mA 1232mA Notes for Table 3: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the SMDs used in the modules. Contact your Bridgelux sales representatives for LM-80 report. 5 Performance Curves Figure 1: Relative Forward Current vs. Forward Voltage, Tc=25°C Relative Forward Current (%) 250% 200% 150% 100% 50% 0% 36.0 37.0 38.0 39.0 40.0 41.0 42.0 Forward Voltage (V) Figure 2: Relative Luminous Flux vs. Relative Forward Current, Tc=25°C 200% Relative Luminous Flux (%) 180% 160% 140% 120% 100% 80% 60% 40% 20% 0% 0% 50% 100% 150% 200% 250% Relative Forward Current (V) 6 Performance Curves Figure 3: Relative Voltage vs. Case Temerature 101.0% Relative Voltage (%) 100.5% 100.0% 99.5% 99.0% 98.5% 98.0% 97.5% 97.0% 96.5% 0 20 40 60 80 100 Case Temperature (°C) Figure 4: Relative Luminous Flux vs. Case Temperature 103% Relative Luminous Flux (%) 101% 99% 97% 95% 93% 91% 89% 87% 85% 0 20 40 60 80 100 Case Temperature (°C) 7 Typical Radiation Pattern Figure 5: Typical Spatial Radiation Pattern 120% Relative Intensity 100% 80% 60% 40% 20% 0% -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (°) Notes for Figure 5: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. 8 Typical Color Spectrum Figure 6: Typical Color Spectra, 90 CRI Note for Figures 5& 6: 1. Color spectra measured at nominal current for Tc = 85°C 9 Mechanical Dimensions Figure 7: Drawing for EB Series Gen3 F90 140mm Table 4: Dimensions for 140mm Parameter Specification Unit Linear length 140 mm Linear width 20 mm Linear thickness 6.1 mm PCB thickness 1.6 mm Figure 8: Drawing for EB Series Gen3 F90 280mm Table 5: Dimensions for 280mm Parameter Specification Unit Linear length 280 mm Linear width 20 mm Linear thickness 6.1 mm PCB thickness 1.6 mm 10 Mechanical Dimensions Figure 9: Drawing for EB Series Gen3 F90 560mm Table 6: Dimensions for 560mm Parameter Specification Unit Linear length 560 mm Linear width 20 mm Linear thickness 6.1 mm PCB thickness 1.6 mm 11 Mechanical Dimensions Figure 10: Drawing for EB Series F90 Gen3 1120mm Notes for Figures 7, 8, 9 & 10. 1. Solder pads are labeled “+” to denote positive polarity, and “-” to denote negative polarity. 2. Drawings are not to scale. 3. Drawing dimensions are in millimeters. 4. Refer to Bridgelux assembly drawing 15-000682, 15-000683, and 15-000684 for complete product configuration Table 6: Dimensions for 1120mm Parameter Specification Unit Linear length 1120 mm Linear width 20 mm Linear thickness 6.1 mm PCB thickness 1.6 mm Table 7: Connector and wiring Parameter Specification Input wire cross-section 18-24 AWG Wire strip length 7-9 mm 12 Color Binning Information Figure 11: Graph of Warm and Neutral White Test Bins in xy Color Space 2700K 3 SDCM 0.43 3000K 3 SDCM 3500K 3 SDCM 0.41 CIE_Y 4000K 3 SDCM 0.39 0.37 0.35 0.36 0.39 0.42 0.45 0.48 CIE_X Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500 K 4000K B3 (3 SDCM) CCT Range 2651K - 2794K 2968K - 3136K 3369K - 3586K 3851K - 4130K Center Point (x, y) (0.458, 0.410) (0.434, 0.403) (0.407, 0.392) (0.382, 0.380) ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) Figure 12: Graph of Cool White Test Bins in xy Color Space Table 9: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5700K B3 (3 SDCM) CCT Range 4835K - 5215K 5490K - 5820K Center Point (x, y) (0.3445, 0.355) (0.329, 0.342) ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) Notes for Tables 8 and 9 1. Color binning at solder point temperature Tsp of SMDs at 85°C. 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. 13 Packaging and Labeling Figure 13: EB Series Packaging and Labeling Table 10: Packaging Structure L0280 modules Tray Box Quantity 40 200 Dimension 63 cm x 39 cm x 2.4 cm 65.5 cm x 41.5 cm x 15.5 cm L0560 modules Tray Box Quantity 20 100 Dimension 63 cm x 39 cm x 2.4 cm 65.5 cm x 41.5 cm x 15.5 cm L1120 modules Tray Box Quantity 20 100 Dimension 119 cm x 39 cm x 2.4 cm 134 cm x 44 cm x 18.5 cm Figure 14: Product Labeling Bridgelux EB Series modules contain a label on the front to help with product identification. In addition to the product identification markings, Bridgelux EB Series modules also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the module. EB Series Gen3 1ft 1000lm 350mA Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. 14 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the EB Series product family. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux EB Series LED linears are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED linear. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux EB Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. EB Series linears are classified as Risk Group 1 when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the linear or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the linear. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the EB Series linear. Use the mechanical features of the linear housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the EB Series linears during operation. Allow the linear to cool for a sufficient period of time before handling. The EB Series linears may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, linear testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 15 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 USA Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. EB Series and Bridging Light and Life are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux EB Series Gen3 Data Sheet DS132 Rev. B (01/2021) 16
BXEB-L0560F-30G2000-S-C3 价格&库存
很抱歉,暂时无法提供与“BXEB-L0560F-30G2000-S-C3”相匹配的价格&库存,您可以联系我们找货
