BXEB-L0590U-27G1500-C-C3
    BRIDGELUX(普瑞)
BXEB-L0590U-27G1500-C-C3 数据手册
Bridgelux EB Series™ Slim Gen 3 ® Product Data Sheet DS171 EB Series™ Introduction EB Slim Gen 3 linear modules are designed for use in premium indoor applications where high efficacy is required. The new generation uses the high-efficacy SMDs to achieve over 200lm/W, which enables designers and fixture manufacturers to meet DLC Premium requirements. They are designed for linear troffers, pendants and other luminaires in indoor commercial applications. Available in 340 mm, 590 mm, and 1190 mm lengths, the modules can be connected end-to-end thereby providing flexibility in designing luminaires. The “slim” width of the module enables easy integration into space constrained luminaires. These modules are easily mountable and offer reusable poke-in connectors. The modules have long lifetimes of greater than 50,000 hours. Features Benefits • High efficacy of up to 200 lm/W (nominal) • Achieve over 200 lm/W by under-driving • Available in both 80 CRI and 90 CRI • • Available in a variety of color temperatures from 2700K to 5700K Heat-sinking may not be required at low drive currents • Reliable use at elevated currents for greater design flexibility • Easy installation using mounting holes and poke-in connectors • Wide lumen range with 2.4x overdrive capability • Long lifetime (L80, B50 > 50,000 hours) Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Electrical Characteristics 4 Absolute Maximum Ratings 5 Performance Curves 6 Typical Radiation Pattern 8 Typical Color Spectrum 9 Mechanical Dimensions 10 Color Binning Information 12 Packaging and Labeling 13 Design Resources 14 Precautions 14 Disclaimers 14 About Bridgelux 15   1 Product Feature Map Bridgelux EB Series Slim Gen 3 modules are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The linear products incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the EB Series family of products. Slim 12.7mm width for narrow slots Re-usable connector Mounting locations Designed to comply with global safety standards for creepage and clearance distances Multiple case temperature measurement points Product Nomenclature The part number designation for Bridgelux EB Slim Gen 3 is explained as follows: 1 2 3 4 - 5 6 7 8 9 10 - 11 12 13 14 15 16 - 17 – 18 BXEB – L0340U – 30 E 0750 – C – C3 Product Family Nominal Dimensions L= Linear 0340 = 340 mm 0590 = 590 mm 1190 = 1190 mm U= Width (12.7 mm) Module Version C = Gen 3 3 = 3 SDCM Module Configuration Nominal CCT 27 = 2700 K 30 = 3000 K 35 = 3500 K 40 = 4000 K 50 = 5000 K 57 = 5700 K Minimum CRI E = 80 G = 90 Flux Indicator 0750 = 0750 lm 1500 = 1500 lm 3000 = 3000 lm 2 Product Selection Guide Table 1: Product Performance (Tc = 25° C) Part Number BXEB-L0340U-27E0750-C-C3 BXEB-L0340U-27G0750-C-C3 BXEB-L0340U-30E0750-C-C3 BXEB-L0340U-30G0750-C-C3 BXEB-L0340U-35E0750-C-C3 BXEB-L0340U-35G0750-C-C3 BXEB-L0340U-40E0750-C-C3 BXEB-L0340U-40G0750-C-C3 BXEB-L0340U-50E0750-C-C3 BXEB-L0340U-50G0750-C-C3 BXEB-L0340U-57E0750-C-C3 BXEB-L0340U-57G0750-C-C3 BXEB-L0590U-27E1500-C-C3 BXEB-L0590U-27G1500-C-C3 BXEB-L0590U-30E1500-C-C3 BXEB-L0590U-30G1500-C-C3 BXEB-L0590U-35E1500-C-C3 BXEB-L0590U-35G1500-C-C3 BXEB-L0590U-40E1500-C-C3 BXEB-L0590U-40G1500-C-C3 BXEB-L0590U-50E1500-C-C3 BXEB-L0590U-50G1500-C-C3 BXEB-L0590U-57E1500-C-C3 BXEB-L0590U-57G1500-C-C3 BXEB-L1190U-27E3000-C-C3 BXEB-L1190U-27G3000-C-C3 BXEB-L1190U-30E3000-C-C3 BXEB-L1190U-30G3000-C-C3 BXEB-L1190U-35E3000-C-C3 BXEB-L1190U-35G3000-C-C3 BXEB-L1190U-40E3000-C-C3 BXEB-L1190U-40G3000-C-C3 BXEB-L1190U-50E3000-C-C3 BXEB-L1190U-50G3000-C-C3 BXEB-L1190U-57E3000-C-C3 BXEB-L1190U-57G3000-C-C3 Nominal Min 1 CRI CCT (K) 2700 3000 3500 4000 5000 5700 2700 3000 3500 4000 5000 5700 2700 3000 3500 4000 5000 5700 Typical Flux2,3 Tc = 25º C (lm) Nominal Drive Current (mA) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 80 1360 178 90 1190 156 80 1425 186 90 1255 164 80 1425 186 90 1255 80 1530 90 1255 164 80 1530 200 90 1255 164 80 1530 200 700 10.9 7.6 164 200 90 1255 164 80 2380 178 90 2085 156 80 2490 186 90 2195 164 80 2490 186 90 2195 80 2675 700 19.1 13.4 164 200 90 2195 164 80 2675 200 90 2195 164 80 2675 200 90 2195 164 80 4760 178 90 4160 155 80 4980 186 90 4390 164 80 4980 186 90 4390 80 5350 700 38.2 26.8 164 200 90 4390 164 80 5350 200 90 4390 164 80 5350 200 90 4390 164 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. Data is at nominal test current where temperature of center case temperature point Tc= 25° C. 3. Bridgelux maintains a ± 7% tolerance on flux data. 3 Electrical Characteristics Table 2: Electrical Characteristics Forward Voltage Tc2 Part Number Driver Selection Typical Coefficient of Forward = 25º C (V) 1, 2,3 Drive Current (mA) Voltages5 (V) Voltage4 Minimum Typical Maximum ∆Vf/∆T (mV/º C) Vf Min, Hot Tc2 = 85º C (V) Vf Max, Cold Tc2 = -40º C (V) 700 10.1 10.9 11.7 -4.1 9.9 11.9 1700 11.0 11.8 12.6 -4.1 10.7 12.9 700 17.8 19.1 20.4 -7.2 17.3 20.9 1700 19.3 20.7 22.1 -7.2 18.8 22.6 700 35.5 38.2 40.9 -14.3 34.7 41.8 1700 38.6 41.5 44.4 -14.3 37.7 45.3 BXEB-L0340U-xxx0750-C-C3 BXEB-L0590U-xxx1500-C-C3 BXEB-L1190U-xxx3000-C-C3 Notes for Table 2: 1. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a tolerance of ± 0.1 V on forward voltage data. 3. This product has been designed and manufactured per IEC 62031:2014. The working voltage designated for the insulation is 60 V d.c. The maximum allowable voltage across the module must be determined in the end product application. 4. Typical coefficient of forward voltage tolerance is ± 0.1 mV for nominal current. 5. Vf min hot and max cold values are provided as reference only and are not guaranteed. These values are provided to aid in driver design and selection over the operating range of the product. 4 Absolute Maximum Ratings Table 3: Maximum Ratings Parameter Maximum Rating Storage Temperature -40°C to +85°C Operating Case Temperature2 (Tc) 85°C Soldering Temperature 350°C or lower for a maximum of 5 seconds Maximum Reverse Voltage Modules are not designed to be driven in reverse bias Maximum Drive Current 1700mA Notes for Table 3: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the SMDs used in the modules. Contact your Bridgelux sales representatives for LM-80 report. 5 Performance Curves Figure 1: 340mm Current vs. Forward Voltage, Tc=25°C Figure 2: 340mm Relative Flux vs. Current, Tc=25°C 1800 250.0% Relative Luminous Flux (%) Forward Current (mA) 1600 1400 1200 1000 800 600 400 200 0 10.0 11.0 11.5 Forward Voltage (V) 100.0% 50.0% 12.0 0 500 1000 1500 Forward Current (mA) 2000 Figure 4: 590mm Relative Flux vs. Current, Tc=25°C 250.0% 1800 Relative Luminous Flux (%) 1600 Forward Current (mA) 150.0% 0.0% 10.5 Figure 3: 590mm Current vs. Forward Voltage, Tc=25°C 1400 1200 1000 800 600 400 200 200.0% 150.0% 100.0% 50.0% 0.0% 0 17.0 18.0 19.0 20.0 Forward Voltage (V) 0 21.0 Figure 5: 1190mm Current vs. Forward Voltage, Tc=25°C 2000 250.0% Relative Luminous Flux (%) 1400 1200 1000 800 600 400 200 0 35.0 500 1000 1500 Forward Current (mA) Figure 6: 1190mm Relative Flux vs. Current, Tc=25°C 1800 1600 Forward Current (mA) 200.0% 200.0% 150.0% 100.0% 50.0% 0.0% 37.0 39.0 41.0 Forward Voltage (V) 43.0 0 500 1000 1500 Forward Current (mA) 2000 6 Performance Curves Figure 7: Relative Voltage vs. Case Temperature Figure 8: Relative Flux vs. Case Temperature 100.5% 102.0% 100.0% 100.0% 25°C Pulsed Relative Flux (%) Relative Voltage (%) 25°C Pulsed 99.5% 99.0% 98.5% 98.0% 96.0% 94.0% 92.0% 98.0% 90.0% 97.5% 0 20 40 60 Case Temperature (C) 80 100 0 20 40 60 Case Temperature (C) 80 100 7 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern 120% Relative Intensity 100% 80% 60% 40% 20% 0% -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (°) Notes for Figure 9: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. 8 Typical Color Spectrum Figure 10: Typical Color Spectra, 80 CRI 100% 90% 80% Relative Intensity 70% 27E 60% 30E 50% 35E 40E 40% 50E 57E 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Figure 11: Typical Color Spectra, 90 CRI 100% 90% 80% Relative Intensity 70% 27G 60% 30G 50% 35G 40G 40% 50G 57G 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Note for Figures 10 & 11: 1. Color spectra measured at nominal current for Tc = 85°C 9 Mechanical Dimensions Figure 12: Drawing for BXEB-L0340U-xxx0750-C-C3 Figure 13: Drawing for BXEB-L0590U-xxx1500-C-C3 10 Mechanical Dimensions Figure 14: Drawing for BXEB-L1190U-xxx3000-C-C3 Notes for Figures 12, 13 & 14: 1. Solder pads are labeled “+” to denote positive polarity, and “-” to denote negative polarity. 2. Drawings are not to scale. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, the tolerances are ± 0.10mm.. Table 4: Module dimensions Part Number Board Length Board Width BXEB-L0340U-xxx0750-C-C3 340 mm 12.7 mm BXEB-L0590U-xxx1500-C-C3 590 mm 12.7 mm BXEB-L1190U-xxx3000-C-C3 1190 mm 12.7 mm Table 5: Connector and wiring Parameter Specification Input wire cross-section 20-24 AWG Wire strip length 6.5-7.5 mm 11 Color Binning Information Figure 15: Color Point Test Bins in CIE 1931 xy Color Space 0.44 0.42 BBL CIE y 0.40 0.38 5000K 3 SDCM 2700K 3 SDCM 5700K 3 SDCM 3000K 3 SDCM 3500K 3 SDCM 0.36 4000K 3 SDCM 0.34 0.32 0.32 0.34 0.36 0.38 0.40 0.42 0.44 0.46 0.48 CIE x Table 6: Bin Coordinates and Associated Typical CCT 3 SDCM Bin 2700K 3000K 3500 K 4000K 5000K 5700K CCT Range 2651K - 2794K 2968K - 3136K 3369K - 3586K 3851K - 4130K 4835K - 5215K 5490K - 5820K Center Point (x, y) (0.458, 0.410) (0.434, 0.403) (0.407, 0.392) (0.382, 0.380) (0.3445, 0.355) (0.329, 0.342) ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) (4745K - 5311K) (5312K - 6022K) Notes for Table 6: 1. Color binning at solder point temperature Tsp of SMDs at 85°C. 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. 12 Packaging and Labeling Figure 16: Packaging and Labeling Table 7: Packaging Structure L0340modules Tray Box Quantity 28 140 Dimension 38 cm x 33.5 cm x 2.4 cm 41 cm x 36 cm x 15.5 cm L0590 modules Tray Box Quantity 36 180 Dimension 63 cm x 39 cm x 2.4 cm 65.5 cm x 41.5 cm x 15.5 cm L1190 modules Tray Box Quantity 36 180 Dimension 123 cm x 39 cm x 2.4 cm 134 cm x 44 cm x 18.5 cm Figure 17: Product Labeling Bridgelux EB Series Slim Gen 3 modules contain a label on the front to help with product identification. In addition to the product identification markings, modules also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the module. BXEB-L0340U-xxx0750-C-C3 Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. 13 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the EB Series product family. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux EB Series LED linears are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED linear. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux EB Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. EB Series linears are classified as Risk Group 1 when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the linear or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the linear. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the EB Series linear. Use the mechanical features of the linear housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the EB Series modules during operation. Allow the linear to cool for a sufficient period of time before handling. The EB Series linears may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, linear testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 14 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 USA Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2019 Bridgelux, IncAll rights reserved. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. EB Series and Bridging Light and Life are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux EB Series Slim Gen3 Data Sheet DS171 Rev. A (06/2019) 15
BXEB-L0590U-27G1500-C-C3 价格&库存
很抱歉,暂时无法提供与“BXEB-L0590U-27G1500-C-C3”相匹配的价格&库存,您可以联系我们找货
