BXRC-27H1000-C-83
BXRC-27H1000-C-83
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) Gen 8 Vero® 10 Array 白色,暖色 星形板
BXRC-27H1000-C-83 数据手册
Bridgelux Gen 8 Vero 10 Array ® ® Product Data Sheet DS420 1 Vero® Series Introduction The Vero® Series is a revolutionary advancement in chip on board (COB) light source technology and innovation, simplifying the luminaire design and manufacturing processes. Vero Chip on Board (COB) LED arrays are available in four LES configurations, engineered to enable new degrees of flexibility and reliability over a broad range of electrical currents. Vero arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero products include an onboard connector port that enables a solder-free electrical interconnect, and simple mounting features for plug-and-play installation. Features Benefits • On board connector port • Solder free installation and field upgradability • Top side part number markings • Improved inventory management and quality control • Efficacy of 178 lm/W typical, 3000K 80 CRI • Enables high efficiency lighting systems and lower operating costs • Reliable operation at up to 3x nominal current, 30% increase in maximum lumens per LES size • Wide selection of CCT options (2700K-6500K) with minimum 70, 80 and 90 CRI options • Uniform high-quality illumination • 2 and 3 SDCM binning options (2700K – 4000K) • Forward voltage bin codes (backside marking) • Thermally isolated solder pads • 10-Year warranty • Supports the trend toward luminaire miniaturization and delivers enhanced optical control • Design flexibility for a broad range of lighting applications • Clean white light without pixelation • Uniform consistent white light • Design flexibility for multi-source applications • Enhanced ease of use and installation • Design with confidence Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 European Product Registry for Energy Labeling 4 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 20 Eye Safety 21 Absolute Maximum Ratings 22 Performance Curves 23 Typical Radiation Pattern 25 Typical Color Spectrum 26 Mechanical Dimensions 27 Color Binning Information 28 Packaging and Labeling 29 Design Resources 31 Precautions 31 Disclaimers 31 About Bridgelux 32 1 Product Feature Map Vero 10 is the smallest form factor in the Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero Series family of products. 2D Bar code provides full manufacturing traceability Thermally isolated solder pads reduce manufacturing cycle time and complexity Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Mounting holes Top side part number marking improves inventory management and outgoing quality control Radial die configuration improves lumen density and beam control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Molex Pico-EZmate™ connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 100 0 – C – 8 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen. 8 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Target Flux Indicator 100x = 1000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E1000-B-8x 2700 80 200 1145 1008 34.2 6.8 167 BXRC-27E1000-C-8x 2700 80 300 1544 1359 30.7 9.2 168 BXRC-27E1000-D-8x 2700 80 250 1043 918 24.9 6.2 168 BXRC-27G1000-B-8x 2700 90 200 945 832 34.2 6.8 138 BXRC-27G1000-C-8x 2700 90 300 1274 1121 30.7 9.2 138 BXRC-27G1000-D-8x 2700 90 250 860 757 24.9 6.2 138 BXRC-27G10H0-B-8x 2700 90 200 986 867 34.2 6.8 144 BXRC-27G10H0-C-8x 2700 90 300 1329 1170 30.7 9.2 144 BXRC-27G10H0-D-8x 2700 90 250 897 790 24.9 6.2 144 BXRC-27H1000-B-8x 2700 97 200 838 737 34.2 6.8 122 123 BXRC-27H1000-C-8x 2700 97 300 1129 994 30.7 9.2 BXRC-27H1000-D-8x 2700 97 250 763 671 24.9 6.2 123 BXRC-30C1001-B-8x 3000 70 200 1274 1121 34.2 6.8 186 BXRC-30C1001-C-8x 3000 70 300 1718 1512 30.7 9.2 187 BXRC-30C1001-D-8x 3000 70 250 1160 1021 24.9 6.2 186 BXRC-30E1000-B-8x 3000 80 200 1217 1071 34.2 6.8 178 BXRC-30E1000-C-8x 3000 80 300 1641 1444 30.7 9.2 178 178 BXRC-30E1000-D-8x 3000 80 250 1108 975 24.9 6.2 BXRC-30G1000-B-8x 3000 90 200 988 869 34.2 6.8 144 BXRC-30G1000-C-8x 3000 90 300 1332 1172 30.7 9.2 145 BXRC-30G1000-D-8x 3000 90 250 899 792 24.9 6.2 144 BXRC-30G10H0-B-8x 3000 90 200 1034 910 34.2 6.8 151 BXRC-30G10H0-C-8x 3000 90 300 1395 1227 30.7 9.2 151 BXRC-30G10H0-D-8x 3000 90 250 942 829 24.9 6.2 151 BXRC-30H1000-B-8x 3000 97 200 895 787 34.2 6.8 131 BXRC-30H1000-C-8x 3000 97 300 1207 1062 30.7 9.2 131 BXRC-30H1000-D-8x 3000 97 250 815 717 24.9 6.2 131 BXRC-35E1000-B-8x 3500 80 200 1246 1096 34.2 6.8 182 BXRC-35E1000-C-8x 3500 80 300 1680 1478 30.7 9.2 182 BXRC-35E1000-D-8x 3500 80 250 1134 998 24.9 6.2 182 BXRC-35G1000-B-8x 3500 90 200 1024 901 34.2 6.8 150 BXRC-35G1000-C-8x 3500 90 300 1380 1215 30.7 9.2 150 BXRC-35G1000-D-8x 3500 90 250 932 820 24.9 6.2 150 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40C1001-B-8x 4000 70 200 1310 1153 34.2 6.8 192 BXRC-40C1001-C-8x 4000 70 300 1766 1555 30.7 9.2 192 BXRC-40C1001-D-8x 4000 70 250 1193 1050 24.9 6.2 192 BXRC-40E1000-B-8x 4000 80 200 1253 1102 34.2 6.8 183 BXRC-40E1000-C-8x 4000 80 300 1689 1487 30.7 9.2 183 BXRC-40E1000-D-8x 4000 80 250 1141 1004 24.9 6.2 183 BXRC-40G1000-B-8x 4000 90 200 1045 920 34.2 6.8 153 BXRC-40G1000-C-8x 4000 90 300 1409 1240 30.7 9.2 153 BXRC-40G1000-D-8x 4000 90 250 952 837 24.9 6.2 153 BXRC-50C1001-B-8x 5000 70 200 1317 1159 34.2 6.8 193 BXRC-50C1001-C-8x 5000 70 300 1776 1563 30.7 9.2 193 BXRC-50C1001-D-8x 5000 70 250 1199 1055 24.9 6.2 193 BXRC-50E1001-B-8x 5000 80 200 1267 1115 34.2 6.8 185 186 BXRC-50E1001-C-8x 5000 80 300 1709 1504 30.7 9.2 BXRC-50E1001-D-8x 5000 80 250 1154 1015 24.9 6.2 185 BXRC-50G1001-B-8x 5000 90 200 1095 964 34.2 6.8 160 BXRC-50G1001-C-8x 5000 90 300 1477 1300 30.7 9.2 160 BXRC-50G1001-D-8x 5000 90 250 997 878 24.9 6.2 160 BXRC-57C1001-B-8x 5700 70 200 1281 1128 34.2 6.8 187 BXRC-57C1001-C-8x 5700 70 300 1728 1521 30.7 9.2 188 BXRC-57C1001-D-8x 5700 70 250 1167 1027 24.9 6.2 187 BXRC-57E1001-B-8x 5700 80 200 1217 1071 34.2 6.8 178 BXRC-57E1001-C-8x 5700 80 300 1641 1444 30.7 9.2 178 BXRC-57E1001-D-8x 5700 80 250 1108 975 24.9 6.2 178 BXRC-65C1001-B-8x 6500 70 200 1281 1128 34.2 6.8 187 188 BXRC-65C1001-C-8x 6500 70 300 1728 1521 30.7 9.2 BXRC-65C1001-D-8x 6500 70 250 1167 1027 24.9 6.2 187 BXRC-65E1001-B-8x 6500 80 200 1231 1084 34.2 6.8 180 BXRC-65E1001-C-8x 6500 80 300 1660 1461 30.7 9.2 180 BXRC-65E1001-D-8x 6500 80 250 1121 987 24.9 6.2 180 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E1000-B-8x 2700 80 200 1031 907 33.6 6.7 154 BXRC-27E1000-C-8x 2700 80 300 1390 1223 30.1 9.0 154 BXRC-27E1000-D-8x 2700 80 250 939 826 24.4 6.1 154 BXRC-27G1000-B-8x 2700 90 200 850 748 33.6 6.7 127 BXRC-27G1000-C-8x 2700 90 300 1147 1009 30.1 9.0 127 BXRC-27G1000-D-8x 2700 90 250 774 681 24.4 6.1 127 BXRC-27G10H0-B-8x 2700 90 200 887 781 33.6 6.7 132 BXRC-27G10H0-C-8x 2700 90 300 1196 1053 30.1 9.0 132 BXRC-27G10H0-D-8x 2700 90 250 808 711 24.4 6.1 132 BXRC-27H1000-B-8x 2700 97 200 754 663 33.6 6.7 112 BXRC-27H1000-C-8x 2700 97 300 1016 894 30.1 9.0 112 BXRC-27H1000-D-8x 2700 97 250 686 604 24.4 6.1 112 BXRC-30C1001-B-8x 3000 70 200 1147 1009 33.6 6.7 171 BXRC-30C1001-C-8x 3000 70 300 1546 1361 30.1 9.0 171 BXRC-30C1001-D-8x 3000 70 250 1044 919 24.4 6.1 171 BXRC-30E1000-B-8x 3000 80 200 1095 964 33.6 6.7 163 BXRC-30E1000-C-8x 3000 80 300 1477 1300 30.1 9.0 163 BXRC-30E1000-D-8x 3000 80 250 997 878 24.4 6.1 163 BXRC-30G1000-B-8x 3000 90 200 889 782 33.6 6.7 133 BXRC-30G1000-C-8x 3000 90 300 1199 1055 30.1 9.0 133 BXRC-30G1000-D-8x 3000 90 250 809 712 24.4 6.1 133 BXRC-30G10H0-B-8x 3000 90 200 931 819 33.6 6.7 139 139 BXRC-30G10H0-C-8x 3000 90 300 1255 1105 30.1 9.0 BXRC-30G10H0-D-8x 3000 90 250 848 746 24.4 6.1 139 BXRC-30H1000-B-8x 3000 97 200 805 709 33.6 6.7 120 BXRC-30H1000-C-8x 3000 97 300 1086 956 30.1 9.0 120 BXRC-30H1000-D-8x 3000 97 250 733 645 24.4 6.1 120 BXRC-35E1000-B-8x 3500 80 200 1121 987 33.6 6.7 167 BXRC-35E1000-C-8x 3500 80 300 1512 1330 30.1 9.0 167 BXRC-35E1000-D-8x 3500 80 250 1021 898 24.4 6.1 167 BXRC-35G1000-B-8x 3500 90 200 921 811 33.6 6.7 137 BXRC-35G1000-C-8x 3500 90 300 1242 1093 30.1 9.0 137 BXRC-35G1000-D-8x 3500 90 250 839 738 24.4 6.1 137 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40C1001-B-8x 4000 70 200 1179 1038 33.6 6.7 176 BXRC-40C1001-C-8x 4000 70 300 1590 1399 30.1 9.0 176 BXRC-40C1001-D-8x 4000 70 250 1073 945 24.4 6.1 176 BXRC-40E1000-B-8x 4000 80 200 1128 992 33.6 6.7 168 BXRC-40E1000-C-8x 4000 80 300 1520 1338 30.1 9.0 168 BXRC-40E1000-D-8x 4000 80 250 1027 903 24.4 6.1 168 BXRC-40G1000-B-8x 4000 90 200 941 828 33.6 6.7 140 BXRC-40G1000-C-8x 4000 90 300 1268 1116 30.1 9.0 140 BXRC-40G1000-D-8x 4000 90 250 856 754 24.4 6.1 140 BXRC-50C1001-B-8x 5000 70 200 1186 1043 33.6 6.7 177 BXRC-50C1001-C-8x 5000 70 300 1599 1407 30.1 9.0 177 BXRC-50C1001-D-8x 5000 70 250 1079 950 24.4 6.1 177 BXRC-50E1001-B-8x 5000 80 200 1140 1004 33.6 6.7 170 BXRC-50E1001-C-8x 5000 80 300 1538 1353 30.1 9.0 170 BXRC-50E1001-D-8x 5000 80 250 1038 914 24.4 6.1 170 BXRC-50G1001-B-8x 5000 90 200 986 867 33.6 6.7 147 BXRC-50G1001-C-8x 5000 90 300 1329 1170 30.1 9.0 147 BXRC-50G1001-D-8x 5000 90 250 897 790 24.4 6.1 147 BXRC-57C1001-B-8x 5700 70 200 1153 1015 33.6 6.7 172 172 BXRC-57C1001-C-8x 5700 70 300 1555 1368 30.1 9.0 BXRC-57C1001-D-8x 5700 70 250 1050 924 24.4 6.1 172 BXRC-57E1001-B-8x 5700 80 200 1095 964 33.6 6.7 163 BXRC-57E1001-C-8x 5700 80 300 1477 1300 30.1 9.0 163 BXRC-57E1001-D-8x 5700 80 250 997 878 24.4 6.1 163 BXRC-65C1001-B-8x 6500 70 200 1153 1015 33.6 6.7 172 172 BXRC-65C1001-C-8x 6500 70 300 1555 1368 30.1 9.0 BXRC-65C1001-D-8x 6500 70 250 1050 924 24.4 6.1 172 BXRC-65E1001-B-8x 6500 80 200 1108 975 33.6 6.7 165 BXRC-65E1001-C-8x 6500 80 300 1494 1315 30.1 9.0 165 BXRC-65E1001-D-8x 6500 80 250 1009 888 24.4 6.1 165 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 European Product Registry for Energy Labeling The European Product Registry for Energy Labeling (EPREL) is defined in the EU Regulation 2017/1369 to provide important energy efficiency information to consumers. Together with Energy Labeling Regulation ELR (EU) 2019/2015 which was amended by regulation (EU) 2021/340 for energy labelling of light sources, manufacturers are required to declare an energy class based on key technical specifications from each of their product and register it in an open data base managed by EPREL It is now a legal requirement for a vendor of light sources to upload information about their products into the EPREL database before placing these products on the market in the EU. Table 3 below provides a list of part numbers that are in compliance with ELR and are currently listed in the EPREL database. At Bridgelux, we are fully committed to supplying products that are compliant with pertinent laws, rules, and obligation imposed by relevant government bodies including the European Energy Labeling regulation. Customers can use these products with full confidence for any projects that fall under the ELR. Table 3: Part numbers registered in European Product Registry for Energy Labeling CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) 2700 80 500 36.8 2323 18.4 126.4 PART NUMBER CCT (K) BXRC-27E1000-B-8x 1 Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database E 871002 https://eprel.ec.europa.eu/qr/871002 https://eprel.ec.europa.eu/qr/871007 BXRC-27E1000-C-8x 2700 80 1000 34.3 4115 34.3 119.9 E 871007 BXRC-27E1000-D-8x 2700 80 1000 28.5 3294 28.5 115.4 F 871012 https://eprel.ec.europa.eu/qr/871012 BXRC-27G1000-B-8x 2700 90 500 36.8 1917 18.4 104.2 F 871071 https://eprel.ec.europa.eu/qr/871071 BXRC-27G1000-C-8x 2700 90 770 33.1 2727 25.5 106.9 F 871076 https://eprel.ec.europa.eu/qr/871076 BXRC-27G1000-D-8x 2700 90 720 27.3 2058 19.7 104.6 F 871081 https://eprel.ec.europa.eu/qr/871081 BXRC-27G10H0-B-8x 2700 90 500 36.8 1999 18.4 108.7 F 871085 https://eprel.ec.europa.eu/qr/871085 BXRC-27G10H0-C-8x 2700 90 870 33.7 3157 29.3 107.8 F 871089 https://eprel.ec.europa.eu/qr/871089 BXRC-27G10H0-D-8x 2700 90 810 27.7 2379 22.5 105.9 F 871093 https://eprel.ec.europa.eu/qr/871093 BXRC-30C1001-B-8x 3000 70 500 36.8 2585 18.4 140.6 E 871258 https://eprel.ec.europa.eu/qr/871258 BXRC-30C1001-C-8x 3000 70 1000 34.3 4578 34.3 133.4 E 871264 https://eprel.ec.europa.eu/qr/871264 BXRC-30C1001-D-8x 3000 70 1000 28.5 3664 28.5 128.4 E 871270 https://eprel.ec.europa.eu/qr/871270 BXRC-30E1000-B-8x 3000 80 500 36.8 2468 18.4 134.2 E 871332 https://eprel.ec.europa.eu/qr/871332 BXRC-30E1000-C-8x 3000 80 1000 34.3 4373 34.3 127.4 E 871337 https://eprel.ec.europa.eu/qr/871337 BXRC-30E1000-D-8x 3000 80 1000 28.5 3500 28.5 122.6 E 871342 https://eprel.ec.europa.eu/qr/871342 BXRC-30G1000-B-8x 3000 90 500 36.8 2004 18.4 109.0 F 871401 https://eprel.ec.europa.eu/qr/871401 BXRC-30G1000-C-8x 3000 90 880 33.7 3195 29.7 107.7 F 871406 https://eprel.ec.europa.eu/qr/871406 BXRC-30G1000-D-8x 3000 90 820 27.8 2409 22.8 105.8 F 871411 https://eprel.ec.europa.eu/qr/871411 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 7 European Product Registry for Energy Labeling Table 3: Part numbers registered in European Product Registry for Energy Labeling (Continued) CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) 3000 90 500 36.8 2098 18.4 114.1 PART NUMBER CCT (K) BXRC-30G10H0-B-8x 1 Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database F 871423 https://eprel.ec.europa.eu/qr/871423 https://eprel.ec.europa.eu/qr/871427 BXRC-30G10H0-C-8x 3000 90 1000 34.3 3717 34.3 108.3 F 871427 BXRC-30G10H0-D-8x 3000 90 920 28.2 2777 25.9 107.1 F 871431 https://eprel.ec.europa.eu/qr/871431 BXRC-35E1000-B-8x 3500 80 500 36.8 2526 18.4 137.4 E 871606 https://eprel.ec.europa.eu/qr/871606 BXRC-35E1000-C-8x 3500 80 1000 34.3 4475 34.3 130.4 E 871611 https://eprel.ec.europa.eu/qr/871611 BXRC-35E1000-D-8x 3500 80 1000 28.5 3582 28.5 125.5 E 871616 https://eprel.ec.europa.eu/qr/871616 BXRC-35G1000-B-8x 3500 90 500 36.8 2076 18.4 112.9 F 871674 https://eprel.ec.europa.eu/qr/871674 https://eprel.ec.europa.eu/qr/871679 BXRC-35G1000-C-8x 3500 90 960 34.1 3555 32.8 108.5 F 871679 BXRC-35G1000-D-8x 3500 90 900 28.1 2699 25.3 106.7 F 871684 https://eprel.ec.europa.eu/qr/871684 BXRC-40C1001-B-8x 4000 70 500 36.8 2657 18.4 144.5 E 871760 https://eprel.ec.europa.eu/qr/871760 BXRC-40C1001-C-8x 4000 70 1000 34.3 4707 34.3 137.1 E 871766 https://eprel.ec.europa.eu/qr/871766 BXRC-40C1001-D-8x 4000 70 1000 28.5 3767 28.5 132.0 E 871772 https://eprel.ec.europa.eu/qr/871772 https://eprel.ec.europa.eu/qr/871838 BXRC-40E1000-B-8x 4000 80 500 36.8 2541 18.4 138.2 E 871838 BXRC-40E1000-C-8x 4000 80 1000 34.3 4501 34.3 131.1 E 871843 https://eprel.ec.europa.eu/qr/871843 BXRC-40E1000-D-8x 4000 80 1000 28.5 3603 28.5 126.2 E 871848 https://eprel.ec.europa.eu/qr/871848 https://eprel.ec.europa.eu/qr/871907 BXRC-40G1000-B-8x 4000 90 500 36.8 2120 18.4 115.3 F 871907 BXRC-40G1000-C-8x 4000 90 1000 34.3 3755 34.3 109.4 F 871912 https://eprel.ec.europa.eu/qr/871912 BXRC-40G1000-D-8x 4000 90 950 28.3 2880 26.9 107.0 F 871917 https://eprel.ec.europa.eu/qr/871917 BXRC-50C1001-B-8x 5000 70 500 36.8 2672 18.4 145.3 E 871996 https://eprel.ec.europa.eu/qr/871996 BXRC-50C1001-C-8x 5000 70 1000 34.3 4733 34.3 137.9 E 872000 https://eprel.ec.europa.eu/qr/872000 BXRC-50C1001-D-8x 5000 70 1000 28.5 3788 28.5 132.7 E 872004 https://eprel.ec.europa.eu/qr/872004 BXRC-50E1001-B-8x 5000 80 500 36.8 2570 18.4 139.8 E 872048 https://eprel.ec.europa.eu/qr/872048 BXRC-50E1001-C-8x 5000 80 1000 34.3 4553 34.3 132.6 E 872052 https://eprel.ec.europa.eu/qr/872052 BXRC-50E1001-D-8x 5000 80 1000 28.5 3644 28.5 127.7 E 872056 https://eprel.ec.europa.eu/qr/872056 BXRC-50G1001-B-8x 5000 90 500 36.8 2222 18.4 120.8 E 872100 https://eprel.ec.europa.eu/qr/872100 BXRC-50G1001-C-8x 5000 90 1000 34.3 3935 34.3 114.7 F 872104 https://eprel.ec.europa.eu/qr/872104 BXRC-50G1001-D-8x 5000 90 1000 28.5 3150 28.5 110.4 F 872108 https://eprel.ec.europa.eu/qr/872108 BXRC-57C1001-B-8x 5700 70 500 36.8 2599 18.4 141.4 E 872206 https://eprel.ec.europa.eu/qr/872206 BXRC-57C1001-C-8x 5700 70 1000 34.3 4604 34.3 134.1 E 872210 https://eprel.ec.europa.eu/qr/872210 BXRC-57C1001-D-8x 5700 70 1000 28.5 3685 28.5 129.1 E 872214 https://eprel.ec.europa.eu/qr/872214 BXRC-57E1001-B-8x 5700 80 500 36.8 2468 18.4 134.2 E 872255 https://eprel.ec.europa.eu/qr/872255 BXRC-57E1001-C-8x 5700 80 1000 34.3 4373 34.3 127.4 E 872259 https://eprel.ec.europa.eu/qr/872259 BXRC-57E1001-D-8x 5700 80 1000 28.5 3500 28.5 122.6 E 872263 https://eprel.ec.europa.eu/qr/872263 BXRC-65C1001-B-8x 6500 70 500 36.8 2599 18.4 141.4 E 872303 https://eprel.ec.europa.eu/qr/872303 BXRC-65C1001-C-8x 6500 70 1000 34.3 4604 34.3 134.1 E 872307 https://eprel.ec.europa.eu/qr/872307 BXRC-65C1001-D-8x 6500 70 1000 28.5 3685 28.5 129.1 E 872311 https://eprel.ec.europa.eu/qr/872311 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 8 European Product Registry for Energy Labeling Table 3: Part numbers registered in European Product Registry for Energy Labeling (Continued) PART NUMBER CCT (K) CRI 1 Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database BXRC-65E1001-B-8x 6500 80 500 36.8 2497 18.4 135.8 E 872353 https://eprel.ec.europa.eu/qr/872353 BXRC-65E1001-C-8x 6500 80 1000 34.3 4424 34.3 128.9 E 872357 https://eprel.ec.europa.eu/qr/872357 BXRC-65E1001-D-8x 6500 80 1000 28.5 3541 28.5 124.1 E 872361 https://eprel.ec.europa.eu/qr/872361 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 9 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E1000-B-8x 80 BXRC-27E1000-C-8x 80 BXRC-27E1000-D-8x 80 BXRC-27G1000-B-8x 90 BXRC-27G1000-C-8x 90 BXRC-27G1000-D-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 597 872 1145 1500 2131 2581 805 1176 1544 1817 2874 4400 544 784 1043 1412 1940 3412 493 719 945 1238 1758 2129 664 970 1274 1499 2371 3630 448 647 860 1165 1601 2815 537 785 1031 1350 1918 2323 725 1058 1390 1635 2586 3960 489 706 939 1271 1746 3070 443 647 850 1114 1582 1917 598 873 1147 1349 2134 3267 404 582 774 1048 1441 2533 181 173 168 159 146 138 181 173 168 162 146 126 181 174 168 158 146 117 150 143 138 131 120 114 150 143 138 134 120 104 150 143 138 130 120 97 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G10H0-B-8x 90 BXRC-27G10H0-C-8x 90 BXRC-27G10H0-D-8x 90 BXRC-27H1000-B-8x 97 BXRC-27H1000-C-8x 97 BXRC-27H1000-D-8x 97 BXRC-30C1001-B-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 514 750 986 1291 1834 2221 693 1012 1329 1564 2473 3787 468 675 897 1215 1670 2936 437 638 838 1097 1558 1887 592 863 1129 1338 2138 3343 400 576 763 1044 1450 2676 664 970 1274 1669 2371 2872 462 675 887 1162 1651 1999 624 911 1196 1407 2226 3408 421 607 808 1093 1503 2642 393 574 754 987 1403 1699 532 777 1016 1204 1924 3009 360 518 686 939 1305 2409 598 873 1147 1502 2134 2584 156 149 144 137 126 118 156 149 144 139 126 108 156 149 144 136 126 101 133 127 122 116 107 101 132 127 122 120 110 97 132 127 123 117 111 95 202 193 186 176 162 153 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30C1001-C-8x 70 BXRC-30C1001-D-8x 70 BXRC-30E1000-B-8x 80 BXRC-30E1000-C-8x 80 BXRC-30E1000-D-8x 80 BXRC-30G1000-B-8x 90 BXRC-30G1000-C-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 900 1313 1718 2036 3252 5086 609 876 1160 1588 2206 4072 634 926 1217 1594 2264 2742 860 1254 1641 1944 3106 4858 581 836 1108 1516 2107 3889 515 752 988 1294 1838 2226 698 1018 1332 1578 2522 3943 810 1182 1546 1832 2927 4578 548 788 1044 1429 1986 3664 571 834 1095 1435 2038 2468 774 1129 1477 1750 2796 4372 523 753 997 1365 1896 3500 463 677 889 1165 1654 2004 628 916 1199 1421 2269 3549 201 193 186 182 167 148 201 193 186 179 169 145 193 184 178 169 155 146 192 184 178 174 160 141 192 184 178 171 162 138 157 149 144 137 126 119 156 149 144 141 130 115 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G1000-D-8x 90 BXRC-30G10H0-B-8x 90 BXRC-30G10H0-C-8x 90 BXRC-30G10H0-D-8x 90 BXRC-30H1000-B-8x 97 BXRC-30H1000-C-8x 97 BXRC-30H1000-D-8x 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 472 679 899 1231 1710 3157 539 787 1034 1355 1925 2331 731 1066 1395 1653 2640 4129 494 711 942 1289 1791 3305 466 681 895 1172 1665 2017 632 922 1207 1430 2284 3572 427 615 815 1115 1549 2859 425 611 809 1108 1539 2841 485 709 931 1219 1732 2098 658 960 1255 1487 2376 3716 445 640 848 1160 1612 2975 420 613 805 1055 1498 1815 569 830 1086 1287 2056 3215 385 554 733 1003 1394 2573 156 149 144 139 131 112 164 156 151 143 132 124 163 156 151 148 136 120 163 156 151 145 137 118 142 135 131 124 114 108 141 135 131 128 117 104 141 135 131 126 119 102 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35E1000-B-8x 80 BXRC-35E1000-C-8x 80 BXRC-35E1000-D-8x 80 BXRC-35G1000-B-8x 90 BXRC-35G1000-C-8x 90 BXRC-35G1000-D-8x 90 BXRC-40C1001-B-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 649 948 1246 1632 2318 2807 880 1284 1680 1990 3179 4972 595 856 1134 1552 2157 3980 534 779 1024 1341 1905 2307 723 1055 1380 1636 2613 4086 489 704 932 1275 1772 3271 683 997 1310 1716 2437 2952 584 853 1121 1468 2086 2526 792 1156 1512 1791 2861 4475 536 770 1021 1397 1941 3582 480 701 921 1207 1714 2076 651 950 1242 1472 2352 3678 440 633 839 1148 1595 2944 615 898 1179 1544 2194 2657 197 188 182 172 159 150 197 188 182 178 164 145 196 188 182 175 165 142 162 155 150 142 131 123 162 155 150 146 134 119 161 155 150 144 136 116 208 198 192 181 167 157 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40C1001-C-8x 70 BXRC-40C1001-D-8x 70 BXRC-40E1000-B-8x 80 BXRC-40E1000-C-8x 80 BXRC-40E1000-D-8x 80 BXRC-40G1000-B-8x 90 BXRC-40G1000-C-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 925 1350 1766 2093 3344 5229 626 900 1193 1632 2268 4186 653 954 1253 1641 2331 2823 885 1291 1689 2002 3198 5001 598 861 1141 1561 2169 4003 545 796 1045 1369 1945 2355 738 1077 1409 1670 2668 4172 833 1215 1590 1884 3009 4706 563 810 1073 1469 2041 3767 588 858 1128 1477 2098 2541 796 1162 1520 1801 2878 4501 539 775 1027 1405 1952 3603 490 716 941 1232 1750 2120 664 970 1268 1503 2401 3755 207 198 192 187 172 152 206 198 192 184 174 149 198 189 183 173 160 151 198 189 183 179 164 146 197 189 183 176 166 142 166 158 153 145 133 126 165 158 153 149 137 121 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40G1000-D-8x 90 BXRC-50C1001-B-8x 70 BXRC-50C1001-C-8x 70 BXRC-50C1001-D-8x 70 BXRC-50E1001-B-8x 80 BXRC-50E1001-C-8x 80 BXRC-50E1001-D-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 499 718 952 1302 1810 3340 687 1003 1317 1725 2451 2968 930 1358 1776 2105 3362 5258 629 905 1199 1641 2281 4209 661 965 1267 1660 2358 2855 895 1306 1709 2025 3234 5058 605 871 1154 1579 2194 4049 449 646 856 1172 1629 3006 618 902 1186 1553 2206 2671 837 1222 1599 1894 3026 4732 566 815 1079 1477 2053 3788 594 868 1140 1494 2122 2570 806 1175 1538 1822 2911 4552 545 784 1038 1421 1974 3644 165 158 153 147 139 119 209 199 193 182 168 158 208 199 193 188 173 153 207 199 193 185 175 150 201 192 185 175 162 152 200 192 185 181 166 147 199 192 185 178 168 144 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50G1001-B-8x 90 BXRC-50G1001-C-8x 90 BXRC-50G1001-D-8x 90 BXRC-57C1001-B-8x 70 BXRC-57C1001-C-8x 70 BXRC-57C1001-D-8x 70 BXRC-57E1001-B-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 571 834 1095 1435 2038 2468 774 1129 1477 1750 2796 4372 523 753 997 1365 1896 3500 668 975 1281 1678 2384 2888 905 1321 1728 2047 3271 5115 612 881 1167 1597 2219 4094 634 926 1217 1594 2264 2742 514 750 986 1291 1834 2221 696 1016 1329 1575 2516 3935 471 677 897 1228 1707 3150 601 878 1153 1511 2146 2599 815 1189 1555 1843 2944 4604 551 793 1050 1437 1997 3685 571 834 1095 1435 2038 2468 174 166 160 152 140 132 173 166 160 156 144 127 172 166 160 154 145 125 203 194 187 177 163 154 202 194 187 183 168 149 202 194 187 180 170 146 193 184 178 169 155 146 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E1001-C-8x 80 BXRC-57E1001-D-8x 80 BXRC-65C1001-B-8x 70 BXRC-65C1001-C-8x 70 BXRC-65C1001-D-8x 70 BXRC-65E1001-B-8x 80 BXRC-65E1001-C-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 24.3 24.6 24.9 25.4 26.1 28.1 32.9 33.6 34.2 35.0 36.5 37.5 29.8 30.3 30.7 31.1 32.4 34.3 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 3.0 4.5 6.2 8.9 13.0 28.1 3.3 5.0 6.8 9.5 14.6 18.7 4.5 6.8 9.2 11.2 19.4 34.3 860 1254 1641 1944 3106 4858 581 836 1108 1516 2107 3889 668 975 1281 1678 2384 2888 905 1321 1728 2047 3271 5115 612 881 1167 1597 2219 4094 642 937 1231 1613 2291 2775 870 1269 1660 1967 3143 4915 774 1129 1477 1750 2796 4372 523 753 997 1365 1896 3500 601 878 1153 1511 2146 2599 815 1189 1555 1843 2944 4604 551 793 1050 1437 1997 3685 578 844 1108 1452 2062 2497 783 1142 1494 1771 2829 4424 192 184 178 174 160 141 192 184 178 171 162 138 203 194 187 177 163 154 202 194 187 183 168 149 202 194 187 180 170 146 195 186 180 171 157 148 194 186 180 176 162 143 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRC-65E1001-D-8x CRI Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 80 125 185 250 350 500 1000 24.3 24.6 24.9 25.4 26.1 28.1 3.0 4.5 6.2 8.9 13.0 28.1 588 846 1121 1534 2132 3934 529 762 1009 1381 1919 3541 194 186 180 173 164 140 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 19 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx100x-B-8x BXRC-xxx100x-C-8x BXRC-xxx100x-D-8x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.62 30.8 37.5 -12.10 0.95 33.7 41.1 33.0 -9.90 0.38 27.6 33.6 35 37.6 -11.29 0.55 31.5 38.4 23.0 24.9 26.8 -8.03 0.37 22.4 27.3 26.9 29.1 31.3 -9.39 0.55 26.2 31.9 Minimum Typical Maximum 200 31.6 34.2 36.8 -11.03 500 34.7 37.5 40.3 300 28.4 30.7 1000 32.4 250 1000 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 1140 V. The working voltage designated for the insulation is 70V d.c. The maximum allowable voltage across the array must be determined in the end product application. 20 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number CCT5 Drive Current (mA) 2700K/3000K 4000K2 5000K3 6500K4 355 RG1 RG1 RG1 RG1 500 RG1 RG1 RG1 RG2 395 RG1 RG1 RG1 RG1 550 RG1 RG1 RG1 RG2 730 RG1 RG1 RG2 RG2 1000 RG1 RG2 RG2 RG2 490 RG1 RG1 RG1 RG1 680 RG1 RG1 RG1 RG2 900 RG1 RG1 RG2 RG2 1000 RG1 RG2 RG2 RG2 BXRC-xxx100x-B-8x BXRC-xxx100x-C-8x BXRC-xxx100x-D-8x Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1980 lx. 3. For products classified as RG2 at 5000K Ethr= 1530 lx. 4. For products classified as RG2 at 6500K, Ethr= 1170 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 21 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRC-xxx100x-B-8x BXRC-xxx100x-C-8x BXRC-xxx100x-D-8x Maximum Drive Current3 500 mA 1000 mA 1000 mA Maximum Peak Pulsed Drive Current4 560 mA 1120 mA 1120 mA Maximum Reverse Voltage5 -60V -55V -45V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN31: Assembly Considerations for Bridgelux Vero LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 22 Performance Curves Figure 1: Vero 10B Drive Current vs. Voltage Figure 2: Vero 10C Drive Current vs. Voltage 36.0 38.0 35.0 37.0 Voltage (V) Voltage (V) 34.0 36.0 35.0 34.0 33.0 32.0 31.0 33.0 30.0 29.0 32.0 0 100 200 300 400 500 0 600 200 Figure 3: Vero 10D Drive Current vs. Voltage 800 1000 1200 250% Relative Luminous Flux (%) 29.0 28.0 Voltage (V) 600 Figure 4: Vero 10B Typical Relative Flux vs. Current 30.0 27.0 26.0 25.0 24.0 23.0 0 200 400 600 800 1000 200% 150% 100% 50% 0% 1200 0 100 Drive Current (mA) 200 300 400 500 600 Drive Current (mA) Figure 5: Vero 10C Typical Relative Flux vs. Current Figure 6 Vero 10D Typical Relative Flux vs. Current 350% Relative Luminous Flux (%) 300% Relative Luminous Flux (%) 400 Drive Current (mA) Drive Current (mA) 250% 200% 150% 100% 50% 0% 0 200 400 600 Drive Current (mA) 800 1000 1200 300% 250% 200% 150% 100% 50% 0% 0 200 400 600 800 1000 1200 Drive Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 23 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature 102% 0.0010 100% 0.0000 98% -0.0010 96% -0.0020 ccy shift Relative Luminous Flux Figure 7: Typical DC Flux vs. Case Temperature 94% 92% 25C Pulsed 0 -0.0030 -0.0040 90% -0.0050 88% -0.0060 -0.0070 86% 0 20 40 60 80 100 120 0 20 40 60 80 100 120 Case Temperature (T c) Case Temperature (T c) Figure 9: Typical DC ccx Shift vs. Case Temperature 0.0020 25C Pulsed 0.0000 ccx shift -0.0020 -0.0040 -0.0060 -0.0080 -0.0100 0 20 40 60 80 100 120 Case Temperature (T c) Note for Figures 7-9: 1. Characteristics shown for Warm White 24 Typical Radiation Pattern Figure 10: Typical Spatial Radiation Pattern Notes for Figure 10: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 11: Typical Polar Radiation Pattern 25 Typical Color Spectrum Figure 12: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Rela�ve Spectral Power Distribu�on 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 12: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. 26 Mechanical Dimensions Figure 13: Drawing for Vero 10 LED Array Notes for Figure 13: 1. Drawings are not to scale. 2. Dimensions are in mm. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Mounting slots (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 19.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 27 Color Binning Information Figure 14: Warm and Neutral White Test Bins in xy Color Figure 15: Graph of Cool White Test Bins in xy Color Space Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 84 (4 SDCM) (4801K - 5282K) (5395K- 5970K) (6200K - 6910K) 83 (3 SDCM) (4835K-5215K) (5460K- 5891K) (6279K -6811K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) Note for Tables 8-9: 1. Bridgelux maintains a tolerance of +/- 0.007 on x and y color coordinates in the CIE 1931 color Space. 28 Packaging and Labeling Figure 16: Drawing for Vero 10 Packaging Tray Notes for Figure 16: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 29 Packaging and Labeling Figure 17: Vero Series Packaging and Labeling Notes for Figure 17: 1. Each tray holds 200 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 18: Gen. 8 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E1000C 83 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 30 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 31 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46410 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 Vero 10 Array Series Product Data Sheet DS420 Rev. C (08/2021) 32
BXRC-27H1000-C-83 价格&库存
很抱歉,暂时无法提供与“BXRC-27H1000-C-83”相匹配的价格&库存,您可以联系我们找货
BXRC-27H1000-C-83
  • 1+69.528711+8.70079
  • 10+52.5800010+6.57983
  • 100+42.65250100+5.33751
  • 500+38.32262500+4.79567
  • 1000+36.916661000+4.61973
  • 2000+35.728072000+4.47099
库存:171
