BXRC-65C10K1-D-74-SE
    BRIDGELUX(普瑞)
    冷白色 6500K CRI:70
BXRC-65C10K1-D-74-SE 数据手册
Bridgelux Vero SE 29 Array ® ® Product Data Sheet DS123 1 Vero SE Introduction Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s seventh generation COB technology with poke-in connectivity enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing cost, simplify luminaire design, improve light quality and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and typical R9 value of 98, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen lamps Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series ™ Entertainment products provide color points developed specifically for the healthcare and entertainment industries. The 5600K cool white color point combined with a CRI of 90 or 97 provides the bright white required by these industries. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Features • Poke-in connectivity • Efficacy of 170 lm/W typical • Lumen output performance ranges from 5,368 to 37,173 lumens Benefits • Poke-in connectivity enables solderless, connector free installation • Broad application coverage for interior and exterior lighting • Broad range of CCT options from 1750K to 6500K • Flexibility for application driven lighting design requirements • CRI options: minimum 65, 70, 80, and 90 • High quality, true color reproduction • Color control: 2 and 3 SDCM for 2700K-4000K CCT • Uniform consistent white light • Reliable operation at up to 2X nominal drive current • Flexibility in design optimization • Radial die pattern and improved lumen density • Enhanced ease of use and assembly • Top side part number markings • No exposed solder pads or electrical connections • Ability to configure multiple arrays in series and parallel reduces customer driver cost • Vf bin code backside marking • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 20 Eye Safety 21 Absolute Maximum Ratings 22 Performance Curves 23 Typical Radiation Pattern 27 Typical Color Spectrum 28 Mechanical Dimensions 29 Color Binning Information 30 Packaging and Labeling 31 Design Resources 33 Precautions 33 Disclaimers 33 About Bridgelux 34 1 Product Feature Map Vero SE 29 is the largest form factor in the product family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero SE Series family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 Tc Measurement point Optic mounting holes Radial die configuration improves lumen density and beam control Mounting holes Top side part number marking improves inventory management and outgoing quality control Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 10K 0 – C – 7 3 – SE Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 7 Array Configuration CRI B = 65 CRI min. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. A = Class A 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted Flux Indicator 10Kx = 10,000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-17E10K0-B-74-SE 1750 80 1800 8590 7731 52.0 93.6 92 BXRC-17E10K0-C-74-SE 1750 80 1710 10891 9802 69.4 118.7 92 BXRC-17E10K0-D-74-SE 1750 80 2100 7246 6522 37.6 79.0 92 BXRC-20B10K1-C-73-SE 2000 65 1710 18585 16727 69.4 118.7 157 BXRC-20B10K1-D-73-SE 2000 65 2100 12366 11129 37.6 79.0 157 BXRC-25E10K0-B-74-SE 2500 80 1800 14285 12856 52.0 93.6 153 BXRC-25E10K0-C-74-SE 2500 80 1710 18112 16301 69.4 118.7 153 BXRC-25E10K0-D-74-SE 2500 80 2100 12051 10846 37.6 79.0 153 BXRC-27E10K0-B-7x-SE 2700 80 1800 14939 13445 52.0 93.6 160 BXRC-27E10K0-C-7x-SE 2700 80 1710 18940 17046 69.4 118.7 160 BXRC-27E10K0-D-7x-SE 2700 80 2100 12602 11342 37.6 79.0 160 BXRC-27G1KH0-B-7x-SE 2700 90 1800 12791 11512 52.0 93.6 137 BXRC-27G1KH0-C-7x-SE 2700 90 1710 16218 14596 69.4 118.7 137 BXRC-27G1KH0-D-7x-SE 2700 90 2100 10790 9711 37.6 79.0 137 BXRC-27G10K0-B-7x-SE 2700 90 1800 12324 11092 52.0 93.6 132 BXRC-27G10K0-C-7x-SE 2700 90 1710 15626 14063 69.4 118.7 132 BXRC-27G10K0-D-7x-SE 2700 90 2100 10397 9357 37.6 79.0 132 BXRC-27H10K0-D-74-SE 2700 97 2100 9215 8294 37.6 79.0 117 BXRC-30C10K1-B-74-SE 3000 70 1800 16619 14957 52.0 93.6 178 178 BXRC-30C10K1-C-74-SE 3000 70 1710 21071 18964 69.4 118.7 BXRC-30C10K1-D-74-SE 3000 70 2100 14020 12618 37.6 79.0 178 BXRC-30E10K0-B-7x-SE10 3000 80 1800 15872 14285 52.0 93.6 170 BXRC-30E10K0-C-7x-SE10 3000 80 1710 20124 18112 69.4 118.7 170 BXRC-30E10K0-D-7x-SE10 3000 80 2100 13390 12051 37.6 79.0 170 BXRC-30G1KH0-B-7x-SE 3000 90 1800 13445 12100 52.0 93.6 144 BXRC-30G1KH0-C-7x-SE 3000 90 1710 17046 15342 69.4 118.7 144 BXRC-30G1KH0-D-7x-SE 3000 90 2100 11342 10208 37.6 79.0 144 BXRC-30G10K0-B-7x-SE 3000 90 1800 12885 11596 52.0 93.6 138 BXRC-30G10K0-C-7x-SE 3000 90 1710 16336 14702 69.4 118.7 138 BXRC-30G10K0-D-7x-SE 3000 90 2100 10869 9782 37.6 79.0 138 BXRC-30H10K0-D-7X-SE 3000 97 2100 9845 8861 37.6 79.0 125 8,9 BXRC-30A10K1-B-73-SE 3000 93 1800 11577 10420 52.0 93.6 124 BXRC-30A10K1-C-73-SE8,9 3000 93 1710 14679 13211 69.4 118.7 124 BXRC-30A10K1-D-73-SE8,9 3000 93 2100 9767 8790 37.6 79.0 124 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI Nominal Drive Current3 (mA) 2 Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E10K0-B-7x-SE10 3500 80 1800 16246 14621 52.0 93.6 174 BXRC-35E10K0-C-7x-SE10 3500 80 1710 20598 18538 69.4 118.7 174 BXRC-35E10K0-D-7x-SE 3500 80 2100 13705 12334 37.6 79.0 174 BXRC-35G10K0-B-7x-SE 3500 90 1800 13351 12016 52.0 93.6 143 10 BXRC-35G10K0-C-7x-SE 3500 90 1710 16928 15235 69.4 118.7 143 BXRC-35G10K0-D-7x-SE 3500 90 2100 11263 10137 37.6 79.0 143 BXRC-35A10K1-B-73-SE8,9 3500 93 1800 12324 11092 52.0 93.6 132 BXRC-35A10K1-C-73-SE8,9 3500 93 1710 15626 14063 69.4 118.7 132 BXRC-35A10K1-D-73-SE8,9 3500 93 2100 10397 9357 37.6 79.0 132 BXRC-40C10K1-B-74-SE 4000 70 1800 17086 15377 52.0 93.6 183 BXRC-40C10K1-C-74-SE 4000 70 1710 21663 19497 69.4 118.7 183 BXRC-40C10K1-D-74-SE 4000 70 2100 14414 12972 37.6 79.0 183 BXRC-40E10K0-B-7x-SE10 4000 80 1800 16339 14705 52.0 93.6 175 BXRC-40E10K0-C-7x-SE10 4000 80 1710 20716 18644 69.4 118.7 175 BXRC-40E10K0-D-7x-SE 4000 80 2100 13783 12405 37.6 79.0 175 BXRC-40G10K0-B-7x-SE 4000 90 1800 13631 12268 52.0 93.6 146 10 BXRC-40G10K0-C-7x-SE 4000 90 1710 17283 15555 69.4 118.7 146 BXRC-40G10K0-D-7x-SE 4000 90 2100 11499 10349 37.6 79.0 146 BXRC-40H10K0-D-7X-SE 4000 97 2100 10397 9357 37.6 79.0 132 BXRC-40A10K1-B-73-SE8,9 4000 93 1800 13351 12016 52.0 93.6 143 BXRC-40A10K1-C-73-SE8,9 4000 93 1710 16928 15235 69.4 118.7 143 8,9 BXRC-40A10K1-D-73-SE 4000 93 2100 11263 10137 37.6 79.0 143 BXRC-50C10K1-B-7x-SE10 5000 70 1800 17179 15461 52.0 93.6 184 BXRC-50C10K1-C-7x-SE10 5000 70 1710 21781 19603 69.4 118.7 184 BXRC-50C10K1-D-7x-SE10 5000 70 2100 14492 13043 37.6 79.0 184 BXRC-50E10K1-B-7x-SE10 5000 80 1800 16526 14873 52.0 93.6 177 BXRC-50E10K1-C-7x-SE10 5000 80 1710 20953 18858 69.4 118.7 177 BXRC-50E10K1-D-7x-SE10 5000 80 2100 13941 12547 37.6 79.0 177 BXRC-50G10K1-B-7x-SE 5000 90 1800 14285 12856 52.0 93.6 153 BXRC-50G10K1-C-74-SE 5000 90 1710 18112 16301 69.4 118.7 153 BXRC-50G10K1-D-74-SE 5000 90 2100 12051 10846 37.6 79.0 153 BXRC-56G10K0-B-74-SE 5600 80 1800 14378 12941 52.0 93.6 154 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 4 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 80 1710 18230 16407 69.4 118.7 154 80 2100 12129 10916 37.6 79.0 154 5600 97 2100 10948 9853 37.6 79.0 139 Part Number Nominal CCT1 (K) CRI2 BXRC-56G10K0-C-74-SE 5600 BXRC-56G10Kx-D-74-SE 5600 BXRC-56H10K0-D-74-SE BXRC-57C10K1-B-74-SE 5700 70 1800 16713 15041 52.0 93.6 179 BXRC-57C10K1-C-74-SE 5700 70 1710 21190 19071 69.4 118.7 179 BXRC-57C10K1-D-74-SE 5700 70 2100 14099 12689 37.6 79.0 179 BXRC-57E10K1-B-74-SE 5700 80 1800 15872 14285 52.0 93.6 170 BXRC-57E10K1-C-74-SE 5700 80 1710 20124 18112 69.4 118.7 170 BXRC-57E10K1-D-74-SE 5700 80 2100 13390 12051 37.6 79.0 170 BXRC-65C10K1-B-74-SE 6500 70 1800 16713 15041 52.0 93.6 179 BXRC-65C10K1-C-74-SE 6500 70 1710 21190 19071 69.4 118.7 179 BXRC-65C10K1-D-74-SE 6500 70 2100 14099 12689 37.6 79.0 179 BXRC-65E10K1-B-74-SE 6500 80 1800 16059 14453 52.0 93.6 172 BXRC-65E10K1-C-74-SE 6500 80 1710 20361 18325 69.4 118.7 172 BXRC-65E10K1-D-74-SE 6500 80 2100 13547 12192 37.6 79.0 172 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A10K1-B-73-SE 3000 80 93 1800 10767 9690 50.9 91.6 118 BXRC-30A10K1-C-73-SE 3000 80 93 1710 13651 12286 67.9 116.1 118 BXRC-30A10K1-D-73-SE 3000 80 93 2100 9083 8175 36.8 77.3 118 BXRC-35A10K1-B-73-SE 3500 80 93 1800 11462 10315 50.9 91.6 125 BXRC-35A10K1-C-73-SE 3500 80 93 1710 14532 13079 67.9 116.1 125 BXRC-35A10K1-D-73-SE 3500 80 93 2100 9669 8702 36.8 77.3 125 BXRC-40A10K1-B-73-SE 4000 80 93 1800 12417 11175 50.9 91.6 136 BXRC-40A10K1-C-73-SE 4000 80 93 1710 15743 14169 67.9 116.1 136 BXRC-40A10K1-D-73-SE 4000 80 93 2100 10475 9427 36.8 77.3 136 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Nominal CCT1 (K) Part Number CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 85 BXRC-17E10K0-B-74-SE 1750 80 1800 7731 6958 50.7 91.2 BXRC-17E10K0-C-74-SE 1750 80 1710 9802 8821 68.1 116.4 84 BXRC-17E10K0-D-74-SE 1750 80 2100 6522 5869 36.6 76.8 85 BXRC-20B10K1-C-73-SE 2000 65 1710 16727 15054 68.1 116.4 144 BXRC-20B10K1-D-73-SE 2000 65 2100 11129 10016 36.6 76.8 145 BXRC-25E10K0-B-74-SE 2500 80 1800 12856 11571 50.7 91.2 141 BXRC-25E10K0-C-74-SE 2500 80 1710 16301 14671 68.1 116.4 140 BXRC-25E10K0-D-74-SE 2500 80 2100 10846 9761 36.6 76.8 141 BXRC-27E10K0-B-7x-SE 2700 80 1800 13445 12100 50.7 91.2 147 BXRC-27E10K0-C-7x-SE 2700 80 1710 17046 15342 68.1 116.4 146 BXRC-27E10K0-D-7x-SE 2700 80 2100 11342 10208 36.6 76.8 148 BXRC-27G1KH0-B-7x-SE 2700 90 1800 11512 10361 50.7 91.2 126 BXRC-27G1KH0-C-7x-SE 2700 90 1710 14596 13136 68.1 116.4 125 BXRC-27G1KH0-D-7x-SE 2700 90 2100 9711 8740 36.6 76.8 127 BXRC-27G10K0-B-7x-SE 2700 90 1800 11092 9983 50.7 91.2 122 BXRC-27G10K0-C-7x-SE 2700 90 1710 14063 12657 68.1 116.4 121 BXRC-27G10K0-D-7x-SE 2700 90 2100 9357 8421 36.6 76.8 122 BXRC-27H10K0-D-74-SE 2700 97 2100 8294 7464 36.6 76.9 108 164 BXRC-30C10K1-B-74-SE 3000 70 1800 14957 13462 50.7 91.2 BXRC-30C10K1-C-74-SE 3000 70 1710 18964 17068 68.1 116.4 163 BXRC-30C10K1-D-74-SE 3000 70 2100 12618 11356 36.6 76.8 164 BXRC-30E10K0-B-7x-SE 3000 80 1800 14285 12856 50.7 91.2 157 BXRC-30E10K0-C-7x-SE 3000 80 1710 18112 16301 68.1 116.4 156 BXRC-30E10K0-D-7x-SE 3000 80 2100 12051 10846 36.6 76.8 157 BXRC-30G1KH0-B-7X-SE 3000 90 1800 12100 10890 50.7 91.2 133 BXRC-30G1KH0-C-7X-SE 3000 90 1710 15342 13808 68.1 116.4 132 BXRC-30G1KH0-D-7X-SE 3000 90 2100 10208 9187 36.6 76.8 133 BXRC-30G10K0-B-7x-SE 3000 90 1800 11596 10436 50.7 91.2 127 BXRC-30G10K0-C-7x-SE 3000 90 1710 14702 13232 68.1 116.4 126 BXRC-30G10K0-D-7x-SE 3000 90 2100 9782 8804 36.6 76.8 127 BXRC-30H10K0-D-7X-SE 3000 97 2100 8861 7975 36.6 76.8 115 7,8 BXRC-30A10K1-B-73-SE 3000 93 1800 10420 9378 50.7 91.2 114 BXRC-30A10K1-C-73-SE7,8 3000 93 1710 13211 11890 68.1 116.4 113 BXRC-30A10K1-D-73-SE7,8 3000 93 2100 8790 7911 36.6 76.8 114 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E10K0-B-7x-SE 3500 80 1800 14621 13159 50.7 91.2 160 BXRC-35E10K0-C-7x-SE 3500 80 1710 18538 16684 68.1 116.4 159 BXRC-35E10K0-D-7x-SE 3500 80 2100 12334 11101 36.6 76.8 161 132 BXRC-35G10K0-B-7x-SE 3500 90 1800 12016 10815 50.7 91.2 BXRC-35G10K0-C-7x-SE 3500 90 1710 15235 13712 68.1 116.4 131 BXRC-35G10K0-D-7x-SE 3500 90 2100 10137 9123 36.6 76.8 132 BXRC-35A10K1-B-73-SE7,8 3500 93 1800 11092 9983 50.7 91.2 122 BXRC-35A10K1-C-73-SE7,8 3500 93 1710 14063 12657 68.1 116.4 121 BXRC-35A10K1-D-73-SE7,8 3500 93 2100 9357 8421 36.6 76.8 122 BXRC-40C10K1-B-74-SE 4000 70 1800 15377 13840 50.7 91.2 169 BXRC-40C10K1-C-74-SE 4000 70 1710 19497 17547 68.1 116.4 167 BXRC-40C10K1-D-74-SE 4000 70 2100 12972 11675 36.6 76.8 169 BXRC-40E10K0-B-7x-SE 4000 80 1800 14705 13235 50.7 91.2 161 BXRC-40E10K0-C-7x-SE 4000 80 1710 18644 16780 68.1 116.4 160 BXRC-40E10K0-D-7x-SE 4000 80 2100 12405 11165 36.6 76.8 162 BXRC-40G10K0-B-7x-SE 4000 90 1800 12268 11041 50.7 91.2 135 BXRC-40G10K0-C-7x-SE 4000 90 1710 15555 13999 68.1 116.4 134 BXRC-40G10K0-D-7x-SE 4000 90 2100 10349 9314 36.6 76.8 135 BXRC-40H10K0-D-7X-SE 4000 97 2100 9357 8421 36.6 76.8 122 7,8 BXRC-40A10K1-B-73-SE 4000 93 1800 12016 10815 50.7 91.2 132 BXRC-40A10K1-C-73-SE7,8 4000 93 1710 15235 13712 68.1 116.4 131 BXRC-40A10K1-D-73-SE7,8 4000 93 2100 10137 9123 36.6 76.8 132 BXRC-50C10K1-B-7x-SE 5000 70 1800 15461 13915 50.7 91.2 170 BXRC-50C10K1-C-7x-SE 5000 70 1710 19603 17643 68.1 116.4 168 BXRC-50C10K1-D-7x-SE 5000 70 2100 13043 11739 36.6 76.8 170 163 BXRC-50E10K1-B-7x-SE 5000 80 1800 14873 13386 50.7 91.2 BXRC-50E10K1-C-7x-SE 5000 80 1710 18858 16972 68.1 116.4 162 BXRC-50E10K1-D-7x-SE 5000 80 2100 12547 11292 36.6 76.8 163 BXRC-50G10K1-B-7x-SE 5000 90 1800 12856 11571 50.7 91.2 141 BXRC-50G10K1-C-7x-SE 5000 90 1710 16301 14671 68.1 116.4 140 BXRC-50G10K1-D-7x-SE 5000 90 2100 10846 9761 36.6 76.8 141 BXRC-56G10K1-B-74-SE 5600 80 1800 12941 11646 50.7 91.2 142 BXRC-56G10K1-C-74-SE 5600 80 1710 16407 14766 68.1 116.4 141 BXRC-56G10Kx-D-74-SE 5600 80 2100 10916 9825 36.6 76.8 142 BXRC-56H10K0-D-74-SE 5600 97 2100 9853 8868 36.6 76.8 128 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 165 BXRC-57C10K1-B-7x-SE 5700 70 1800 15041 13537 50.7 91.2 BXRC-57C10K1-C-7x-SE 5700 70 1710 19071 17164 68.1 116.4 164 BXRC-57C10K1-D-7x-SE 5700 70 2100 12689 11420 36.6 76.8 165 BXRC-57E10K1-B-7x-SE 5700 80 1800 14285 12856 50.7 91.2 157 BXRC-57E10K1-C-7x-SE 5700 80 1710 18112 16301 68.1 116.4 156 BXRC-57E10K1-D-7x-SE 5700 80 2100 12051 10846 36.6 76.8 157 BXRC-65C10K1-B-7x-SE 6500 70 1800 15041 13537 50.7 91.2 165 BXRC-65C10K1-C-7x-SE 6500 70 1710 19071 17164 68.1 116.4 164 BXRC-65C10K1-D-7x-SE 6500 70 2100 12689 11420 36.6 76.8 165 BXRC-65E10K1-B-7x-SE 6500 80 1800 14453 13008 50.7 91.2 158 BXRC-65E10K1-C-7x-SE 6500 80 1710 18325 16492 68.1 116.4 157 BXRC-65E10K1-D-7x-SE 6500 80 2100 12192 10973 36.6 76.8 159 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 9 Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-17E10K0-B-74-SE 80 BXRC-17E10K0-C-74-SE 80 BXRC-17E10K0-D-74-SE 80 BXRC-20B10K1-C-73-SE 65 BXRC-20B10K1-D-73-SE 65 BXRC-25E10K0-B-74-SE 80 BXRC-25E10K0-C-74-SE 80 BXRC-25E10K0-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 4459 5871 8590 12382 15847 6187 7863 10891 15450 19365 3986 5130 7246 10316 13002 10558 13419 18585 26365 33047 6802 8754 12366 17604 22188 7416 9764 14285 20592 26355 10289 13077 18112 25694 32205 6628 8531 12051 17156 21623 4070 5337 7731 11042 13963 5887 7253 9802 13288 16272 3884 4774 6522 8692 10617 10047 12378 16727 22676 27768 6627 8147 11129 14833 18118 6769 8876 12856 18364 23221 9791 12063 16301 22099 27061 6459 7939 10846 14455 17657 100 97 92 85 79 109 103 92 84 76 107 101 92 83 75 187 175 157 143 130 183 173 157 142 128 166 161 153 141 131 182 170 153 139 127 178 168 153 138 125 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27E10K0-B-7x-SE 80 BXRC-27E10K0-C-7x-SE 80 BXRC-27E10K0-D-7x-SE 80 BXRC-27G1KH0-B-7x-SE 90 BXRC-27G1KH0-C-7x-SE 90 BXRC-27G1KH0-D-7x-SE 90 BXRC-27G10K0-B-7x-SE 90 BXRC-27G10K0-C-7x-SE 90 BXRC-27G10K0-D-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 7755 10211 14939 21534 27561 10759 13675 18940 26869 33678 6932 8921 12602 17941 22612 6640 8743 12791 18438 23599 9213 11709 16218 23007 28837 5935 7639 10790 15362 19361 6398 8424 12324 17765 22738 8877 11282 15626 22167 27784 5719 7360 10397 14801 18655 7079 9282 13445 19204 24283 10239 12615 17046 23110 28299 6754 8302 11342 15117 18464 6061 7948 11512 16444 20792 8767 10801 14596 19788 24231 5783 7109 9711 12944 15810 5840 7658 11092 15843 20033 8447 10407 14063 19065 23347 5572 6849 9357 12471 15233 174 169 160 147 137 190 178 160 145 132 186 176 160 144 131 149 144 137 126 117 163 153 137 124 113 160 151 137 124 112 143 139 132 122 113 157 147 132 120 109 154 145 132 119 108 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27H10K0-D-74-SE 97 BXRC-30C10K1-B-74-SE 70 BXRC-30C10K1-C-74-SE 70 BXRC-30C10K1-D-74-SE 70 BXRC-30E10K0-B-7x-SE 80 BXRC-30E10K0-C-7x-SE 80 BXRC-30E10K0-D-7x-SE 80 BXRC-30G1KH0-B-7x-SE 90 BXRC-30G1KH0-C-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 5069 6523 9215 13119 16535 9441 11999 16619 23576 29551 11590 14916 21071 29998 37808 7712 9925 14020 19959 25156 8240 10849 15872 22879 29283 11432 14530 20124 28549 35783 7365 9479 13390 19062 24025 6979 9190 13445 19380 24805 9683 12308 17046 24182 30310 4939 6071 8294 11054 13502 8984 11069 14957 20277 24831 11293 13882 18964 25276 30873 7514 9236 12618 16817 20542 7521 9862 14285 20404 25801 10878 13403 18112 24554 30068 7176 8821 12051 16062 19619 6371 8354 12100 17284 21855 9215 11353 15342 20799 25469 136 129 117 105 96 211 198 178 161 147 205 194 178 162 149 207 196 178 160 145 184 179 170 157 146 202 189 170 154 141 198 187 170 153 139 156 152 144 133 123 171 160 144 131 119 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G1KH0-D-7x-SE 90 BXRC-30G10K0-B-7x-SE 90 BXRC-30G10K0-C-7x-SE 90 BXRC-30G10K0-D-7x-SE 90 BXRC-30H10K0-D-7x-SE 97 BXRC-30A10K1-B-73-SE 93 BXRC-30A10K1-C-73-SE 93 BXRC-30A10K1-D-73-SE 93 BXRC-35E10K0-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 6239 8029 11342 16147 20351 6689 8807 12885 18573 23771 9280 11795 16336 23175 29047 5979 7694 10869 15474 19503 5415 6970 9845 14016 17665 6010 7914 11577 16689 21360 8339 10598 14679 20824 26100 5372 6914 9767 13904 17524 8434 11105 16246 23418 29972 6079 7472 10208 13605 16618 6106 8006 11596 16564 20944 8831 10880 14702 19932 24408 5825 7161 9782 13038 15926 5277 6486 8861 11810 14425 5486 7193 10420 14883 18819 7935 9776 13211 17910 21932 5234 6434 8790 11715 14310 7698 10094 14621 20884 26408 168 159 144 130 118 150 145 138 127 118 164 154 138 125 114 161 152 138 124 113 146 138 125 113 102 135 131 124 114 106 147 138 124 113 103 144 137 124 112 101 189 183 174 160 149 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35E10K0-C-7x-SE 80 BXRC-35E10K0-D-7x-SE 80 BXRC-35G10K0-B-7x-SE 90 BXRC-35G10K0-C-7x-SE 90 BXRC-35G10K0-D-7x-SE 90 BXRC-35A10K1-B-73-SE 93 BXRC-35A10K1-C-73-SE 93 BXRC-35A10K1-D-73-SE 93 BXRC-40C10K1-B-74-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 11701 14872 20598 29220 36625 7538 9702 13705 19511 24590 6931 9126 13351 19246 24632 9616 12222 16928 24014 30100 6195 7973 11263 16035 20209 6398 8424 12324 17765 22738 8877 11282 15626 22167 27784 5719 7360 10397 14801 18655 8870 11679 17086 24629 31523 11134 13718 18538 25132 30775 7345 9029 12334 16439 20080 6327 8296 12016 17164 21703 9151 11274 15235 20654 25292 6036 7420 10137 13511 16503 5840 7658 11092 15843 20033 8447 10407 14063 19065 23347 5572 6849 9357 12471 15233 8096 10616 15377 21965 27774 207 194 174 158 144 203 192 174 157 142 155 151 143 132 123 170 159 143 130 118 166 157 143 129 117 143 139 132 122 113 157 147 132 120 109 154 145 132 119 108 199 193 183 169 157 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40C10K1-C-74-SE 70 BXRC-40C10K1-D-74-SE 70 BXRC-40E10K0-B-7x-SE 80 BXRC-40E10K0-C-7x-SE 80 BXRC-40E10K0-D-7x-SE 80 BXRC-40G10K0-B-7x-SE 90 BXRC-40G10K0-C-7x-SE 90 BXRC-40G10K0-D-7x-SE 90 BXRC-40H10K0-D-7x-SE 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 1050 1400 2100 3150 4200 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 35.4 36.2 37.6 39.5 41.2 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 37.2 50.6 79.0 124.4 172.9 12306 15641 21663 30732 38519 7928 10203 14414 20520 25862 8482 11168 16339 23552 30145 11768 14957 20716 29388 36835 7582 9757 13783 19623 24732 7076 9318 13631 19649 25149 9818 12479 17283 24518 30731 6325 8140 11499 16371 20633 5719 7360 10397 14801 18655 11710 14428 19497 26432 32367 7725 9496 12972 17290 21119 7743 10152 14705 21004 26560 11198 13797 18644 25276 30952 7387 9081 12405 16534 20196 6459 8470 12268 17524 22158 9343 11511 15555 21087 25823 6163 7576 10349 13794 16849 5572 6849 9357 12471 15233 217 204 183 166 151 213 201 183 165 150 190 184 175 161 150 208 195 175 159 145 204 193 175 158 143 158 154 146 135 125 174 163 146 133 121 170 161 146 132 119 154 145 132 119 108 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40A10K1-B-73-SE 93 BXRC-40A10K1-C-73-SE 93 BXRC-40A10K1-D-73-SE 93 BXRC-50C10K1-B-74-SE 70 BXRC-50C10K1-C-74-SE 70 BXRC-50C10K1-D-74-SE 70 BXRC-50E10K1-B-74-SE 80 BXRC-50E10K1-C-74-SE 80 BXRC-50E10K1-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 6931 9126 13351 19246 24632 9616 12222 16928 24014 30100 6195 7973 11263 16035 20209 8918 11743 17179 24764 31695 12373 15726 21781 30900 38730 7971 10259 14492 20632 26004 8579 11296 16526 23822 30489 11903 15128 20953 29724 37256 7668 9869 13941 19847 25014 6327 8296 12016 17164 21703 9151 11274 15235 20654 25292 6036 7420 10137 13511 16503 8141 10674 15461 22085 27925 11774 14507 19603 26576 32544 7767 9548 13043 17384 21234 7831 10268 14873 21245 26863 11326 13955 18858 25565 31306 7472 9184 12547 16723 20426 155 151 143 132 123 170 159 143 130 118 166 157 143 129 117 200 194 184 170 158 219 205 184 167 152 214 203 184 166 150 192 187 177 163 152 210 197 177 161 146 206 195 177 160 145 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50G10K1-B-74-SE 90 BXRC-50G10K1-C-74-SE 90 BXRC-50G10K1-D-74-SE 90 BXRC-56G10K0-B-74-SE 80 BXRC-56G10K0-C-74-SE 80 BXRC-56G10K0-D-74-SE 80 BXRC-56H10K0-D-74-SE 80 BXRC-57C10K1-B-74-SE 70 BXRC-57C10K1-C-74-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 7416 9764 14285 20592 26355 10289 13077 18112 25694 32205 6628 8531 12051 17156 21623 7464 9828 14378 20726 26527 10356 13162 18230 25862 32415 6672 8586 12129 17268 21764 6022 7750 10948 15586 19644 8676 11424 16713 24091 30834 12037 15299 21190 30060 37677 6769 8876 12856 18364 23221 9791 12063 16301 22099 27061 6459 7939 10846 14455 17657 6813 8934 12941 18484 23372 9855 12141 16407 22243 27238 6501 7991 10916 14550 17772 5868 7213 9853 13133 16041 7920 10384 15041 21485 27167 11454 14112 19071 25854 31659 166 161 153 141 131 182 170 153 139 127 178 168 153 138 125 167 162 154 142 132 183 172 154 140 127 179 170 154 139 126 162 153 139 125 114 194 189 179 165 153 213 199 179 162 148 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57C10K1-D-74-SE 70 BXRC-57E10K1-B-74-SE 80 BXRC-57E10K1-C-74-SE 80 BXRC-57E10K1-D-74-SE 80 BXRC-65C10K1-B-74-SE 70 BXRC-65C10K1-C-74-SE 70 BXRC-65C10K1-D-74-SE 70 BXRC-65E10K1-B-74-SE 80 BXRC-65E10K1-C-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 7755 9980 14099 20071 25297 8240 10849 15872 22879 29283 11432 14530 20124 28549 35783 7365 9479 13390 19062 24025 8676 11424 16713 24091 30834 12037 15299 21190 30060 37677 7755 9980 14099 20071 25297 8337 10977 16059 23149 29628 11566 14701 20361 28884 36204 7556 9288 12689 16912 20657 7521 9862 14285 20404 25801 10878 13403 18112 24554 30068 7176 8821 12051 16062 19619 7920 10384 15041 21485 27167 11454 14112 19071 25854 31659 7556 9288 12689 16912 20657 7610 9978 14453 20644 26104 11006 13561 18325 24843 30421 208 197 179 161 146 184 179 170 157 146 202 189 170 154 141 198 187 170 153 139 194 189 179 165 153 213 199 179 162 148 208 197 179 161 146 187 181 172 158 147 204 192 172 156 142 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRC-65E10K1-D-7x-SE CRI Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 80 1050 1400 2100 3150 4200 35.4 36.2 37.6 39.5 41.2 37.2 50.6 79.0 124.4 172.9 7452 9590 13547 19286 24308 7261 8925 12192 16251 19849 200 189 172 155 141 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 19 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.06 46.1 57.5 -24.9 0.07 49.7 61.6 74.6 -33.2 0.04 61.5 76.8 74.4 80.0 -33.2 0.05 66.2 82.2 34.8 37.6 40.4 -17.4 0.06 33.4 41.6 38.1 41.2 44.3 -17.4 0.07 36.7 45.4 Minimum Typical Maximum 1800 48.1 52.0 55.9 -24.9 3600 51.7 55.8 60.0 1710 64.2 69.4 3420 68.8 2100 4200 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 20 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 1800 RG1 RG1 RG1 RG1 2700 RG1 RG1 RG2 RG2 3600 RG1 RG1 RG2 RG2 1710 RG1 RG1 RG1 RG2 2565 RG1 RG1 RG2 RG2 3420 RG1 RG2 RG2 RG2 2100 RG1 RG1 RG1 RG1 3150 RG1 RG1 RG1 RG2 4200 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero SE Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 21 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE Maximum Drive Current3 3600mA 3420mA 4200mA Maximum Peak Pulsed Drive Current4 5140mA 4890mA 6000mA Maximum Reverse Voltage5 -90V -120V -65V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN120: Assembly Considerations for Bridgelux Vero SE LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 22 Performance Curves Figure 2: Vero SE 29C Drive Current vs. Voltage 4000 4000 3500 3500 3000 3000 Forward Current (mA) Forward Current (mA) Figure 1: Vero SE 29B Drive Current vs. Voltage 2500 2000 1500 1000 2500 2000 1500 1000 500 0 500 47 48 49 50 51 52 53 54 55 56 57 0 58 63 64 65 66 67 68 Forward Voltage (V) Figure 3: Vero SE 29D Drive Current vs. Voltage 71 72 73 74 75 76 200% 180% 4000 160% Relative Luminous Flux 3500 Forward Current (mA) 70 Figure 4: Vero SE 29B Typical Relative Flux vs. Current 4500 3000 2500 2000 1500 1000 140% 120% 100% 80% 60% 40% 500 0 69 Forward Voltage (V) 20% 33 34 35 36 37 38 39 40 41 42 0% 0 Forward Voltage (V) 500 1000 1500 2000 2500 3000 3500 4000 Forward Current (mA) Figure 6 Vero SE 29D Typical Relative Flux vs. Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux Figure 5: Vero SE 29C Typical Relative Flux vs. Current 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0 400 800 1200 1600 2000 2400 Forward Current (mA) 2800 3200 3600 4000 0% 0 500 1000 1500 2000 2500 3000 3500 4000 4500 Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 23 Performance Curves Figure 7: Typical DC Flux vs. Case Temperature Figure 8: Typical DC ccy Shift vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 Neutral White Cool White 25°C Pulsed 125 Case Temperature (°C) Case Temperature (°C) Figure 10: 2000K, 65 CRI Color Shift vs. Case Temperature Figure 9: Typical DC ccx Shift vs. Case Temperature 0.4101 0 25 50 75 100 0.41 125 0.4099 0.000 0.4098 -0.002 Pulsed Center Point Tc=25°C 15°C 25°C 0.4097 ccy ccx Shift -0.004 -0.006 65°C 0.4093 Warm White -0.012 0.4095 0.4094 -0.008 -0.010 45°C 0.4096 Neutral White 85°C 0.4092 Cool White 25°C Pulsed 105°C 0.4091 Case Temperature (°C) 0.409 0.525 0.526 0.527 0.528 0.529 0.53 0.531 0.532 ccx Notes for Figures 7-9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. . For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 24 Performance Curves Figure 11: 1750K Color Shift vs. Case Temperature1 Figure 12: 2500K Color Shift vs. Case Temperature1 0.3705 0.4145 Pulsed Center Point Tc = 25°C 15°C 0.37 15°C 0.414 25°C 0.413 0.3695 0.369 ccy ccy 45°C 85°C 0.411 105°C 0.52 70°C 85°C 0.4115 0.3685 0.5198 45°C 0.4125 0.412 70°C 0.368 0.5196 0.5202 0.5204 105°C 0.4105 0.468 0.5206 0.47 0.472 Figure 13: 5600K Color Shift vs. Case Temperature1,3 0.369 0.342 25°C 0.338 25°C 0.367 0.366 0.336 45°C 0.334 ccy ccy 15°C 0.368 Pulsed Center Point Tc = 25°C 15°C 0.34 0.332 70°C 0.478 Pulsed Center Point Tc=25°C 45°C 0.365 0.364 70°C 0.363 85°C 0.328 0.476 Figure 14: 3000K Class A Color Shift vs. Case Temperature1 0.344 0.326 0.474 ccx ccx 0.33 Pulsed Center Point Tc = 25°C 0.4135 25°C 85°C 0.362 105°C 0.361 0.324 0.322 0.32 0.322 0.324 0.326 0.328 105°C 0.36 0.416 0.33 0.4165 0.417 ccx Figure 15: 3500K Class A Color Shift vs. Case Temperature1 ccx 0.4175 0.418 0.4185 Figure 16: 4000K Class A Color Shift vs. Case Temperature1 0.37 0.3760 15°C 0.368 Pulsed Center Point Tc=25°C 25°C 0.366 15°C 0.3740 25°C 0.3720 45°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.364 0.3680 70°C 0.362 85°C 0.36 85°C 0.3640 105°C 0.358 0.392 70°C 0.3660 105°C 0.393 0.394 0.395 0.396 0.397 ccx 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 Note for Figures 10-16: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Color shift shown for product hot targeted at Tc=85°C 25 Performance Curves Figure 17: Vero SE 29D Drive Current Derating Curve 4400 Drive Current (mA) 4200 4000 3960 3800 3600 3400 Max Drive Current LM-80 Max Drive Current 3200 0 10 20 30 40 50 60 70 80 90 100 110 Case Temperature (⁰C) Notes for Figure 17: 1. The maximum allowable drive current for the Vero 29D product is dependent on the operating case temperature. Please refer to the Product Feature Map (page 2) for the location of the Tc Point 2. LM-80 Max Drive Current must not be exceeded in order to meet LM-80 lifetime projections. 3. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these products. Contact your Bridgelux sales representative for LM-80 report. 26 Typical Radiation Pattern Figure 18: Typical Spatial Radiation Pattern Note for Figure 18: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 19: Typical Polar Radiation Pattern 27 Typical Color Spectrum Figure 20: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 20: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 21: Typical Color Spectrum for Vero SE 29 with Décor Series 1 17E 20B 0.9 25E 27H Relative Spectral Power Distribution 0.8 30H 56G 0.7 56H 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 21: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 28 Mechanical Dimensions Figure 22: Drawing for Vero SE 29 LED Array Notes for Figure 22: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 43.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 29 Color Binning Information Figure 23: Graph of Warm and Neutral White Test Bins in xy Color Space 0.44 2500K 4SDCM 3 SDCM 4 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2500K 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) - - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5167, 0.336) (0.4765, 0.4137) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Class A products. Please contact your Bridgelux Sales Representative for more information. Figure 24: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5600K1 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5475K - 5830K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) (0.3287, 0.3417) (0.3123, 0.3282) Note for Table 9: 1. Select configurations with a CCT of 5600K are available with center point targets at Tc = 85°C or Tc = 25°C. 30 Packaging and Labeling Figure 25: Drawing for Vero SE 29 Packaging Tray Notes for Figure 25: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 31 Packaging and Labeling Figure 26: Vero SE Series Packaging and Labeling Notes for Figure 26: 1. Each tray holds 50 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 27: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E10K0C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin definitions. 32 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN120 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 33 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vero SE 29 Array Series Product Data Sheet DS123 Rev. L (03/2019) 34
BXRC-65C10K1-D-74-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-65C10K1-D-74-SE”相匹配的价格&库存,您可以联系我们找货
  • 100+171.53692100+22.00306
