BXEB-TL-L0280Z-2750E1000-A-C3
    BRIDGELUX(普瑞)
BXEB-TL-L0280Z-2750E1000-A-C3 数据手册
Bridgelux Vesta™ Tunable Linear Gen 3 2 SMD Rows ® Product Data Sheet DS138 Lengths: 280mm, 560mm, 1120mm CRIs: 80, 90 CCT Ranges: 2700-5000K, 2700-6500K Product Feature Map Bridgelux Vesta Series Tunable White Linear (TL) modules are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The linear products incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the Vesta Series family of products. Multiple case temperature measurement points Polarity symbols Re-usable connector Zhaga compatible mounting holes Designed to comply with global safety standards for creepage and clearance distances Product Nomenclature The part number designation for Bridgelux Vesta Series TL Gen 3 with 2 SMD rows is explained as follows: 1,2,3,4 BXEB 5,6 7,8,9,10,11,12 13,14,15,16 - TL - L0560Z - 2750 17 18,19,20,21 G 2000 22 23 24 - A - C 3 Product Family Color Accuracy 3 = 3 SDCM Tunable White Linear Nominal Dimensions L = Linear 0280 = 280mm long 0560 = 560mm long 1120 = 1120mm long Z= Zhaga compatible width (31 mm) Version C = Gen 3 Configuration CCT Range 27 = 2700K 50 = 5000K 65 = 6500K Flux Designator 1000 = 1xxx lumen range 2000 = 2xxx lumen range 4000 = 4xxx lumen range Minimum CRI E = 80 CRI G = 90 CRI 2 Product Selection Guide Table 1: Product Performance (Tc = 25° C) Part Number BXEB-TL-L0280Z-2750E1000-A-C3 BXEB-TL-L0280Z-2765E1000-A-C3 BXEB-TL-L0280Z-2750G1000-A-C3 BXEB-TL-L0280Z-2765G1000-A-C3 BXEB-TL-L0560Z-2750E2000-A-C3 BXEB-TL-L0560Z-2765E2000-A-C3 BXEB-TL-L0560Z-2750G2000-A-C3 BXEB-TL-L0560Z-2765G2000-A-C3 BXEB-TL-L1120Z-2750E4000-A-C3 BXEB-TL-L1120Z-2765E4000-A-C3 BXEB-TL-L1120Z-2750G4000-A-C3 BXEB-TL-L1120Z-2765G4000-A-C3 Nominal Minimum 1 CRI CCT (K) 2700 5000 2700 80 6500 Typical Flux2,3 (lm) Nominal Drive Current (mA) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 1663 171 1836 189 1663 171 1826 500 19.4 9.7 188 2700 1418 5000 1556 160 1418 146 6500 1556 160 2700 3325 171 3672 189 3325 171 2700 5000 2700 90 80 146 6500 3652 2700 2836 5000 3111 160 2836 146 6500 3111 160 2700 6650 171 7344 189 2700 5000 2700 90 80 1000 19.4 19.4 188 146 6650 171 6500 7303 188 2700 5671 5000 2700 6500 90 1000 38.8 38.8 146 6222 160 5671 146 6222 160 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. Data is at nominal test current where temperature of center case temperature point Tc= 25° C. 3. Bridgelux maintains a ± 7% tolerance on typical flux data (typical SMD flux bins) 3 Electrical Characteristics Table 2: Electrical Characteristics Forward Voltage Tc2 Part Number Drive Current (mA) Voltages5 (V) Voltage4 Minimum 500 Driver Selection Typical Coefficient of Forward = 25º C (V) 1, 2,3 18.0 Typical 19.4 Maximum ∆Vf/∆T (mV/º C) 20.8 BXEB-TL-L0280Z-27xxE1000-A-C3 Vf Min, Hot Tc2 = 85º C (V) Vf Max, Cold Tc2 = -40º C (V) 17.7 21.1 19.2 22.8 17.7 21.1 19.2 22.8 17.7 21.1 19.2 22.8 17.7 21.1 19.2 22.8 35.4 42.3 38.4 45.7 35.4 42.3 38.4 45.7 -5.7 1000 19.5 21.0 22.5 500 18.0 19.4 20.8 BXEB-TL-L0280Z-27xxG1000-A-C3 -5.7 1000 19.5 21.0 22.5 1000 18.0 19.4 20.8 BXEB-TL-L0560Z-27xxE2000-A-C3 -5.7 2000 19.5 21.0 22.5 1000 18.0 19.4 20.8 BXEB-TL-L0560Z-27xxG2000-A-C3 -5.7 2000 19.5 21.0 22.5 1000 36.1 38.8 41.5 BXEB-TL-L1120Z-27xxE4000-A-C3 -11.4 2000 39.1 42.0 44.9 1000 36.1 38.8 41.5 BXEB-TL-L1120Z-27xxG4000-A-C3 -11.4 2000 39.1 42.0 44.9 Notes for Table 2: 1. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a tolerance of ± 0.1 V on forward voltage data. 3. This product has been designed and manufactured per IEC 62031:2014. The working voltage designated for the insulation is 60 Vdc. The maximum allowable voltage across the module must be determined in the end product application. 4. Typical coefficient of forward voltage tolerance is ± 0.1 mV for nominal current. 5. Vf min hot and max cold values are provided as reference only and are not guaranteed. These values are provided to aid in driver design and selection over the operating range of the product. 4 Absolute Maximum Ratings Table 3: Maximum Ratings Parameter Maximum Rating Storage Temperature -40°C to +85°C Operating Case Temperature2 (Tc) 85°C Soldering Temperature 350°C or lower for a maximum of 5 seconds Maximum Reverse Voltage Modules are not designed to be driven in reverse bias BXEB-TL-L0280Z-27xxy1000-A-C3 BXEB-TL-L0560Z-27xxy2000-A-C3 BXEB-TL-L1120Z-27xxy4000-A-C3 Drive Current, Maximum Combined3 1000 mA 2000 mA 2000 mA Drive Current, Maximum Per Channel3 1000 mA 2000 mA 2000 mA Notes for Table 3 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the SMDs used in the modules. Contact your Bridgelux sales representatives for LM-80 report. 3. The Maximum Combined Drive Current is defined as the sum of the drive currents in both channels. • Example #1: If 1000mA is applied to the 2700K (warm white) channel of the BXEB-TL-L0280Z-27xxy1000-A-C3 module, then 0mA may be applied to the alternate cool white channel. • Example #2: If 1500mA is applied to the cool white channel of the BXEB-TL-L0560Z-27xxy2000-A-C3 module, then a maximum of 500mA may be applied to the warm white channel. 5 Performance Curves Figure 1: Current vs. Forward Voltage (280mm only) Figure 2: Flux vs. Current (280mm only) 200% 180% 900 160% 750 Relative Flux Forward Current (mA) 1050 600 450 300 0% 18.50 19.00 19.50 20.00 Voltage (V) 20.50 0 21.00 900 1050 180% 1750 160% 1400 Relative Flux Forward Current (mA) 300 450 600 750 Forward Current (mA) 200% 1050 700 140% 120% 100% 80% 60% 40% 350 20% 0% 18.50 19.00 19.50 20.00 Voltage (V) 20.50 0 21.00 Figure 5: Current vs. Forward Voltage (1120mm only) 350 700 1050 1400 Forward Current (mA) 1750 2100 1750 2100 Figure 6: Flux vs. Current (1120mm only) 2100 200% 180% 1750 160% 1400 Relative Flux Forward Current (mA) 150 Figure 4: Flux vs. Current (560mm only) 2100 1050 700 140% 120% 100% 80% 60% 40% 350 0 36.00 80% 60% 20% Figure 3: Current vs. Forward Voltage (560mm only) 0 18.00 120% 100% 40% 150 0 18.00 140% 20% 0% 37.00 38.00 39.00 40.00 Voltage (V) 41.00 42.00 0 350 700 1050 1400 Forward Current (mA) Notes for Figures 1-6; 1. All measurements were performed at Tc=25C 6 Performance Curves Figure 7: Flux vs. Current Ratio (2700K-5000K) Figure 8: CCT vs. Current Ratio (2700K-5000K) 5000 100% 4500 96% CCT (K) Relative Flux 98% 94% 92% 88% 5000K 3500 3000 90% 2700K 4000 2500 0 0.0 1.0 0.2 0.4 0.6 0.8 0.2 0.4 0.6 0.8 0.8 Warm 0.6 0.4 Ratio 0.2 White Current Current Ratio 1.01 0.0 Figure 9: Flux vs. Current Ratio (2700K-6500K) 2700K 5000K 0 0.0 1.0 0.2 0.4 0.6 0.8 0.2 0.4 0.6 0.8 0.8 Warm 0.6 0.4 Ratio 0.2 White Current Current Ratio 1 1.0 0.0 Figure 10: CCT vs. Current Ratio (2700K-6500K) 6500 100% 6000 5500 96% CCT (K) Relative Flux 98% 94% 5000 4500 4000 3500 92% 3000 2500 90% 2700K 6500K 0 0.0 1.0 0.2 0.4 0.6 0.8 0.2 0.4 0.6 0.8 0.8 Warm 0.6 0.4 Ratio 0.2 White Current Current Ratio 1.01 0.0 2700K 6500K 0 0.0 1.0 0.2 0.4 0.6 0.8 0.2 0.4 0.6 0.8 0.8 Warm 0.6 0.4 Ratio 0.2 White Current Current Ratio 1 1.0 0.0 Notes for Figures 7-10; 1. All measurements were performed at Tc=25C 2. Current Ratio is calculated by dividing the channel with the lower drive current by the channel with the higher drive current. For example if the CW channel is operated at 1500mA and the WW channel is operated at 300mA, then the WW current ratio = 300/1500 = 0.2 7 Performance Curves Figure 11: Voltage vs Case Temperature 100.5% 25°C Pulsed Relative Voltage 100.0% 99.5% 99.0% 98.5% 98.0% 97.5% 0 20 40 60 Case Temperature (C) 80 100 Figure 12: Flux vs Case Temperature (2700K-5000K) 100.5% 25°C Pulsed Relatie Flux 98.5% 96.5% 94.5% 2700K 92.5% 5000K 90.5% 88.5% 0 20 40 60 Case Temperature (C) 80 100 Figure 13: Flux vs Case Temperature (2700K-6500K) 100.5% 25°C Pulsed Relative Flux 98.5% 96.5% 94.5% 2700K 92.5% 6500K 90.5% 88.5% 0 20 40 60 Case Temperature (C) 80 100 8 Typical Radiation Pattern Figure 14: Typical Spatial Radiation Pattern 120% Relative Intensity 100% 80% 60% 40% 20% 0% -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (°) Notes for Figure 14: 1. Typical viewing angle is 120⁰.FWHM 2. The viewing angle is defined as the full-width off-axis angle where the intensity is 50% of the peak value. 9 Typical Color Spectrum Figure 15: Typical Color Spectra, 80 CRI 100% 90% 80% Relative Intensity 70% 60% 27E 50% 50E 65E 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Figure 16: Typical Color Spectra, 90 CRI 100% 90% 80% Relative Intensity 70% 60% 27G 50% 50G 65G 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Note for Figures 15 & 16: 1. Color spectra measured at nominal current for Tc = 65°C 10 Mechanical Dimensions Figure 17: Drawing Overview for 280mm Figure 18: Drawing Overview for 560mm Figure 19: Drawing Overview for 1120mm Notes for Figures 17, 18 & 19: 1. Solder pads are labeled “+” to denote positive polarity, and “-” to denote negative polarity. 2. “WW” labels stand for Warm White and refer to the low CCT SMDs on the module (i.e. 2700K). “CW” labels stand for Cool White and refer to the high CCT SMDs on the module (i.e. 5000K or 6500K) 3. Dimensions are in millimeters. 4. Refer to Bridgelux assembly drawing 15-000715, 15-000716, and 15-000717 for complete product configuration Table 5: Module Dimensions & Connector Wiring Parameter BXEB-TL-L0280Z-27xxy1000-A-C3 BXEB-TL-L0560Z-27xxy2000-A-C3 BXEB-TL-L1120Z-27xxy4000-A-C3 Linear length 280.0 mm 560.0 mm 1120.0 mm Linear width 31 mm Overall thickness 5.6 mm PCB thickness 1.6 mm Input wire cross-section 18-24 AWG Wire strip length 7-9 mm 11 Color Binning Information Figure 20: 3 SDCM Color Bins in CIE 1931 xy Color Space 0.44 0.42 CIE y 0.40 0.38 0.36 0.34 0.32 0.30 0.30 0.32 0.34 0.36 0.38 0.40 0.42 0.44 0.46 0.48 0.50 CIE x Table 6: Bin Coordinates and Associated Typical CCT CCT Color Consistency CIE Center Point (x, y) Corresponding CCT Range 2700K 3 SDCM (0.458, 0.410) 2651K - 2794K 5700K 3 SDCM (0.329, 0.342) 5490K - 5820K 6500K 3 SDCM (0.312, 0.328) 6250K - 6745K Notes for Table 6 1. Color binning at solder point temperature Tsp of SMDs at 25°C for 80 CRI and 85°C for 90 CRI. 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. 3. Quadrangular ANSI bins shown for reference only 12 Packaging and Labeling Figure 21: Vesta Series Packaging and Labeling Note: This label & packaging diagram is for illustration only and may differ from actual product label and packaging for this product Table 7: Packaging Structure Box Parameter L0280 modules L0560 modules L1120 modules Quantity 320 160 160 Dimension 63.7 cm x 4.1.7 cm x 15.0 cm 63.7 cm x 4.1.7 cm x 15.0 cm 115.9 cm x 41.7 cm x 15.0 cm Figure 22: Product Labeling Bridgelux Vesta Series modules contain a label on the front to help with product identification. In addition to the product identification markings, Bridgelux Vesta Series modules also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the module. Vesta Series Gen3 280mm 1000lm 500mA Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. 13 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vesta Series product family. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vesta Series modules are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED linear. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vesta Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. Vesta Series linears are classified as Risk Group 1 (TBD) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch or apply stress to the module SMD LESs (yellow phosphor resin area). Contact may cause damage to the module. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the module. Use the mechanical features of the module housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the Vesta Series modules during operation. Allow the linear to cool for a sufficient period of time before handling. The Vesta Series maodules may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, module testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 14 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/Bridgelux WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 USA Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2020 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design and Vesta are registered trademarks of Bridgelux, Inc. EB Series and Bridging Light and Life are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vesta TL Gen3 2R Data Sheet DS138 Rev. A (06/2020) 15
BXEB-TL-L0280Z-2750E1000-A-C3 价格&库存
很抱歉,暂时无法提供与“BXEB-TL-L0280Z-2750E1000-A-C3”相匹配的价格&库存,您可以联系我们找货
  • 320+56.77958320+7.37865
