BXEM-57C-12H-6A-00-0-0
    BRIDGELUX(普瑞)
BXEM-57C-12H-6A-00-0-0 数据手册
Bridgelux SMD 3030 Gen2 1w 6v ® Product Data Sheet DS230 Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) | | | | | | | BXEM-22E 27x 30x 35x 40x 50x 57x 65x SMD 3030 SMD 3030 Introduction The Bridgelux SMD 3030 offers exceptional performance in a compact LED package. This high power LED is hot-color targeted which ensures that the LEDs fall within their specified color bin at the typical application conditions of 85°C. With its broad lumen coverage and wide range of CCT and CRI options, the SMD 3030 provides unparalleled design-in flexibility for indoor and outdoor lighting applications. Its high flux capability reduces the number of LEDs and enables industry leading system level lumen per dollar. The SMD 3030 is ideal as a drop in replacement for emitters with an industry standard 3.0mm x 3.0mm footprint. Features Benefits • Industry-standard 3030 footprint • Lower operating and manufacturing cost • Excellent color maintenance • Ease of design and rapid go-to-market • 9 bin color control • Uniform consistent white light • Superior luminous flux at maximum current for reduced LED count • Reliable and constant white point • Hot-color targeting ensures that color is within the ANSI bin at the typical application conditions of 85°C • Enables 3- and 5-step MacAdam ellipse custom binning kits • RoHS compliant and lead free • Multiple CCT and CRI configurations for a wide range of lighting applications Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) • Compliant with environmental standards • Design flexibility Contents Product Feature Map 2 Product Nomenclature 2 Product Test Conditions 2 Product Selection Guide 3 Electrical Characteristics 5 Absolute Maximum Ratings 6 Product Bin Definitions 7 Performance Curves 10 Typical Radiation Pattern 13 Typical Color Spectrum 14 Mechanical Dimensions 15 Reliability 16 Reflow Characteristics 17 Packaging 18 Design Resources 20 Precautions 20 Disclaimers 20 About Bridgelux 21 Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 1 Product Feature Map Bridgelux SMD LED products come in industry standard package sizes and follow ANSI binning standards. These LEDs are optimized for cost and performance, helping to ensure highly competitive system lumen per dollar performance while addressing the stringent efficacy and reliability standards required for modern lighting applications. Cathode Mark Yellow phosphor Light Emitting Surface (LES) Product Nomenclature The part number designation for Bridgelux SMD 3030 is explained as follows: 1 2 3 4 56 7 8 9 10 11 12 13 14 15 16 BXEM – 30 E - 12H – 6A – 00 - 0 - 0 Color Bin Options Product Family Forward Voltage Bins Nominal CCT 22 = 2,200K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 45 = 4,500K 50 = 5,000K 57 = 5,700K 65 = 6,500K Flux Bins Product Version Typical Forward Voltage Minimum CRI C = 70 CRI E = 80 CRI G = 90 CRI High Power Die count in series Die count in parallel Product Test Conditions Bridgelux SMD 3030 LEDs are tested and binned with a 10ms pulse of 150mA at Tj (junction temperature)=Tsp (solder point temperature) =25°C. Forward voltage and luminous flux are binned at a Tj=Tsp=25°C, while color is hot targeted at a Tsp of 85°C. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data at 150mA (Tj=Tsp=25°C) Forward Voltage4, 5 (V) Part Number1,6 Nominal CCT2 (K) CRI3, 5 Nominal Drive Current (mA) Typical Pulsed Flux (lm)4, 5 Typical Power (W) Min Typical Max BXEM-22E-12H-6A-00-0-0 2200 80 150 5.8 6.1 BXEM-27C-12H-6A-00-0-0 2700 70 150 5.8 6.1 6.6 114 0.9 126 6.6 145 0.9 159 Typical Efficcy (lm/W) BXEM-27E-12H-6A-00-0-0 2700 80 150 5.8 6.1 6.6 133 0.9 146 BXEM-27G-12H-6A-00-0-0 2700 90 150 5.8 6.1 6.6 117 0.9 128 BXEM-30C-12H-6A-00-0-0 3000 70 150 5.8 6.1 6.6 150 0.9 164 BXEM-30E-12H-6A-00-0-0 3000 80 150 5.8 6.1 6.6 137 0.9 150 BXEM-30G-12H-6A-00-0-0 3000 90 150 5.8 6.1 6.6 121 0.9 132 BXEM-35C-12H-6A-00-0-0 3500 70 150 5.8 6.1 6.6 154 0.9 169 BXEM-35E-12H-6A-00-0-0 3500 80 150 5.8 6.1 6.6 140 0.9 154 BXEM-35G-12H-6A-00-0-0 3500 90 150 5.8 6.1 6.6 124 0.9 136 BXEM-40C-12H-6A-00-0-0 4000 70 150 5.8 6.1 6.6 158 0.9 173 BXEM-40E-12H-6A-00-0-0 4000 80 150 5.8 6.1 6.6 144 0.9 158 BXEM-40G-12H-6A-00-0-0 4000 90 150 5.8 6.1 6.6 127 0.9 139 BXEM-45C-12H-6A-00-0-0 4500 70 150 5.8 6.1 6.6 158 0.9 173 BXEM-45E-12H-6A-00-0-0 4500 80 150 5.8 6.1 6.6 144 0.9 158 139 BXEM-45G-12H-6A-00-0-0 4500 90 150 5.8 6.1 6.6 127 0.9 BXEM-50C-12H-6A-00-0-0 5000 70 150 5.8 6.1 6.6 158 0.9 173 BXEM-50E-12H-6A-00-0-0 5000 80 150 5.8 6.1 6.6 144 0.9 158 BXEM-50G-12H-6A-00-0-0 5000 90 150 5.8 6.1 6.6 127 0.9 139 BXEM-57C-12H-6A-00-0-0 5700 70 150 5.8 6.1 6.6 155 0.9 170 BXEM-57E-12H-6A-00-0-0 5700 80 150 5.8 6.1 6.6 143 0.9 156 BXEM-57G-12H-6A-00-0-0 5700 90 150 5.8 6.1 6.6 126 0.9 139 BXEM-65C-12H-6A-00-0-0 6500 70 150 5.8 6.1 6.6 153 0.9 168 BXEM-65E-12H-6A-00-0-0 6500 80 150 5.8 6.1 6.6 141 0.9 155 BXEM-65G-12H-6A-00-0-0 6500 90 150 5.8 6.1 6.6 125 0.9 137 Notes for Table 1: 1. The last 6 characters (including hyphens ‘-’) refer to flux, forward voltage, and color bins, respectively. “00-0-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEM-30E-12H-6A-00-0-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 80CRI. 1x2 die configuration, high power, 6.25V typical forward voltage. 2. Product CCT is hot targeted at Tsp = 85°C. Nominal CCT as defined by ANSI C78.377-2011. 3. Listed CRIs are minimum values and include test tolerance. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where T­j=T­sp=25°C. 5. Bridgelux maintains a ±7.5% tolerance on luminous flux measurements, ±0.1V tolerance on forward voltage measurements, and ±2 tolerance on CRI measurements for the SMD 3030. 6. Refer to Table 5 and Table 6 for Bridgelux SMD 3030 Luminous Flux Binning and Forward Voltage Binning information. 7. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 3 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (T­sp = 85°C)6,7 Forward Voltage4 (V) Part Number1,5 Nominal CCT2 (K) CRI3, 4 Nominal Drive Current (mA) Typical DC Flux (lm)4 Typical Power (W) Min Typical Max BXEM-22E-12H-6A-00-0-0 2200 80 150 5.6 5.9 BXEM-27C-12H-6A-00-0-0 2700 70 150 5.6 5.9 6.3 102 0.9 117 6.3 129 0.9 144 132 Typical Effccy (lm/W) BXEM-27E-12H-6A-00-0-0 2700 80 150 5.6 5.9 6.3 119 0.9 BXEM-27G-12H-6A-00-0-0 2700 90 150 5.6 5.9 6.3 105 0.9 117 BXEM-30C-12H-6A-00-0-0 3000 70 150 5.6 5.9 6.3 134 0.9 149 BXEM-30E-12H-6A-00-0-0 3000 80 150 5.6 5.9 6.3 122 0.9 137 BXEM-30G-12H-6A-00-0-0 3000 90 150 5.6 5.9 6.3 108 0.9 120 153 BXEM-35C-12H-6A-00-0-0 3500 70 150 5.6 5.9 6.3 137 0.9 BXEM-35E-12H-6A-00-0-0 3500 80 150 5.6 5.9 6.3 126 0.9 140 BXEM-35G-12H-6A-00-0-0 3500 90 150 5.6 5.9 6.3 111 0.9 124 158 BXEM-40C-12H-6A-00-0-0 4000 70 150 5.6 5.9 6.3 141 0.9 BXEM-40E-12H-6A-00-0-0 4000 80 150 5.6 5.9 6.3 129 0.9 144 BXEM-40G-12H-6A-00-0-0 4000 90 150 5.6 5.9 6.3 114 0.9 127 BXEM-45C-12H-6A-00-0-0 4500 70 150 5.6 5.9 6.3 141 0.9 158 BXEM-45E-12H-6A-00-0-0 4500 80 150 5.6 5.9 6.3 129 0.9 144 BXEM-45G-12H-6A-00-0-0 4500 90 150 5.6 5.9 6.3 114 0.9 127 158 BXEM-50C-12H-6A-00-0-0 5000 70 150 5.6 5.9 6.3 141 0.9 BXEM-50E-12H-6A-00-0-0 5000 80 150 5.6 5.9 6.3 129 0.9 144 BXEM-50G-12H-6A-00-0-0 5000 90 150 5.6 5.9 6.3 114 0.9 127 155 BXEM-57C-12H-6A-00-0-0 5700 70 150 5.6 5.9 6.3 139 0.9 BXEM-57E-12H-6A-00-0-0 5700 80 150 5.6 5.9 6.3 127 0.9 142 BXEM-57G-12H-6A-00-0-0 5700 90 150 5.6 5.9 6.3 112 0.9 126 153 BXEM-65C-12H-6A-00-0-0 6500 70 150 5.6 5.9 6.3 137 0.9 BXEM-65E-12H-6A-00-0-0 6500 80 150 5.6 5.9 6.3 126 0.9 141 BXEM-65G-12H-6A-00-0-0 6500 90 150 5.6 5.9 6.3 111 0.9 124 Notes for Table 2: 1. The last 6 characters (including hyphens ‘-’) refer to flux, forward voltage, and color bins, respectively. “00-0-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEM-30E-12H-6A-00-0-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 80CRI. 1x2 die configuration, high power, 6.0V typical forward voltage. 2. Product CCT is hot targeted at Tsp = 85°C. Nominal CCT as defined by ANSI C78.377-2011. 3. Listed CRIs are minimum values and include test tolerance. 4. Bridgelux maintains a ±7.5% tolerance on luminous flux measurements, ±0.1V tolerance on forward voltage measurements, and ±2 tolerance on CRI measurements for the SMD 3030. 5. Refer to Table 5 and Table 6 for Bridgelux SMD 3030 Luminous Flux Binning and Forward Voltage Binning information. 6. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7. Typical performance is estimated based on operation under DC (direct current) with LED emitter mounted onto a heat sink with thermal interface material and the solder point temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 8. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 4 Electrical Characteristics Table 3: Electrical Characteristics Forward Voltage (V) 2,3 Part Number 1 BXEM-xxx-12H-6A-00-0-0 Drive Current (mA) Minimum Typical Maximum 5.8 6.1 6.6 150 Typical Temperature Coefficient of Forward Voltage ∆Vf/∆T (mV/ºC) Typical Thermal Resistance Junction to Solder Point4,5 R j-sp (C/W) -2.0 to -4.0 12 Notes for Table 3: 1. The last 6 characters (including hyphens ‘-’) refer to flux, forward voltage, and color bins, respectively. “00-0-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEM-30E-12H-6A-00-0-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 80CRI. 1x2 die configuration, high power, 6.0V typical forward voltage. 2. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Voltage minimum and maximum values at the nominal drive current are guaranteed by 100% test. 3. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tsp = 25°C. 4. Thermal Resistance values based on 3000K 80CRI product. 5. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 5 Absolute Maximum Ratings Table 4: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +100°C Operating Solder Point Temperature (TSp) -40°C to +100°C Soldering Temperature 260°C or lower for a maximum of 10 seconds Maximum Drive Current 240mA Maximum Peak Pulsed Forward Current1 480mA Maximum Reverse Voltage2 - Moisture Sensitivity Rating MSL 3 Electrostatic Discharge 2kV HBM. JEDEC-JS-001-HBM and JEDEC-JS-001-2012 Notes for Table 4: 1. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 10 ms when operating LED SMD at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED SMD can be driven without catastrophic failures. 2. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. no rating is provided. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 6 Product Bin Definitions Table 5 lists the standard photometric luminous flux bins for Bridgelux SMD 3030 LEDs. Although several bins are outlined, product availability in a particular bin varies by production run and by product performance. Not all bins are available in all CCTs. Table 5: Luminous Flux Bin Definitions at 150mA, Tsp=25°C Bin Code Minimum Maximum 09 90 100 10 100 110 11 110 120 12 120 130 13 130 140 14 140 150 15 150 160♤ ♥ 16 160 170 Unit Condition lm IF=150mA Unit Condition V IF=150mA Note for Table 5: 1. Bridgelux maintains a tolerance of ± 7.5% on luminous flux measurements. Table 6: Forward Voltage Bin Definition at 150mA, Tsp=25°C Bin Code Minimum Maximum P 5.8 6.0 Q 6.0 6.2 R 6.2 6.4 S 6.4 6.6 Note for Table 6: 1. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 7 Product Bin Definitions Table 7: 3- and 5-step MacAdam Ellipse Color Bin Definitions CCT 2200K 2700K 3000K 3500K 4000K 5000K 5700K 6500K Color Space Center Point Major Axis Minor Axis Ellipse Rotation Angle Color Bin X Y 3 SDCM 0.5018 0.4153 0.00863 0.00398 49.27 1 5 SDCM 0.5018 0.4153 0.01438 0.00663 49.27 1/A/B/C/D 3 SDCM 0.4578 0.4101 0.00810 0.00420 53.70 1 5 SDCM 0.4578 0.4101 0.01350 0.00700 53.70 1/A/B/C/D 3 SDCM 0.4338 0.4030 0.00834 0.00408 53.22 1 5 SDCM 0.4338 0.4030 0.01390 0.00680 53.22 1/A/B/C/D 3 SDCM 0.4073 0.3917 0.00927 0.00414 54.00 1 5 SDCM 0.4073 0.3917 0.01545 0.00690 54.00 1/A/B/C/D 3 SDCM 0.3818 0.3797 0.00939 0.00402 53.72 1 5 SDCM 0.3818 0.3797 0.01565 0.00670 53.72 1/A/B/C/D 3 SDCM 0.3447 0.3553 0.00822 0.00354 59.62 1 5 SDCM 0.3447 0.3553 0.01370 0.00590 59.62 1/A/B/C/D 3 SDCM 0.3287 0.3417 0.00746 0.00320 59.09 1 5 SDCM 0.3287 0.3417 0.01243 0.00533 59.09 1/A/B/C/D 3 SDCM 0.3123 0.3282 0.00669 0.00285 58.57 1 5 SDCM 0.3123 0.3282 0.01115 0.00475 58.57 1/A/B/C/D Notes for Table 7: 1. Color binning at Tsp=85°C 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 8 Product Bin Definitions Figure 1: C.I.E. 1931 Chromaticity Diagram (9 Color Bin Structure, Hot-color Targeted at Tsp=85°C) 2200K 0.43 E H A 0.42 2700K 0.435 0.425 E D 1 B C G 0.39 0.475 0.405 F 0.4 0.485 0.505 0.515 0.385 0.435 0.525 F G 0.395 0.495 B C 0.445 0.455 0.4300 0.4200 3000K 0.4200 0.485 3500K H 0.4000 E 1 0.4000 B C 0.3900 H D A y 0.4100 F G A 0.3900 D 1 B C 0.3800 0.3800 F G 0.3700 0.4200 0.4300 0.4400 0.4500 0.3600 0.3800 0.4600 0.3900 0.4000 0.4100 0.4100 0.4200 0.3800 4000K 0.4000 H 0.3700 D A 0.3800 B F C 0.3700 E 0.3600 1 D A 1 y E 0.4400 5000K H 0.3900 0.4300 x x B 0.3500 F C G 0.3400 0.3600 0.3500 0.3600 0.475 0.4100 E 0.3700 0.4100 0.465 x x y 1 y y 0.41 y H D A 0.415 0.3700 0.3800 0.3900 0.4000 G 0.3300 0.3300 0.4100 0.3400 0.3700 0.3500 0.3600 x x 6500K 5700K 0.3450 H 0.3600 H A 1 0.3400 0.3200 0.3180 E 1 A y y E 0.3300 0.3350 D 0.3500 D B 0.3250 B F F C C 0.3150 G G 0.3280 0.3380 x Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 0.3050 0.2980 0.3080 0.3180 0.3280 x 9 Performance Curves Figure 2: Drive Current vs. Voltage (Tsp=25°C) Forward Current(mA) 250 200 150 100 50 0 5.3 5.5 5.7 5.9 6.1 6.3 6.5 6.7 Forward Voltage(V) Figure 3: Typical Relative Luminous Flux vs. Drive Current (Tsp=25°C) 160% Relative Luminous Flux 140% 120% 100% 80% 60% 40% 20% 0% 0 50 100 150 200 250 300 Forward Current(mA) Note for Figure 3: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 10 Performance Curves Figure 4: Typical Relative DC Flux vs. Solder Point Temperature Relative Luminous Flux 100% 95% 90% 85% neutral white 80% 0 25 50 75 100 125 100 125 Solder Point Temperature(℃) Figure 5: Typical DC ccx Shift vs. Solder Point Temperature 0 ccx Shift -0.002 -0.004 -0.006 -0.008 neutral whilte -0.01 0 25 50 75 Solder Point Temperature(℃) Notes for Figures 4 & 5: 1. Characteristics shown for neutral white based on 4000K and 70 CRI. 2. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 11 Performance Curves Figure 6: Typical DC ccy Shift vs. Solder Point Temperature 0 ccy Shift -0.002 -0.004 -0.006 -0.008 neutral whilte -0.01 0 25 50 75 100 125 Solder Point Temperature(℃) Notes for Figure 6: 1. Characteristics shown for neutral white based on 4000K and 70 CRI. 2. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 12 Typical Radiation Pattern Figure 7: Typical Spatial Radiation Pattern at 150mA, Tsp=25°C Notes for Figure 7: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 8: Typical Polar Radiation Pattern at 150mA, Tsp=25°C Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 13 Typical Color Spectrum Figure 9: Typical Color Spectrum 100% 2700K 3000K 4000K 5000K 5700K 6500K Relative Radiant Power(%) 80% 60% 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength(nm) Note for Figure 9: 1. Color spectra measured at nominal current for Tsp = 25°C 2. Color spectra shown for 80 CRI products. Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 14 Mechanical Dimensions Figure 10: Drawing for SMD 3030 Notes for Figure 10: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. The optical center of the LED emitter is nominally defined by the mechanical center of the emitter. The light emitting surface (LES) is centered on the mechanical center of the LED emitter to a tolerance of ± 0.2 mm Recommended PCB Soldering Pad Pattern Bridgelux SMD 3030 Product Data Sheet DS230 Rev. A (08/2019) 15 Reliability Table 8: Reliability Test Items and Conditions No . Items R而非人eference Standard Test Conditions 1 Moisture/Reflow Sensitivity J-STD-020E 2 Low Temperature Storage 3 Drive Current Test Duration Units Failed/Tested Tsld = 260°C, 10sec, Precondition: 85°C, 60%RH, 168hr 3 reflows 0/22 JESD22-A119 Ta=-40°C 1000 hours 0/22 High Temperature Storage JESD22-A103D Ta=100°C 1000 hours 0/22 4 Low Temperature Operating Life JESD22-A108D Ta=-40°C 150mA 1000 hours 0/22 5 Temperature Humidity Operating Life JESD22-A101C Tsp=85°C℃, RH=85% 150mA 1000 hours 0/22 6 High Temperature Operating Life JESD22-A108D Tsp=105°C 240mA 1000 hours 0/22 7 Thermal Shock JESD22-A106B Ta=-40°C ~100°C; Dwell : 15min; Transfer: 10sec 200 Cycle 0/22 8 Temperature Cycle JESD22-A104E Ta=-40°C ~100°C; Dwell at extreme temperature: 15min; Ramp rate < 105°C/min 200 Cycle 0/22 9 Electrostatic Discharge JS-001-2012 HBM, 2KV, 1.5kΩ, 100pF, Alternately positive or negative 0/22 Passing Criteria Item Symbol Test Condition Passing Criteria Forward Voltage Vf 150mA ΔΔVf
BXEM-57C-12H-6A-00-0-0 价格&库存
很抱歉,暂时无法提供与“BXEM-57C-12H-6A-00-0-0”相匹配的价格&库存,您可以联系我们找货
