BXEN-18G-11M-3C-00-0-0
    BRIDGELUX(普瑞)
BXEN-18G-11M-3C-00-0-0 数据手册
Bridgelux SMD 2835 0.5W 3V ® Product Data Sheet DS242 Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) BXEN-18G|22G|27G| 30G| 35G| 40G| 50G| 57G| 65G SMD 2835 Introduction The Bridgelux SMD 2835 mid power LED is hot-color targeted, which ensures that the LEDs fall within their specified color bin at the typical application conditions of 85°C. With its broad lumen coverage and wide range of CCT options, the SMD 2835 provides unparalleled design-in flexibility for indoor and outdoor lighting applications. The SMD 2835 is ideal as a drop-in replacement for emitters with an industry standard 2.8mm x 3.5mm footprint. Features Benefits • Industry-standard 2835 footprint • Lower operating and manufacturing cost • 9 bin color control • Ease of design and rapid go-to-market • Hot-color targeting ensures that color is within the ANSI bin at the typical application conditions of 85°C • Uniform, consistent white light • Enables 3- and 5-step MacAdam ellipse custom binning kits • RoHS compliant and lead free • Multiple CCT configurations for a wide range of lighting applications Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) • Reliable and constant white point • Compliant with environmental standards • Design flexibility Contents Product Feature Map 2 Product Nomenclature 2 Product Test Conditions 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 4 Electrical Characteristics 5 Absolute Maximum Ratings 6 Product Bin Definitions 7 Performance Curves 10 Typical Radiation Pattern 13 Typical Color Spectrum 14 Mechanical Dimensions 15 Reliability 16 Reflow Characteristics 17 Packaging 18 Design Resources 20 Precautions 20 Disclaimers 20 About Bridgelux 21 Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 1 Product Feature Map Bridgelux SMD LED products come in industry standard package sizes and follow ANSI binning standards. These LEDs are optimized for cost and performance, helping to ensure highly competitive system lumen per dollar performance while addressing the stringent efficacy and reliability standards required for modern lighting applications. Cathode Mark Yellow phosphor Light Emitting Surface (LES) Product Nomenclature The part number designation for Bridgelux SMD 2835 is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 BXEN – 30 G – 1 1 M – 3 C – 00 – 0 – 0 Color Bin Options Product Family Nominal CCT 18 = 1,800K 22 = 2,200K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Forward Voltage Bins Flux Bins Minimum CRI G = 90 CRI Product Version Typical Forward Voltage Mid Power Die count in series Die count in parallel Product Test Conditions Bridgelux SMD 2835 LEDs are tested and binned with a 10ms pulse of 150mA at Tj (junction temperature)=Tsp (solder point temperature) =25°C. Forward voltage and luminous flux are binned at a Tj=Tsp=25°C.while color is hot targeted at a Tsp of 85°C Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data at 150mA (Tj=Tsp=25°C) Part Number1,6 Nominal CCT2 (K) CRI3, 5 Nominal Drive Current (mA) Forward Voltage4, 5 (V) Min Typical Max Typical Pulsed Flux (lm)4, 5 Typical Power (W) Typical Efficacy (lm/W) BXEN-18G-11M-3C-00-0-0 1800 90 150 2.8 3.0 3.2 42 0.5 93 BXEN-22G-11M-3C-00-0-0 2200 90 150 2.8 3.0 3.2 47 0.5 104 BXEN-27G-11M-3C-00-0-0 2700 90 150 2.8 3.0 3.2 58 0.5 129 BXEN-30G-11M-3C-00-0-0 3000 90 150 2.8 3.0 3.2 61 0.5 136 BXEN-35G-11M-3C-00-0-0 3500 90 150 2.8 3.0 3.2 62 0.5 138 BXEN-40G-11M-3C-00-0-0 4000 90 150 2.8 3.0 3.2 65 0.5 144 BXEN-50G-11M-3C-00-0-0 5000 90 150 2.8 3.0 3.2 65 0.5 144 BXEN-57G-11M-3C-00-0-0 5700 90 150 2.8 3.0 3.2 65 0.5 144 Typical Pulsed Flux (lm)5 Typical Power (W) Typical Efficacy (lm/W) Table 2: Selection Guide, Pulsed Test Performance (T = 85°C) ­ sp Part Number1,6 Nominal CCT2 (K) CRI3, 5 Nominal Drive Current (mA) 7,8 Forward Voltage5 (V) Min Typical Max BXEN-18G-11M-3C-00-0-0 1800 90 150 2.7 2.9 3.1 38 0.5 87 BXEN-22G-11M-3C-00-0-0 2200 90 150 2.8 3.0 3.2 43 0.5 99 BXEN-27G-11M-3C-00-0-0 2700 90 150 2.7 2.9 3.1 52 0.5 120 BXEN-30G-11M-3C-00-0-0 3000 90 150 2.7 2.9 3.1 55 0.5 126 BXEN-35G-11M-3C-00-0-0 3500 90 150 2.7 2.9 3.1 56 0.5 128 BXEN-40G-11M-3C-00-0-0 4000 90 150 2.7 2.9 3.1 58 0.5 134 BXEN-50G-11M-3C-00-0-0 5000 90 150 2.7 2.9 3.1 58 0.5 134 BXEN-57G-11M-3C-00-0-0 5700 90 150 2.7 2.9 3.1 58 0.5 134 Notes for Tables 1 & 2: 1. The last 6 characters (including hyphens ‘-’) refer to flux bins, forward voltage bins, and color bin options, respectively. “00-0-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEN-30G-11M-3C-00-0-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 90CRI, 1x1 die configuration, mid power, 3.0V typical forward voltage. 2. Product CCT is hot targeted at Tsp = 85°C. Nominal CCT as defined by ANSI C78.377-2011. 3. Listed CRIs are minimum values and include test tolerance. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tj=Tsp=25°C. 5. Bridgelux maintains a ±7.5% tolerance on luminous flux measurements, ±0.1V tolerance on forward voltage measurements, and ±2 tolerance on CRI measurements for the SMD 2835. 6. Refer to Table 6 and Table 7 for Bridgelux SMD 2835 Luminous Flux Binning and Forward Voltage Binning information. 7. Typical pulsed test performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under pulsed current with LED emitter mounted onto a heat sink with thermal interface material and the solder point temperature maintained at 25°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 3 Performance at Commonly Used Drive Currents SMD 2835 LEDs are tested to the specifications shown using the nominal drive currents in Table 1. SMD 2835 may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 2 and the relative luminous flux vs. current characteristics shown in Figure 3. The performance at commonly used drive currents is summarized in Table 3. Table 3: Performance at Commonly Used Drive Currents Part Number BXEN-18G-11M-3C-00-0-0 BXEN-22G-11M-3C-00-0-0 BXEN-27G-11M-3C-00-0-0 BXEN-30G-11M-3C-00-0-0 BXEN-35G-11M-3C-00-0-0 BXEN-40G-11M-3C-00-0-0 BXEN-50G-11M-3C-00-0-0 BXEN-57G-11M-3C-00-0-0 BXEN-65G-11M-3C-00-0-0 CRI 90 90 90 90 90 90 90 90 90 Typical Pulsed Flux2 Tsp = 25°C (lm) Typical DC Flux3 Tsp = 85°C (lm) Typical Efficacy Tsp = 25°C (lm/W) Drive Current1 (mA) Typical Vf Tsp = 25°C (V) Typical Power Tsp = 25°C (W) 30 2.69 0.1 9.1 8 113 42 2.74 0.1 12.6 10 110 60 2.78 0.2 17.8 15 107 90 2.86 0.3 26.2 22 102 120 2.93 0.4 34.2 28 97 150 3.00 0.5 42.0 38 93 30 2.69 0.1 9.9 9 126 42 2.74 0.1 13.8 13 123 60 2.78 0.2 19.6 18 119 90 2.86 0.3 29.0 27 114 120 2.93 0.4 38.1 35 108 150 3.00 0.5 47.0 43 104 30 2.69 0.1 12.6 11 156 42 2.74 0.1 17.5 14 152 60 2.78 0.2 24.6 21 148 90 2.86 0.3 36.2 30 141 120 2.93 0.4 47.2 39 134 150 3.00 0.5 58.0 52 129 30 2.69 0.1 13.2 12 164 42 2.74 0.1 18.4 15 160 60 2.78 0.2 25.9 22 156 90 2.86 0.3 38.1 32 148 120 2.93 0.4 49.7 41 141 150 3.00 0.5 61.0 55 136 30 2.69 0.1 13.4 12 166 42 2.74 0.1 18.7 15 162 60 2.78 0.2 26.3 22 158 150 90 2.86 0.3 38.7 32 120 2.93 0.4 50.5 41 144 150 3.00 0.5 62.0 56 138 30 2.69 0.1 14.1 13 174 42 2.74 0.1 19.6 16 170 60 2.78 0.2 27.6 23 166 90 2.86 0.3 40.6 34 158 120 2.93 0.4 52.9 43 151 150 3.00 0.5 65.0 58 144 30 2.69 0.1 14.1 13 174 42 2.74 0.1 19.6 16 170 60 2.78 0.2 27.6 23 166 90 2.86 0.3 40.6 34 158 120 2.93 0.4 52.9 43 151 150 3.00 0.5 65.0 58 144 30 2.69 0.1 14.1 13 174 42 2.74 0.1 19.6 16 170 60 2.78 0.2 27.6 23 166 90 2.86 0.3 40.6 34 158 120 2.93 0.4 52.9 43 151 150 3.00 0.5 65.0 58 144 30 2.69 0.1 14.1 13 174 42 2.74 0.1 19.6 16 170 60 2.78 0.2 27.6 23 166 90 2.86 0.3 40.6 34 158 120 2.93 0.4 52.9 43 151 150 3.00 0.5 65.0 58 144 Notes for Tables 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7.5% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 4 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage (V) 2,3 Part Number 1 BXEN-XXG-11M-3C-00-0-0 Drive Current (mA) Minimum Typical Maximum 2.8 3.0 3.2 150 Typical Temperature Coefficient of Forward Voltage ∆Vf/∆T (mV/ºC) Typical Thermal Resistance Junction to Solder Point4 R j-sp (ºC/W) -1.35 24 Notes for Tables 4: 1. The last 6 characters (including hyphens ‘-’) refer to flux bins, forward voltage bins, and color bin options, respectively. “00-0-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEN-30G-11M-3C-00-0-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 90CRI, 1x1 die configuration, mid power, 3.0V typical forward voltage. 2. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Voltage minimum and maximum values at the nominal drive current are guaranteed by 100% test. 3. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tsp = 25°C. 4. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 5 Absolute Maximum Ratings Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Solder Point Temperature (TSp) -40°C to +105°C Soldering Temperature 260°C or lower for a maximum of 10 seconds Maximum Drive Current 180mA Maximum Peak Pulsed Forward Current1 360mA Maximum Reverse Voltage2 - Moisture Sensitivity Rating MSL 3 Electrostatic Discharge 2kV HBM. JEDEC-JS-001-HBM and JEDEC-JS-001-2012 Notes for Tables 5: 1. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 10 ms when operating LED SMD at maximum peak pulsed current specified. Maximum peak pulsed current indicate values where LED SMD can be driven without catastrophic failures. 2. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. no rating is provided. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 6 Product Bin Definitions Table 6 lists the standard photometric luminous flux bins for Bridgelux SMD 2835 LEDs. Although several bins are listed, product availability in a particular bin varies by production run and by product performance. Not all bins are available in all CCTs. Table 6: Luminous Flux Bin Definitions at 150mA, Tsp=25°C Bin Code Minimum Maximum 28 40 ≦45 29 45 ≦50 2A 50 55 2B 55 60 2C 60 65 2D 65 70 2E 70 75 Unit Condition lm IF=150mA Unit Condition V IF=150mA Note for Tables 6: 1. Bridgelux maintains a tolerance of ± 7.5% on luminous flux measurements. Table 7: Forward Voltage Bin Definition at 150mA, Tsp=25°C Bin Code Minimum Maximum 2.8 9 2.7 A 2.8 2.9 B 2.9 3.0 C 3.0 3.1 D 3.1 3.2 Note for Tables 7: 1. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 7 Product Bin Definitions Table 8: 3- and 5-step MacAdam Ellipse Color Bin Definitions CCT 1800k ( Tsp=25°C) 2700K 3000K 3500K 4000K 5000K 5700K 6500K V-up H-right Center Minor Axis Ellipse Rotation Angle Color Bin 0.4081 0.0160 0.00765 53.70 5 0.4578 0.4101 0.00810 0.00420 53.70 1 0.4578 0.4101 0.01350 0.00700 53.70 1/A/B/C/D Y 5SDCM 0.5496 3 SDCM 5 SDCM 3 SDCM 0.4338 0.4030 0.00834 0.00408 53.22 1 5 SDCM 0.4338 0.4030 0.01390 0.00680 53.22 1/A/B/C/D 3 SDCM 0.4073 0.3917 0.00927 0.00414 54.00 1 5 SDCM 0.4073 0.3917 0.01545 0.00690 54.00 1/A/B/C/D 3 SDCM 0.3818 0.3797 0.00939 0.00402 53.72 1 5 SDCM 0.3818 0.3797 0.01565 0.00670 53.72 1/A/B/C/D 3 SDCM 0.3447 0.3553 0.00822 0.00354 59.62 1 5 SDCM 0.3447 0.3553 0.01370 0.00590 59.62 1/A/B/C/D 3 SDCM 0.3287 0.3417 0.00746 0.00320 59.09 1 1/A/B/C/D 5 SDCM 0.3287 0.3417 0.01243 0.00533 59.09 3 SDCM 0.3123 0.3282 0.00669 0.00285 58.57 1 5 SDCM 0.3123 0.3282 0.01115 0.00475 58.57 1/A/B/C/D 3000K 3500K 4000K 5000K 5700K 6500K Color Bin x y x y x y x y x y x y x y 0.4813 0.4319 0.4562 0.4260 0.4299 0.4165 0.4006 0.4044 0.3551 0.3760 0.3376 0.3616 0.3205 0.3481 0.4562 0.426 0.4299 0.4165 0.3996 0.4015 0.3736 0.3874 0.3376 0.3616 0.3207 0.3462 0.3028 0.3304 0.4373 0.3893 0.4147 0.3814 0.3889 0.3690 0.3670 0.3578 0.3366 0.3369 0.3222 0.3243 0.3068 0.3113 0.4593 0.3944 0.4373 0.3893 0.4147 0.3814 0.3898 0.3716 0.3515 0.3487 0.3366 0.3369 0.3221 0.3261 0.4687 0.4289 0.4431 0.4213 0.4148 0.4090 0.3871 0.3959 0.3463 0.3687 0.3290 0.3538 0.3115 0.3391 0.4618 0.4170 0.4377 0.4101 0.4112 0.3996 0.3847 0.3873 0.3457 0.3617 0.3290 0.3470 0.3124 0.3328 0.4483 0.3919 0.4260 0.3854 0.4018 0.3752 0.3784 0.3647 0.3440 0.3427 0.3290 0.3300 0.3144 0.3186 V-down H-left Major Axis X 2700K Point ANSI Center Point Color Space 0.4542 0.4031 0.4310 0.3960 0.4053 0.3844 0.3807 0.3730 0.3445 0.3495 0.3290 0.3369 0.3135 0.3250 0.4468 0.4077 0.4223 0.3990 0.3941 0.3848 0.3702 0.3722 0.3371 0.3490 0.3215 0.3350 0.3048 0.3207 0.4524 0.4089 0.4283 0.4013 0.4012 0.3885 0.3755 0.3755 0.3395 0.3509 0.3240 0.3372 0.3081 0.3240 0.4703 0.4132 0.4468 0.4077 0.4223 0.3990 0.3950 0.3875 0.3533 0.3620 0.3371 0.3490 0.3213 0.3373 0.4632 0.4115 0.4394 0.4052 0.4133 0.3945 0.3880 0.3834 0.3498 0.3592 0.3334 0.3456 0.3165 0.3325 0.4578 0.4101 0.4338 0.4030 0.4073 0.3917 0.3818 0.3797 0.3447 0.3553 0.3287 0.3417 0.3123 0.3282 CCT Center Point X 2200k Tsp=25°C 0.5382 Bin Code A Y Bin Code 1 Bin Code B X Y X Y X Y 0.5268 0.4661 0.5336 0.4608 0.5518 0.4467 0.5178 0.4547 0.5247 0.4493 0.5428 0.4352 0.5247 0.4493 0.5428 0.4352 0.5496 0.4299 0.5336 0.4608 0.5518 0.4467 0.5586 0.4414 0.448 E/F/ G/H Color Bin 1/A/B Notes for Tables 8: 1. Color binning at Tsp=85°C unless otherwise specified 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 8 Product Bin Definitions Figure 1: C.I.E. 1931 Chromaticity Diagram (9 Color Bin Structure, Hot-color Targeted at Tsp=85°C,18G /22G at Tsp=25°C) 1800K 2200K T =25℃ sp 0.47 0.4300 T =25℃ sp A 0.46 0.4200 1 y y 0.45 0.4100 B 0.44 0.4000 0.43 0.42 0.3900 0.5300 0.5400 0.5500 0.5600 x 0.51 0.5700 0.53 0.54 0.55 0.56 0.57 x 0.4300 2700K 0.435 0.52 3000K 0.4200 E 0.425 E H 0.405 0.385 0.435 0.3900 B F G F G 1 0.4000 C B C 0.395 y y 1 H D A D A 0.415 0.4100 0.3800 0.445 0.455 0.465 0.475 0.3700 0.4100 0.485 0.4200 0.4300 0.4400 0.4200 0.4100 3500K E A 0.3900 1 E 0.4100 D A 1 0.3800 B F B C 0.3800 H 0.3900 D y y 0.4000 4000K H 0.4000 F G C 0.3700 G 0.3600 0.3700 0.3900 0.4000 0.4100 0.4200 0.4300 0.3500 0.3600 0.4400 0.3700 0.3800 0.3800 0.3700 5000K H 0.3700 5700K 0.3600 H D y 1 B 0.3500 F E G 0.3300 0.3400 A 1 0.3400 B C 0.3300 0.3300 D 0.3500 A y E 0.3600 0.3900 x x 0.3400 0.4600 0.4000 0.4100 0.3600 0.3800 0.4500 x x 0.3500 0.3600 x 0.3200 0.3180 F C G 0.3280 0.3380 x 6500K 0.3450 H D 0.3350 E 1 y A B 0.3250 F C 0.3150 0.3050 0.2980 G 0.3080 0.3180 0.3280 x Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 9 Performance Curves Figure 2: Drive Current vs. Voltage (Tsp=25°C) 180 Forward Current(mA) 150 120 90 60 30 0 2.5 2.6 2.7 2.8 2.9 Forward Voltage(V) 3.0 3.1 150 180 Figure 3: Typical Relative Luminous Flux vs. Drive Current (Tsp=25°C) 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 0 30 60 90 120 Forward Current(mA) Note for Figure 3: 1. Bridgelux does not recommend driving mid power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 10 Performance Curves Figure 4: Typical Relative Flux vs. Solder Point Temperature Relative Luminous Flux 100% 95% 90% warm white 85% 80% neutral white cool white 0 25 50 75 100 Solder Point Temperature(℃) 125 Figure 5: Typical ccx Shift vs. Solder Point Temperature 0.000 ccx Shift -0.002 -0.004 warm white -0.006 -0.008 neutral white cool white 0 25 50 75 100 Solder Point Temperature(℃) 125 Notes for Figures 4 & 5: 1. Characteristics shown for warm white based on 3000K and 90 CRI. 2. Characteristics shown for neutral white based on 4000K and 90 CRI. 3. Characteristics shown for cool white based on 5000K and 90 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 11 Performance Curves Figure 6: Typical ccy Shift vs. Solder Point Temperature 0.000 -0.002 ccy Shift -0.004 -0.006 -0.008 warm white -0.010 -0.012 neutral white cool white 0 25 50 75 100 Solder Point Temperature(℃) 125 Notes for Figure 6: 1. Characteristics shown for warm white based on 3000K and 90 CRI. 2. Characteristics shown for neutral white based on 4000K and 90 CRI. 3. Characteristics shown for cool white based on 5000K and 90 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 12 Typical Radiation Pattern Figure 7: Typical Spatial Radiation Pattern at 150mA, Tsp=25°C Relative Intensity 100% 80% 60% 40% 20% 0% -90 -75 -60 -45 -30 -15 0 15 30 45 60 75 90 Angular Displacement (⁰) Notes for Figure 7: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where luminous intensity (Iv) is ½ of the peak value. Figure 8: Typical Polar Radiation Pattern at 150mA, Tsp=25°C 0° 30° Radiation Angle -30° -90° 100 -60° 60° 90° 50 0 50 100 Relative Luminosity Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 13 Typical Color Spectrum Figure 9: Typical Color Spectrum Relative Radiant Power(%) 100% 3000K 4000K 80% 5000K 60% 40% 20% 0% 400 450 500 550 600 650 Wavelength(nm) 700 750 800 Notes for Figure 9: 1. Color spectra measured at nominal current for Tsp = 25°C 2. Color spectra shown for 90 CRI products. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 14 Mechanical Dimensions Figure 10: Drawing for SMD 2835 Notes for Figure 10: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Different mould pattern differences may 4. Unless otherwise specified, tolerances are ± 0.10mm. Bridgelux SMD 2835 0.5W 3V Product Data Sheet DS242 Rev. B (04/2020) 15 Reliability Table 9: Reliability Test Items and Conditions No . Items R而非人eference Standard Test Conditions Drive Current Test Duration Units Failed/Tested 1 Moisture/Reflow Sensitivity J-STD-020E Tsld = 260°C, 10sec, Precondition: 60°C, 60%RH, 168hr - 3 reflows 0/22 2 Low Temperature Storage JESD22-A119 Ta=-40°C - 1000 hours 0/22 3 High Temperature Storage JESD22-A103D Ta= 100°C - 1000 hours 0/22 4 Low Temperature Operating Life JESD22-A108D Ta=-40°C 150mA 1000 hours 0/22 5 Temperature Humidity Operating Life JESD22-A101C Tsp=85°C℃, RH=85% 150mA 1000 hours 0/22 6 High Temperature Operating Life JESD22-A108D Tsp=85°C 180mA 1000 hours 0/22 7 Power switching IEC62717:2014 Tsp= 85°C 30 sec on, 30 sec off 180mA 30000 cycles 0/22 8 Thermal Shock JESD22-A106B Ta=-40°C ~100°C; Dwell : 15min; Transfer: 10sec - 200 cycles 0/22 9 Temperature Cycle JESD22-A104E Ta=-40°C ~100°C; Dwell at extreme temperature: 15min; Ramp rate < 105°C/min - 200 cycles 0/22 10 Electrostatic Discharge JS-001-2012 HBM, 2KV, 1.5kΩ, 100pF, Alternately positive or negative - - 0/22 Passing Criteria Item Symbol Test Condition Passing Criteria Forward Voltage Vf 150mA ΔΔVf
BXEN-18G-11M-3C-00-0-0 价格&库存
很抱歉,暂时无法提供与“BXEN-18G-11M-3C-00-0-0”相匹配的价格&库存,您可以联系我们找货
