BXRC-27G40H0-B-73-SE
    BRIDGELUX(普瑞)
BXRC-27G40H0-B-73-SE 数据手册
Bridgelux Vero SE 18 Array ® ® Product Data Sheet DS122 1 Vero SE Introduction Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s seventh generation COB technology with poke-in connectivity enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing cost, simplify luminaire design, improve light quality and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is also a good replacement for halogen lamps. Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series ™ Entertainment products provide color points developed specifically for the healthcare and entertainment industries. The 5600K cool white color point combined with a CRI of 90 or 97 provides the bright white required by these industries. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features • Poke-in connectivity • Efficacy of 157 lm/W typical • Lumen output performance ranges from 1,372 to 13,060 lumens Benefits • Poke-in connectivity enables solderless, connector free installation • Broad application coverage for interior and exterior lighting • Broad range of CCT options from 1750K to 6500K • Flexibility for application driven lighting design requirements • CRI options: minimum 65, 70, 80, and 90 • High quality, true color reproduction • Color control: 2 and 3 SDCM for 2700K-4000K CCT • Uniform consistent white light • Reliable operation at up to 2X nominal drive current • Flexibility in design optimization • Radial die pattern and improved lumen density • Enhanced ease of use and assembly • Top side part number markings • Ability to configure multiple Vero SE arrays in series and parallel reduces customer driver cost • No exposed solder pads or electrical connections • Vf bin code backside marking • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 20 Eye Safety 21 Absolute Maximum Ratings 22 Performance Curves 23 Typical Radiation Pattern 27 Typical Color Spectrum 28 Mechanical Dimensions 29 Color Binning Information 30 Packaging and Labeling 31 Design Resources 33 Precautions 33 Disclaimers 33 About Bridgelux 34 1 Product Feature Map Vero SE 18 is the second largest form factor in the product family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www. bridgelux.com for more information on the Vero SE family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 Tc Measurement point Optic mounting holes Radial die configuration improves lumen density and beam control Mounting holes Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 400 0 – C – 7 3 – SE Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 7 Array Configuration CRI B = 65 CRI min. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Target Flux Indicator 400x = 4000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) 80 900 2725 2452 80 1170 3542 3188 Part Number Nominal CCT1 (K) CRI2 BXRC-17E4000-B-74-SE 1750 BXRC-17E4000-C-74-SE 1750 Typical Power (W) Typical Efficacy (lm/W) 34.8 31.3 87 34.8 40.7 87 BXRC-17E4000-D-74-SE 1750 80 1050 2649 2384 29.0 30.5 87 BXRC-20B4000-C-73-SE 2000 65 1170 5985 5387 34.8 40.7 147 BXRC-20B4000-D-73-SE 2000 65 1050 4476 4029 29.0 30.5 147 BXRC-25E4000-B-74-SE 2500 80 900 4416 3975 34.8 31.3 141 BXRC-25E4000-C-74-SE 2500 80 1170 5741 5167 34.8 40.7 141 BXRC-25E4000-D-74-SE 2500 80 1050 4293 3864 29.0 30.5 141 BXRC-27E4000-B-7X-SE 2700 80 900 4729 4256 34.8 31.3 151 151 BXRC-27E4000-C-7X-SE 2700 80 1170 6148 5533 34.8 40.7 BXRC-27E4000-D-7X-SE 2700 80 1050 4598 4138 29.0 30.5 151 BXRC-27G40H0-B-7X-SE 2700 90 900 4072 3664 34.8 31.3 130 BXRC-27G40H0-C-7X-SE 2700 90 1170 5293 4764 34.8 40.7 130 BXRC-27G40H0-D-7X-SE 2700 90 1050 3959 3563 29.0 30.5 130 BXRC-27G4000-B-7X-SE 2700 90 900 3946 3552 34.8 31.3 126 BXRC-27G4000-C-7X-SE 2700 90 1170 5130 4617 34.8 40.7 126 BXRC-27G4000-D-7X-SE 2700 90 1050 3837 3453 29.0 30.5 126 BXRC-27H4000-B-7x-SE 2700 97 900 3414 3072 34.8 31.3 109 BXRC-27H4000-C-7x-SE 2700 97 1170 4438 3994 34.8 40.7 109 BXRC-27H4000-D-7x-SE 2700 97 1050 3319 2987 29.0 30.5 109 BXRC-30C4001-B-74-SE 3000 70 900 5387 4848 34.8 31.3 172 BXRC-30C4001-C-74-SE 3000 70 1170 7003 6303 34.8 40.7 172 BXRC-30C4001-D-74-SE 3000 70 1050 5237 4714 29.0 30.5 172 BXRC-30E4000-B-7X-SE 3000 80 900 4917 4426 34.8 31.3 157 BXRC-30E4000-C-7X-SE 3000 80 1170 6392 5753 34.8 40.7 157 BXRC-30E4000-D-7X-SE 3000 80 1050 4781 4303 29.0 30.5 157 BXRC-30G40H0-B-7X-SE 3000 90 900 4291 3862 34.8 31.3 137 BXRC-30G40H0-C-7X-SE 3000 90 1170 5578 5020 34.8 40.7 137 BXRC-30G40H0-D-7X-SE 3000 90 1050 4172 3754 29.0 30.5 137 BXRC-30G4000-B-7X-SE 3000 90 900 4103 3693 34.8 31.3 131 BXRC-30G4000-C-7X-SE 3000 90 1170 5334 4800 34.8 40.7 131 BXRC-30G4000-D-7X-SE 3000 90 1050 3989 3590 29.0 30.5 131 BXRC-30G400C-B-73-SE 3000 90 900 3790 3411 34.8 31.3 121 BXRC-30G400C-D-73-SE 3000 90 1050 3684 3316 29.0 30.5 121 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30H4000-B-7x-SE 3000 97 900 3664 3298 34.8 31.3 117 BXRC-30H4000-C-7x-SE 3000 97 1170 4764 4287 34.8 40.7 117 BXRC-30H4000-D-7x-SE 3000 97 1050 3563 3206 29.0 30.5 117 BXRC-30A4001-B-73-SE8,9 3000 93 900 3696 3326 34.8 31.3 118 BXRC-30A4001-C-73-SE8,9 3000 93 1170 4804 4324 34.8 40.7 118 BXRC-30A4001-D-73-SE8,9 3000 93 1050 3593 3234 29.0 30.5 118 BXRC-35E4000-B-7X-SE 3500 80 900 5074 4566 34.8 31.3 162 BXRC-35E4000-C-7X-SE 3500 80 1170 6596 5936 8,9 34.8 40.7 162 BXRC-35E4000-D-7X-SE 3500 80 1050 4933 4440 29.0 30.5 162 BXRC-35G4000-B-7X-SE 3500 90 900 4228 3805 34.8 31.3 135 BXRC-35G4000-C-7X-SE 3500 90 1170 5497 4947 34.8 40.7 135 BXRC-35G4000-D-7X-SE 3500 90 1050 4111 3700 29.0 30.5 135 BXRC-35A4001-B-73-SE8,9 3500 93 900 3978 3580 34.8 31.3 127 BXRC-35A4001-C-73-SE8,9 3500 93 1170 5171 4654 34.8 40.7 127 BXRC-35A4001-D-73-SE8,9 3500 93 1050 3867 3480 29.0 30.5 127 BXRC-40C4001-B-74-SE 4000 90 900 5544 4989 34.8 31.3 177 177 BXRC-40C4001-C-74-SE 4000 90 1170 7207 6486 34.8 40.7 BXRC-40C4001-D-74-SE 4000 90 1050 5390 4851 29.0 30.5 177 BXRC-40E4000-B-7X-SE 4000 80 900 5105 4595 34.8 31.3 163 163 BXRC-40E4000-C-7X-SE 4000 80 1170 6637 5973 34.8 40.7 BXRC-40E4000-D-7X-SE 4000 80 1050 4963 4467 29.0 30.5 163 BXRC-40G4000-B-7X-SE 4000 90 900 4385 3946 34.8 31.3 140 BXRC-40G4000-C-7X-SE 4000 90 1170 5700 5130 34.8 40.7 140 BXRC-40G4000-D-7X-SE 4000 90 1050 4263 3837 29.0 30.5 140 BXRC-40H4000-B-7X-SE 4000 97 900 3758 3383 34.8 31.3 120 BXRC-40H4000-C-7X-SE 4000 97 1170 4886 4397 34.8 40.7 120 BXRC-40H4000-D-7X-SE 4000 97 1050 3654 3289 29.0 30.5 120 BXRC-40A4001-B-73-SE8,9 4000 93 900 4260 3834 34.8 31.3 136 BXRC-40A4001-C-73-SE8,9 4000 93 1170 5537 4984 34.8 40.7 136 BXRC-40A4001-D-73-SE8,9 4000 93 1050 4141 3727 29.0 30.5 136 BXRC-50C4001-B-74-SE 5000 70 900 5606 5046 34.8 31.3 179 BXRC-50C4001-C-74-SE 5000 70 1170 7288 6559 34.8 40.7 179 BXRC-50C4001-D-74-SE 5000 70 1050 5451 4905 29.0 30.5 179 BXRC-50E4001-B-74-SE 5000 80 900 5262 4736 34.8 31.3 168 BXRC-50E4001-C-74-SE 5000 80 1170 6840 6156 34.8 40.7 168 BXRC-50E4001-D-74-SE 5000 80 1050 5116 4604 29.0 30.5 168 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-50G4001-B-74-SE 5000 90 900 4479 4031 34.8 31.3 143 BXRC-50G4001-C-74-SE 5000 90 1170 5822 5240 34.8 40.7 143 BXRC-50G4001-D-74-SE 5000 90 1050 4354 3919 29.0 30.5 143 BXRC-56G4000-B-74-SE 5600 90 900 4698 4228 34.8 31.3 150 BXRC-56G4000-C-74-SE 5600 90 1170 6107 5497 34.8 40.7 150 BXRC-56G4000-D-74-SE 5600 90 1050 4568 4111 29.0 30.5 150 BXRC-56H4000-D-74-SE 5600 97 1050 3959 3563 29.0 30.5 130 BXRC-57C4001-B-74-SE 5700 70 900 5418 4877 34.8 31.3 173 BXRC-57C4001-C-74-SE 5700 70 1170 7044 6339 34.8 40.7 173 BXRC-57C4001-D-74-SE 5700 70 1050 5268 4741 29.0 30.5 173 BXRC-57E4001-B-74-SE 5700 80 900 5199 4679 34.8 31.3 166 BXRC-57E4001-C-74-SE 5700 80 1170 6759 6083 34.8 40.7 166 BXRC-57E4001-D-74-SE 5700 80 1050 5055 4549 29.0 30.5 166 BXRC-65C4001-B-74-SE 6500 70 900 5512 4961 34.8 31.3 176 BXRC-65C4001-C-74-SE 6500 70 1170 7166 6449 34.8 40.7 176 BXRC-65C4001-D-74-SE 6500 70 1050 5359 4823 29.0 30.5 176 BXRC-65E4001-B-74-SE 6500 80 900 5293 4764 34.8 31.3 169 BXRC-65E4001-C-74-SE 6500 80 1170 6881 6193 34.8 40.7 169 BXRC-65E4001-D-74-SE 6500 80 1050 5146 4631 29.0 30.5 169 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A4001-B-73-SE 3000 80 93 900 3437 3093 34.3 30.9 111 BXRC-30A4001-C-73-SE 3000 80 93 1170 4468 4021 34.3 40.2 111 BXRC-30A4001-D-73-SE 3000 80 93 1050 3342 3007 28.5 29.9 112 BXRC-35A4001-B-73-SE 3500 80 93 900 3699 3329 34.3 30.9 120 BXRC-35A4001-C-73-SE 3500 80 93 1170 4809 4328 34.3 40.2 120 BXRC-35A4001-D-73-SE 3500 80 93 1050 3596 3237 28.5 29.9 120 BXRC-40A4001-B-73-SE 4000 80 93 900 3961 3565 34.3 30.9 128 BXRC-40A4001-C-73-SE 4000 80 93 1170 5150 4635 34.3 40.2 128 BXRC-40A4001-D-73-SE 4000 80 93 1050 3851 3466 28.5 29.9 129 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-17E4000-B-74-SE 1750 80 900 2452 2207 33.9 30.5 80 BXRC-17E4000-C-74-SE 1750 80 1170 3188 2869 33.9 39.7 80 BXRC-17E4000-D-74-SE 1750 80 1050 2384 2146 28.3 29.7 80 BXRC-20B4000-C-73-SE 2000 65 1170 5387 4848 34.1 39.9 135 BXRC-20B4000-D-73-SE 2000 65 1050 4029 3626 28.3 29.7 136 BXRC-25E4000-B-74-SE 2500 80 900 3975 3577 33.9 30.5 130 BXRC-25E4000-C-74-SE 2500 80 1170 5167 4650 33.9 39.7 130 BXRC-25E4000-D-74-SE 2500 80 1050 3864 3478 28.3 29.7 130 BXRC-27E4000-B-7X-SE 2700 80 900 4256 3831 33.9 30.5 139 BXRC-27E4000-C-7X-SE 2700 80 1170 5533 4980 33.9 39.7 139 BXRC-27E4000-D-7X-SE 2700 80 1050 4138 3724 28.3 29.7 139 BXRC-27G40H0-B-7X-SE 2700 90 900 3664 3298 33.9 30.5 120 BXRC-27G40H0-C-7X-SE 2700 90 1170 4764 4287 33.9 39.7 120 BXRC-27G40H0-D-7X-SE 2700 90 1050 3563 3206 28.3 29.7 120 BXRC-27G4000-B-7X-SE 2700 90 900 3552 3197 33.9 30.5 116 BXRC-27G4000-C-7X-SE 2700 90 1170 4617 4155 33.9 39.7 116 BXRC-27G4000-D-7X-SE 2700 90 1050 3453 3108 28.3 29.7 116 BXRC-27H4000-B-7x-SE 2700 97 900 3072 2765 33.9 30.5 101 101 BXRC-27H4000-C-7x-SE 2700 97 1170 3994 3595 33.9 39.7 BXRC-27H4000-D-7x-SE 2700 97 1050 2987 2688 28.3 29.7 101 BXRC-30C4001-B-74-SE 3000 70 900 4848 4364 33.9 30.5 159 BXRC-30C4001-C-74-SE 3000 70 1170 6303 5673 33.9 39.7 159 BXRC-30C4001-D-74-SE 3000 70 1050 4714 4242 28.3 29.7 159 BXRC-30E4000-B-7X-SE 3000 80 900 4426 3983 33.9 30.5 145 BXRC-30E4000-C-7X-SE 3000 80 1170 5753 5178 33.9 39.7 145 BXRC-30E4000-D-7X-SE 3000 80 1050 4303 3872 28.3 29.7 145 BXRC-30G40H0-B-7X-SE 3000 90 900 3862 3476 33.9 30.5 127 BXRC-30G40H0-C-7X-SE 3000 90 1170 5020 4518 33.9 39.7 127 BXRC-30G40H0-D-7X-SE 3000 90 1050 3754 3379 28.3 29.7 126 BXRC-30G4000-B-7X-SE 3000 90 900 3693 3323 33.9 30.5 121 BXRC-30G4000-C-7X-SE 3000 90 1170 4800 4320 33.9 39.7 121 BXRC-30G4000-D-7X-SE 3000 90 1050 3590 3231 28.3 29.7 121 BXRC-30G400C-B-73-SE 3000 90 900 3411 3070 33.9 30.5 112 BXRC-30G400C-D-73-SE 3000 90 1050 3316 2984 28.3 29.7 112 BXRC-30H4000-B-7x-SE 3000 97 900 3298 2968 33.9 30.5 108 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30H4000-C-7x-SE 3000 97 1170 4287 3859 33.9 39.7 108 BXRC-30H4000-D-7x-SE 3000 97 1050 3206 2886 28.3 29.7 108 BXRC-30A4001-B-73-SE7,8 3000 93 900 3326 2994 33.9 30.5 109 BXRC-30A4001-C-73-SE7,8 3000 93 1170 4324 3892 33.9 39.7 109 BXRC-30A4001-D-73-SE7,8 3000 93 1050 3234 2910 28.3 29.7 109 BXRC-35E4000-B-7X-SE 3500 80 900 4566 4110 33.9 30.5 150 BXRC-35E4000-C-7X-SE 3500 80 1170 5936 5343 33.9 39.7 150 7,8 BXRC-35E4000-D-7X-SE 3500 80 1050 4440 3996 28.3 29.7 150 BXRC-35G4000-B-7X-SE 3500 90 900 3805 3425 33.9 30.5 125 BXRC-35G4000-C-7X-SE 3500 90 1170 4947 4452 33.9 39.7 125 BXRC-35G4000-D-7X-SE 3500 90 1050 3700 3330 28.3 29.7 125 BXRC-35A4001-B-73-SE7,8 3500 93 900 3580 3222 33.9 30.5 117 BXRC-35A4001-C-73-SE7,8 3500 93 1170 4654 4188 33.9 39.7 117 BXRC-35A4001-D-73-SE7,8 3500 93 1050 3480 3132 28.3 29.7 117 BXRC-40C4001-B-74-SE 4000 70 900 4989 4490 33.9 30.5 164 BXRC-40C4001-C-74-SE 4000 70 1170 6486 5837 33.9 39.7 164 BXRC-40C4001-D-74-SE 4000 70 1050 4851 4366 28.3 29.7 163 BXRC-40E4000-B-7X-SE 4000 80 900 4595 4135 33.9 30.5 151 BXRC-40E4000-C-7X-SE 4000 80 1170 5973 5376 33.9 39.7 151 BXRC-40E4000-D-7X-SE 4000 80 1050 4467 4020 28.3 29.7 150 BXRC-40G4000-B-7X-SE 4000 90 900 3946 3552 33.9 30.5 129 BXRC-40G4000-C-7X-SE 4000 90 1170 5130 4617 33.9 39.7 129 BXRC-40G4000-D-7X-SE 4000 90 1050 3837 3453 28.3 29.7 129 BXRC-40H4000-B-7X-SE 4000 97 900 3383 3044 33.9 30.5 111 BXRC-40H4000-C-7X-SE 4000 97 1170 4397 3958 33.9 39.7 111 BXRC-40H4000-D-7X-SE 4000 97 1050 3289 2960 28.3 29.7 111 BXRC-40A4001-B-73-SE7,8 4000 93 900 3834 3450 34.1 30.7 125 BXRC-40A4001-C-73-SE7,8 4000 93 1170 4984 4485 34.1 39.9 125 BXRC-40A4001-D-73-SE7,8 4000 93 1050 3727 3354 28.3 29.7 126 BXRC-50C4001-B-74-SE 5000 70 900 5046 4541 34.1 30.7 165 BXRC-50C4001-C-74-SE 5000 70 1170 6559 5903 34.1 39.9 165 BXRC-50C4001-D-74-SE 5000 70 1050 4905 4415 28.3 29.7 165 BXRC-50E4001-B-74-SE 5000 80 900 4736 4262 34.1 30.7 154 BXRC-50E4001-C-74-SE 5000 80 1170 6156 5541 34.1 39.9 154 BXRC-50E4001-D-74-SE 5000 80 1050 4604 4144 28.3 29.7 155 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 131 BXRC-50G4001-B-74-SE 5000 90 900 4031 3628 34.1 30.7 BXRC-50G4001-C-74-SE 5000 90 1170 5240 4716 34.1 39.9 131 BXRC-50G4001-D-74-SE 5000 90 1050 3919 3527 28.3 29.7 132 BXRC-56G4000-B-74-SE 5600 90 900 4228 3805 34.1 30.7 138 BXRC-56G4000-C-74-SE 5600 90 1170 5497 4947 34.1 39.9 138 BXRC-56G4000-D-74-SE 5600 90 1050 4111 3700 28.3 29.7 138 BXRC-56H4000-D-74-SE 5600 97 1050 3563 3206 28.3 29.7 120 159 BXRC-57C4001-B-74-SE 5700 80 900 4877 4389 34.1 30.7 BXRC-57C4001-C-74-SE 5700 80 1170 6339 5706 34.1 39.9 159 BXRC-57C4001-D-74-SE 5700 80 1050 4741 4267 28.3 29.7 160 BXRC-57E4001-B-74-SE 5700 80 900 4679 4211 34.1 30.7 153 BXRC-57E4001-C-74-SE 5700 80 1170 6083 5475 34.1 39.9 153 BXRC-57E4001-D-74-SE 5700 80 1050 4549 4094 28.3 29.7 153 BXRC-65C4001-B-74-SE 6500 70 900 4961 4465 34.1 30.7 162 BXRC-65C4001-C-74-SE 6500 70 1170 6449 5804 34.1 39.9 162 BXRC-65C4001-D-74-SE 6500 70 1050 4823 4341 28.3 29.7 163 155 BXRC-65E4001-B-74-SE 6500 80 900 4764 4287 34.1 30.7 BXRC-65E4001-C-74-SE 6500 80 1170 6193 5574 34.1 39.9 155 BXRC-65E4001-D-74-SE 6500 80 1050 4631 4168 28.3 29.7 156 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 98. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 9 Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-17E4000-B-74-SE 80 BXRC-17E4000-C-74-SE 80 BXRC-17E4000-D-74-SE 80 BXRC-20B4000-C-73-SE 65 BXRC-20B4000-D-73-SE 65 BXRC-25E4000-B-74-SE 80 BXRC-25E4000-C-74-SE 80 BXRC-25E4000-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 1463 1919 2725 4053 5215 1851 2425 3542 5096 6537 1411 1835 2649 3784 4817 3127 4098 5985 8610 11045 2384 3101 4476 6394 8139 2371 3110 4416 6568 8452 3000 3931 5741 8259 10594 2287 2974 4293 6133 7807 1315 1721 2452 3571 4533 1752 2248 3188 4485 5634 1310 1682 2384 3346 4189 2960 3798 5387 7579 9519 2213 2841 4029 5654 7078 2131 2790 3975 5787 7347 2839 3643 5167 7269 9131 2123 2725 3864 5423 6789 98 95 87 82 77 95 92 87 79 74 97 93 87 79 73 161 155 147 134 124 164 157 147 133 123 159 154 141 133 124 155 149 141 129 119 157 151 141 128 118 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27E4000-B-7x-SE 80 BXRC-27E4000-C-7x-SE 80 BXRC-27E4000-D-7x-SE 80 BXRC-27G40H0-B-7x-SE 90 BXRC-27G40H0-C-7x-SE 90 BXRC-27G40H0-D-7x-SE 90 BXRC-27G4000-B-7x-SE 90 BXRC-27G4000-C-7x-SE 90 BXRC-27G4000-D-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 2539 3331 4729 7034 9051 3212 4209 6148 8845 11345 2449 3185 4598 6568 8360 2186 2868 4072 6056 7793 2766 3624 5293 7615 9767 2109 2742 3959 5654 7198 2119 2779 3946 5869 7553 2680 3513 5130 7380 9467 2044 2658 3837 5480 6976 2282 2988 4256 6198 7868 3040 3901 5533 7785 9778 2273 2919 4138 5807 7270 1964 2572 3664 5336 6774 2617 3358 4764 6702 8418 1957 2513 3563 5000 6259 1904 2493 3552 5171 6565 2537 3255 4617 6496 8159 1897 2436 3453 4846 6067 170 164 151 143 133 166 160 151 138 128 168 161 151 137 126 147 142 130 123 115 142 137 130 119 110 145 139 130 118 109 142 137 126 119 111 138 133 126 115 107 140 135 126 114 105 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27H4000-B-7x-SE 80 BXRC-27H4000-C-7x-SE 80 BXRC-27H4000-D-7x-SE 80 BXRC-30C4001-B-74-SE 70 BXRC-30C4001-C-74-SE 70 BXRC-30C4001-D-74-SE 70 BXRC-30E4000-B-7x-SE 80 BXRC-30E4000-C-7x-SE 80 BXRC-30E4000-D-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 1833 2404 3414 5077 6534 2319 3039 4438 6385 8190 1768 2299 3319 4741 6035 2892 3794 5387 8012 10310 3659 4795 7003 10075 12923 2790 3628 5237 7481 9523 2640 3463 4917 7313 9411 3340 4377 6392 9196 11796 2547 3312 4781 6828 8693 1647 2157 3072 4474 5680 2194 2816 3994 5619 7059 1641 2107 2987 4192 5248 2599 3403 4848 7059 8962 3463 4443 6303 8867 11138 2590 3325 4714 6615 8281 2372 3106 4426 6444 8181 3161 4056 5753 8094 10167 2364 3035 4303 6038 7559 123 119 109 103 96 119 115 109 100 92 121 116 109 99 91 194 187 172 163 151 189 182 172 157 146 192 184 172 156 144 177 171 157 149 138 172 166 157 143 133 175 168 157 142 131 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G40H0-B-7x-SE 90 BXRC-30G40H0-C-7x-SE 90 BXRC-30G40H0-D-7x-SE 90 BXRC-30G4000-B-7x-SE 90 BXRC-30G4000-C-7x-SE 90 BXRC-30G4000-D-7x-SE 90 BXRC-30G400C-B-73-SE 90 BXRC-30G400C-D-73-SE 90 BXRC-30H4000-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 525 700 1050 1575 2100 450 600 900 1350 1800 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 2304 3022 4291 6382 8212 2914 3819 5578 8025 10293 2222 2890 4172 5959 7585 2203 2890 4103 6102 7853 2787 3652 5334 7673 9843 2125 2763 3989 5698 7253 2035 2669 3790 5636 7253 1963 2552 3684 5263 6699 1967 2581 3664 5450 7013 2070 2711 3862 5623 7139 2758 3539 5020 7063 8872 2063 2648 3754 5269 6596 1979 2592 3693 5377 6826 2637 3384 4800 6754 8483 1972 2532 3590 5038 6307 1828 2394 3411 4966 6305 1822 2339 3316 4654 5826 1768 2315 3298 4802 6097 154 149 137 130 121 150 145 137 125 116 153 146 137 124 115 148 143 131 124 115 144 139 131 120 111 146 140 131 119 110 136 132 121 115 107 135 129 121 110 101 132 127 117 111 103 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30H4000-C-7x-SE 80 BXRC-30H4000-D-7x-SE 80 BXRC-30A4001-B-73-SE 93 BXRC-30A4001-C-73-SE 93 BXRC-30A4001-D-73-SE 93 BXRC-35E4000-B-7x-SE 80 BXRC-35E4000-C-7x-SE 80 BXRC-35E4000-D-7x-SE 80 BXRC-35G4000-B-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 2489 3262 4764 6853 8791 1898 2468 3563 5089 6478 1984 2603 3696 5497 7073 2510 3290 4804 6912 8866 1914 2489 3593 5132 6533 2724 3574 5074 7546 9711 3446 4516 6596 9489 12172 2628 3417 4933 7046 8969 2270 2978 4228 6289 8092 2356 3023 4287 6032 7577 1762 2262 3206 4500 5633 1783 2335 3326 4843 6149 2376 3048 4324 6083 7641 1777 2281 3234 4538 5681 2448 3205 4566 6649 8441 3261 4185 5936 8352 10491 2439 3131 4440 6230 7800 2040 2671 3805 5541 7034 128 124 117 107 99 130 125 117 106 98 133 129 118 112 104 129 125 118 108 100 131 126 118 107 99 183 176 162 153 143 178 171 162 148 137 180 173 162 147 135 152 147 135 128 119 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35G4000-C-7x-SE 90 BXRC-35G4000-D-7x-SE 90 BXRC-35A4001-B-73-SE 93 BXRC-35A4001-C-73-SE 93 BXRC-35A4001-D-73-SE 93 BXRC-40C4001-B-74-SE 70 BXRC-40C4001-C-74-SE 70 BXRC-40C4001-D-74-SE 70 BXRC-40E4000-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 2872 3763 5497 7907 10143 2190 2848 4111 5872 7475 2136 2801 3978 5916 7613 2702 3540 5171 7439 9542 2060 2679 3867 5524 7032 2976 3904 5544 8245 10610 3765 4934 7207 10368 13299 2871 3733 5390 7698 9800 2741 3596 5105 7593 9771 2718 3488 4947 6960 8742 2033 2610 3700 5192 6500 1919 2513 3580 5212 6618 2557 3281 4654 6547 8224 1912 2455 3480 4884 6115 2675 3502 4989 7265 9223 3563 4573 6486 9125 11462 2665 3421 4851 6807 8522 2463 3225 4595 6690 8493 148 143 135 123 114 150 144 135 123 113 143 138 127 120 112 139 134 127 116 108 141 136 127 115 106 200 193 177 168 156 194 187 177 162 150 197 189 177 161 148 184 178 163 154 144 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E4000-C-7x-SE 80 BXRC-40E4000-D-7x-SE 80 BXRC-40G4000-B-7x-SE 90 BXRC-40G4000-C-7x-SE 90 BXRC-40G4000-D-7x-SE 90 BXRC-40H4000-B-7x-SE 97 BXRC-40H4000-C-7x-SE 97 BXRC-40H4000-D-7x-SE 97 BXRC-40A4001-B-73-SE 93 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 3468 4544 6637 9548 12247 2644 3438 4963 7089 9025 2354 3088 4385 6522 8392 2978 3903 5700 8200 10519 2271 2953 4263 6089 7751 2018 2647 3758 5590 7193 2553 3345 4886 7029 9016 1947 2531 3654 5219 6644 2287 3000 4260 6335 8152 3282 4211 5973 8403 10555 2454 3151 4467 6269 7848 2115 2770 3946 5746 7295 2819 3617 5130 7218 9066 2108 2706 3837 5384 6741 1813 2374 3383 4925 6253 2416 3100 4397 6187 7771 1807 2320 3289 4615 5778 2055 2691 3834 5582 7087 179 172 163 149 138 182 174 163 148 136 158 152 140 133 123 153 148 140 128 119 156 149 140 127 117 135 131 120 114 106 132 127 120 110 102 134 128 120 109 100 153 148 136 129 120 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40A4001-C-73-SE 93 BXRC-40A4001-D-73-SE 93 BXRC-50C4001-B-74-SE 70 BXRC-50C4001-C-74-SE 70 BXRC-50C4001-D-74-SE 70 BXRC-50E4001-B-74-SE 80 BXRC-50E4001-C-74-SE 80 BXRC-50E4001-D-74-SE 80 BXRC-50G4001-B-74-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 2893 3791 5537 7966 10218 2206 2869 4141 5915 7530 3010 3949 5606 8338 10730 3808 4990 7288 10485 13449 2904 3776 5451 7785 9911 2825 3706 5262 7826 10070 3574 4683 6840 9840 12623 2725 3544 5116 7307 9302 2405 3154 4479 6661 8572 2738 3513 4984 7011 8807 2048 2629 3727 5231 6548 2705 3541 5046 7347 9327 3604 4624 6559 9228 11592 2695 3460 4905 6884 8618 2539 3324 4736 6895 8754 3382 4340 6156 8661 10879 2529 3247 4604 6461 8089 2161 2829 4031 5869 7451 149 144 136 124 115 152 145 136 123 114 202 195 179 169 158 196 189 179 163 152 199 191 179 162 150 189 183 168 159 148 184 178 168 153 142 187 179 168 152 140 161 156 143 135 126 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50G4001-C-74-SE 90 BXRC-50G4001-D-74-SE 90 BXRC-56G4000-B-74-SE 80 BXRC-56G4000-C-74-SE 80 BXRC-56G4000-D-74-SE 80 BXRC-56H4000-D-74-SE 97 BXRC-57C4001-B-74-SE 70 BXRC-57C4001-C-74-SE 70 BXRC-57C4001-D-74-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 3042 3986 5822 8376 10744 2320 3016 4354 6220 7918 2522 3309 4698 6987 8992 3191 4182 6107 8786 11270 2433 3164 4568 6524 8305 2109 2742 3959 5654 7198 2909 3816 5418 8059 10370 3680 4823 7044 10133 12998 2806 3649 5268 7524 9579 2879 3694 5240 7372 9260 2153 2764 3919 5500 6885 2267 2968 4228 6156 7816 3020 3875 5497 7733 9714 2258 2899 4111 5769 7222 1957 2513 3563 5000 6259 2614 3423 4877 7100 9015 3483 4469 6339 8919 11203 2605 3344 4741 6654 8330 157 151 143 131 121 159 153 143 130 120 169 163 150 142 132 164 159 150 137 127 167 160 150 136 125 145 139 130 118 109 195 188 173 164 152 190 183 173 158 146 193 185 173 157 145 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E4001-B-74-SE 80 BXRC-57E4001-C-74-SE 80 BXRC-57E4001-D-74-SE 80 BXRC-65C4001-B-74-SE 70 BXRC-65C4001-C-74-SE 70 BXRC-65C4001-D-74-SE 70 BXRC-65E4001-B-74-SE 80 BXRC-65E4001-C-74-SE 80 BXRC-65E4001-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 2791 3662 5199 7733 9951 3531 4628 6759 9723 12472 2693 3501 5055 7220 9191 2960 3882 5512 8198 10550 3744 4906 7166 10309 13224 2855 3712 5359 7655 9745 2842 3728 5293 7872 10130 3595 4711 6881 9899 12698 2741 3565 5146 7350 9357 2508 3284 4679 6813 8650 3342 4288 6083 8558 10750 2499 3209 4549 6384 7992 2659 3482 4961 7224 9171 3543 4547 6449 9074 11397 2650 3402 4823 6769 8474 2554 3344 4764 6936 8806 3402 4366 6193 8713 10944 2544 3267 4631 6500 8137 187 181 166 157 146 182 176 166 152 141 185 177 166 151 139 198 192 176 167 155 193 186 176 161 149 196 188 176 160 147 191 184 169 160 149 185 179 169 154 143 188 180 169 153 141 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 19 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.15 31.0 38.4 -14.9 0.19 33.8 41.6 37.4 -14.9 0.11 31.0 38.4 37.8 40.6 -14.9 0.13 33.8 41.6 26.8 29.0 31.2 -12.2 0.16 25.8 32.0 29.2 31.5 33.9 -12.2 0.19 28.2 34.7 Minimum Typical Maximum 900 32.2 34.8 37.4 -14.9 1800 35.0 37.8 40.6 1170 32.2 34.8 2340 35.0 1050 2100 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 20 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 900 RG1 RG1 RG1 RG1 1350 RG1 RG1 RG1 RG2 1800 RG1 RG1 RG2 RG2 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG1 RG2 RG2 1050 RG1 RG1 RG1 RG1 1575 RG1 RG1 RG1 RG2 2100 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero SE Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 21 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE Maximum Drive Current3 1800mA 2340mA 2100mA Maximum Peak Pulsed Drive Current4 2570mA 3340mA 3000mA Maximum Reverse Voltage5 -60V -60V -50V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN120: Assembly Considerations for Bridgelux Vero SE LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 22 Performance Curves Figure 2: Vero SE 18C Drive Current vs. Voltage 2000 2700 1800 2400 1600 2100 1400 Forward Current (mA) Forward Current (mA) Figure 1: Vero SE 18B Drive Current vs. Voltage 1200 1000 800 600 1800 1500 1200 900 600 400 300 200 0 0 32 33 34 35 36 37 38 39 32 33 34 200% 2000 180% 1750 160% 1500 140% Relative Luminous Flux Forward Current (mA) 2250 1250 37 38 39 1000 750 500 120% 100% 80% 60% 40% 250 20% 26 27 28 29 30 31 0% 32 0 200 400 600 Forward Voltage (V) 800 1000 1200 1400 1600 1800 2000 Forward Current (mA) Figure 5: Vero SE 18C Typical Relative Flux vs. Current Figure 6: Vero SE 18D Typical Relative Flux vs. Current y = -7E-08x + 0.001x + 0.027 2 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 36 Figure 4: Vero SE 18B Typical Relative Flux vs. Current Figure 3: Vero SE 18D Drive Current vs. Voltage 0 35 Forward Voltage (V) Forward Voltage (V) 120% 100% 80% 60% 40% 120% 100% 80% 60% 40% 20% 20% 0% 100 400 700 1000 1300 1600 Forward Current (mA) 1900 2200 2500 0% 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 2400 Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 23 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature Figure 7: Typical DC Flux vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 125 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Case Temperature (°C) Figure 9: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 7-9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 24 Performance Curves Figure 10: 1750K Color Shift vs. Case Temperature1 Figure 11: 2000K, 65 CRI Color Shift vs. Case Temperature1 0.3705 0.37 0.4101 Pulsed Center Point Tc = 25°C 15°C 0.41 0.4099 25°C 0.4098 Pulsed Center Point Tc=25°C 15°C 25°C 0.4097 0.3695 0.369 ccy ccy 45°C 45°C 0.4096 0.4095 65°C 0.4094 70°C 0.4093 85°C 0.3685 85°C 0.4092 105°C 0.368 0.5196 105°C 0.4091 0.5198 0.52 0.5202 0.5204 0.409 0.525 0.5206 0.526 0.527 0.528 Figure 12: 2500K Color Shift vs. Case Temperature1 0.4135 Pulsed Center Point Tc = 25°C 0.411 70°C 0.399 65°C 85°C 0.397 105°C 0.396 0.47 45°C 0.398 85°C 0.4105 0.468 Pulsed Center Point Tc=25°C 25°C 0.4 0.4125 0.4115 0.472 0.474 0.476 0.395 0.444 0.478 105°C 0.4445 0.445 0.4455 0.446 0.4465 0.447 ccx ccx Figure 14: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 15: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.532 0.401 45°C 0.412 15°C 0.402 ccy ccy 0.413 0.531 0.403 15°C 25°C 0.53 Figure 13: 3000K, 90 CRI Color Shift vs. Case Temperature1,3,4 0.4145 0.414 0.529 ccx ccx 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.4572 0.4574 0.4576 0.4578 0.458 ccx Notes for Figures 10-15: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRC-30G400C-x-73-SE 4. Color shift shown for product hot targeted at Tc=85°C 0.3950 0.4323 0.4328 0.4333 0.4338 0.4343 0.4348 0.4353 ccx 25 Performance Curves Figure 16: 5600K Color Shift vs. Case Temperature1 Figure 17: 3000K Class A Color Shift vs. Case Temperature1 0.344 0.369 0.342 25°C 0.338 0.336 0.367 0.366 0.332 70°C 0.33 45°C 0.364 70°C 85°C 0.362 105°C 0.324 0.361 0.322 0.32 0.322 0.324 0.326 0.328 Figure 18: 3500K Class A Color Shift vs. Case Temperature1 105°C 0.36 0.416 0.33 ccx 0.4165 0.417 ccx 0.4175 0.418 0.4185 Figure 19: 4000K Class A Color Shift vs. Case Temperature1 0.3760 0.37 15°C 0.368 15°C 0.3740 Pulsed Center Point Tc=25°C 25°C 0.366 25°C 0.3720 45°C Pulsed Center Point Tc=25°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.365 0.363 85°C 0.328 0.326 25°C 45°C 0.334 15°C 0.368 ccy ccy Pulsed Center Point Tc = 25°C 15°C 0.34 0.364 0.3680 70°C 0.362 0.3660 85°C 0.36 85°C 0.3640 105°C 0.358 0.392 70°C 105°C 0.393 0.394 0.395 0.396 0.397 ccx 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 Notes for Figures 16-19: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 26 Typical Radiation Pattern Figure 20: Typical Spatial Radiation Pattern Notes for Figure 20: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 21: Typical Polar Radiation Pattern 27 Typical Color Spectrum Figure 22: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 22: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 23: Typical Color Spectrum for Vero SE 18 with Décor Series 1 17E 20B 0.9 25E 27H 30G (Décor Series Showcase) 0.8 30H Relative Spectral Power Distribution 56G 56H 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 23: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 28 Mechanical Dimensions Figure 24: Drawing for Vero SE 18 LED Array Notes for Figure 24: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 29 Color Binning Information Figure 25: Warm and Neutral White Test Bins in xy Color Space 0.44 3 SDCM 2500K 4SDCM 4 SDCM 2 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2000K 2500K 2700K ANSI Bin (for reference only) - - - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - - - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - - - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5167, 0.336) (0.5280, 0.4100) (0.4765, 0.4137) (0.4578, 0.4101) 3000K1 3500K1 4000K1 (0.4338, 0.403) (0.4073, 0.3917) (0.4465, 0.4024)2 (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Figure 26: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5600K1 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5475K - 5830K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) (0.3287, 0.3417) (0.3123, 0.3282) Note for Table 9: 1. Select configurations with a CCT of 5600K are available with center point targets at Tc = 85°C or Tc = 25°C. 30 Packaging and Labeling Figure 27: Drawing for Vero SE 18 Packaging Tray Notes for Figure 27: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 31 Packaging and Labeling Figure 28: Vero SE Series Packaging and Labeling Notes for Figure 28: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 29: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin definitions. 32 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN121 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 33 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vero SE 18 Array Series Product Data Sheet DS122 Rev. I (09/2018) 34
BXRC-27G40H0-B-73-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-27G40H0-B-73-SE”相匹配的价格&库存,您可以联系我们找货
  • 200+77.07821200+9.88683
