BXRC-56H10K0-D-84
BXRC-56H10K0-D-84
    BRIDGELUX(普瑞)
BXRC-56H10K0-D-84 数据手册
Bridgelux Gen 8 Vero 29 Array ® ® Product Data Sheet DS423 1 Vero® Series Introduction The Vero® Series is a revolutionary advancement in chip on board (COB) light source technology and innovation, simplifying the luminaire design and manufacturing processes. Vero Chip on Board (COB) LED arrays are available in four LES configurations, engineered to enable new degrees of flexibility and reliability over a broad range of electrical currents. Vero arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero products include an onboard connector port that enables a solder-free electrical interconnect, and simple mounting features for plug-and-play installation. Features Benefits • On board connector port • Solder free installation and field upgradability • Top side part number markings • Improved inventory management and quality control • Efficacy of 185 lm/W typical, 3000K 80 CRI • Enables high efficiency lighting systems and lower operating costs • Reliable operation at up to 3x nominal current, 30% increase in maximum lumens per LES size • Wide selection of CCT options (2700K-6500K) with minimum 70, 80 and 90 CRI options • Uniform high-quality illumination • 2 and 3 SDCM binning options (2700K – 4000K) • Forward voltage bin codes (backside marking) • Thermally isolated solder pads • 10-Year warranty • Supports the trend toward luminaire miniaturization and delivers enhanced optical control • Design flexibility for a broad range of lighting applications • Clean white light without pixelation • Uniform consistent white light • Design flexibility for multi-source applications • Enhanced ease of use and installation • Design with confidence Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 European Product Registry for Energy Labeling 4 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 20 Eye Safety 21 Absolute Maximum Ratings 22 Performance Curves 23 Typical Radiation Pattern 25 Typical Color Spectrum 26 Mechanical Dimensions 27 Color Binning Information 28 Packaging and Labeling 29 Design Resources 31 Precautions 31 Disclaimers 31 About Bridgelux 32 1 Product Feature Map Vero 29 is the largest form factor in the Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero Series family of products. Mounting holes Thermally isolated solder pads reduce manufacturing cycle time and complexity Polarity indication marks simplify manufacturing operator instructions Tc Measurement point 2D Bar code provides full manufacturing traceability Top side part number marking improves inventory management and outgoing quality control Radial die configuration improves lumen density and beam control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Bridgelux Vero wire harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 10K 0 – C – 8 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Gen. 8 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted Flux Indicator 10Kx = 10,000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E10K0-B-8x 2700 80 1400 12247 11022 50.2 70.3 174 BXRC-27E10K0-C-8x 2700 80 1300 15099 13589 66.7 86.7 174 BXRC-27E10K0-D-8x 2700 80 1700 10771 9694 36.4 61.9 174 BXRC-27G10K0-B-8x 2700 90 1400 10103 9093 50.2 70.3 144 144 BXRC-27G10K0-C-8x 2700 90 1300 12457 11211 66.7 86.7 BXRC-27G10K0-D-8x 2700 90 1700 8886 7997 36.4 61.9 144 BXRC-27G1KH0-B-8x 2700 90 1400 10540 9486 50.2 70.3 150 BXRC-27G1KH0-C-8x 2700 90 1300 12995 11695 66.7 86.7 150 BXRC-27G1KH0-D-8x 2700 90 1700 9270 8343 36.4 61.9 150 BXRC-27H10K0-B-8x 2700 97 1400 8955 8060 50.2 70.3 127 BXRC-27H10K0-C-8x 2700 97 1300 11041 9937 66.7 86.7 127 BXRC-27H10K0-D-8x 2700 97 1700 7876 7089 36.4 61.9 127 BXRC-30C10K1-B-8x 3000 70 1400 13624 12262 50.2 70.3 194 194 BXRC-30C10K1-C-8x 3000 70 1300 16798 15118 66.7 86.7 BXRC-30C10K1-D-8x 3000 70 1700 11983 10784 36.4 61.9 194 BXRC-30E10K0-B-8x 3000 80 1400 13012 11711 50.2 70.3 185 185 BXRC-30E10K0-C-8x 3000 80 1300 16043 14439 66.7 86.7 BXRC-30E10K0-D-8x 3000 80 1700 11444 10300 36.4 61.9 185 BXRC-30G10K0-B-8x 3000 90 1400 10563 9506 50.2 70.3 150 BXRC-30G10K0-C-8x 3000 90 1300 13023 11721 66.7 86.7 150 BXRC-30G10K0-D-8x 3000 90 1700 9290 8361 36.4 61.9 150 BXRC-30G1KH0-B-8x 3000 90 1400 11060 9954 50.2 70.3 157 BXRC-30G1KH0-C-8x 3000 90 1300 13637 12273 66.7 86.7 157 BXRC-30G1KH0-D-8x 3000 90 1700 9727 8755 36.4 61.9 157 BXRC-30H10K0-B-8x 3000 97 1400 9568 8611 50.2 70.3 136 BXRC-30H10K0-C-8x 3000 97 1300 11796 10617 66.7 86.7 136 BXRC-30H10K0-D-8x 3000 97 1700 8415 7573 36.4 61.9 136 BXRC-35E10K0-B-8x 3500 80 1400 13318 11986 50.2 70.3 190 BXRC-35E10K0-C-8x 3500 80 1300 16420 14778 66.7 86.7 189 BXRC-35E10K0-D-8x 3500 80 1700 11713 10542 36.4 61.9 189 BXRC-35G10K0-B-8x 3500 90 1400 10945 9851 50.2 70.3 156 BXRC-35G10K0-C-8x 3500 90 1300 13495 12145 66.7 86.7 156 BXRC-35G10K0-D-8x 3500 90 1700 9626 8664 36.4 61.9 156 BXRC-40C10K1-B-8x 4000 70 1400 14007 12606 50.2 70.3 199 BXRC-40C10K1-C-8x 4000 70 1300 17270 15543 66.7 86.7 199 BXRC-40C10K1-D-8x 4000 70 1700 12319 11087 36.4 61.9 199 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. Minimum R9 value for 97 CRI products is 93 on 2700K and 3000K,and it is 85 on 3500K /4000K/5000K and 5700K. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40E10K0-B-8x 4000 80 1400 13395 12055 50.2 70.3 191 BXRC-40E10K0-C-8x 4000 80 1300 16515 14863 66.7 86.7 190 BXRC-40E10K0-D-8x 4000 80 1700 11781 10603 36.4 61.9 190 BXRC-40G10K0-B-8x 4000 90 1400 11175 10058 50.2 70.3 159 BXRC-40G10K0-C-8x 4000 90 1300 13778 12400 66.7 86.7 159 BXRC-40G10K0-D-8x 4000 90 1700 9828 8846 36.4 61.9 159 BXRC-50C10K1-B-8x 5000 70 1400 14084 12675 50.2 70.3 200 BXRC-50C10K1-C-8x 5000 70 1300 17364 15628 66.7 86.7 200 BXRC-50C10K1-D-8x 5000 70 1700 12386 11148 36.4 61.9 200 BXRC-50E10K1-B-8x 5000 80 1400 13548 12193 50.2 70.3 193 BXRC-50E10K1-C-8x 5000 80 1300 16704 15033 66.7 86.7 193 BXRC-50E10K1-D-8x 5000 80 1700 11915 10724 36.4 61.9 193 BXRC-50G10K1-B-8x 5000 90 1400 11711 10540 50.2 70.3 167 BXRC-50G10K1-C-8x 5000 90 1300 14439 12995 66.7 86.7 167 BXRC-50G10K1-D-8x 5000 90 1700 10300 9270 36.4 61.9 166 BXRC-56H10K0-C-8x 5600 97 1300 13118 11806 66.7 86.7 151 BXRC-56H10K0-D-8x 5600 97 1700 9357 8421 36.4 61.9 151 BXRC-57C10K1-B-8x 5700 70 1400 13701 12331 50.2 70.3 195 195 BXRC-57C10K1-C-8x 5700 70 1300 16892 15203 66.7 86.7 BXRC-57C10K1-D-8x 5700 70 1700 12050 10845 36.4 61.9 195 BXRC-57E10K1-B-8x 5700 80 1400 13012 11711 50.2 70.3 185 BXRC-57E10K1-C-8x 5700 80 1300 16043 14439 66.7 86.7 185 BXRC-57E10K1-D-8x 5700 80 1700 11444 10300 36.4 61.9 185 BXRC-65C10K1-B-8x 6500 70 1400 13701 12331 50.2 70.3 195 BXRC-65C10K1-C-8x 6500 70 1300 16892 15203 66.7 86.7 195 BXRC-65C10K1-D-8x 6500 70 1700 12050 10845 36.4 61.9 195 BXRC-65E10K1-B-8x 6500 80 1400 13165 11849 50.2 70.3 187 BXRC-65E10K1-C-8x 6500 80 1300 16232 14609 66.7 86.7 187 BXRC-65E10K1-D-8x 6500 80 1700 11579 10421 36.4 61.9 187 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. Minimum R9 value for 97 CRI products is 93 on 2700K and 3000K,and it is 85 on 3500K /4000K/5000K and 5700K. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E10K0-B-8x 2700 80 1400 11022 9920 49.2 68.9 160 BXRC-27E10K0-C-8x 2700 80 1300 13589 12230 65.4 85.0 160 BXRC-27E10K0-D-8x 2700 80 1700 9694 8724 35.7 60.7 160 BXRC-27G10K0-B-8x 2700 90 1400 9093 8184 49.2 68.9 132 BXRC-27G10K0-C-8x 2700 90 1300 11211 10090 65.4 85.0 132 BXRC-27G10K0-D-8x 2700 90 1700 7997 7198 35.7 60.7 132 BXRC-27G1KH0-B-8x 2700 90 1400 9486 8537 49.2 68.9 138 BXRC-27G1KH0-C-8x 2700 90 1300 11695 10526 65.4 85.0 138 BXRC-27G1KH0-D-8x 2700 90 1700 8343 7508 35.7 60.7 138 BXRC-27H10K0-B-8x 2700 97 1400 8060 7254 49.2 68.9 117 BXRC-27H10K0-C-8x 2700 97 1300 9937 8944 65.4 85.0 117 BXRC-27H10K0-D-8x 2700 97 1700 7089 6380 35.7 60.7 117 BXRC-30C10K1-B-8x 3000 70 1400 12262 11036 49.2 68.9 178 BXRC-30C10K1-C-8x 3000 70 1300 15118 13606 65.4 85.0 178 BXRC-30C10K1-D-8x 3000 70 1700 10784 9706 35.7 60.7 178 BXRC-30E10K0-B-8x 3000 80 1400 11711 10540 49.2 68.9 170 BXRC-30E10K0-C-8x 3000 80 1300 14439 12995 65.4 85.0 170 BXRC-30E10K0-D-8x 3000 80 1700 10300 9270 35.7 60.7 170 BXRC-30G10K0-B-8x 3000 90 1400 9506 8556 49.2 68.9 138 BXRC-30G10K0-C-8x 3000 90 1300 11721 10549 65.4 85.0 138 BXRC-30G10K0-D-8x 3000 90 1700 8361 7525 35.7 60.7 138 BXRC-30G1KH0-B-8x 3000 90 1400 9954 8959 49.2 68.9 144 BXRC-30G1KH0-C-8x 3000 90 1300 12273 11046 65.4 85.0 144 BXRC-30G1KH0-D-8x 3000 90 1700 8755 7879 35.7 60.7 144 BXRC-30H10K0-B-8x 3000 97 1400 8611 7750 49.2 68.9 125 BXRC-30H10K0-C-8x 3000 97 1300 10617 9555 65.4 85.0 125 BXRC-30H10K0-D-8x 3000 97 1700 7573 6816 35.7 60.7 125 BXRC-35E10K0-B-8x 3500 80 1400 11986 10788 49.2 68.9 174 BXRC-35E10K0-C-8x 3500 80 1300 14778 13301 65.4 85.0 174 BXRC-35E10K0-D-8x 3500 80 1700 10542 9488 35.7 60.7 174 BXRC-35G10K0-B-8x 3500 90 1400 9851 8866 49.2 68.9 143 143 BXRC-35G10K0-C-8x 3500 90 1300 12145 10931 65.4 85.0 BXRC-35G10K0-D-8x 3500 90 1700 8664 7797 35.7 60.7 143 BXRC-40C10K1-B-8x 4000 70 1400 12606 11346 49.2 68.9 183 BXRC-40C10K1-C-8x 4000 70 1300 15543 13989 65.4 85.0 183 BXRC-40C10K1-D-8x 4000 70 1700 11087 9978 35.7 60.7 183 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. Minimum R9 value for 97 CRI products is 93 on 2700K and 3000K,and it is 85 on 3500K /4000K/5000K and 5700K. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40E10K0-B-8x 4000 80 1400 12055 10850 49.2 68.9 175 BXRC-40E10K0-C-8x 4000 80 1300 14863 13377 65.4 85.0 175 BXRC-40E10K0-D-8x 4000 80 1700 10603 9542 35.7 60.7 175 BXRC-40G10K0-B-8x 4000 90 1400 10058 9052 49.2 68.9 146 BXRC-40G10K0-C-8x 4000 90 1300 12400 11160 65.4 85.0 146 BXRC-40G10K0-D-8x 4000 90 1700 8846 7961 35.7 60.7 146 BXRC-50C10K1-B-8x 5000 70 1400 12675 11408 49.2 68.9 184 BXRC-50C10K1-C-8x 5000 70 1300 15628 14065 65.4 85.0 184 BXRC-50C10K1-D-8x 5000 70 1700 11148 10033 35.7 60.7 184 BXRC-50E10K1-B-8x 5000 80 1400 12193 10974 49.2 68.9 177 BXRC-50E10K1-C-8x 5000 80 1300 15033 13530 65.4 85.0 177 BXRC-50E10K1-D-8x 5000 80 1700 10724 9651 35.7 60.7 177 BXRC-50G10K1-B-8x 5000 90 1400 10540 9486 49.2 68.9 153 BXRC-50G10K1-C-8x 5000 90 1300 12995 11695 65.4 85.0 153 BXRC-50G10K1-D-8x 5000 90 1700 9270 8343 35.7 60.7 153 139 BXRC-56H10K0-C-8x 5600 97 1300 11806 10626 65.4 85.0 BXRC-56H10K0-D-8x 5600 97 1700 8422 7579 35.7 60.7 139 BXRC-57C10K1-B-8x 5700 70 1400 12331 11098 49.2 68.9 179 179 BXRC-57C10K1-C-8x 5700 70 1300 15203 13683 65.4 85.0 BXRC-57C10K1-D-8x 5700 70 1700 10845 9760 35.7 60.7 179 BXRC-57E10K1-B-8x 5700 80 1400 11711 10540 49.2 68.9 170 BXRC-57E10K1-C-8x 5700 80 1300 14439 12995 65.4 85.0 170 BXRC-57E10K1-D-8x 5700 80 1700 10300 9270 35.7 60.7 170 BXRC-65C10K1-B-8x 6500 70 1400 12331 11098 49.2 68.9 179 BXRC-65C10K1-C-8x 6500 70 1300 15203 13683 65.4 85.0 179 BXRC-65C10K1-D-8x 6500 70 1700 10845 9760 35.7 60.7 179 BXRC-65E10K1-B-8x 6500 80 1400 11849 10664 49.2 68.9 172 BXRC-65E10K1-C-8x 6500 80 1300 14609 13148 65.4 85.0 172 BXRC-65E10K1-D-8x 6500 80 1700 10421 9379 35.7 60.7 172 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. Minimum R9 value for 97 CRI products is 93 on 2700K and 3000K,and it is 85 on 3500K /4000K/5000K and 5700K. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 European Product Registry for Energy Labeling The European Product Registry for Energy Labeling (EPREL) is defined in the EU Regulation 2017/1369 to provide important energy efficiency information to consumers. Together with Energy Labeling Regulation ELR (EU) 2019/2015 which was amended by regulation (EU) 2021/340 for energy labelling of light sources, manufacturers are required to declare an energy class based on key technical specifications from each of their product and register it in an open data base managed by EPREL It is now a legal requirement for a vendor of light sources to upload information about their products into the EPREL database before placing these products on the market in the EU. Table 3 below provides a list of part numbers that are in compliance with ELR and are currently listed in the EPREL database. At Bridgelux, we are fully committed to supplying products that are compliant with pertinent laws, rules, and obligation imposed by relevant government bodies including the European Energy Labeling regulation. Customers can use these products with full confidence for any projects that fall under the ELR. Table 3: Part numbers registered in European Product Registry for Energy Labeling CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) 2700 80 1510 49.6 8823 74.9 117.8 PART NUMBER CCT (K) BXRC-27E10K0-B-8x 1 Energy efficiency class4 F Registration No URL to Product Information Sheet in EPREL Database 871017 https://eprel.ec.europa.eu/qr/871017 BXRC-27E10K0-C-8x 2700 80 4090 72.8 35553 297.7 119.4 E 871022 https://eprel.ec.europa.eu/qr/871022 BXRC-27E10K0-D-8x 2700 80 5500 39.9 34020 219.5 155.0 D 871027 https://eprel.ec.europa.eu/qr/871027 https://eprel.ec.europa.eu/qr/871098 BXRC-27G10K0-B-8x 2700 90 620 47.3 3151 29.3 107.4 F 871098 BXRC-27G10K0-C-8x 2700 90 2180 68.2 16662 148.7 112.1 F 871103 https://eprel.ec.europa.eu/qr/871103 BXRC-27G10K0-D-8x 2700 90 5500 39.9 28067 219.5 127.9 E 871108 https://eprel.ec.europa.eu/qr/871108 BXRC-27G1KH0-B-8x 2700 90 4750 55.5 33291 263.6 126.3 E 871114 https://eprel.ec.europa.eu/qr/871114 BXRC-27G1KH0-C-8x 2700 90 4750 74.3 41047 353.1 116.3 F 871118 https://eprel.ec.europa.eu/qr/871118 BXRC-27G1KH0-D-8x 2700 90 5500 39.9 29279 219.5 133.4 E 871122 https://eprel.ec.europa.eu/qr/871122 BXRC-30C10K1-B-8x 3000 70 2050 50.7 13096 103.9 126.1 E 871276 https://eprel.ec.europa.eu/qr/871276 BXRC-30C10K1-C-8x 3000 70 4670 74.1 44084 346.3 127.3 E 871282 https://eprel.ec.europa.eu/qr/871282 BXRC-30C10K1-D-8x 3000 70 5500 39.9 37848 219.5 172.4 D 871288 https://eprel.ec.europa.eu/qr/871288 BXRC-30E10K0-B-8x 3000 80 2280 51.1 13814 116.5 118.6 F 871347 https://eprel.ec.europa.eu/qr/871347 BXRC-30E10K0-C-8x 3000 80 4750 74.3 42744 353.1 121.1 E 871352 https://eprel.ec.europa.eu/qr/871352 BXRC-30E10K0-D-8x 3000 80 5500 39.9 36146 219.5 164.7 D 871357 https://eprel.ec.europa.eu/qr/871357 https://eprel.ec.europa.eu/qr/871436 BXRC-30G10K0-B-8x 3000 90 810 47.9 4226 38.8 108.8 F 871436 BXRC-30G10K0-C-8x 3000 90 2810 69.7 22027 196.0 112.4 F 871441 https://eprel.ec.europa.eu/qr/871441 BXRC-30G10K0-D-8x 3000 90 5500 39.9 29342 219.5 133.7 E 871446 https://eprel.ec.europa.eu/qr/871446 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 7 European Product Registry for Energy Labeling Table 3: Part numbers registered in European Product Registry for Energy Labeling (Continued) CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) 3000 90 4750 55.5 34935 263.6 132.5 E PART NUMBER CCT (K) BXRC-30G1KH0-B-8x 1 Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database 871452 https://eprel.ec.europa.eu/qr/871452 BXRC-30G1KH0-C-8x 3000 90 4750 74.3 43074 353.1 122.0 E 871456 https://eprel.ec.europa.eu/qr/871456 BXRC-30G1KH0-D-8x 3000 90 5500 39.9 30725 219.5 140.0 E 871460 https://eprel.ec.europa.eu/qr/871460 BXRC-35E10K0-B-8x 3500 80 2610 51.7 16025 135.0 118.7 F 871621 https://eprel.ec.europa.eu/qr/871621 BXRC-35E10K0-C-8x 3500 80 4750 74.3 43750 353.1 123.9 E 871626 https://eprel.ec.europa.eu/qr/871626 BXRC-35E10K0-D-8x 3500 80 5500 39.9 36997 219.5 168.5 D 871631 https://eprel.ec.europa.eu/qr/871631 BXRC-35G10K0-B-8x 3500 90 1030 48.5 5490 50.0 109.8 F 871689 https://eprel.ec.europa.eu/qr/871689 BXRC-35G10K0-C-8x 3500 90 3330 71.0 26596 236.4 112.5 F 871694 https://eprel.ec.europa.eu/qr/871694 BXRC-35G10K0-D-8x 3500 90 5500 39.9 30406 219.5 138.5 E 871699 https://eprel.ec.europa.eu/qr/871699 BXRC-40C10K1-B-8x 4000 70 2430 51.4 15778 124.9 126.4 E 871779 https://eprel.ec.europa.eu/qr/871779 BXRC-40C10K1-C-8x 4000 70 4750 74.3 46013 353.1 130.3 E 871785 https://eprel.ec.europa.eu/qr/871785 BXRC-40C10K1-D-8x 4000 70 5500 39.9 38911 219.5 177.2 C 871791 https://eprel.ec.europa.eu/qr/871791 BXRC-40E10K0-B-8x 4000 80 2690 51.9 16571 139.5 118.8 F 871853 https://eprel.ec.europa.eu/qr/871853 BXRC-40E10K0-C-8x 4000 80 4750 74.3 44001 353.1 124.6 E 871858 https://eprel.ec.europa.eu/qr/871858 https://eprel.ec.europa.eu/qr/871863 BXRC-40E10K0-D-8x 4000 80 5500 39.9 37210 219.5 169.5 D 871863 BXRC-40G10K0-B-8x 4000 90 1190 48.9 6426 58.2 110.4 F 871922 https://eprel.ec.europa.eu/qr/871922 BXRC-40G10K0-C-8x 4000 90 3630 71.7 29293 260.3 112.5 F 871927 https://eprel.ec.europa.eu/qr/871927 BXRC-40G10K0-D-8x 4000 90 5500 39.9 31043 219.5 141.4 E 871932 https://eprel.ec.europa.eu/qr/871932 https://eprel.ec.europa.eu/qr/872009 BXRC-50C10K1-B-8x 5000 70 2510 51.5 16347 129.3 126.4 E 872009 BXRC-50C10K1-C-8x 5000 70 4750 74.3 46264 353.1 131.0 E 872013 https://eprel.ec.europa.eu/qr/872013 BXRC-50C10K1-D-8x 5000 70 5500 39.9 39123 219.5 178.2 C 872017 https://eprel.ec.europa.eu/qr/872017 BXRC-50E10K1-B-8x 5000 80 2850 52.2 17669 148.6 118.9 E 872061 https://eprel.ec.europa.eu/qr/872061 BXRC-50E10K1-C-8x 5000 80 4750 74.3 44504 353.1 126.0 E 872065 https://eprel.ec.europa.eu/qr/872065 BXRC-50E10K1-D-8x 5000 80 5500 39.9 37635 219.5 171.4 D 872069 https://eprel.ec.europa.eu/qr/872069 BXRC-50G10K1-B-8x 5000 90 1680 50.0 9333 83.9 111.2 F 872113 https://eprel.ec.europa.eu/qr/872113 https://eprel.ec.europa.eu/qr/872117 BXRC-50G10K1-C-8x 5000 90 4270 73.2 35240 312.6 112.7 F 872117 BXRC-50G10K1-D-8x 5000 90 5500 39.9 32532 219.5 148.2 D 872121 https://eprel.ec.europa.eu/qr/872121 BXRC-57C10K1-B-8x 5700 70 2130 50.8 13650 108.3 126.1 E 872218 https://eprel.ec.europa.eu/qr/872218 BXRC-57C10K1-C-8x 5700 70 4750 74.3 45007 353.1 127.5 E 872222 https://eprel.ec.europa.eu/qr/872222 BXRC-57C10K1-D-8x 5700 70 5500 39.9 38060 219.5 173.4 C 872226 https://eprel.ec.europa.eu/qr/872226 BXRC-57E10K1-B-8x 5700 80 2280 51.1 13814 116.5 118.6 F 872267 https://eprel.ec.europa.eu/qr/872267 BXRC-57E10K1-C-8x 5700 80 4750 74.3 42744 353.1 121.1 E 872271 https://eprel.ec.europa.eu/qr/872271 https://eprel.ec.europa.eu/qr/872275 BXRC-57E10K1-D-8x 5700 80 5500 39.9 36146 219.5 164.7 D 872275 BXRC-65C10K1-B-8x 6500 70 2130 50.8 13650 108.3 126.1 E 872315 https://eprel.ec.europa.eu/qr/872315 BXRC-65C10K1-C-8x 6500 70 4750 74.3 45007 353.1 127.5 E 872319 https://eprel.ec.europa.eu/qr/872319 BXRC-65C10K1-D-8x 6500 70 5500 39.9 38060 219.5 173.4 C 872323 https://eprel.ec.europa.eu/qr/872323 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 8 European Product Registry for Energy Labeling Table 3: Part numbers registered in European Product Registry for Energy Labeling (Continued) PART NUMBER CCT (K) CRI 1 Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database BXRC-65E10K1-B-8x 6500 80 2440 51.4 14886 125.4 118.7 F 872365 https://eprel.ec.europa.eu/qr/872365 BXRC-65E10K1-C-8x 6500 80 4750 74.3 43247 353.1 122.5 E 872369 https://eprel.ec.europa.eu/qr/872369 BXRC-65E10K1-D-8x 6500 80 5500 39.9 36572 219.5 166.6 D 872373 https://eprel.ec.europa.eu/qr/872373 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 9 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E10K0-B-8x 80 BXRC-27E10K0-C-8x 80 BXRC-27E10K0-D-8x 80 BXRC-27G10K0-B-8x 90 BXRC-27G10K0-C-8x 90 BXRC-27G10K0-D-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 6175 9223 12247 15496 23309 36738 7614 11372 15099 19521 28739 48070 5431 8112 10771 13122 20500 31080 5095 7609 10103 12784 19230 30308 6281 9382 12457 16105 23709 39658 4481 6692 8886 10826 16913 25641 5558 8301 11022 13946 20978 33064 6852 10235 13589 17569 25865 43263 4888 7301 9694 11810 18450 27972 4585 6848 9093 11506 17307 27278 5653 8444 11211 14494 21338 35692 4033 6023 7997 9743 15221 23077 182 178 174 168 156 137 182 178 174 168 156 134 182 178 174 169 156 139 150 147 144 139 129 113 150 147 144 138 129 110 150 147 144 140 129 114 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G1KH0-B-8x 90 BXRC-27G1KH0-C-8x 90 BXRC-27G1KH0-D-8x 90 BXRC-27H10K0-B-8x 97 typ. BXRC-27H10K0-C-8x 97 typ. BXRC-27H10K0-D-8x 97 typ. Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 5315 7938 10540 13336 20060 31617 6553 9787 12995 16800 24733 41370 4674 6981 9270 11294 17643 26748 4516 6745 8955 11331 17045 26864 5568 8316 11041 14275 21015 35151 3972 5932 7876 9596 14991 22727 4783 7144 9486 12002 18054 28456 5897 8808 11695 15120 22260 37233 4207 6283 8343 10164 15879 24073 4064 6070 8060 10198 15340 24178 5011 7484 9937 12847 18914 31636 3574 5339 7089 8636 13492 20454 156 153 150 145 135 118 156 153 150 144 135 115 156 153 150 146 135 119 133 130 127 123 114 100 133 130 127 123 114 98 133 130 127 124 114 101 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30C10K1-B-8x 70 BXRC-30C10K1-C-8x 70 BXRC-30C10K1-D-8x 70 BXRC-30E10K0-B-8x 80 BXRC-30E10K0-C-8x 80 BXRC-30E10K0-D-8x 80 BXRC-30G10K0-B-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 6870 10261 13624 17239 25931 40871 8470 12651 16798 21717 31972 53478 6042 9025 11983 14599 22806 34576 6561 9800 13012 16464 24766 39034 8090 12083 16043 20741 30535 51074 5771 8619 11444 13943 21781 33022 5326 7955 10563 13365 20104 31686 6183 9235 12262 15515 23338 36783 7623 11386 15118 19545 28775 48130 5438 8122 10784 13139 20526 31119 5905 8820 11711 14818 22289 35130 7281 10874 14439 18667 27481 45967 5194 7757 10300 12548 19603 29720 4794 7160 9506 12029 18094 28518 202 198 194 187 174 152 202 198 194 187 174 149 202 198 194 188 174 154 193 189 185 179 166 145 193 189 185 178 166 142 193 189 185 180 166 147 157 153 150 145 135 118 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G10K0-C-8x 90 BXRC-30G10K0-D-8x 90 BXRC-30G1KH0-B-8x 90 BXRC-30G1KH0-C-8x 90 BXRC-30G1KH0-D-8x 90 BXRC-30H10K0-B-8x 97 typ. BXRC-30H10K0-C-8x 97 typ. Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 6567 9808 13023 16837 24787 41460 4684 6997 9290 11318 17681 26806 5577 8330 11060 13995 21051 33179 6876 10270 13637 17630 25955 43413 4905 7326 9727 11851 18514 28069 4825 7206 9568 12106 18210 28701 5948 8884 11796 15251 22452 37554 5910 8827 11721 15153 22308 37314 4216 6297 8361 10186 15913 24126 5019 7497 9954 12595 18946 29861 6189 9243 12273 15867 23359 39072 4415 6594 8755 10666 16663 25262 4342 6485 8611 10895 16389 25831 5354 7996 10617 13726 20207 33799 157 153 150 145 135 115 157 153 150 146 135 120 164 161 157 152 141 123 164 161 157 152 141 121 164 161 157 153 141 125 142 139 136 131 122 107 142 139 136 131 122 104 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30H10K0-D-8x 97 typ. BXRC-35E10K0-B-8x 80 BXRC-35E10K0-C-8x 80 BXRC-35E10K0-D-8x 80 BXRC-35G10K0-B-8x 90 BXRC-35G10K0-C-8x 90 BXRC-35G10K0-D-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 4243 6337 8415 10252 16016 24281 6716 10030 13318 16852 25349 39952 8280 12367 16420 21229 31253 52276 5906 8822 11713 14271 22294 33799 5519 8243 10945 13849 20832 32834 6805 10164 13495 17447 25685 42962 4854 7250 9626 11728 18322 27778 3819 5704 7573 9227 14414 21853 6044 9027 11986 15166 22814 35957 7452 11130 14778 19106 28128 47048 5316 7940 10542 12844 20065 30419 4967 7419 9851 12464 18749 29551 6124 9147 12145 15702 23117 38666 4369 6525 8664 10555 16490 25000 142 139 136 132 122 108 198 193 189 183 170 149 198 193 189 182 170 145 198 193 189 184 170 151 162 159 156 150 140 122 162 159 156 150 140 119 162 159 156 151 140 124 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40C10K1-B-8x 70 BXRC-40C10K1-C-8x 70 BXRC-40C10K1-D-8x 70 BXRC-40E10K0-B-8x 80 BXRC-40E10K0-C-8x 80 BXRC-40E10K0-D-8x 80 BXRC-40G10K0-B-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 7063 10549 14007 17723 26660 42019 8708 13007 17270 22327 32870 54980 6212 9278 12319 15009 23447 35548 6754 10088 13395 16948 25494 40182 8328 12438 16515 21351 31433 52576 5940 8872 11781 14353 22422 33994 5635 8416 11175 14140 21269 33523 6357 9494 12606 15951 23994 37817 7838 11706 15543 20094 29583 49482 5591 8350 11087 13508 21102 31993 6079 9079 12055 15254 22945 36164 7495 11194 14863 19216 28290 47319 5346 7985 10603 12917 20180 30594 5072 7575 10058 12726 19143 30171 208 203 199 192 179 156 208 203 199 192 179 153 208 203 199 193 179 159 199 194 190 184 171 150 199 194 190 183 171 146 199 194 190 185 171 152 166 162 159 154 143 125 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40G10K0-C-8x 90 BXRC-40G10K0-D-8x 90 BXRC-50C10K1-B-8x 70 BXRC-50C10K1-C-8x 70 BXRC-50C10K1-D-8x 70 BXRC-50E10K1-B-8x 80 BXRC-50E10K1-C-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 6948 10377 13778 17813 26224 43864 4956 7402 9828 11974 18706 28360 7102 10607 14084 17820 26805 42248 8756 13078 17364 22449 33049 55280 6246 9329 12386 15091 23575 35742 6832 10203 13548 17142 25786 40641 8423 12580 16704 21595 31792 53177 6253 9339 12400 16032 23602 39477 4460 6662 8846 10777 16836 25524 6392 9546 12675 16038 24125 38023 7880 11770 15628 20204 29744 49752 5621 8396 11148 13582 21218 32168 6148 9183 12193 15428 23207 36577 7581 11322 15033 19435 28613 47859 166 162 159 153 143 122 166 162 159 154 143 127 209 204 200 194 180 157 209 204 200 193 180 154 209 204 200 195 180 159 201 197 193 186 173 151 201 197 193 186 173 148 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50E10K1-D-8x 80 BXRC-50G10K1-B-8x 90 BXRC-50G10K1-C-8x 90 BXRC-50G10K1-D-8x 90 BXRC-56H10K0-C-8x 97 BXRC-56H10K0-D-8x 97 BXRC-57C10K1-B-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 6008 8974 11915 14517 22678 34382 5905 8820 11711 14818 22289 35130 7281 10874 14439 18667 27481 45967 5194 7757 10300 12548 19603 29720 6615 9880 13118 16959 24968 41762 4718 7047 9357 11400 17809 27000 6909 10319 13701 17336 26077 41100 5407 8076 10724 13065 20410 30944 5315 7938 10540 13336 20060 31617 6553 9787 12995 16800 24733 41370 4674 6981 9270 11294 17643 26748 5953 8892 11806 15263 22471 37586 4246 6342 8421 10260 16028 24300 6218 9287 12331 15602 23469 36990 201 197 193 187 173 153 174 170 166 161 149 131 174 170 166 160 149 128 174 170 167 162 149 133 158 154 151 146 136 116 158 154 151 147 136 120 203 199 195 188 175 153 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57C10K1-C-8x 70 BXRC-57C10K1-D-8x 70 BXRC-57E10K1-B-8x 80 BXRC-57E10K1-C-8x 80 BXRC-57E10K1-D-8x 80 BXRC-65C10K1-B-8x 70 BXRC-65C10K1-C-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 8518 12722 16892 21839 32151 53778 6076 9075 12050 14681 22935 34771 6561 9800 13012 16464 24766 39034 8090 12083 16043 20741 30535 51074 5771 8619 11444 13943 21781 33022 6909 10319 13701 17336 26077 41100 8518 12722 16892 21839 32151 53778 7666 11450 15203 19655 28936 48400 5469 8168 10845 13213 20641 31294 5905 8820 11711 14818 22289 35130 7281 10874 14439 18667 27481 45967 5194 7757 10300 12548 19603 29720 6218 9287 12331 15602 23469 36990 7666 11450 15203 19655 28936 48400 203 199 195 188 175 149 203 199 195 189 175 155 193 189 185 179 166 145 193 189 185 178 166 142 193 189 185 180 166 147 203 199 195 188 175 153 203 199 195 188 175 149 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-65C10K1-D-8x 70 BXRC-65E10K1-B-8x 80 BXRC-65E10K1-C-8x 80 BXRC-65E10K1-D-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 850 1275 1700 2100 3400 5500 700 1050 1400 1800 2800 4750 650 975 1300 1710 2600 4750 850 1275 1700 2100 3400 5500 35.1 35.8 36.4 36.9 38.6 40.7 48.5 49.4 50.2 51.2 53.3 56.6 64.4 65.6 66.7 68.0 70.7 75.8 35.1 35.8 36.4 36.9 38.6 40.7 29.9 45.6 61.9 77.6 131.1 224.1 34.0 51.9 70.3 92.1 149.1 268.8 41.9 64.0 86.7 116.4 183.9 360.1 29.9 45.6 61.9 77.6 131.1 224.1 6076 9075 12050 14681 22935 34771 6639 9915 13165 16658 25057 39493 8185 12225 16232 20985 30894 51675 5839 8720 11579 14107 22038 33411 5469 8168 10845 13213 20641 31294 5975 8924 11849 14992 22551 35544 7366 11002 14609 18886 27805 46507 5255 7848 10421 12696 19834 30070 203 199 195 189 175 155 195 191 187 181 168 147 195 191 187 180 168 144 195 191 187 182 168 149 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 19 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx10Kx-B-8x BXRC-xxx10Kx-C-8x BXRC-xxx10Kx-D-8x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.05 45.1 55.0 -18.26 0.10 50.9 62.0 71.7 -21.51 0.05 60.0 73.1 75.8 81.5 -24.45 0.11 68.2 83.1 33.7 36.4 39.1 -11.74 0.06 32.7 39.9 37.6 40.7 43.8 -13.13 0.11 36.6 44.6 Minimum Typical Maximum 1400 46.4 50.2 54.0 -16.19 4750 52.4 56.6 60.8 1300 61.7 66.7 4750 70.1 1700 5500 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 1140 V. The working voltage designated for the insulation is 70V d.c. The maximum allowable voltage across the array must be determined in the end product application. 20 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number CCT5 Drive Current (mA) 2700K/3000K 4000K2 5000K3 6500K4 2145 RG1 RG1 RG1 RG1 2970 RG1 RG1 RG1 RG2 3945 RG1 RG1 RG2 RG2 4750 RG1 RG2 RG2 RG2 1615 RG1 RG1 RG1 RG1 2235 RG1 RG1 RG1 RG2 2970 RG1 RG1 RG2 RG2 4750 RG1 RG2 RG2 RG2 2960 RG1 RG1 RG1 RG1 4100 RG1 RG1 RG1 RG2 5500 RG1 RG1 RG2 RG2 BXRC-xxx10Kx-B-8x BXRC-xxx10Kx-C-8x BXRC-xxx10Kx-D-8x Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1980 lx. 3. For products classified as RG2 at 5000K Ethr= 1530 lx. 4. For products classified as RG2 at 6500K, Ethr= 1170 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 21 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRC-xxx10Kx-B-8x BXRC-xxx10Kx-C-8x BXRC-xxx10Kx-D-8x Maximum Drive Current3 4750 mA 4750 mA 5500 mA Maximum Peak Pulsed Drive Current4,5 5320 mA 5320 mA 6160 mA Maximum Reverse Voltage6 -90V -120V -65V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN31: Assembly Considerations for Bridgelux Vero LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Per IEC 62031, LED Modules for General Lighting - Safety Specifications, the maximum allowable current when using the Molex Pico Connector is 3150mA. 5. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 6. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 22 Performance Curves Figure 1: Vero 29B Drive Current vs. Voltage Figure 2: Vero 29C Drive Current vs. Voltage 57.0 78.0 56.0 76.0 74.0 54.0 Voltage (V) Voltage (V) 55.0 53.0 52.0 51.0 72.0 70.0 68.0 50.0 66.0 49.0 64.0 48.0 0 750 1500 2250 3000 3750 4500 62.0 5250 0 750 1500 2250 Drive Current (mA) Figure 3: Vero 29D Drive Current vs. Voltage 4500 5250 350% Relative Luminous Flux (%) 41.0 40.0 Voltage (V) 3750 Figure 4: Vero 29B Typical Relative Flux vs. Current 42.0 39.0 38.0 37.0 36.0 35.0 34.0 0 750 1500 2250 3000 3750 4500 5250 300% 250% 200% 150% 100% 50% 0% 6000 0 750 1500 Drive Current (mA) 2250 3000 3750 4500 5250 Drive Current (mA) Figure 5: Vero 29C Typical Relative Flux vs. Current Figure 6: Vero 29D Typical Relative Flux vs. Current 350% Relative Luminous Flux (%) 350% Relative Luminous Flux (%) 3000 Drive Current (mA) 300% 250% 200% 150% 100% 50% 300% 250% 200% 150% 100% 50% 0% 0% 0 750 1500 2250 3000 Drive Current (mA) 3750 4500 5250 0 750 1500 2250 3000 3750 4500 5250 6000 Drive Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 23 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature Figure 7: Typical DC Flux vs. Case Temperature 0.0010 102% 0.0000 Relative Luminous Flux 100% -0.0010 98% -0.0020 ccy shift 96% 94% -0.0030 -0.0040 92% -0.0050 90% -0.0060 -0.0070 88% 0 20 40 60 80 100 0 120 20 40 60 80 100 120 100 120 Case Temperature (Tc) Case Temperature (Tc) Figure 10: Derating Curve Figure 9: Typical DC ccx Shift vs. Case Temperature 0.0020 6000 25C Pulsed Drive Current (mA) 0.0000 ccx shift -0.0020 -0.0040 -0.0060 5000 4000 3000 BXRC-xxx10K0-B-8x 2000 BXRC-xxx10Kx-C-8x 1000 BXRC-xxx10Kx-D-8x -0.0080 0 0 -0.0100 0 20 40 60 80 100 120 20 40 60 80 Case Temperature (Tc) Case Temperature (Tc) Note for Figures 7-9: 1. Characteristics shown for Warm White. 24 Typical Radiation Pattern Figure 11: Typical Spatial Radiation Pattern Notes for Figure 11: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 12: Typical Polar Radiation Pattern 25 Typical Color Spectrum Figure 13: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 13: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. 26 Mechanical Dimensions Figure 14: Drawing for Vero 29 LED Array Notes for Figure 14: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Mounting holes (4X) are for M3 screws. 5. Bridgelux recommends four tapped holes for mounting screws with 43.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 27 Color Binning Information Figure 15: Warm and Neutral White Test Bins in xy Color Figure 16: Cool White Test Bins in xy Color Space Space 0.44 0.39 4 SDCM 3 SDCM 3 SDCM 0.38 2 SDCM 2700K 0.42 0.37 3000K 0.4 5000K 0.36 3500K 5700K 0.35 Y Y 4000K 0.34 0.38 6500K 0.33 0.36 0.32 0.31 0.34 0.36 0.39 0.42 X 0.45 0.3 0.48 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 85°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C9 Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 84 (4 SDCM) (4801K - 5282K) (5395K- 5970K) (6200K - 6910K) 83 (3 SDCM) (4835K - 5215K) (5460K- 5891K) (6279K -6811K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) Note for Tables 8-9: 1. Bridgelux maintains a tolerance of +/- 0.007 on x and y color coordinates in the CIE 1931 color Space. 28 Packaging and Labeling Figure 17: Drawing for Vero 29 Packaging Tray Notes for Figure 17: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 29 Packaging and Labeling Figure 18: Vero Series Packaging and Labeling Notes for Figure 18: 1. Each tray holds 50 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 19: Gen. 8 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E10K0C 83 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 30 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 31 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46410 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 Vero 29 Array Series Product Data Sheet DS423 Rev. D (12/2021) 32
BXRC-56H10K0-D-84 价格&库存
很抱歉,暂时无法提供与“BXRC-56H10K0-D-84”相匹配的价格&库存,您可以联系我们找货
