BXRH-30G1000-G-73
BXRH-30G1000-G-73
    BRIDGELUX(普瑞)
BXRH-30G1000-G-73 数据手册
Bridgelux Gen. 7 V6 HD LED Array ® Product Data Sheet DS401 1 V Series HD Introduction V Series™ HD LED array product, an ultra-high lumen density COB product line, is designed for high intensity spotlights used in commercial and retail settings. V Series HD arrays offer industry leading color over angle uniformity, and replace ceramic metal halide lamps by providing equal or greater center beam candle power at lower power and at greater lifetimes. Their tight beam control and exceptional quality of light is well suited for demanding directional spot applications. The V6 HD LED array is available in a variety of CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, but are not limited to, commercial and residential down lights, accent, spot and track lights. Bridgelux Décor Series™ is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 91, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features Benefits • Efficacy of 125 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixelation • Uniform high quality illumination • High quality true color reproduction • Minimum 80, 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 3 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 5 Electrical Characteristics 7 Eye Safety 8 Absolute Maximum Ratings 9 Performance Curves 10 Typical Radiation Pattern 12 Typical Color Spectrum 13 Mechanical Dimensions 14 Color Binning Information 15 Packaging and Labeling 16 Design Resources 18 Precautions 18 Disclaimers 18 About Bridgelux 19 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series HD arrays are the most compact chip-on-board devices across all of Designed to comply with global safety standards for creepage and clearance distances Bridgelux’s LED array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series HD family of products. Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series HD LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRH – 30 E 100 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K Gen. 7 3 = 3 SDCM Array Configuration CRI E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 100x = 1000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRH-27E1000-B-73 2700 80 350 1508 1297 36.4 12.7 118 BXRH-27E1000-G-73 2700 80 700 1508 1297 18.2 12.7 118 BXRH-27G1000-B-73 2700 90 350 1254 1078 36.4 12.7 98 BXRH-27G1000-G-73 2700 90 700 1254 1078 18.2 12.7 98 BXRH-27H1000-B-73 2700 97 350 1111 955 36.4 12.7 87 BXRH-27H1000-G-73 2700 97 700 1111 955 18.2 12.7 87 BXRH-30E1000-B-73 3000 80 350 1587 1365 36.4 12.7 125 BXRH-30E1000-G-73 3000 80 700 1587 1365 18.2 12.7 125 BXRH-30G1000-B-73 3000 90 350 1333 1146 36.4 12.7 105 BXRH-30G1000-G-73 3000 90 700 1333 1146 18.2 12.7 105 BXRH-30G100C-B-73 3000 90 350 1222 1051 36.4 12.7 96 BXRH-30G100C-G-73 3000 90 700 1222 1051 18.2 12.7 96 BXRH-30H1000-B-73 3000 97 350 1174 1010 36.4 12.7 92 BXRH-30H1000-G-73 3000 97 700 1174 1010 18.2 12.7 92 BXRH-35A1001-B-738,9 3500 93 350 1333 1146 36.4 12.7 105 BXRH-35A1001-G-738,9 3500 93 700 1333 1146 18.2 12.7 105 BXRH-35G1000-B-73 3500 90 350 1365 1174 36.4 12.7 107 BXRH-35G1000-G-73 3500 90 700 1365 1174 18.2 12.7 107 BXRH-40E1000-B-73 4000 80 350 1650 1419 36.4 12.7 130 BXRH-40E1000-G-73 4000 80 700 1650 1419 18.2 12.7 130 BXRH-40G1000-B-73 4000 90 350 1397 1201 36.4 12.7 110 BXRH-40G1000-G-73 4000 90 700 1397 1201 18.2 12.7 110 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 91. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRH-27E1000-B-73 2700 80 350 1327 1141 35.4 12.4 107 BXRH-27E1000-G-73 2700 80 700 1327 1141 17.7 12.4 107 BXRH-27G1000-B-73 2700 90 350 1103 949 35.4 12.4 89 BXRH-27G1000-G-73 2700 90 700 1103 949 17.7 12.4 89 79 BXRH-27H1000-B-73 2700 97 350 978 841 35.4 12.4 BXRH-27H1000-G-73 2700 97 700 978 841 17.7 12.4 79 BXRH-30E1000-B-73 3000 80 350 1397 1201 35.4 12.4 113 BXRH-30E1000-G-73 3000 80 700 1397 1201 17.7 12.4 113 BXRH-30G1000-B-73 3000 90 350 1173 1009 35.4 12.4 95 BXRH-30G1000-G-73 3000 90 700 1173 1009 17.7 12.4 95 BXRH-30G100C-B-73 3000 90 350 1075 925 35.4 12.4 87 BXRH-30G100C-G-73 3000 90 700 1075 925 17.7 12.4 87 BXRH-30H1000-B-73 3000 97 350 1033 889 35.4 12.4 83 BXRH-30H1000-G-73 3000 97 700 1033 889 17.7 12.4 83 BXRH-35A1001-B-738,9 3500 93 350 1173 1009 35.4 12.4 95 BXRH-35A1001-G-738,9 3500 93 700 1173 1009 17.7 12.4 95 BXRH-35G1000-B-73 3500 90 350 1201 1033 35.4 12.4 97 BXRH-35G1000-G-73 3500 90 700 1201 1033 17.7 12.4 97 BXRH-40E1000-B-73 4000 80 350 1452 1249 35.4 12.4 117 BXRH-40E1000-G-73 4000 80 700 1452 1249 17.7 12.4 117 BXRH-40G1000-B-73 4000 90 350 1229 1057 35.4 12.4 99 BXRH-40G1000-G-73 4000 90 700 1229 1057 17.7 12.4 99 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 91. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 4 Performance at Commonly Used Drive Currents V Series HD LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series HD LED arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 1 and the flux vs. current characteristics shown in Figure 2. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRH-27E1000-B-73 80 BXRH-27E1000-G-73 80 BXRH-27G1000-B-73 90 BXRH-27G1000-G-73 90 BXRH-27H1000-B-73 97 (typical) BXRH-27H1000-G-73 97 (typical) BXRH-30E1000-B-73 80 BXRH-30E1000-G-73 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 813 1123 1508 1833 1970 813 1123 1508 1833 1970 676 934 1254 1524 1638 676 934 1254 1524 1638 599 827 1111 1351 1452 599 827 1111 1351 1452 855 1182 1587 1930 2074 855 1182 1587 1930 2074 715 988 1327 1613 1734 715 988 1327 1613 1734 595 822 1103 1341 1442 595 822 1103 1341 1442 527 728 978 1189 1277 527 728 978 1189 1277 753 1040 1397 1698 1825 753 1040 1397 1698 1825 136 128 118 112 109 137 129 120 113 110 113 106 98 93 90 114 107 100 94 91 100 94 87 82 80 101 95 88 83 81 143 134 125 117 114 144 136 126 119 116 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRH-30G1000-B-73 90 BXRH-30G1000-G-73 90 BXRH-30G100C-B-73 90 BXRH-30G100C-G-73 90 BXRH-30H1000-B-73 97 (typical) BXRH-30H1000-G-73 97 (typical) BXRH-35A1001-B-73 93 (typical) BXRH-35A1001-G-73 93 (typical) BXRH-35G1000-B-73 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 718 993 1333 1621 1742 718 993 1333 1621 1742 659 910 1222 1486 1597 659 910 1222 1486 1597 633 874 1174 1428 1535 633 874 1174 1428 1535 718 993 1333 1621 1742 718 993 1333 1621 1742 736 1016 1365 1659 1783 632 874 1173 1426 1533 632 874 1173 1426 1533 580 801 1075 1308 1405 580 801 1075 1308 1405 557 770 1033 1257 1350 557 770 1033 1257 1350 632 874 1173 1426 1533 632 874 1173 1426 1533 647 894 1201 1460 1569 120 113 105 99 96 121 114 106 100 97 110 103 96 90 88 111 105 97 91 89 106 99 92 87 85 107 100 93 88 86 120 113 105 99 96 121 114 106 100 97 123 116 107 101 98 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 6 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRH-35G1000-G-73 90 BXRH-40E1000-B-73 80 BXRH-40E1000-G-73 80 BXRH-40G1000-B-73 90 BXRH-40G1000-G-73 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 175 250 350 440 480 350 500 700 880 960 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 34.2 35.2 36.4 37.3 37.7 16.9 17.4 18.2 18.5 18.7 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 6.0 8.8 12.7 16.4 18.1 5.9 8.7 12.7 16.3 17.9 736 1016 1365 1659 1783 889 1229 1650 2007 2157 889 1229 1650 2007 2157 753 1040 1397 1698 1825 753 1040 1397 1698 1825 647 894 1201 1460 1569 783 1082 1452 1766 1898 783 1082 1452 1766 1898 662 915 1229 1494 1606 662 915 1229 1494 1606 124 117 108 102 99 149 140 130 122 119 150 141 131 123 120 126 118 110 103 101 127 119 111 104 102 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRH-xxx100x-B-73 BXRH-xxx100x-G-73 Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.36 32.8 40.2 -16.2 0.39 33.9 41.5 19.6 -8.1 0.36 16.4 20.1 20.2 -8.1 0.39 16.9 20.8 Minimum Typical Maximum 350 34.1 36.4 39.1 -16.2 480 35.2 37.8 40.4 700 17.0 18.2 960 17.6 18.9 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 50V d.c. The maximum allowable voltage across the array must be determined in the end product application. 8 Eye Safety Table 5: Eye Safety Risk Group (RG) Classifications Part Number BXRH-xxx100x-B-73 BXRH-xxx100x-G-73 CCT1,3 Drive Current3 (mA) 2700K/3000K 4000K2 350 RG1 RG2 480 RG1 RG2 700 RG1 RG2 960 RG1 RG2 Notes for Table 5: 1. Eye safety classification for the use of Bridgelux V Series HD LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1760 lx. 3. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 9 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRH-xxx100x-B-7x BXRH-xxx100x-G-7x Maximum Drive Current3 480mA 960mA Maximum Peak Pulsed Drive Current4 680mA 1360mA Maximum Reverse Voltage5 -60V -35V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced, and product warranty will be void. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 10 Performance Curves Figure 2: Drive Current vs. Voltage V6G HD2 Figure 1: Drive Current vs. Voltage V6B HD2 1200 600 1000 Forward Current (mA) Forward Current (mA) 500 400 300 800 600 200 200 100 0 0 32 33 34 35 Forward Voltage (Vf) 36 37 16 38 16.5 17 17.5 Forward Voltage (Vf) 18 18.5 19 Figure 4: Typical Relative Flux vs. Current V6G HD1,2 Figure 3: Typical Relative Flux vs. Current V6B HD1,2 140% 140% 120% 120% Relative Luminous Flux Relative Luminous Flux 400 100% 80% 60% 40% 100% 80% 60% 40% 20% 20% 0% 0% 0 100 200 300 400 500 600 0 200 400 600 800 1000 1200 Drive Current (mA) Drive Current (mA) Figure 5: Typical DC Flux vs. Case Temperature3 103% Warm White Neutral White Relative Luminous Flux 100% Cool White 25°C Pulsed 97% 94% 91% 88% 85% 82% 0 25 50 75 100 125 Case Temperature (°C) Notes for Figures 1-5: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 3. Characteristics shown for warm white based on 3000K and 80 CRI. Characteristics shown for neutral white based on 4000K and 80 CRI. Characteristics shown for warm white includes Decor Series Class A 11 Performance Curves Figure 6: Typical DC ccx Shift vs. Case Temperature4 0 20 40 60 80 100 Figure 7: Typical DC ccy Shift vs. Case Temperature4 120 0.0000 0 20 40 60 80 100 120 0.0020 -0.0005 -0.0010 0.0000 -0.0020 -0.0020 ccy shift ccx shift -0.0015 -0.0025 -0.0030 -0.0040 -0.0060 -0.0035 -0.0040 -0.0080 -0.0045 -0.0100 -0.0050 Case Temperature (Tc) -0.0120 Case Temperature (Tc) Figure 8: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 9: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.3950 0.4323 0.4572 0.4574 0.4576 0.4578 0.4328 0.4333 ccx 0.4343 0.4348 0.4353 ccx Figure 10: 3500K Class A Color Shift vs. Case Temperature1 Figure 11: 3000K, 90 CRI Color Shift vs. Case Temperature3 0.403 0.37 15°C 0.368 25°C 0.366 70°C 0.399 85°C 0.397 0.36 0.396 105°C 0.393 65°C 0.398 85°C 0.358 0.392 45°C 0.4 0.364 Pulsed Center Point Tc=25°C 25°C 0.401 45°C 0.362 15°C 0.402 Pulsed Center Point Tc=25°C ccy ccy 0.4338 0.458 0.394 0.395 0.396 0.397 0.395 0.444 105°C 0.4445 0.445 ccx 0.4455 0.446 0.4465 0.447 ccx Notes for Figures 6-11: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRH-30G100C-x-73 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 12 Typical Radiation Pattern Figure 12: Typical Spatial Radiation Pattern Notes for Figure 12: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 13: Typical Polar Radiation Pattern 13 Typical Color Spectrum Figure 14: Typical Color Spectrum 100% 27E 30E 90% 40E Relative Spectral Power Distribution 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Notes for Figure 14: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 2700K and 80 CRI. 3. Color spectra shown is 3000K and 80 CRI. 4. Color spectra shown is 4000K and 80 CRI. Figure 15: Typical Color Spectrum for Décor Series 100% 27H 90% 30H 30G (Décor Series Showcase) Relative Spectral Power Distribution 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 15: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 14 Mechanical Dimensions Figure 16: Drawing for V6 HD LED Array Notes for Figure 16: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 15 Color Binning Information Figure 17: Warm and Neutral White Test Bins in xy Color Space 0.44 3 SDCM Poly. (Black Body Curve) 2700K 0.42 3000K 3500K 0.4 Y 4000K 0.38 0.36 0.34 0.36 0.39 0.42 0.45 0.48 X Note: Pulsed Test Conditions, Tc = 25°C Table 7: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Notes for Table 7: 1. Color Binning information excludes Décor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. 16 Packaging and Labeling Figure 18: V6 HD Packaging Tube BXRH-30E1000-B-73 30 Notes for Figure 18: 1. Each tube holds 35 V6 HD COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 15.4 (W) x 8.3 (H) x 430 (L) mm. Dimensions for the anti-static bag are 75 (W) x 615 (L) x 0.075 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 17 Packaging and Labeling Figure 19: V Series HD Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E1000B 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 18 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series HD product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series HD LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series HD LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series HD LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 19 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, V Series and Decor Series are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V6 HD Array Series Product Data Sheet DS401 Rev. D (09/2018) 20
BXRH-30G1000-G-73 价格&库存
很抱歉,暂时无法提供与“BXRH-30G1000-G-73”相匹配的价格&库存,您可以联系我们找货
BXRH-30G1000-G-73
