BXEB-L1120Z-40E8000-C-D3
    BRIDGELUX(普瑞)
BXEB-L1120Z-40E8000-C-D3 数据手册
Bridgelux EB Series™ Gen 3 High Output ® Product Data Sheet DS134 Lengths: 280mm, 560mm, 1120mm CRIs: 80, 90 CCTs: 2700K, 3000K, 3500K, 4000K, 5000K, 5700K, 6500K Product Feature Map Bridgelux EB Series Gen 3 High Output modules are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The linear products incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the EB Series family of products. Multiple case temperature measurement points Label containing part number and lot codes is attached on the front of the module where shown Re-usable connector Designed to comply with global safety standards for creepage and clearance distances Zhaga compatible mounting holes Product Nomenclature The part number designation for Bridgelux EB Series Gen 3 Hight Output is explained as follows: 1 2 3 4 - 5 6 7 8 9 10 - 11 12 13 14 15 16 - 17 – 18 BXEB – L0280Z – 30 E 2000 – C – D3 Product Family Nominal Dimensions L= Linear 0280 = 280 mm 0560 = 560 mm 1120 = 1120 mm Z= Zhaga compatible width (24 mm) Module Version D = Gen 3 High Output 3 = 3 SDCM Module Configuration Nominal CCT 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 57 = 5700K 65 = 6500K Minimum CRI E = 80 G = 90 Flux Indicator 2000 = 2000 lm 4000 = 4000 lm 8000 = 8000 lm 2 Product Selection Guide Table 1: Product Performance (Tc = 25° C) Part Number BXEB-L0280Z-27E2000-C-D3 BXEB-L0280Z-27G2000-C-D3 BXEB-L0280Z-30E2000-C-D3 BXEB-L0280Z-30G2000-C-D3 BXEB-L0280Z-35E2000-C-D3 BXEB-L0280Z-35G2000-C-D3 BXEB-L0280Z-40E2000-C-D3 BXEB-L0280Z-40G2000-C-D3 BXEB-L0280Z-50E2000-C-D3 BXEB-L0280Z-50G2000-C-D3 BXEB-L0280Z-57E2000-C-D3 BXEB-L0280Z-57G2000-C-D3 BXEB-L0280Z-65E2000-C-D3 BXEB-L0280Z-65G2000-C-D3 BXEB-L0560Z-27E4000-C-D3 BXEB-L0560Z-27G4000-C-D3 BXEB-L0560Z-30E4000-C-D3 BXEB-L0560Z-30G4000-C-D3 BXEB-L0560Z-35E4000-C-D3 BXEB-L0560Z-35G4000-C-D3 BXEB-L0560Z-40E4000-C-D3 BXEB-L0560Z-40G4000-C-D3 BXEB-L0560Z-50E4000-C-D3 BXEB-L0560Z-50G4000-C-D3 BXEB-L0560Z-57E4000-C-D3 BXEB-L0560Z-57G4000-C-D3 BXEB-L0560Z-65E4000-C-D3 BXEB-L0560Z-65G4000-C-D3 Nominal Minimum 1 CRI Typical Flux2,3 (lm) 80 2350 CCT (K) 2700 3000 3500 4000 5000 5700 6500 2700 3000 3500 4000 5000 5700 6500 Nominal Drive Current (mA) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 175 90 2000 149 80 2480 185 90 2095 156 80 2480 185 90 2095 156 80 2610 700 19.2 13.4 194 90 2225 80 2610 166 194 90 2225 166 80 2610 194 90 2225 166 80 2610 194 90 2225 166 80 4700 175 90 4000 149 80 4960 185 90 4190 156 80 4960 185 90 4190 156 80 5220 1400 19.2 26.9 194 90 4450 80 5220 166 194 90 4450 166 80 5220 194 90 4450 166 80 5220 194 90 4450 166 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. Data is at nominal test current where temperature of center case temperature point Tc= 25° C. 3. Bridgelux maintains a ± 7% tolerance on typical flux data (typical SMD flux bins) 3 Product Selection Guide Table 2: Product Performance (Tc = 25° C) Part Number BXEB-L1120Z-27E8000-C-D3 BXEB-L1120Z-27G8000-C-D3 BXEB-L1120Z-30E8000-C-D3 BXEB-L1120Z-30G8000-C-D3 BXEB-L1120Z-35E8000-C-D3 BXEB-L1120Z-35G8000-C-D3 BXEB-L1120Z-40E8000-C-D3 BXEB-L1120Z-40G8000-C-D3 BXEB-L1120Z-50E8000-C-D3 BXEB-L1120Z-50G8000-C-D3 BXEB-L1120Z-57E8000-C-D3 BXEB-L1120Z-57G8000-C-D3 BXEB-L1120Z-65E8000-C-D3 BXEB-L1120Z-65G8000-C-D3 Nominal Minimum CCT1 (K) CRI 2700 3000 3500 4000 5000 5700 6500 Typical Flux2,3 (lm) Nominal Drive Current (mA) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 80 9400 175 90 8000 149 80 9920 185 90 8380 156 80 9920 185 90 8380 156 80 10440 90 8900 80 10440 194 1400 38.4 53.8 194 166 90 8900 166 80 10440 194 90 8900 166 80 10440 194 90 8900 166 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011 2. Data is at nominal test current where temperature of center case temperature point Tc= 25° C 3. Bridgelux maintains a ± 7% tolerance on typical flux data (typical SMD flux bins) 4 Electrical Characteristics Table 3: Electrical Characteristics Forward Voltage Tc2 Part Number Driver Selection Typical Coefficient of Forward = 25º C (V) 1, 2,3 Drive Current (mA) Voltages5 (V) Voltage4 Minimum Typical Maximum ∆Vf/∆T (mV/º C) Vf Min, Hot Tc2 = 85º C (V) Vf Max, Cold Tc2 = -40º C (V) 700 17.9 19.2 20.5 -7 17.4 21.0 1400 18.7 20.1 21.5 -7 18.3 22.0 1400 17.9 19.2 20.5 -7 17.4 21.0 2800 18.7 20.1 21.5 -7 18.3 22.0 1400 35.7 38.4 41.1 -14 34.9 42.0 2800 37.4 40.2 43.0 -14 36.5 43.9 BXEB-L0280Z-xxy2000-C-D3 BXEB-L0560Z-xxy4000-C-D3 BXEB-L1120Z-xxy8000-C-D3 Notes for Table 3: 1. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a tolerance of ± 0.1 V on forward voltage data. 3. This product has been designed and manufactured per IEC 62031:2014. The working voltage designated for the insulation is 60 V d.c. The maximum allowable voltage across the module must be determined in the end product application. 4. Typical coefficient of forward voltage tolerance is ± 0.1 mV for nominal current. 5. Vf min hot and max cold values are provided as reference only and are not guaranteed. These values are provided to aid in driver design and selection over the operating range of the product. 5 Absolute Maximum Ratings Table 4: Maximum Ratings Parameter Maximum Rating Storage Temperature -40°C to +85°C Operating Case Temperature2 (Tc) 85°C Soldering Temperature 350°C or lower for a maximum of 5 seconds Maximum Reverse Voltage Modules are not designed to be driven in reverse bias Maximum Drive Current BXEB-L0280Z-xxx2000-C-D3 BXEB-L0560Z-xxx4000-C-D3 BXEB-L1120Z-xxx8000-C-D3 1400mA 2800mA 2800mA Notes for Table 4: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the SMDs used in the modules. Contact your Bridgelux sales representatives for LM-80 report. 6 Performance Curves Figure 1: 280mm Current vs. Forward Voltage, Tc=25°C Figure 2: 280mm Relative Flux vs. Current, Tc=25°C 1600 200% 180% 160% 1200 Relative Flux Forward Current (mA) 1400 1000 800 600 400 0% 18.50 19.00 19.50 Forward Voltage (V) 20.00 20.50 0 1500 180% 2500 160% 2000 Relative Flux Forward Current (mA) 600 900 1200 Forward Current (mA) 200% 1500 1000 140% 120% 100% 80% 60% 40% 500 20% 0% 18.50 19.00 19.50 Forward Voltage (V) 20.00 20.50 Figure 5: 1120mm Current vs. Forward Voltage, Tc=25°C 0 500 1000 1500 2000 Forward Current (mA) 2500 3000 Figure 6: 1120mm Relative Flux vs. Current, Tc=25°C 3000 200% 180% 2500 160% 2000 Relative Flux Forward Current (mA) 300 Figure 4: 560mm Relative Flux vs. Current, Tc=25°C 3000 1500 1000 140% 120% 100% 80% 60% 40% 500 0 36.00 80% 60% 20% Figure 3: 560mm Current vs. Forward Voltage, Tc=25°C 0 18.00 120% 100% 40% 200 0 18.00 140% 20% 0% 37.00 38.00 39.00 Forward Voltage (V) 40.00 41.00 0 500 1000 1500 2000 Forward Current (mA) 2500 3000 7 Performance Curves Figure 7: Relative Voltage vs. Case Temperature Figure 8: Relative Flux vs. Case Temperature 100.5% 102.0% 25°C Pulsed 25°C Pulsed 100.0% 99.5% Relative Flux Relative Voltage 100.0% 99.0% 98.5% 98.0% 98.0% 96.0% 94.0% 92.0% 97.5% 90.0% 0 20 40 60 Case Temperature (C) 80 100 0 20 40 60 Case Temperature (C) 80 100 8 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern 120% Relative Intensity 100% 80% 60% 40% 20% 0% -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (°) Notes for Figure 9: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. 9 Typical Color Spectrum Figure 10: Typical Color Spectra, 80 CRI 100% 90% 80% Relative Intensity 70% 27E 60% 30E 35E 50% 40E 50E 40% 57E 30% 65E 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Figure 11: Typical Color Spectra, 90 CRI 100% 90% 80% Relative Intensity 70% 27G 60% 30G 35G 50% 40G 50G 40% 57G 30% 65G 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Note for Figures 10 & 11: 1. Color spectra measured at nominal current for Tc = 65°C 10 Mechanical Dimensions Figure 12: Drawing Overview for 280mm Figure 13: Drawing Overview for 560mm Figure 14: Drawing Overview for 1120mm Notes for Figures 12, 13 & 14: 1. Solder pads are labeled “+” to denote positive polarity, and “-” to denote negative polarity. 2. Drawing dimensions are in millimeters. 3. Refer to Bridgelux assembly drawing 15-000682, 15-000683, and 15-000684 for complete product configuration Table 5: Module Dimensions & Connector Wiring Parameter BXEB-L0280Z-xxx2000-C-D3 BXEB-L0560Z-xxx4000-C-D3 BXEB-L1120Z-xxx8000-C-D3 Linear length 280.0 mm 560.0 mm 1120.0 mm Linear width 24 mm Overall thickness 6.1 mm PCB thickness 1.6 mm Input wire cross-section 18-24 AWG Wire strip length 7-9 mm 11 Color Binning Information Figure 15: 3 SDCM Color Bins in CIE 1931 xy Color Space 0.44 0.42 CIE y 0.40 0.38 0.36 0.34 0.32 0.30 0.30 0.32 0.34 0.36 0.38 0.40 0.42 0.44 0.46 0.48 0.50 CIE x Table 6: Bin Coordinates and Associated Typical CCT CCT Color Consistency CIE Center Point (x, y) Corresponding CCT Range 2700K 3 SDCM (0.458, 0.410) 2651K - 2794K 3000K 3 SDCM (0.434, 0.403) 2968K - 3136K 3500K 3 SDCM (0.407, 0.392) 3369K - 3586K 4000K 3 SDCM (0.382, 0.380) 3851K - 4130K 5000K 3 SDCM (0.3445, 0.355) 4835K - 5215K 5700K 3 SDCM (0.329, 0.342) 5490K - 5820K 6500K 3 SDCM (0.312, 0.328) 6250K - 6745K Notes for Table 6 1. Color binning at solder point temperature Tsp of SMDs at 25°C for 80 CRI and 85°C for 90 CRI. 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. 3. Quadrangular ANSI bins shown for reference only 12 Packaging and Labeling Figure 16: EB Series Packaging and Labeling Note: This label & packaging diagram is for illustration only and may differ from actual product label and packaging for this product Table 7: Packaging Structure Box Parameter L0280 modules L0560 modules L1120 modules Quantity 200 100 100 Dimension 34.6 cm x 29.6 cm x 16.9 cm 60.0 cm x 19.4 cm x 16.9 cm 115.9 cm x 19.4 cm x 16.9 cm Figure 17: Product Labeling Bridgelux EB Series modules contain a label on the front to help with product identification. In addition to the product identification markings, Bridgelux EB Series modules also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the module. EB Series Gen3 1ft 2000lm 700mA Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. 13 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the EB Series product family. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux EB Series LED linears are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED linear. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux EB Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. EB Series linears are classified as Risk Group 1 (TBD) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the linear or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the linear. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the EB Series linear. Use the mechanical features of the linear housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the EB Series linears during operation. Allow the linear to cool for a sufficient period of time before handling. The EB Series linears may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, linear testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 14 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 USA Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2020 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. EB Series and Bridging Light and Life are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux EB Series Gen3 High Output Data Sheet DS134 Rev. A (06/2020) 15
BXEB-L1120Z-40E8000-C-D3 价格&库存
很抱歉,暂时无法提供与“BXEB-L1120Z-40E8000-C-D3”相匹配的价格&库存,您可以联系我们找货
