BXRE-35S4001-C-73
BXRE-35S4001-C-73
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) Gen 7 V18 Thrive™ Array 白色,暖色 方形
BXRE-35S4001-C-73 数据手册
® Bridgelux Gen 7 V18 Thrive™ Array Product Data Sheet DS322 1 | | | | | | BXRE-27S 30S 35S 40S 50S 57S 65S V18 Thrive Introduction Bridgelux Thrive™ combines unique chip, phosphor and packaging technology to closely match the spectra of natural light over the visible wavelength range. Thrive can be used in constant color point luminaires to bring full spectrum natural light indoors or in tunable white luminaires to incorporate circadian elements that may impact human well-being. The high fidelity spectral output of Thrive creates stunning environments with excellent color rendering and outstanding TM30 metrics. Thrive is available in both SMD components and LED arrays to enable a broad range of lighting applications including retail, hospitality, office, education, architectural, museums, healthcare and residential lighting. Features Benefits • Engineered spectrum to closely match natural light • Full consistent spectrum with fewer spectral spikes • CRI >95, R1-R15 >90, high Rf and Rg values • Natural and vivid color rendering • High efficacy full spectrum solution • Greater energy savings, lower utility costs • No violet chip augmentation • Economical, high efficiency solution • Hot color targeted • Uniform and consistent white light at application conditions • Form factor consistent with existing Bridgelux COB arrays • Broad product platform availability (SMDs and COBs) • Ease of design and rapid go-to-market • Enables greater design flexibility and platform color consistency Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Spectrum Characteristics 5 Electrical Characteristics 8 Absolute Maximum Ratings 9 Eye Safety 10 Product Bin Definitions 11 Performance Curves 12 Typical Radiation Pattern 13 Mechanical Dimensions 14 Packaging and Labeling 15 Design Resources 17 Precautions 17 Disclaimers 17 About Bridgelux 18 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Designed to comply with global safety standards for creepage and clearance distances Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux COB arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 S 4001 – C – 7 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen 7 Array Configuration 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Flux Indicator 4001 = 4000 lm Minimum CRI S = Thrive 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tc= 25°C) Typical Pulsed Flux4,5,6,7 Tc = 25ºC (lm) Minimum Pulsed Flux6,7,8 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) 34.4 4347 3825 40.2 108 75.85 2.07 34.4 4669 4109 40.2 116 79.77 2.16 CRI Nominal Drive Current3 (mA) Typical Vf (V) 2700 95 1170 3000 95 1170 Nominal CCT1 (K) BXRE-27S4001-C-7x BXRE-30S4001-C-7x Part Number1,6 2 BXRE-35S4001-C-7x 3500 95 1170 34.4 4890 4303 40.2 121 80.93 2.17 BXRE-40S4001-C-7x 4000 95 1170 34.4 4969 4372 40.2 123 80.88 2.15 BXRE-50S4001-C-7x 5000 95 1170 34.4 5232 4604 40.2 130 85.76 2.26 BXRE-57S4001-C-7x 5700 95 1170 34.4 5312 4675 40.2 132 87.34 2.29 BXRE-65S4001-C-7x 6500 95 1170 34.4 5205 4581 40.2 129 85.58 2.23 Minimum DC Flux6,7,8,9 Tc = 85ºC (lm) Typical Power (W) Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) Table 2: Selection Guide, Stabilized DC Test Performance (Tc= 85°C)4,5,6 CRI Nominal Drive Current3 (mA) Typical Vf (V) Typical DC Flux4,5,6,7 Tc = 85ºC (lm) 2700 95 1170 33.7 3956 3481 39.4 100 69.03 1.92 3000 95 1170 33.7 4249 3739 39.4 108 72.59 2.00 Nominal CCT1 (K) BXRE-27S4001-C-7x BXRE-30S4001-C-7x Part Number 1,6 2 BXRE-35S4001-C-7x 3500 95 1170 33.7 4450 3916 39.4 113 73.64 2.02 BXRE-40S4001-C-7x 4000 95 1170 33.7 4521 3979 39.4 115 73.58 2.00 BXRE-50S4001-C-7x 5000 95 1170 33.7 4761 4190 39.4 121 78.04 2.10 BXRE-57S4001-C-7x 5700 95 1170 33.7 4834 4254 39.4 123 79.48 2.12 BXRE-65S4001-C-7x 6500 95 1170 33.7 4737 4168 39.4 120 77.88 2.07 Notes for Table 1 & 2: 1. Product CCT is hot targeted at Tj= 85°C. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are minimums. Bridgelux maintains a ± 3 tolerance on CRI values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents V Series Thrive LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series Thrive LED Arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 10 and the flux vs. current characteristics shown in Figure 11. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRE-27S4001-C-73 BXRE-30S4001-C-73 BXRE-35S4001-C-73 BXRE-40S4001-C-73 BXRE-50S4001-C-73 BXRE-57S4001-C-73 BXRE-65S4001-C-73 CRI 95 95 95 95 95 95 95 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 120 585 32.2 18.8 2259 2082 780 33.6 26.2 2972 2731 113 1170 34.4 40.2 4347 3956 108 101 1755 35.2 61.8 6269 5627 2340 35.7 83.5 8101 6142 97 585 32.2 18.8 2426 2237 129 780 33.6 26.2 3192 2934 122 1170 34.4 40.2 4669 4249 116 1755 35.2 61.8 6734 6044 109 2340 35.7 83.5 8701 6597 104 585 32.2 18.8 2541 2343 135 780 33.6 26.2 3343 3073 128 1170 34.4 40.2 4890 4450 121 1755 35.2 61.8 7053 6330 114 2340 35.7 83.5 9113 6909 109 585 32.2 18.8 2582 2380 137 780 33.6 26.2 3397 3122 130 1170 34.4 40.2 4969 4521 123 1755 35.2 61.8 7166 6432 116 2340 35.7 83.5 9259 7020 111 585 32.2 18.8 2719 2506 144 780 33.6 26.2 3577 3288 136 1170 34.4 40.2 5232 4761 130 122 1755 35.2 61.8 7546 6773 2340 35.7 83.5 9750 7392 117 585 32.2 18.8 2761 2545 147 780 33.6 26.2 3632 3338 139 1170 34.4 40.2 5312 4834 132 124 1755 35.2 61.8 7661 6876 2340 35.7 83.5 9899 7505 118 585 32.2 18.8 2705 2494 144 780 33.6 26.2 3559 3271 136 1170 34.4 40.2 5205 4737 129 1755 35.2 61.8 7507 6738 122 2340 35.7 83.5 9701 7354 116 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Spectrum Characteristics Table 4: Typical Color Rendering Index and TM-30 Values at, Tc=85°C Nominal CCT1 Rf Rg R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 2700K 95 103 97 99 94 94 97 98 97 98 99 97 91 98 98 95 98 3000K 95 104 98 99 93 94 97 98 96 96 97 96 92 95 98 95 97 3500K 95 98 98 98 97 98 98 98 98 97 93 97 97 95 98 97 98 4000K 97 100 99 99 97 99 99 99 99 98 94 97 99 96 99 98 98 5000K 97 100 98 99 98 98 98 98 99 98 95 98 98 98 98 98 97 5700K 94 98 98 98 97 95 98 97 96 95 92 97 96 96 98 98 97 6500K 95 98 98 98 97 96 98 98 96 96 93 97 96 97 98 98 97 Note for Table 4: 1. Bridgelux maintains a tolerance of ± 3 on Color Rendering Index R1-R15 measurements and TM-30 measurements. Figure 1: 2700K Thrive TM-30 Graphs Figure 2: 3000K Thrive TM-30 Graphs Figure 3: 3500K Thrive TM-30 Graphs 5 Spectrum Characteristics Figure 4: 4000K Thrive TM-30 Graphs Figure 5: 5000K Thrive TM-30 Graphs Figure 6: 5700K Thrive TM30 Graphs Figure 7: 6500K Thrive TM-30 Graphs 6 Spectrum Characteristics Figure 8: Typical Color Spectrum 100% 100% 2700K 5000K 5700K 6500K 80% Relative Radiant Power(%) Relative Radiant Power(%) 3000K 3500K 4000K 60% 40% 20% 0% 350 400 450 500 550 600 650 700 750 800 Wavelength(nm) 80% 60% 40% 20% 0% 350 400 450 500 550 600 650 700 750 800 Wavelength(nm) Note for Figure 8: 1. Color spectra measured at nominal current for Tj = 85°C. Spectral Matching to Natural Light The lighting market is in the early stages of adoption of human-centric lighting (HCL). HCL encompasses the effects of lighting on the physical and emotional health and well-being of people. Throughout evolution, the human visual system has evolved under the natural light of sun and fire. These light sources have standardized industry spectral power definitions that describe the state of natural light. However, conventional metrics such as CCT, CRI, and TM-30 fail to adequately quantify the naturalness, or closeness of these light sources to the standardized natural spectra. Due to a lack of an industry standard metric to quantitatively measure the naturalness of a light source, Bridgelux has pioneered a new metric that takes the guesswork out of comparing LED light sources to natural light. Average Spectral Difference, or ASD, is calculated by measuring the absolute difference between two spectra at discrete wavelengths. These values are averaged across a wavelength range derived from the photopic response curve, or V(λ); a luminous efficiency function describing the average spectral sensitivity of human perception of brightness. The range of 425nm to 690nm was selected to remove the tails of the V(λ) gaussian distribution below 1% of the peak value at 555nm, covering 99.9% of the area under the photopic response curve. Natural light is defined following the approach of IES TM-30; black body curves for light sources of ≤4000K and the CIE standard illuminant D for light sources of ≥ 5000K. Natural light has an ASD of 0%; lower ASD values indicate a closer match to natural light. Thrive is engineered to provide the closest match to natural light available using proprietary chip, phosphor and packaging technology, resulting in an ASD between 8% to 10% for all CCTs. By comparison, standard 80, 90, and 98 CRI light sources have ASD values that are 100% to 300% larger than Thrive. To learn more about the ASD metric, please contact your Bridgelux sales representative. Bridgelux will publish a white paper to further educate the market about the benefits of the ASD metric in Q2 2020. 7 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRE-xxx4001-C-7x Drive Current (mA) Maximum Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Minimum Typical 1170 32.2 34.4 37.4 -14.5 2340 34.6 37.5 40.3 -14.5 Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.11 31.1 38.4 0.13 33.5 41.2 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 8 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds Maximum Drive Current3 2340mA Maximum Peak Pulsed Drive Current4 3340mA Maximum Reverse Voltage5 -60V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 9 Eye Safety Table 7: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx4001-C-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG1 RG2 RG2 Notes for Table 7: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 10 Product Bin Definitions Table 8: 2-, 3- and 4-step MacAdam Ellipse Color Bin Definitions Center Point Degree 2-step 3-step 4-step CCT x y Φ(°) a b a b a b 2700K 0.4578 0.4101 53.700 0.00540 0.00280 0.0081 0.0042 N/A N/A 3000K 0.4338 0.403 53.217 0.00556 0.00272 0.0083 0.0041 N/A N/A 4000K 0.3818 0.3797 53.717 0.00626 0.00268 0.0094 0.0040 N/A N/A 5000K 0.3447 0.3553 59.617 N/A N/A 0.0082 0.0035 0.0110 0.0047 5700K 0.3287 0.3417 59.060 N/A N/A 0.0074 0.0032 0.0099 0.0042 6500K 0.3123 0.3282 58.567 N/A N/A 0.0066 0.0028 0.0090 0.0038 Notes for Table 8: 1. Color binning at Tc=85°C 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Figure 9: C.I.E. 1931 Chromaticity Diagram (Color targeted at Tc=85°C) 0.44 0.39 3 SDCM 4 SDCM 2 SDCM 0.38 2700K 3 SDCM 0.42 3000K 0.37 3500K 5000K 0.36 0.4 5700K 0.35 Y Y 4000K 0.38 6500K 0.34 0.33 0.36 0.32 0.34 0.36 0.31 0.39 0.42 0.45 X 0.48 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 0.37 X 11 Performance Curves Figure 11: V18C Typical Relative Flux vs. Current (Tc=25°C) Figure 10: V18C Drive Current vs. Voltage (Tc=25°C) 250% 3000 Relative Luminus Flux Forward Current (mA) 3500 2500 2000 1500 1000 200% 150% 100% 50% 500 0 32.0 0% 33.0 34.0 35.0 36.0 37.0 38.0 0 39.0 500 1500 2000 2500 3000 3500 Forward Current (mA) Forward Voltage (V) Figure 12: Typical DC Flux vs. Case Temperature 1000 Figure 13: Typical ccx Shift vs. Case Temperature 105% 0.0030 100% 0.0020 95% 0.0010 Neutral White Cool White ccx Shift Relative Luminus Flux Warm White 90% Warm White Neutral White Cool White 85% 80% 0 25 0.0000 -0.0010 -0.0020 50 75 100 0 Case Temperature (°C) 25 50 75 Case Temperature (°C) 100 Figure 14: Typical ccy Shift vs. Case Temperature 0.000 Notes for Figures 12-14: -0.001 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. ccy Shift 2. Characteristics shown for warm white based on 3000K Thrive -0.002 3. Characteristics shown for neutral white based on 4000K Thrive 4. Characteristics shown for cool white based on 5700K Thrive -0.003 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Warm White -0.004 Neutral White Cool White -0.005 0 25 50 75 100 125 Case Temperature (°C) 12 Typical Radiation Pattern Figure 15: Typical Spatial Radiation Pattern Notes for Figure 15: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 16: Typical Polar Radiation Pattern 13 Mechanical Dimensions Figure 17: V18C LED Array Notes for Figure 17: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting locations (2X) are for M2.5 screws. 5. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 14 Packaging and Labeling Figure 18: V18C Packaging Notes for Figure 18: 1. Each tube holds 20 V18 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 8.3 (W) x 15.4 (H) x 430 (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 15 Packaging and Labeling Figure 19: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30S4001C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 16 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 17 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/bridgelux-inc-_2 youtube.com/user/Bridgelux WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2019 Bridgelux, Inc. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. Thrive is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 V18 Thrive Array Product Data Sheet DS322 Rev. A (12/2019) 18
BXRE-35S4001-C-73 价格&库存
很抱歉,暂时无法提供与“BXRE-35S4001-C-73”相匹配的价格&库存,您可以联系我们找货
BXRE-35S4001-C-73
  • 600+103.39290600+13.39122
