BXRE-40G4000-C-82
BXRE-40G4000-C-82
    BRIDGELUX(普瑞)
BXRE-40G4000-C-82 数据手册
Bridgelux Gen 8 V18 Array Series ® Product Data Sheet DS415 1 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These chip on board (CoB) arrays can be efficiently driven up to three times the nominal drive current, enabling design flexibility not previously possible. These high flux density light sources are designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for both interior and exterior commercial and residential applications. The V18 LED Array is available in a variety of electrical, CCT, and CRI combinations providing substantial design flexibility and energy efficiency advantages. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and a longer service life. Typical applications include replacement lamps and task, accent, spot, track, wide area, security, wall packs and down lights. Features • Efficacy of 180 lm/W typical, 3000K 80 CRI • Reliable operation at up to 3x nominal current, 30% increase in maximum lumens per LES size • Wide selection of CCT options (2700K-6500K) with minimum 70, 80 and 90 CRI options • Uniform high-quality illumination • 2 and 3 SDCM binning options (2700K – 4000K) • Forward voltage bin codes and backside marking • Instant light with unlimited dimming • 5-Year warranty Benefits • Enables high efficiency lighting systems and lower operating costs • Supports the trend toward luminaire miniaturization and delivers enhanced optical control • Design flexibility for a broad range of lighting applications • Clean white light without pixelation • Uniform consistent white light • Design flexibility for multi-source applications • Easy to use with daylight and motion sensors to increase energy savings • Design with confidence Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 7 Electrical Characteristics 13 Eye Safety 14 Absolute Maximum Ratings 15 Performance Curves 16 Typical Radiation Pattern 18 Typical Color Spectrum 19 Mechanical Dimensions 20 Color Binning Information 21 Packaging and Labeling 22 Design Resources 24 Precautions 24 Disclaimers 24 About Bridgelux 25 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Designed to comply with global safety standards for creepage and clearance distances Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 400 0 – C – 8 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen. 8 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 400x = 4000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) CRI Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 2700 80 700 4028 3625 33.9 23.7 170 Part Number Nominal CCT1 (K) BXRE-27E4000-B-8x 2 BXRE-27E4000-C-8x 2700 80 1050 6024 5421 33.9 35.6 169 BXRE-27G4000-B-8x 2700 90 700 3323 2991 33.9 23.7 140 BXRE-27G4000-C-8x 2700 90 1050 4969 4472 33.9 35.6 140 BXRE-27G40H0-B-8x 2700 90 700 3467 3120 33.9 23.7 146 BXRE-27G40H0-C-8x 2700 90 1050 5184 4666 33.9 35.6 146 BXRE-30C4001-B-8x 3000 70 700 4481 4033 33.9 23.7 189 BXRE-30C4001-C-8x 3000 70 1050 6701 6031 33.9 35.6 188 BXRE-30E4000-B-8x 3000 80 700 4280 3852 33.9 23.7 180 BXRE-30E4000-C-8x 3000 80 1050 6400 5760 33.9 35.6 180 BXRE-30G4000-B-8x 3000 90 700 3474 3127 33.9 23.7 146 BXRE-30G4000-C-8x 3000 90 1050 5195 4676 33.9 35.6 146 BXRE-30G40H0-B-8x 3000 90 700 3638 3274 33.9 23.7 153 BXRE-30G40H0-C-8x 3000 90 1050 5440 4896 33.9 35.6 153 BXRE-35E4000-B-8x 3500 80 700 4381 3943 33.9 23.7 185 BXRE-35E4000-C-8x 3500 80 1050 6551 5896 33.9 35.6 184 152 BXRE-35G4000-B-8x 3500 90 700 3600 3240 33.9 23.7 BXRE-35G4000-C-8x 3500 90 1050 5384 4845 33.9 35.6 151 BXRE-40C4001-B-8x 4000 70 700 4607 4147 33.9 23.7 194 BXRE-40C4001-C-8x 4000 70 1050 6889 6200 33.9 35.6 194 BXRE-40E4000-B-8x 4000 80 700 4406 3965 33.9 23.7 186 BXRE-40E4000-C-8x 4000 80 1050 6588 5929 33.9 35.6 185 BXRE-40G4000-B-8x 4000 90 700 3676 3308 33.9 23.7 155 BXRE-40G4000-C-8x 4000 90 1050 5496 4947 33.9 35.6 154 195 BXRE-50C4001-B-8x 5000 70 700 4632 4169 33.9 23.7 BXRE-50C4001-C-8x 5000 70 1050 6927 6234 33.9 35.6 195 BXRE-50E4001-B-8x 5000 80 700 4456 4011 33.9 23.7 188 BXRE-50E4001-C-8x 5000 80 1050 6664 5997 33.9 35.6 187 BXRE-50G4001-B-8x 5000 90 700 3852 3467 33.9 23.7 162 BXRE-50G4001-C-8x 5000 90 1050 5760 5184 33.9 35.6 162 BXRE-57C4001-B-8x 5700 70 700 4507 4056 33.9 23.7 190 BXRE-57C4001-C-8x 5700 70 1050 6739 6065 33.9 35.6 189 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-57E4001-B-8x 5700 80 700 4280 3852 33.9 23.7 180 BXRE-57E4001-C-8x 5700 80 1050 6400 5760 33.9 35.6 180 BXRE-65C4001-B-8x 6500 70 700 4507 4056 33.9 23.7 190 BXRE-65C4001-C-8x 6500 70 1050 6739 6065 33.9 35.6 189 BXRE-65E4001-B-8x 6500 80 700 4330 3897 33.9 23.7 182 BXRE-65E4001-C-8x 6500 80 1050 6475 5828 33.9 35.6 182 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-27E4000-B-8x 2700 80 700 3625 3263 33.1 23.2 156 BXRE-27E4000-C-8x 2700 80 1050 5421 4879 33.1 34.8 156 BXRE-27G4000-B-8x 2700 90 700 2991 2692 33.1 23.2 129 BXRE-27G4000-C-8x 2700 90 1050 4472 4025 33.1 34.8 129 BXRE-27G40H0-B-8x 2700 90 700 3120 2808 33.1 23.2 135 BXRE-27G40H0-C-8x 2700 90 1050 4666 4199 33.1 34.8 134 BXRE-30C4001-B-8x 3000 70 700 4033 3630 33.1 23.2 174 BXRE-30C4001-C-8x 3000 70 1050 6031 5428 33.1 34.8 173 BXRE-30E4000-B-8x 3000 80 700 3852 3467 33.1 23.2 166 BXRE-30E4000-C-8x 3000 80 1050 5760 5184 33.1 34.8 166 BXRE-30G4000-B-8x 3000 90 700 3127 2814 33.1 23.2 135 BXRE-30G4000-C-8x 3000 90 1050 4676 4208 33.1 34.8 134 141 BXRE-30G40H0-B-8x 3000 90 700 3274 2947 33.1 23.2 BXRE-30G40H0-C-8x 3000 90 1050 4896 4406 33.1 34.8 141 BXRE-35E4000-B-8x 3500 80 700 3943 3548 33.1 23.2 170 BXRE-35E4000-C-8x 3500 80 1050 5896 5306 33.1 34.8 170 BXRE-35G4000-B-8x 3500 90 700 3240 2916 33.1 23.2 140 BXRE-35G4000-C-8x 3500 90 1050 4845 4361 33.1 34.8 139 BXRE-40C4001-B-8x 4000 70 700 4147 3732 33.1 23.2 179 BXRE-40C4001-C-8x 4000 70 1050 6200 5580 33.1 34.8 178 171 BXRE-40E4000-B-8x 4000 80 700 3965 3569 33.1 23.2 BXRE-40E4000-C-8x 4000 80 1050 5929 5336 33.1 34.8 171 BXRE-40G4000-B-8x 4000 90 700 3308 2977 33.1 23.2 143 BXRE-40G4000-C-8x 4000 90 1050 4947 4452 33.1 34.8 142 BXRE-50C4001-B-8x 5000 70 700 4169 3752 33.1 23.2 180 BXRE-50C4001-C-8x 5000 70 1050 6234 5611 33.1 34.8 179 BXRE-50E4001-B-8x 5000 80 700 4011 3610 33.1 23.2 173 BXRE-50E4001-C-8x 5000 80 1050 5997 5397 33.1 34.8 172 BXRE-50G4001-B-8x 5000 90 700 3467 3120 33.1 23.2 150 BXRE-50G4001-C-8x 5000 90 1050 5184 4666 33.1 34.8 149 BXRE-57C4001-B-8x 5700 70 700 4056 3650 33.1 23.2 175 BXRE-57C4001-C-8x 5700 70 1050 6065 5458 33.1 34.8 174 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-57E4001-B-8x 5700 80 700 3852 3467 33.1 23.2 166 BXRE-57E4001-C-8x 5700 80 1050 5760 5184 33.1 34.8 166 BXRE-65C4001-B-8x 6500 70 700 4056 3650 33.1 23.2 175 BXRE-65C4001-C-8x 6500 70 1050 6065 5458 33.1 34.8 174 BXRE-65E4001-B-8x 6500 80 700 3897 3508 33.1 23.2 168 BXRE-65E4001-C-8x 6500 80 1050 5828 5245 33.1 34.8 168 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRE-27E4000-B-8x 80 BXRE-27E4000-C-8x 80 BXRE-27G4000-B-8x 90 BXRE-27G4000-C-8x 90 BXRE-27G40H0-B-8x 90 BXRE-27G40H0-C-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 2115 3065 4028 5053 7600 10500 3162 4570 6024 6616 11365 15700 1745 2529 3323 4169 6270 8662 2609 3770 4969 5458 9376 12953 1820 2638 3467 4349 6541 9036 2721 3933 5184 5694 9781 13512 1903 2759 3625 4548 6840 9450 2846 4113 5421 5954 10228 14130 1570 2276 2991 3752 5643 7796 2348 3393 4472 4912 8438 11658 1638 2374 3120 3914 5887 8133 2449 3540 4666 5125 8803 12161 185 175 170 163 151 140 184 175 169 166 150 139 153 145 140 134 125 115 152 144 140 137 124 115 159 151 146 140 130 120 159 151 146 143 129 120 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30C4001-B-8x 70 BXRE-30C4001-C-8x 70 BXRE-30E4000-B-8x 80 BXRE-30E4000-C-8x 80 BXRE-30G4000-B-8x 90 BXRE-30G4000-C-8x 90 BXRE-30G40H0-B-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 2353 3410 4481 5622 8455 11681 3518 5084 6701 7360 12643 17467 2247 3257 4280 5369 8075 11156 3360 4856 6400 7030 12075 16682 1824 2644 3474 4359 6555 9056 2727 3942 5195 5706 9802 13542 1910 2768 3638 4564 6864 9482 2117 3069 4033 5060 7610 10513 3166 4576 6031 6624 11379 15720 2022 2931 3852 4832 7268 10040 3024 4370 5760 6327 10868 15013 1641 2379 3127 3923 5900 8150 2455 3548 4676 5136 8822 12187 1719 2492 3274 4108 6178 8534 206 195 189 181 168 156 205 195 188 184 167 155 196 186 181 173 160 149 196 186 180 176 160 148 159 151 147 140 130 121 159 151 146 143 130 120 167 158 153 147 136 126 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30G40H0-C-8x 90 BXRE-35E4000-B-8x 80 BXRE-35E4000-C-8x 80 BXRE-35G4000-B-8x 90 BXRE-35G4000-C-8x 90 BXRE-40C4001-B-8x 70 BXRE-40C4001-C-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 2856 4127 5440 5975 10264 14179 2300 3334 4381 5496 8265 11418 3439 4970 6551 7195 12359 17074 1890 2740 3600 4517 6793 9384 2826 4085 5384 5913 10157 14032 2419 3506 4607 5780 8693 12009 3617 5227 6889 7567 12999 17957 2570 3715 4896 5378 9238 12761 2070 3000 3943 4946 7439 10276 3095 4473 5896 6476 11123 15367 1701 2466 3240 4065 6113 8446 2544 3676 4845 5322 9142 12629 2177 3155 4147 5202 7824 10808 3255 4704 6200 6810 11699 16162 166 158 153 150 136 126 201 191 185 177 164 152 200 190 184 180 164 152 165 157 152 145 135 125 165 156 151 148 134 125 211 201 194 186 173 160 211 200 194 190 172 159 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-40E4000-B-8x 80 BXRE-40E4000-C-8x 80 BXRE-40G4000-B-8x 90 BXRE-40G4000-C-8x 90 BXRE-50C4001-B-8x 70 BXRE-50C4001-C-8x 70 BXRE-50E4001-B-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 2313 3353 4406 5527 8313 11484 3459 4999 6588 7236 12430 17172 1930 2797 3676 4611 6935 9581 2885 4170 5496 6037 10370 14327 2432 3525 4632 5811 8740 12075 3636 5256 6927 7609 13070 18055 2339 3391 4456 5590 8408 11615 2082 3017 3965 4974 7482 10336 3113 4499 5929 6513 11187 15455 1737 2517 3308 4150 6242 8623 2597 3753 4947 5433 9333 12894 2189 3173 4169 5230 7866 10867 3273 4730 6234 6848 11763 16250 2105 3052 4011 5031 7567 10454 202 192 186 178 165 153 202 191 185 181 165 152 169 160 155 149 138 128 168 160 155 151 137 127 213 202 195 187 174 161 212 201 195 191 173 160 205 194 188 180 167 155 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-50E4001-C-8x 80 BXRE-50G4001-B-8x 90 BXRE-50G4001-C-8x 90 BXRE-57C4001-B-8x 70 BXRE-57C4001-C-8x 70 BXRE-57E4001-B-8x 80 BXRE-57E4001-C-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 3498 5056 6664 7319 12572 17369 2022 2931 3852 4832 7268 10040 3024 4370 5760 6327 10868 15013 2366 3429 4507 5654 8503 11746 3538 5113 6739 7402 12714 17565 2247 3257 4280 5369 8075 11156 3360 4856 6400 7030 12075 16682 3148 4550 5997 6587 11315 15632 1820 2638 3467 4349 6541 9036 2721 3933 5184 5694 9781 13512 2129 3086 4056 5088 7653 10572 3184 4602 6065 6662 11443 15808 2022 2931 3852 4832 7268 10040 3024 4370 5760 6327 10868 15013 204 194 187 183 166 154 177 168 163 156 144 134 176 167 162 159 144 133 207 196 190 182 169 156 206 196 190 185 168 156 196 186 181 173 160 149 196 186 180 176 160 148 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-65C4001-B-8x 70 BXRE-65C4001-C-8x 70 BXRE-65E4001-B-8x 80 BXRE-65E4001-C-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 2366 3429 4507 5654 8503 11746 3538 5113 6739 7402 12714 17565 2273 3295 4330 5432 8170 11287 3399 4913 6475 7112 12217 16878 2129 3086 4056 5088 7653 10572 3184 4602 6065 6662 11443 15808 2046 2966 3897 4889 7353 10158 3059 4422 5828 6401 10996 15190 207 196 190 182 169 156 206 196 190 185 168 156 199 189 183 175 162 150 198 188 182 178 162 150 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRE-xxx400x-B-8x BXRE-xxx400x-C-8x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.14 30.5 37.2 -12.10 0.23 33.7 41.1 36.4 -10.93 0.12 30.5 37.2 40.3 -12.10 0.20 33.7 41.1 Minimum Typical Maximum 700 31.4 33.9 36.4 -10.93 2000 34.7 37.5 40.3 1050 31.4 33.9 3000 34.7 37.5 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1140 V. The working voltage designated for the insulation is 70V d.c. The maximum allowable voltage across the array must be determined in the end product application. 13 Eye Safety Table 5: Eye Safety Risk Group (RG) Classifications Part Number CCT Drive Current (mA) 2700K/3000K 4000K2 5000K3 6500K4 1440 RG1 RG1 RG1 RG1 2000 RG1 RG1 RG1 RG2 1440 RG1 RG1 RG1 RG1 1995 RG1 RG1 RG1 RG2 2650 RG1 RG1 RG2 RG2 3000 RG1 RG2 RG2 RG2 BXRE-xxx400x-B-8x BXRE-xxx400x-C-8x Notes for Table 5: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1980 lx. 3. For products classified as RG2 at 5000K Ethr= 1530 lx. 4. For products classified as RG2 at 6500K, Ethr= 1170 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 14 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx400x-B-8x BXRE-xxx400x-C-8x Maximum Drive Current3 2000 mA 3000 mA Maximum Peak Pulsed Drive Current4 2240 mA 3360 mA Maximum Reverse Voltage5 -60V -60V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 15 Performance Curves Figure 1: V18B Drive Current vs. Voltage Figure 2: V18C Drive Current vs. Voltage 38.0 38.0 37.0 36.0 Voltage (V) Voltage (V) 37.0 35.0 34.0 36.0 35.0 34.0 33.0 33.0 32.0 32.0 0 250 500 750 1000 1250 1500 1750 2000 0 2250 500 1500 2000 2500 3000 3500 Figure 4: V18C Typical Relative Flux vs. Current Figure 3: V18B Typical Relative Flux vs. Current 300% 300% Relative Luminous Flux (%) Relative Luminous Flux (%) 1000 Drive Current (mA) Drive Current (mA) 250% 200% 150% 100% 50% 0% 0 250 500 750 1000 1250 1500 Drive Current (mA) 1750 2000 2250 250% 200% 150% 100% 50% 0% 0 500 1000 1500 2000 2500 3000 3500 Drive Current (mA) Notes for Figures 1-4: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 16 Performance Curves Figure 6: Typical DC ccy Shift vs. Case Temperature 102% 0.0010 100% 0.0000 -0.0010 98% -0.0020 96% ccy shift Relative Luminous Flux Figure 5: Typical DC Flux vs. Case Temperature 94% 92% -0.0030 -0.0040 -0.0050 90% -0.0060 88% -0.0070 0 20 40 60 80 100 120 0 20 40 Case Temperature (Tc) 80 100 120 Figure 8: Derating Curve Figure 7: Typical DC ccx Shift vs. Case Temperature 0.0020 3500 25C Pulsed 3000 Drive Current (mA) 0.0000 60 Case Temperature (Tc) ccx shift -0.0020 -0.0040 -0.0060 -0.0080 2500 2000 1500 1000 BXRE-xxx400x-C-8x 500 0 0 -0.0100 0 20 40 60 80 100 120 20 40 60 80 Case Temperature (Tc) 100 120 Case Temperature (Tc) Notes for Figures 5-7: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 17 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern Note for Figure 9: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 10: Typical Polar Radiation Pattern 18 Typical Color Spectrum Figure 11: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 11: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. 19 Mechanical Dimensions Figure 12: Drawing for V18 LED Array Notes for Figure 12; 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 20 Color Binning Information Figure 13: Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) ANSI Bin (for reference only) Figure 14: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Table 8: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 84 (4 SDCM) (4801K - 5282K) (5829K - 5481K) (6270K - 6765K) 83 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 21 Packaging and Labeling Figure 15: Drawing for V18 Packaging Tube 8 Notes for Figure 15 1. Each tube holds 20 V18 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 26.3 (W) x 9.5(H) x 510 (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 22 Packaging and Labeling Figure 16: Gen. 8 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 83 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. Internal Bin Code 23 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 24 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2020 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, V Series and Decor Series are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 V18 Array Series Product Data Sheet DS415 Rev. A (06/2020) 25
BXRE-40G4000-C-82 价格&库存
很抱歉,暂时无法提供与“BXRE-40G4000-C-82”相匹配的价格&库存,您可以联系我们找货
