BXRE-40S1001-B-72
BXRE-40S1001-B-72
    BRIDGELUX(普瑞)
BXRE-40S1001-B-72 数据手册
® Bridgelux Gen 7 V10 Thrive™ Array Product Data Sheet DS320 1 | | | | | | BXRE-27S 30S 35S 40S 50S 57S 65S V10 Thrive Introduction Bridgelux Thrive™ combines unique chip, phosphor and packaging technology to closely match the spectra of natural light over the visible wavelength range. Thrive can be used in constant color point luminaires to bring full spectrum natural light indoors or in tunable white luminaires to incorporate circadian elements that may impact human well-being. The high fidelity spectral output of Thrive creates stunning environments with excellent color rendering and outstanding TM30 metrics. Thrive is available in both SMD components and LED arrays to enable a broad range of lighting applications including retail, hospitality, office, education, architectural, museums, healthcare and residential lighting. Features Benefits • Engineered spectrum to closely match natural light • Full consistent spectrum with fewer spectral spikes • CRI >95, R1-R15 >90, high Rf and Rg values • Natural and vivid color rendering • High efficacy full spectrum solution • Greater energy savings, lower utility costs • No violet chip augmentation • Economical, high efficiency solution • Hot color targeted • Uniform and consistent white light at application conditions • Form factor consistent with existing Bridgelux COB arrays • Broad product platform availability (SMDs and COBs) • Ease of design and rapid go-to-market • Enables greater design flexibility and platform color consistency Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Spectrum Characteristics 6 Electrical Characteristics 9 Absolute Maximum Ratings 10 Eye Safety 11 Product Bin Definitions 12 Performance Curves 13 Typical Radiation Pattern 15 Mechanical Dimensions 16 Packaging and Labeling 17 Design Resources 19 Precautions 19 Disclaimers 19 About Bridgelux 20 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols White ring around LES Fully engineered substrate for consistent thermal, mechanical and optical properties Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux COB arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 S 1000 – C – 7 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen 7 Array Configuration 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Flux Indicator 1001 = 1000 lm Minimum CRI S = Thrive 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tc= 25°C) Part Number1,6 Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Vf (V) Typical Pulsed Flux4,5,6,7 Tc = 25ºC (lm) Minimum Pulsed Flux6,7,8 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) BXRE-27S1001-B-7x 2700 95 270 34.4 1003 883 9.3 108 17.50 1.90 BXRE-27S1001-C-7x 2700 95 360 34.4 1337 1177 12.4 108 23.33 1.90 BXRE-30S1001-B-7x 3000 95 270 34.4 1077 948 9.3 116 18.40 1.99 BXRE-30S1001-C-7x 3000 95 360 34.4 1437 1264 12.4 116 24.55 1.99 BXRE-35S1001-B-7x 3500 95 270 34.4 1124 989 9.3 121 18.60 1.99 BXRE-35S1001-C-7x 3500 95 360 34.4 1498 1319 12.4 121 24.79 1.99 BXRE-40S1001-B-7x 4000 95 270 34.4 1142 1005 9.3 123 18.59 1.97 BXRE-40S1001-C-7x 4000 95 360 34.4 1523 1340 12.4 123 24.79 1.97 BXRE-50S1001-B-74 5000 95 270 34.4 1198 1054 9.3 129 19.64 2.06 BXRE-50S1001-C-74 5000 95 360 34.4 1598 1406 12.4 129 26.19 2.06 2.10 BXRE-57S1001-B-74 5700 95 270 34.4 1226 1079 9.3 132 20.16 BXRE-57S1001-C-74 5700 95 360 34.4 1635 1439 12.4 132 26.88 2.10 BXRE-65S1001-B-74 6500 95 270 34.4 1207 1063 9.3 130 19.85 2.07 BXRE-65S1001-C-74 6500 95 360 34.4 1610 1417 12.4 130 26.47 2.07 Minimum DC Flux6,7,8,9 Tc = 85ºC (lm) Typical Power (W) Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) Table 2: Selection Guide, Stabilized DC Test Performance (Tc= 85°C)4,5,6 Part Number1,6 Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Vf (V) Typical DC Flux4,5,6,7 Tc = 85ºC (lm) BXRE-27S1001-B-7x 2700 95 270 33.7 903 794 9.1 99 15.76 1.90 BXRE-27S1001-C-7x 2700 95 360 33.7 1204 1059 12.1 99 21.01 1.90 BXRE-30S1001-B-7x 3000 95 270 33.7 970 853 9.1 107 16.57 1.99 BXRE-30S1001-C-7x 3000 95 360 33.7 1293 1138 12.1 107 22.09 1.99 BXRE-35S1001-B-7x 3500 95 270 33.7 1011 890 9.1 111 16.73 1.99 BXRE-35S1001-C-7x 3500 95 360 33.7 1349 1187 12.1 111 22.33 1.99 BXRE-40S1001-B-7x 4000 95 270 33.7 1028 905 9.1 113 16.73 1.97 BXRE-40S1001-C-7x 4000 95 360 33.7 1371 1206 12.1 113 22.31 1.97 BXRE-50S1001-B-74 5000 95 270 33.7 1078 949 9.1 119 17.67 2.06 BXRE-50S1001-C-74 5000 95 360 33.7 1438 1265 12.1 119 23.57 2.06 BXRE-57S1001-B-74 5700 95 270 33.7 1103 971 9.1 121 18.14 2.10 BXRE-57S1001-C-74 5700 95 360 33.7 1471 1295 12.1 121 24.19 2.10 BXRE-65S1001-B-74 6500 95 270 33.7 1087 956 9.1 119 17.87 2.07 BXRE-65S1001-C-74 6500 95 360 33.7 1449 1275 12.1 119 23.82 2.07 Notes for Table 1 & 2: 1. Product CCT is hot targeted at Tj= 85°C. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are minimums. Bridgelux maintains a ± 3 tolerance on CRI values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents V Series Thrive LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series Thrive LED Arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 10 & 11 and the flux vs. current characteristics shown in Figures 12 & 13. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRE-27S1001-B-7x BXRE-27S1001-C-7x BXRE-30S1001-B-7x BXRE-30S1001-C-7x BXRE-35S1001-B-7x BXRE-35S1001-C-7x BXRE-40S1001-B-7x BXRE-40S1001-C-7x CRI 95 95 95 95 95 95 95 95 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 32.8 4.4 535 480 121 180 33.6 6.1 701 629 116 270 34.4 9.3 1003 903 108 405 35.2 14.3 1472 1309 103 540 35.7 19.3 1885 1669 98 180 32.8 5.9 711 635 120 240 33.6 8.1 932 828 115 360 34.4 12.4 1337 1204 108 540 35.2 19.0 1948 1692 102 720 35.7 25.7 2488 2130 97 135 32.8 4.4 574 516 130 180 33.6 6.1 753 675 124 270 34.4 9.3 1077 970 116 405 35.2 14.3 1581 1406 111 540 35.7 19.3 2025 1792 105 129 180 32.8 5.9 764 682 240 33.6 8.1 1001 889 124 360 34.4 12.4 1437 1293 116 540 35.2 19.0 2092 1817 110 720 35.7 25.7 2672 2287 104 135 32.8 4.4 599 538 135 180 33.6 6.1 785 704 130 270 34.4 9.3 1124 1011 121 405 35.2 14.3 1649 1467 116 540 35.7 19.3 2112 1870 109 180 32.8 5.9 797 711 135 240 33.6 8.1 1044 927 129 360 34.4 12.4 1498 1349 121 540 35.2 19.0 2182 1896 115 720 35.7 25.7 2787 2386 108 137 135 32.8 4.4 609 547 180 33.6 6.1 798 716 132 270 34.4 9.3 1142 1028 123 405 35.2 14.3 1676 1491 117 540 35.7 19.3 2147 1900 111 180 32.8 5.9 810 723 137 240 33.6 8.1 1061 943 132 360 34.4 12.4 1523 1371 123 540 35.2 19.0 2218 1927 117 720 35.7 25.7 2833 2425 110 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRE-50S1001-B-74 BXRE-50S1001-C-74 BXRE-57S1001-B-74 BXRE-57S1001-C-74 BXRE-65S1001-B-74 BXRE-65S1001-C-74 CRI 95 95 95 95 95 95 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 32.8 4.4 638 574 144 180 33.6 6.1 837 751 138 270 34.4 9.3 1198 1078 129 405 35.2 14.3 1758 1564 123 540 35.7 19.3 2252 1993 117 180 32.8 5.9 849 758 144 240 33.6 8.1 1113 989 138 360 34.4 12.4 1598 1438 129 540 35.2 19.0 2326 2021 122 720 35.7 25.7 2972 2544 116 135 32.8 4.4 653 587 147 180 33.6 6.1 857 768 142 270 34.4 9.3 1226 1103 132 405 35.2 14.3 1799 1600 126 540 35.7 19.3 2304 2039 119 180 32.8 5.9 869 776 147 240 33.6 8.1 1139 1012 141 360 34.4 12.4 1635 1471 132 540 35.2 19.0 2380 2068 125 720 35.7 25.7 3041 2603 118 135 32.8 4.4 643 578 145 180 33.6 6.1 844 757 139 270 34.4 9.3 1207 1087 130 405 35.2 14.3 1771 1576 124 540 35.7 19.3 2269 2009 118 180 32.8 5.9 856 764 145 240 33.6 8.1 1121 996 139 360 34.4 12.4 1610 1449 130 540 35.2 19.0 2344 2037 123 720 35.7 25.7 2995 2563 116 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Spectrum Characteristics Table 4: Typical Color Rendering Index and TM-30 Values at, Tc=85°C Nominal CCT1 Rf Rg R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 2700K 95 103 97 99 94 94 97 98 97 98 99 97 91 98 98 95 98 3000K 95 104 98 99 93 94 97 98 96 96 97 96 92 95 98 95 97 3500K 95 98 98 98 97 98 98 98 98 97 93 97 97 95 98 97 98 4000K 97 100 99 99 97 99 99 99 99 98 94 97 99 96 99 98 98 5000K 97 100 98 99 98 98 98 98 99 98 95 98 98 98 98 98 97 5700K 94 98 98 98 97 95 98 97 96 95 92 97 96 96 98 98 97 6500K 95 98 98 98 97 96 98 98 96 96 93 97 96 97 98 98 97 Note for Table 4: 1. Bridgelux maintains a tolerance of ± 3 on Color Rendering Index R1-R15 measurements and TM-30 measurements. Figure 1: 2700K Thrive TM-30 Graphs Figure 2: 3000K Thrive TM-30 Graphs Figure 3: 3500K Thrive TM-30 Graphs 6 Spectrum Characteristics Figure 4: 4000K Thrive TM-30 Graphs Figure 5: 5000K Thrive TM-30 Graphs Figure 6: 5700K Thrive TM30 Graphs Figure 7: 6500K Thrive TM-30 Graphs 7 Spectrum Characteristics Figure 8: Typical Color Spectrum 100% 100% 2700K 5000K 5700K 6500K 80% Relative Radiant Power(%) Relative Radiant Power(%) 3000K 3500K 4000K 60% 40% 20% 0% 350 400 450 500 550 600 650 700 750 800 Wavelength(nm) 80% 60% 40% 20% 0% 350 400 450 500 550 600 650 700 750 800 Wavelength(nm) Note for Figure 8: 1. Color spectra measured at nominal current for Tj = 85°C. Spectral Matching to Natural Light The lighting market is in the early stages of adoption of human-centric lighting (HCL). HCL encompasses the effects of lighting on the physical and emotional health and well-being of people. Throughout evolution, the human visual system has evolved under the natural light of sun and fire. These light sources have standardized industry spectral power definitions that describe the state of natural light. However, conventional metrics such as CCT, CRI, and TM-30 fail to adequately quantify the naturalness, or closeness of these light sources to the standardized natural spectra. Due to a lack of an industry standard metric to quantitatively measure the naturalness of a light source, Bridgelux has pioneered a new metric that takes the guesswork out of comparing LED light sources to natural light. Average Spectral Difference, or ASD, is calculated by measuring the absolute difference between two spectra at discrete wavelengths. These values are averaged across a wavelength range derived from the photopic response curve, or V(λ); a luminous efficiency function describing the average spectral sensitivity of human perception of brightness. The range of 425nm to 690nm was selected to remove the tails of the V(λ) gaussian distribution below 1% of the peak value at 555nm, covering 99.9% of the area under the photopic response curve. Natural light is defined following the approach of IES TM-30; black body curves for light sources of ≤4000K and the CIE standard illuminant D for light sources of ≥ 5000K. Natural light has an ASD of 0%; lower ASD values indicate a closer match to natural light. Thrive is engineered to provide the closest match to natural light available using proprietary chip, phosphor and packaging technology, resulting in an ASD between 8% to 10% for all CCTs. By comparison, standard 80, 90, and 98 CRI light sources have ASD values that are 100% to 300% larger than Thrive. To learn more about the ASD metric, please contact your Bridgelux sales representative. Bridgelux will publish a white paper to further educate the market about the benefits of the ASD metric in Q2 2020. 8 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRE-xxx1001-B-7x BXRE-xxx1001-C-7x Drive Current (mA) Minimum Typical Maximum Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 270 32.2 34.4 37.4 -16.1 0.49 30.9 38.5 540 33.4 35.7 38.8 -16.1 0.56 32.1 39.9 360 32.2 34.4 37.4 -16.1 0.37 30.9 38.5 720 33.4 35.7 38.8 -16.1 0.45 32.1 39.9 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 9 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx1001-B-7x BXRE-xxx1001-C-7x Maximum Drive Current3 540mA 720mA Maximum Peak Pulsed Drive Current4 770mA 1030mA Maximum Reverse Voltage5 -60V -60V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 10 Eye Safety Table 7: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx100x-B-7x BXRE-xxx100x-C-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 270 RG1 RG1 RG1 RG1 405 RG1 RG1 RG1 RG2 540 RG1 RG1 RG2 RG2 360 RG1 RG1 RG1 RG2 540 RG1 RG1 RG2 RG2 720 RG1 RG2 RG2 RG2 Notes for Table 7: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 11 Product Bin Definitions Table 8: 2-, 3- and 4-step MacAdam Ellipse Color Bin Definitions Center Point Degree 2-step 3-step 4-step CCT x y Φ(°) a b a b a b 2700K 0.4578 0.4101 53.700 0.00540 0.00280 0.0081 0.0042 N/A N/A 3000K 0.4338 0.403 53.217 0.00556 0.00272 0.0083 0.0041 N/A N/A 4000K 0.3818 0.3797 53.717 0.00626 0.00268 0.0094 0.0040 N/A N/A 5000K 0.3447 0.3553 59.617 N/A N/A 0.0082 0.0035 0.0110 0.0047 5700K 0.3287 0.3417 59.060 N/A N/A 0.0074 0.0032 0.0099 0.0042 6500K 0.3123 0.3282 58.567 N/A N/A 0.0066 0.0028 0.0090 0.0038 Notes for Table 8: 1. Color binning at Tc=85°C 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Figure 9: C.I.E. 1931 Chromaticity Diagram (Color targeted at Tc=85°C) 0.44 0.39 3 SDCM 4 SDCM 2 SDCM 0.38 2700K 3 SDCM 0.42 3000K 0.37 3500K 5000K 0.36 0.4 5700K 0.35 Y Y 4000K 0.38 6500K 0.34 0.33 0.36 0.32 0.34 0.36 0.31 0.39 0.42 0.45 X 0.48 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 0.37 X 12 Performance Curves Figure 10: V10B Drive Current vs. Voltage (Tc=25°C) Figure 11: V10C Drive Current vs. Voltage (Tc=25°C) 800 600 700 Forward Current (mA) Forward Current(mA) 500 400 300 200 100 600 500 400 300 200 100 0 32.0 33.0 34.0 35.0 36.0 0 32.0 37.0 33.0 Figure 12: V10B Typical Relative Flux vs. Current (Tc=25°C) 35.0 36.0 37.0 Figure 13: V10C Typical Relative Flux vs. Current (Tc=25°C) 200% 200% 180% 180% 160% 160% Relative Luminus Flux Relative Luminus Flux 34.0 Forward Voltage (V) Forward Voltage(V) 140% 120% 100% 80% 60% 40% 20% 140% 120% 100% 80% 60% 40% 20% 0% 0 100 200 300 Forward Current (mA) 400 500 600 0% 0 100 200 300 400 500 600 700 800 Forward Current (mA) 13 Performance Curves Figure 15: Typical ccx Shift vs. Case Temperature Figure 14: Typical DC Flux vs. Case Temperature 105% 0.0012 100% 0.0009 Neutral White Cool White 0.0006 95% ccx Shift Relative Luminus Flux Warm White 90% Warm White 0.0003 0.0000 Neutral White 85% -0.0003 Cool White 80% 0 25 50 75 -0.0006 100 0 Case Temperature(°C) 25 50 75 100 125 Case Temperature (°C) Figure 16: Typical ccy Shift vs. Case Temperature 0 25 50 75 100 125 0.000 ccy Shift -0.001 -0.002 -0.003 Warm White -0.004 Neutral White Cool White -0.005 Case Temperature (°C) Notes for Figures 14-16: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for warm white based on 3000K Thrive 3. Characteristics shown for neutral white based on 4000K Thrive 4. Characteristics shown for cool white based on 5000K Thrive 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 14 Typical Radiation Pattern Figure 17: Typical Spatial Radiation Pattern Notes for Figure 17: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 18: Typical Polar Radiation Pattern 15 Mechanical Dimensions Figure 19: V10 LED Array Notes for Figure 19: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting locations (2X) are for M2.5 screws. 5. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 16 Packaging and Labeling Figure 20: V10 Packaging Notes for Figure 20: 1. Each tube holds 30 V10 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 8.3 (W) x 15.4 (H) x 430 (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 17 Packaging and Labeling Figure 21: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30S1001C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 18 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 19 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/bridgelux-inc-_2 youtube.com/user/Bridgelux WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2019 Bridgelux, Inc. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 V10 Thrive Array Product Data Sheet DS320 Rev. A (10/2019) 20
BXRE-40S1001-B-72 价格&库存
很抱歉,暂时无法提供与“BXRE-40S1001-B-72”相匹配的价格&库存,您可以联系我们找货
