BXRV-DR-1830G-0600-B-23
    BRIDGELUX(普瑞)
BXRV-DR-1830G-0600-B-23 数据手册
Bridgelux Vesta® Series Dim-To-Warm Gen 2 6mm Array ® Product Data Sheet DS190 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the Vesta Series family of products. Fully engineered substrate for consistent thermal, mechanical and optical properties Solder Pads Polarity symbols Case Temperature (Tc) Measurement Point White ring around LES Yellow phosphor Light Emitting Surface (LES) Designed to comply with global safety standards for creepage and clearance distances Dimming control component Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux Vesta Series arrays is explained as follows: 1 2 3 4 - 5 6 - 7 8 9 10 11 - 12131415 - 16 - 17 18 BXRV DR – 1 830 G – 0600 – A – 23 Product Family CCT Bin Options 3 = 3 SDCM at 2700K and 3000K, 5 SDCM at 1800K Dim-To-Warm Array Product Generation 2 = Gen 2 Nominal CCT 18 = 1,800K 27 = 2,700K 30 = 3,000K Array Configuration Minimum CRI G = 90 CRI A = 6W, 17V B = 10W, 34V Form Factor Designator 0600 = 6mm LES 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Measurement Data Part Number BXRV-DR-1827G-0600-A-23 BXRV-DR-1830G-0600-A-23 BXRV-DR-1827G-0600-B-23 BXRV-DR-1830G-0600-B-23 Nominal CCT 1 (K) Minimum CRI 2 Drive Current (mA) Typical Vf Tc=25°C (V) Typical Power Tc=25°C (W) Typical Pulsed Flux 3, 4, 5 Tc=25°C (lm) Typical Efficacy Tc=25°C (lm/W) Minimum Pulsed Flux 6, 7 Tc=25°C (lm) Typical DC Flux 7, 8 Tc=85°C (lm) 2700 90 350 17.0 6.0 627 105 564 564 1800 90 14 11.2 0.2 14 89 13 13 3000 90 350 17.0 6.0 660 111 594 594 1800 90 14 11.2 0.2 16 102 14 14 2700 90 280 34.6 9.7 1026 106 923 923 1800 90 14 27.3 0.4 40 105 36 36 3000 90 280 34.6 9.7 1080 111 972 972 1800 90 14 27.3 0.4 40 105 36 36 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2017. 2. Minimum R9 value for 90/90 CRI products is 50. Bridgelux maintains a ±3 tolerance on all CRI and R9 values. 3. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 4. Typical performance values are provided as a reference only and are not a guarantee of performance. 5. Bridgelux maintains a ±7% tolerance on flux measurements. 6. Minimum flux values at the nominal test current are guaranteed by 100% test. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 European Product Registry for Energy Labeling The European Product Registry for Energy Labeling (EPREL) is defined in the EU Regulation 2017/1369 to provide information about a product’s energy efficiency to consumers. Together with Energy Labeling Regulation ELR (EU) 2019/2015, which was amended by regulation (EU) 2021/340 for energy labelling of light sources, manufacturers are required to declare an energy class based on key technical specifications from each of their product and register it in an open data base managed by EPREL. It is now a legal requirement for a vendor of light sources to upload information about their products into the EPREL database before placing these products on the market in the EU. Table 2 provides a list of part numbers that are in compliance with EPREL regulations and are currently listed in the EPREL database. At Bridgelux, we are fully committed to supplying products that are compliant with pertinent laws, rules, and obligation imposed by relevant government bodies including the ELR regulation. Customers can use these products with full confidence for any projects that fall under the EPREL requirement. Table 2: Table of products registered in the European Product Registry for Energy Labeling (EPREL) Part Number CCT (K) CRI Current 3 (mA) Voltage 3 (V) Useful Flux 2 ØΦuseful Tc=85C (lm) Power (W) Efficacy (lm/W) Energy Efficiency Class 4 A G X Registration No URL 1 BXRV-DR-1827G-0600-A-23 2700 90 400 16.8 650 6.7 96 F 876240 https://tinyurl.com/9m39skpv BXRV-DR-1830G-0600-A-23 3000 90 420 16.9 713 7.1 100 F 876248 https://tinyurl.com/yzdj2f39 BXRV-DR-1827G-0600-B-23 2700 90 190 31.5 650 6.0 108 F 879003 BXRV-DR-1830G-0600-B-23 3000 90 230 32.1 814 7.4 110 F 879017 https://tinyurl.com/4pb8mwvv https://tinyurl.com/dcdmz8p8 Notes for Table 2: 1. The performance data in this table is a subset of the data that was submitted to EPREL for obtaining the energy class listed here. For accessing a complete set of technical documentation of Bridgelux registered products in the EPREL database, please visit one of the hyperlinks listed above. 2. For a definition of useful luminous flux (ØΦuseful), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 3. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 4. EPREL requires a symbol for displaying the energy classification of a product in marketing literature. This symbol consists of a letter stating a product’s energy efficiency class inside a specific arrow logo as defined by EPREL. 5. All products listed here must be disposed as e-waste according to the guidelines in the country in which the product is used. 4 Electrical Characteristics Table 3: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 7 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage 4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case 5 Rj-c (ºC/W) Driver Selection Voltages 6 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.89 15.0 18.9 -6.1 0.92 15.3 19.2 37.6 -12.4 0.89 30.6 38.4 38.6 -12.4 0.92 31.4 39.4 Minimum Typical Maximum 350 15.5 17.0 18.5 -6.1 420 15.8 17.3 18.8 280 31.6 34.6 350 32.4 35.5 BXRV-DR-18xxx-0600-A-23 BXRV-DR-18xxx-0600-B-23 Notes for Table 3: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 6. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 7. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 45V d.c. The maximum allowable voltage across the array must be determined in the end product application. 5 Absolute Maximum Ratings Table 4: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 350°C or lower for a maximum of 10 seconds BXRV-DR-18xxG-0600-A-23 BXRV-DR-18xxG-0600-B-23 Maximum Drive Current3 420mA 350mA Maximum Peak Pulsed Drive Current4 600mA 500mA Maximum Reverse Voltage5 -30V -50V Notes for Table 4: 1. For IEC 62717 requirement, please contact Bridgelux Sales Support. 2. See Bridgelux Application Note AN101 “Handling and Assembly of LED Arrays” for more information. 3. Please refer to Figure X for a drive current derating curve. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20ms when operating LED arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 6 Performance Curves Figure 1: Forward Voltage vs. Forward Current, Tc=25°C Figure 2: Relative Flux vs. Case Temperature BXRV-DR-18xxG-0600-A-23 BXRV-DR-18xxG-0600-A-23 102% 450 25°C Pulsed 400 350mA 100% 14mA 98% 300 Relative LOP Forward Current (mA) 350 250 200 150 96% 94% 92% 100 90% 50 0 10.0 88% 11.0 12.0 13.0 14.0 15.0 Forward Voltage (V) 16.0 17.0 15 18.0 Figure 3: Forward Voltage vs. Forward Current, Tc=25°C 25 35 85 95 105 102% 350 100% 300 98% 14mA 96% 25℃ pulsed 250 200 150 100 280mA 94% 92% 90% 88% 50 0 27.00 115 BXRV-DR-18xxG-0600-B-23 400 Relative LOP Forward Current (mA) 55 65 75 Case Temperature (°C) Figure 4: Relative Flux vs. Case Temperature BXRV-DR-18xxG-0600-B-23 86% 29.00 31.00 33.00 Forward Voltage (V) 35.00 84% 37.00 Figure 5: Relative LOP vs. Drive Current, Tc=25°C 15 25 35 45 55 65 75 85 Case Temperature (℃) 95 105 115 Figure 6: Relative LOP vs. Drive Current, Tc=25°C BXRV-DR-18xxG-0600-A-23 BXRV-DR-18xxG-0600-B-23 140% 140% 120% 100% 100% Relative LOP 120% Relative LOP 45 80% 60% 40% 80% 60% 40% 20% 20% 0% 0 0% 0 100 200 300 Drive Current (mA) 400 500 100 200 Forward Current (mA) 300 400 7 Performance Curves Figure 7: CCT vs. Forward Current, Tc=25°C Figure 8: CCT vs. Forward Current, Tc=25°C BXRV-DR-1827G-0600-A-23 BXRV-DR-1830G-0600-A-23 2800 3200 3000 2600 2800 CCT (K) CCT (K) 2400 2200 2000 2600 2400 2200 2000 1800 1800 1600 0 100 200 300 400 500 1600 0 100 200 Current (mA) 300 400 500 Current (mA) Figure 9: CCT vs. Forward Current, Tc=25°C Figure 10: CCT vs. Forward Current, Tc=25°C BXRV-DR-1827G-0600-B-23 BXRV-DR-1830G-0600-B-23 2800 3200 3000 2600 2800 CCT (K) CCT (K) 2400 2200 2000 2600 2400 2200 2000 1800 1800 1600 1600 0 100 200 Forward Current (mA) 300 400 0 100 200 Forward Current (mA) 300 400 8 Performance Curves Figure 11: Derating Curve Figure 12: Derating Curve BXRV-DR-18xxG-0600-A-23 BXRV-DR-18xxG-0600-B-23 400 450 400 350 350 mA 300 Current (mA) Current (mA) 350 300 250 200 150 250 200 150 100 100 50 50 0 0 25 45 65 85 Case Temperature (˚C) 105 125 Figure 13: Color shift vs. Forward Current 3000K - 1800K 25 45 105 Figure 14: Color shift vs. Forward Current 2700K - 1800K BXRV-DR-1830G-0600-A-23 BXRV-DR-1827G-0600-A-23 0.43 0.42 0.42 0.41 0.41 0.4 CCY 0.43 CCY 65 85 Case Temperature (℃) 1800K 2700K 0.4 1800K 3000K 0.39 0.39 0.38 0.38 0.37 0.41 0.43 0.45 0.47 0.49 CCX 0.51 0.53 0.55 0.57 Figure 15: Color shift vs. Forward Current 3000K - 1800K 0.37 0.41 0.45 0.47 0.49 CCX 0.51 0.53 0.55 0.57 Figure 16: Color shift vs. Forward Current 2700K - 1800K BXRV-DR-1830G-0600-B-23 0.45 BXRV-DR-1827G-0600-B-23 0.45 0.43 0.43 CCY CCY 0.43 0.41 0.43 0.45 1800K 0.39 0.37 0.41 2700K 1800K 3000K 0.39 0.41 0.47 0.49 CCX 0.51 0.53 0.55 0.37 0.44 0.46 0.48 0.5 0.52 0.54 0.56 CCX 9 Typical Radiation Pattern Figure 17: Typical Spatial Radiation Pattern 100% 90% Relative Intensity (%) 80% 70% 60% 50% 40% 30% 20% 10% 0% -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Displacement (⁰) Notes for Figure 9: 1. Typical viewing angle is 110⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 18: Typical Polar Radiation Pattern -30⁰ -15⁰ 15⁰ 30⁰ 100% 90% -45⁰ 80% 45⁰ 70% 60% -60⁰ 50% 60⁰ 40% 30% -75⁰ 20% 75⁰ 10% -90⁰ 0% 90⁰ 10 Typical Color Spectrum Figure 19: Typical Color Spectrum Relative Spectral Power Distribution (%) 120% 1800K (14mA) 2700K (250mA (350mA) or 350mA) 3000K (350mA) (250mA or 350mA) 100% 80% 60% 40% 20% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 19: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 11 Mechanical Dimensions Figure 20: Mechanical Drawing Specifications BXRV-DR-18xxG-0600-A-23 BXRV-DR-18xxG-0600-B-23 Notes for Figure 20: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes for product handling, mounting and heat sink recommendations. 5. The optical center of the LED array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.2 mm. 6. Solder pads are labeled “+” to denote positive polarity, and “-” to denote negative polarity. 12 Color Binning Information Table 5: McAdam ellipse CCT color bin definitions for product operating at Tc = 25ºC CCT Center Point Bin Size Axis a Axis b Rotation Angle 1800K x=0.5496 y=0.4081 5 SDCM 0.01164 0.00655 40.00º 2700K x=0.4578 y= 0.4101 3 SDCM 0.00810 0.00420 53.70º 3000K x=0.4338 y=0.4030 3 SDCM 0.00834 0.00408 53.22º Notes for Table 5: 1. The x,y center points are the center points of the respective ANSI bins in the CIE 1931 xy Color Space 2. Products are binned at Tc=25°C 3. Bridgelux maintains a tolerance of +/-0.007 on x and y color coordinates in the CIE 1931 Color Space Figure 21: Definition of the McAdam ellipse a b φ x, y, center point 13 Packaging and Labeling Figure 22: Packaging Specifications Tray label Bag label Box label BXRV-DR-1830G-0600-A-13 BXRV-DR-1830G-0600-A-13 BXRV-DR-1830G-0600-A-13 13 13 420mA Notes for Figure 22: 1. Each tray holds 35 Vesta Series Dim-To-Warm 6mm arrays. 2. Eight trays are sealed in an anti-static bag. One such bag is placed in a box and shipped. Depending on quantities ordered, a bigger shipping box, containing more boxes will be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tray are 200 (W) x 12(H) x 300 (L) mm. Dimensions for the anti-static bag are 440 (W) x 350mm (L) x 0.1 mm (T) and that of a shipping box are 350 x 245 x 67 mm. Figure 23: Product Labeling Bridgelux arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 1830G06A 13 Internal Bridgelux use only. 14 Design Resources Application Notes Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vesta Series product family of LED array products. Please see Bridgelux Application Note, AN101 for more information. For a list of resources under development visit www.bridgelux.com. 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux Vesta Series LED arrays are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vesta Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. Vesta Series Dim-To-Warm arrays are classified as Risk Group 1 when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Do not touch the LES (Light Emitting Surface, defined by the yellow phosphor resin area). Do not apply any stress to the LES or resistors to avoid damage to the LED array. Holder and secondary optics may be mounted on the top surface of the Vesta Series array as long as they do not make contact with the LES and resistors. Use the edges of the Vesta Series array to align and mount holder and secondary optics devices. CAUTION: RISK OF BURN Do not touch the Vesta Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vesta Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, array testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 15 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux WeChat ID: BridgeluxInChina 46410 Fremont Blvd Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved 2021. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc, and Vesta Series is a registered trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vesta Series Dim-To-Warm Gen 2 6mm Array Product Data Sheet DS190 Rev. B (08/2021) 16
BXRV-DR-1830G-0600-B-23 价格&库存
很抱歉,暂时无法提供与“BXRV-DR-1830G-0600-B-23”相匹配的价格&库存,您可以联系我们找货
  • 280+20.39879280+2.63847
        库存:175
