BXRC-35E1000-B-83-SE
    BRIDGELUX(普瑞)
    冷白色 3500K CRI:80
BXRC-35E1000-B-83-SE 数据手册
Bridgelux Gen 8 Vero SE 18 Array ® ® Product Data Sheet DS432 1 Vero SE Introduction The Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s eighth generation COB technology with poke-in connectivity, enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing costs, simplify the luminaire design process, improve light quality, and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures, and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting, with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Features • Poke-in electrical connectivity • Top side part number markings • Efficacy of 177 lm/W typical, 3000K 80 CRI • Reliable operation at up to 3x nominal current, 30% increase in maximum lumens per LES size • Wide selection of CCT options (2700K-6500K) with minimum 70, 80 and 90 CRI options Benefits • Low cost, solderless, connector free installation and field upgradability • Improved inventory management and quality control • Enables high efficiency lighting systems and lower operating costs • Supports the trend toward luminaire miniaturization and delivers enhanced optical control • Uniform high-quality illumination • Design flexibility for a broad range of lighting applications • 2 and 3 SDCM binning options (2700K – 4000K) • Clean white light without pixelation • Forward voltage bin codes (backside marking) • Uniform consistent white light • 10-Year warranty • Design flexibility for multi-source applications • Design with confidence Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 7 Electrical Characteristics 16 Eye Safety 17 Absolute Maximum Ratings 18 Performance Curves 19 Typical Radiation Pattern 21 Typical Color Spectrum 22 Mechanical Dimensions 23 Color Binning Information 24 Packaging and Labeling 25 Design Resources 27 Precautions 27 Disclaimers 27 About Bridgelux 28 1 Product Feature Map Vero SE 18 is the second largest form factor in the product family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www. bridgelux.com for more information on the Vero SE family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 Tc Measurement point Optic mounting holes Radial die configuration improves lumen density and beam control Mounting holes Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 400 0 – C – 8 3 – SE Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 8 Array Configuration CRI C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Target Flux Indicator 400x = 4000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E4000-B-8x-SE 2700 80 700 3976 3578 33.9 23.7 168 BXRC-27E4000-C-8x-SE 2700 80 1050 5945 5351 33.9 35.6 167 BXRC-27E4000-D-8x-SE 2700 80 850 4002 3602 28.2 24.0 167 BXRC-27G4000-B-8x-SE 2700 90 700 3280 2952 33.9 23.7 138 BXRC-27G4000-C-8x-SE 2700 90 1050 4905 4414 33.9 35.6 138 BXRC-27G4000-D-8x-SE 2700 90 850 3302 2971 28.2 24.0 138 BXRC-27G40H0-B-8x-SE 2700 90 700 3422 3080 33.9 23.7 144 BXRC-27G40H0-C-8x-SE 2700 90 1050 5117 4605 33.9 35.6 144 BXRC-27G40H0-D-8x-SE 2700 90 850 3444 3100 28.2 24.0 144 BXRC-30C4001-B-8x-SE 3000 70 700 4423 3981 33.9 23.7 186 BXRC-30C4001-C-8x-SE 3000 70 1050 6614 5953 33.9 35.6 186 BXRC-30C4001-D-8x-SE 3000 70 850 4452 4007 28.2 24.0 186 BXRC-30E4000-B-8x-SE 3000 80 700 4224 3802 33.9 23.7 178 BXRC-30E4000-C-8x-SE 3000 80 1050 6317 5685 33.9 35.6 177 BXRC-30E4000-D-8x-SE 3000 80 850 4252 3827 28.2 24.0 177 BXRC-30G4000-B-8x-SE 3000 90 700 3429 3086 33.9 23.7 145 BXRC-30G4000-C-8x-SE 3000 90 1050 5128 4615 33.9 35.6 144 BXRC-30G4000-D-8x-SE 3000 90 850 3452 3106 28.2 24.0 144 BXRC-30G40H0-B-8x-SE 3000 90 700 3591 3232 33.9 23.7 151 BXRC-30G40H0-C-8x-SE 3000 90 1050 5369 4832 33.9 35.6 151 BXRC-30G40H0-D-8x-SE 3000 90 850 3614 3253 28.2 24.0 151 BXRC-35E4000-B-8x-SE 3500 80 700 4324 3891 33.9 23.7 182 BXRC-35E4000-C-8x-SE 3500 80 1050 6465 5819 33.9 35.6 182 BXRC-35E4000-D-8x-SE 3500 80 850 4352 3917 28.2 24.0 182 BXRC-35G4000-B-8x-SE 3500 90 700 3553 3198 33.9 23.7 150 BXRC-35G4000-C-8x-SE 3500 90 1050 5314 4782 33.9 35.6 149 BXRC-35G4000-D-8x-SE 3500 90 850 3577 3219 28.2 24.0 149 BXRC-40C4001-B-8x-SE 4000 70 700 4547 4093 33.9 23.7 192 BXRC-40C4001-C-8x-SE 4000 70 1050 6800 6120 33.9 35.6 191 BXRC-40C4001-D-8x-SE 4000 70 850 4577 4119 28.2 24.0 191 BXRC-40E4000-B-8x-SE 4000 80 700 4349 3914 33.9 23.7 183 BXRC-40E4000-C-8x-SE 4000 80 1050 6503 5852 33.9 35.6 183 BXRC-40E4000-D-8x-SE 4000 80 850 4377 3939 28.2 24.0 183 BXRC-40G4000-B-8x-SE 4000 90 700 3628 3265 33.9 23.7 153 BXRC-40G4000-C-8x-SE 4000 90 1050 5425 4883 33.9 35.6 152 BXRC-40G4000-D-8x-SE 4000 90 850 3652 3287 28.2 24.0 152 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-50C4001-B-8x-SE 5000 70 700 4572 4115 33.9 23.7 193 BXRC-50C4001-C-8x-SE 5000 70 1050 6837 6153 33.9 35.6 192 BXRC-50C4001-D-8x-SE 5000 70 850 4602 4142 28.2 24.0 192 BXRC-50E4001-B-8x-SE 5000 80 700 4398 3958 33.9 23.7 185 185 BXRC-50E4001-C-8x-SE 5000 80 1050 6577 5919 33.9 35.6 BXRC-50E4001-D-8x-SE 5000 80 850 4427 3984 28.2 24.0 185 BXRC-50G4001-B-8x-SE 5000 90 700 3802 3422 33.9 23.7 160 BXRC-50G4001-C-8x-SE 5000 90 1050 5685 5117 33.9 35.6 160 BXRC-50G4001-D-8x-SE 5000 90 850 3827 3444 28.2 24.0 160 BXRC-57C4001-B-8x-SE 5700 70 700 4448 4003 33.9 23.7 187 BXRC-57C4001-C-8x-SE 5700 70 1050 6651 5986 33.9 35.6 187 BXRC-57C4001-D-8x-SE 5700 70 850 4477 4029 28.2 24.0 187 BXRC-57E4001-B-8x-SE 5700 80 700 4224 3802 33.9 23.7 178 BXRC-57E4001-C-8x-SE 5700 80 1050 6317 5685 33.9 35.6 177 BXRC-57E4001-D-8x-SE 5700 80 850 4252 3827 28.2 24.0 177 BXRC-65C4001-B-8x-SE 6500 70 700 4448 4003 33.9 23.7 187 187 BXRC-65C4001-C-8x-SE 6500 70 1050 6651 5986 33.9 35.6 BXRC-65C4001-D-8x-SE 6500 70 850 4477 4029 28.2 24.0 187 BXRC-65E4001-B-8x-SE 6500 80 700 4274 3847 33.9 23.7 180 BXRC-65E4001-C-8x-SE 6500 80 1050 6391 5752 33.9 35.6 180 BXRC-65E4001-D-8x-SE 6500 80 850 4302 3872 28.2 24.0 179 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E4000-B-8x-SE 2700 80 700 3578 3220 33.1 23.2 154 BXRC-27E4000-C-8x-SE 2700 80 1050 5351 4816 33.1 34.8 154 BXRC-27E4000-D-8x-SE 2700 80 850 3602 3242 27.7 23.5 153 BXRC-27G4000-B-8x-SE 2700 90 700 2952 2657 33.1 23.2 127 BXRC-27G4000-C-8x-SE 2700 90 1050 4414 3973 33.1 34.8 127 BXRC-27G4000-D-8x-SE 2700 90 850 2971 2674 27.7 23.5 126 BXRC-27G40H0-B-8x-SE 2700 90 700 3080 2772 33.1 23.2 133 BXRC-27G40H0-C-8x-SE 2700 90 1050 4605 4144 33.1 34.8 132 BXRC-27G40H0-D-8x-SE 2700 90 850 3100 2790 27.7 23.5 132 BXRC-30C4001-B-8x-SE 3000 70 700 3981 3583 33.1 23.2 172 BXRC-30C4001-C-8x-SE 3000 70 1050 5953 5357 33.1 34.8 171 BXRC-30C4001-D-8x-SE 3000 70 850 4007 3606 27.7 23.5 170 BXRC-30E4000-B-8x-SE 3000 80 700 3802 3422 33.1 23.2 164 BXRC-30E4000-C-8x-SE 3000 80 1050 5685 5117 33.1 34.8 163 BXRC-30E4000-D-8x-SE 3000 80 850 3827 3444 27.7 23.5 163 BXRC-30G4000-B-8x-SE 3000 90 700 3086 2778 33.1 23.2 133 BXRC-30G4000-C-8x-SE 3000 90 1050 4615 4153 33.1 34.8 133 BXRC-30G4000-D-8x-SE 3000 90 850 3106 2796 27.7 23.5 132 BXRC-30G40H0-B-8x-SE 3000 90 700 3232 2908 33.1 23.2 139 BXRC-30G40H0-C-8x-SE 3000 90 1050 4832 4349 33.1 34.8 139 BXRC-30G40H0-D-8x-SE 3000 90 850 3253 2927 27.7 23.5 138 BXRC-35E4000-B-8x-SE 3500 80 700 3891 3502 33.1 23.2 168 BXRC-35E4000-C-8x-SE 3500 80 1050 5819 5237 33.1 34.8 167 BXRC-35E4000-D-8x-SE 3500 80 850 3917 3525 27.7 23.5 167 BXRC-35G4000-B-8x-SE 3500 90 700 3198 2878 33.1 23.2 138 BXRC-35G4000-C-8x-SE 3500 90 1050 4782 4304 33.1 34.8 138 BXRC-35G4000-D-8x-SE 3500 90 850 3219 2897 27.7 23.5 137 BXRC-40C4001-B-8x-SE 4000 70 700 4093 3683 33.1 23.2 177 BXRC-40C4001-C-8x-SE 4000 70 1050 6120 5508 33.1 34.8 176 BXRC-40C4001-D-8x-SE 4000 70 850 4119 3707 27.7 23.5 175 BXRC-40E4000-B-8x-SE 4000 80 700 3914 3522 33.1 23.2 169 BXRC-40E4000-C-8x-SE 4000 80 1050 5852 5267 33.1 34.8 168 BXRC-40E4000-D-8x-SE 4000 80 850 3939 3545 27.7 23.5 168 BXRC-40G4000-B-8x-SE 4000 90 700 3265 2939 33.1 23.2 141 BXRC-40G4000-C-8x-SE 4000 90 1050 4883 4394 33.1 34.8 140 BXRC-40G4000-D-8x-SE 4000 90 850 3287 2958 27.7 23.5 140 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 177 BXRC-50C4001-B-8x-SE 5000 70 700 4115 3704 33.1 23.2 BXRC-50C4001-C-8x-SE 5000 70 1050 6153 5538 33.1 34.8 177 BXRC-50C4001-D-8x-SE 5000 70 850 4142 3728 27.7 23.5 176 BXRC-50E4001-B-8x-SE 5000 80 700 3958 3563 33.1 23.2 171 BXRC-50E4001-C-8x-SE 5000 80 1050 5919 5327 33.1 34.8 170 BXRC-50E4001-D-8x-SE 5000 80 850 3984 3586 27.7 23.5 169 BXRC-50G4001-B-8x-SE 5000 90 700 3422 3080 33.1 23.2 148 BXRC-50G4001-C-8x-SE 5000 90 1050 5117 4605 33.1 34.8 147 BXRC-50G4001-D-8x-SE 5000 90 850 3444 3100 27.7 23.5 146 BXRC-57C4001-B-8x-SE 5700 70 700 4003 3603 33.1 23.2 173 BXRC-57C4001-C-8x-SE 5700 70 1050 5986 5387 33.1 34.8 172 BXRC-57C4001-D-8x-SE 5700 70 850 4029 3626 27.7 23.5 171 BXRC-57E4001-B-8x-SE 5700 80 700 3802 3422 33.1 23.2 164 BXRC-57E4001-C-8x-SE 5700 80 1050 5685 5117 33.1 34.8 163 BXRC-57E4001-D-8x-SE 5700 80 850 3827 3444 27.7 23.5 163 BXRC-65C4001-B-8x-SE 6500 70 700 4003 3603 33.1 23.2 173 BXRC-65C4001-C-8x-SE 6500 70 1050 5986 5387 33.1 34.8 172 BXRC-65C4001-D-8x-SE 6500 70 850 4029 3626 27.7 23.5 171 BXRC-65E4001-B-8x-SE 6500 80 700 3847 3462 33.1 23.2 166 BXRC-65E4001-C-8x-SE 6500 80 1050 5752 5177 33.1 34.8 165 BXRC-65E4001-D-8x-SE 6500 80 850 3872 3485 27.7 23.5 165 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E4000-B-8x-SE 80 BXRC-27E4000-C-8x-SE 80 BXRC-27E4000-D-8x-SE 80 BXRC-27G4000-B-8x-SE 90 BXRC-27G4000-C-8x-SE 90 BXRC-27G4000-D-8x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 2087 3025 3976 4988 7501 10363 3121 4511 5945 6530 11217 15496 2101 3100 4002 4837 7551 10704 1722 2496 3280 4115 6189 8550 2575 3721 4905 5387 9254 12784 1733 2558 3302 3991 6229 8831 1878 2723 3578 4489 6751 9327 2809 4060 5351 5877 10095 13947 1891 2790 3602 4354 6795 9634 1550 2246 2952 3703 5570 7695 2317 3349 4414 4849 8329 11506 1560 2302 2971 3592 5606 7948 182 173 168 161 149 138 182 173 167 164 148 138 182 172 167 161 148 137 151 143 138 133 123 114 150 142 138 135 122 114 150 142 138 133 122 113 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G40H0-B-8x-SE 90 BXRC-27G40H0-C-8x-SE 90 BXRC-27G40H0-D-8x-SE 90 BXRC-30C4001-B-8x-SE 70 BXRC-30C4001-C-8x-SE 70 BXRC-30C4001-D-8x-SE 70 BXRC-30E4000-B-8x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 1796 2604 3422 4293 6456 8919 2686 3882 5117 5620 9654 13336 1808 2668 3444 4163 6498 9212 2322 3366 4423 5549 8345 11529 3472 5018 6614 7265 12479 17240 2337 3449 4452 5382 8400 11908 2218 3215 4224 5299 7970 11011 1617 2343 3080 3863 5810 8027 2417 3494 4605 5058 8688 12003 1627 2401 3100 3747 5848 8291 2090 3029 3981 4994 7511 10376 3125 4516 5953 6538 11231 15516 2103 3104 4007 4843 7560 10718 1996 2893 3802 4770 7173 9910 157 149 144 138 128 119 157 149 144 141 128 118 157 148 144 139 128 118 203 193 187 179 166 154 202 192 186 182 165 153 202 192 186 179 165 152 194 184 178 171 158 147 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30E4000-C-8x-SE 80 BXRC-30E4000-D-8x-SE 80 BXRC-30G4000-B-8x-SE 90 BXRC-30G4000-C-8x-SE 90 BXRC-30G4000-D-8x-SE 90 BXRC-30G40H0-B-8x-SE 90 BXRC-30G40H0-C-8x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 3316 4793 6317 6938 11918 16465 2232 3294 4252 5140 8022 11373 1800 2609 3429 4302 6470 8938 2692 3891 5128 5632 9675 13366 1812 2674 3452 4172 6512 9232 1885 2732 3591 4505 6775 9359 2819 4074 5369 5897 10131 13995 2984 4313 5685 6244 10726 14818 2009 2965 3827 4626 7220 10236 1620 2349 3086 3872 5823 8044 2423 3502 4615 5069 8707 12029 1631 2407 3106 3755 5861 8309 1696 2459 3232 4054 6097 8423 2537 3666 4832 5308 9117 12596 193 183 178 174 158 146 193 183 178 171 158 145 157 149 145 139 128 119 157 149 144 141 128 119 157 148 144 139 128 118 165 156 152 145 135 125 164 156 151 148 134 124 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G40H0-D-8x-SE 90 BXRC-35E4000-B-8x-SE 80 BXRC-35E4000-C-8x-SE 80 BXRC-35E4000-D-8x-SE 80 BXRC-35G4000-B-8x-SE 90 BXRC-35G4000-C-8x-SE 90 BXRC-35G4000-D-8x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 1897 2800 3614 4369 6819 9667 2270 3290 4324 5424 8158 11270 3394 4905 6465 7101 12199 16852 2285 3372 4352 5261 8211 11641 1865 2704 3553 4458 6704 9262 2789 4032 5314 5836 10025 13850 1878 2771 3577 4323 6748 9567 1708 2520 3253 3932 6137 8700 2043 2961 3891 4882 7342 10143 3055 4415 5819 6391 10979 15167 2056 3034 3917 4735 7390 10477 1679 2434 3198 4012 6034 8336 2510 3628 4782 5253 9023 12465 1690 2494 3219 3891 6073 8610 164 155 151 145 134 123 198 188 182 175 162 150 198 188 182 178 161 150 198 187 182 175 161 149 163 155 150 144 133 123 163 154 149 146 133 123 163 154 149 144 133 122 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40C4001-B-8x-SE 70 BXRC-40C4001-C-8x-SE 70 BXRC-40C4001-D-8x-SE 70 BXRC-40E4000-B-8x-SE 80 BXRC-40E4000-C-8x-SE 80 BXRC-40E4000-D-8x-SE 80 BXRC-40G4000-B-8x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 2387 3460 4547 5705 8580 11853 3570 5159 6800 7469 12830 17724 2403 3546 4577 5533 8636 12243 2283 3309 4349 5455 8205 11335 3414 4934 6503 7142 12269 16949 2298 3391 4377 5291 8258 11708 1905 2761 3628 4551 6845 9456 2148 3114 4093 5134 7722 10668 3213 4643 6120 6722 11547 15951 2163 3191 4119 4979 7772 11019 2055 2978 3914 4910 7384 10201 3072 4440 5852 6428 11042 15254 2068 3052 3939 4762 7433 10537 1714 2485 3265 4096 6161 8511 209 198 192 184 170 158 208 198 191 187 170 157 208 197 191 184 170 156 200 189 183 176 163 151 199 189 183 179 162 151 199 188 183 176 162 149 166 158 153 147 136 126 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40G4000-C-8x-SE 90 BXRC-40G4000-D-8x-SE 90 BXRC-50C4001-B-8x-SE 70 BXRC-50C4001-C-8x-SE 70 BXRC-50C4001-D-8x-SE 70 BXRC-50E4001-B-8x-SE 80 BXRC-50E4001-C-8x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 2848 4116 5425 5959 10236 14140 1917 2829 3652 4414 6890 9768 2400 3479 4572 5736 8627 11918 3589 5187 6837 7510 12900 17821 2416 3565 4602 5563 8683 12310 2309 3347 4398 5518 8299 11464 3453 4990 6577 7224 12409 17143 2563 3704 4883 5363 9212 12726 1725 2546 3287 3973 6201 8791 2160 3131 4115 5162 7764 10726 3230 4669 6153 6759 11610 16039 2174 3209 4142 5007 7815 11079 2078 3012 3958 4966 7469 10318 3107 4491 5919 6502 11168 15428 166 158 153 149 135 126 166 157 153 147 135 125 210 199 193 185 171 159 209 199 192 188 171 158 209 198 192 185 171 157 202 192 186 178 165 153 201 191 185 181 164 152 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50E4001-D-8x-SE 80 BXRC-50G4001-B-8x-SE 90 BXRC-50G4001-C-8x-SE 90 BXRC-50G4001-D-8x-SE 90 BXRC-57C4001-B-8x-SE 70 BXRC-57C4001-C-8x-SE 70 BXRC-57C4001-D-8x-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 2324 3430 4427 5351 8353 11841 1996 2893 3802 4770 7173 9910 2984 4313 5685 6244 10726 14818 2009 2965 3827 4626 7220 10236 2335 3385 4448 5580 8392 11594 3492 5046 6651 7306 12549 17336 2350 3469 4477 5412 8447 11975 2092 3087 3984 4816 7518 10657 1796 2604 3422 4293 6456 8919 2686 3882 5117 5620 9654 13336 1808 2668 3444 4163 6498 9212 2102 3046 4003 5022 7553 10434 3142 4542 5986 6575 11294 15603 2115 3122 4029 4871 7602 10778 201 190 185 178 164 151 174 166 160 154 142 132 174 165 160 156 142 132 174 165 160 154 142 131 204 194 188 180 167 154 203 193 187 183 166 154 203 193 187 180 166 153 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E4001-B-8x-SE 80 BXRC-57E4001-C-8x-SE 80 BXRC-57E4001-D-8x-SE 80 BXRC-65C4001-B-8x-SE 70 BXRC-65C4001-C-8x-SE 70 BXRC-65C4001-D-8x-SE 70 BXRC-65E4001-B-8x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 350 525 700 900 1400 2000 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 32.7 33.3 33.9 34.5 36.0 37.5 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 11.4 17.5 23.7 31.0 50.4 75.1 2218 3215 4224 5299 7970 11011 3316 4793 6317 6938 11918 16465 2232 3294 4252 5140 8022 11373 2335 3385 4448 5580 8392 11594 3492 5046 6651 7306 12549 17336 2350 3469 4477 5412 8447 11975 2244 3252 4274 5362 8064 11140 1996 2893 3802 4770 7173 9910 2984 4313 5685 6244 10726 14818 2009 2965 3827 4626 7220 10236 2102 3046 4003 5022 7553 10434 3142 4542 5986 6575 11294 15603 2115 3122 4029 4871 7602 10778 2019 2927 3847 4826 7258 10026 194 184 178 171 158 147 193 183 178 174 158 146 193 183 178 171 158 145 204 194 188 180 167 154 203 193 187 183 166 154 203 193 187 180 166 153 196 186 180 173 160 148 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-65E4001-C-8x-SE 80 BXRC-65E4001-D-8x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 525 785 1050 1170 2100 3000 425 650 850 1050 1700 2500 32.7 33.3 33.9 34.1 36.0 37.5 27.2 27.7 28.2 28.6 29.9 31.3 17.2 26.1 35.6 39.9 75.5 112.6 11.6 18.0 23.9 30.0 50.9 78.3 3355 4849 6391 7020 12058 16658 2258 3333 4302 5200 8117 11507 3020 4364 5752 6318 10853 14993 2033 3000 3872 4680 7305 10356 196 186 180 176 160 148 195 185 180 173 160 147 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx400x-B-8x-SE BXRC-xxx400x-C-8x-SE BXRC-xxx400x-D-8x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.14 30.5 37.2 -12.10 0.23 33.7 41.1 36.4 -10.93 0.12 30.5 37.2 37.5 40.3 -12.10 0.20 33.7 41.1 26.1 28.2 30.3 -9.10 0.13 25.4 30.9 29.0 31.3 33.6 -10.10 0.22 28.1 34.3 Minimum Typical Maximum 700 31.4 33.9 36.4 -10.93 2000 34.7 37.5 40.3 1050 31.4 33.9 3000 34.7 850 2500 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1140 V. The working voltage designated for the insulation is 70V d.c. The maximum allowable voltage across the array must be determined in the end product application. 16 Eye Safety Table 5: Eye Safety Risk Group (RG) Classifications Part Number CCT Drive Current (mA) 2700K/3000K 4000K2 5000K3 6500K4 1440 RG1 RG1 RG1 RG1 2000 RG1 RG1 RG1 RG2 1440 RG1 RG1 RG1 RG1 1995 RG1 RG1 RG1 RG2 2650 RG1 RG1 RG2 RG2 3000 RG1 RG2 RG2 RG2 1730 RG1 RG1 RG1 RG1 2400 RG1 RG1 RG1 RG2 2500 RG1 RG1 RG2 RG2 BXRC-xxx400x-B-8x-SE BXRC-xxx400x-C-8x-SE BXRC-xxx400x-D-8x-SE Notes for Table 5: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1980 lx. 3. For products classified as RG2 at 5000K Ethr= 1530 lx. 4. For products classified as RG2 at 6500K, Ethr= 1170 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 17 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRC-xxx400x-B-8x-SE BXRC-xxx400x-C-8x-SE BXRC-xxx400x-D-8x-SE Maximum Drive Current3 2000 mA 3000 mA 2500 mA Maximum Peak Pulsed Drive Current4 2240 mA 3360 mA 2800 mA Maximum Reverse Voltage5 -60V -60V -50V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN121: Assembly Considerations for Bridgelux Vero SE LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 18 Performance Curves Figure 1: Vero SE 18B Drive Current vs. Voltage Figure 2: Vero SE 18C Drive Current vs. Voltage 38.0 38.0 37.0 36.0 Voltage (V) Voltage (V) 37.0 35.0 34.0 36.0 35.0 34.0 33.0 33.0 32.0 32.0 0 250 500 750 1000 1250 1500 1750 2000 0 2250 500 1000 Drive Current (mA) 2000 2500 3000 3500 Figure 4: Vero SE 18B Typical Relative Flux vs. Current Figure 3: Vero SE 18D Drive Current vs. Voltage 32.0 300% Relative Luminous Flux (%) 31.5 31.0 30.5 Voltage (V) 1500 Drive Current (mA) 30.0 29.5 29.0 28.5 28.0 27.5 250% 200% 150% 100% 50% 27.0 0% 26.5 0 500 1000 1500 2000 2500 0 3000 250 Figure 5: Vero SE 18C Typical Relative Flux vs. Current 750 1000 1250 1500 1750 2000 2250 Figure 6 Vero SE 18D Typical Relative Flux vs. Current 300% Relative Luminous Flux (%) 300% Relative Luminous Flux (%) 500 Drive Current (mA) Drive Current (mA) 250% 200% 150% 100% 50% 250% 200% 150% 100% 50% 0% 0% 0 500 1000 1500 2000 Drive Current (mA) 2500 3000 3500 0 500 1000 1500 2000 2500 3000 Drive Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 19 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature 102% 0.0010 100% 0.0000 -0.0010 98% -0.0020 96% ccy shift Relative Luminous Flux Figure 7: Typical DC Flux vs. Case Temperature 94% 92% -0.0030 -0.0040 -0.0050 90% -0.0060 88% -0.0070 0 20 40 60 80 100 120 0 20 Case Temperature (Tc) 60 80 100 120 Case Temperature (Tc) Figure 10: Derating Curve Figure 9: Typical DC ccx Shift vs. Case Temperature 0.0020 3500 25C Pulsed 0.0000 40 Drive Current (mA) 3000 ccx shift -0.0020 -0.0040 -0.0060 -0.0080 2500 2000 1500 1000 BXRC-xxx400x-C-8x-SE 500 0 -0.0100 0 20 40 60 80 Case Temperature (Tc) 100 120 0 20 40 60 80 Case Temperature (Tc) 100 120 20 Typical Radiation Pattern Figure 11: Typical Spatial Radiation Pattern Note for Figure 11: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 12: Typical Polar Radiation Pattern 21 Typical Color Spectrum Figure 13: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 13: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. 22 Mechanical Dimensions Figure 14: Drawing for Vero SE 18 LED Array Notes for Figure 14: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array 23 Color Binning Information Figure 15: Warm and Neutral White Test Bins in xy Color Space 0.44 3 SDCM 2 SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 0.38 0.36 0.34 0.36 0.39 0.42 X 0.45 0.48 Note: Pulsed Test Conditions, Tc = 25°C Table 7: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 16: Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Table 8: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 84 (4 SDCM) (4801K - 5282K) (5481K - 5829K) (6270K - 6765K) 83 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 24 Packaging and Labeling Figure 17: Drawing for Vero SE 18 Packaging Tray Notes for Figure 17: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 25 Packaging and Labeling Figure 18: Vero SE Series Packaging and Labeling Notes for Figure 18: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 19: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 83 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin definitions. 26 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN121 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 27 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2020 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 Vero SE 18 Array Series Product Data Sheet DS432 Rev. A (06/2020) 28
物料型号:BM1000AS 器件简介:BM1000AS是一款高性能的电机驱动IC,专为电动汽车和工业电机设计,提供高效率和高可靠性。
引脚分配:该IC包含多种引脚,如电源引脚、地线引脚、控制引脚等,具体分配详见数据手册。
参数特性:包括但不限于工作电压范围、最大输出电流、工作温度范围等,详细参数请参考数据手册。
功能详解:BM1000AS具备多种功能,如过流保护、过温保护、短路保护等,具体功能介绍请查看详细文档。
应用信息:适用于电动汽车电机驱动、工业电机控制等领域。
封装信息:通常为QFN或DIP封装,具体封装类型和尺寸请参考数据手册。
BXRC-35E1000-B-83-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-35E1000-B-83-SE”相匹配的价格&库存,您可以联系我们找货
