BXRV-TR-1840G-06A0-B-25
    BRIDGELUX(普瑞)
BXRV-TR-1840G-06A0-B-25 数据手册
Bridgelux® Vesta® Series Tunable White Gen 2 6mm Array Product Data Sheet DS349 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the Vesta Series family of products. Fully engineered substrate for consistent thermal, mechanical and optical properties Polarity symbols Solder Pads (Cool White) Case Temperature (Tc) Measurement Point Solder Pads (Warm White) Designed to comply with global safety standards for creepage and clearance distances Product Nomenclature The part number designation for Bridgelux Vesta Series arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 BXRV TR – 2 750 G - 06A0 – B – 2 3 CCT Bin Options Product Family 3 = 3SDCM for 2700K/5000K/6500K 5 = 3SDCM for 4000K, and 5SDCM for 1800K Tunable White Array Nominal CCT 18 = 1800K 27 = 2700K 40 = 4000K 50 = 5000K 65 = 6500K Gen. 2 Minimum CRI G = 90 CRI Array Configuration B = 36V Form Factor Designator 06A0 = 6mm LES 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Measurement Data Part Number BXRV-TR-2750G 06A0-B-23 BXRV-TR-2765G-06A0-B-23 BXRV-TR-1840G-06A0-B-23 Nominal Drive Current Nominal CCT 1 Tc=85°C (K) Typical CRI 2 Tc=85°C per channel Typical Vf 3 Tc=25°C (V) Typical Power Tc=25°C (W) Typical Pulsed Flux 3, 4, 5 Tc=25°C (lm) (mA) Typical Efficacy 5 Tc=25°C (lm/W) Minimum Pulsed Flux 8 Tc=25°C (lm) Typical DC Flux 7, 8 Tc=85°C (lm) 2700 93 150 37 5.6 530 95 477 456 5000 92 150 37 5.6 610 110 549 519 2700 93 150 37 5.6 530 95 477 456 6500 92 150 37 5.6 615 111 554 523 1800 93 150 37 5.6 350 63 315 305 4000 92 150 37 5.6 580 105 522 499 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. For CRI 92-93 products, the minimum CRI value is 90 and the minimum R9 value is 50. Bridgelux maintains a ±3 tolerance on all R9 values. 3. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 4. Typical performance values are provided as a reference only and are not a guarantee of performance. 5. Bridgelux maintains a ±7% tolerance on flux measurements. 6. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 8. Minimum flux values at pulsed nominal test current are guaranteed by 100% test. 3 European Product Registry for Energy Labeling The European Product Registry for Energy Labeling (EPREL) is defined in the EU Regulation 2017/1369 to provide information about a product’s energy efficiency to consumers. Together with Energy Labeling Regulation ELR (EU) 2019/2015, which was amended by regulation (EU) 2021/340 for energy labelling of light sources, manufacturers are required to declare an energy class based on key technical specifications from each of their product and register it in an open data base managed by EPREL. It is now a legal requirement for a vendor of light sources to upload information about their products into the EPREL database before placing these products on the market in the EU. Table 2 provides a list of part numbers that are in compliance with EPREL regulations and are currently listed in the EPREL database. At Bridgelux, we are fully committed to supplying products that are compliant with pertinent laws, rules, and obligation imposed by relevant government bodies including the ELR regulation. Customers can use these products with full confidence for any projects that fall under the EPREL requirement. Table 2: Table of products registered in the European Product Registry for Energy Labeling (EPREL) Part Number CCT (K) CRI Current 3 (mA) Voltage 3 (V) Useful Flux 2 ØΦuseful Tc=85C (lm) Power (W) Efficacy (lm/W) Energy Efficiency Class 4 A G Registration No URL 1 X BXRV-TR-2750G-06A0-B-23 5000 90 200 36.33 653 7 89 G 876352 https://tinyurl.com/a6vzp34 BXRV-TR-2765G-06A0-B-23 6500 90 200 36.33 659 7 90 G 879088 https://tinyurl.com/4mbcrxzs BXRV-TR-1840G-06A0-B-23 4000 90 180 35.79 576 6 89 G 890639 https://tinyurl.com/p482bxcb Notes for Table 2: 1. The performance data in this table is a subset of the data that was submitted to EPREL for obtaining the energy class listed here. For accessing a complete set of technical documentation of Bridgelux registered products in the EPREL database, please visit one of the hyperlinks listed above. 2. For a definition of useful luminous flux (ØΦuseful), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 3. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 4. EPREL requires a symbol for displaying the energy classification of a product in marketing literature. This symbol consists of a letter stating a product’s energy efficiency class inside a specific arrow logo as defined by EPREL. 5. All products listed here must be disposed as e-waste according to the guidelines in the country in which the product is used. 4 Electrical Characteristics Table 3: Electrical Characteristics Part Number BXRV-TR-xxxxG06A0-B-23 Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 7 Typical Temperature Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Nominal Drive Current (mA) Minimum Typical Maximum 1800/2700 150 34.8 37.0 39.2 -10.6 4000K/5000/6500K 150 34.8 37.0 39.2 -11.1 CCT Typical Thermal Resistance Junction to Case5 Rj-c (ºC/W) 2.1 Driver Selection Voltages6 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 33.9 39.9 33.9 39.9 Notes for Table 3: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical temperature coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 6. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 7. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 500V. The working voltage designated for the insulation is 60V DC. The maximum allowable voltage across the array must be determined in the end product application. 5 Absolute Maximum Ratings Table 4: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds Maximum Combined Drive Current4 200mA Channel 1 1800K/2700K Channel 2 4000K/5000K/6500K Maximum Drive Current Per Channel3,4 200mA 200mA Maximum Peak Pulsed Drive Current Per Channel5 240mA 240mA Maximum Total Power 7.4W Notes for Table 4: 1. For IEC 62717 requirement, please contact Bridgelux Sales Support. 2. See Bridgelux Application Note AN101 for more information. 3. Lumen maintenance and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report. Contact your Bridgelux sales representatives for the LM-80 report. 4. The maximum combined drive current is the sum of the currents in both channels. For example, if 200mA is applied to the 1800K/2700K channel, no current may be applied to the 4000K/5000K/6500K channel of the array. If 150mA is applied to the 1800K/2700K channel, then a maximum of 50mA can be applied to the 4000K/5000K/6500K channel. 5. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20ms when operating LED arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 6 Performance Curves Figure 1: Forward Voltage vs. Forward Current, Tc=25°C Figure 2: Relative Flux vs. Drive Current, Tc=25°C 250 140% 120% Relative LOP (%) Current (mA) 200 150 100 4000K, 5000K, 6500K 50 1800K, 2700K 100% 80% 60% 40% 4000K, 5000K, 6500K 20% 0 1800K, 2700K 0% 30 32 34 36 38 0 50 100 Voltage (V) Figure 3: Relative Voltage vs. Case Temperature 200 250 Figure 4: Relative Light Output vs. Case Temperature 105% 101% 4000K, 5000K, 6500K 101% 5000K/6500K 100% 1800K, 2700K 100% Relative LOP (%) Relative Voltage (%) 150 Current (mA) 100% 99% 99% 98% 2700K 95% 90% 85% 98% 97% 5 25 45 65 85 105 125 Case Temperature (˚C) 80% 5 25 45 65 85 105 125 Case Temperature (˚C) Figure 5: Relative Light Output vs. Case Temperature 105% 3000K 4000K Relative LOP (%) 100% 1800K 1800K 95% 90% 85% 80% 5 25 45 65 85 105 125 Case Temperature (˚C) 7 Performance Curves Figure 6: CCT vs. Relative Warm White Current Figure 7: CCT vs. Relative Warm White Current 7000 6000 6000 CCT (K) CCT (K) 5000 4000 3000 5000K 4000 3000 2000 2000 2700K 5000 0.0 0.0 1.0 0.2 0.8 0.4 0.6 0.6 0.4 Relative Current Relative Current 0.8 0.2 1.0 0.0 0.8 0.8 0.2 1.0 1.0 0.0 2700K 6500K 0.0 0.0 1.0 0.2 0.2 0.8 0.4 0.6 0.4 0.6 0.6 0.4 Relative Current Relative Current 0.8 0.2 1.0 1.0 0.0 Figure 8: CCT vs. Relative Current, Tc=85C BXRV-TR-1840G-06A0-B-25 4000 3800 3600 3400 CCT (K) 3200 3000 2800 2600 2400 2200 2000 1800 1800K 4000K 0.0 0.0 1.0 0.2 0.2 0.8 0.4 0.4 0.6 0.6 WW 0.6 Current Ratio 0.4 Relative Current 8 Performance Curves Figure 9: Relative Flux vs. Relative Current Figure 10: Relative Flux vs. Relative Current BXRV-TR-27xxG-06A0-B-23 100% 98% 100% 95% 94% Relative Flux (%) Relative Flux (%) 96% 92% 90% 88% 86% 85% 80% 75% 84% 82% 65% 80% 5000/6500K 60% 0.0 0.0 1.0 0.2 0.2 0.8 0.4 0.6 0.4 0.6 WW 0.6 Current Ratio 0.4 Relative Current 0.8 0.8 1.0 1.0 0.0 0.2 1800K 4000K 0.2 0.2 0.8 0.4 0.4 0.6 0.6 WW 0.6 Current Ratio 0.4 0.8 0.8 0.2 Relative Current 1.0 1.0 0.0 0.410 0.420 2700K 0.400 2700K 0.390 0.400 0.380 ccy 0.380 0.360 5000K 0.370 0.360 0.350 0.340 0.320 0.300 0.330 1.0 0.420 0.440 0.340 0.0 0.0 Figure 12: CCT Tuning Range, Tc=85 Figure 11: CCT Tuning Range, Tc=85 ccy 90% 70% 2700K BXRV-TR-1840G-06A0-B-25 105% 6500K 0.330 0.350 0.370 0.390 0.410 0.430 0.450 0.470 ccx 0.320 0.300 0.350 0.400 ccx 0.450 0.500 Figure 13: CCT Tuning Range, Tc=85 0.420 0.410 1800K 0.400 0.390 ccy 0.380 4000K 0.370 0.360 0.350 0.340 0.330 0.320 0.300 0.350 0.400 0.450 0.500 0.550 ccx 9 Typical Radiation Pattern Figure 14: Typical Spatial Radiation Pattern 100% 90% Relative Intensity (%) 80% 70% 60% 50% 40% 30% 20% 10% 0% -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 Angular Displacement (⁰) 30 40 50 60 70 80 90 Notes for Figure 14: 1. Typical viewing angle is 130⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 15: Typical Polar Radiation Pattern -30⁰ -15⁰ 15⁰ 30⁰ 100% 90% -45⁰ 80% 45⁰ 70% 60% -60⁰ 50% 60⁰ 40% 30% -75⁰ 20% 75⁰ 10% -90⁰ 0% 90⁰ 10 Typical Color Spectrum Figure 16: 2700K - 6500K with 90 CRI 1.2 Relative Spectral Power Distribution (%) 2700K 3000K 1.0 4000K 5000K 0.8 6500K 0.6 0.4 0.2 0.0 380 430 480 530 580 Wavelength (nm) 630 680 730 780 Note for Figure 16: 1. Color spectra measured at nominal current and Tc = 25°C. Figure 17: 2700K - 5000K with 90 CRI Relative Spectral Power Distribution (%) 1.2 2700K 3000K 4000K 5000K 1.0 0.8 0.6 0.4 0.2 0.0 380 430 480 530 580 Wavelength (nm) 630 680 730 780 Note for Figure 17: 1. Color spectra measured at nominal current and Tc = 25°C. Figure 18: 1800K - 4000K with 90 CRI Normalized Intensity (%) 120% 1800K 100% 4000K 80% 60% 40% 20% 0% 380 480 580 680 780 Wavelength (nm) Note for Figure 18: 1. Color spectra measured at nominal current and Tc = 25°C. 11 Mechanical Dimensions Figure 19: Mechanical Drawing Specifications Notes for Figure 19: 1. Solder pads are labeled “+” to denote positive polarity and “-” to denote negative polarity. Solder pads have a gold surface finish. 2. Drawings are not to scale. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, tolerances are ± 0.10mm. 5. The optical center of the LED array is nominally defined by the mechanical center of the array. 6. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes for product handling, mounting and heat sink recommendations. 12 Color Binning Information Figure 20: Graph of Bins in xy Color Space, Tc=85C 0.460 0.440 0.420 Blackbody Curve 2700K 0.400 1800K 3000K ccy 0.380 4000K 0.360 5000K 0.340 6500K 0.320 0.300 0.300 0.350 0.400 0.450 0.500 0.550 ccx Table 5: McAdam ellipse CCT color bin definitions for product operating at Tc = 85ºC CCT Center Point Bin Size Axis a Axis b Rotation Angle 2700K x=0.4578 y= 0.4101 3 SDCM 0.00810 0.00420 53.70º 5000K x=0.3447 y=0.3553 3 SDCM 0.00822 0.00354 59.62º 6500K x=0.3123 y=0.3282 3 SDCM 0.00690 0.00285 58.57º 1800K x=0.5496 y=0.4081 5SDCM 0.01164 0.00655 40.00º 4000K x=0.3818 y=0.3797 3SDCM 0.00939 0.00402 53.72º Notes for Table 5: 1. The x,y center points are the center points of the respective ANSI bins in the CIE 1931 xy Color Space 2. Products are binned at Tc=85°C 3. Bridgelux maintains a tolerance of +/-0.007 on x and y color coordinates in the CIE 1931 Color Space Figure 21: Definition of the McAdam ellipse a b φ x, y, center point 13 Packaging and Labeling Figure 22: Vesta Series Tunable White 6mm Packaging and Labeling NTW6 Packaging 40EA/Tube 8,30 14,30 14,30 530.00 Tube label BXRV-TR-2750G-06A0-B-23 40 23 Bag label Box label BXRV-TR-2750G-06A0-B-23 BXRV-TR-2750G-06A0-B-23 23 23 800 160 200mA Notes for Figure 22: 1. Each tube holds 40 Vesta Series Tunable White 6mm arrays. 2. Four tubes are sealed in an anti-static bag. The dimensions of an empty anti-static bag are 75.0 mm (W) x 615.0 mm (L) x 0.1 mm (T). 3. Up to five anti-static bags are placed in a shipping box. The dimensions of the shipping box are 58.7 mm (L) x 13.3 mm (W) x 7.9 mm (H) 4. Depending on quantities ordered, a bigger shipping box, containing four of the boxes outlined in item 3. will be used. 3. Each packaging unit contains a label as shown in the example above. Figure 23: Product Labeling Bridgelux arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 1830G06A 13 Internal Bridgelux use only. 14 Design Resources Application Notes 3D CAD Models Vesta Series Tunable White arrays are intended for use in dry, indoor applications. Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vesta Series product family of LED array products. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vesta Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Please contact your Bridgelux sales representative for more information. Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vesta Series is in accordance with IEC/TR62778 specification ‘IEC 62471 for the assessment of blue light hazard to light source and luminaires’. Vesta Series Tunable White arrays are classified as Risk Group 1 when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the Vesta Series LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the Vesta Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vesta Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, array testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 15 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux WeChat ID: BridgeluxInChina 46410 Fremont Blvd Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved 2021. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vesta are registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vesta Series Tunable White Gen 2 6mm Array Product Data Sheet DS349 Rev. C (08/2021) 16
BXRV-TR-1840G-06A0-B-25 价格&库存
很抱歉,暂时无法提供与“BXRV-TR-1840G-06A0-B-25”相匹配的价格&库存,您可以联系我们找货
