BXEB-L0570A-40E3000-E-C3
    BRIDGELUX(普瑞)
BXEB-L0570A-40E3000-E-C3 数据手册
Bridgelux® EB SeriesTM Modules Product Data Sheet DS130 BXEB-LXXXXZ-30xx000 | 35xx000 | 40xx000 | 50xx000 | 57xx000 EB Series Introduction EB Series linear modules are designed for linear troffers, pendants and other luminaires in indoor commercial and industrial applications. Available in 280 mm, 560 mm, and 1120 mm lengths, the modules can be connected end-to-end thereby providing flexibility in designing luminaires. The Zhaga compatible modules further simplify design by providing easy mounting options, reusable poke-in connectors and by being compatible with a variety of off-the-shelf optics. The modules have long lifetimes of greater than 50,000 hours and are backed by a 5-year warranty. Features • • • High efficacy, up to 159 lm/W and wide lumen range with 2x overdrive capability Benefits • No separate heat sinking required • Lumen output of up to 2270 lm, 4450 lm, and 8900 lm for 280 mm, 560 mm and 1120 mm modules. Reliable use at elevated currents enables greater design flexibility • Designed following Zhaga Book 7 standards L28W2 and L56W2 Easy installation using mounting holes and connectors • Long lifetime of > 50000 hours • High quality, true color reproduction • Easy, automated wiring enabled by poke-in connectors • 5 year limited warranty • Available in a variety of color temperatures (3000K-5700K) • Energy Star / ANSI compliant 3 SDCM color binning structure Contents Product Feature Map 4 Product Nomenclature 4 Product Selection Guide 5 Performance at Commonly Used Drive Currents 6 Electrical Characteristics 9 Absolute Maximum Ratings 10 Performance Curves 11 Typical Radiation Pattern 14 Typical Color Spectrum 15 Mechanical Dimensions 16 Color Binning Information 18 Packaging and Labeling 19 Design Resources 20 Precautions 20 Disclaimers 20 About Bridgelux 21 3 Product Feature Map EB Series modules are engineered to enable exceptional design flexibility and added value for an assortment of commercial and industrial applications. The modules incorporate several features such as reusable connectors, optic mounting holes and solder pads to simplify design and assembly, and to ensure superior reliability. Optic mounting holes Zhaga compatible mounting holes Re-usable connector Tc3 Tc2 Case Temperature Measurement Points Tc1 Designed to comply with global safety standards for creepage and clearance distances Solder Pad Note: Label containing part number and lot codes is attached on the front of the module. Product Nomenclature Part number designation for Bridgelux EB Series modules is explained as follows: 1 2 3 4 - 5 6 7 8 9 10 - 11 12 13 14 15 16 - 1 7 – 18 BXEB – L0280Z – 30 E 1000 – C – A3 Product Family Nominal Dimensions L= Length 0280 = 280 mm 0560 = 560 mm 1120 = 1120 mm Z= Zhaga compatible width (24 mm) CCT Bin Options A = Version 3 = 3 SDCM Module Configuration Nominal CCT 30 = 3000 K 35 = 3500 K 40 = 4000 K 50 = 5000 K 57 = 5700 K Minimum CRI E = 80 Nominal Flux 1000 = 1000 lm 2000 = 2000 lm 4000 = 4000 lm 4 Product Selection Guide The following product configurations are available: Table 1a: Selection Guide, Pulsed Measurement Data for 280 mm, L0280 modules ( Tc2 = 50 °C) Nominal Drive Current (mA) Typical Flux3,4 80 350 1205 80 350 1205 4000 80 350 5000 80 350 80 350 Nominal CCT1 (K) CRI2 BXEB-L0280Z-30E1000-C-A3 3000 BXEB-L0280Z-35E1000-C-A3 3500 BXEB-L0280Z-40E1000-C-A3 BXEB-L0280Z-50E1000-C-A3 BXEB-L0280Z-57E1000-C-A3 5700 Part Number Tc2 Minimum Flux4,5 Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 1085 22.1 7.7 156 1085 22.1 7.7 156 1230 1107 22.1 7.7 159 1230 1107 22.1 7.7 159 1230 1107 22.1 7.7 159 Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) = 50º C (lm) = 50º C Tc2 (lm) Table 1b: Selection Guide, Pulsed Measurement Data for 560 mm, L0560 modules ( Tc2 = 50 °C) Nominal Drive Current (mA) Typical Flux3,4 80 700 2410 2169 22.1 15.5 156 80 700 2410 2169 22.1 15.5 156 4000 80 700 2460 2214 22.1 15.5 159 BXEB-L0560Z-50E2000-C-A3 5000 80 700 2460 2214 22.1 15.5 159 BXEB-L0560Z-57E2000-C-A3 5700 80 700 2460 2214 22.1 15.5 159 Nominal CCT1 (K) CRI2 BXEB-L0560Z-30E2000-C-A3 3000 BXEB-L0560Z-35E2000-C-A3 3500 BXEB-L0560Z-40E2000-C-A3 Part Number Tc2 = 50º C (lm) Minimum Flux4,5 Tc2 = 50º C (lm) Table 1c: Selection Guide, Pulsed Measurement Data for 1120 mm, L1120 modules ( Tc2 = 50 °C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current (mA) Typical Flux3,4 Tc2 = 50º C (lm) Minimum Flux4,5 Tc2 = 50º C (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXEB-L1120Z-30E4000-C-A3 3000 80 700 4820 4338 44.2 31.0 156 BXEB-L1120Z-35E4000-C-A3 3500 80 700 4820 4338 44.2 31.0 156 BXEB-L1120Z-40E4000-C-A3 4000 80 700 4920 4428 44.2 31.0 159 BXEB-L1120Z-50E4000-C-A3 5000 80 700 4920 4428 44.2 31.0 159 BXEB-L1120Z-57E4000-C-A3 5700 80 700 4920 4428 44.2 31.0 159 Notes for Tables 1a, 1b and 1c: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. 3. Products tested at nominal test current where temperature of center case temperature point Tc2= 50° C. Two other measurement points Tc1 and Tc3 are provided for reference only. Values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 4. Bridgelux maintains a ± 7% tolerance on flux measurements. 5. Minimum performance values are provided as reference only and are not a guarantee of performance. 5 Performance at Commonly Used Drive Currents EB Series modules are tested to the specifications shown using the nominal drive currents in Tables 1a-1c. EB Series may also be driven at other drive currents depending on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1-3 and the flux vs. current characteristics shown in Figures 4-5. The performance at commonly used drive currents is summarized in Tables 2a-2c. Table 2a: Product Performance at Commonly Used Drive Currents for 280 mm, L0280 modules Drive Part Number CRI 1 Current (mA) 100 BXEB-L0280Z-30E1000-C-A3 BXEB-L0280Z-35E1000-C-A3 BXEB-L0280Z-40E1000-C-A3 BXEB-L0280Z-50E1000-C-A3 BXEB-L0280Z-57E1000-C-A3 80 80 80 80 80 Typical Vf Tc2 = 50º C (V) 21.0 Typical Typical Power Tc2 = 50º C (W) Flux2 Tc2 2.1 = 50º C (lm) 349 Typical Efficacy Tc2 = 50º C (lm/W) 166 200 21.5 4.3 704 164 350 22.1 7.7 1205 156 500 22.7 11.3 1667 147 700 23.3 16.3 2223 136 100 21.0 2.1 349 166 200 21.5 4.3 704 164 350 22.1 7.7 1205 156 500 22.7 11.3 1667 147 700 23.3 16.3 2223 136 100 21.0 2.1 356 170 200 21.5 4.3 719 167 350 22.1 7.7 1230 159 500 22.7 11.3 1702 150 700 23.3 16.3 2269 139 100 21.0 2.1 356 170 200 21.5 4.3 719 167 350 22.1 7.7 1230 159 500 22.7 11.3 1702 150 700 23.3 16.3 2269 139 100 21.0 2.1 356 170 200 21.5 4.3 719 167 350 22.1 7.7 1230 159 500 22.7 11.3 1702 150 700 23.3 16.3 2269 139 Notes for Table 2a: 1. Alternate drive currents in Table 2 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 6 Performance at Commonly Used Drive Currents Table 2b: Product Performance at Commonly Used Drive Currents for 560 mm, L0560 modules Drive Part Number BXEB-L0560Z-30E2000-C-A3 BXEB-L0560Z-35E2000-C-A3 BXEB-L0560Z-40E2000-C-A3 BXEB-L0560Z-50E2000-C-A3 BXEB-L0560Z-57E2000-C-A3 CRI 80 80 80 80 80 1 Current (mA) Typical Vf Tc2 = 50º C (V) Typical Power Tc2 = 50º C (W) Typical Flux2 Tc2 = 50º C (lm) Typical Efficacy Tc2 = 50º C (lm/W) 200 21.0 4.2 706 168 500 21.7 10.9 1759 162 700 22.1 15.5 2410 156 1000 22.7 22.7 3309 146 1400 23.3 32.6 4362 134 200 21.0 4.2 706 168 500 21.7 10.9 1759 162 700 22.1 15.5 2410 156 1000 22.7 22.7 3309 146 1400 23.3 32.6 4362 134 200 21.0 4.2 721 171 500 21.7 10.9 1796 165 700 22.1 15.5 2460 159 1000 22.7 22.7 3377 149 1400 23.3 32.6 4452 137 200 21.0 4.2 721 171 500 21.7 10.9 1796 165 700 22.1 15.5 2460 159 1000 22.7 22.7 3377 149 1400 23.3 32.6 4452 137 200 21.0 4.2 721 171 500 21.7 10.9 1796 165 700 22.1 15.5 2460 159 1000 22.7 22.7 3377 149 1400 23.3 32.6 4452 137 Notes for Table 2b: 1. Alternate drive currents in Table 2 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 7 Performance at Commonly Used Drive Currents Table 2c: Product Performance at Commonly Used Drive Currents for 1120 mm, L1120 modules Drive Part Number BXEB-L1120Z-30E4000-C-A3 BXEB-L1120Z-35E4000-C-A3 BXEB-L1120Z-40E4000-C-A3 BXEB-L1120Z-50E4000-C-A3 BXEB-L1120Z-57E4000-C-A3 CRI 80 80 80 80 80 1 Current (mA) Typical Vf Tc2 = 50º C (V) Typical Typical Power Tc2 = 50º C (W) Flux2 Tc2 = 50º C (lm) Typical Efficacy Tc2 = 50º C (lm/W) 200 42.1 8.4 1412 168 500 43.4 21.7 3519 162 700 44.2 31.0 4820 156 1000 45.3 45.3 6617 146 1400 46.5 65.2 8724 134 200 42.1 8.4 1412 168 500 43.4 21.7 3519 162 700 44.2 31.0 4820 156 1000 45.3 45.3 6617 146 1400 46.5 65.2 8724 134 200 42.1 8.4 1441 171 500 43.4 21.7 3592 165 700 44.2 31.0 4920 159 1000 45.3 45.3 6754 149 1400 46.5 65.2 8905 137 200 42.1 8.4 1441 171 500 43.4 21.7 3592 165 700 44.2 31.0 4920 159 1000 45.3 45.3 6754 149 1400 46.5 65.2 8905 137 200 42.1 8.4 1441 171 500 43.4 21.7 3592 165 700 44.2 31.0 4920 159 1000 45.3 45.3 6754 149 1400 46.5 65.2 8905 137 Notes for Table 2c: 1. Alternate drive currents in Table 2 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 8 Electrical Characteristics Table 3: Electrical Characteristics Forward Voltage Tc2 Part Number Driver Selection Typical Coefficient of Forward = 50º C (V) 1, 2,3 Drive Current (mA) Voltages5 (V) Voltage4 Minimum Typical Maximum ∆Vf/∆T (mV/º C) Vf Min, Hot Tc2 = 85º C (V) Vf Max, Cold Tc2 = -40º C (V) 350 20.5 22.1 24.8 -9.5 20.2 25.6 700 21.6 23.3 26.1 -9.5 21.3 27.0 700 20.5 22.1 24.8 -9.5 20.2 25.6 1400 21.6 23.3 26.1 -9.5 21.3 27.0 700 41.0 44.2 49.5 -19.0 40.4 51.2 1400 43.2 46.5 52.1 -19.0 42.5 53.8 BXEB-L0280Z-xxx1000-C-A3 BXEB-L0560Z-xxx2000-C-A3 BXEB-L1120Z-xxx4000-C-A3 Notes for Table 3: 1. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a tolerance of ± 0.10 V on forward voltage measurements. 3. This product has been designed and manufactured per IEC 62031:2014. The working voltage designated for the insulation is 48 V d.c. The maximum allowable voltage across the module must be determined in the end product application. 4. Typical coefficient of forward voltage tolerance is ± 0.1 mV for nominal current. 5. Vf min hot and max cold values are provided as reference only and are not guaranteed. These values are provided to aid in driver design and selection over the operating range of the product. 9 Absolute Maximum Ratings Table 4: Absolute Maximum Ratings Parameter Maximum Rating Storage Temperature -40 °C to +85 °C Operating Case Temperature1 (Tc) 85 °C Soldering Temperature2 350 °C or lower for a maximum of 5 seconds Maximum Drive Current3 700 mA for L0280 modules 1400 mA for L0560 and L1120 modules Maximum Reverse Voltage EB Series modules are not designed to be driven in reverse bias Notes for Table 4: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Design Guide for handling EB Series linear modules. 3. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the SMDs used in the modules. Contact your Bridgelux sales representatives for LM-80 report. 10 Performance Curves Figure 1: Drive Current vs. Voltage (Tc2 = 50°C) for L0280 modules 800 700 Current (mA) 600 500 400 300 200 100 0 20 21 22 23 24 Forward Voltage (V) Figure 2: Drive Current vs. Voltage (Tc2 = 50°C) for L0560 modules 1600 1400 Current (mA) 1200 1000 800 600 400 200 0 20 21 22 23 24 Forward Voltage (V) 11 Performance Curves Figure 3: Drive Current vs. Voltage (Tc2 = 50°C) for L1120 modules 1600 1400 Current (mA) 1200 1000 800 600 400 200 0 41 42 43 44 45 46 47 Forward Voltage (V) Figure 4: Typical Relative Luminous Flux vs. Drive Current (Tc2 = 50°C) for L0280 modules 200% 180% 160% Relative Flux 140% 120% 100% 80% 60% 40% 20% 0% 0 100 200 300 400 500 600 700 800 Current (mA) 12 Performance Curves Figure 5: Typical Relative Luminous Flux vs. Drive Current (Tc2 = 50°C) for L0560 and L1120 modules 200% 180% 160% Relative Flux 140% 120% 100% 80% 60% 40% 20% 0% 0 200 400 600 800 1000 1200 1400 1600 Current (mA) Figure 6: Typical DC Flux vs. Case Temperature (Tc2) 108% 106% Relative Flux 104% 102% 100% 98% 96% 94% 92% 0 10 20 30 40 50 60 70 80 90 Case Temperature Tc2 (°C) 13 Typical Radiation Pattern Figure 7: Typical Spatial Radiation Pattern 120% Relative Intensity 100% 80% 60% 40% 20% 0% -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (°) Note for Figure 7: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is 50% of the peak value. 14 Typical Color Spectrum Figure 8: Typical Color Spectrum 120% 30E Relative Intensity 100% 40E 57E 80% 60% 40% 20% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 8: 1. Color spectra measured at nominal current for Tc2 = 50°C. 2. Color spectra shown for 30E is 3000K and 80 CRI. 3. Color spectra shown for 40E is 4000K and 80 CRI. 4. Color spectra shown for 57E is 5700K and 80 CRI. 15 Mechanical Dimensions Figure 9: Drawing for L0280 module Table 5: Dimensions for L0280 module Parameter Specification Tolerance Unit Module length 280 ± 0.3 mm Module width 24 ±0.2 mm Module thickness 6.1 ±0.2 mm PCB thickness 1.6 ±0.16 mm Figure 10: Drawing for L0560 module Table 6: Dimensions for L0560 module Parameter Specification Tolerance Unit Module length 560 ± 0.3 mm Module width 24 ±0.2 mm Module thickness 6.1 ±0.2 mm PCB thickness 1.6 ±0.16 mm 16 Mechanical Dimensions Figure 11: Drawing for L1120 module Table 7: Dimensions for L1120 module Parameter Specification Tolerance Unit Module length Module width 1120 ±1 mm 24 ±0.2 mm Module thickness 6.1 ±0.2 mm PCB thickness 1.6 ±0.16 mm Notes for Figures 9,10 and 11: 1. Solder pads are labeled “+” and “-“ to denote positive and negative polarity, respectively. 2. Drawings are not to scale. 3. Drawing dimensions are in millimeters. 4. Tolerances for certain dimensions are provided. Tolerances for all other dimensions are listed in drawings for EB Series modules on the Bridgelux website. 5. Holes for mounting optics are 4.5 mm in diameter and shall only use insulated screws or washer plugs minimum 1.0 mm thick on the surface of the PCB. Table 8: Connector and wiring Parameter Specification Input wire cross-section 24-18 AWG Terminal strip length 7-9 mm 17 Color Binning Information Figure 12: Graph of Warm and Neutral White Test Bins in xy Color Space Table 9: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 3000K 3500 K 4000K ANSI Bin (for reference only) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) A3 (3SDCM) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) Center Point (x,y) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 13: Graph of Cool White Test Bins in xy Color Space Table 10: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5700K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) A3 (3SDCM) (4835K - 5155K) (5445K - 5850K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) Notes for Tables 9 and 10 1. Color binning at solder point temperature Tsp of SMDs at 85°C. 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. 18 Packaging and Labeling Figure 14: EB Series Packaging and Labeling Table 11: Packaging Structure L0280 modules Tray Box Shipping Box Quantity 40 200 400 Dimension 63 cm x 39 cm x 2.4 cm 63.5 cm x 41.5 cm x 13.5 cm 134 cm x 43.5 cm x 18 cm Quantity 20 100 200 Dimension 63 cm x 39 cm x 2.4 cm 63.5 cm x 41.5 cm x 13.5 cm 134 cm x 43.5 cm x 18 cm Quantity 20 n/a 100 Dimension 119 cm x 39 cm x 2.4 cm n/a 134 cm x 43.5 cm x 18 cm L0560 modules L1120 modules Figure 15: Product Labeling Bridgelux EB Series modules contain a label on the front to help with product identification. In addition to the product identification markings, Bridgelux EB Series modules also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the module. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. 19 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with EB Series modules. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux EB Series modules are available in both IGES and STEP formats. Visit www.bridgelux.com for details. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the module. Please consult Bridgelux Application Note AN81 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux EB Series modules is in accordance with IEC specification TR 62778: Photobiological Safety of Lamps and Lamp Systems. EB Series modules are classified as Risk Group 1 ( Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the module or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the module. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the Bridgelux EB Series module except the optical area. Customers may use the optical mounting holes or edges of the module to locate and secure optical devices as needed but do not apply large bending forces on the edges of the module. Do not touch the EB Series module during operation. Allow the module to cool for a sufficient period of time before handling. EB Series modules may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, module testing is performed at the nominal drive current. 20 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux https://www.linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and EB Series are registered trademarks,. All other trademarks are the property of their respective owners. Bridgelux EB Series Product Data Sheet DS130 Rev. A (10/2016) 21
BXEB-L0570A-40E3000-E-C3 价格&库存
很抱歉,暂时无法提供与“BXEB-L0570A-40E3000-E-C3”相匹配的价格&库存,您可以联系我们找货
