BXRA-W1203-00000
BXRA-W1203-00000
    BRIDGELUX(普瑞)
BXRA-W1203-00000 数据手册
Bridgelux ES Array Series Product Data Sheet Introduction The Bridgelux family of LED Array products delivers high performance, compact and cost-effective solidstate lighting solutions to serve the general lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of many conventional lighting sources. The Bridgelux ES Array Series has been specified to enable lamp and luminaire designs surpassing efficacy and quality of light requirements driven by regulatory standards with reasonable system design margins, enabling lighting product compliance to Energy Star, Title 24, Part L and other global standards. The Bridgelux ES Array products provide a high performance alternative to conventional solid state solutions, delivering between 400 and 2000 lumens under application conditions in warm, neutral and cool white color temperatures. These compact high flux density light sources deliver uniform high quality illumination without pixilation or the multiple shadow effect caused by LED component based solutions. To simplify system design for appropriate light output, Bridgelux LED Arrays are specified to deliver performance under typical use conditions. These integrated plug and play solutions reduce system complexity and enable miniaturized costeffective lamp and luminaire designs. Lighting system designs incorporating these LED Arrays deliver comparable performance to that of 20-100 Watt incandescent and halogen, 7-42 Watt compact fluorescent, and 18-50 Watt HID based luminaires and feature increased system level efficacy and service life. Typical applications include replacement lamps, task, accent, spot, retail, track, down light, low bay, wide area, security, wall pack and street lighting. Features Benefits • Compact high flux density light source • Enhanced optical control • Uniform high quality illumination • Clean white light without pixilation • Streamlined thermal path • • Energy Star / ANSI compliant binning structure Significantly reduced thermal resistance and increased operating temperatures • Uniform consistent white light • Lower operating costs • Increased safety • Easy to use with daylight and motion detectors to enable increased energy savings • Reduced maintenance costs • Environmentally friendly, no disposal issues • More energy efficient than incandescent, halogen and fluorescent lamps • Low voltage DC operation • Instant light with unlimited dimming • Long operating life • RoHS compliant and Pb free 1 0 1 P o rt o l a A v e n u e , L i v e rm o re , C A 9 4 5 5 1 • T e l : (9 2 5 ) 5 8 3 -8 4 0 0 • Fa x: (9 2 5 ) 5 8 3 -8 4 0 1 • ww w. b ri d g e l u x. c o m Table of Contents Page Product Nomenclature 3 Average Lumen Maintenance Characteristics 3 Environmental Compliance 3 UL Recognition 4 Minor Product Change Policy 4 Cautionary Statements 4 Case Temperature Measurement Point 5 Flux Characteristics 6 Optical Characteristics 7 Electrical Characteristics 8 Absolute Minimum and Maximum Ratings 9 Typical Performance at Alternative Drive Currents 10 Mechanical Dimensions 13 Typical Radiation Pattern 15 Wavelength Characteristics at Rated Test Current, Tj=25°C 16 Typical Relative Luminous Flux vs. Current, Tj=25° C 18 Typical Light Output Characteristics vs. Temperature 21 Typical Chromaticity Characteristics vs. Temperature 22 Typical Forward Current Characteristics at Tj = 25°C 23 Current Derating Curves 29 Product Binning 35 Luminous Flux Binning Information 35 Color Binning Information 36 Mechanical Assembly and Handling 39 Product Packaging and Labeling 40 Packaging Tube Design 43 Design Resources 44 Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 2 of 45 Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRA–ABCDE–RRRRR Where: B X R A – designates product family A – designates color, C for Cool White, N for Neutral White and W for Warm White B C – designates LED Array product flux, 04 for a 400 lumen array, 08 for a 800 lumen array, 12 for a 1200 lumen array, and 20 for a 2000 lumen array D E – designates product family R R R R R – used to designate product options, 00000 by default The base product part number (BXRA-ABCDE) is indicated on each individual unit, printed on the bottom of the LED Array. Average Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation with case temperature maintained at or below 70°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Bridgelux LED Arrays are compliant to the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux will not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 3 of 45 UL Recognition Bridgelux product became UL Recognized on 31 March, 2010. Please refer to the UL file E333389. Bridgelux uses UL Recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 Driver to facilitate the UL listing process. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Contact with the resin area should be avoided. Applying stress to the resin area can result in damage to the product. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is contained in the CIE S 009/E2002 Photobiological Safety of Lamps and Lamp Systems specification. Bridgelux LED Arrays are classified under section 6 lamp classification as Risk Group 2 (Moderate Risk). Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. Luminaire manufacturers should refer to CIE S 009/E2002 to establish the classification of their product. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 4 of 45 Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Measuring the top surface of the product can lead to inaccurate results due to the poor thermal conductivity of the top layers of the array such as the solder mask and other materials. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 5 of 45 Flux Characteristics Table 1: Flux Characteristics Color Base Part Number Typical Luminous Flux фv (lm), [3] Tcase=60°C Minimum Luminous Flux фv (lm), [1] Tj=25°C Typical Luminous Flux фv (lm), Tj=25°C Test Current [2] (mA) BXRA-W0401 400 400 440 700 BXRA-W0402 420 400 460 700 BXRA-W0403 400 400 460 250 BXRA-W0802 850 800 930 1050 BXRA-W1202 1200 1200 1320 1200 BXRA-W1203 1240 1200 1370 1050 BXRA-N0402 400 400 440 600 BXRA-N0802 920 880 1020 1050 BXRA-N1203 1380 1380 1530 1050 BXRA-C0402 410 400 450 500 BXRA-C0603 560 560 620 250 BXRA-C0802 800 800 880 700 BXRA-C1202 1200 1200 1320 1050 BXRA-C2002 2000 2000 2200 1500 Warm White Neutral White Cool White Notes for Table 1: 1. Bridgelux maintains a ± 7% tolerance of flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Typical performance when driven with direct current using Bridgelux test set-up. Please contact a Bridgelux sales representative for additional details. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 6 of 45 Optical Characteristics Table 2: Optical Characteristics Color Temperature [1],[2],[3] (CCT) Color Warm White Neutral White Cool White Typical Viewing Angle (Degrees) [6] 2 θ½ Typical Center Beam Candle Power [5] (cd) BXRA-W0401 120 140 BXRA-W0402 120 145 120 145 BXRA-W0802 120 295 BXRA-W1202 120 420 BXRA-W1203 120 435 BXRA-N0402 120 140 120 325 BXRA-N1203 120 480 BXRA-C0402 120 145 BXRA-C0603 120 200 120 280 BXRA-C1202 120 420 BXRA-C2002 120 700 Base Part Number Min Typ Max Typical Color Rendering [4] Index BXRA-W0403 2850 K BXRA-N0802 BXRA-C0802 3700K 4750 K 3000 K 4100 K 5600 K 3700 K 4750K 7000 K 82 80 65 Notes for Table 2: 1. 2. 3. 4. 5. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Refer to Flux Characteristic Table for test current data. Product is binned for color in x y coordinates. Higher CRI options available upon request. Center beam candle power is a calculated value based on lambertian radiation pattern at nominal test current. 6. Viewing angle is the off axis angle from the centerline where Iv is ½ of the peak value. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 7 of 45 Electrical Characteristics Table 3: Electrical Characteristics Forward Voltage Vf [1],[2] (V) Color Warm White Neutral White Cool White Test Current [2] (mA) Typical Temperature Coefficient of Forward Voltage (mV/°C) ΔVf/ΔTj Typical Thermal Resistance Junction to Case (°C/W) RѲ j-c Base Part Number Min Typ Max BXRA-W0401 8.7 9.5 10.3 700 -3 to -9 1.0 BXRA-W0402 8.3 9.0 9.7 700 -3 to -9 1.0 BXRA-W0403 25.8 28.6 31.7 250 -9 to -27 1.0 BXRA-W0802 11.2 12.2 13.2 1050 -4 to -12 0.7 BXRA-W1202 13.9 15.1 16.3 1200 -5 to -15 0.5 BXRA-W1203 17.3 18.3 19.8 1050 -6 to -18 0.5 BXRA-N0402 8.4 8.9 9.7 600 -3 to -9 1.0 BXRA-N0802 11.2 12.2 13.2 1050 -4 to -12 0.7 BXRA-N1203 17.3 18.3 19.8 1050 -6 to -18 0.5 BXRA-C0402 8.7 9.5 10.3 500 -3 to -9 1.4 BXRA-C0603 25.8 28.6 31.7 250 -9 to -27 1.0 BXRA-C0802 11.7 12.7 13.7 700 -4 to -12 0.8 BXRA-C1202 11.8 12.8 13.8 1050 -4 to -12 0.7 BXRA-C2002 14.9 16.2 17.5 1500 -5 to -15 0.5 Notes for Table 3: 1. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 8 of 45 Absolute Minimum and Maximum Ratings Table 4: Minimum and Maximum Current and Reverse Voltage Ratings Part Number Maximum DC Forward Current (mA) Minimum DC Forward [2] Current (mA) Maximum Peak Pulsed [3] Current (mA) Maximum Reverse Voltage [1] (Vr) BXRA-W0401 1500 450 2100 -15 Volts BXRA-W0402 1500 450 2100 -15 Volts BXRA-W0403 500 150 700 -45 Volts BXRA-W0802 2000 600 2800 -20 Volts BXRA-W1202 2500 750 3500 -25 Volts BXRA-W1203 2000 600 2800 -30 Volts BXRA-N0402 1500 450 2100 -15 Volts BXRA-N0802 2000 600 2800 -20 Volts BXRA-N1203 2000 600 2800 -30 Volts BXRA-C0402 1000 300 1400 -15 Volts BXRA-C0603 500 150 700 -45 Volts BXRA-C0802 1500 450 2100 -20 Volts BXRA-C1202 2000 600 2800 -20 Volts BXRA-C2002 2500 750 3500 -25 Volts Notes for Table 4: 1. Light emitting diodes are not designed to be driven in reverse voltage. 2. Driving these high current devices at low currents can result in variations in performance. For low current operation pulse width modulation is recommended. 3. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature 3.5 seconds, 350°C or lower Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 9 of 45 Typical Performance at Alternative Drive Currents The Bridgelux LED Arrays are tested and binned against the specifications shown in Tables 1, 2 and 3. Customers also have options to drive the LED Arrays at alternative drive currents dependent on the specific application. The typical performance at any drive current can be derived from the flux vs. current characteristics shown in Figures 8-12 and from the current vs. voltage characteristics shown in Figures 16-27. The typical performance at common drive currents is also summarized in Table 6 for warm white products, Table 7 for neutral white products and Table 8 for cool white products. Table 6: Typical Product Performance at Alternative Drive Currents – Warm White Color Part Number BXRA-W0401 BXRA-W0402 BXRA-W0403 Warm White BXRA-W0802 BXRA-W1202 BXRA-W1203 Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) 290 325 9.2 500 400 440 9.5 700 560 620 9.9 1050 315 350 8.8 500 420 460 9.0 700 600 660 9.5 1050 270 300 27.3 150 410 460 28.6 250 560 620 29.7 350 430 480 11.4 500 580 640 11.7 700 850 930 12.2 1050 1050 1170 12.6 1400 740 820 14.4 700 1060 1180 14.9 1050 1200 1320 15.1 1200 1360 1510 15.4 1400 1640 1820 15.8 1750 630 700 17.1 500 860 960 17.6 700 1230 1370 18.3 1050 1570 1750 18.9 1400 [1] [1] [1] [1] [1] [1] Notes for Table 6: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Table 6, with a case temperature maintained at or below 70°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 10 of 45 Typical Performance at Alternative Drive Currents (continued) Table 7: Typical Product Performance at Alternative Drive Currents – Neutral White Color Part Number BXRA-N0402 BXRA-N0802 Neutral White Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) 330 370 8.8 500 400 440 8.9 600 450 500 9.0 700 470 525 11.4 500 640 710 11.7 700 920 1020 12.2 1050 1170 1300 12.6 1400 710 790 17.1 500 960 1070 17.6 700 1380 1530 18.3 1050 1750 1950 18.9 1400 [1] BXRA-N1203 [1] [1] Notes for Table 7: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Table 7, with a case temperature maintained at or below 70°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 11 of 45 Typical Performance at Alternative Drive Currents (continued) Table 8: Typical Product Performance at Alternative Drive Currents – Cool White Color Part Number BXRA-C0402 BXRA-C0603 BXRA-C0802 Cool White BXRA-C1202 BXRA-C2002 Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) 315 340 9.2 350 410 450 9.5 500 560 620 9.9 700 360 400 27.3 150 560 620 28.6 250 750 830 29.7 350 590 650 12.2 500 800 880 12.7 700 1120 1240 13.2 1050 830 920 12.3 700 1200 1320 12.8 1050 1510 1680 13.2 1400 1020 1130 15.1 700 1460 1620 15.6 1050 1850 2050 16.1 1400 2000 2200 16.2 1500 2270 2520 16.5 1750 [1] [1] [1] [1] [1] Notes for Table 8: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Table 8, with a case temperature maintained at or below 70°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 12 of 45 Mechanical Dimensions Figure 1: Drawing for 400 lumen product options (part numbers BXRA-C0402, BXRA-N0402, BXRA-W0401, BXRA-W0403, BXRA-W0402 and BXRA-C0603). Notes for Figure 1: 1. 2. 3. 4. 5. 6. 7. 8. 9. Slots are for M2.5 or #4 screws. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. Drawings are not to scale. Drawing dimensions are in millimeters. Bridgelux recommends two tapped holes for mounting screws with 19.20 ± 0.05mm center-tocenter spacing. Unless otherwise specified, tolerances are ± 0.10mm. Dimensions with parentheses “( )” are for reference only. Refer to product Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. The optical center of the LED Array is defined by the mechanical center of the array. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 13 of 45 Mechanical Dimensions (continued) Figure 2: Drawing for 800, 1200, and 2000 lumen product options (part numbers BXRA-C0802, BXRAW0802, BXRA-C1202, BXRA-W1202, BXRA-W1203, BXRA-N0802, BXRA-N1203 and BXRAC2002). Notes for Figure 2: 1. 2. 3. 4. 5. 6. 7. 8. 9. Mounting holes are for M2.5 or #4 screws. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. Drawings are not to scale. Drawing dimensions are in millimeters. Bridgelux recommends two tapped holes for mounting screws with 26.92 ± 0.10mm center-to-center spacing. Unless otherwise specified, tolerances are ± 0.10mm. Dimensions with parentheses “( )” are for reference only. Refer to product Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. The optical center of the LED Array is defined by the mechanical center of the array. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 14 of 45 Typical Radiation Pattern Figure 3: Typical Spatial Radiation Pattern Figure 4: Typical Polar Radiation Pattern Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 15 of 45 Wavelength Characteristics at Rated Test Current, Tj=25°C Figure 5: Typical Warm White Color Spectrum Figure 6: Typical Neutral White Color Spectrum Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 16 of 45 Wavelength Characteristics at Rated Test Current, Tj=25°C (continued) Figure 7: Typical Cool White Color Spectrum Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 17 of 45 Typical Relative Luminous Flux vs. Current, Tj=25° C Figure 8: Typical Flux vs. Current (400lm arrays) 2.60 2.40 Normalized Luminous Flux 2.20 2.00 1.80 1.60 1.40 1.20 1.00 BXRA-C0402 BXRA-W0401, BXRA-W0402 0.80 0.60 BXRA-N0402 0.40 0.20 0.00 0 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 2400 Current (mA) Figure 9: Typical Flux vs. Current Normalized Luminous Flux 2.60 2.40 2.20 2.00 1.80 1.60 1.40 1.20 1.00 0.80 BXRA-W0403 BXRA-C0603 0.60 0.40 0.20 0.00 0 100 200 300 400 500 600 700 Current (mA) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 18 of 45 Typical Relative Luminous Flux vs. Current, Tj=25° C (continued) Figure 10: Typical Flux vs. Current (800 lm Arrays) 2.60 2.40 Normalized Luminous Flux 2.20 2.00 1.80 1.60 1.40 1.20 1.00 BXRA-C0802 0.80 0.60 BXRA-N0802, BXRA-W0802 0.40 0.20 0.00 0 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 Current (mA) Figure 11: Typical Flux vs. Current (1200 lm Arrays) 2.60 2.40 Normalized Luminous Flux 2.20 2.00 1.80 1.60 1.40 BXRA-C1202, BXRA-N1203, BXRA-W1203 1.20 1.00 BXRA-W1202 0.80 0.60 0.40 0.20 0.00 0 250 500 750 1000 1250 1500 1750 2000 2250 2500 2750 3000 3250 3500 3750 Current (mA) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 19 of 45 Typical Relative Luminous Flux vs. Current, Tj=25° C (continued) Figure 12: Typical Flux vs. Current (2000 lm Arrays) 2.60 2.40 Normalized Luminous Flux 2.20 2.00 1.80 1.60 1.40 1.20 1.00 0.80 BXRA-C2002 0.60 0.40 0.20 0.00 0 250 500 750 1000 1250 1500 1750 2000 2250 2500 2750 3000 3250 3500 3750 Current (mA) Note for Figures 8 through 12: Bridgelux does not recommend driving high power LED Arrays at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 20 of 45 Typical Light Output Characteristics vs. Temperature Figure 11: Typical Typical Flux Fluxvs. vs.Junction JunctionTemperature Temperature Figure 13: 1.20 Normalized Luminous Flux 1.10 1.00 0.90 0.80 0.70 0.60 Cool White 0.50 Warm White 0.40 Neutral White 0.30 0.20 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, ºC Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 21 of 45 Typical Chromaticity Characteristics vs. Temperature Figure 12: Typical x Shift vs. Junction Temperature Figure 14: Typical x Shift vs. Junction Temperature 0.02 0.01 0.00 ∆x -0.01 -0.02 -0.03 Cool White -0.04 Neutral White Warm White -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, ºC Figure Temperature Figure13: 15: Typical Typical yy Shift Shift vs. vs. Junction Junction Temperature 0.02 0.01 0.00 ∆y -0.01 -0.02 -0.03 Cool White -0.04 Neutral White Warm White -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, ºC Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 22 of 45 Typical Forward Current Characteristics at Tj = 25°C Current (mA) Figure 16: Typical Current vs. Voltage, BXRA-C0402 1500 1400 1300 1200 1100 1000 900 800 700 600 500 400 300 200 100 0 8.5 8.7 8.9 9.1 9.3 9.5 9.7 9.9 10.1 10.3 10.5 10.7 10.9 11.1 Forward Voltage (V) Figure 17: Typical Current vs. Voltage, BXRA-N0402 2200 2000 1800 Current (mA) 1600 1400 1200 1000 800 600 400 200 0 8.2 8.4 8.6 8.8 9.0 9.2 9.4 9.6 9.8 10.0 10.2 10.4 10.6 10.8 Forward Voltage (V) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 23 of 45 Typical Forward Current Characteristics at Tj = 25°C (continued) Figure 18: Typical Current vs. Voltage, BXRA-W0401 2200 2000 1800 Current ( mA ) 1600 1400 1200 1000 800 600 400 200 0 8.6 8.8 9.0 9.2 9.4 9.6 9.8 10.0 10.2 10.4 10.6 10.8 11.0 11.2 10.4 10.6 10.8 Forward Voltage (V) Figure 19: Typical Current vs. Voltage, BXRA-W0402 2200 2000 1800 Current (mA) 1600 1400 1200 1000 800 600 400 200 0 8.2 8.4 8.6 8.8 9.0 9.2 9.4 9.6 9.8 10.0 10.2 Forward Voltage (V) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 24 of 45 Typical Forward Current Characteristics at Tj = 25°C (continued) Figure 20: Typical Current vs. Voltage, BXRA-W0403 and BXRA-C0603 800 700 600 500 400 300 200 100 0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 Forward Voltage (V) Figure 21: Typical Current vs. Voltage, BXRA-C0802 2200 2000 1800 Current ( mA ) 1600 1400 1200 1000 800 600 400 200 0 11.6 11.8 12.0 12.2 12.4 12.6 12.8 13.0 13.2 13.4 13.6 13.8 14.0 14.2 14.4 14.6 14.8 Forward Voltage (V) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 25 of 45 Typical Forward Current Characteristics at Tj = 25°C (continued) Current ( mA ) Figure 22: Typical Current vs. Voltage, BXRA-N0802 and BXRA-W0802 3000 2800 2600 2400 2200 2000 1800 1600 1400 1200 1000 800 600 400 200 0 11.2 11.4 11.6 11.8 12.0 12.2 12.4 12.6 12.8 13.0 13.2 13.4 13.6 13.8 14.0 14.2 Forward Voltage (V) Current ( mA ) Figure 23: Typical Current vs. Voltage, BXRA-C1202 3000 2800 2600 2400 2200 2000 1800 1600 1400 1200 1000 800 600 400 200 0 11.6 11.8 12.0 12.2 12.4 12.6 12.8 13.0 13.2 13.4 13.6 13.8 14.0 14.2 14.4 14.6 14.8 Forward Voltage (V) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 26 of 45 Current (mA) Figure 24: Typical Current vs. Voltage, BXRA-N1203, BXRA-W1203 3200 3000 2800 2600 2400 2200 2000 1800 1600 1400 1200 1000 800 600 400 200 0 16.8 17.2 17.6 18.0 18.4 18.8 19.2 19.6 20.0 20.4 20.8 21.2 Forward Voltage (V) Current ( mA ) Figure 25: Typical Current vs. Voltage, BXRA-W1202 3600 3400 3200 3000 2800 2600 2400 2200 2000 1800 1600 1400 1200 1000 800 600 400 200 0 14.0 14.2 14.4 14.6 14.8 15.0 15.2 15.4 15.6 15.8 16.0 16.2 16.4 16.6 16.8 17.0 17.2 17.4 17.6 Forward Voltage (V) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 27 of 45 Typical Forward Current Characteristics at Tj = 25°C (continued) Current ( mA ) Figure 26: Typical Current vs. Voltage, BXRA-C2002 3600 3400 3200 3000 2800 2600 2400 2200 2000 1800 1600 1400 1200 1000 800 600 400 200 0 14.6 14.8 15.0 15.2 15.4 15.6 15.8 16.0 16.2 16.4 16.6 16.8 17.0 17.2 17.4 17.6 17.8 18.0 18.2 18.4 Forward Voltage (V) Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 28 of 45 Current Derating Curves The graphs below illustrate the relationship between the system thermal resistance, drive current, and ambient temperature. Please note that absolute maximum ratings requirements, including that of maximum case temperature, must be adhered to in the system design. The thermal resistance values indicated in Figures 27-37 are total system values (junction to ambient) including the thermal resistance of the LED Array. Individual LED Array thermal resistance values are listed in Table 3. Figure 27: Derating Curve for BXRA-W0403 and BXRA-C0603, 250mA Drive Current If - Forward Current (mA) 300 250 200 150 10.0˚C/W 100 7.0˚C/W 50 5.0˚C/W 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature, C Figure 28: Derating Curve for BXRA-C0402, 500mA Drive Current If - Forward Current (mA) 600 500 400 300 10.0˚C/W 200 7.0˚C/W 100 5.0˚C/W 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature °C Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 29 of 45 Current Derating Curves (continued) Figure 29: Derating Curve for BXRA-N0402, 600mA Drive Current If - Forward Current (mA) 700 600 500 400 8.0˚C/W 300 6.0˚C/W 200 4.0˚C/W 100 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature, C If - Forward Current (mA) Figure 30: Derating Curve for BXRA-W0401, 700mA Drive Current 800 700 600 500 400 6.0˚C/W 300 4.0˚C/W 200 3.0˚C/W 100 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature ° C Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 30 of 45 Current Derating Curves (continued) If - Forward Current (mA) Figure 31: Derating Curve for BXRA-W0402, 700mA Drive Current 800 700 600 500 6.0˚C/W 400 4.0˚C/W 300 3.0˚C/W 200 100 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature ° C If - Forward Current (mA) Figure 32: Derating Curve for BXRA-C0802, 700mA Drive Current 800 700 600 500 5.0˚C/W 400 3.0˚C/W 300 200 2.0˚C/W 100 0 0 10 20 30 40 50 60 70 80 90 100 110 120 o Ta - Ambient Temperature C Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 31 of 45 Current Derating Curves (continued) Figure 33: Derating Curve for BXRA-W0802, BXRA-N0802, 1050mA Drive Current If - Forward Current (mA) 1400 1200 1000 800 4.0˚C/W 600 3.0˚C/W 400 1.5˚C/W 200 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature °C If - Forward Current (mA) Figure 34: Derating Curve for BXRA-C1202, 1050 mA Drive Current 1200 1000 800 4.0˚C/W 600 400 3.0˚C/W 200 1.5˚C/W 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature °C Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 32 of 45 Current Derating Curves (continued) Figure 35: Derating Curve for BXRA-N1203 and BXRA-W1203, 1050 mA Drive Current If - Forward Current (mA) 1200 1000 800 2.0˚C/W 600 1.5˚C/W 400 1.0˚C/W 200 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature, C Figure 36: Derating Curve for BXRA-W1202, 1200 mA Drive Current If - Forward Current (mA) 1400 1200 1000 800 2.0˚C/W 600 1.5˚C/W 400 1.0˚C/W 200 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature ° C Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 33 of 45 Current Derating Curves (continued) Figure 37: Derating Curve for BXRA-C2002, 1500 mA Drive Current 1600 If - Forward Current (mA) 1400 1200 1000 800 2.0˚C/W 600 1.5˚C/W 400 1.0˚C/W 200 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta – Ambient Temperature °C Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 34 of 45 Product Binning Typical manufacturing processes of semiconductor products result in a variation in performance surrounding the typical data sheet values. In order to minimize variation in the end product or application, Bridgelux bins its LED Arrays for luminous flux and color. Bridgelux LED Arrays are labeled using a 4-digit alphanumeric bin code. This bin code is printed on the back of each LED Array in the following format: ABCD Where: A – designates flux bin (P, Q, R etc.) B C – designates color bin (P3, P4, Q3, etc.) D – reserved for future product designations. All product packaged within a single tube are of the same flux and color bin combination (or bin code). Using these codes it is possible to determine the best product utilization to deliver the consistency required in a given application. Luminous Flux Binning Information The table below lists the standard photometric luminous flux bins for Bridgelux LED Arrays (tested and binned at the indicated test current). Although several bins are outlined, product availability in a particular bin varies by product and production run. Please contact your Bridgelux sales representative for further information regarding product availability. All production testing and binning (both flux and color binning) is conducted under pulsed test conditions at Tj = 25°C. Table 9: Luminous Flux Bins Bin Code C D E F Min Max Min Max 400 lm 440 lm 500 lm 560 lm Bin Code K L M N 360 lm 400 lm 440 lm 500 lm 800 lm 880 lm 1020 lm 1090 lm 880 lm 1020 lm 1090 lm 1200 lm G H J 560 lm 620 lm 720 lm 620 lm 720 lm 800 lm P Q R 1200 lm 1320 lm 1380 lm 1320 lm 1380 lm 1530 lm Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Bin Code S T U V Min Max 1530 lm 1740 lm 2000 lm 2200 lm 1740 lm 2000 lm 2200 lm 2450 lm W X 2450 lm 2700 lm 2700 lm 3000 lm Page 35 of 45 Color Binning Information Figure 38: Graph of Warm White Test Bins in xy Color Space 0.43 0.43 0.42 0.42 0.41 0.41 Q3 R3 R3 P3 P3 0.40 0.40 N3 N3 0.39 0.39 Q4 Q4 P4 P4 R4 N4 N4 37 32 65 0.36 0.36 70 28 45 34 10 K K 0.37 0.37 30 2 30 0 K 45 K K 0.38 0.38 R4 K Y Q3 0.35 0.35 0.38 0.38 0.40 0.40 0.42 0.42 0.44 0.44 X 0.46 0.46 X Table 10: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code N3 N4 P3 P4 X Y 0.3943 0.3996 0.4148 0.4083 0.3889 0.3943 0.4083 0.4018 0.4083 0.4148 0.4299 0.4223 0.3853 0.4015 0.4090 0.3921 0.3690 0.3853 0.3921 0.3752 0.3921 0.4090 0.4165 0.3990 0.4018 0.4083 0.4223 0.4147 0.3752 0.3921 0.3990 0.3814 ANSI CCT (K) Bin Code 3500 Q3 3500 Q4 3500 3500 Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) R3 R4 X Y 0.4223 0.4299 0.4431 0.4345 0.4147 0.4223 0.4345 0.4260 0.4345 0.4431 0.4562 0.4468 0.3990 0.4165 0.4213 0.4033 0.3814 0.3990 0.4033 0.3854 0.4033 0.4213 0.4260 0.4077 0.4260 0.4345 0.4468 0.4373 0.3854 0.4033 0.4077 0.3893 ANSI CCT (K) 3000 3000 3000 3000 Page 36 of 45 Color Binning Information (continued) Figure 39: Graph of Neutral White Test Bins in xy Color Space Table 11: Neutral White xy Bin Coordinates and Associated Typical CCT Bin J3 J4 K3 K4 X Y 0.3530 0.3548 0.3642 0.3617 0.3512 0.3530 0.3617 0.3591 0.3617 0.3642 0.3736 0.3703 0.3591 0.3617 0.3703 0.3670 0.3601 0.3736 0.3805 0.3663 0.3465 0.3601 0.3663 0.3522 0.3663 0.3805 0.3874 0.3726 0.3522 0.3663 0.3726 0.3578 ANSI CCT (K) Bin 4500 L3 4500 L4 4500 M3 4500 M4 Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) X Y 0.3703 0.3736 0.3871 0.3828 0.3670 0.3703 0.3828 0.3784 0.3828 0.3871 0.4006 0.3952 0.3784 0.3828 0.3952 0.3898 0.3726 0.3874 0.3959 0.3803 0.3578 0.3726 0.3803 0.3647 0.3803 0.3959 0.4044 0.3880 0.3647 0.3803 0.3880 0.3716 ANSI CCT (K) 4000 4000 4000 4000 Page 37 of 45 Color Binning Information (continued) Figure 40: Graph of Cool White Test Bins in xy Color Space 0K H4 G4 E3 D3 C3 0.32 C4 0.31 0.30 0.31 K E4 D4 0.32 0.33 0.34 K F4 474 5 0.33 F3 5310 K 0.34 H3 G3 5028 0K 704 0.35 6 53 0.36 Y 60 20 K 0.37 5665 K 0.38 0.35 0.36 X Table 12: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code C3 C4 D3 D4 X Y 0.3048 0.3131 0.3117 0.3028 0.3068 0.3145 0.3131 0.3048 0.3131 0.3213 0.3205 0.3117 0.3145 0.3221 0.3213 0.3131 0.3209 0.3290 0.3393 0.3304 0.3113 0.3187 0.3290 0.3209 0.3290 0.3371 0.3481 0.3393 0.3187 0.3261 0.3371 0.3290 ANSI CCT (K) Bin Code 6500 E3 6500 E4 6500 F3 6500 F4 X Y 0.3215 0.3293 0.3292 0.3207 0.3222 0.3294 0.3293 0.3215 0.3292 0.3293 0.3371 0.3376 0.3294 0.3366 0.3371 0.3293 0.3353 0.3423 0.3539 0.3462 0.3243 0.3306 0.3423 0.3353 0.3539 0.3423 0.3493 0.3616 0.3306 0.3369 0.3493 0.3423 Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) ANSI CCT (K) Bin Code 5700 G3 5700 G4 5700 H3 5700 H4 X Y 0.3376 0.3464 0.3452 0.3371 0.3371 0.3452 0.3441 0.3366 0.3464 0.3551 0.3533 0.3452 0.3452 0.3533 0.3515 0.3441 0.3616 0.3688 0.3558 0.3493 0.3493 0.3558 0.3428 0.3369 0.3688 0.3760 0.3624 0.3558 0.3558 0.3624 0.3487 0.3428 ANSI CCT (K) 5000 5000 5000 5000 Page 38 of 45 Mechanical Assembly and Handling Recommended assembly is illustrated below. When handling parts, please avoid contacting and do not apply stress to the resin area (see Figures 1 and 2, resin area is indicated in yellow). Product should be firmly secured onto appropriate heat sink by fastening M2.5 or #4 screws on both sides of the product as illustrated in Figure 41. The recommended center-to-center spacing for these the two tapped holes for mounting screws is 19.20 ± 0.05mm for hexagonal star products and 26.92 ± 0.10mm for rectangular array products. Bridgelux recommends the use of hard non-electrically conductive flat washers with lock washers. Refer to Application Note AN11 – Handling and Assembly of Bridgelux LED Arrays, for more details. A thin layer of thermal grease should be applied to the bottom surface of the LED Array, between the bottom of the array and the heat sink. All air gaps and voids between the heat sink and array should be eliminated. Ensure that sufficient thermal grease is used to cover the entire bottom surface of the array, but not so much that the thermal grease creeps up to the top of the array. Figure 41: Recommended Assembly Method Drawing Not to Scale For the hexagonal star products, preferred screw mounting locations are indicated in Figure 42. Figure 42: Recommended Mounting Locations for Hexagonal Star Products Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 39 of 45 Product Packaging and Labeling All Bridgelux LED Array products are 100% tested, binned and labeled. Products are labeled by printing pertinent information on the back side of the array. The following format is used for labeling the Bridgelux LED Arrays: ABCD BXRA–xxxxx EFGHJ–WWYY Where: A B C D – designates the bin code (LQ30, etc.) x x x x x – designates the base part number (W0802, etc.) E F G H J – designates the production lot code (12345, etc.) W W Y Y – designates the date code (production week and production year, 0210, etc.) Individual Bridgelux LED Arrays are packaged in tubes for shipment. All product packaged within a single tube are of the same flux and color bin combination (or bin code). Each tube is labeled with the information required for effective inventory management. An example of the tube label is shown in Figure 43. Figure 43: Tube Label Example Where: X X X X X – designates the base part number (W0802, etc.) A B C D – designates the bin code (LQ30, etc.) E F G H J – designates the production lot code (12345, etc.) W W Y Y – designates the date code (production week and production year, 0210, etc.) Z Z – designates the quantity (25 products per tube for hexagonal stars, 20 for rectangles). Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 40 of 45 Product Packaging and Labeling (continued) Tubes of Bridgelux LED Arrays are packaged in bags prior to loading into boxes for shipment. One tube is loaded per bag, resulting in an SPI of 25 for hexagonal star products and 20 for rectangular product configurations. All products packaged within a single bag are of the same flux and color bin combination (or bin code). Each bag is labeled with the information required for effective inventory management. An example of the bag label is shown in Figure 44. Figure 44: Bag Label Example Where: X X X X X – designates the base part number (W0802, etc.) A B C D – designates the bin code (LQ30, etc.) E F G H J – designates product lot code W W Y Y – designates the date code (production week and production year, 0210, etc.) Z Z – designates the quantity (25 products per tube for hexagonal stars, 20 for rectangles). Bags of Bridgelux LED Arrays are packaged in boxes prior to shipment. Multiple bags are packaged into a box. All products packaged within a box are of the same base part number. Each box is labeled with the information required for effective inventory management. An example of the box label is shown in Figure 46. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 41 of 45 Product Packaging and Labeling (continued) Figure 45: Box Label Example Where: X X X X X– designates the base part number (W0802, etc.) R R R R R – used to designate product options, 00000 by default. Q Q Q – designates the total quantity of LED Arrays contained in the box. E F G H J – designates product lot code. A B C D – designates the bin code (LQ30, etc.) W W Y Y – designates the date code (production week and production year, 0210, etc.) Z Z Z – designates the quantity per listed bin code contained in the box. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 42 of 45 Packaging Tube Design Figure 46: Tube Design for Hexagonal Star Products Figure 47: Tube Design for Rectangular Array Products Notes for Figures 46 and 47: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 43 of 45 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes • • • • • • AN10: AN11: AN12: AN14: AN15: AN16: Effective Thermal Management of Bridgelux LED Arrays Assembly Considerations for Bridgelux LED Arrays Electrical Drive Considerations for Bridgelux LED Arrays Reliability Data Sheet for Bridgelux LED Arrays Reflow Soldering of Bridgelux LED Arrays Optical Considerations for Bridgelux LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance. • • • • • • • • • Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 44 of 45 About Bridgelux Bridgelux LED Arrays are developed, manufactured and marketed by Bridgelux, Inc. Bridgelux is a U.S. lighting company and leading developer of technologies and solutions that will transform the $40 billion global lighting industry into a $100 billion market opportunity. Based in Silicon Valley, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for solid state lighting by driving down the cost of light through innovation. Bridgelux’s patented light source technology replaces traditional lighting technologies (such as incandescent, halogen and fluorescent lamps) with integrated, solid-state solutions, enabling lamp and luminaire manufacturers to develop high performance and energy-efficient white light products. The plug and play simplicity of the Bridgelux LED Arrays enable our customers to address the rapidly growing interior and exterior solid state lighting markets, including street lights, retail lighting, commercial lighting and consumer applications. With more than 250 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2010 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux ES Array Series Product Data Sheet DS11 (06/23/10) Page 45 of 45
BXRA-W1203-00000 价格&库存
很抱歉,暂时无法提供与“BXRA-W1203-00000”相匹配的价格&库存,您可以联系我们找货
