BXRC-30H2000-C-83-SE
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) Gen 8 Vero® SE 13 Array 白色,暖色 圆形
BXRC-30H2000-C-83-SE 数据手册
Bridgelux Gen 8 Vero SE 13 Array ® ® Product Data Sheet DS431 1 Vero SE Introduction The Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s eighth generation COB technology with poke-in connectivity, enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing costs, simplify the luminaire design process, improve light quality, and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures, and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting, with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Features • Poke-in electrical connectivity • Top side part number markings • Efficacy of 175 lm/W typical, 3000K 80 CRI • Reliable operation at up to 3x nominal current, 30% increase in maximum lumens per LES size • Wide selection of CCT options (2700K-6500K) with minimum 70, 80 and 90 CRI options Benefits • Low cost, solderless, connector free installation and field upgradability • Improved inventory management and quality control • Enables high efficiency lighting systems and lower operating costs • Supports the trend toward luminaire miniaturization and delivers enhanced optical control • Uniform high-quality illumination • Design flexibility for a broad range of lighting applications • 2 and 3 SDCM binning options (2700K – 4000K) • Clean white light without pixelation • Forward voltage bin codes (backside marking) • Uniform consistent white light • 10-Year warranty • Design flexibility for multi-source applications • Design with confidence Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 European Product Registry for Energy Labeling 7 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 20 Eye Safety 21 Absolute Maximum Ratings 22 Performance Curves 23 Typical Radiation Pattern 25 Typical Color Spectrum 26 Mechanical Dimensions 27 Color Binning Information 28 Packaging and Labeling 29 Design Resources 31 Precautions 31 Disclaimers 31 About Bridgelux 32 1 Product Feature Map Vero SE 13 is the second smallest form factor in the product family of the next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www. bridgelux.com for more information on the Vero SE family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 Tc Measurement point Optic mounting holes Radial die configuration improves lumen density and beam control Mounting holes Top side part number marking improves inventory management and outgoing quality control Zhaga Book 3 compatible mounting locations Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 200 0 – C – 8 3 – SE Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 8 Array Configuration CRI C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Flux Indicator 200x = 2000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E2000-B-8x-SE 2700 80 350 1924 1732 33.4 11.7 165 BXRC-27E2000-C-8x-SE 2700 80 500 2749 2474 33.4 16.7 165 BXRC-27E2000-D-8x-SE 2700 80 400 2026 1824 30.9 12.4 164 BXRC-27G2000-B-8x-SE 2700 90 350 1587 1429 33.4 11.7 136 BXRC-27G2000-C-8x-SE 2700 90 500 2268 2041 33.4 16.7 136 BXRC-27G2000-D-8x-SE 2700 90 400 1672 1505 30.9 12.4 135 BXRC-27G20H0-B-8x-SE 2700 90 350 1656 1490 33.4 11.7 142 BXRC-27G20H0-C-8x-SE 2700 90 500 2366 2129 33.4 16.7 142 BXRC-27G20H0-D-8x-SE 2700 90 400 1744 1570 30.9 12.4 141 BXRC-27H2000-B-8x-SE 2700 97 350 1407 1266 33.4 11.7 120 BXRC-27H2000-C-8x-SE 2700 97 500 2010 1809 33.4 16.7 120 BXRC-27H2000-D-8x-SE 2700 97 400 1482 1334 30.9 12.4 120 BXRC-30C2001-B-8x-SE 3000 70 350 2140 1926 33.4 11.7 183 BXRC-30C2001-C-8x-SE 3000 70 500 3058 2752 33.4 16.7 183 BXRC-30C2001-D-8x-SE 3000 70 400 2254 2029 30.9 12.4 182 BXRC-30E2000-B-8x-SE 3000 80 350 2044 1840 33.4 11.7 175 175 BXRC-30E2000-C-8x-SE 3000 80 500 2920 2628 33.4 16.7 BXRC-30E2000-D-8x-SE 3000 80 400 2153 1938 30.9 12.4 174 BXRC-30G2000-B-8x-SE 3000 90 350 1659 1494 33.4 11.7 142 142 BXRC-30G2000-C-8x-SE 3000 90 500 2371 2134 33.4 16.7 BXRC-30G2000-D-8x-SE 3000 90 400 1748 1573 30.9 12.4 141 BXRC-30G20H0-B-8x-SE 3000 90 350 1738 1564 33.4 11.7 149 BXRC-30G20H0-C-8x-SE 3000 90 500 2482 2234 33.4 16.7 149 BXRC-30G20H0-D-8x-SE 3000 90 400 1830 1647 30.9 12.4 148 BXRC-30H2000-B-8x-SE 3000 97 350 1503 1353 33.4 11.7 129 BXRC-30H2000-C-8x-SE 3000 97 500 2147 1933 33.4 16.7 129 BXRC-30H2000-D-8x-SE 3000 97 400 1583 1425 30.9 12.4 128 179 BXRC-35E2000-B-8x-SE 3500 80 350 2092 1883 33.4 11.7 BXRC-35E2000-C-8x-SE 3500 80 500 2989 2690 33.4 16.7 179 BXRC-35E2000-D-8x-SE 3500 80 400 2204 1983 30.9 12.4 178 BXRC-35G2000-B-8x-SE 3500 90 350 1720 1548 33.4 11.7 147 BXRC-35G2000-C-8x-SE 3500 90 500 2457 2211 33.4 16.7 147 BXRC-35G2000-D-8x-SE 3500 90 400 1811 1630 30.9 12.4 147 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40C2001-B-8x-SE 4000 70 350 2201 1981 33.4 11.7 188 188 BXRC-40C2001-C-8x-SE 4000 70 500 3144 2829 33.4 16.7 BXRC-40C2001-D-8x-SE 4000 70 400 2318 2086 30.9 12.4 188 BXRC-40E2000-B-8x-SE 4000 80 350 2104 1894 33.4 11.7 180 180 BXRC-40E2000-C-8x-SE 4000 80 500 3006 2706 33.4 16.7 BXRC-40E2000-D-8x-SE 4000 80 400 2216 1995 30.9 12.4 179 BXRC-40G2000-B-8x-SE 4000 90 350 1756 1580 33.4 11.7 150 BXRC-40G2000-C-8x-SE 4000 90 500 2508 2257 33.4 16.7 150 BXRC-40G2000-D-8x-SE 4000 90 400 1849 1664 30.9 12.4 150 BXRC-50C2001-B-8x-SE 5000 70 350 2213 1991 33.4 11.7 189 BXRC-50C2001-C-8x-SE 5000 70 500 3161 2845 33.4 16.7 189 BXRC-50C2001-D-8x-SE 5000 70 400 2330 2097 30.9 12.4 189 BXRC-50E2001-B-8x-SE 5000 80 350 2128 1916 33.4 11.7 182 BXRC-50E2001-C-8x-SE 5000 80 500 3041 2737 33.4 16.7 182 BXRC-50E2001-D-8x-SE 5000 80 400 2242 2018 30.9 12.4 181 BXRC-50G2001-B-8x-SE 5000 90 350 1840 1656 33.4 11.7 157 157 BXRC-50G2001-C-8x-SE 5000 90 500 2628 2366 33.4 16.7 BXRC-50G2001-D-8x-SE 5000 90 400 1938 1744 30.9 12.4 157 BXRC-57C2001-B-8x-SE 5700 70 350 2153 1937 33.4 11.7 184 BXRC-57C2001-C-8x-SE 5700 70 500 3075 2768 33.4 16.7 184 BXRC-57C2001-D-8x-SE 5700 70 400 2267 2040 30.9 12.4 183 BXRC-57E2001-B-8x-SE 5700 80 350 2044 1840 33.4 11.7 175 BXRC-57E2001-C-8x-SE 5700 80 500 2920 2628 33.4 16.7 175 BXRC-57E2001-D-8x-SE 5700 80 400 2153 1938 30.9 12.4 174 BXRC-65C2001-B-8x-SE 6500 70 350 2153 1937 33.4 11.7 184 BXRC-65C2001-C-8x-SE 6500 70 500 3075 2768 33.4 16.7 184 BXRC-65C2001-D-8x-SE 6500 70 400 2267 2040 30.9 12.4 183 BXRC-65E2001-B-8x-SE 6500 80 350 2068 1861 33.4 11.7 177 BXRC-65E2001-C-8x-SE 6500 80 500 2955 2659 33.4 16.7 177 BXRC-65E2001-D-8x-SE 6500 80 400 2178 1961 30.9 12.4 176 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50.the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E2000-B-8x-SE 2700 80 350 1732 1558 32.7 11.4 151 BXRC-27E2000-C-8x-SE 2700 80 500 2474 2226 32.7 16.3 151 BXRC-27E2000-D-8x-SE 2700 80 400 1824 1641 30.2 12.1 151 BXRC-27G2000-B-8x-SE 2700 90 350 1429 1286 32.7 11.4 125 BXRC-27G2000-C-8x-SE 2700 90 500 2041 1837 32.7 16.3 125 BXRC-27G2000-D-8x-SE 2700 90 400 1505 1354 30.2 12.1 124 BXRC-27G20H0-B-8x-SE 2700 90 350 1490 1341 32.7 11.4 130 BXRC-27G20H0-C-8x-SE 2700 90 500 2129 1916 32.7 16.3 130 BXRC-27G20H0-D-8x-SE 2700 90 400 1570 1413 30.2 12.1 130 111 BXRC-27H2000-B-8x-SE 2700 97 350 1266 1140 32.7 11.4 BXRC-27H2000-C-8x-SE 2700 97 500 1809 1628 32.7 16.3 111 BXRC-27H2000-D-8x-SE 2700 97 400 1334 1200 30.2 12.1 110 BXRC-30C2001-B-8x-SE 3000 70 350 1926 1734 32.7 11.4 168 BXRC-30C2001-C-8x-SE 3000 70 500 2752 2477 32.7 16.3 168 BXRC-30C2001-D-8x-SE 3000 70 400 2029 1826 30.2 12.1 168 BXRC-30E2000-B-8x-SE 3000 80 350 1840 1656 32.7 11.4 161 BXRC-30E2000-C-8x-SE 3000 80 500 2628 2366 32.7 16.3 161 BXRC-30E2000-D-8x-SE 3000 80 400 1938 1744 30.2 12.1 160 131 BXRC-30G2000-B-8x-SE 3000 90 350 1494 1344 32.7 11.4 BXRC-30G2000-C-8x-SE 3000 90 500 2134 1920 32.7 16.3 131 BXRC-30G2000-D-8x-SE 3000 90 400 1573 1416 30.2 12.1 130 BXRC-30G20H0-B-8x-SE 3000 90 350 1564 1407 32.7 11.4 137 BXRC-30G20H0-C-8x-SE 3000 90 500 2234 2011 32.7 16.3 137 BXRC-30G20H0-D-8x-SE 3000 90 400 1647 1482 30.2 12.1 136 BXRC-30H2000-B-8x-SE 3000 97 350 1353 1218 32.7 11.4 118 BXRC-30H2000-C-8x-SE 3000 97 500 1933 1739 32.7 16.3 118 BXRC-30H2000-D-8x-SE 3000 97 400 1425 1282 30.2 12.1 118 BXRC-35E2000-B-8x-SE 3500 80 350 1883 1695 32.7 11.4 165 BXRC-35E2000-C-8x-SE 3500 80 500 2690 2421 32.7 16.3 165 BXRC-35E2000-D-8x-SE 3500 80 400 1983 1785 30.2 12.1 164 BXRC-35G2000-B-8x-SE 3500 90 350 1548 1393 32.7 11.4 135 BXRC-35G2000-C-8x-SE 3500 90 500 2211 1990 32.7 16.3 135 BXRC-35G2000-D-8x-SE 3500 90 400 1630 1467 30.2 12.1 135 BXRC-40G2000-B-8x-SE 4000 90 350 1580 1422 32.7 11.4 138 BXRC-40G2000-C-8x-SE 4000 90 500 2257 2032 32.7 16.3 138 BXRC-40G2000-D-8x-SE 4000 90 400 1664 1498 30.2 12.1 138 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50. the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40C2001-B-8x-SE 4000 70 350 1981 1782 32.7 11.4 173 BXRC-40C2001-C-8x-SE 4000 70 500 2829 2546 32.7 16.3 173 BXRC-40C2001-D-8x-SE 4000 70 400 2086 1877 30.2 12.1 173 BXRC-40E2000-B-8x-SE 4000 80 350 1894 1705 32.7 11.4 166 BXRC-40E2000-C-8x-SE 4000 80 500 2706 2435 32.7 16.3 166 BXRC-40E2000-D-8x-SE 4000 80 400 1995 1795 30.2 12.1 165 BXRC-40G2000-B-8x-SE 4000 90 350 1580 1422 32.7 11.4 138 BXRC-40G2000-C-8x-SE 4000 90 500 2257 2032 32.7 16.3 138 BXRC-40G2000-D-8x-SE 4000 90 400 1664 1498 30.2 12.1 138 BXRC-50C2001-B-8x-SE 5000 70 350 1991 1792 32.7 11.4 174 BXRC-50C2001-C-8x-SE 5000 70 500 2845 2560 32.7 16.3 174 BXRC-50C2001-D-8x-SE 5000 70 400 2097 1888 30.2 12.1 173 BXRC-50E2001-B-8x-SE 5000 80 350 1916 1724 32.7 11.4 167 BXRC-50E2001-C-8x-SE 5000 80 500 2737 2463 32.7 16.3 167 BXRC-50E2001-D-8x-SE 5000 80 400 2018 1816 30.2 12.1 167 BXRC-50G2001-B-8x-SE 5000 90 350 1656 1490 32.7 11.4 145 BXRC-50G2001-C-8x-SE 5000 90 500 2366 2129 32.7 16.3 145 BXRC-50G2001-D-8x-SE 5000 90 400 1744 1570 30.2 12.1 144 BXRC-57C2001-B-8x-SE 5700 70 350 1937 1744 32.7 11.4 169 BXRC-57C2001-C-8x-SE 5700 70 500 2768 2491 32.7 16.3 169 BXRC-57C2001-D-8x-SE 5700 70 400 2040 1836 30.2 12.1 169 BXRC-57E2001-B-8x-SE 5700 80 350 1840 1656 32.7 11.4 161 BXRC-57E2001-C-8x-SE 5700 80 500 2628 2366 32.7 16.3 161 BXRC-57E2001-D-8x-SE 5700 80 400 1938 1744 30.2 12.1 160 BXRC-65C2001-B-8x-SE 6500 70 350 1937 1744 32.7 11.4 169 BXRC-65C2001-C-8x-SE 6500 70 500 2768 2491 32.7 16.3 169 BXRC-65C2001-D-8x-SE 6500 70 400 2040 1836 30.2 12.1 169 BXRC-65E2001-B-8x-SE 6500 80 350 1861 1675 32.7 11.4 163 BXRC-65E2001-C-8x-SE 6500 80 500 2659 2393 32.7 16.3 163 BXRC-65E2001-D-8x-SE 6500 80 400 1961 1764 30.2 12.1 162 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50. the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 European Product Registry for Energy Labeling The European Product Registry for Energy Labeling (EPREL) is defined in the EU Regulation 2017/1369 to provide important energy efficiency information to consumers. Together with Energy Labeling Regulation ELR (EU) 2019/2015 which was amended by regulation (EU) 2021/340 for energy labelling of light sources, manufacturers are required to declare an energy class based on key technical specifications from each of their product and register it in an open data base managed by EPREL It is now a legal requirement for a vendor of light sources to upload information about their products into the EPREL database before placing these products on the market in the EU. Table 3 below provides a list of part numbers that are in compliance with ELR and are currently listed in the EPREL database. At Bridgelux, we are fully committed to supplying products that are compliant with pertinent laws, rules, and obligation imposed by relevant government bodies including the European Energy Labeling regulation. Customers can use these products with full confidence for any projects that fall under the ELR. Table 3: Part numbers registered in European Product Registry for Energy Labeling CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) 2700 80 1250 33.4 4549 41.8 109 PART NUMBER CCT (K) BXRC-27E2000-D-8x-SE 1 Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database F 872503 https://eprel.ec.europa.eu/qr/872503 https://eprel.ec.europa.eu/qr/872579 BXRC-27G2000-B-8x-SE 2700 90 1250 38.3 4015 47.9 84 G 872579 BXRC-27G2000-C-8x-SE 2700 90 1750 36.8 5634 64.4 88 G 872584 https://eprel.ec.europa.eu/qr/872584 BXRC-27G2000-D-8x-SE 2700 90 1250 33.4 3753 41.8 90 G 872589 https://eprel.ec.europa.eu/qr/872589 BXRC-27G20H0-B-8x-SE 2700 90 1250 38.3 4189 47.9 87 G 872593 https://eprel.ec.europa.eu/qr/872593 BXRC-27G20H0-C-8x-SE 2700 90 1750 36.8 5877 64.4 91 G 872597 https://eprel.ec.europa.eu/qr/872597 BXRC-27G20H0-D-8x-SE 2700 90 1250 33.4 3915 41.8 94 F 872601 https://eprel.ec.europa.eu/qr/872601 BXRC-27H2000-B-8x-SE 2700 95 1070 37.5 3130 40.1 78 G 872652 https://eprel.ec.europa.eu/qr/872652 BXRC-27H2000-C-8x-SE 2700 95 1650 36.5 4757 60.2 79 G 872656 https://eprel.ec.europa.eu/qr/872656 BXRC-27H2000-D-8x-SE 2700 95 1250 33.4 3327 41.8 80 G 872660 https://eprel.ec.europa.eu/qr/872660 BXRC-30C2001-B-8x-SE 3000 70 1250 38.3 5415 47.9 113 F 872731 https://eprel.ec.europa.eu/qr/872731 BXRC-30C2001-C-8x-SE 3000 70 1750 36.8 7598 64.4 118 F 872737 https://eprel.ec.europa.eu/qr/872737 BXRC-30C2001-D-8x-SE 3000 70 1250 33.4 5061 41.8 121 E 872743 https://eprel.ec.europa.eu/qr/872743 BXRC-30E2000-B-8x-SE 3000 80 1250 38.3 5171 47.9 108 F 872799 https://eprel.ec.europa.eu/qr/872799 BXRC-30E2000-C-8x-SE 3000 80 1750 36.8 7256 64.4 113 F 872804 https://eprel.ec.europa.eu/qr/872804 BXRC-30E2000-D-8x-SE 3000 80 1250 33.4 4834 41.8 116 F 872809 https://eprel.ec.europa.eu/qr/872809 BXRC-30G2000-B-8x-SE 3000 90 1250 38.3 4198 47.9 88 G 872889 https://eprel.ec.europa.eu/qr/872889 BXRC-30G2000-C-8x-SE 3000 90 1750 36.8 5890 64.4 92 G 872894 https://eprel.ec.europa.eu/qr/872894 BXRC-30G2000-D-8x-SE 3000 90 1250 33.4 3924 41.8 94 F 872899 https://eprel.ec.europa.eu/qr/872899 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 7 European Product Registry for Energy Labeling Table 3: Part numbers registered in European Product Registry for Energy Labeling (Continued) CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) 3000 90 1250 38.3 4396 47.9 92 G PART NUMBER CCT (K) BXRC-30G20H0-B-8x-SE 1 Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database 872910 https://eprel.ec.europa.eu/qr/872910 BXRC-30G20H0-C-8x-SE 3000 90 1750 36.8 6168 64.4 96 F 872914 https://eprel.ec.europa.eu/qr/872914 BXRC-30G20H0-D-8x-SE 3000 90 1250 33.4 4109 41.8 98 F 872918 https://eprel.ec.europa.eu/qr/872918 BXRC-30H2000-B-8x-SE 3000 95 1250 38.3 3802 47.9 79 G 872975 https://eprel.ec.europa.eu/qr/872975 BXRC-30H2000-C-8x-SE 3000 95 1750 36.8 5335 64.4 83 G 872979 https://eprel.ec.europa.eu/qr/872979 BXRC-30H2000-D-8x-SE 3000 95 1250 33.4 3554 41.8 85 G 872983 https://eprel.ec.europa.eu/qr/872983 BXRC-35E2000-B-8x-SE 3500 80 1250 38.3 5293 47.9 110 F 873046 https://eprel.ec.europa.eu/qr/873046 BXRC-35E2000-C-8x-SE 3500 80 1750 36.8 7427 64.4 115 F 873051 https://eprel.ec.europa.eu/qr/873051 BXRC-35E2000-D-8x-SE 3500 80 1250 33.4 4947 41.8 118 F 873056 https://eprel.ec.europa.eu/qr/873056 https://eprel.ec.europa.eu/qr/873108 BXRC-35G2000-B-8x-SE 3500 90 1250 38.3 4350 47.9 91 G 873108 BXRC-35G2000-C-8x-SE 3500 90 1750 36.8 6104 64.4 95 F 873113 https://eprel.ec.europa.eu/qr/873113 BXRC-35G2000-D-8x-SE 3500 90 1250 33.4 4066 41.8 97 F 873118 https://eprel.ec.europa.eu/qr/873118 BXRC-40C2001-B-8x-SE 4000 70 1250 38.3 5567 47.9 116 F 873194 https://eprel.ec.europa.eu/qr/873194 BXRC-40C2001-C-8x-SE 4000 70 1750 36.8 7811 64.4 121 E 873200 https://eprel.ec.europa.eu/qr/873200 https://eprel.ec.europa.eu/qr/873206 BXRC-40C2001-D-8x-SE 4000 70 1250 33.4 5203 41.8 124 E 873206 BXRC-40E2000-B-8x-SE 4000 80 1250 38.3 5323 47.9 111 F 873262 https://eprel.ec.europa.eu/qr/873262 BXRC-40E2000-C-8x-SE 4000 80 1750 36.8 7470 64.4 116 F 873267 https://eprel.ec.europa.eu/qr/873267 BXRC-40E2000-D-8x-SE 4000 80 1250 33.4 4976 41.8 119 E 873272 https://eprel.ec.europa.eu/qr/873272 BXRC-40G2000-B-8x-SE 4000 90 1250 38.3 4441 47.9 93 F 873324 https://eprel.ec.europa.eu/qr/873324 BXRC-40G2000-C-8x-SE 4000 90 1750 36.8 6232 64.4 97 F 873329 https://eprel.ec.europa.eu/qr/873329 BXRC-40G2000-D-8x-SE 4000 90 1250 33.4 4151 41.8 99 F 873334 https://eprel.ec.europa.eu/qr/873334 BXRC-50C2001-B-8x-SE 5000 70 1250 38.3 5597 47.9 117 F 873398 https://eprel.ec.europa.eu/qr/873398 BXRC-50C2001-C-8x-SE 5000 70 1750 36.8 7854 64.4 122 E 873402 https://eprel.ec.europa.eu/qr/873402 BXRC-50C2001-D-8x-SE 5000 70 1250 33.4 5232 41.8 125 E 873406 https://eprel.ec.europa.eu/qr/873406 BXRC-50E2001-B-8x-SE 5000 80 1250 38.3 5384 47.9 112 F 873446 https://eprel.ec.europa.eu/qr/873446 https://eprel.ec.europa.eu/qr/873450 BXRC-50E2001-C-8x-SE 5000 80 1750 36.8 7555 64.4 117 F 873450 BXRC-50E2001-D-8x-SE 5000 80 1250 33.4 5033 41.8 120 E 873454 https://eprel.ec.europa.eu/qr/873454 BXRC-50G2001-B-8x-SE 5000 90 1250 38.3 4654 47.9 97 F 873494 https://eprel.ec.europa.eu/qr/873494 https://eprel.ec.europa.eu/qr/873498 BXRC-50G2001-C-8x-SE 5000 90 1750 36.8 6530 64.4 101 F 873498 BXRC-50G2001-D-8x-SE 5000 90 1250 33.4 4350 41.8 104 F 873502 https://eprel.ec.europa.eu/qr/873502 BXRC-57C2001-B-8x-SE 5700 70 1250 38.3 5445 47.9 114 F 873580 https://eprel.ec.europa.eu/qr/873580 BXRC-57C2001-C-8x-SE 5700 70 1750 36.8 7640 64.4 119 F 873584 https://eprel.ec.europa.eu/qr/873584 BXRC-57C2001-D-8x-SE 5700 70 1250 33.4 5089 41.8 122 E 873588 https://eprel.ec.europa.eu/qr/873588 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 8 European Product Registry for Energy Labeling Table 3: Part numbers registered in European Product Registry for Energy Labeling (Continued) CRI Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) Power (W) Efficacy (lm/W) 5700 80 1250 38.3 5171 47.9 108 F PART NUMBER CCT (K) BXRC-57E2001-B-8x-SE 1 Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database 873628 https://eprel.ec.europa.eu/qr/873628 BXRC-57E2001-C-8x-SE 5700 80 1750 36.8 7256 64.4 113 F 873632 https://eprel.ec.europa.eu/qr/873632 BXRC-57E2001-D-8x-SE 5700 80 1250 33.4 4834 41.8 116 F 873636 https://eprel.ec.europa.eu/qr/873636 BXRC-65C2001-B-8x-SE 6500 70 1250 38.3 5445 47.9 114 F 873676 https://eprel.ec.europa.eu/qr/873676 BXRC-65C2001-C-8x-SE 6500 70 1750 36.8 7640 64.4 119 F 873680 https://eprel.ec.europa.eu/qr/873680 BXRC-65C2001-D-8x-SE 6500 70 1250 33.4 5089 41.8 122 E 873684 https://eprel.ec.europa.eu/qr/873684 BXRC-65E2001-B-8x-SE 6500 80 1250 38.3 5232 47.9 109 F 873724 https://eprel.ec.europa.eu/qr/873724 BXRC-65E2001-C-8x-SE 6500 80 1750 36.8 7341 64.4 114 F 873728 https://eprel.ec.europa.eu/qr/873728 BXRC-65E2001-D-8x-SE 6500 80 1250 33.4 4890 41.8 117 F 873732 https://eprel.ec.europa.eu/qr/873732 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 9 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 3. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E2000-B-8x-SE 80 BXRC-27E2000-C-8x-SE 80 BXRC-27E2000-D-8x-SE 80 BXRC-27G2000-B-8x-SE 90 BXRC-27G2000-C-8x-SE 90 BXRC-27G2000-D-8x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 998 1447 1924 2429 3675 6236 1426 2086 2749 3404 5250 8750 1051 1538 2026 2491 3871 5828 823 1194 1587 2004 3032 5145 1176 1721 2268 2808 4331 7219 867 1269 1672 2055 3193 4808 898 1302 1732 2186 3307 5612 1283 1877 2474 3064 4725 7875 946 1384 1824 2242 3483 5245 741 1074 1429 1803 2729 4630 1059 1549 2041 2527 3898 6497 781 1142 1505 1849 2874 4327 176 169 165 159 149 133 176 169 164 159 149 133 175 169 164 159 149 137 145 140 136 131 123 109 145 139 136 131 123 110 145 139 135 131 123 113 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G20H0-B-8x-SE 90 BXRC-27G20H0-C-8x-SE 90 BXRC-27G20H0-D-8x-SE 90 BXRC-27H2000-B-8x-SE 97 typ. BXRC-27H2000-C-8x-SE 97 typ. BXRC-27H2000-D-8x-SE 97 typ. BXRC-30C2001-B-8x-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 859 1245 1656 2090 3163 5367 1227 1795 2366 2930 4518 7530 905 1323 1744 2144 3331 5016 730 1058 1407 1776 2687 4560 1043 1525 2010 2489 3839 6398 769 1124 1482 1821 2830 4262 1110 1610 2140 2702 4088 6937 773 1121 1490 1881 2847 4830 1104 1616 2129 2637 4066 6777 814 1191 1570 1929 2998 4514 657 952 1266 1598 2419 4104 938 1373 1809 2240 3455 5758 692 1012 1334 1639 2547 3836 999 1449 1926 2432 3680 6244 151 146 142 137 128 114 151 145 142 137 128 115 151 145 141 137 128 118 129 124 120 116 109 97 128 123 120 117 109 97 128 123 120 116 109 100 196 188 183 177 166 148 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30C2001-C-8x-SE 70 BXRC-30C2001-D-8x-SE 70 BXRC-30E2000-B-8x-SE 80 BXRC-30E2000-C-8x-SE 80 BXRC-30E2000-D-8x-SE 80 BXRC-30G2000-B-8x-SE 90 BXRC-30G2000-C-8x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 1586 2320 3058 3787 5841 9734 1170 1711 2254 2771 4306 6484 1061 1537 2044 2580 3905 6626 1515 2216 2920 3617 5578 9297 1117 1634 2153 2646 4112 6192 861 1248 1659 2095 3170 5378 1230 1799 2371 2936 4528 7547 1428 2088 2752 3408 5257 8761 1053 1540 2029 2494 3875 5835 954 1384 1840 2322 3514 5963 1364 1995 2628 3255 5020 8367 1005 1470 1938 2382 3701 5573 775 1123 1494 1885 2853 4841 1107 1619 2134 2642 4075 6792 195 188 183 177 166 148 195 187 183 177 166 152 187 180 175 169 159 141 187 179 175 169 158 142 186 179 174 169 158 145 152 146 142 137 129 114 151 146 142 137 129 115 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G2000-D-8x-SE 90 BXRC-30G20H0-B-8x-SE 90 BXRC-30G20H0-C-8x-SE 90 BXRC-30G20H0-D-8x-SE 90 BXRC-30H2000-B-8x-SE 97 typ. BXRC-30H2000-C-8x-SE 97 typ. BXRC-30H2000-D-8x-SE 97 typ. Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 907 1326 1748 2148 3338 5027 901 1307 1738 2193 3319 5632 1288 1884 2482 3074 4741 7902 949 1389 1830 2249 3496 5263 780 1130 1503 1897 2871 4872 1114 1630 2147 2659 4102 6836 821 1201 1583 1946 3024 4553 816 1194 1573 1933 3005 4524 811 1176 1564 1974 2987 5069 1159 1695 2234 2767 4267 7112 854 1250 1647 2025 3146 4737 702 1017 1353 1708 2584 4385 1003 1467 1933 2393 3691 6152 739 1081 1425 1751 2721 4098 151 145 142 137 128 118 159 153 149 144 135 120 159 152 148 144 135 120 158 152 148 144 134 123 137 132 129 124 117 104 137 132 128 124 116 104 137 132 128 124 116 107 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40G2000-C-8x-SE 90 BXRC-40G2000-D-8x-SE 90 BXRC-50C2001-B-8x-SE 70 BXRC-35E2000-B-8x-SE 80 BXRC-35E2000-C-8x-SE 80 BXRC-35E2000-D-8x-SE 80 BXRC-35G2000-B-8x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 1301 1886 2508 3166 4791 8129 959 1403 1849 2290 3532 5886 1148 1679 2213 2720 4226 6364 1086 1574 2092 2641 3997 6781 1551 2268 2989 3702 5709 9515 1143 1672 2204 2709 4209 6338 892 1293 1720 2171 3285 5573 1171 1698 2257 2849 4312 7316 863 1263 1664 2061 3179 5298 1033 1511 1991 2448 3804 5727 977 1416 1883 2377 3597 6103 1396 2041 2690 3332 5138 8564 1029 1505 1983 2438 3788 5704 803 1164 1548 1954 2956 5016 229 220 215 207 195 173 118 114 111 107 100 90 191 184 179 174 163 149 191 184 179 173 162 144 191 184 179 173 162 145 191 183 179 173 162 149 157 151 147 142 133 119 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35G2000-C-8x-SE 90 BXRC-35G2000-D-8x-SE 90 BXRC-40C2001-B-8x-SE 70 BXRC-40C2001-C-8x-SE 70 BXRC-40C2001-D-8x-SE 70 BXRC-40E2000-B-8x-SE 80 BXRC-40E2000-C-8x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 1274 1864 2457 3042 4692 7820 940 1374 1811 2226 3459 5209 1142 1655 2201 2778 4203 7132 1631 2386 3144 3893 6005 10008 1202 1759 2318 2849 4427 6666 1092 1583 2104 2656 4020 6820 1560 2281 3006 3723 5742 9570 1147 1678 2211 2738 4223 7038 846 1237 1630 2004 3113 4688 1027 1489 1981 2500 3783 6419 1468 2147 2829 3504 5404 9007 1082 1583 2086 2564 3984 5999 983 1424 1894 2391 3618 6138 1404 2053 2706 3351 5168 8613 157 151 147 142 133 119 157 151 147 142 133 122 201 193 188 182 171 152 201 193 188 182 171 152 201 193 188 182 170 156 192 185 180 174 163 145 192 185 180 174 163 146 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E2000-D-8x-SE 80 BXRC-40G2000-B-8x-SE 90 BXRC-40G2000-C-8x-SE 90 BXRC-40G2000-D-8x-SE 90 BXRC-50C2001-B-8x-SE 70 BXRC-50C2001-C-8x-SE 70 BXRC-50C2001-D-8x-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 1150 1682 2216 2724 4233 6374 911 1320 1756 2216 3353 5690 1301 1903 2508 3106 4791 7984 959 1403 1849 2273 3532 5318 1148 1664 2213 2793 4226 7171 1640 2399 3161 3915 6037 10062 1209 1768 2330 2864 4451 6702 1035 1514 1995 2452 3810 5737 820 1188 1580 1994 3018 5121 1171 1713 2257 2796 4312 7186 863 1263 1664 2046 3179 4786 1033 1498 1991 2514 3804 6454 1476 2159 2845 3523 5434 9056 1088 1592 2097 2578 4006 6032 192 184 180 174 163 149 160 154 150 145 136 121 160 154 150 145 136 122 160 154 150 145 136 125 202 194 189 183 172 153 202 194 189 183 171 153 202 194 189 183 171 157 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50E2001-B-8x-SE 80 BXRC-50E2001-C-8x-SE 80 BXRC-50E2001-D-8x-SE 80 BXRC-50G2001-B-8x-SE 90 BXRC-50G2001-C-8x-SE 90 BXRC-50G2001-D-8x-SE 90 BXRC-57C2001-B-8x-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 1104 1601 2128 2687 4065 6898 1577 2307 3041 3766 5808 9679 1163 1701 2242 2755 4282 6447 954 1384 1840 2322 3514 5963 1364 1995 2628 3255 5020 8367 1005 1470 1938 2382 3701 5573 1117 1619 2153 2717 4111 6976 994 1441 1916 2418 3659 6209 1420 2077 2737 3389 5227 8711 1047 1531 2018 2480 3854 5803 859 1245 1656 2090 3163 5367 1227 1795 2366 2930 4518 7530 905 1323 1744 2144 3331 5016 1005 1457 1937 2445 3700 6279 195 187 182 176 165 147 194 187 182 176 165 147 194 186 182 176 165 151 168 162 157 152 143 127 168 161 157 152 143 127 168 161 157 152 142 131 197 189 184 178 167 148 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57C2001-C-8x-SE 70 BXRC-57C2001-D-8x-SE 70 BXRC-57E2001-B-8x-SE 80 BXRC-57E2001-C-8x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 1595 2333 3075 3808 5873 9789 1176 1720 2267 2787 4330 6520 1061 1537 2044 2580 3905 6626 1515 2216 2920 3617 5578 9297 1436 2100 2768 3427 5286 8810 1059 1548 2040 2508 3897 5868 954 1384 1840 2322 3514 5963 1364 1995 2628 3255 5020 8367 196 189 184 178 167 149 196 189 184 178 167 153 187 180 175 169 159 141 187 179 175 169 158 142 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E2001-D-8x-SE 80 BXRC-65C2001-B-8x-SE 70 BXRC-65C2001-C-8x-SE 70 BXRC-65C2001-D-8x-SE 70 BXRC-65E2001-B-8x-SE 80 BXRC-65E2001-C-8x-SE 80 BXRC-65E2001-D-8x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 175 260 350 450 700 1250 250 375 500 630 1000 1750 200 300 400 500 800 1250 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 32.4 32.9 33.4 33.9 35.2 37.6 32.5 33.0 33.4 33.9 35.2 37.5 30.0 30.4 30.9 31.3 32.5 34.1 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 5.7 8.6 11.7 15.3 24.6 47.0 8.1 12.4 16.7 21.4 35.2 65.7 6.0 9.1 12.3 15.6 26.0 42.7 1117 1634 2153 2646 4112 6192 1117 1619 2153 2717 4111 6976 1595 2333 3075 3808 5873 9789 1176 1720 2267 2787 4330 6520 1073 1555 2068 2611 3951 6704 1533 2242 2955 3659 5644 9406 1130 1653 2178 2678 4161 6265 1005 1470 1938 2382 3701 5573 1005 1457 1937 2445 3700 6279 1436 2100 2768 3427 5286 8810 1059 1548 2040 2508 3897 5868 966 1400 1861 2350 3556 6033 1380 2018 2659 3293 5079 8465 1017 1488 1961 2410 3745 5639 186 179 174 169 158 145 197 189 184 178 167 148 196 189 184 178 167 149 196 189 184 178 167 153 189 182 177 171 160 143 189 181 177 171 160 143 189 181 177 171 160 147 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 19 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx200x-B-8x-SE BXRC-xxx200x-C-8x-SE BXRC-xxx200x-D-8x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.22 30.0 36.6 -12.13 0.34 33.8 41.2 35.9 -10.77 0.19 30.0 36.6 37.5 40.3 -12.10 0.29 33.7 41.1 28.6 30.9 33.2 -9.97 0.25 27.8 33.9 31.5 34.1 36.7 -11.00 0.38 30.7 37.4 Minimum Typical Maximum 350 30.9 33.4 35.9 -10.77 1250 34.8 37.6 40.4 500 30.9 33.4 1750 34.7 400 1250 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 1140 V. The working voltage designated for the insulation is 70V d.c. The maximum allowable voltage across the array must be determined in the end product application. 20 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx200x-B-8x-SE CCT Drive Current (mA) 2700K/3000K 4000K2 5000K3 6500K4 800 RG1 RG1 RG1 RG1 1110 RG1 RG1 RG1 RG2 1250 RG1 RG1 RG2 RG2 800 RG1 RG1 RG1 RG1 1110 RG1 RG1 RG1 RG2 1470 RG1 RG1 RG2 RG2 1750 RG1 RG2 RG2 RG2 865 RG1 RG1 RG1 RG1 1195 RG1 RG1 RG1 RG2 1250 RG1 RG1 RG2 RG2 BXRC-xxx200x-C-8x-SE BXRC-xxx200x-D-8x-SE Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1980 lx. 3. For products classified as RG2 at 5000K Ethr= 1530 lx. 4. For products classified as RG2 at 6500K, Ethr= 1170 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 21 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRC-xxx200x-B-8x-SE BXRC-xxx200x-C-8x-SE BXRC-xxx200x-D-8x-SE Maximum Drive Current3 1250 mA 1750 mA 1250 mA Maximum Peak Pulsed Drive Current4 1400 mA 1960 mA 1400 mA Maximum Reverse Voltage5 -60V -60V -55V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN120: Bridgelux Vero SE Array Design Guide. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 22 Performance Curves Figure 2: Vero SE 13C Drive Current vs. Voltage 38.0 38.0 37.0 37.0 36.0 36.0 Voltage (V) Voltage (V) Figure 1: Vero SE 13B Drive Current vs. Voltage 35.0 34.0 35.0 34.0 33.0 33.0 32.0 32.0 0 150 300 450 600 750 900 1050 1200 0 1350 200 400 Figure 3: Vero SE 13D Drive Current vs. Voltage 1000 1200 1400 1600 1800 2000 350% 34.5 Relative Luminous Flux (%) 33.5 33.0 Voltage (V) 800 Figure 4: Vero SE 13B Typical Relative Flux vs. Current 34.0 32.5 32.0 31.5 31.0 30.5 30.0 300% 250% 200% 150% 100% 50% 0% 29.5 0 150 300 450 600 750 900 1050 1200 0 1350 150 300 Figure 5: Vero SE 13C Typical Relative Flux vs. Current 450 600 750 900 1050 1200 1350 Drive Current (mA) Drive Current (mA) Figure 6 Vero SE 13D Typical Relative Flux vs. Current 350% Relative Luminous Flux (%) 350% Relative Luminous Flux (%) 600 Drive Current (mA) Drive Current (mA) 300% 250% 200% 150% 100% 50% 300% 250% 200% 150% 100% 50% 0% 0% 0 200 400 600 800 1000 1200 1400 1600 1800 2000 Drive Current (mA) 0 150 300 450 600 750 900 1050 1200 1350 Drive Current (mA) Notes for Figure 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 23 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature 102% 0.0010 100% 0.0000 25C Pulsed -0.0010 98% -0.0020 96% ccy shift Relative Luminous Flux Figure 7: Typical DC Flux vs. Case Temperature 94% 92% -0.0030 -0.0040 -0.0050 90% -0.0060 -0.0070 88% 0 20 40 60 80 100 120 0 20 40 60 80 100 120 Case Temperature (T c) Case Temperature (T c) Figure 9: Typical DC ccx Shift vs. Case Temperature 0.0020 25C Pulsed 0.0000 ccx shift -0.0020 -0.0040 -0.0060 -0.0080 -0.0100 0 20 40 60 80 100 120 Case Temperature (T c) Note for Figures 7-9: 1. Characteristics shown for Warm White. 24 Typical Radiation Pattern Figure 10: Typical Spatial Radiation Pattern Notes for Figure 10: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 11: Typical Polar Radiation Pattern 25 Typical Color Spectrum Figure 12: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Rela�ve Spectral Power Distribu�on 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 12: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. 26 Mechanical Dimensions Figure 13: Drawing for Vero SE 13 LED Array Notes for Figure 13: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 35 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array 27 Color Binning Information Figure 14: Warm and Neutral White Test Bins in xy Color Figure 15: Cool White Test Bins in xy Color Space Space 0.44 0.39 4 SDCM 3 SDCM 3 SDCM 0.38 2 SDCM 2700K 0.42 0.37 3000K 0.4 5000K 0.36 3500K 5700K 0.35 Y Y 4000K 0.34 0.38 6500K 0.33 0.36 0.32 0.31 0.34 0.36 0.39 0.42 X 0.45 0.3 0.48 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 84 (4 SDCM) (4801K - 5282K) (5395K- 5970K) (6200K - 6910K) 83 (3 SDCM) (4835K-5215K) (5460K- 5891K) (6279K -6811K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) Note for Tables 8-9: 1. Bridgelux maintains a tolerance of +/- 0.007 on x and y color coordinates in the CIE 1931 color Space. 28 Packaging and Labeling Figure 16: Drawing for Vero SE 13 Packaging Tray Notes for Figure 16: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 29 Packaging and Labeling Figure 17: Vero SE Series Packaging and Labeling Notes for Figure 17: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 18: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E2000C 83 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 30 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN120 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 31 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46410 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 Vero SE 13 Array Series Product Data Sheet DS431 Rev. C (09/2021) 32
BXRC-30H2000-C-83-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-30H2000-C-83-SE”相匹配的价格&库存,您可以联系我们找货
  • 1+101.829551+13.19049
  • 10+78.3553510+10.14976
  • 100+64.66256100+8.37607
  • 500+58.70360500+7.60417
  • 1000+56.770491000+7.35377
库存:168
