BXRC-50E1001-C-74-SE
    BRIDGELUX(普瑞)
    VERO SE 10 Series 5000K 80 CRI min 1950 lm 35 V 4 SDCM Cool White LED Array
BXRC-50E1001-C-74-SE 数据手册
Bridgelux Vero SE 10 Array ® ® Product Data Sheet DS120 1 Vero SE Introduction Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s seventh generation COB technology with poke-in connectivity enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing cost, simplify luminaire design, improve light quality and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series™ Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is also a good replacement for halogen lamps. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features • Poke-in connectivity • Efficacy of 162 lm/W typical • Broad range of CCT options from 2700K to 6500K • CRI options: minimum 65, 70, 80, and 90 Benefits • Poke-in connectivity enables solderless, connector free installation • Broad application coverage for interior and exterior lighting • Color control: 2 and 3 SDCM for 2700K-4000K CCT • Flexibility for application driven lighting design requirements • Reliable operation at up to 2X nominal drive current • High quality, true color reproduction • Radial die pattern and improved lumen density • Uniform consistent white light • Top side part number markings • Flexibility in design optimization • No exposed solder pads or electrical connections • Enhanced ease of use and assembly • Vf bin code backside marking • Ability to configure multiple Vero SE arrays in series and parallel reduces customer driver cost • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 19 Eye Safety 20 Absolute Maximum Ratings 21 Performance Curves 22 Typical Radiation Pattern 25 Typical Color Spectrum 26 Mechanical Dimensions 27 Color Binning Information 28 Packaging and Labeling 29 Design Resources 31 Precautions 31 Disclaimers 31 About Bridgelux 32 1 Product Feature Map Vero SE 10 is the smallest form factor in the product family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www. bridgelux.com for more information on the Vero SE family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms (x4) Tc Measurement point Mounting holes Optic mounting holes Radial die configuration improves lumen density and beam control Top side part number marking improves inventory management and outgoing quality control Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 100 0 – C – 7 3 – SE Product Family Nominal CCT 20 = 2,000K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 7 Array Configuration CRI B = 65 CRI min. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Flux Indicator 100x = 1000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-20B1001-B-73-SE 2000 65 270 1391 1224 34.8 9.4 148 BXRC-20B1001-D-73-SE 2000 65 350 1347 1185 26.0 9.1 148 BXRC-27E1000-B-7x-SE 2700 80 270 1417 1247 34.8 9.4 151 BXRC-27E1000-C-7x-SE 2700 80 360 1890 1663 34.8 12.5 151 BXRC-27E1000-D-7x-SE 2700 80 350 1373 1208 26.0 9.1 151 BXRC-27G10H0-B-7x-SE 2700 90 270 1214 1068 34.8 9.4 129 BXRC-27G10H0-C-7x-SE 2700 90 360 1618 1424 34.8 12.5 129 BXRC-27G10H0-D-7x-SE 2700 90 350 1175 1034 26.0 9.1 129 BXRC-27G1000-B-7x-SE 2700 90 270 1169 1029 34.8 9.4 124 BXRC-27G1000-C-7x-SE 2700 90 360 1559 1372 34.8 12.5 124 BXRC-27G1000-D-7x-SE 2700 90 350 1133 997 26.0 9.1 124 BXRC-27H1000-B-7x-SE 2700 97 270 1036 912 34.8 9.4 110 110 BXRC-27H1000-C-7x-SE 2700 97 360 1382 1216 34.8 12.5 BXRC-27H1000-D-7x-SE 2700 97 350 1004 883 26.0 9.1 110 BXRC-30C1001-B-74-SE 3000 70 270 1577 1388 34.8 9.4 168 168 BXRC-30C1001-C-74-SE 3000 70 360 2103 1850 34.8 12.5 BXRC-30C1001-D-74-SE 3000 70 350 1527 1344 26.0 9.1 168 BXRC-30E1000-B-7x-SE 3000 80 270 1506 1325 34.8 9.4 160 BXRC-30E1000-C-7x-SE 3000 80 360 2008 1767 34.8 12.5 160 BXRC-30E1000-D-7x-SE 3000 80 350 1459 1284 26.0 9.1 160 BXRC-30G10H0-B-7x-SE 3000 90 270 1276 1123 34.8 9.4 136 BXRC-30G10H0-C-7x-SE 3000 90 360 1701 1497 34.8 12.5 136 BXRC-30G10H0-D-7x-SE 3000 90 350 1235 1087 26.0 9.1 136 BXRC-30G1000-B-7x-SE 3000 90 270 1223 1076 34.8 9.4 130 BXRC-30G1000-C-7x-SE 3000 90 360 1630 1434 34.8 12.5 130 BXRC-30G1000-D-7x-SE 3000 90 350 1184 1042 26.0 9.1 130 BXRC-30G100C-B-73-SE 3000 90 270 1178 1037 34.8 9.4 125 BXRC-30G100C-D-73-SE 3000 90 350 1141 1004 26.0 9.1 125 BXRC-30H1000-B-7x-SE 3000 97 270 1107 974 34.8 9.4 118 BXRC-30H1000-C-7x-SE 3000 97 360 1476 1299 34.8 12.5 118 BXRC-30H1000-D-7x-SE 3000 97 350 1072 944 26.0 9.1 118 BXRC-30A1001-B-73-SE8,9 3000 93 270 1099 967 34.8 9.4 117 BXRC-30A1001-C-73-SE 8,9 3000 93 360 1465 1289 34.8 12.5 117 BXRC-30A1001-D-73-SE8,9 3000 93 350 1064 936 26.0 9.1 117 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E1000-B-7x-SE 3500 80 270 1541 1356 34.8 9.4 164 BXRC-35E1000-C-7x-SE 3500 80 360 2055 1809 34.8 12.5 164 BXRC-35E1000-D-7x-SE 3500 80 350 1493 1314 26.0 9.1 164 BXRC-35G1000-B-7x-SE 3500 90 270 1267 1115 34.8 9.4 135 BXRC-35G1000-C-7x-SE 3500 90 360 1689 1486 34.8 12.5 135 BXRC-35G1000-D-7x-SE 3500 90 350 1227 1080 26.0 9.1 135 BXRC-35A1001-B-73-SE8,9 3500 93 270 1169 1029 34.8 9.4 124 BXRC-35A1001-C-73-SE8,9 3500 93 360 1559 1372 34.8 12.5 124 BXRC-35A1001-D-73-SE8,9 3500 93 350 1133 997 26.0 9.1 124 BXRC-40C1001-B-74-SE 4000 70 270 1621 1427 34.8 9.4 173 BXRC-40C1001-C-74-SE 4000 70 360 2162 1902 34.8 12.5 173 BXRC-40C1001-D-74-SE 4000 70 350 1570 1382 26.0 9.1 173 BXRC-40E1000-B-7x-SE 4000 80 270 1550 1364 34.8 9.4 165 BXRC-40E1000-C-7x-SE 4000 80 360 2067 1819 34.8 12.5 165 BXRC-40E1000-D-7x-SE 4000 80 350 1501 1321 26.0 9.1 165 BXRC-40G1000-B-7x-SE 4000 90 270 1293 1138 34.8 9.4 138 BXRC-40G1000-C-7x-SE 4000 90 360 1725 1518 34.8 12.5 138 BXRC-40G1000-D-7x-SE 4000 90 350 1253 1102 26.0 9.1 138 BXRC-40H1000-B-7x-SE 4000 97 270 1169 1029 34.8 9.4 124 BXRC-40H1000-C-7x-SE 4000 97 360 1559 1372 34.8 12.5 124 BXRC-40H1000-D-7x-SE 4000 97 350 1133 997 26.0 9.1 124 BXRC-40A1001-B-73-SE 8,9 4000 93 270 1267 1115 34.8 9.4 135 BXRC-40A1001-C-73-SE8,9 4000 93 360 1689 1486 34.8 12.5 135 BXRC-40A1001-D-73-SE8,9 4000 93 350 1227 1080 26.0 9.1 135 BXRC-50C1001-B-7x-SE 5000 70 270 1630 1434 34.8 9.4 173 BXRC-50C1001-C-7x-SE 5000 70 360 2173 1913 34.8 12.5 173 BXRC-50C1001-D-7x-SE 5000 70 350 1579 1389 26.0 9.1 173 BXRC-50E1001-B-7x-SE 5000 80 270 1568 1380 34.8 9.4 167 BXRC-50E1001-C-7x-SE 5000 80 360 2091 1840 34.8 12.5 167 BXRC-50E1001-D-7x-SE 5000 80 350 1519 1336 26.0 9.1 167 BXRC-50G1001-B-7x-SE 5000 90 270 1355 1193 34.8 9.4 144 BXRC-50G1001-C-7x-SE 5000 90 360 1807 1590 34.8 12.5 144 BXRC-50G1001-D-7x-SE 5000 90 350 1313 1155 26.0 9.1 144 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-57C1001-B-7x-SE 5700 70 270 1586 1395 34.8 9.4 169 BXRC-57C1001-C-7x-SE 5700 70 360 2114 1861 34.8 12.5 169 BXRC-57C1001-D-7x-SE 5700 70 350 1536 1351 26.0 9.1 169 BXRC-57E1001-B-7x-SE 5700 80 270 1506 1325 34.8 9.4 160 BXRC-57E1001-C-7x-SE 5700 80 360 2008 1767 34.8 12.5 160 BXRC-57E1001-D-7x-SE 5700 80 350 1459 1284 26.0 9.1 160 BXRC-65C1001-B-7x-SE 6500 70 270 1586 1395 34.8 9.4 169 BXRC-65C1001-C-7x-SE 6500 70 360 2114 1861 34.8 12.5 169 BXRC-65C1001-D-7x-SE 6500 70 350 1536 1351 26.0 9.1 169 BXRC-65E1001-B-7x-SE 6500 80 270 1524 1341 34.8 9.4 162 BXRC-65E1001-C-7x-SE 6500 80 360 2032 1788 34.8 12.5 162 BXRC-65E1001-D-7x-SE 6500 80 350 1476 1299 26.0 9.1 162 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A1001-B-73 3000 80 93 270 1022 899 34.3 9.3 110 BXRC-30A1001-C-73 3000 80 93 360 1362 1199 34.3 12.3 110 BXRC-30A1001-D-73 3000 80 93 350 989 871 25.5 8.9 111 BXRC-35A1001-B-73 3500 80 93 270 1088 957 34.3 9.3 117 BXRC-35A1001-C-73 3500 80 93 360 1450 1276 34.3 12.3 117 BXRC-35A1001-D-73 3500 80 93 350 1053 927 25.5 8.9 118 BXRC-40A1001-B-73 4000 80 93 270 1178 1037 34.3 9.3 127 BXRC-40A1001-C-73 4000 80 93 360 1571 1382 34.3 12.3 127 BXRC-40A1001-D-73 4000 80 93 350 1141 1004 25.5 8.9 128 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 137 BXRC-20B1001-B-73-SE 2000 65 270 1252 1102 33.8 9.1 BXRC-20B1001-D-73-SE 2000 65 350 1212 1067 25.3 8.9 137 BXRC-27E1000-B-7x-SE 2700 80 270 1276 1123 33.8 9.1 140 BXRC-27E1000-C-7x-SE 2700 80 360 1701 1497 33.8 12.2 140 BXRC-27E1000-D-7x-SE 2700 80 350 1235 1087 25.3 8.9 140 BXRC-27G10H0-B-7x-SE 2700 90 270 1092 961 33.8 9.1 120 BXRC-27G10H0-C-7x-SE 2700 90 360 1456 1282 33.8 12.2 120 BXRC-27G10H0-D-7x-SE 2700 90 350 1058 931 25.3 8.9 120 BXRC-27G1000-B-7x-SE 2700 90 270 1052 926 33.8 9.1 115 BXRC-27G1000-C-7x-SE 2700 90 360 1403 1235 33.8 12.2 115 BXRC-27G1000-D-7x-SE 2700 90 350 1019 897 25.3 8.9 115 BXRC-27H1000-B-7x-SE 2700 97 270 933 821 33.8 9.1 102 BXRC-27H1000-C-7x-SE 2700 97 360 1244 1095 33.8 12.2 102 BXRC-27H1000-D-7x-SE 2700 97 350 903 795 25.3 8.9 102 BXRC-30C1001-B-74-SE 3000 70 270 1419 1249 33.8 9.1 155 BXRC-30C1001-C-74-SE 3000 70 360 1892 1665 33.8 12.2 155 BXRC-30C1001-D-74-SE 3000 70 350 1374 1210 25.3 8.9 155 BXRC-30E1000-B-7x-SE 3000 80 270 1355 1193 33.8 9.1 148 BXRC-30E1000-C-7x-SE 3000 80 360 1807 1590 33.8 12.2 148 BXRC-30E1000-D-7x-SE 3000 80 350 1313 1155 25.3 8.9 148 BXRC-30G10H0-B-7x-SE 3000 90 270 1148 1010 33.8 9.1 126 BXRC-30G10H0-C-7x-SE 3000 90 360 1531 1347 33.8 12.2 126 BXRC-30G10H0-D-7x-SE 3000 90 350 1112 979 25.3 8.9 126 BXRC-30G1000-B-7x-SE 3000 90 270 1100 968 33.8 9.1 120 BXRC-30G1000-C-7x-SE 3000 90 360 1467 1291 33.8 12.2 120 120 BXRC-30G1000-D-7x-SE 3000 90 350 1066 938 25.3 8.9 BXRC-30G100C-B-73-SE 3000 90 270 1060 933 34.0 9.2 115 BXRC-30G100C-D-73-SE 3000 90 350 1027 904 25.3 8.9 116 BXRC-30H1000-B-7x-SE 3000 97 270 997 877 33.8 9.1 109 BXRC-30H1000-C-7x-SE 3000 97 360 1329 1169 33.8 12.2 109 BXRC-30H1000-D-7x-SE 3000 97 350 965 849 25.3 8.9 109 7,8 BXRC-30A1001-B-73-SE 3000 93 270 989 870 33.8 9.1 108 BXRC-30A1001-C-73-SE7,8 3000 93 360 1318 1160 33.8 12.2 108 BXRC-30A1001-D-73-SE7,8 3000 93 350 958 843 25.3 8.9 108 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E1000-B-7x-SE 3500 80 270 1387 1221 33.8 9.1 152 BXRC-35E1000-C-7x-SE 3500 80 360 1850 1628 33.8 12.2 152 BXRC-35E1000-D-7x-SE 3500 80 350 1344 1182 25.3 8.9 152 BXRC-35G1000-B-7x-SE 3500 90 270 1140 1003 33.8 9.1 125 BXRC-35G1000-C-7x-SE 3500 90 360 1520 1338 33.8 12.2 125 BXRC-35G1000-D-7x-SE 3500 90 350 1104 972 25.3 8.9 125 BXRC-35A1001-B-73-SE7,8 3500 93 270 1052 926 33.8 9.1 115 BXRC-35A1001-C-73-SE7,8 3500 93 360 1403 1235 33.8 12.2 115 BXRC-35A1001-D-73-SE7,8 3500 93 350 1019 897 25.3 8.9 115 BXRC-40C1001-B-74-SE 4000 70 270 1459 1284 33.8 9.1 160 BXRC-40C1001-C-74-SE 4000 70 360 1945 1712 33.8 12.2 160 BXRC-40C1001-D-74-SE 4000 70 350 1413 1244 25.3 8.9 160 BXRC-40E1000-B-7x-SE 4000 80 270 1395 1228 33.8 9.1 153 BXRC-40E1000-C-7x-SE 4000 80 360 1860 1637 33.8 12.2 153 BXRC-40E1000-D-7x-SE 4000 80 350 1351 1189 25.3 8.9 153 BXRC-40G1000-B-7x-SE 4000 90 270 1164 1024 33.8 9.1 127 BXRC-40G1000-C-7x-SE 4000 90 360 1552 1366 33.8 12.2 127 BXRC-40G1000-D-7x-SE 4000 90 350 1127 992 25.3 8.9 127 BXRC-40H1000-B-7x-SE 4000 97 270 1052 926 33.8 9.1 115 115 BXRC-40H1000-C-7x-SE 4000 97 360 1403 1235 33.8 12.2 BXRC-40H1000-D-7x-SE 4000 97 350 1019 897 25.3 8.9 115 BXRC-40A1001-B-73-SE7,8 4000 93 270 1140 1003 33.8 9.1 125 BXRC-40A1001-C-73-SE7,8 4000 93 360 1520 1338 33.8 12.2 125 BXRC-40A1001-D-73-SE7,8 4000 93 350 1104 972 25.3 8.9 125 BXRC-50C1001-B-7x-SE 5000 70 270 1467 1291 33.8 9.1 161 161 BXRC-50C1001-C-7x-SE 5000 70 360 1956 1721 33.8 12.2 BXRC-50C1001-D-7x-SE 5000 70 350 1421 1250 25.3 8.9 161 BXRC-50E1001-B-7x-SE 5000 80 270 1411 1242 33.8 9.1 154 BXRC-50E1001-C-7x-SE 5000 80 360 1882 1656 33.8 12.2 154 BXRC-50E1001-D-7x-SE 5000 80 350 1367 1203 25.3 8.9 154 BXRC-50G1001-B-7x-SE 5000 90 270 1220 1073 33.8 9.1 134 BXRC-50G1001-C-7x-SE 5000 90 360 1626 1431 33.8 12.2 134 BXRC-50G1001-D-7x-SE 5000 90 350 1181 1040 25.3 8.9 133 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-57C1001-B-7x-SE 5700 70 270 1427 1256 33.8 9.1 156 BXRC-57C1001-C-7x-SE 5700 70 360 1903 1675 33.8 12.2 156 BXRC-57C1001-D-7x-SE 5700 70 350 1382 1216 25.3 8.9 156 BXRC-57E1001-B-7x-SE 5700 80 270 1355 1193 33.8 9.1 148 BXRC-57E1001-C-7x-SE 5700 80 360 1807 1590 33.8 12.2 148 BXRC-57E1001-D-7x-SE 5700 80 350 1313 1155 25.3 8.9 148 BXRC-65C1001-B-7x-SE 6500 70 270 1427 1256 33.8 9.1 156 156 BXRC-65C1001-C-7x-SE 6500 70 360 1903 1675 33.8 12.2 BXRC-65C1001-D-7x-SE 6500 70 350 1382 1216 25.3 8.9 156 BXRC-65E1001-B-7x-SE 6500 80 270 1371 1207 33.8 9.1 150 BXRC-65E1001-C-7x-SE 6500 80 360 1828 1609 33.8 12.2 150 BXRC-65E1001-D-7x-SE 6500 80 350 1328 1169 25.3 8.9 150 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 9 Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-20B1001-B-73-SE 65 BXRC-20B1001-D-73-SE 65 BXRC-27E1000-B-7x-SE 80 BXRC-27E1000-C-7x-SE 80 BXRC-27E1000-D-7x-SE 80 BXRC-27G10H0-B-7x-SE 90 BXRC-27G10H0-C-7x-SE 90 BXRC-27G10H0-D-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 4.5 6.1 9.4 14.7 20.3 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 741 972 1391 2040 2614 719 944 1347 1983 2540 755 990 1417 2079 2664 1005 1316 1890 2752 3515 733 962 1373 2021 2589 647 848 1214 1781 2281 860 1127 1618 2356 3010 628 823 1175 1730 2217 666 872 1252 1815 2314 654 848 1212 1710 2139 679 888 1276 1850 2358 897 1169 1701 2391 3009 666 865 1235 1743 2180 581 761 1355 1584 2019 768 1001 1807 2047 2577 571 740 1313 1492 1867 166 160 148 139 129 165 159 148 138 128 169 164 151 142 131 169 163 151 141 130 168 162 151 141 130 145 140 129 121 113 144 140 129 121 111 144 139 129 120 111 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G1000-B-7x-SE 90 BXRC-27G1000-C-7x-SE 90 BXRC-27G1000-D-7x-SE 90 BXRC-27H1000-B-7x-SE 97 BXRC-27H1000-C-7x-SE 97 BXRC-27H1000-D-7x-SE 97 BXRC-30C1001-B-7x-SE 70 BXRC-30C1001-C-7x-SE 70 BXRC-30C1001-D-7x-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 623 817 1169 1716 2198 829 1086 1559 2270 2900 605 793 1133 1667 2136 552 724 1036 1521 1948 735 963 1382 2012 2571 536 703 1004 1478 1893 840 1102 1577 2313 2964 1118 1464 2103 3062 3911 815 1070 1527 2248 2880 560 733 1052 1526 1945 740 965 1403 1972 2483 550 713 1019 1438 1798 496 650 933 1353 1724 656 855 1244 1748 2200 487 632 903 1274 1594 755 988 1419 2058 2623 997 1301 1892 2660 3348 741 962 1374 1939 2425 140 135 124 117 108 139 135 124 116 107 139 134 124 116 107 124 120 110 104 96 123 119 110 103 95 123 119 110 103 95 188 182 168 158 146 188 181 168 157 145 187 181 168 156 145 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30E1000-B-7x-SE 80 BXRC-30E1000-C-7x-SE 80 BXRC-30E1000-D-7x-SE 80 BXRC-30G10H0-B-7x-SE 90 BXRC-30G10H0-C-7x-SE 90 BXRC-30G10H0-D-7x-SE 90 BXRC-30G1000-B-7x-SE 90 BXRC-30G1000-C-7x-SE 90 BXRC-30G1000-D-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 803 1052 1506 2209 2831 1068 1399 2008 2924 3735 779 1022 1459 2147 2751 680 891 1276 1872 2398 904 1185 1701 2477 3164 660 865 1235 1819 2330 651 854 1223 1794 2298 867 1135 1630 2374 3032 632 829 1184 1743 2233 721 944 1355 1965 2505 953 1243 1807 2540 3197 708 919 1313 1852 2316 611 799 1148 1665 2122 807 1052 1531 2152 2708 600 778 1112 1568 1962 585 766 1100 1595 2034 773 1009 1467 2062 2595 575 746 1066 1503 1880 180 174 160 151 140 179 173 160 150 138 179 173 160 149 138 152 147 136 128 118 152 147 136 127 117 151 146 136 127 117 146 141 130 122 113 145 141 130 121 112 145 140 130 121 112 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G100C-B-73-SE 90 BXRC-30G100C-D-73-SE 90 BXRC-30H1000-B-7x-SE 97 BXRC-30H1000-C-7x-SE 97 BXRC-30H1000-D-7x-SE 97 BXRC-30A1001-B-73 93 BXRC-30A1001-C-73 93 BXRC-30A1001-D-73 93 BXRC-35E1000-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 4.5 6.1 9.4 14.7 20.3 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 628 823 1178 1729 2214 609 799 1141 1680 2152 590 774 1107 1625 2081 785 1028 1476 2150 2746 573 751 1072 1579 2022 585 768 1099 1612 2065 779 1020 1465 2133 2724 568 745 1064 1566 2006 821 1077 1541 2261 2897 564 738 1060 1538 1960 554 719 1027 1449 1812 530 694 997 1445 1842 700 914 1329 1868 2351 521 675 965 1362 1703 526 688 989 1434 1827 695 906 1318 1853 2332 517 670 958 1351 1689 738 966 1387 2012 2564 141 136 125 118 109 140 135 125 117 108 132 128 118 111 103 132 127 118 110 102 131 127 118 110 102 131 127 117 110 102 131 126 117 109 101 130 126 117 109 101 184 178 164 154 143 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35E1000-C-7x-SE 80 BXRC-35E1000-D-7x-SE 80 BXRC-35G1000-B-7x-SE 90 BXRC-35G1000-C-7x-SE 90 BXRC-35G1000-D-7x-SE 90 BXRC-35A1001-B-73-SE 93 BXRC-35A1001-C-73-SE 93 BXRC-35A1001-D-73-SE 93 BXRC-40C1001-B-7x-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 1093 1432 2055 2993 3823 797 1046 1493 2197 2815 675 885 1267 1859 2381 898 1177 1689 2460 3142 655 859 1227 1806 2314 623 817 1169 1716 2198 829 1086 1559 2270 2900 605 793 1133 1667 2136 864 1133 1621 2378 3047 975 1272 1850 2600 3272 725 940 1344 1895 2371 607 794 1140 1653 2107 801 1045 1520 2137 2689 596 773 1104 1558 1948 560 733 1052 1526 1945 740 965 1403 1972 2483 550 713 1019 1438 1798 776 1016 1459 2116 2697 183 177 164 153 142 183 177 164 153 142 151 146 135 127 117 151 146 135 126 116 150 145 135 126 116 140 135 124 117 108 139 135 124 116 107 139 134 124 116 107 194 187 173 162 150 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40C1001-C-7x-SE 70 BXRC-40C1001-D-7x-SE 70 BXRC-40E1000-B-7x-SE 80 BXRC-40E1000-C-7x-SE 70 BXRC-40E1000-D-7x-SE 70 BXRC-40G1000-B-7x-SE 80 BXRC-40G1000-C-7x-SE 80 BXRC-40G1000-D-7x-SE 80 BXRC-40H1000-B-7X-SE 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 1149 1506 2162 3148 4021 838 1100 1570 2311 2961 826 1083 1550 2274 2914 1099 1440 2067 3010 3845 802 1052 1501 2210 2831 689 904 1293 1898 2431 917 1201 1725 2511 3208 669 877 1253 1844 2362 623 817 1169 1716 2198 1025 1338 1945 2734 3442 762 989 1413 1993 2493 742 972 1395 2023 2579 981 1279 1860 2615 3291 729 946 1351 1906 2384 619 811 1164 1688 2152 818 1067 1552 2182 2746 608 789 1127 1590 1989 560 733 1052 1526 1945 193 186 173 161 149 192 186 173 161 149 185 179 165 155 144 184 178 165 154 142 184 178 165 154 142 154 149 138 129 120 154 149 138 128 119 153 148 138 128 119 140 135 124 117 108 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40H1000-C-7x-SE 97 BXRC-40H1000-D-7x-SE 97 BXRC-40A1001-B-73-SE 93 BXRC-40A1001-C-73-SE 93 BXRC-40A1001-D-73-SE 93 BXRC-50C1001-B-7x-SE 70 BXRC-50C1001-C-7x-SE 70 BXRC-50C1001-D-7x-SE 70 BXRC-50E1001-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 829 1086 1559 2270 2900 605 793 1133 1667 2136 675 885 1267 1859 2381 898 1177 1689 2460 3142 655 859 1227 1806 2314 869 1139 1630 2391 3064 1156 1514 2173 3165 4043 843 1106 1579 2324 2977 836 1096 1568 2300 2947 740 965 1403 1972 2483 550 713 1019 1438 1798 607 794 1140 1653 2107 801 1045 1520 2137 2689 596 773 1104 1558 1948 781 1022 1467 2127 2712 1031 1345 1956 2749 3461 766 994 1421 2004 2507 751 983 1411 2046 2608 139 135 124 116 107 139 134 124 116 107 151 146 135 127 117 151 146 135 126 116 150 145 135 126 116 195 188 173 163 151 194 188 173 162 150 193 187 173 162 150 187 181 167 157 145 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50E1001-C-7x-SE 80 BXRC-50E1001-D-7x-SE 80 BXRC-50G1001-B-7x-SE 90 BXRC-50G1001-C-7x-SE 90 BXRC-50G1001-D-7x-SE 90 BXRC-57C1001-B-7x-SE 70 BXRC-57C1001-C-7x-SE 70 BXRC-57C1001-D-7x-SE 70 BXRC-57E1001-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 1112 1456 2091 3044 3889 811 1064 1519 2235 2864 722 947 1355 1988 2548 961 1259 1807 2632 3362 701 920 1313 1932 2476 845 1108 1586 2326 2980 1124 1473 2114 3079 3933 820 1076 1536 2261 2896 803 1052 1506 2209 2831 992 1294 1882 2645 3329 737 956 1367 1928 2412 649 849 1220 1769 2255 857 1118 1626 2286 2877 637 827 1181 1666 2085 759 994 1427 2070 2638 1003 1308 1903 2675 3366 746 967 1382 1950 2439 721 944 1355 1965 2505 187 180 167 156 144 186 180 167 156 144 162 156 144 136 126 161 156 144 135 125 161 155 144 134 124 189 183 169 159 147 189 182 169 157 146 188 182 169 157 146 180 174 160 151 140 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E1001-C-7x-SE 80 BXRC-57E1001-D-7x-SE 80 BXRC-65C1001-B-7x-SE 70 BXRC-65C1001-C-7x-SE 70 BXRC-65C1001-D-7x-SE 70 BXRC-65E1001-B-7x-SE 80 BXRC-65E1001-C-7x-SE 80 BXRC-65E1001-D-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 135 180 270 405 540 180 240 360 540 720 175 233 350 525 700 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 33.1 33.6 34.8 36.2 37.5 33.1 33.6 34.8 36.2 37.5 24.9 25.4 26.0 27.4 28.4 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 4.5 6.1 9.4 14.7 20.3 6.0 8.1 12.5 19.5 27.0 4.4 5.9 9.1 14.4 19.9 1068 1399 2008 2924 3735 779 1022 1459 2147 2751 845 1108 1586 2326 2980 1124 1473 2114 3079 3933 820 1076 1536 2261 2896 812 1065 1524 2235 2864 1080 1415 2032 2958 3779 788 1034 1476 2172 2783 953 1243 1807 2540 3197 708 919 1313 1852 2316 759 994 1427 2070 2638 1003 1308 1903 2675 3366 746 967 1382 1950 2439 730 955 1371 1989 2535 964 1257 1828 2570 3235 716 929 1328 1873 2343 179 173 160 150 138 179 173 160 149 138 189 183 169 159 147 189 182 169 157 146 188 182 169 157 146 182 176 162 152 141 181 175 162 151 140 181 175 162 151 140 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.49 30.9 38.5 -16.1 0.56 33.4 41.4 37.4 -16.1 0.37 30.9 38.5 37.5 40.3 -16.1 0.45 33.4 41.4 24.1 26.0 28.0 -11.8 0.49 23.1 28.7 26.3 28.4 30.5 -11.8 0.57 25.3 31.3 Minimum Typical Maximum 270 32.2 34.8 37.4 -16.1 540 34.7 37.5 40.3 360 32.2 34.8 720 34.7 350 700 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 19 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 270 RG1 RG1 RG1 RG1 405 RG1 RG1 RG1 RG2 540 RG1 RG1 RG2 RG2 360 RG1 RG1 RG1 RG2 540 RG1 RG1 RG2 RG2 720 RG1 RG2 RG2 RG2 350 RG1 RG1 RG1 RG1 525 RG1 RG1 RG1 RG2 700 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero SE Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 20 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE Maximum Drive Current3 540mA 720mA 700mA Maximum Peak Pulsed Drive Current4 770mA 1030mA 1000mA Maximum Reverse Voltage5 -60V -60V -45V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN120: Assembly Considerations for Bridgelux Vero SE LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 21 Performance Curves Figure 1: Vero SE 10B Drive Current vs. Voltage Figure 2: Vero SE 10C Drive Current vs. Voltage 600 800 700 400 Forward Current (mA) Forward Current (mA) 500 300 200 100 600 500 400 300 200 100 0 32 33 34 35 36 0 38 37 32 33 34 35 Forward Voltage (V) Figure 3: Vero SE 10D Drive Current vs. Voltage 180% 160% 600 Relative Luminous Flux Forward Current (mA) 38 200% 700 500 400 300 200 140% 120% 100% 80% 60% 40% 100 20% 24 25 26 27 28 0% 29 0 100 200 Forward Voltage (V) 300 400 500 600 Forward Current (mA) Figure 5: Vero 10C SE Typical Relative Flux vs. Current Figure 6 Vero 10D SE Typical Relative Flux vs. Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 37 Figure 4: Vero 10B SE Typical Relative Flux vs. Current 800 0 36 Forward Voltage (V) 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0% 0 100 200 300 400 500 Forward Current (mA) 600 700 800 0 100 200 300 400 500 600 700 800 Forward Current (mA) Notes for Figure 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 22 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature Figure 7: Typical DC Flux vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 Neutral White Cool White 25°C Pulsed 125 Case Temperature (°C) Case Temperature (°C) Figure 10: 2000K, 65 CRI Color Shift vs. Case Temperature Figure 9: Typical DC ccx Shift vs. Case Temperature 0.4101 0 25 50 75 100 0.41 125 0.000 0.4099 0.4098 -0.002 Pulsed Center Point Tc=25°C 15°C 25°C 0.4097 ccy ccx Shift -0.004 -0.006 65°C 0.4093 Warm White -0.012 0.4095 0.4094 -0.008 -0.010 45°C 0.4096 Neutral White 85°C 0.4092 Cool White 25°C Pulsed 105°C 0.4091 Case Temperature (°C) 0.409 0.525 0.526 0.527 0.528 0.529 0.53 0.531 0.532 ccx Notes for Figures 7 - 9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 23 Performance Curves Figure 11: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 12: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.4572 0.4574 0.4576 0.4578 0.3950 0.4323 0.458 0.4328 0.4333 0.4338 ccx 0.369 15°C Pulsed Center Point Tc=25°C 25°C 25°C 0.367 0.366 45°C ccy ccy 15°C 0.368 0.401 0.399 0.4353 Figure 14: 3000K Class A Color Shift vs. Case Temperature1 0.403 0.4 0.4348 ccx Figure 13: 3000K, 90 CRI Color Shift vs. Case Temperature1,3 0.402 0.4343 65°C 0.398 45°C 0.365 0.364 70°C 0.363 85°C 0.397 Pulsed Center Point Tc=25°C 85°C 0.362 105°C 0.396 0.395 0.444 0.361 0.4445 0.445 0.4455 0.446 0.4465 105°C 0.36 0.416 0.447 0.4165 0.417 ccx 0.4175 0.418 0.4185 ccx Figure 15: 3500K Class A Color Shift vs. Case Temperature1 Figure 16: 4000K Class A Color Shift vs. Case Temperature1 0.37 0.3760 15°C 0.368 25°C 0.366 Pulsed Center Point Tc=25°C 15°C 0.3740 25°C 0.3720 45°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.364 0.3680 70°C 0.362 85°C 0.3660 0.36 85°C 0.3640 105°C 0.358 0.392 70°C 105°C 0.393 0.394 0.395 0.396 0.397 ccx Note for Figures 10-16: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRC-30G100C-x-73-SE 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 24 Typical Radiation Pattern Figure 17: Typical Spatial Radiation Pattern Note for Figure 17: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 18: Typical Polar Radiation Pattern 25 Typical Color Spectrum Figure 19: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 19: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 20: Typical Color Spectrum for Vero SE 10 with Décor Series 1 20B 27H 0.9 30G (Décor Series Showcase) 30H Relative Spectral Power Distribution 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 20: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 26 Mechanical Dimensions Figure 21: Drawing for Vero SE 10 LED Array Notes for Figure 21: 1. Drawings are not to scale. 2. Dimensions are in mm. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 19.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 27 Color Binning Information Figure 22: Warm and Neutral White Test Bins in xy Color Figure 23: Cool White Test Bins in xy Color Space Space 0.44 0.39 4 SDCM 3 SDCM 2000K 3SDCM 2 SDCM 0.42 2700K 0.37 3000K 5000K 0.36 3500K 0.4 3 SDCM 0.38 5700K 0.35 Y Y 4000K 0.34 0.38 6500K 0.33 0.36 0.32 0.31 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code1 2000K 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5280, 0.4100) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5481K - 5829K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 28 Packaging and Labeling Figure 24: Drawing for Vero SE 10 Packaging Tray Notes for Figure 24: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 29 Packaging and Labeling Figure 25: Vero SE Series Packaging and Labeling Notes for Figure 25: 1. Each tray holds 200 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 26: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number, Vf bin and other Bridgelux internal production information. Customer Use- Product part number 30E1000C 72 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 30 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN121 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 31 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series, V Series HD and are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vero SE 10 Array Series Product Data Sheet DS120 Rev. L (03/2019) 32
BXRC-50E1001-C-74-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-50E1001-C-74-SE”相匹配的价格&库存,您可以联系我们找货
