BXRE-40G0800-D-83
BXRE-40G0800-D-83
    BRIDGELUX(普瑞)
BXRE-40G0800-D-83 数据手册
Bridgelux Gen 8 V8 Array ® Product Data Sheet DS411 1 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These chip on board (CoB) arrays can be efficiently driven up to three times the nominal drive current, enabling design flexibility not previously possible. These high flux density light sources are designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for both interior and exterior commercial and residential applications. The V8 LED Array is available in a variety of electrical, CCT, and CRI combinations providing substantial design flexibility and energy efficiency advantages. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and a longer service life. Typical applications include replacement lamps and task, accent, spot, track, wide area, security, wall packs and down lights. Features Benefits • Efficacy of 178 lm/W typical for 3000K, 80 CRI • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform, high quality illumination • High quality, true color reproduction • Minimum 70, 80, and 90 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 2, 3 and 4 SDCM standard • Uniform, consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issues • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 5 Electrical Characteristics 10 Eye Safety 11 Absolute Maximum Ratings 12 Performance Curves 13 Typical Color Spectrum 15 Typical Radiation Pattern 16 Mechanical Dimensions 17 Color Binning Information 18 Packaging and Labeling 19 Design Resources 21 Precautions 21 Disclaimers 21 About Bridgelux 22 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact CoB devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Solder pads Case Temperature (Tc) Measurement Point White ring around LES Yellow phosphor Light Emitting Surface (LES) Fully engineered substrate for consistent thermal, mechanical and optical properties Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 G 080 0 – D – 82 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen. 8 Array Configuration 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator Minimum CRI C = 70 CRI E = 80 CRI G = 90 CRI Flux Indicator 080x = 800lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) 300 842 150 842 90 300 695 90 150 695 3000 70 300 937 3000 70 150 937 BXRE-30E0800-D-8x 3000 80 300 895 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) BXRE-27E0800-D-8x 2700 80 BXRE-27E0800-E-8x 2700 80 BXRE-27G0800-D-8x 2700 BXRE-27G0800-E-8x 2700 BXRE-30C0801-D-8x BXRE-30C0801-E-8x Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 741 16.8 5.0 167 741 33.5 5.0 168 612 16.8 5.0 138 612 33.5 5.0 138 825 16.8 5.0 186 825 33.5 5.0 186 788 16.8 5.0 178 BXRE-30E0800-E-8x 3000 80 150 895 788 33.5 5.0 178 BXRE-30G0800-D-8x 3000 90 300 727 639 16.8 5.0 144 BXRE-30G0800-E-8x 3000 90 150 727 639 33.5 5.0 145 BXRE-35E0800-D-8x 3500 80 300 916 806 16.8 5.0 182 BXRE-35E0800-E-8x 3500 80 150 916 806 33.5 5.0 182 BXRE-35G0800-D-8x 3500 90 300 753 663 16.8 5.0 149 BXRE-35G0800-E-8x 3500 90 150 753 663 33.5 5.0 150 BXRE-40C0801-D-8x 4000 70 300 963 848 16.8 5.0 191 BXRE-40C0801-E-8x 4000 70 150 963 848 33.5 5.0 192 BXRE-40E0800-D-8x 4000 80 300 921 811 16.8 5.0 183 BXRE-40E0800-E-8x 4000 80 150 921 811 33.5 5.0 183 BXRE-40G0800-D-8x 4000 90 300 769 676 16.8 5.0 153 BXRE-40G0800-E-8x 4000 90 150 769 676 33.5 5.0 153 BXRE-50C0801-D-8x 5000 70 300 969 852 16.8 5.0 192 BXRE-50C0801-E-8x 5000 70 150 969 852 33.5 5.0 193 BXRE-50E0801-D-8x 5000 80 300 932 820 16.8 5.0 185 BXRE-50E0801-E-8x 5000 80 150 932 820 33.5 5.0 185 BXRE-50G0801-D-8x 5000 90 300 806 709 16.8 5.0 160 BXRE-50G0801-E-8x 5000 90 150 806 709 33.5 5.0 160 BXRE-57C0801-D-8x 5700 70 300 942 829 16.8 5.0 187 BXRE-57C0801-E-8x 5700 70 150 942 829 33.5 5.0 188 BXRE-57E0801-D-8x 5700 80 300 895 788 16.8 5.0 178 BXRE-57E0801-E-8x 5700 80 150 895 788 33.5 5.0 178 BXRE-65C0801-D-8x 6500 70 300 942 829 16.8 5.0 187 BXRE-65C0801-E-8x 6500 70 150 942 829 33.5 5.0 188 BXRE-65E0801-D-8x 6500 80 300 906 797 16.8 5.0 180 BXRE-65E0801-E-8x 6500 80 150 906 797 33.5 5.0 180 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI values are minimums and tested at Tj = Tc = 25°C. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-27E0800-D-8x 2700 80 300 758 667 16.5 4.9 154 BXRE-27E0800-E-8x 2700 80 150 758 667 32.9 4.9 154 BXRE-27G0800-D-8x 2700 90 300 625 550 16.5 4.9 127 BXRE-27G0800-E-8x 2700 90 150 625 550 32.9 4.9 127 BXRE-30C0801-D-8x 3000 70 300 843 742 16.5 4.9 171 BXRE-30C0801-E-8x 3000 70 150 843 742 32.9 4.9 171 BXRE-30E0800-D-8x 3000 80 300 806 709 16.5 4.9 163 BXRE-30E0800-E-8x 3000 80 150 806 709 32.9 4.9 163 BXRE-30G0800-D-8x 3000 90 300 654 575 16.5 4.9 132 BXRE-30G0800-E-8x 3000 90 150 654 575 32.9 4.9 132 BXRE-35E0800-D-8x 3500 80 300 824 726 16.5 4.9 167 BXRE-35E0800-E-8x 3500 80 150 824 726 32.9 4.9 167 BXRE-35G0800-D-8x 3500 90 300 678 596 16.5 4.9 137 BXRE-35G0800-E-8x 3500 90 150 678 596 32.9 4.9 137 BXRE-40C0801-D-8x 4000 70 300 867 763 16.5 4.9 176 BXRE-40C0801-E-8x 4000 70 150 867 763 32.9 4.9 176 BXRE-40E0800-D-8x 4000 80 300 829 730 16.5 4.9 168 BXRE-40E0800-E-8x 4000 80 150 829 730 32.9 4.9 168 BXRE-40G0800-D-8x 4000 90 300 692 609 16.5 4.9 140 BXRE-40G0800-E-8x 4000 90 150 692 609 32.9 4.9 140 BXRE-50C0801-D-8x 5000 70 300 872 767 16.5 4.9 177 BXRE-50C0801-E-8x 5000 70 150 872 767 32.9 4.9 177 BXRE-50E0801-D-8x 5000 80 300 839 738 16.5 4.9 170 BXRE-50E0801-E-8x 5000 80 150 839 738 32.9 4.9 170 BXRE-50G0801-D-8x 5000 90 300 725 638 16.5 4.9 147 BXRE-50G0801-E-8x 5000 90 150 725 638 32.9 4.9 147 BXRE-57C0801-D-8x 5700 70 300 848 746 16.5 4.9 172 BXRE-57C0801-E-8x 5700 70 150 848 746 32.9 4.9 172 BXRE-57E0801-D-8x 5700 80 300 806 709 16.5 4.9 163 BXRE-57E0801-E-8x 5700 80 150 806 709 32.9 4.9 163 BXRE-65C0801-D-8x 6500 70 300 848 746 16.5 4.9 172 BXRE-65C0801-E-8x 6500 70 150 848 746 32.9 4.9 172 BXRE-65E0801-D-8x 6500 80 300 815 717 16.5 4.9 165 BXRE-65E0801-E-8x 6500 80 150 815 717 32.9 4.9 165 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI values are minimums and tested at Tj = Tc = 25°C. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 4 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 and 2 and the flux vs. current characteristics shown in Figure 3 and 4. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRE-27E0800-D-8x 80 BXRE-27E0800-E-8x 80 BXRE-27G0800-D-8x 90 BXRE-27G0800-E-8x 90 BXRE-30C0801-D-8x 70 BXRE-30C0801-E-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 438 640 842 966 1342 2466 438 627 842 966 1342 2466 362 528 695 797 1107 2034 362 517 695 797 1107 2034 488 712 937 1075 1492 2743 488 697 937 1075 1492 2743 395 576 758 870 1207 2219 395 564 758 870 1207 2219 326 475 625 717 996 1831 326 465 625 717 996 1831 439 641 843 967 1343 2469 439 627 843 967 1343 2469 180 172 167 163 154 131 180 173 167 163 154 131 148 142 138 134 127 108 149 143 138 134 127 108 200 191 186 181 171 145 200 192 186 181 171 146 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRE-30E0800-D-8x 80 BXRE-30E0800-E-8x 80 BXRE-30G0800-D-8x 90 BXRE-30G0800-E-8x 90 BXRE-35E0800-D-8x 80 BXRE-35E0800-E-8x 80 BXRE-35G0800-D-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 466 680 895 1027 1425 2620 466 666 895 1027 1425 2620 378 552 727 833 1157 2127 378 541 727 833 1157 2127 477 696 916 1051 1459 2682 477 682 916 1051 1459 2682 392 572 753 864 1199 2204 419 612 806 924 1283 2358 419 599 806 924 1283 2358 340 497 654 750 1041 1914 340 486 654 750 1041 1914 429 626 824 946 1313 2414 429 613 824 946 1313 2414 353 515 678 777 1079 1984 191 183 178 173 163 139 191 184 178 173 164 139 155 148 144 140 132 113 155 149 144 141 133 113 196 187 182 177 167 142 196 188 182 177 167 142 161 154 149 145 137 117 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 6 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRE-35G0800-E-8x 90 BXRE-40C0801-D-8x 70 BXRE-40C0801-E-8x 70 BXRE-40E0800-D-8x 80 BXRE-40E0800-E-8x 80 BXRE-40G0800-D-8x 90 BXRE-40G0800-E-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 392 560 753 864 1199 2204 501 732 963 1105 1534 2820 501 717 963 1105 1534 2820 480 700 921 1057 1467 2697 480 685 921 1057 1467 2697 400 584 769 882 1224 2250 400 572 769 882 1224 2250 353 504 678 777 1079 1984 451 659 867 995 1381 2538 451 645 867 995 1381 2538 432 630 829 951 1321 2427 432 617 829 951 1321 2427 360 526 692 793 1102 2025 360 515 692 793 1102 2025 161 154 150 146 138 117 206 197 191 186 176 149 206 198 192 186 176 150 197 188 183 178 168 143 197 189 183 178 168 143 164 157 153 148 140 119 164 158 153 149 140 119 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRE-50C0801-D-8x 70 BXRE-50C0801-E-8x 70 BXRE-50E0801-D-8x 80 BXRE-50E0801-E-8x 80 BXRE-50G0801-D-8x 90 BXRE-50G0801-E-8x 90 BXRE-57C0801-D-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 504 736 969 1111 1543 2836 504 721 969 1111 1543 2836 485 708 932 1069 1484 2728 485 693 932 1069 1484 2728 419 612 806 924 1283 2358 419 599 806 924 1283 2358 491 716 942 1081 1501 2759 454 662 872 1000 1388 2552 454 649 872 1000 1388 2552 437 637 839 962 1336 2455 437 624 839 962 1336 2455 377 551 725 832 1155 2122 377 539 725 832 1155 2122 441 644 848 973 1351 2483 207 198 192 187 177 150 207 199 193 187 177 150 199 190 185 180 170 144 199 191 185 180 170 145 172 165 160 156 147 125 172 165 160 156 147 125 201 192 187 182 172 146 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRE-57C0801-E-8x 70 BXRE-57E0801-D-8x 80 BXRE-57E0801-E-8x 80 BXRE-65C0801-D-8x 70 BXRE-65C0801-E-8x 70 BXRE-65E0801-D-8x 80 BXRE-65E0801-E-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 150 225 300 350 500 1000 75 110 150 175 250 500 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 16.3 16.5 16.8 17.0 17.5 18.9 32.4 33.0 33.5 33.9 34.9 37.7 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 2.4 3.7 5.0 5.9 8.7 18.9 2.4 3.6 5.0 5.9 8.7 18.8 491 701 942 1081 1501 2759 466 680 895 1027 1425 2620 466 666 895 1027 1425 2620 491 716 942 1081 1501 2759 491 701 942 1081 1501 2759 471 688 906 1039 1442 2651 471 674 906 1039 1442 2651 441 631 848 973 1351 2483 419 612 806 924 1283 2358 419 599 806 924 1283 2358 441 644 848 973 1351 2483 441 631 848 973 1351 2483 424 619 815 935 1298 2386 424 606 815 935 1298 2386 202 193 187 182 172 146 191 183 178 173 163 139 191 184 178 173 164 139 201 192 187 182 172 146 202 193 187 182 172 146 193 185 180 175 165 140 194 186 180 175 165 141 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.79 15.1 18.4 -6.10 1.13 17.0 20.7 36.0 -10.81 0.79 30.1 36.7 40.5 -12.16 1.13 33.9 41.3 Minimum Typical Maximum 300 15.5 16.8 18.1 -5.42 1000 17.5 18.9 20.3 150 31.0 33.5 500 34.9 37.7 BXRE-xxx080x-D-8x BXRE-xxx080x-E-8x Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1140 V. The working voltage designated for the insulation is 70V d.c. The maximum allowable voltage across the array must be determined in the end product application. 10 Eye Safety Table 5: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx080x-D-8x BXRE-xxx080x-E-8x CCT4 Drive Current (mA) 2700K/3000K 4000K2 5000K3 6500K4 515 RG1 RG1 RG1 RG1 715 RG1 RG1 RG1 RG2 1000 RG1 RG1 RG2 RG2 260 RG1 RG1 RG1 RG1 360 RG1 RG1 RG1 RG2 500 RG1 RG1 RG2 RG2 Notes for Table 5: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 5000K Ethr= 1530 lx. 3. For products classified as RG2 at 6500K, Ethr= 1170 lx. 4. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 11 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx080x-D-8x BXRE-xxx080x-E-8x Maximum Drive Current3 1000 mA 500 mA Maximum Peak Pulsed Drive Current4 1120 mA 560 mA Maximum Reverse Voltage5 -30V -60V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 12 Performance Curves Figure 1: V8D Drive Current vs. Voltage (Tj = Tc = 25°C)1 Figure 2: V8E Drive Current vs. Voltage (Tj = Tc = 25°C)1 19.5 38.0 19.0 37.0 Voltage (V) Voltage (V) 18.5 18.0 17.5 17.0 36.0 35.0 34.0 33.0 16.5 32.0 16.0 0 200 400 600 800 1000 0 1200 100 Figure 3: V8D Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C)1 300 400 500 600 Figure 4: V8E Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C)1 350% 350% 300% Relative Luminous Flux (%) Relative Luminous Flux (%) 200 Drive Current (mA) Drive Current (mA) 250% 200% 150% 100% 50% 0% 0 200 400 600 Drive Current (mA) 800 1000 1200 300% 250% 200% 150% 100% 50% 0% 0 100 200 300 400 500 600 Drive Current (mA) Notes for Figures 1 - 4: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for 3000K and 90 CRI. 13 Performance Curves Figure 5: Typical DC Flux vs. Case Temperature Figure 6: Typical DC ccx Shift vs. Case Temperature 102% 0.0020 100% -0.0020 96% ccx shift Relative Luminous Flux 25C Pulsed 0.0000 98% 94% -0.0040 92% -0.0060 90% -0.0080 88% 86% 0 20 40 60 80 100 120 Case Temperature (Tc) -0.0100 0 20 40 60 80 100 120 Case Temperature (Tc) Figure 7: Typical DC ccy Shift vs. Case Temperature 0.0010 0.0000 -0.0010 ccy shift -0.0020 -0.0030 -0.0040 -0.0050 -0.0060 -0.0070 -0.0080 0 20 40 60 80 100 120 Case Temperature (Tc) 14 Typical Color Spectrum Figure 8: Typical Color Spectrum 100% 27E 30E 40E 50C 90% Relative Spectral Power Distribution 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 8: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 2700K and 80 CRI. 3. Color spectra shown is 3000K and 80 CRI. 4. Color spectra shown is 4000K and 80 CRI. 5. Color spectra shown is 5000K and 70 CRI. 15 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern Note for Figure 9: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 10: Typical Polar Radiation Pattern 16 Mechanical Dimensions Figure 11: V8 LED Array Notes for Figure 11: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Solder pads are labeled “+” and “-“ to denote positive and negative polarity, respectively. 4. Unless otherwise specified, tolerances are ±0.1mm. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 17 Color Binning Information Figure 12: Graph of Warm and Neutral White Test Bins Figure 13: Graph of Cool White Test Bins in xy Color in xy Color Space Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 7: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Table 8: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 84 (4 SDCM) (4801K - 5282K) (5481K - 5829K) (6270K - 6765K) 83 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 18 Packaging and Labeling Figure 14: Drawing for V8 Packaging Tube 8 Notes for Figure 14: 1. Each tube holds 40 V8 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 8.3mm (W) x 14.3mm (H) x 530mm (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 19 Packaging and Labeling Figure 15: Gen. 8 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E0800C 83 2F Internal Bin Code Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 20 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. Please contact your Bridgelux Sales Representative for more information. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representatives for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Use the mechanical features of the LED array housing and/or edges to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 21 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2020 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, V Series and Decor Series are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 V8 Array Series Product Data Sheet DS411 Rev. A (07/2020) 22
BXRE-40G0800-D-83 价格&库存
很抱歉,暂时无法提供与“BXRE-40G0800-D-83”相匹配的价格&库存,您可以联系我们找货
BXRE-40G0800-D-83
  • 600+13.70614600+1.75809
BXRE-40G0800-D-83
