BXDR-60BS-U220P-01-A
    BRIDGELUX(普瑞)
BXDR-60BS-U220P-01-A 数据手册
Bridgelux® Vesta® Flex Dual Channel 60W Driver Product Data Sheet DS 452 Vesta Flex Platform The Bridgelux Vesta Flex Dual Channel Driver and Control Module family is a bundled system, guaranteed to work together out of the box, that enables seamless control of the Bridgelux Vesta Series Tunable White Arrays and Modules. The Driver's high resolution dimming and tuning algorithm provides for smooth and flicker-free CCT tuning, dimming to 0.1%, and dim-to-off. These specification grade drivers and control modules are separate devices which, when connected via an ethernet cable, form a smart and flexible lighting control system. The platform offers a number of driver and control module options to choose from, enabling application flexibility and interoperability with third party systems. These different control modules support wired control protocols such as DALI-2 DT8 and 0-10V as well as wireless control protocols with WiFi and Bluetooth mesh. These platforms come with ready-built iOS and Android apps and web portals which provide for commissioning, light management, and services designed to expand the capability of modern lighting systems. Vesta Flex is a future-ready solution, designed to quickly adapt to new control systems without requiring luminaire recertification. Vesta Flex Platform Overview Vesta Flex Dual Channel Driver Partner App Partner Cloud Cloud Connector 3rd Party Cloud Partner Services Vesta Flex Control Module System Monitoring Commissioning Light Control Device Management Rules Setting Amazon Alexa Data Analytics Predictive Maintenance Asset Tracking Smart Buildings, BMS Systems Heat Mapping Vesta Flex Dual Channel Driver Features and Benefits • • • • • • • • • 120-277VAC/50-60Hz universal input voltage Side and bottom feed poke-in connector terminals Strain relief and stud mounting options Smooth, flicker free dimming and CCT tuning Each channel is dimmable to 0.1%, dim to dark NFC port for programming multiple driver settings Linear, square and logarithmic intensity dimming profiles RJ45 control port reliably connects with all Vesta Flex Control Modules Inter-operable with a large ecosystem of BLE mesh, Wi-Fi, DALI-2 DT8 and 0-10V devices and controls For more information on the Vesta Flex Dual Channel Driver and Control Module options, please visit www.bridgelux.com 1 Product Feature Map Bridgelux Vesta Flex Dual Channel 60W Driver provides two dynamic constant current outputs for dual channel CCT tunable LED modules and arrays. This Driver interoperates with industry standard lighting systems and protocols and allows for simple integration of Vesta Flex Tunable White Arrays and Linear modules. Please visit www.bridgelux.com for more information. NFC programming interface Control Port compatible with Vesta Flex Control Modules Slots for fastening driver Case temperature measurement point Tc Dual channel LED Output, side and bottom feed Universal input 120-277VAC, side and bottom feed Slots for mounting strain relief Product Nomenclature The part number designation for Bridgelux Vesta Flex Dual Channel 60W Driver is explained as follows: 1,2,3,4 BXDR Product Family 5 , 6 ,7,8, - 60xT 9,10,11,12,13, 14,15, 16 - U220P - 01 - A Product Generation A = Generation A BXDR = LED Driver Maximum Output Power 60 = 60W Product Version 01 = Standard Form Factor B = Brick S = Brick with mounting studs Control input P = PWM Connection Type T = Terminal Block S = Strain relief attached Input Voltage U = Universal (120-277VAC) Maximum Output Current x 100mA 20 = 2000mA Output Channels 2 = Dual Channel Table 1: Product Selection Guide Part Number Configuration BXDR-60BT-U220P-01-A Brick BXDR-60ST-U220P-01-A Brick with mounting studs BXDR-60BS-U220P-01-A Brick with strain relief attached Class 2 Class P 2 Electrical Characteristics Table 2: Electrical Characteristics Parameter Specification Input Voltage 120VAC to 277VAC ±10% Input Power 70W (max) Input Current 0.6A (max) Inrush Current Beneath NEMA 410-2011 limit Surge Protection 6kV per EN 61547: 2009 (IEC 61000-4-5: 2006) ESD Rating Class 3B, HBM Output Power 60W (max) Output Voltage per Channel 14 - 55V DC Output Current per Channel 1 2000mA (max) Output Current 1 from both Channels combined 2000mA (max) Output Current Tolerance ±1% at output loads ranging from 10% - 100% of max load Output Current Variation between Channels 2 ±5% Startup Time
BXDR-60BS-U220P-01-A 价格&库存
很抱歉,暂时无法提供与“BXDR-60BS-U220P-01-A”相匹配的价格&库存,您可以联系我们找货
