BXEB-L0560Z-40E2000-C-C3
    BRIDGELUX(普瑞)
BXEB-L0560Z-40E2000-C-C3 数据手册
Bridgelux EB Series™ Gen 3 ® Product Data Sheet DS132 EB Series™ Introduction EB Series Gen 3 linear modules are designed for use in premium indoor applications where a high efficacy is required. The new generation uses the high-efficacy SMDs to achieve over 200lm/W, which enables designers and fixture manufacturers to meet DLC Premium requirements. They are designed for linear troffers, pendants and other luminaires in indoor commercial applications. Available in 280 mm, 560 mm, and 1120 mm lengths, the modules can be connected end-to-end thereby providing flexibility in designing luminaires. The Zhaga compatible modules further simplify design by providing easy mounting options, reusable poke-in connectors and by being compatible with a variety of off-the-shelf optics. The modules have long lifetimes of greater than 50,000 hours. Features Benefits • High efficacy of up to 200 lm/W (nominal) • Achieve over 200 lm/W by under-driving • Now available in both 80 CRI and 90 CRI • Long lifetime (L80, B50 > 50,000 hours) • Available in a variety of color temperatures from 2700K to 5700K • Heat-sinking may not be required at low drive currents • Wide lumen range with 2x overdrive capability • • Designed following Zhaga standards L28W2 and L56W2 Reliable use at elevated currents for greater design flexibility • Easy installation using mounting holes and poke-in connectors Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Electrical Characteristics 4 Absolute Maximum Ratings 5 Performance Curves 6 Typical Radiation Pattern 8 Typical Color Spectrum 9 Mechanical Dimensions 10 Color Binning Information 12 Packaging and Labeling 13 Design Resources 14 Precautions 14 Disclaimers 14 About Bridgelux 15   1 Product Feature Map Bridgelux EB Series Gen 3 modules are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The linear products incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the EB Series family of products. Multiple case temperature measurement points Label containing part number and lot codes is attached on the front of the module where shown Re-usable connector Designed to comply with global safety standards for creepage and clearance distances Zhaga compatible mounting holes Product Nomenclature The part number designation for Bridgelux EB Series Gen 3 is explained as follows: 1 2 3 4 - 5 6 7 8 9 10 - 11 12 13 14 15 16 - 17 – 18 BXEB – L0280Z – 30 E 1000 – C – C3 Product Family Nominal Dimensions L= Linear 0280 = 280 mm 0560 = 560 mm 1120 = 1120 mm Z= Zhaga compatible width (24 mm) Module Version C = Gen 3 3 = 3 SDCM Module Configuration Nominal CCT 27 = 2700 K 30 = 3000 K 35 = 3500 K 40 = 4000 K 50 = 5000 K 57 = 5700 K Minimum CRI E = 80 G = 90 Flux Indicator 1000 = 1000 lm 2000 = 2000 lm 4000 = 4000 lm 2 Product Selection Guide Table 1: Product Performance (Tc = 25° C) Part Number BXEB-L0280Z-27E1000-C-C3 BXEB-L0280Z-27G1000-C-C3 BXEB-L0280Z-30E1000-C-C3 BXEB-L0280Z-30G1000-C-C3 BXEB-L0280Z-35E1000-C-C3 BXEB-L0280Z-35G1000-C-C3 BXEB-L0280Z-40E1000-C-C3 BXEB-L0280Z-40G1000-C-C3 BXEB-L0280Z-50E1000-C-C3 BXEB-L0280Z-50G1000-C-C3 BXEB-L0280Z-57E1000-C-C3 BXEB-L0280Z-57G1000-C-C3 BXEB-L0560Z-27E2000-C-C3 BXEB-L0560Z-27G2000-C-C3 BXEB-L0560Z-30E2000-C-C3 BXEB-L0560Z-30G2000-C-C3 BXEB-L0560Z-35E2000-C-C3 BXEB-L0560Z-35G2000-C-C3 BXEB-L0560Z-40E2000-C-C3 BXEB-L0560Z-40G2000-C-C3 BXEB-L0560Z-50E2000-C-C3 BXEB-L0560Z-50G2000-C-C3 BXEB-L0560Z-57E2000-C-C3 BXEB-L0560Z-57G2000-C-C3 BXEB-L1120Z-27E4000-C-C3 BXEB-L1120Z-27G4000-C-C3 BXEB-L1120Z-30E4000-C-C3 BXEB-L1120Z-30G4000-C-C3 BXEB-L1120Z-35E4000-C-C3 BXEB-L1120Z-35G4000-C-C3 BXEB-L1120Z-40E4000-C-C3 BXEB-L1120Z-40G4000-C-C3 BXEB-L1120Z-50E4000-C-C3 BXEB-L1120Z-50G4000-C-C3 BXEB-L1120Z-57E4000-C-C3 BXEB-L1120Z-57G4000-C-C3 Nominal Min 1 CRI CCT (K) 2700 3000 3500 4000 5000 5700 2700 3000 3500 4000 5000 5700 2700 3000 3500 4000 5000 5700 Typical Flux2,3 Tc = 25º C (lm) Nominal Drive Current (mA) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 80 1190 178 90 1045 156 80 1250 187 90 1100 164 80 1250 187 90 1100 80 1340 90 1100 164 80 1340 200 90 1100 164 80 1340 200 350 19.1 6.7 164 200 90 1100 164 80 2380 178 90 2085 156 80 2490 186 90 2195 164 80 2490 186 90 2195 80 2675 700 19.1 13.4 164 200 90 2195 164 80 2675 200 90 2195 164 80 2675 200 90 2195 164 80 4760 178 90 4160 155 80 4980 186 90 4390 164 80 4980 186 90 4390 80 5350 700 38.3 26.8 164 200 90 4390 164 80 5350 200 90 4390 164 80 5350 200 90 4390 164 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. Data is at nominal test current where temperature of center case temperature point Tc= 25° C. 3. Bridgelux maintains a ± 7% tolerance on flux data. 3 Electrical Characteristics Table 2: Electrical Characteristics Forward Voltage Tc2 Part Number Driver Selection Typical Coefficient of Forward = 25º C (V) 1, 2,3 Drive Current (mA) Voltages5 (V) Voltage4 Minimum Typical Maximum ∆Vf/∆T (mV/º C) Vf Min, Hot Tc2 = 85º C (V) Vf Max, Cold Tc2 = -40º C (V) 350 17.8 19.1 20.4 -7.2 17.3 20.9 700 18.8 20.2 21.6 -7.2 18.4 22.1 700 17.8 19.1 20.4 -7.2 17.3 20.9 1400 18.8 20.2 21.6 -7.2 18.4 22.1 700 35.6 38.3 41.0 -14.3 34.8 41.9 1400 37.7 40.5 43.3 -14.3 36.8 44.3 BXEB-L0280Z-xxx1000-C-C3 BXEB-L0560Z-xxx2000-C-C3 BXEB-L1120Z-xxx4000-C-C3 Notes for Table 2: 1. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a tolerance of ± 0.1 V on forward voltage data. 3. This product has been designed and manufactured per IEC 62031:2014. The working voltage designated for the insulation is 60 V d.c. The maximum allowable voltage across the module must be determined in the end product application. 4. Typical coefficient of forward voltage tolerance is ± 0.1 mV for nominal current. 5. Vf min hot and max cold values are provided as reference only and are not guaranteed. These values are provided to aid in driver design and selection over the operating range of the product. 4 Absolute Maximum Ratings Table 3: Maximum Ratings Parameter Maximum Rating Storage Temperature -40°C to +85°C Operating Case Temperature2 (Tc) 85°C Soldering Temperature 350°C or lower for a maximum of 5 seconds Maximum Reverse Voltage Modules are not designed to be driven in reverse bias Maximum Drive Current BXEB-L0280Z-xxx1000-C-C3 BXEB-L0560Z-xxx2000-C-C3 BXEB-L1120Z-xxx4000-C-C3 700mA 1400mA 1400mA Notes for Table 3: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the SMDs used in the modules. Contact your Bridgelux sales representatives for LM-80 report. 5 Performance Curves Figure 1: 280mm Current vs. Forward Voltage, Tc=25°C Figure 2: 280mm Relative Flux vs. Current, Tc=25°C 800 200% Relative Luminous Flux (%) Forward Current (mA) 700 600 500 400 300 200 100 0 18.0 18.5 19.0 19.5 Forward Voltage (V) 20.0 120% 100% 80% 60% 40% 20% 20.5 Figure 3: 560mm Current vs. Forward Voltage, Tc=25°C 0 200 400 600 Forward Current (mA) 800 Figure 4: 560mm Relative Flux vs. Current, Tc=25°C 1600 200% Relative Luminous Flux (%) 1400 Forward Current (mA) 140% 0% 17.5 1200 1000 800 600 400 200 180% 160% 140% 120% 100% 80% 60% 40% 20% 0% 0 17.5 18.0 18.5 19.0 19.5 Forward Voltage (V) 20.0 0 20.5 Figure 5: 1120mm Current vs. Forward Voltage, Tc=25°C 1500 200% Relative Luminous Flux (%) 1400 1200 1000 800 600 400 200 0 35.0 500 1000 Forward Current (mA) Figure 6: 1120mm Relative Flux vs. Current, Tc=25°C 1600 Forward Current (mA) 180% 160% 180% 160% 140% 120% 100% 80% 60% 40% 20% 0% 36.0 37.0 38.0 39.0 Forward Voltage (V) 40.0 41.0 0 500 1000 Forward Current (mA) 1500 6 Performance Curves Figure 7: Relative Voltage vs. Case Temperature Figure 8: Relative Flux vs. Case Temperature 102.0% Relative Luminous Flux (%) 100.5% Relative Voltage (%) 100.0% 25°C Pulsed 99.5% 99.0% 98.5% 98.0% 25°C Pulsed 100.0% 98.0% 96.0% 94.0% 92.0% 90.0% 97.5% 0 20 40 60 Case Temperature (°C) 80 100 0 20 40 60 Case Temperature (°C) 80 100 7 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern 120% Relative Intensity 100% 80% 60% 40% 20% 0% -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (°) Notes for Figure 9: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. 8 Typical Color Spectrum Figure 10: Typical Color Spectra, 80 CRI 100% 90% 80% Relative Intensity 70% 27E 60% 30E 50% 35E 40E 40% 50E 57E 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Figure 11: Typical Color Spectra, 90 CRI 100% 90% 80% Relative Intensity 70% 27G 60% 30G 50% 35G 40G 40% 50G 57G 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Note for Figures 10 & 11: 1. Color spectra measured at nominal current for Tc = 85°C 9 Mechanical Dimensions Figure 12: Drawing for EB Series Gen3 Table 4: Dimensions for 280mm Parameter Specification Unit Linear length 280 mm Linear width 24 mm Linear thickness 6.1 mm PCB thickness 1.6 mm Figure 13: Drawing for EB Series Gen3 560mm Table 5: Dimensions for 560mm Parameter Specification Unit Linear length 560 mm Linear width 24 mm Linear thickness 6.1 mm PCB thickness 1.6 mm 10 Mechanical Dimensions Figure 14: Drawing for EB Series Gen3 1120mm Notes for Figures 12, 13 & 14: 1. Solder pads are labeled “+” to denote positive polarity, and “-” to denote negative polarity. 2. Drawings are not to scale. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, the tolerances are ± 0.10mm.. Table 6: Dimensions for 1120mm Parameter Specification Unit Linear length 1120 mm Linear width 24 mm Linear thickness 6.1 mm PCB thickness 1.6 mm Table 7: Connector and wiring Parameter Specification Input wire cross-section 18-24 AWG Wire strip length 7-9 mm 11 Color Binning Information Figure 15: Graph of Warm and Neutral White Test Bins in xy Color Space 2700K 3 SDCM 0.43 3000K 3 SDCM 3500K 3 SDCM 0.41 CIE_Y 4000K 3 SDCM 0.39 0.37 0.35 0.36 0.39 0.42 0.45 0.48 CIE_X Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500 K 4000K B3 (3 SDCM) CCT Range 2651K - 2794K 2968K - 3136K 3369K - 3586K 3851K - 4130K Center Point (x, y) (0.458, 0.410) (0.434, 0.403) (0.407, 0.392) (0.382, 0.380) ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) Figure 16: Graph of Cool White Test Bins in xy Color Table 9: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5700K B3 (3 SDCM) CCT Range 4835K - 5215K 5490K - 5820K Center Point (x, y) (0.3445, 0.355) (0.329, 0.342) ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) Notes for Tables 8 and 9 1. Color binning at solder point temperature Tsp of SMDs at 85°C. 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. 12 Packaging and Labeling Figure 17: EB Series Packaging and Labeling Table 10: Packaging Structure L0280 modules Tray Box Quantity 40 200 Dimension 63 cm x 39 cm x 2.4 cm 65.5 cm x 41.5 cm x 15.5 cm L0560 modules Tray Box Quantity 20 100 Dimension 63 cm x 39 cm x 2.4 cm 65.5 cm x 41.5 cm x 15.5 cm L1120 modules Tray Box Quantity 20 100 Dimension 119 cm x 39 cm x 2.4 cm 134 cm x 44 cm x 18.5 cm Figure 18: Product Labeling Bridgelux EB Series modules contain a label on the front to help with product identification. In addition to the product identification markings, Bridgelux EB Series modules also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the module. EB Series Gen3 1ft 1000lm 350mA Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. 13 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the EB Series product family. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux EB Series LED linears are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED linear. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux EB Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. EB Series linears are classified as Risk Group 1 (TBD) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the linear or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the linear. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the EB Series linear. Use the mechanical features of the linear housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the EB Series linears during operation. Allow the linear to cool for a sufficient period of time before handling. The EB Series linears may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, linear testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 14 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 USA Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. EB Series and Bridging Light and Life are trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux EB Series Gen3 Data Sheet DS132 Rev. A (06/2019) 15
BXEB-L0560Z-40E2000-C-C3 价格&库存
很抱歉,暂时无法提供与“BXEB-L0560Z-40E2000-C-C3”相匹配的价格&库存,您可以联系我们找货
    • 1+48.51360
    • 200+19.36440
    • 500+18.71640
    • 1000+18.39240
