BXRC-50G2001-D-74-SE
    BRIDGELUX(普瑞)
BXRC-50G2001-D-74-SE 数据手册
Bridgelux Vero SE 13 Array ® ® Product Data Sheet DS121 1 Vero SE Introduction Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s seventh generation COB technology with poke-in connectivity enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing cost, simplify luminaire design, improve light quality and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is also a good replacement for halogen lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features • Poke-in connectivity • Efficacy of 167 lm/W typical • Lumen output performance ranges from 511 to 6,931 lumens Benefits • Poke-in connectivity enables solderless, connector free installation • Broad application coverage for interior and exterior lighting • Broad range of CCT options from 2700K to 6500K • Flexibility for application driven lighting design requirements • CRI options; minimum 70, 80, and 90 • High quality, true color reproduction • Color control: 2 and 3 SDCM for 2700K-4000K CCT • Uniform consistent white light • Reliable operation at up to 2X nominal drive current • Flexibility in design optimization • Radial die pattern and improved lumen density • Enhanced ease of use and assembly • Top side part number markings • Ability to configure multiple Vero SE arrays in series and parallel reduces customer driver cost • No exposed solder pads or electrical connections • Vf bin code backside marking • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 19 Eye Safety 20 Absolute Maximum Ratings 21 Performance Curves 22 Typical Radiation Pattern 25 Typical Color Spectrum 26 Mechanical Dimensions 27 Color Binning Information 28 Packaging and Labeling 29 Design Resources 31 Precautions 31 Disclaimers 31 About Bridgelux 32 1 Product Feature Map Vero SE 13 is the second smallest form factor in the product family of the next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www. bridgelux.com for more information on the Vero SE family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 Tc Measurement point Optic mounting holes Radial die configuration improves lumen density and beam control Mounting holes Top side part number marking improves inventory management and outgoing quality control Zhaga Book 3 compatible mounting locations Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 200 0 – C – 7 3 – SE Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 7 Array Configuration CRI C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Flux Indicator 200x = 2000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E2000-B-7X-SE 2700 80 450 2455 2210 34.8 15.7 157 BXRC-27E2000-C-7X-SE 2700 80 630 3438 3094 34.8 21.9 157 BXRC-27E2000-D-7X-SE 2700 80 500 2493 2244 31.8 15.9 157 BXRC-27G20H0-B-7X-SE 2700 90 450 2103 1892 34.8 15.7 134 BXRC-27G20H0-C-7X-SE 2700 90 630 2944 2649 34.8 21.9 134 BXRC-27G20H0-D-7X-SE 2700 90 500 2135 1921 31.8 15.9 134 BXRC-27G2000-B-7X-SE 2700 90 450 2026 1823 34.8 15.7 129 BXRC-27G2000-C-7X-SE 2700 90 630 2836 2552 34.8 21.9 129 BXRC-27G2000-D-7X-SE 2700 90 500 2057 1851 31.8 15.9 129 BXRC-27H2000-B-7x-SE 2700 97 450 1796 1616 34.8 15.7 115 BXRC-27H2000-C-7x-SE 2700 97 630 2514 2262 34.8 21.9 115 BXRC-27H2000-D-7x-SE 2700 97 500 1823 1641 31.8 15.9 115 BXRC-30C2001-B-7X-SE 3000 70 450 2732 2459 34.8 15.7 174 BXRC-30C2001-C-7X-SE 3000 70 630 3824 3442 34.8 21.9 174 BXRC-30C2001-D-7X-SE 3000 70 500 2774 2496 31.8 15.9 174 BXRC-30E2000-B-7X-SE 3000 80 450 2609 2348 34.8 15.7 167 BXRC-30E2000-C-7X-SE 3000 80 630 3653 3287 34.8 21.9 167 BXRC-30E2000-D-7X-SE 3000 80 500 2649 2384 31.8 15.9 167 BXRC-30G20H0-B-7X-SE 3000 90 450 2210 1989 34.8 15.7 141 BXRC-30G20H0-C-7X-SE 3000 90 630 3094 2785 34.8 21.9 141 BXRC-30G20H0-C-7X-SE 3000 90 500 2244 2019 31.8 15.9 141 BXRC-30G2000-B-7X-SE 3000 90 450 2118 1906 34.8 15.7 135 135 BXRC-30G2000-C-7X-SE 3000 90 630 2965 2669 34.8 21.9 BXRC-30G2000-D-7X-SE 3000 90 500 2150 1935 31.8 15.9 135 BXRC-30G200C-B-73-SE 3000 90 450 2053 1848 34.8 15.8 130 BXRC-30G200C-D-73-SE 3000 90 500 2072 1865 31.8 15.9 130 BXRC-30H2000-B-7x-SE 3000 97 450 1918 1727 34.8 15.7 123 BXRC-30H2000-C-7x-SE 3000 97 630 2686 2417 34.8 21.9 123 BXRC-30H2000-D-7x-SE 3000 97 500 1948 1753 31.8 15.9 123 BXRC-30A2001-B-73-SE8,9 3000 93 450 1903 1713 34.8 15.7 122 BXRC-30A2001-C-73-SE8,9 3000 93 630 2664 2398 34.8 21.9 122 BXRC-30A2001-D-73-SE 3000 93 500 1932 1739 31.8 15.9 122 8,9 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E2000-B-7X-SE 3500 80 450 2670 2403 34.8 15.7 171 BXRC-35E2000-C-7X-SE 3500 80 630 3738 3365 34.8 21.9 171 BXRC-35E2000-D-7X-SE 3500 80 500 2711 2440 31.8 15.9 171 BXRC-35G2000-B-7X-SE 3500 90 450 2195 1975 34.8 15.7 140 BXRC-35G2000-C-7X-SE 3500 90 630 3072 2765 34.8 21.9 140 BXRC-35G2000-D-7X-SE 3500 90 500 2228 2005 31.8 15.9 140 BXRC-35A2001-B-73-SE8,9 3500 93 450 2026 1823 34.8 15.7 129 BXRC-35A2001-C-73-SE8,9 3500 93 630 2836 2552 34.8 21.9 129 BXRC-35A2001-D-73-SE8,9 3500 93 500 2057 1851 31.8 15.9 129 BXRC-40C2001-B-7X-SE 4000 70 450 2808 2528 34.8 15.7 179 BXRC-40C2001-C-7X-SE 4000 70 630 3932 3539 34.8 21.9 179 BXRC-40C2001-D-7X-SE 4000 70 500 2852 2566 31.8 15.9 179 BXRC-40E2000-B-7X-SE 4000 80 450 2686 2417 34.8 15.7 172 BXRC-40E2000-C-7X-SE 4000 80 630 3760 3384 34.8 21.9 172 BXRC-40E2000-D-7X-SE 4000 80 500 2727 2454 31.8 15.9 172 BXRC-40G2000-B-7X-SE 4000 90 450 2241 2017 34.8 15.7 143 BXRC-40G2000-C-7X-SE 4000 90 630 3137 2823 34.8 21.9 143 BXRC-40G2000-D-7X-SE 4000 90 500 2275 2047 31.8 15.9 143 BXRC-40H2000-B-7X-SE 4000 97 450 2026 1823 34.8 15.7 129 129 BXRC-40H2000-C-7X-SE 4000 97 630 2836 2552 34.8 21.9 BXRC-40H2000-D-7X-SE 4000 97 500 2057 1851 31.8 15.9 129 BXRC-40A2001-B-73-SE8,9 4000 93 450 2195 1975 34.8 15.7 140 BXRC-40A2001-C-73-SE8,9 4000 93 630 3072 2765 34.8 21.9 140 BXRC-40A2001-D-73-SE8,9 4000 93 500 2228 2005 31.8 15.9 140 BXRC-50C2001-B-74-SE 5000 70 450 2824 2541 34.8 15.7 180 BXRC-50C2001-C-74-SE 5000 70 630 3953 3558 34.8 21.9 180 BXRC-50C2001-D-74-SE 5000 70 500 2867 2580 31.8 15.9 180 BXRC-50E2001-B-74-SE 5000 80 450 2716 2445 34.8 15.7 173 BXRC-50E2001-C-74-SE 5000 80 630 3803 3423 34.8 21.9 173 BXRC-50E2001-D-74-SE 5000 80 500 2758 2482 31.8 15.9 173 BXRC-50G2001-B-74-SE 5000 90 450 2348 2113 34.8 15.7 150 BXRC-50G2001-C-74-SE 5000 90 630 3287 2959 34.8 21.9 150 BXRC-50G2001-D-74-SE 5000 90 500 2384 2146 31.8 15.9 150 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-57C2001-B-74-SE 5700 70 450 2747 2472 34.8 15.7 175 BXRC-57C2001-C-74-SE 5700 70 630 3846 3461 34.8 21.9 175 BXRC-57C2001-D-74-SE 5700 70 500 2789 2510 31.8 15.9 175 BXRC-57E2001-B-74-SE 5700 80 450 2609 2348 34.8 15.7 167 BXRC-57E2001-C-74-SE 5700 80 630 3653 3287 34.8 21.9 167 BXRC-57E2001-D-74-SE 5700 80 500 2649 2384 31.8 15.9 167 BXRC-65C2001-B-74-SE 6500 70 450 2747 2472 34.8 15.7 175 BXRC-65C2001-C-74-SE 6500 70 630 3846 3461 34.8 21.9 175 BXRC-65C2001-D-74-SE 6500 70 500 2789 2510 31.8 15.9 175 BXRC-65E2001-B-74-SE 6500 80 450 2640 2376 34.8 15.7 169 BXRC-65E2001-C-74-SE 6500 80 630 3696 3326 34.8 21.9 169 BXRC-65E2001-D-74-SE 6500 80 500 2680 2412 31.8 15.9 169 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A2001-B-73 3000 80 93 450 1770 1557 34.4 15.5 115 BXRC-30A2001-C-73 3000 80 93 630 2478 2180 34.4 21.6 115 BXRC-30A2001-D-73 3000 80 93 500 1797 1581 31.2 15.6 115 BXRC-35A2001-B-73 3500 80 93 450 1884 1658 34.4 15.5 122 BXRC-35A2001-C-73 3500 80 93 630 2638 2321 34.4 21.6 122 BXRC-35A2001-D-73 3500 80 93 500 1913 1683 31.2 15.6 123 BXRC-40A2001-B-73 4000 80 93 450 2041 1796 34.4 15.5 132 BXRC-40A2001-C-73 4000 80 93 630 2857 2514 34.4 21.6 132 BXRC-40A2001-D-73 4000 80 93 500 2072 1824 31.2 15.6 133 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E2000-B-7X-SE 2700 80 450 2210 1989 33.9 15.3 145 BXRC-27E2000-C-7X-SE 2700 80 630 3094 2785 33.9 21.4 145 BXRC-27E2000-D-7X-SE 2700 80 500 2244 2019 30.9 15.5 145 BXRC-27G20H0-B-7X-SE 2700 90 450 1892 1703 33.9 15.3 124 BXRC-27G20H0-C-7X-SE 2700 90 630 2649 2384 33.9 21.4 124 BXRC-27G20H0-D-7X-SE 2700 90 500 1921 1729 30.9 15.5 124 BXRC-27G2000-B-7X-SE 2700 90 450 1823 1641 33.9 15.3 119 BXRC-27G2000-C-7X-SE 2700 90 630 2552 2297 33.9 21.4 119 BXRC-27G2000-D-7X-SE 2700 90 500 1851 1666 30.9 15.5 120 BXRC-27H2000-B-7x-SE 2700 97 450 1616 1454 33.9 15.3 106 BXRC-27H2000-C-7x-SE 2700 97 630 2262 2036 33.9 21.4 106 BXRC-27H2000-D-7x-SE 2700 97 500 1641 1477 30.9 15.5 106 BXRC-30C2001-B-7X-SE 3000 70 450 2459 2213 33.9 15.3 161 BXRC-30C2001-C-7X-SE 3000 70 630 3442 3098 33.9 21.4 161 BXRC-30C2001-D-7X-SE 3000 70 500 2496 2247 30.9 15.5 161 BXRC-30E2000-B-7X-SE 3000 80 450 2348 2113 33.9 15.3 154 BXRC-30E2000-C-7X-SE 3000 80 630 3287 2959 33.9 21.4 154 BXRC-30E2000-D-7X-SE 3000 80 500 2384 2146 30.9 15.5 154 BXRC-30G20H0-B-7X-SE 3000 90 450 1989 1790 33.9 15.3 130 BXRC-30G20H0-C-7X-SE 3000 90 630 2785 2506 33.9 21.4 130 BXRC-30G20H0-D-7X-SE 3000 90 500 2019 1817 30.9 15.5 131 BXRC-30G2000-B-7X-SE 3000 90 450 1906 1715 33.9 15.3 125 BXRC-30G2000-C-7X-SE 3000 90 630 2669 2402 33.9 21.4 125 BXRC-30G2000-D-7X-SE 3000 90 500 1935 1742 30.9 15.5 125 BXRC-30G200C-B-73-SE 3000 90 450 1848 1663 33.9 15.3 121 BXRC-30G200C-D-73-SE 3000 90 500 1865 1679 30.9 15.5 121 BXRC-30H2000-B-7x-SE 3000 97 450 1727 1554 33.9 15.3 113 BXRC-30H2000-C-7x-SE 3000 97 630 2417 2175 33.9 21.4 113 BXRC-30H2000-D-7x-SE 3000 97 500 1753 1578 30.9 15.5 113 BXRC-30A2001-B-73-SE7,8 3000 93 450 1713 1541 33.9 15.3 112 BXRC-30A2001-C-73-SE7,8 3000 93 630 2398 2158 33.9 21.4 112 BXRC-30A2001-D-73-SE 3000 93 500 1739 1565 30.9 15.5 112 7,8 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E2000-B-7X-SE 3500 80 450 2403 2163 33.9 15.3 158 BXRC-35E2000-C-7X-SE 3500 80 630 3365 3028 33.9 21.4 158 BXRC-35E2000-D-7X-SE 3500 80 500 2440 2196 30.9 15.5 158 BXRC-35G2000-B-7X-SE 3500 90 450 1975 1778 33.9 15.3 129 BXRC-35G2000-C-7X-SE 3500 90 630 2765 2489 33.9 21.4 129 BXRC-35G2000-D-7X-SE 3500 90 500 2005 1805 30.9 15.5 130 BXRC-35A2001-B-73-SE7,8 3500 93 450 1823 1641 33.9 15.3 119 BXRC-35A2001-C-73-SE7,8 3500 93 630 2552 2297 33.9 21.4 119 BXRC-35A2001-D-73-SE7,8 3500 93 500 1851 1666 30.9 15.5 120 BXRC-40C2001-B-7X-SE 4000 70 450 2528 2275 33.9 15.3 166 BXRC-40C2001-C-7X-SE 4000 70 630 3539 3185 33.9 21.4 166 BXRC-40C2001-D-7X-SE 4000 70 500 2566 2310 30.9 15.5 166 BXRC-40E2000-B-7X-SE 4000 80 450 2417 2175 33.9 15.3 158 BXRC-40E2000-C-7X-SE 4000 80 630 3384 3046 33.9 21.4 158 BXRC-40E2000-D-7X-SE 4000 80 500 2454 2209 30.9 15.5 159 BXRC-40G2000-B-7X-SE 4000 90 450 2017 1815 33.9 15.3 132 BXRC-40G2000-C-7X-SE 4000 90 630 2823 2541 33.9 21.4 132 BXRC-40G2000-D-7X-SE 4000 90 500 2047 1843 30.9 15.5 132 BXRC-40H2000-B-7X-SE 4000 97 450 1823 1641 33.9 15.3 119 BXRC-40H2000-C-7X-SE 4000 97 630 2552 2297 33.9 21.4 119 BXRC-40H2000-D-7X-SE 4000 97 500 1851 1666 30.9 15.5 120 BXRC-40A2001-B-73-SE7,8 4000 93 450 1975 1778 33.9 15.3 129 BXRC-40A2001-C-73-SE7,8 4000 93 630 2765 2489 33.9 21.4 129 BXRC-40A2001-D-73-SE7,8 4000 93 500 2005 1805 30.9 15.5 130 BXRC-50C2001-B-74-SE 5000 70 450 2541 2287 33.9 15.3 167 167 BXRC-50C2001-C-74-SE 5000 70 630 3558 3202 33.9 21.4 BXRC-50C2001-D-74-SE 5000 70 500 2580 2322 30.9 15.5 167 BXRC-50E2001-B-74-SE 5000 80 450 2445 2200 33.9 15.3 160 160 BXRC-50E2001-C-74-SE 5000 80 630 3423 3080 33.9 21.4 BXRC-50E2001-D-74-SE 5000 80 500 2482 2234 30.9 15.5 161 BXRC-50G2001-B-74-SE 5000 90 450 2113 1902 33.9 15.3 139 BXRC-50G2001-C-74-SE 5000 90 630 2959 2663 33.9 21.4 139 BXRC-50G2001-D-74-SE 5000 90 500 2146 1931 30.9 15.5 139 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-57C2001-B-74-SE 5700 70 450 2472 2225 33.9 15.3 162 BXRC-57C2001-C-74-SE 5700 70 630 3461 3115 33.9 21.4 162 BXRC-57C2001-D-74-SE 5700 70 500 2510 2259 30.9 15.5 162 BXRC-57E2001-B-74-SE 5700 80 450 2348 2113 33.9 15.3 154 BXRC-57E2001-C-74-SE 5700 80 630 3287 2959 33.9 21.4 154 BXRC-57E2001-D-74-SE 5700 80 500 2384 2146 30.9 15.5 154 BXRC-65C2001-B-74-SE 6500 70 450 2472 2225 33.9 15.3 162 162 BXRC-65C2001-C-74-SE 6500 70 630 3461 3115 33.9 21.4 BXRC-65C2001-D-74-SE 6500 70 500 2510 2259 30.9 15.5 162 BXRC-65E2001-B-74-SE 6500 80 450 2376 2138 33.9 15.3 156 BXRC-65E2001-C-74-SE 6500 80 630 3326 2993 33.9 21.4 156 BXRC-65E2001-D-74-SE 6500 80 500 2412 2171 30.9 15.5 156 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 9 Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E2000-B-7X 80 BXRC-27E2000-C-7X 80 BXRC-27E2000-D-7X 80 BXRC-27G20H0-B-7X 90 BXRC-27G20H0-C-7X 90 BXRC-27G20H0-D-7X 90 BXRC-27G2000-B-7X 90 BXRC-27G2000-C-7X 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 669 1294 2455 3549 4526 929 1798 3438 4934 6297 660 1279 2493 3523 4505 573 1108 2103 3038 3876 795 1540 2944 4225 5392 565 1095 2135 3017 3857 552 1068 2026 2928 3734 766 1483 2836 4071 5195 613 1174 2210 3108 3888 878 1693 3094 4613 5868 630 1219 2244 3338 4257 525 1005 1892 2661 3329 752 1450 2649 3950 5024 540 1043 1921 2858 3645 506 968 1823 2564 3208 724 1397 2552 3805 4841 185 174 157 146 135 184 173 157 145 134 179 169 157 142 131 158 149 134 125 116 157 148 134 124 115 153 144 134 121 112 153 144 129 120 111 151 143 129 119 111 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G2000-D-7X 90 BXRC-27H2000-B-7X-SE 80 BXRC-27H2000-C-7X-SE 80 BXRC-27H2000-D-7X-SE 80 BXRC-30C2001-B-74-SE 70 BXRC-30C2001-C-74-SE 70 BXRC-30C2001-D-74-SE 70 BXRC-30E2000-B-7X-SE 80 BXRC-30E2000-C-7X-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 544 1055 2057 2907 3716 489 947 1796 2595 3310 679 1315 2514 3608 4605 483 936 1823 2576 3294 744 1440 2732 3948 5036 1033 2000 3824 5489 7006 734 1423 2774 3920 5012 711 1375 2609 3770 4809 987 1910 3653 5242 6691 520 1005 1851 2754 3512 448 858 1616 2272 2843 642 1238 2262 3373 4291 461 891 1641 2441 3113 682 1306 2459 3457 4325 977 1884 3442 5132 6528 701 1356 2496 3713 4736 651 1247 2348 3302 4131 933 1799 3287 4901 6234 147 139 129 117 108 135 127 115 107 99 134 126 115 106 98 131 123 115 103 96 206 194 174 162 150 204 192 174 161 149 199 188 174 157 146 197 185 167 155 143 195 184 167 154 142 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30E2000-D-7X-SE 80 BXRC-30G20H0-B-7X 90 BXRC-30G20H0-C-7X 90 BXRC-30G20H0-D-7X 90 BXRC-30G2000-B-7X-SE 90 BXRC-30G2000-C-7X-SE 90 BXRC-30G2000-D-7X-SE 90 BXRC-30G200C-B-73-SE 90 BXRC-30G200C-D-73-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 125 250 500 750 1000 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 3.7 7.6 15.9 24.9 34.4 701 1359 2649 3743 4786 602 1165 2210 3194 4074 836 1618 3094 4441 5668 594 1151 2244 3171 4054 577 1116 2118 3061 3904 801 1551 2965 4256 5432 569 1103 2150 3039 3885 559 1082 2053 2967 3784 549 1063 2072 2929 3745 670 1295 2384 3546 4523 552 1057 1989 2797 3499 790 1524 2785 4151 5281 567 1097 2019 3004 3831 529 1013 1906 2680 3353 757 1460 2669 3978 5061 544 1051 1935 2879 3672 512 981 1848 2598 3250 524 1013 1865 2774 3539 190 179 167 150 139 166 157 141 131 121 165 156 141 130 121 161 152 141 127 118 160 150 135 126 116 158 149 135 125 116 154 145 135 122 113 155 146 131 122 113 149 140 130 118 109 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30H2000-B-7X-SE 80 BXRC-30H2000-C-7X-SE 80 BXRC-30H2000-D-7X-SE 80 BXRC-30A2001-B-73-SE 93 BXRC-30A2001-C-73-SE 93 BXRC-30A2001-D-73-SE 93 BXRC-35E2000-B-7X-SE 80 BXRC-35E2000-C-7X-SE 80 BXRC-35E2000-D-7X-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 522 1011 1918 2772 3536 726 1405 2686 3855 4920 516 999 1948 2752 3519 518 1003 1903 2750 3508 720 1394 2664 3824 4881 511 991 1932 2730 3491 727 1408 2670 3859 4923 1010 1955 3738 5366 6848 718 1391 2711 3831 4899 479 917 1727 2428 3038 686 1323 2417 3604 4584 492 952 1753 2608 3326 475 910 1713 2408 3013 681 1312 2398 3575 4547 488 944 1739 2587 3299 666 1277 2403 3380 4228 955 1841 3365 5016 6381 685 1325 2440 3630 4629 145 136 123 114 105 143 135 123 113 105 140 132 123 111 102 143 135 122 113 105 142 134 122 112 104 138 131 122 110 101 201 189 171 159 147 200 188 171 157 146 194 183 171 154 142 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35G2000-B-7X-SE 90 BXRC-35G2000-C-7X-SE 90 BXRC-35G2000-D-7X-SE 90 BXRC-35A2001-B-73-SE 93 BXRC-35A2001-C-73-SE 93 BXRC-35A2001-D-73-SE 93 BXRC-40C2001-B-74-SE 70 BXRC-40C2001-C-74-SE 70 BXRC-40C2001-D-74-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 598 1157 2195 3172 4046 830 1607 3072 4410 5628 590 1143 2228 3149 4026 552 1068 2026 2928 3734 766 1483 2836 4071 5195 544 1055 2057 2907 3716 765 1480 2808 4059 5177 1062 2057 3932 5643 7203 755 1463 2852 4030 5152 548 1049 1975 2777 3475 785 1513 2765 4123 5244 563 1089 2005 2983 3805 506 968 1823 2564 3208 724 1397 2552 3805 4841 520 1005 1851 2754 3512 701 1343 2528 3554 4447 1004 1937 3539 5276 6711 721 1394 2566 3817 4869 165 156 140 130 121 164 155 140 129 120 160 151 140 126 117 153 144 129 120 111 151 143 129 119 111 147 139 129 117 108 212 199 179 167 154 210 198 179 166 153 204 193 179 162 150 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E2000-B-7X-SE 80 BXRC-40E2000-C-7X-SE 80 BXRC-40E2000-D-7X-SE 80 BXRC-40G2000-B-7X-SE 90 BXRC-40G2000-C-7X-SE 90 BXRC-40G2000-D-7X-SE 90 BXRC-40H2000-B-7X-SE 97 BXRC-40H2000-C-7X-SE 97 BXRC-40H2000-D-7X-SE 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 731 1416 2686 3881 4951 1016 1967 3760 5397 6888 722 1399 2727 3853 4927 610 1181 2241 3238 4130 848 1641 3137 4502 5746 602 1167 2275 3215 4111 552 1068 2026 2928 3734 766 1483 2836 4071 5195 544 1055 2057 2907 3716 670 1284 2417 3399 4253 960 1852 3384 5045 6418 689 1333 2454 3651 4656 559 1071 2017 2836 3548 801 1545 2823 4209 5354 575 1112 2047 3046 3885 506 968 1823 2564 3208 724 1397 2552 3805 4841 520 1005 1851 2754 3512 202 191 172 159 148 201 189 172 158 147 195 184 172 155 143 169 159 143 133 123 167 158 143 132 122 163 154 143 129 119 153 144 129 120 111 151 143 129 119 111 147 139 129 117 108 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40A2001-B-73-SE 93 BXRC-40A2001-C-73-SE 93 BXRC-40A2001-D-73-SE 93 BXRC-50C2001-B-74-SE 70 BXRC-50C2001-C-74-SE 70 BXRC-50C2001-D-74-SE 70 BXRC-50E2001-B-74-SE 80 BXRC-50E2001-C-74-SE 80 BXRC-50E2001-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 598 1157 2195 3172 4046 830 1607 3072 4410 5628 590 1143 2228 3149 4026 769 1489 2824 4081 5205 1068 2068 3953 5674 7242 759 1471 2867 4052 5181 740 1432 2716 3926 5007 1028 1989 3803 5458 6967 730 1415 2758 3897 4983 548 1049 1975 2777 3475 785 1513 2765 4123 5244 563 1089 2005 2983 3805 705 1350 2541 3574 4471 1010 1947 3558 5305 6748 725 1401 2580 3838 4896 678 1299 2445 3438 4301 971 1873 3423 5103 6491 697 1348 2482 3692 4709 165 156 140 130 121 164 155 140 129 120 160 151 140 126 117 213 200 180 168 155 211 199 180 166 154 205 194 180 163 150 205 193 173 161 149 203 191 173 160 148 198 187 173 157 145 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50G2001-B-74-SE 90 BXRC-50G2001-C-74-SE 90 BXRC-50G2001-D-74-SE 90 BXRC-57C2001-B-74-SE 70 BXRC-57C2001-C-74-SE 70 BXRC-57C2001-D-74-SE 70 BXRC-57E2001-B-74-SE 80 BXRC-57E2001-C-74-SE 80 BXRC-57E2001-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 639 1238 2348 3393 4328 888 1719 3287 4718 6022 631 1223 2384 3369 4308 748 1448 2747 3970 5064 1039 2012 3846 5520 7045 738 1431 2789 3942 5040 711 1375 2609 3770 4809 987 1910 3653 5242 6691 701 1359 2649 3743 4786 586 1123 2113 2972 3718 840 1619 2959 4411 5611 603 1165 2146 3192 4071 686 1313 2472 3477 4350 982 1894 3461 5160 6565 705 1363 2510 3734 4763 651 1247 2348 3302 4131 933 1799 3287 4901 6234 670 1295 2384 3546 4523 177 167 150 139 129 175 165 150 138 128 171 161 150 135 125 207 195 175 163 151 205 193 175 162 150 200 189 175 158 146 197 185 167 155 143 195 184 167 154 142 190 179 167 150 139 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-65C2001-B-74-SE 70 BXRC-65C2001-C-74-SE 70 BXRC-65C2001-D-74-SE 70 BXRC-65E2001-B-74-SE 80 BXRC-65E2001-C-74-SE 80 BXRC-65E2001-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 748 1448 2747 3970 5064 1039 2012 3846 5520 7045 738 1431 2789 3942 5040 719 1391 2640 3815 4866 998 1933 3696 5304 6770 709 1375 2680 3787 4843 686 1313 2472 3477 4350 982 1894 3461 5160 6565 705 1363 2510 3734 4763 659 1262 2376 3341 4180 944 1820 3326 4959 6308 678 1310 2412 3588 4576 207 195 175 163 151 205 193 175 162 150 200 189 175 158 146 199 187 169 157 145 197 186 169 156 144 192 181 169 152 141 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.28 31.0 38.3 -14.3 0.35 33.4 41.0 37.4 -14.3 0.20 31.0 38.3 37.3 40.1 -14.3 0.24 33.4 41.0 29.4 31.8 34.2 -13.3 0.34 28.4 35.0 31.8 34.4 37.0 -13.3 0.41 30.8 37.9 Minimum Typical Maximum 450 32.2 34.8 37.4 -14.3 900 34.5 37.3 40.1 630 32.2 34.8 1260 34.5 500 1000 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 19 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Drive Current 5 (mA) CCT1,5 2700K/3000K 4000K2 5000K3 6500K4 450 RG1 RG1 RG1 RG1 675 RG1 RG1 RG1 RG2 900 RG1 RG1 RG2 RG2 630 RG1 RG1 RG1 RG1 945 RG1 RG1 RG2 RG2 1260 RG1 RG2 RG2 RG2 500 RG1 RG1 RG1 RG1 750 RG1 RG1 RG1 RG2 1000 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero SE Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 20 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Maximum Drive Current3 900mA 1260mA 1000mA Maximum Peak Pulsed Drive Current4 1290mA 1800mA 1430mA Maximum Reverse Voltage5 -60V -60V -55V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN120: Assembly Considerations for Bridgelux Vero SE LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 21 Performance Curves Figure 1: Vero SE 13B Drive Current vs. Voltage Figure 2: Vero SE 13C Drive Current vs. Voltage 1000 1400 900 1200 700 Forward Current (mA) Forward Current (mA) 800 600 500 400 300 1000 800 600 400 200 200 100 0 32 33 34 35 36 37 0 38 32 33 34 Forward Voltage (V) 35 36 37 38 Forward Voltage (V) Figure 3: Vero SE 13D Drive Current vs. Voltage Figure 4: Vero SE 13B Typical Relative Flux vs. Current 200% 1100 180% 1000 160% Relative Luminous Flux Forward Current (mA) 900 800 700 600 500 400 300 120% 100% 80% 60% 40% 200 20% 100 0 140% 0% 29 30 31 32 33 34 0 35 100 200 300 200% 200% 180% 180% 160% 160% 140% 140% 120% 100% 80% 60% 850 Forward Current (mA) 900 1000 60% 20% 0% 700 800 80% 40% 550 700 100% 20% 400 600 120% 40% 250 500 Figure 6 Vero SE 13D Typical Relative Flux vs. Current Relative Luminous Flux Relative Luminous Flux Figure 5: Vero SE 13C Typical Relative Flux vs. Current 100 400 Forward Current (mA) Forward Voltage (V) 1000 1150 1300 0% 0 100 200 300 400 500 600 700 800 900 1000 1100 Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 22 Performance Curves Figure 7: Typical DC Flux vs. Case Temperature 0 103% 25 50 75 100 125 0.003 Warm White Neutral White 100% Cool White 0.000 25°C Pulsed 97% -0.003 94% ccy Shift Relative Luminous Flux Figure 8: Typical DC ccy Shift vs. Case Temperature 91% -0.006 88% -0.009 85% -0.012 82% -0.015 Warm White 0 25 50 75 100 125 Case Temperature (°C) Neutral White Cool White 25°C Pulsed Case Temperature (°C) Figure 9: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 7 - 9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 23 Performance Curves Figure 10: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 11: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.3950 0.4323 0.4572 0.4574 0.4576 0.4578 0.4328 0.4333 0.458 0.4343 0.4348 0.4353 ccx ccx Figure 12: 3000K, 90 CRI Color Shift vs. Case Temperature1,3 0.4338 Figure 13: 3000K Class A Color Shift vs. Case Temperature1 0.403 15°C 0.402 0.369 Pulsed Center Point Tc=25°C 25°C 25°C 0.401 0.367 45°C 0.4 0.399 0.366 65°C ccy ccy 15°C 0.368 0.398 85°C 0.364 70°C 85°C 0.362 105°C 0.396 45°C 0.365 0.363 0.397 0.361 0.395 0.444 0.4445 0.445 0.4455 0.446 0.4465 Figure 14: 3500K Class A Color Shift vs. Case Temperature1 0.366 0.417 ccx 0.4175 0.418 0.4185 0.3760 15°C 25°C 0.4165 Figure 15: 4000K Class A Color Shift vs. Case Temperature1 0.37 0.368 105°C 0.36 0.416 0.447 ccx Pulsed Center Point Tc=25°C 15°C 0.3740 25°C 0.3720 45°C Pulsed Center Point Tc=25°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.364 0.3680 70°C 0.362 70°C 0.3660 85°C 0.36 85°C 0.3640 105°C 0.358 0.392 105°C 0.393 0.394 0.395 0.396 0.397 ccx Notes for Figures 10-15: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRC-30G400C-x-73-SE 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 24 Typical Radiation Pattern Figure 16: Typical Spatial Radiation Pattern Note for Figure 16: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 17: Typical Polar Radiation Pattern 25 Typical Color Spectrum Figure 18: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 18: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 19: Typical Color Spectrum for Vero SE 13 with Décor Series 1 27H 0.9 30H 30G (Décor Series Showcase) Relative Spectral Power Distribution 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 19: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 26 Mechanical Dimensions Figure 20: Drawing for Vero SE 13 LED Array Notes for Figure 20: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 27 Color Binning Information Figure 21: Warm and Neutral White Test Bins in xy Color Figure 22: Cool White Test Bins in xy Color Space Space 0.39 4 SDCM 0.44 3 SDCM 0.38 3 SDCM 2 SDCM 0.37 2700K 0.42 3000K 5700K 3500K 0.35 Y 0.4 5000K 0.36 Y 4000K 0.34 0.38 6500K 0.33 0.32 0.36 0.31 0.3 0.34 0.36 0.39 0.42 X 0.45 0.3 0.48 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 28 Packaging and Labeling Figure 23: Drawing for Vero SE 13 Packaging Tray Notes for Figure 23: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 29 Packaging and Labeling Figure 24: Vero SE Series Packaging and Labeling Notes for Figure 24: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 25: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E2000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 30 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN121 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 31 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vero SE 13 Array Series Product Data Sheet DS121 Rev. L (03/2019) 32
BXRC-50G2001-D-74-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-50G2001-D-74-SE”相匹配的价格&库存,您可以联系我们找货
  • 200+39.91474200+5.12219
