BXRV-DR-1830G-3000-A-13
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) Vesta™ 白色,暖色 矩形
BXRV-DR-1830G-3000-A-13 数据手册
Bridgelux Vesta® Series Dim-To-Warm 13mm and 15mm Arrays ® Product Data Sheet DS151 Vesta Series Introduction Vesta® Series Dim-To-Warm Array products deliver adaptable light in a cost-effective, solid state lighting package. Vesta Series products tap into the powerful mediums of light and color to influence experience, well-being, and human emotion. They allow fixture manufacturers to simulate the familiar glow and dimming of incandescent lamps. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. Lighting system designs incorporating these LED arrays deliver comparable performance to 150 Watt incandescentbased luminaires, while increasing system level efficacy and prolonging service life. Typical luminaire and lamp types appropriate for this family include replacement lamps, down lights, wall packs and accent, spot and track lights. Features • Dimming range from 2700K to 1800K and 3000K to 1800K • Efficacy of 83 lm to 115 lm/W typical at 3000K 95 CRI • Uniform, high quality illumination • Minimum 90 and 95 CRI options • More energy efficient than incandescent, halogen and fluorescent lamps • Industry standardized dimensions • Flux packages from 1600 to 3725 lumens typical Benefits • Superior color dimming transition • Compact system design resulting from high lumen density • High quality, true color reproduction • Enhanced optical control • Uniform, consistent white light • Lower operating costs • Reduced maintenance costs Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Electrical Characteristics 4 Absolute Maximum Ratings 5 Performance Curves 6 Performance Curves 7 Performance Curves 8 Typical Radiation Pattern 9 Typical Color Spectrum 10 Mechanical Dimensions 11 Mechanical Dimensions 12 Color Binning Information 13 Packaging and Labeling 14 Design Resources 15 Precautions 15 Disclaimers 15 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the Vesta Series family of products. Fully engineered substrate for consistent thermal, mechanical and optical properties Solder Pads Polarity symbols Case Temperature (Tc) Measurement Point White ring around LES Yellow phosphor Light Emitting Surface (LES) Dimming control component Designed to comply with global safety standards for creepage and clearance distances Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux Vesta Series arrays is explained as follows: 1 2 3 4 BXRV 5 6 7 8 9 10 11 12131415 – 16 17 18 DR – 1830H - 3000 – A – 13 Product Family CCT Bin Options 13 = 3 SDCM Dim-To-Warm Array Nominal CCT 18 = 1,800K 27 = 2,700K 30 = 3,000K Array Configuration Minimum CRI G = 90 CRI H = 95 CRI A = 20W for 13mm 33W for 15mm Form Factor Designator 2000 = 13mm LES 3000 = 15mm LES 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Measurement Data Part Number BXRV-DR-1827G-2000-A-13 BXRV-DR-1827G-3000-A-13 BXRV-DR-1827H-2000-A-13 BXRV-DR-1827H-3000-A-13 BXRV-DR-1830G-2000-A-13 BXRV-DR-1830G-3000-A-13 BXRV-DR-1830H-2000-A-13 BXRV-DR-1830H-3000-A-13 Tc=25°C (lm) Minimum Pulsed Flux6 Tc=25°C (lm) Typical DC Flux7, 8 Tc=85°C (lm) 105 2111 1899 1766 88 47 43 40 32.4 105 3401 3061 2847 0.5 88 46 42 39 33.5 20.1 83 1668 1501 1396 26.9 0.5 73 39 35 33 34.1 32.4 83 2689 2420 2251 26.4 0.5 73 39 35 32 20.1 115 2312 2080 1935 0.5 104 56 50 47 32.4 115 3725 3353 3118 0.5 104 55 49 46 33.5 20.1 101 2028 1825 1832 26.9 0.5 87 47 42 43 34.1 32.4 102 3300 2970 3000 26.4 0.5 89 47 42 43 Typical Vf Tc=25°C (V) Typical Power Tc=25°C (W) Typical Efficacy Tc=25°C (lm/W) 600 33.5 20.1 20 26.9 0.5 950 34.1 20 26.4 600 20 950 20 600 33.5 20 26.9 950 34.1 20 26.4 600 20 95 950 95 20 Nominal CCT1 (K) CRI 2700 90 1800 90 2700 90 1800 90 2700 95 1800 95 2700 95 1800 95 3000 90 1800 90 3000 90 1800 90 3000 95 1800 95 3000 1800 2 Drive Current (mA) Typical Pulsed Flux 3, 4, 5 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. Minimum R9 value for 95 CRI products is 85, Bridgelux maintains a ±3 tolerance on all CRI and R9 values. 3. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 4. Typical performance values are provided as a reference only and are not a guarantee of performance. 5. Bridgelux maintains a ±7% tolerance on flux measurements. 6. Minimum flux values at the nominal test current are guaranteed by 100% test. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Electrical Characteristics Table 2: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 7 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case4, 5 Rj-c (ºC/W) Driver Selection Voltages6 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.23 30.0 36.8 -12.1 0.25 30.5 37.4 37.3 -15.0 0.15 29.7 38.3 37.7 -15.0 0.16 30.1 38.7 Minimum Typical Maximum 600 31.0 33.5 36.0 -12.1 720 31.5 34.0 36.6 950 30.9 34.1 1050 31.3 34.5 BXRV-DR-xxxxx-2000-A-13 BXRV-DR-xxxxx-3000-A-13 Notes for Table 2: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 6. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 7. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 45V d.c. The maximum allowable voltage across the array must be determined in the end product application. 4 Absolute Maximum Ratings Table 3: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 350°C or lower for a maximum of 10 seconds BXRV-DR-xxxxx-2000-A-13 BXRV-DR-xxxxx-3000-A-13 Maximum Drive Current3 720mA 1050mA Maximum Peak Pulsed Drive Current4 1030mA 1500mA Maximum Reverse Voltage5 -60V -60V Notes for Table 3: 1. For IEC 62717 requirement, please contact Bridgelux Sales Support. 2. See Bridgelux Application Note for more information. 3. Please refer to Figures 11 and 12 for drive current derating curves. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20ms when operating LED arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 5 Performance Curves Figure 1: Vesta Dim-to-Warm 13mm 20W Forward Voltage vs. Forward Current, Tc=25°C Figure 2: Vesta Dim-to-Warm 15mm 33W Forward Voltage vs. Forward Current, Tc=25°C 800 1200 700 1000 Forward Current (mA) Forward Current (mA) 600 500 400 300 200 800 600 400 200 100 0 25.0 27.0 29.0 31.0 Forward Voltage (V) 33.0 0 25.0 35.0 27.0 29.0 31.0 Forward Voltage (V) 33.0 35.0 37.0 Figure 4: Vesta Dim-to-Warm 15mm 33W Relative LOP vs. Drive Current, Tc=25°C Figure 3: Vesta Dim-to-Warm 13mm 20W Relative LOP vs. Drive Current, Tc=25°C 140% 120% 120% 100% 100% Relative LOP Relative LOP 80% 80% 60% 40% 20% 60% 40% 20% 0% 0 100 200 300 400 500 Drive Current (mA) 600 700 800 Figure 5: Vesta Dim-to-Warm 13mm 20W Relative Flux vs. Case Temperature 0% 0 200 400 600 Drive Current (mA) 800 1000 1200 Figure 6: Vesta Dim-to-Warm 15mm 33W Relative Flux vs. Case Temperature 102% 102% 25°C Pulsed 600mA 20mA 100% 25°C Pulsed 950mA 100% 20mA 98% 98% Relative LOP Relative LOP 96% 94% 92% 90% 96% 94% 92% 90% 88% 86% 88% 84% 86% 0 20 40 60 Case Temperature (°C) 80 100 120 0 20 40 60 Case Temperature (°C) 80 100 120 6 Performance Curves Figure 8: Vesta Dim-to-Warm 15mm 33W CCT vs. Forward Current Figure 7: Vesta Dim-to-Warm 13mm 20W CCT vs. Forward Current 3300 3100 3100 2900 2900 2700 2700 2500 2500 CCT (K) CCT (K) 3300 2300 2300 2100 2100 1900 1900 1700 1700 1500 0 100 200 300 400 500 Forward Current (mA) 600 700 1500 800 0 200 400 600 Forward Current (mA) 800 1000 1200 Figure 10: Vesta Dim-to-Warm 13mm 20W Color Shift vs. Forward Current 3000K - 1800K Figure 9: Vesta Dim-to-Warm 13mm 20W Color Shift vs. Forward Current 2700K-1800K 0.43 0.43 0.42 0.42 0.41 1800K CCY CCY 0.41 2700K 0.4 0.4 1800K 3000K 0.39 0.39 0.38 0.38 0.37 0.41 0.43 0.45 0.47 0.49 CCX 0.51 0.53 0.55 0.37 0.57 0.41 0.43 0.45 0.47 0.49 0.51 0.53 0.55 0.57 CCX Figure 12: Vesta Dim-to-Warm 15mm 33W Color Shift vs. Forward Current 3000K-1800K Figure 11: Vesta Dim-to-Warm 15mm 33W Color Shift vs. Forward Current 2700K-1800K 0.43 0.43 0.42 0.42 0.41 1800K CCY CCY 0.41 2700K 0.4 0.4 1800K 3000K 0.39 0.39 0.38 0.38 0.37 0.41 0.43 0.45 0.47 0.49 CCX 0.51 0.53 0.55 0.57 0.37 0.41 0.43 0.45 0.47 0.49 CCX 0.51 0.53 0.55 0.57 7 Figure 14: Vesta Dim-to-Warm 15mm 33W Derating Curve Figure 13: Vesta Dim-to-Warm 13mm 20W Derating Curve 750 720mA 675 600 1000 525 950 mA 800 450 Current (mA) Current (mA) 1200 600mA 375 300 225 150 600 400 200 75 0 0 25 45 65 85 Case Temperature (C) 105 125 25 45 65 85 105 125 Case Temperature (˚C) 8 Typical Radiation Pattern Figure 15: Typical Spatial Radiation Pattern 100% 90% Relative Intensity (%) 80% 70% 60% 50% 40% 30% 20% 10% 0% -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Displacement (⁰) Notes for Figure 15: 1. Typical viewing angle is 110⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 16: Typical Polar Radiation Pattern -30⁰ -15⁰ 15⁰ 30⁰ 100% 90% -45⁰ 80% 45⁰ 70% 60% -60⁰ 50% 60⁰ 40% 30% -75⁰ 20% 75⁰ 10% -90⁰ 0% 90⁰ 9 Typical Color Spectrum Figure 17: Typical Color Spectrum Relative Spectral Power Distribution (%) 120% 1800K (20mA) 2700K (600mA or 950mA) 3000K (600mA or 950mA) 100% 80% 60% 40% 20% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 17: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 10 Mechanical Dimensions Figure 18: Drawing for Vesta Series Dim-To-Warm 13mm Array Notes for Figure 18: 1. Solder pads are labeled “+” to denote positive polarity and “-” to denote negative polarity. 2. Drawing is not to scale. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, tolerances are ± 0.10mm. 5. The optical center of the LED array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.2 mm 6. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes for product handling, mounting and heat sink recommendations. 11 Mechanical Dimensions Figure 19: Drawing for Vesta Series Dim-To-Warm 15mm Array Notes for Figure 19: 1. Solder pads are labeled “+” to denote positive polarity and “-” to denote negative polarity. 2. Drawing is not to scale. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, tolerances are ± 0.10mm. 5. The optical center of the LED array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.2 mm 6. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes for product handling, mounting and heat sink recommendations. 12 Color Binning Information Figure 20: Graph of Warm White Test Bins in xy Color Space 0.44 0.43 0.42 2700K 1800K CCY 0.41 0.4 0.39 0.38 0.37 0.4 0.42 0.44 0.46 0.48 0.5 0.52 0.54 0.56 0.58 CCX 0.44 0.43 0.42 3000K 1800K CCY 0.41 Black Body Curve 0.4 0.39 0.38 0.37 0.4 0.42 0.44 0.46 0.48 0.5 0.52 0.54 0.56 0.58 CCX Note: Pulsed Test Conditions, Tc = 25°C Table 4: Bin Coordinates and Associated Typical CCT Bin Code 3000K 2700K 1800K ANSI Bin (for reference only) (2870K - 3220K) (2580K-2870K) - 3 (3SDCM) (2968K - 3136K) (2651K - 2794K) - 5 (5SDCM) - - (1735K - 1880K) Center Point (x,y) (0.4338, 0.403) (0.4578, 0.4101) (0.5496, 0.4081) 13 Packaging and Labeling Figure 21: Vesta Series Dim-To-Warm 13mm and 15mm Packaging and Labelin1 Tray label Bag label Box label Notes for Figure 21: 1. Each tray holds 30 Vesta Series Dim-To-Warm 13mm or 15mm arrays. 2. Eight trays are sealed in an anti-static bag. One such bag is placed in a box and shipped. Depending on quantities ordered, a bigger shipping box, containing more boxes will be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tray are 200 (W) x 12(H) x 300 (L) mm. Dimensions for the anti-static bag are 440 (W) x 350mm (L) x 0.1 mm (T) mm and that of a shipping box are 350 x 245 x 67 mm. Figure 22: Product Labeling Bridgelux arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number Internal Bridgelux use only. 14 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vesta Series product family of LED array products. Please see Bridgelux Application Note, AN101 for more information. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vesta Series LED arrays are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note, AN101 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vesta Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. Vesta Series Dim-To-Warm arrays are classified as Risk Group 1 when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES and resistors. Do not touch the LES or resistors of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the Vesta Series LED array. Use the mechanical features of the LED array housing and edges to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the Vesta Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vesta Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, array testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 15 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 Tel (925) 583-8400 www.bridgelux.com © 2017-2018 Bridgelux, Inc. All rights reserved 2017-2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vesta are registered trademarks of Bridgelux, Inc, All other trademarks are the property of their respective owners. Bridgelux Vesta Series Dim-To-Warm 13mm and 15mm Array Product Data Sheet DS151 Rev. B (03/2018) 16
BXRV-DR-1830G-3000-A-13 价格&库存
很抱歉,暂时无法提供与“BXRV-DR-1830G-3000-A-13”相匹配的价格&库存,您可以联系我们找货
    • 30+44.7276230+5.59440
    • 60+44.2838960+5.53890
    • 120+43.84017120+5.48340
    • 150+43.66268150+5.46120
    • 450+42.77522450+5.35020
      • 30+57.9506730+7.24830
      • 60+57.5956860+7.20390
      • 90+57.3294590+7.17060
      • 120+57.06321120+7.13730
      • 1+50.879081+6.36381
      • 50+49.0815250+6.13898
      • 100+48.87392100+6.11301
      库存:263
