BXEB-L0560Z-40E2000-C-B3
    BRIDGELUX(普瑞)
    2000 LM NEUTRAL WHITE LINEAR MOD
BXEB-L0560Z-40E2000-C-B3 数据手册
Bridgelux EB Series™ Gen 2 ® Product Data Sheet DS131 EB Series™ Introduction EB Series Gen 2 Linears are designed for use in premium indoor or industrial applications where a high level of efficacy is required. The new generation uses the high-efficacy SMDs to achieve up to 180lm/W, which enables designers and fixture manufacturers to meet DLC Premium requirements. They are designed for linear troffers, pendants and other luminaires in indoor commercial and industrial applications. Available in 280 mm, 560 mm, and 1120 mm lengths, the modules can be connected end-to-end thereby providing flexibility in designing luminaires. The Zhaga compatible modules further simplify design by providing easy mounting options, reusable poke-in connectors and by being compatible with a variety of off-the-shelf optics. The modules have long lifetimes of greater than 50,000 hours. Features • Leading efficacy, up to 180 lm/W typical with 2x overdrive capability • Ideal for DLC Premium Application • Uniform, high quality illumination • Available in a variety of color temperatures • Designed following Zhaga Book 7 standards L28W2 and L56W2 • ENERGY STAR® / ANSI compliant 3 SDCM color binning structure • Lumen output of up to 2386lm, 4772lm, and 9544lm for 280mm, 560mm and 1120mm modules Benefits • Compact system design • High quality, true color reproduction • Enhanced optical control • Uniform, consistent white light • Reliable use at elevated currents enables greater design flexibility • Easy installation using mounting cutout and connectors • Long lifetime of > 50,000 hours • Easy wiring enabled by poke-in connectors Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Electrical Characteristics 4 Absolute Maximum Ratings 5 Performance Curves 6 Typical Radiation Pattern 8 Typical Color Spectrum 9 Mechanical Dimensions 10 Color Binning Information 12 Packaging and Labeling 13 Design Resources 14 Precautions 14 Disclaimers 14 About Bridgelux 15   1 Product Feature Map Bridgelux EB Series Gen 2 Linears are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The linear products incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the EB Series family of products. Case Temperature Measurement Points Optic mounting holes Designed to comply with global safety standards for creepage and clearance distances Zhaga compatible mounting holes Re-usable connector Note: Label containing part number and lot codes is attached on the front of the module. Product Nomenclature The part number designation for Bridgelux EB Series Gen 2 is explained as follows: 1 2 3 4 - 5 6 7 8 9 10 - 11 12 13 14 15 16 - 1 7 – 18 BXEB – L0280Z – 30 E 1000 – C – B3 Product Family Nominal Dimensions L= Length 0280 = 280 mm 0560 = 560 mm 1120 = 1120 mm Z= Zhaga compatible width (24 mm) CCT Bin Options B = Version 3 = 3 SDCM Module Configuration Nominal CCT 30 = 3000 K 35 = 3500 K 40 = 4000 K 50 = 5000 K 57 = 5700 K Minimum CRI E = 80 Nominal Flux 1000 = 1000 lm 2000 = 2000 lm 4000 = 4000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Measurement Data (Tc = 25° C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current (mA) Typical Flux3,4 Tc2 = 25º C (lm) Minimum Flux4,5 Tc2 = 25º C (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXEB-L0280Z-30E1000-C-B3 3000 1195 1076 19.5 6.8 175 BXEB-L0280Z-35E1000-C-B3 3500 1195 1076 19.5 6.8 175 BXEB-L0280Z-40E1000-C-B3 4000 1230 1107 19.5 6.8 180 BXEB-L0280Z-50E1000-C-B3 5000 1230 1107 19.5 6.8 180 BXEB-L0280Z-57E1000-C-B3 5700 1230 1107 19.5 6.8 180 BXEB-L0560Z-30E2000-C-B3 3000 2390 2151 19.5 13.6 175 BXEB-L0560Z-35E2000-C-B3 3500 2390 2151 19.5 13.6 175 BXEB-L0560Z-40E2000-C-B3 4000 2460 2214 19.5 13.6 180 BXEB-L0560Z-50E2000-C-B3 5000 2460 2214 19.5 13.6 180 BXEB-L0560Z-57E2000-C-B3 5700 2460 2214 19.5 13.6 180 BXEB-L1120Z-30E4000-C-B3 3000 4780 4302 39.0 27.3 175 BXEB-L1120Z-35E4000-C-B3 3500 4780 4302 39.0 27.3 175 BXEB-L1120Z-40E4000-C-B3 4000 4920 4428 39.0 27.3 180 BXEB-L1120Z-50E4000-C-B3 5000 4920 4428 39.0 27.3 180 BXEB-L1120Z-57E4000-C-B3 5700 4920 4428 39.0 27.3 180 80 80 80 350 700 700 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. 3. Products tested at nominal test current where temperature of center case temperature point Tc= 25° C. Values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 4. Bridgelux maintains a ± 7% tolerance on flux measurements. 5. Minimum performance values are provided as reference only and are not a guarantee of performance. 3 Electrical Characteristics Table 2: Electrical Characteristics Forward Voltage Tc2 Part Number Driver Selection Typical Coefficient of Forward = 25º C (V) 1, 2,3 Drive Current (mA) Voltages5 (V) Voltage4 Minimum Typical Maximum ∆Vf/∆T (mV/º C) Vf Min, Hot Tc2 = 85º C (V) Vf Max, Cold Tc2 = -40º C (V) 350 18.5 19.5 20.6 -7.0 18.1 21.1 700 19.4 20.5 21.6 -7.0 19.0 22.1 700 18.5 19.5 20.6 -7.0 18.1 21.1 1400 19.4 20.5 21.6 -7.0 19.0 22.1 700 37.0 39.0 41.2 -14.0 36.2 42.1 1400 38.8 41.0 43.2 -14.0 38.0 44.1 BXEB-L0280Z-xxx1000-C-B3 BXEB-L0560Z-xxx2000-C-B3 BXEB-L1120Z-xxx4000-C-B3 Notes for Table 2: 1. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a tolerance of ± 0.10 V on forward voltage measurements. 3. This product has been designed and manufactured per IEC 62031:2014. The working voltage designated for the insulation is 60 V d.c. The maximum allowable voltage across the module must be determined in the end product application. 4. Typical coefficient of forward voltage tolerance is ± 0.1 mV for nominal current. 5. Vf min hot and max cold values are provided as reference only and are not guaranteed. These values are provided to aid in driver design and selection over the operating range of the product. 4 Absolute Maximum Ratings Table 3: Maximum Ratings Parameter Maximum Rating Storage Temperature -40°C to +85°C Operating Case Temperature1 (Tc) 85°C Soldering Temperature2 350°C or lower for a maximum of 5 seconds Maximum Reverse Voltage Linears are not designed to be driven in reverse bias Maximum Drive Current3 BXEB-L0280Z-xxx1000-C-B3 BXEB-L0560Z-xxx2000-C-B3 BXEB-L1120Z-xxx4000-C-B3 700mA 1400mA 1400mA Notes for Table 3: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the SMDs used in the modules. Contact your Bridgelux sales representatives for LM-80 report. 5 Performance Curves Figure 1: 280mm Current vs. Forward Voltage, Tc=25°C Figure 2: 280mm Relative Flux vs. Current, Tc=25°C 800 250% Relative Luminous Flux (%) Forward Current (mA) 700 600 500 400 300 200 200% 150% 100% 50% 100 0 18.0 18.5 19.0 19.5 20.0 Forward Voltage (V) 20.5 0% 21.0 0 400 600 800 Drive Current (mA) Figure 3: 560mm Current vs. Forward Voltage, Tc=25°C Figure 4: 560mm Relative Flux vs. Current, Tc=25°C 1600 250% Relative Luminous Flux (%) 1400 Forward Current (mA) 200 1200 1000 800 600 400 200% 150% 100% 50% 200 0 18.0 0% 18.5 19.0 19.5 20.0 Forward Voltage (V) 20.5 0 21.0 500 1000 1500 Drive Current (mA) Figure 5: 1120mm Current vs. Forward Voltage, Tc=25°C Figure 6: 1120mm Relative Flux vs. Current, Tc=25°C 250% 1600 Relative Luminous Flux (%) Forward Current (mA) 1400 1200 1000 800 600 400 200% 150% 100% 50% 200 0 36.0 0% 37.0 38.0 39.0 40.0 Forward Voltage (V) 41.0 42.0 0 500 1000 1500 Drive Current (mA) 6 Performance Curves Figure 7: Relative Flux vs. Case Temperature Figure 8: Relative Voltage vs. Case Temperature 100.5% 102% 25°C Pulsed 25°C Pulsed 100.0% 98% Relative Voltage Relative Luminous Flux (%) 100% 96% 94% 99.5% 99.0% 98.5% 98.0% 92% 90% 97.5% 0 20 40 60 Case Temperature (°C) 80 100 0 20 40 60 80 100 Case Temperature (°C) 7 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern 120% Relative Intensity 100% 80% 60% 40% 20% 0% -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (°) Notes for Figure 9: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. 8 Typical Color Spectrum Figure 10: Typical Color Spectrum 120% 30E Relative Intensity 100% 40E 50E 80% 60% 40% 20% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 10: 1. Color spectra measured at nominal current for Tc2 = 50°C. 2. Color spectra shown for 30E is 3000K and 80 CRI. 3. Color spectra shown for 40E is 4000K and 80 CRI. 4. Color spectra shown for 57E is 5700K and 80 CRI. 9 Mechanical Dimensions Figure 11: Drawing for EB Series Gen2 280mm Table 4: Dimensions for 280mm Parameter Specification Unit Linear length 280 mm Linear width 24 mm Linear thickness 6.1 mm PCB thickness 1.6 mm Figure 12: Drawing for EB Series Gen2 560mm Table 5: Dimensions for 560mm Parameter Specification Unit Linear length 560 mm Linear width 24 mm Linear thickness 6.1 mm PCB thickness 1.6 mm 10 Mechanical Dimensions Figure 13: Drawing for EB Series Gen2 1120mm Table 6: Dimensions for 1120mm Parameter Specification Unit Linear length 1120 mm Linear width 24 mm Linear thickness 6.1 mm PCB thickness 1.6 mm Notes for Figures 11, 12 & 13: 1. Solder pads are labeled “+” to denote positive polarity, and “-” to denote negative polarity. 2. Drawings are not to scale. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, the tolerances are ± 0.10mm.. Table 7: Connector and wiring Parameter Specification Input wire cross-section 18-24 AWG Terminal strip length 7-9 mm 11 Color Binning Information Figure 14: Graph of Warm and Neutral White Test Bins in xy Color Space Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 3000K 3500 K 4000K ANSI Bin (for reference only) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) B3 (3SDCM) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) Center Point (x,y) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 15: Graph of Cool White Test Bins in xy Color Space Table 9: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5700K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) B3 (3SDCM) (4835K - 5155K) (5445K - 5850K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) Notes for Tables 8 and 9 1. Color binning at solder point temperature Tsp of SMDs at 85°C. 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. 12 Packaging and Labeling Figure 16: EB Series Packaging and Labeling Table 10: Packaging Structure L0280 modules Tray Box Shipping Box Quantity 40 200 400 Dimension 63 cm x 39 cm x 2.4 cm 63.5 cm x 41.5 cm x 13.5 cm 134 cm x 43.5 cm x 18 cm L0560 modules Tray Box Shipping Box Quantity 20 100 200 Dimension 63 cm x 39 cm x 2.4 cm 63.5 cm x 41.5 cm x 13.5 cm 134 cm x 43.5 cm x 18 cm L1120 modules Tray Box Shipping Box Quantity 20 n/a 100 Dimension 119 cm x 39 cm x 2.4 cm n/a 134 cm x 43.5 cm x 18 cm Figure 17: Product Labeling Bridgelux EB Series modules contain a label on the front to help with product identification. In addition to the product identification markings, Bridgelux EB Series modules also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the module. EB Series Gen2 1ft 1000lm 350mA Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. 13 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the EB Series product family. For a list of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux EB Series LED linears are available in both IGES and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED linear. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux EB Series is in accordance with IEC/TR62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. EB Series linears are classified as Risk Group 1 (TBD) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the linear or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the linear. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the EB Series linear. Use the mechanical features of the linear housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the EB Series linears during operation. Allow the linear to cool for a sufficient period of time before handling. The EB Series linears may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, linear testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 14 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2017 Bridgelux, Inc. All rights reserved 2017. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc, and EB Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux EB Series Gen2 Data Sheet DS131 Rev. A (10/2017) 15
BXEB-L0560Z-40E2000-C-B3 价格&库存
很抱歉,暂时无法提供与“BXEB-L0560Z-40E2000-C-B3”相匹配的价格&库存,您可以联系我们找货
    • 1+37.02240
    • 200+14.77440
    • 500+14.28840
    • 1000+14.04000
