BXRH-40G0600-B-82
BXRH-40G0600-B-82
    BRIDGELUX(普瑞)
BXRH-40G0600-B-82 数据手册
Bridgelux Gen 8 V4 HD LED Array ® Product Data Sheet DS404 1 V Series HD Introduction V Series™ HD LED array product, an ultra-high lumen density COB product line, is designed for high intensity spotlights used in commercial and retail settings. V Series HD arrays offer industry leading color over angle uniformity, and replace ceramic metal halide lamps by providing equal or greater center beam candle power at lower power and at greater lifetimes. Their tight beam control and exceptional quality of light is well suited for demanding directional spot applications. The V4 HD LED array is available in a variety of CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, but are not limited to, commercial and residential down lights, accent, spot and track lights. Bridgelux Décor Series™ is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 91, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen. Features Benefits • Efficacy of 134 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixelation • Uniform high quality illumination • High quality true color reproduction • Minimum 80, 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 3 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 5 Electrical Characteristics 9 Eye Safety 10 Absolute Maximum Ratings 11 Performance Curves 12 Typical Radiation Pattern 14 TTypical Color Spectrum 15 Mechanical Dimensions 16 Color Binning Information 17 Packaging and Labeling 18 Design Resources 20 Precautions 20 Disclaimers 20 About Bridgelux 21 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series HD arrays are the most compact chip-on-borad devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series HD family of products. Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties Yellow phosphor Light Emitting Surface (LES) White ring around LES Case Temperature (Tc) Measurement Point Solder pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series HD LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRH – 30 E 060 0 – A – 8 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K Gen. 8 3 = 3 SDCM Array Configuration CRI E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted Flux Indicator 060x = 600 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) BXRH-25E0600-B-8x 2500 80 350 781 BXRH-27E0600-A-8x 2700 80 175 817 Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 703 18.3 6.4 122 735 36.6 6.4 128 BXRH-27E0600-B-8x 2700 80 350 817 735 18.3 6.4 128 BXRH-27G0600-A-8x 2700 90 175 674 607 36.6 6.4 105 BXRH-27G0600-B-8x 2700 90 350 674 607 18.3 6.4 105 BXRH-27H0600-A-8x 2700 97 175 597 538 36.6 6.4 93 BXRH-27H0600-B-8x 2700 97 350 597 538 18.3 6.4 93 BXRH-30E0600-A-8x 3000 80 175 868 781 36.6 6.4 136 BXRH-30E0600-B-8x 3000 80 350 868 781 18.3 6.4 136 110 BXRH-30G0600-A-8x 3000 90 175 705 634 36.6 6.4 BXRH-30G0600-B-8x 3000 90 350 705 634 18.3 6.4 110 BXRH-30H0600-A-8x 3000 90 175 638 574 36.6 6.4 100 BXRH-30H0600-B-8x 3000 90 350 638 574 18.3 6.4 100 BXRH-35E0600-A-8x 3000 90 175 888 800 36.6 6.4 139 BXRH-35E0600-B-8x 3000 90 350 888 800 18.3 6.4 139 BXRH-35G0600-A-8x 3500 90 175 730 657 36.6 6.4 114 BXRH-35G0600-B-8x 3500 90 350 730 657 18.3 6.4 114 BXRH-35H0600-A-8x 3500 97 175 656 590 36.6 6.4 102 BXRH-35H0600-B-8x 3500 97 350 656 590 18.3 6.4 102 BXRH-40E0600-A-8x 4000 80 175 894 804 36.6 6.4 140 BXRH-40E0600-B-8x 4000 80 350 894 804 18.3 6.4 140 116 BXRH-40G0600-A-8x 4000 90 175 745 671 36.6 6.4 BXRH-40G0600-B-8x 4000 90 350 745 671 18.3 6.4 116 BXRH-40H0600-A-8x 4000 97 175 674 607 36.6 6.4 105 BXRH-40H0600-B-8x 4000 97 350 674 607 18.3 6.4 105 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI values are typical for Decor Series Ultra CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 91. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) BXRH-25E0600-B-8x 2500 80 350 703 BXRH-27E0600-A-8x 2700 80 175 735 Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 633 17.7 6.2 113 662 35.4 6.2 119 BXRH-27E0600-B-8x 2700 80 350 735 662 17.7 6.2 119 BXRH-27G0600-A-8x 2700 90 175 607 546 35.4 6.2 98 BXRH-27G0600-B-8x 2700 90 350 607 546 17.7 6.2 98 BXRH-27H0600-A-8x 2700 97 175 538 484 35.4 6.2 87 BXRH-27H0600-B-8x 2700 97 350 538 484 17.7 6.2 87 BXRH-30E0600-A-8x 3000 80 175 781 703 35.4 6.2 126 BXRH-30E0600-B-8x 3000 80 350 781 703 17.7 6.2 126 BXRH-30G0600-A-8x 3000 90 175 634 571 35.4 6.2 102 BXRH-30G0600-B-8x 3000 90 350 634 571 17.7 6.2 102 93 BXRH-30H0600-A-8x 3000 97 175 574 517 35.4 6.2 BXRH-30H0600-B-8x 3000 97 350 574 517 17.7 6.2 93 BXRH-35E0600-A-8x 3500 80 175 800 720 35.4 6.2 129 BXRH-35E0600-B-8x 3500 80 350 800 720 17.7 6.2 129 BXRH-35G0600-A-8x 3500 90 175 657 591 35.4 6.2 106 BXRH-35G0600-B-8x 3500 90 350 657 591 17.7 6.2 106 BXRH-35H0600-A-8x 3500 97 175 590 531 35.4 6.2 95 BXRH-35H0600-B-8x 3500 97 350 590 531 17.7 6.2 95 130 BXRH-40E0600-A-8x 4000 80 175 804 724 35.4 6.2 BXRH-40E0600-B-8x 4000 80 350 804 724 17.7 6.2 130 BXRH-40G0600-A-8x 4000 90 175 671 604 35.4 6.2 108 BXRH-40G0600-B-8x 4000 90 350 671 604 17.7 6.2 108 BXRH-40H0600-A-8x 4000 97 175 607 546 35.4 6.2 98 BXRH-40H0600-B-8x 4000 97 350 607 546 17.7 6.2 98 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra . CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 91. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 4 Performance at Commonly Used Drive Currents V Series HD LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series HD LED arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRH-25E0600-B-8x 80 BXRH-27E0600-A-8x 80 BXRH-27E0600-B-8x 80 BXRH-27G0600-A-8x 90 BXRH-27G0600-B-8x 90 BXRH-27H0600-A-8x 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 409 601 781 949 1020 1217 427 629 817 993 1066 1273 427 629 817 993 1066 1273 353 519 674 819 880 1050 353 519 674 819 880 1050 312 460 597 726 780 931 368 541 703 854 918 1095 385 566 735 893 960 1146 385 566 735 893 960 1146 317 467 607 737 792 945 317 467 607 737 792 945 281 414 538 653 702 838 141 130 122 114 111 103 147 136 128 119 116 107 147 136 128 119 116 107 121 113 105 99 96 89 121 113 105 99 96 89 108 100 93 87 85 79 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRH-27H0600-B-8x 97 BXRH-30E0600-A-8x 80 BXRH-30E0600-B-8x 80 BXRH-30G0600-A-8x 90 BXRH-30G0600-B-8x 90 BXRH-30H0600-A-8x 90 BXRH-30H0600-B-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 312 460 597 726 780 931 454 668 868 1055 1133 1352 454 668 868 1055 1133 1352 369 542 705 856 920 1098 369 542 705 856 920 1098 334 491 638 775 833 994 334 491 638 775 833 994 281 414 538 653 702 838 409 601 781 949 1020 1217 409 601 781 949 1020 1217 332 488 634 770 828 988 332 488 634 770 828 988 300 442 574 698 750 895 300 442 574 698 750 895 108 100 93 87 85 79 156 145 136 127 123 114 156 145 136 127 123 114 127 118 110 103 100 93 127 118 110 103 100 93 115 107 100 93 91 84 115 107 100 93 91 84 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 6 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRH-35E0600-A-8x 90 BXRH-35E0600-B-8x 90 BXRH-35G0600-A-8x 90 BXRH-35G0600-B-8x 90 BXRH-35H0600-A-8x 97 BXRH-35H0600-B-8x 97 BXRH-40E0600-A-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 465 684 888 1079 1160 1384 465 684 888 1079 1160 1384 382 562 730 887 953 1138 382 562 730 887 953 1138 343 505 656 797 856 1022 343 505 656 797 856 1022 467 688 894 1086 1166 1392 418 615 800 971 1044 1246 418 615 800 971 1044 1246 344 506 657 798 858 1024 344 506 657 798 858 1024 309 454 590 717 771 920 309 454 590 717 771 920 421 619 804 977 1050 1253 160 148 139 130 126 117 160 148 139 130 126 117 132 122 114 107 104 96 132 122 114 107 104 96 118 110 102 96 93 86 118 110 102 96 93 86 161 149 140 131 127 118 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRH-40E0600-B-8x 80 BXRH-40H0600-A-8x 97 BXRH-40H0600-B-8x 97 BXRH-40G0600-A-8x 90 BXRH-40G0600-B-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 85 130 175 220 240 300 170 260 350 440 480 600 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 34.1 35.5 36.6 37.8 38.2 39.5 17.1 17.7 18.3 18.9 19.1 19.7 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 2.9 4.6 6.4 8.3 9.2 11.8 467 688 894 1086 1166 1392 353 519 674 819 880 1050 353 519 674 819 880 1050 390 574 745 906 973 1161 390 574 745 906 973 1161 421 619 804 977 1050 1253 317 467 607 737 792 945 317 467 607 737 792 945 351 516 671 815 876 1045 351 516 671 815 876 1045 161 149 140 131 127 118 121 113 105 99 96 89 121 113 105 99 96 89 134 124 116 109 106 98 134 124 116 109 106 98 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 1.43 32.3 40.6 -21.58 1.67 34.8 43.9 19.7 -10.00 1.43 16.1 20.3 21.2 -10.77 1.67 17.4 21.9 Minimum Typical Maximum 175 33.9 36.6 39.3 -20.00 300 36.5 39.5 42.5 350 16.9 18.3 600 18.2 19.7 BXRH-xxx060x-A-8x BXRH-xxx060x-B-8x Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 50V d.c. The maximum allowable voltage across the array must be determined in the end product application. 9 Eye Safety Table 5: Eye Safety Risk Group (RG) Classifications Part Number CCT1,3 Drive Current (mA) 2700K/3000K 4000K2 175 RG1 RG1 300 RG1 RG2 350 RG1 RG1 600 RG1 RG2 BXRH-xxx060x-A-8x BXRH-xxx060x-B-8x Notes for Table 5: 1. Eye safety classification for the use of Bridgelux V Series HD LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1760 lx. 3. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 10 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRH-xxx060x-A-8x BXRH-xxx060x-B-8x Maximum Drive Current3 300 mA 600 mA Maximum Peak Pulsed Drive Current4 340 mA 680 mA Maximum Reverse Voltage5 -30V -60V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 11 Performance Curves Figure 1: V4A HD Drive Current vs. Voltage (Tj = Tc = 25°C)1 Figure 2: V4B HD Drive Current vs. Voltage (Tj = Tc = 25°C)1 20.0 39.0 19.5 38.0 19.0 Voltage (V) Voltage (V) 40.0 37.0 36.0 18.5 18.0 35.0 17.5 34.0 17.0 33.0 0 100 200 300 16.5 400 0 200 Drive Current (mA) 180% 800 180% 160% Relative Luminous Flux (%) Relative Luminous Flux (%) 600 Figure 4: V4B HD Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C)1 Figure 3: V4A HD Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C)1 140% 120% 100% 80% 60% 40% 20% 0% 0 100 200 300 160% 140% 120% 100% 80% 60% 40% 20% 0% 400 0 200 Drive Current (mA) 400 600 800 Drive Current (mA) Figure 5: Typical DC Flux vs. Case Temperature Figure 6: Typical DC ccx Shift vs. Case Temperature 102% 0.0010 100% 0.0008 98% 0.0006 96% 0.0004 94% 92% 25℃ Pulsed 90% ccx shift Relative Luminous Flux 400 Drive Current (mA) 0.0002 0.0000 -0.0002 88% -0.0004 86% -0.0006 -0.0008 84% 0 20 40 60 80 Case Temperature (Tc) 100 120 0 20 40 60 80 100 120 Case Temperature (Tc) Notes for Figures 1 - 6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for 3000K and 90 CRI. 12 Performance Curves Figure 8: Derating Curve 0.0010 700 0.0000 600 -0.0010 500 Drive Current (mA) ccy shift Figure 7: Typical DC ccy Shift vs. Case Temperature -0.0020 -0.0030 -0.0040 -0.0050 400 300 BXRH-xxx060x-A-8x 200 BXRH-xxx060x-B-8x 100 -0.0060 0 20 40 60 80 Case Temperature (Tc) 100 120 0 0 20 40 60 80 Case Temperature (Tc) 100 120 Notes for Figures 7: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for 3000K and 90 CRI. 13 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern Notes for Figure 9: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 10: Typical Polar Radiation Pattern 14 Typical Color Spectrum Figure 11: Typical Color Spectrum 100% 27E 30E 90% 40E Relative Spectral Power Distribution 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Notes for Figure 11: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 2700K and 80 CRI. 3. Color spectra shown is 3000K and 80 CRI. 4. Color spectra shown is 4000K and 80 CRI. Figure 12: Typical Color Spectrum for Décor Series 100% 27H 90% 30H 30G (Décor Series Showcase) Relative Spectral Power Distribution 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 12: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 15 Mechanical Dimensions Figure 13: Drawing for V4 HD LED Array Notes for Figure 13: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Solder pads are labeled “+” and “-“ to denote positive and negative polarity, respectively. 4. Unless otherwise specified, tolerances are ±0.1mm. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 16 Color Binning Information Figure 14: Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 7: 1. Bridgelux maintains a tolerance of +/- 0.007 on x and y color coordinates in the CIE 1931 color Space. 17 Packaging and Labeling Figure 15: V4 HD Packaging Tube BXRH-30E0600-A-83 40 240 Notes for Figure 15: 1. Each tube holds 40 V4 HD COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 14.3 (W) x 8.3(H) x 530 (L) mm. Dimensions for the anti-static bag are 75 (W) x 615 (L) x 0.075 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 18 Packaging and Labeling Figure 16: V Series HD Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E0600A 83 Internal Bin Code 19 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series HD LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representatives for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series HD LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series HD LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 20 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V4 HD Array Series Product Data Sheet DS404 Rev. A (05/2021) 21
BXRH-40G0600-B-82 价格&库存
很抱歉,暂时无法提供与“BXRH-40G0600-B-82”相匹配的价格&库存,您可以联系我们找货
