BXRC-40E1000-B-83-SE
    BRIDGELUX(普瑞)
BXRC-40E1000-B-83-SE 数据手册
Bridgelux Gen 8 Vero 10 Array ® ® Product Data Sheet DS420 1 Vero® Series Introduction The Vero® Series is a revolutionary advancement in chip on board (COB) light source technology and innovation, simplifying the luminaire design and manufacturing processes. Vero Chip on Board (COB) LED arrays are available in four LES configurations, engineered to enable new degrees of flexibility and reliability over a broad range of electrical currents. Vero arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero products include an onboard connector port that enables a solder-free electrical interconnect, and simple mounting features for plug-and-play installation. Features Benefits • On board connector port • Solder free installation and field upgradability • Top side part number markings • Improved inventory management and quality control • Efficacy of 178 lm/W typical, 3000K 80 CRI • Enables high efficiency lighting systems and lower operating costs • Reliable operation at up to 3x nominal current, 30% increase in maximum lumens per LES size • Wide selection of CCT options (2700K-6500K) with minimum 70, 80 and 90 CRI options • Uniform high-quality illumination • 2 and 3 SDCM binning options (2700K – 4000K) • Forward voltage bin codes (backside marking) • Thermally isolated solder pads • 10-Year warranty • Supports the trend toward luminaire miniaturization and delivers enhanced optical control • Design flexibility for a broad range of lighting applications • Clean white light without pixelation • Uniform consistent white light • Design flexibility for multi-source applications • Enhanced ease of use and installation • Design with confidence Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 7 Electrical Characteristics 16 Eye Safety 17 Absolute Maximum Ratings 18 Performance Curves 19 Typical Radiation Pattern 21 Typical Color Spectrum 22 Mechanical Dimensions 23 Color Binning Information 24 Packaging and Labeling 25 Design Resources 27 Precautions 27 Disclaimers 27 About Bridgelux 28 1 Product Feature Map Vero 10 is the smallest form factor in the Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero Series family of products. 2D Bar code provides full manufacturing traceability Thermally isolated solder pads reduce manufacturing cycle time and complexity Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Mounting holes Top side part number marking improves inventory management and outgoing quality control Radial die configuration improves lumen density and beam control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Molex Pico-EZmate™ connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 100 0 – C – 83 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen. 8 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Target Flux Indicator 100x = 1000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E1000-B-8x 2700 80 200 1145 1008 34.2 6.8 167 BXRC-27E1000-C-8x 2700 80 300 1544 1359 30.7 9.2 168 BXRC-27E1000-D-8x 2700 80 250 1043 918 24.9 6.2 168 BXRC-27G1000-B-8x 2700 90 200 945 832 34.2 6.8 138 BXRC-27G1000-C-8x 2700 90 300 1274 1121 30.7 9.2 138 BXRC-27G1000-D-8x 2700 90 250 860 757 24.9 6.2 138 BXRC-27G10H0-B-8x 2700 90 200 986 867 34.2 6.8 144 BXRC-27G10H0-C-8x 2700 90 300 1329 1170 30.7 9.2 144 BXRC-27G10H0-D-8x 2700 90 250 897 790 24.9 6.2 144 BXRC-30C1001-B-8x 3000 70 200 1274 1121 34.2 6.8 186 BXRC-30C1001-C-8x 3000 70 300 1718 1512 30.7 9.2 187 BXRC-30C1001-D-8x 3000 70 250 1160 1021 24.9 6.2 186 BXRC-30E1000-B-8x 3000 80 200 1217 1071 34.2 6.8 178 BXRC-30E1000-C-8x 3000 80 300 1641 1444 30.7 9.2 178 BXRC-30E1000-D-8x 3000 80 250 1108 975 24.9 6.2 178 BXRC-30G1000-B-8x 3000 90 200 988 869 34.2 6.8 144 BXRC-30G1000-C-8x 3000 90 300 1332 1172 30.7 9.2 145 BXRC-30G1000-D-8x 3000 90 250 899 792 24.9 6.2 144 BXRC-30G10H0-B-8x 3000 90 200 1034 910 34.2 6.8 151 BXRC-30G10H0-C-8x 3000 90 300 1395 1227 30.7 9.2 151 BXRC-30G10H0-D-8x 3000 90 250 942 829 24.9 6.2 151 BXRC-35E1000-B-8x 3500 80 200 1246 1096 34.2 6.8 182 BXRC-35E1000-C-8x 3500 80 300 1680 1478 30.7 9.2 182 BXRC-35E1000-D-8x 3500 80 250 1134 998 24.9 6.2 182 BXRC-35G1000-B-8x 3500 90 200 1024 901 34.2 6.8 150 BXRC-35G1000-C-8x 3500 90 300 1380 1215 30.7 9.2 150 BXRC-35G1000-D-8x 3500 90 250 932 820 24.9 6.2 150 BXRC-40C1001-B-8x 4000 70 200 1310 1153 34.2 6.8 192 BXRC-40C1001-C-8x 4000 70 300 1766 1555 30.7 9.2 192 BXRC-40C1001-D-8x 4000 70 250 1193 1050 24.9 6.2 192 BXRC-40E1000-B-8x 4000 80 200 1253 1102 34.2 6.8 183 BXRC-40E1000-C-8x 4000 80 300 1689 1487 30.7 9.2 183 BXRC-40E1000-D-8x 4000 80 250 1141 1004 24.9 6.2 183 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Part Number CRI BXRC-40G1000-B-8x 4000 90 200 1045 BXRC-40G1000-C-8x 4000 90 300 1409 BXRC-40G1000-D-8x 4000 90 250 952 837 24.9 6.2 153 BXRC-50C1001-B-8x 5000 70 200 1317 1159 34.2 6.8 193 193 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Nominal CCT1 (K) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 920 34.2 6.8 153 1240 30.7 9.2 153 BXRC-50C1001-C-8x 5000 70 300 1776 1563 30.7 9.2 BXRC-50C1001-D-8x 5000 70 250 1199 1055 24.9 6.2 193 BXRC-50E1001-B-8x 5000 80 200 1267 1115 34.2 6.8 185 BXRC-50E1001-C-8x 5000 80 300 1709 1504 30.7 9.2 186 BXRC-50E1001-D-8x 5000 80 250 1154 1015 24.9 6.2 185 BXRC-50G1001-B-8x 5000 90 200 1095 964 34.2 6.8 160 BXRC-50G1001-C-8x 5000 90 300 1477 1300 30.7 9.2 160 BXRC-50G1001-D-8x 5000 90 250 997 878 24.9 6.2 160 BXRC-57C1001-B-8x 5700 70 200 1281 1128 34.2 6.8 187 BXRC-57C1001-C-8x 5700 70 300 1728 1521 30.7 9.2 188 BXRC-57C1001-D-8x 5700 70 250 1167 1027 24.9 6.2 187 BXRC-57E1001-B-8x 5700 80 200 1217 1071 34.2 6.8 178 BXRC-57E1001-C-8x 5700 80 300 1641 1444 30.7 9.2 178 BXRC-57E1001-D-8x 5700 80 250 1108 975 24.9 6.2 178 BXRC-65C1001-B-8x 6500 70 200 1281 1128 34.2 6.8 187 BXRC-65C1001-C-8x 6500 70 300 1728 1521 30.7 9.2 188 BXRC-65C1001-D-8x 6500 70 250 1167 1027 24.9 6.2 187 BXRC-65E1001-B-8x 6500 80 200 1231 1084 34.2 6.8 180 BXRC-65E1001-C-8x 6500 80 300 1660 1461 30.7 9.2 180 BXRC-65E1001-D-8x 6500 80 250 1121 987 24.9 6.2 180 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E1000-B-8x 2700 80 200 1031 907 33.6 6.7 154 BXRC-27E1000-C-8x 2700 80 300 1390 1223 30.1 9.0 154 BXRC-27E1000-D-8x 2700 80 250 939 826 24.4 6.1 154 BXRC-27G1000-B-8x 2700 90 200 850 748 33.6 6.7 127 BXRC-27G1000-C-8x 2700 90 300 1147 1009 30.1 9.0 127 BXRC-27G1000-D-8x 2700 90 250 774 681 24.4 6.1 127 BXRC-27G10H0-B-8x 2700 90 200 887 781 33.6 6.7 132 BXRC-27G10H0-C-8x 2700 90 300 1196 1053 30.1 9.0 132 BXRC-27G10H0-D-8x 2700 90 250 808 711 24.4 6.1 132 BXRC-30C1001-B-8x 3000 70 200 1147 1009 33.6 6.7 171 BXRC-30C1001-C-8x 3000 70 300 1546 1361 30.1 9.0 171 BXRC-30C1001-D-8x 3000 70 250 1044 919 24.4 6.1 171 BXRC-30E1000-B-8x 3000 80 200 1095 964 33.6 6.7 163 BXRC-30E1000-C-8x 3000 80 300 1477 1300 30.1 9.0 163 BXRC-30E1000-D-8x 3000 80 250 997 878 24.4 6.1 163 BXRC-30G1000-B-8x 3000 90 200 889 782 33.6 6.7 133 BXRC-30G1000-C-8x 3000 90 300 1199 1055 30.1 9.0 133 BXRC-30G1000-D-8x 3000 90 250 809 712 24.4 6.1 133 BXRC-30G10H0-B-8x 3000 90 200 931 819 33.6 6.7 139 139 BXRC-30G10H0-C-8x 3000 90 300 1255 1105 30.1 9.0 BXRC-30G10H0-D-8x 3000 90 250 848 746 24.4 6.1 139 BXRC-35E1000-B-8x 3500 80 200 1121 987 33.6 6.7 167 BXRC-35E1000-C-8x 3500 80 300 1512 1330 30.1 9.0 167 BXRC-35E1000-D-8x 3500 80 250 1021 898 24.4 6.1 167 BXRC-35G1000-B-8x 3500 90 200 921 811 33.6 6.7 137 BXRC-35G1000-C-8x 3500 90 300 1242 1093 30.1 9.0 137 BXRC-35G1000-D-8x 3500 90 250 839 738 24.4 6.1 137 BXRC-40C1001-B-8x 4000 70 200 1179 1038 33.6 6.7 176 BXRC-40C1001-C-8x 4000 70 300 1590 1399 30.1 9.0 176 BXRC-40C1001-D-8x 4000 70 250 1073 945 24.4 6.1 176 BXRC-40E1000-B-8x 4000 80 200 1128 992 33.6 6.7 168 BXRC-40E1000-C-8x 4000 80 300 1520 1338 30.1 9.0 168 BXRC-40E1000-D-8x 4000 80 250 1027 903 24.4 6.1 168 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40G1000-B-8x 4000 90 200 941 828 33.6 6.7 140 BXRC-40G1000-C-8x 4000 90 300 1268 1116 30.1 9.0 140 BXRC-40G1000-D-8x 4000 90 250 856 754 24.4 6.1 140 BXRC-50C1001-B-8x 5000 70 200 1186 1043 33.6 6.7 177 BXRC-50C1001-C-8x 5000 70 300 1599 1407 30.1 9.0 177 BXRC-50C1001-D-8x 5000 70 250 1079 950 24.4 6.1 177 BXRC-50E1001-B-8x 5000 80 200 1140 1004 33.6 6.7 170 BXRC-50E1001-C-8x 5000 80 300 1538 1353 30.1 9.0 170 BXRC-50E1001-D-8x 5000 80 250 1038 914 24.4 6.1 170 BXRC-50G1001-B-8x 5000 90 200 986 867 33.6 6.7 147 BXRC-50G1001-C-8x 5000 90 300 1329 1170 30.1 9.0 147 BXRC-50G1001-D-8x 5000 90 250 897 790 24.4 6.1 147 BXRC-57C1001-B-8x 5700 70 200 1153 1015 33.6 6.7 172 BXRC-57C1001-C-8x 5700 70 300 1555 1368 30.1 9.0 172 BXRC-57C1001-D-8x 5700 70 250 1050 924 24.4 6.1 172 BXRC-57E1001-B-8x 5700 80 200 1095 964 33.6 6.7 163 BXRC-57E1001-C-8x 5700 80 300 1477 1300 30.1 9.0 163 BXRC-57E1001-D-8x 5700 80 250 997 878 24.4 6.1 163 BXRC-65C1001-B-8x 6500 70 200 1153 1015 33.6 6.7 172 172 BXRC-65C1001-C-8x 6500 70 300 1555 1368 30.1 9.0 BXRC-65C1001-D-8x 6500 70 250 1050 924 24.4 6.1 172 BXRC-65E1001-B-8x 6500 80 200 1108 975 33.6 6.7 165 BXRC-65E1001-C-8x 6500 80 300 1494 1315 30.1 9.0 165 BXRC-65E1001-D-8x 6500 80 250 1009 888 24.4 6.1 165 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are minimums for all products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E1000-B-8x 80 BXRC-27E1000-C-8x 80 BXRC-27E1000-D-8x 80 BXRC-27G1000-B-8x 90 BXRC-27G1000-C-8x 90 BXRC-27G1000-D-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 597 872 1145 1500 2131 2581 805 1176 1544 1817 2874 4400 544 784 1043 1412 1940 3412 493 719 945 1238 1758 2129 664 970 1274 1499 2371 3630 448 647 860 1165 1601 2815 537 785 1031 1350 1918 2323 725 1058 1390 1635 2586 3960 489 706 939 1271 1746 3070 443 647 850 1114 1582 1917 598 873 1147 1349 2134 3267 404 582 774 1048 1441 2533 181 173 168 159 146 138 181 173 168 162 146 126 181 174 168 158 146 117 150 143 138 131 120 114 150 143 138 134 120 104 150 143 138 130 120 97 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G10H0-B-8x 90 BXRC-27G10H0-C-8x 90 BXRC-27G10H0-D-8x 90 BXRC-30C1001-B-8x 70 BXRC-30C1001-C-8x 70 BXRC-30C1001-D-8x 70 BXRC-30E1000-B-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 514 750 986 1291 1834 2221 693 1012 1329 1564 2473 3787 468 675 897 1215 1670 2936 664 970 1274 1669 2371 2872 896 1308 1718 2021 3197 4895 605 872 1160 1571 2159 3795 634 926 1217 1594 2264 2742 462 675 887 1162 1651 1999 624 911 1196 1407 2226 3408 421 607 808 1093 1503 2642 598 873 1147 1502 2134 2584 806 1177 1546 1819 2877 4405 544 785 1044 1414 1943 3416 571 834 1095 1435 2038 2468 156 149 144 137 126 118 156 149 144 139 126 108 156 149 144 136 126 101 202 193 186 176 162 153 202 193 186 180 162 140 202 193 186 175 162 130 193 184 178 169 155 146 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30E1000-C-8x 80 BXRC-30E1000-D-8x 80 BXRC-30G1000-B-8x 90 BXRC-30G1000-C-8x 90 BXRC-30G1000-D-8x 90 BXRC-30G10H0-B-8x 90 BXRC-30G10H0-C-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 855 1249 1641 1930 3053 4675 578 833 1108 1500 2062 3625 515 752 988 1294 1838 2226 694 1014 1332 1567 2479 3795 469 676 899 1218 1673 2942 539 787 1034 1355 1925 2331 727 1062 1395 1641 2595 3974 770 1124 1477 1737 2748 4207 520 750 997 1350 1855 3262 463 677 889 1165 1654 2004 625 913 1199 1410 2231 3415 422 609 809 1096 1506 2648 485 709 931 1219 1732 2098 654 956 1255 1477 2336 3576 193 184 178 172 155 133 193 184 178 167 155 124 157 149 144 137 126 119 157 149 144 140 126 108 157 150 144 136 126 101 164 156 151 143 132 124 164 156 151 146 132 113 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G10H0-D-8x 90 BXRC-35E1000-B-8x 80 BXRC-35E1000-C-8x 80 BXRC-35E1000-D-8x 80 BXRC-35G1000-B-8x 90 BXRC-35G1000-C-8x 90 BXRC-35G1000-D-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 491 708 942 1275 1752 3081 649 948 1246 1632 2318 2807 876 1279 1680 1976 3125 4785 591 853 1134 1535 2110 3710 534 779 1024 1341 1905 2307 720 1051 1380 1624 2568 3932 486 701 932 1262 1734 3049 442 637 848 1147 1577 2773 584 853 1121 1468 2086 2526 788 1151 1512 1778 2813 4306 532 767 1021 1382 1899 3339 480 701 921 1207 1714 2076 648 946 1242 1461 2311 3539 437 631 839 1136 1561 2744 164 157 151 142 132 106 197 188 182 172 159 150 197 188 182 176 159 137 197 189 182 171 159 127 162 155 150 142 131 123 162 155 150 145 131 112 162 155 150 141 131 105 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40C1001-B-8x 70 BXRC-40C1001-C-8x 70 BXRC-40C1001-D-8x 70 BXRC-40E1000-B-8x 80 BXRC-40E1000-C-8x 80 BXRC-40E1000-D-8x 80 BXRC-40G1000-B-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 683 997 1310 1716 2437 2952 921 1345 1766 2078 3287 5032 622 897 1193 1615 2219 3902 653 954 1253 1641 2331 2823 881 1286 1689 1987 3143 4812 595 857 1141 1544 2122 3731 545 796 1045 1369 1945 2355 615 898 1179 1544 2194 2657 829 1210 1590 1870 2958 4529 560 807 1073 1453 1997 3512 588 858 1128 1477 2098 2541 793 1157 1520 1788 2829 4331 535 772 1027 1390 1910 3358 490 716 941 1232 1750 2120 208 198 192 181 167 157 208 198 192 185 167 144 208 198 192 180 167 134 198 189 183 173 160 151 198 189 183 177 160 137 198 190 183 172 160 128 166 158 153 145 133 126 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40G1000-C-8x 90 BXRC-40G1000-D-8x 90 BXRC-50C1001-B-8x 70 BXRC-50C1001-C-8x 70 BXRC-50C1001-D-8x 70 BXRC-50E1001-B-8x 80 BXRC-50E1001-C-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 735 1073 1409 1658 2622 4015 496 715 952 1288 1770 3113 687 1003 1317 1725 2451 2968 926 1352 1776 2089 3305 5060 625 902 1199 1624 2231 3923 661 965 1267 1660 2358 2855 891 1301 1709 2010 3179 4867 661 966 1268 1492 2360 3613 446 644 856 1159 1593 2802 618 902 1186 1553 2206 2671 833 1217 1599 1880 2974 4554 563 811 1079 1461 2008 3531 594 868 1140 1494 2122 2570 802 1171 1538 1809 2861 4381 166 158 153 148 133 115 166 158 153 144 133 107 209 199 193 182 168 158 209 199 193 186 168 144 209 200 193 181 168 135 201 192 185 175 162 152 201 192 185 179 162 139 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50E1001-D-8x 80 BXRC-50G1001-B-8x 90 BXRC-50G1001-C-8x 90 BXRC-50G1001-D-8x 90 BXRC-57C1001-B-8x 70 BXRC-57C1001-C-8x 70 BXRC-57C1001-D-8x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 601 867 1154 1562 2146 3774 571 834 1095 1435 2038 2468 770 1124 1477 1737 2748 4207 520 750 997 1350 1855 3262 668 975 1281 1678 2384 2888 901 1315 1728 2032 3215 4922 608 877 1167 1579 2171 3817 541 781 1038 1406 1932 3397 514 750 986 1291 1834 2221 693 1012 1329 1564 2473 3787 468 675 897 1215 1670 2936 601 878 1153 1511 2146 2599 811 1184 1555 1829 2893 4430 547 789 1050 1421 1954 3435 201 192 185 174 162 130 174 166 160 152 140 132 174 166 160 155 140 120 174 166 160 151 140 112 203 194 187 177 163 154 203 194 187 181 163 140 203 194 187 176 163 131 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E1001-B-8x 80 BXRC-57E1001-C-8x 80 BXRC-57E1001-D-8x 80 BXRC-65C1001-B-8x 70 BXRC-65C1001-C-8x 70 BXRC-65C1001-D-8x 70 BXRC-65E1001-B-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 150 225 300 360 600 1000 125 185 250 350 500 1000 100 150 200 270 400 500 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 32.9 33.6 34.2 35.0 36.5 37.5 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 3.3 5.0 6.8 9.5 14.6 18.7 634 926 1217 1594 2264 2742 855 1249 1641 1930 3053 4675 578 833 1108 1500 2062 3625 668 975 1281 1678 2384 2888 901 1315 1728 2032 3215 4922 608 877 1167 1579 2171 3817 642 937 1231 1613 2291 2775 571 834 1095 1435 2038 2468 770 1124 1477 1737 2748 4207 520 750 997 1350 1855 3262 601 878 1153 1511 2146 2599 811 1184 1555 1829 2893 4430 547 789 1050 1421 1954 3435 578 844 1108 1452 2062 2497 193 184 178 169 155 146 193 184 178 172 155 133 193 184 178 167 155 124 203 194 187 177 163 154 203 194 187 181 163 140 203 194 187 176 163 131 195 186 180 171 157 148 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-65E1001-C-8x 80 BXRC-65E1001-D-8x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 150 225 300 360 600 1000 125 185 250 350 500 1000 29.6 30.2 30.7 31.2 32.8 35.0 24.0 24.4 24.9 25.6 26.6 29.1 4.4 6.8 9.2 11.2 19.7 35.0 3.0 4.5 6.2 9.0 13.3 29.1 865 1264 1660 1953 3089 4730 584 843 1121 1518 2086 3667 779 1137 1494 1758 2780 4257 526 758 1009 1366 1877 3301 195 186 180 174 157 135 195 187 180 169 157 126 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx100x-B-8x BXRC-xxx100x-C-8x BXRC-xxx100x-D-8x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.62 30.8 37.5 -12.10 0.95 33.7 41.1 33.0 -9.90 0.38 27.6 33.6 35 37.6 -11.29 0.55 31.5 38.4 23.0 24.9 26.8 -8.03 0.37 22.4 27.3 26.9 29.1 31.3 -9.39 0.55 26.2 31.9 Minimum Typical Maximum 200 31.6 34.2 36.8 -11.03 500 34.7 37.5 40.3 300 28.4 30.7 1000 32.4 250 1000 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1140 V. The working voltage designated for the insulation is 70V d.c. The maximum allowable voltage across the array must be determined in the end product application. 16 Eye Safety Table 5: Eye Safety Risk Group (RG) Classifications Part Number CCT Drive Current (mA) 2700K/3000K 4000K2 5000K3 6500K4 355 RG1 RG1 RG1 RG1 500 RG1 RG1 RG1 RG2 395 RG1 RG1 RG1 RG1 550 RG1 RG1 RG1 RG2 730 RG1 RG1 RG2 RG2 1000 RG1 RG2 RG2 RG2 490 RG1 RG1 RG1 RG1 680 RG1 RG1 RG1 RG2 900 RG1 RG1 RG2 RG2 1000 RG1 RG2 RG2 RG2 BXRC-xxx100x-B-8x BXRC-xxx100x-C-8x BXRC-xxx100x-D-8x Notes for Table 5: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1980 lx. 3. For products classified as RG2 at 5000K Ethr= 1530 lx. 4. For products classified as RG2 at 6500K, Ethr= 1170 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 17 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRC-xxx100x-B-8x BXRC-xxx100x-C-8x BXRC-xxx100x-D-8x Maximum Drive Current3 500 mA 1000 mA 1000 mA Maximum Peak Pulsed Drive Current4 560 mA 1120 mA 1120 mA Maximum Reverse Voltage5 -60V -55V -45V Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN31: Assembly Considerations for Bridgelux Vero LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 18 Performance Curves Figure 1: Vero 10B Drive Current vs. Voltage Figure 2: Vero 10C Drive Current vs. Voltage 36.0 38.0 35.0 37.0 Voltage (V) Voltage (V) 34.0 36.0 35.0 34.0 33.0 32.0 31.0 33.0 30.0 29.0 32.0 0 100 200 300 400 500 0 600 200 Figure 3: Vero 10D Drive Current vs. Voltage 800 1000 1200 250% Relative Luminous Flux (%) 29.0 28.0 Voltage (V) 600 Figure 4: Vero 10B Typical Relative Flux vs. Current 30.0 27.0 26.0 25.0 24.0 23.0 0 200 400 600 800 1000 200% 150% 100% 50% 0% 1200 0 100 Drive Current (mA) 200 300 400 500 600 Drive Current (mA) Figure 5: Vero 10C Typical Relative Flux vs. Current Figure 6 Vero 10D Typical Relative Flux vs. Current 350% Relative Luminous Flux (%) 300% Relative Luminous Flux (%) 400 Drive Current (mA) Drive Current (mA) 250% 200% 150% 100% 50% 0% 0 200 400 600 Drive Current (mA) 800 1000 1200 300% 250% 200% 150% 100% 50% 0% 0 200 400 600 800 1000 1200 Drive Current (mA) Notes for Figure 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 19 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature 102% 0.0010 100% 0.0000 98% -0.0010 96% -0.0020 ccy shift Relative Luminous Flux Figure 7: Typical DC Flux vs. Case Temperature 94% 92% 25C Pulsed 0 -0.0030 -0.0040 90% -0.0050 88% -0.0060 -0.0070 86% 0 20 40 60 80 100 120 0 20 40 60 80 100 120 Case Temperature (Tc) Case Temperature (Tc) Figure 9: Typical DC ccx Shift vs. Case Temperature 0.0020 25C Pulsed 0.0000 ccx shift -0.0020 -0.0040 -0.0060 -0.0080 -0.0100 0 20 40 60 80 100 120 Case Temperature (Tc) 20 Typical Radiation Pattern Figure 10: Typical Spatial Radiation Pattern Note for Figure 10: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 11: Typical Polar Radiation Pattern 21 Typical Color Spectrum Figure 12: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 12: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. 22 Mechanical Dimensions Figure 13: Drawing for Vero 10 LED Array Notes for Figure 13: 1. Drawings are not to scale. 2. Dimensions are in mm. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Mounting slots (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 19.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 23 Color Binning Information Figure 14: Warm and Neutral White Test Bins in xy Color Figure 15: Graph of Cool White Test Bins in xy Color Space Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 7: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Table 8: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 84 (4 SDCM) (4801K - 5282K) (5481K - 5829K) (6270K - 6765K) 83 (3 SDCM) (4835K-5215K) (5490K-5820K) (6250K-6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 24 Packaging and Labeling Figure 16: Drawing for Vero 10 Packaging Tray Notes for Figure 16: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 25 Packaging and Labeling Figure 17: Vero Series Packaging and Labeling Notes for Figure 17: 1. Each tray holds 200 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 18: Gen. 8 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E1000C 83 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 26 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 27 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2020 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 Vero 10 Array Series Product Data Sheet DS420 Rev. A (07/2020) 28
BXRC-40E1000-B-83-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-40E1000-B-83-SE”相匹配的价格&库存,您可以联系我们找货
