BXRC-30A4001-B-73-SE
    BRIDGELUX(普瑞)
    暖白色 3000K CRI:93
BXRC-30A4001-B-73-SE 数据手册
Bridgelux Vero SE 18 Array ® ® Product Data Sheet DS122 1 Vero SE Introduction Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s seventh generation COB technology with poke-in connectivity enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing cost, simplify luminaire design, improve light quality and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is also a good replacement for halogen lamps. Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series ™ Entertainment products provide color points developed specifically for the healthcare and entertainment industries. The 5600K cool white color point combined with a CRI of 90 or 97 provides the bright white required by these industries. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features • Poke-in connectivity • Efficacy of 168 lm/W typical • Lumen output performance ranges from 1,372 to 13,060 lumens Benefits • Poke-in connectivity enables solderless, connector free installation • Broad application coverage for interior and exterior lighting • Broad range of CCT options from 1750K to 6500K • Flexibility for application driven lighting design requirements • CRI options: minimum 65, 70, 80, and 90 • High quality, true color reproduction • Color control: 2 and 3 SDCM for 2700K-4000K CCT • Uniform consistent white light • Reliable operation at up to 2X nominal drive current • Flexibility in design optimization • Radial die pattern and improved lumen density • Enhanced ease of use and assembly • Top side part number markings • Ability to configure multiple Vero SE arrays in series and parallel reduces customer driver cost • No exposed solder pads or electrical connections • Vf bin code backside marking • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 20 Eye Safety 21 Absolute Maximum Ratings 22 Performance Curves 23 Typical Radiation Pattern 27 Typical Color Spectrum 28 Mechanical Dimensions 29 Color Binning Information 30 Packaging and Labeling 31 Design Resources 33 Precautions 33 Disclaimers 33 About Bridgelux 34 1 Product Feature Map Vero SE 18 is the second largest form factor in the product family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www. bridgelux.com for more information on the Vero SE family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 Tc Measurement point Optic mounting holes Radial die configuration improves lumen density and beam control Mounting holes Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 400 0 – C – 7 3 – SE Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 7 Array Configuration CRI B = 65 CRI min. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Target Flux Indicator 400x = 4000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 BXRC-17E4000-B-74-SE 1750 80 BXRC-17E4000-C-74-SE 1750 80 Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) 900 2844 2560 1170 3697 3327 Nominal Drive Current3 (mA) Typical Power (W) Typical Efficacy (lm/W) 34.8 31.3 91 34.8 40.7 91 BXRC-17E4000-D-74-SE 1750 80 1050 2765 2488 29.0 30.5 91 BXRC-20B4001-C-73-SE 2000 65 1170 6309 5678 34.8 40.7 155 BXRC-20B4001-D-73-SE 2000 65 1050 4719 4247 29.0 30.5 155 BXRC-25E4000-B-74-SE 2500 80 900 4730 4257 34.8 31.3 151 BXRC-25E4000-C-74-SE 2500 80 1170 6149 5534 34.8 40.7 151 BXRC-25E4000-D-74-SE 2500 80 1050 4598 4138 29.0 30.5 151 BXRC-27E4000-B-7x-SE 2700 80 900 4946 4451 34.8 31.3 158 BXRC-27E4000-C-7x-SE 2700 80 1170 6430 5787 34.8 40.7 158 BXRC-27E4000-D-7x-SE 2700 80 1050 4809 4328 29.0 30.5 158 BXRC-27G40H0-B-7x-SE 2700 90 900 4235 3812 34.8 31.3 135 BXRC-27G40H0-C-7x-SE 2700 90 1170 5506 4955 34.8 40.7 135 BXRC-27G40H0-D-7x-SE 2700 90 1050 4117 3706 29.0 30.5 135 BXRC-27G4000-B-7x-SE 2700 90 900 4080 3672 34.8 31.3 130 BXRC-27G4000-C-7x-SE 2700 90 1170 5305 4774 34.8 40.7 130 BXRC-27G4000-D-7x-SE 2700 90 1050 3967 3570 29.0 30.5 130 BXRC-27H4000-B-7x-SE 2700 97 900 3617 3255 34.8 31.3 115 BXRC-27H4000-C-7x-SE 2700 97 1170 4702 4232 34.8 40.7 115 BXRC-27H4000-D-7x-SE 2700 97 1050 3516 3165 29.0 30.5 115 BXRC-30C4001-B-74-SE 3000 70 900 5502 4952 34.8 31.3 176 176 BXRC-30C4001-C-74-SE 3000 70 1170 7153 6438 34.8 40.7 BXRC-30C4001-D-74-SE 3000 70 1050 5350 4815 29.0 30.5 176 BXRC-30E4000-B-7x-SE 3000 80 900 5255 4730 34.8 31.3 168 BXRC-30E4000-C-7x-SE 3000 80 1170 6832 6149 34.8 40.7 168 BXRC-30E4000-D-7x-SE 3000 80 1050 5109 4598 29.0 30.5 168 BXRC-30G40H0-B-7x-SE 3000 90 900 4451 4006 34.8 31.3 142 BXRC-30G40H0-C-7x-SE 3000 90 1170 5787 5208 34.8 40.7 142 BXRC-30G40H0-D-7x-SE 3000 90 1050 4328 3895 29.0 30.5 142 BXRC-30G4000-B-7x-SE 3000 90 900 4266 3839 34.8 31.3 136 BXRC-30G4000-C-7x-SE 3000 90 1170 5546 4991 34.8 40.7 136 BXRC-30G4000-D-7x-SE 3000 90 1050 4147 3733 29.0 30.5 136 BXRC-30G400C-B-73-SE 3000 90 900 4111 3700 34.8 31.3 131 BXRC-30G400C-D-73-SE 3000 90 1050 3997 3597 29.0 30.5 131 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30H4000-B-7x-SE 3000 97 900 3864 3478 34.8 31.3 123 BXRC-30H4000-C-7x-SE 3000 97 1170 5023 4521 34.8 40.7 123 BXRC-30H4000-D-7x-SE 3000 97 1050 3757 3381 29.0 30.5 123 BXRC-30A4001-B-73-SE8,9 3000 93 900 3833 3450 34.8 31.3 122 BXRC-30A4001-C-73-SE 8,9 3000 93 1170 4983 4485 34.8 40.7 122 BXRC-30A4001-D-73-SE8,9 3000 93 1050 3727 3354 29.0 30.5 122 BXRC-35E4000-B-7x-SE 3500 80 900 5379 4841 34.8 31.3 172 BXRC-35E4000-C-7x-SE 3500 80 1170 6992 6293 34.8 40.7 172 BXRC-35E4000-D-7x-SE 3500 80 1050 5229 4706 29.0 30.5 172 BXRC-35G4000-B-7x-SE 3500 90 900 4421 3978 34.8 31.3 141 BXRC-35G4000-C-7x-SE 3500 90 1170 5747 5172 34.8 40.7 141 BXRC-35G4000-D-7x-SE 3500 90 1050 4298 3868 29.0 30.5 141 BXRC-35A4001-B-73-SE8,9 3500 93 900 4080 3672 34.8 31.3 130 BXRC-35A4001-C-73-SE8,9 3500 93 1170 5305 4774 34.8 40.7 130 BXRC-35A4001-D-73-SE8,9 3500 93 1050 3967 3570 29.0 30.5 130 BXRC-40C4001-B-74-SE 4000 90 900 5657 5091 34.8 31.3 181 181 BXRC-40C4001-C-74-SE 4000 90 1170 7354 6619 34.8 40.7 BXRC-40C4001-D-74-SE 4000 90 1050 5500 4950 29.0 30.5 181 BXRC-40E4000-B-7x-SE 4000 80 900 5410 4869 34.8 31.3 173 173 BXRC-40E4000-C-7x-SE 4000 80 1170 7033 6329 34.8 40.7 BXRC-40E4000-D-7x-SE 4000 80 1050 5259 4734 29.0 30.5 173 BXRC-40G4000-B-7x-SE 4000 90 900 4513 4062 34.8 31.3 144 BXRC-40G4000-C-7x-SE 4000 90 1170 5867 5281 34.8 40.7 144 BXRC-40G4000-D-7x-SE 4000 90 1050 4388 3949 29.0 30.5 144 BXRC-40H4000-B-7X-SE 4000 97 900 4080 3672 34.8 31.3 130 BXRC-40H4000-C-7X-SE 4000 97 1170 5305 4774 34.8 40.7 130 BXRC-40H4000-D-7X-SE 4000 97 1050 3967 3570 29.0 30.5 130 BXRC-40A4001-B-73-SE8,9 4000 93 900 4421 3978 34.8 31.3 141 BXRC-40A4001-C-73-SE8,9 4000 93 1170 5747 5172 34.8 40.7 141 BXRC-40A4001-D-73-SE8,9 4000 93 1050 4298 3868 29.0 30.5 141 BXRC-50C4001-B-7x-SE 5000 70 900 5688 5119 34.8 31.3 182 BXRC-50C4001-C-7x-SE 5000 70 1170 7394 6655 34.8 40.7 182 BXRC-50C4001-D-7x-SE 5000 70 1050 5530 4977 29.0 30.5 182 BXRC-50E4001-B-7x-SE 5000 80 900 5472 4924 34.8 31.3 175 BXRC-50E4001-C-7x-SE 5000 80 1170 7113 6402 34.8 40.7 175 BXRC-50E4001-D-7x-SE 5000 80 1050 5320 4788 29.0 30.5 175 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-50G4001-B-7x-SE 5000 90 900 4730 4257 34.8 31.3 151 BXRC-50G4001-C-7x-SE 5000 90 1170 6149 5534 34.8 40.7 151 BXRC-50G4001-D-7x-SE 5000 90 1050 4598 4138 29.0 30.5 151 BXRC-56G4000-B-74-SE 5600 90 900 4761 4285 34.8 31.3 152 BXRC-56G4000-C-74-SE 5600 90 1170 6189 5570 34.8 40.7 152 BXRC-56G400x-D-74-SE 5600 90 1050 4628 4166 29.0 30.5 152 BXRC-56H4000-D-74-SE 5600 97 1050 4178 3760 29.0 30.5 137 BXRC-57C4001-B-7x-SE 5700 70 900 5533 4980 34.8 31.3 177 BXRC-57C4001-C-7x-SE 5700 70 1170 7193 6474 34.8 40.7 177 BXRC-57C4001-D-7x-SE 5700 70 1050 5380 4842 29.0 30.5 177 BXRC-57E4001-B-7x-SE 5700 80 900 5255 4730 34.8 31.3 168 BXRC-57E4001-C-7x-SE 5700 80 1170 6832 6149 34.8 40.7 168 BXRC-57E4001-D-7x-SE 5700 80 1050 5109 4598 29.0 30.5 168 BXRC-65C4001-B-7x-SE 6500 70 900 5533 4980 34.8 31.3 177 BXRC-65C4001-C-7x-SE 6500 70 1170 7193 6474 34.8 40.7 177 BXRC-65C4001-D-7x-SE 6500 70 1050 5380 4842 29.0 30.5 177 BXRC-65E4001-B-7x-SE 6500 80 900 5317 4785 34.8 31.3 170 BXRC-65E4001-C-7x-SE 6500 80 1170 6912 6221 34.8 40.7 170 BXRC-65E4001-D-7x-SE 6500 80 1050 5169 4652 29.0 30.5 170 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A4001-B-73-SE 3000 80 93 900 3565 3208 34.3 30.9 115 BXRC-30A4001-C-73-SE 3000 80 93 1170 4634 4171 34.3 40.2 115 BXRC-30A4001-D-73-SE 3000 80 93 1050 3466 3119 28.5 29.9 116 BXRC-35A4001-B-73-SE 3500 80 93 900 3795 3415 34.3 30.9 123 BXRC-35A4001-C-73-SE 3500 80 93 1170 4933 4440 34.3 40.2 123 BXRC-35A4001-D-73-SE 3500 80 93 1050 3689 3321 28.5 29.9 123 BXRC-40A4001-B-73-SE 4000 80 93 900 4111 3700 34.3 30.9 133 BXRC-40A4001-C-73-SE 4000 80 93 1170 5344 4810 34.3 40.2 133 BXRC-40A4001-D-73-SE 4000 80 93 1050 3997 3597 28.5 29.9 134 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-17E4000-B-74-SE 1750 80 900 2560 2304 33.9 30.5 84 BXRC-17E4000-C-74-SE 1750 80 1170 3327 2995 33.9 39.7 84 BXRC-17E4000-D-74-SE 1750 80 1050 2488 2240 28.3 29.7 84 BXRC-20B4001-C-73-SE 2000 65 1170 5678 5111 34.1 39.9 142 BXRC-20B4001-D-73-SE 2000 65 1050 4247 3822 28.3 29.7 143 BXRC-25E4000-B-74-SE 2500 80 900 4257 3831 33.9 30.5 139 BXRC-25E4000-C-74-SE 2500 80 1170 5534 4980 33.9 39.7 139 BXRC-25E4000-D-74-SE 2500 80 1050 4138 3725 28.3 29.7 139 BXRC-27E4000-B-7x-SE 2700 80 900 4451 4006 33.9 30.5 146 BXRC-27E4000-C-7x-SE 2700 80 1170 5787 5208 33.9 39.7 146 BXRC-27E4000-D-7x-SE 2700 80 1050 4328 3895 28.3 29.7 146 BXRC-27G40H0-B-7x-SE 2700 90 900 3812 3430 33.9 30.5 125 BXRC-27G40H0-C-7x-SE 2700 90 1170 4955 4460 33.9 39.7 125 BXRC-27G40H0-D-7x-SE 2700 90 1050 3706 3335 28.3 29.7 125 BXRC-27G4000-B-7x-SE 2700 90 900 3672 3305 33.9 30.5 120 120 BXRC-27G4000-C-7x-SE 2700 90 1170 4774 4297 33.9 39.7 BXRC-27G4000-D-7x-SE 2700 90 1050 3570 3213 28.3 29.7 120 BXRC-27H4000-B-7x-SE 2700 97 900 3255 2930 33.9 30.5 107 BXRC-27H4000-C-7x-SE 2700 97 1170 4232 3808 33.9 39.7 107 BXRC-27H4000-D-7x-SE 2700 97 1050 3165 2848 28.3 29.7 107 BXRC-30C4001-B-74-SE 3000 70 900 4952 4457 33.9 30.5 162 BXRC-30C4001-C-74-SE 3000 70 1170 6438 5794 33.9 39.7 162 BXRC-30C4001-D-74-SE 3000 70 1050 4815 4333 28.3 29.7 162 BXRC-30E4000-B-7x-SE 3000 80 900 4730 4257 33.9 30.5 155 BXRC-30E4000-C-7x-SE 3000 80 1170 6149 5534 33.9 39.7 155 BXRC-30E4000-D-7x-SE 3000 80 1050 4598 4138 28.3 29.7 155 BXRC-30G40H0-B-7x-SE 3000 90 900 4006 3606 33.9 30.5 131 BXRC-30G40H0-C-7x-SE 3000 90 1170 5208 4687 33.9 39.7 131 BXRC-30G40H0-D-7x-SE 3000 90 1050 3895 3506 28.3 29.7 131 BXRC-30G4000-B-7x-SE 3000 90 900 3839 3455 33.9 30.5 126 BXRC-30G4000-C-7x-SE 3000 90 1170 4991 4492 33.9 39.7 126 BXRC-30G4000-D-7x-SE 3000 90 1050 3733 3359 28.3 29.7 126 BXRC-30G400C-B-73-SE 3000 90 900 3700 3330 33.9 30.5 121 BXRC-30G400C-D-73-SE 3000 90 1050 3597 3238 28.3 29.7 121 BXRC-30H4000-B-7x-SE 3000 97 900 3478 3130 33.9 30.5 114 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30H4000-C-7x-SE 3000 97 1170 4521 4069 33.9 39.7 114 BXRC-30H4000-D-7x-SE 3000 97 1050 3381 3043 28.3 29.7 114 BXRC-30A4001-B-73-SE7,8 3000 93 900 3450 3105 33.9 30.5 113 BXRC-30A4001-C-73-SE7,8 3000 93 1170 4485 4036 33.9 39.7 113 BXRC-30A4001-D-73-SE7,8 3000 93 1050 3354 3019 28.3 29.7 113 BXRC-35E4000-B-7x-SE 3500 80 900 4841 4357 33.9 30.5 159 BXRC-35E4000-C-7x-SE 3500 80 1170 6293 5664 33.9 39.7 159 BXRC-35E4000-D-7x-SE 3500 80 1050 4706 4236 28.3 29.7 159 BXRC-35G4000-B-7x-SE 3500 90 900 3978 3581 33.9 30.5 130 BXRC-35G4000-C-7x-SE 3500 90 1170 5172 4655 33.9 39.7 130 BXRC-35G4000-D-7x-SE 3500 90 1050 3868 3481 28.3 29.7 130 BXRC-35A4001-B-73-SE7,8 3500 93 900 3672 3305 33.9 30.5 120 BXRC-35A4001-C-73-SE7,8 3500 93 1170 4774 4297 33.9 39.7 120 BXRC-35A4001-D-73-SE7,8 3500 93 1050 3570 3213 28.3 29.7 120 BXRC-40C4001-B-74-SE 4000 70 900 5091 4582 33.9 30.5 167 BXRC-40C4001-C-74-SE 4000 70 1170 6619 5957 33.9 39.7 167 BXRC-40C4001-D-74-SE 4000 70 1050 4950 4455 28.3 29.7 167 BXRC-40E4000-B-7x-SE 4000 80 900 4869 4382 33.9 30.5 160 BXRC-40E4000-C-7x-SE 4000 80 1170 6329 5696 33.9 39.7 160 BXRC-40E4000-D-7x-SE 4000 80 1050 4734 4260 28.3 29.7 159 BXRC-40G4000-B-7x-SE 4000 90 900 4062 3656 33.9 30.5 133 BXRC-40G4000-C-7x-SE 4000 90 1170 5281 4752 33.9 39.7 133 BXRC-40G4000-D-7x-SE 4000 90 1050 3949 3554 28.3 29.7 133 BXRC-40H4000-B-7X-SE 4000 97 900 3672 3305 33.9 30.5 120 120 BXRC-40H4000-C-7X-SE 4000 97 1170 4774 4297 33.9 39.7 BXRC-40H4000-D-7X-SE 4000 97 1050 3570 3213 28.3 29.7 120 BXRC-40A4001-B-73-SE7,8 4000 93 900 3978 3581 34.1 30.7 130 BXRC-40A4001-C-73-SE7,8 4000 93 1170 5172 4655 34.1 39.9 130 BXRC-40A4001-D-73-SE7,8 4000 93 1050 3868 3481 28.3 29.7 130 BXRC-50C4001-B-7x-SE 5000 70 900 5119 4607 34.1 30.7 167 BXRC-50C4001-C-7x-SE 5000 70 1170 6655 5989 34.1 39.9 167 BXRC-50C4001-D-7x-SE 5000 70 1050 4977 4479 28.3 29.7 168 BXRC-50E4001-B-7x-SE 5000 80 900 4924 4432 34.1 30.7 161 BXRC-50E4001-C-7x-SE 5000 80 1170 6402 5762 34.1 39.9 161 BXRC-50E4001-D-7x-SE 5000 80 1050 4788 4309 28.3 29.7 161 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-50G4001-B-7x-SE 5000 90 900 4257 3831 34.1 30.7 139 BXRC-50G4001-C-7x-SE 5000 90 1170 5534 4980 34.1 39.9 139 BXRC-50G4001-D-7x-SE 5000 90 1050 4138 3725 28.3 29.7 139 BXRC-56G4000-B-74-SE 5600 90 900 4285 3856 34.1 30.7 140 BXRC-56G4000-C-74-SE 5600 90 1170 5570 5013 34.1 39.9 140 BXRC-56G400x-D-74-SE 5600 90 1050 4166 3749 28.3 29.7 140 BXRC-56H4000-D-74-SE 5600 97 1050 3760 3384 28.3 29.7 127 162 BXRC-57C4001-B-7x-SE 5700 80 900 4980 4482 34.1 30.7 BXRC-57C4001-C-7x-SE 5700 80 1170 6474 5827 34.1 39.9 162 BXRC-57C4001-D-7x-SE 5700 80 1050 4842 4358 28.3 29.7 163 154 BXRC-57E4001-B-7x-SE 5700 80 900 4730 4257 34.1 30.7 BXRC-57E4001-C-7x-SE 5700 80 1170 6149 5534 34.1 39.9 154 BXRC-57E4001-D-7x-SE 5700 80 1050 4598 4138 28.3 29.7 155 BXRC-65C4001-B-7x-SE 6500 70 900 4980 4482 34.1 30.7 162 BXRC-65C4001-C-7x-SE 6500 70 1170 6474 5827 34.1 39.9 162 BXRC-65C4001-D-7x-SE 6500 70 1050 4842 4358 28.3 29.7 163 BXRC-65E4001-B-7x-SE 6500 80 900 4785 4307 34.1 30.7 156 BXRC-65E4001-C-7x-SE 6500 80 1170 6221 5599 34.1 39.9 156 BXRC-65E4001-D-7x-SE 6500 80 1050 4652 4187 28.3 29.7 157 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 98. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 9 Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-17E4000-B-74-SE 80 BXRC-17E4000-C-74-SE 80 BXRC-17E4000-D-74-SE 80 BXRC-20B4001-C-73-SE 65 BXRC-20B4001-D-73-SE 65 BXRC-25E4000-B-74-SE 80 BXRC-25E4000-C-74-SE 80 BXRC-25E4000-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 1527 2003 2844 4230 5443 1932 2531 3697 5319 6822 1473 1915 2765 3949 5028 3297 4320 6309 9077 11643 2514 3269 4719 6740 8580 2539 3331 4730 7034 9052 3213 4210 6149 8845 11346 2450 3185 4598 6568 1372 1797 2560 3727 4732 1828 2346 3327 4681 5880 1367 1755 2488 3492 4372 3120 4003 5678 7989 10035 2333 2995 4247 5960 7461 2282 2988 4257 6198 7869 3040 3901 5534 7785 9779 2274 2919 4138 5808 102 99 91 86 80 100 96 91 83 77 101 97 91 82 76 170 164 155 142 131 173 165 155 141 130 170 164 151 143 133 166 160 151 138 128 168 161 151 137 2100 31.5 66.2 8361 7271 126 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27E4000-B-7x-SE 80 BXRC-27E4000-C-7x-SE 80 BXRC-27E4000-D-7x-SE 80 BXRC-27G40H0-B-7x-SE 90 BXRC-27G40H0-C-7x-SE 90 BXRC-27G40H0-D-7x-SE 90 BXRC-27G4000-B-7x-SE 90 BXRC-27G4000-C-7x-SE 90 BXRC-27G4000-D-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 2656 3484 4946 7356 9466 3360 4402 6430 9250 11865 2562 3331 4809 6868 8744 2274 2983 4235 6299 8105 2877 3770 5506 7920 10160 2193 2852 4117 5881 7487 2191 2874 4080 6069 7810 2772 3632 5305 7631 9789 2113 2748 3967 5667 7213 2386 3124 4451 6482 8229 3179 4080 5787 8141 10226 2378 3053 4328 6074 7603 2043 2675 3812 5550 7046 2722 3493 4955 6971 8756 2036 2614 3706 5201 6510 1969 2578 3672 5347 6789 2623 3366 4774 6717 8437 1962 2518 3570 5011 6273 178 172 158 149 139 173 167 158 144 134 176 169 158 143 132 152 147 135 128 119 148 143 135 123 114 151 144 135 123 113 147 142 130 123 115 143 138 130 119 110 145 139 130 118 109 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27H4000-B-7x-SE 80 BXRC-27H4000-C-7x-SE 80 BXRC-27H4000-D-7x-SE 80 BXRC-30C4001-B-74-SE 70 BXRC-30C4001-C-74-SE 70 BXRC-30C4001-D-74-SE 70 BXRC-30E4000-B-7x-SE 80 BXRC-30E4000-C-7x-SE 80 BXRC-30E4000-D-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 1942 2547 3617 5379 6922 2457 3219 4702 6764 8676 1873 2436 3516 5023 6394 2954 3875 5502 8184 1745 2285 3255 4740 6017 2325 2983 4232 5953 7478 1739 2232 3165 4441 5560 2655 3476 4952 7211 130 126 115 109 102 127 122 115 105 98 129 123 115 105 97 198 191 176 166 1800 37.8 68.1 10531 9154 155 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 3737 4898 7153 10291 13200 2850 3706 5350 7641 9727 2822 3701 5255 7816 3537 4539 6438 9057 11377 2645 3396 4815 6757 8459 2535 3320 4730 6887 193 186 176 160 149 196 188 176 159 147 189 183 168 159 1800 37.8 68.1 10058 8743 148 585 780 1170 1755 2340 525 700 1050 1575 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 3570 4678 6832 9828 12607 2722 3539 5109 7298 3378 4335 6149 8650 10866 2526 3243 4598 6453 184 177 168 153 142 187 179 168 152 2100 31.5 66.2 9290 8079 140 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G40H0-B-7x-SE 90 BXRC-30G40H0-C-7x-SE 90 BXRC-30G40H0-D-7x-SE 90 BXRC-30G4000-B-7x-SE 90 BXRC-30G4000-C-7x-SE 90 BXRC-30G4000-D-7x-SE 90 BXRC-30G400C-B-73-SE 90 BXRC-30G400C-D-73-SE 90 BXRC-30H4000-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 525 700 1050 1575 2100 450 600 900 1350 1800 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 2390 3135 4451 6621 8520 3024 3962 5787 8325 10679 2305 2998 4328 6182 7869 2290 3005 4266 6345 8165 2898 3797 5546 7978 10234 2209 2873 4147 5924 7541 2207 2896 4111 6115 7869 2129 2769 3997 5709 7268 2075 2721 3864 5747 7396 2148 2812 4006 5833 7406 2861 3672 5208 7327 9204 2140 2747 3895 5466 6843 2058 2695 3839 5590 7097 2742 3519 4991 7022 8820 2051 2633 3733 5238 6558 1984 2597 3700 5388 6840 1976 2537 3597 5049 6320 1864 2441 3478 5064 6429 160 155 142 135 125 156 150 142 130 120 158 152 142 129 119 154 148 136 129 120 149 144 136 124 115 152 145 136 124 114 148 143 131 124 116 146 140 131 119 110 139 134 123 117 109 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30H4000-C-7x-SE 80 BXRC-30H4000-D-7x-SE 80 BXRC-30A4001-B-73-SE 93 BXRC-30A4001-C-73-SE 93 BXRC-30A4001-D-73-SE 93 BXRC-35E4000-B-7x-SE 80 BXRC-35E4000-C-7x-SE 80 BXRC-35E4000-D-7x-SE 80 BXRC-35G4000-B-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 2625 3439 5023 7227 9270 2001 2602 3757 5366 6831 2058 2700 3833 5701 7336 2604 3412 4983 7169 9196 1985 2581 3727 5323 6776 2888 3788 5379 8000 10295 3653 4788 6992 10059 12903 2786 3622 5229 7469 9509 2373 3113 4421 6575 8460 2484 3187 4521 6361 7989 1858 2385 3381 4745 5940 1849 2421 3450 5023 6377 2464 3162 4485 6310 7926 1843 2366 3354 4707 5893 2595 3398 4841 7049 8949 3458 4437 6293 8854 11121 2586 3320 4706 6605 8269 2133 2792 3978 5793 7354 135 130 123 113 104 137 132 123 112 103 138 133 122 116 108 134 129 122 112 104 136 131 122 111 102 194 187 172 163 151 188 182 172 157 145 191 183 172 156 144 159 154 141 134 124 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35G4000-C-7x-SE 90 BXRC-35G4000-D-7x-SE 90 BXRC-35A4001-B-73-SE 93 BXRC-35A4001-C-73-SE 93 BXRC-35A4001-D-73-SE 93 BXRC-40C4001-B-74-SE 70 BXRC-40C4001-C-74-SE 70 BXRC-40C4001-D-74-SE 70 BXRC-40E4000-B-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 3003 3935 5747 8267 10604 2289 2977 4298 6139 7815 2191 2874 4080 6069 7810 2772 3632 5305 7631 9789 2113 2748 3967 5667 7213 3037 3984 5657 8414 10827 3842 5035 7354 10580 13571 2930 3810 5500 7856 10000 2904 3810 5410 8046 10354 2842 3646 5172 7276 9140 2125 2728 3868 5428 6796 1969 2578 3672 5347 6789 2623 3366 4774 6717 8437 1962 2518 3570 5011 6273 2729 3574 5091 7413 9412 3636 4666 6619 9312 11697 2719 3491 4950 6947 8696 2610 3417 4869 7089 9000 155 149 141 129 119 157 151 141 128 118 147 142 130 123 115 143 138 130 119 110 145 139 130 118 109 204 197 181 171 159 198 191 181 165 153 201 193 181 164 151 195 188 173 163 152 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E4000-C-7x-SE 80 BXRC-40E4000-D-7x-SE 80 BXRC-40G4000-B-7x-SE 90 BXRC-40G4000-C-7x-SE 90 BXRC-40G4000-D-7x-SE 90 BXRC-40H4000-B-7x-SE 97 BXRC-40H4000-C-7x-SE 97 BXRC-40H4000-D-7x-SE 97 BXRC-40A4001-B-73-SE 93 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 3674 4815 7033 10117 12978 2802 3643 5259 7512 9563 2423 3179 4513 6713 8638 3066 4017 5867 8441 10827 2337 3040 4388 6267 7979 2191 2874 4080 6069 7810 2772 3632 5305 7631 9789 2113 2748 3967 5667 7213 2373 3113 4421 6575 8460 3477 4462 6329 8905 11185 2601 3339 4734 6643 8316 2177 2851 4062 5914 7509 2901 3723 5281 7429 9332 2170 2785 3949 5542 6938 1969 2578 3672 5347 6789 2623 3366 4774 6717 8437 1962 2518 3570 5011 6273 2133 2792 3978 5793 7354 189 183 173 158 146 192 184 173 157 144 162 157 144 136 127 158 152 144 132 122 161 154 144 131 120 147 142 130 123 115 143 138 130 119 110 145 139 130 118 109 159 154 141 134 124 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40A4001-C-73-SE 93 BXRC-40A4001-D-73-SE 93 BXRC-50C4001-B-7x-SE 70 BXRC-50C4001-C-7x-SE 70 BXRC-50C4001-D-7x-SE 70 BXRC-50E4001-B-7x-SE 80 BXRC-50E4001-C-7x-SE 80 BXRC-50E4001-D-7x-SE 80 BXRC-50G4001-B-7x-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 3003 3935 5747 8267 10604 2289 2977 4298 6139 7815 3054 4006 5688 8460 10886 3863 5063 7394 10638 13645 2946 3831 5530 7899 10055 2938 3854 5472 8138 10472 3716 4870 7113 10233 13126 2834 3685 5320 7598 9673 2539 3331 4730 7034 9052 2842 3646 5172 7276 9140 2125 2728 3868 5428 6796 2744 3593 5119 7454 9463 3656 4692 6655 9363 11760 2734 3510 4977 6985 8744 2640 3456 4924 7170 9103 3517 4513 6402 9007 11313 2630 3377 4788 6719 8411 2282 2988 4257 6198 7869 155 149 141 129 119 157 151 141 128 118 205 198 182 172 160 199 192 182 166 154 202 194 182 165 152 197 190 175 165 154 191 185 175 160 148 195 186 175 159 146 170 164 151 143 133 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50G4001-C-7x-SE 90 BXRC-50G4001-D-7x-SE 90 BXRC-56G4000-B-74-SE 80 BXRC-56G4000-C-74-SE 80 BXRC-56G400x-D-74-SE 80 BXRC-56H4000-D-74-SE 97 BXRC-57C4001-B-7x-SE 70 BXRC-57C4001-C-7x-SE 70 BXRC-57C4001-D-7x-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 3213 4210 6149 8845 11346 2450 3185 4598 6568 8361 2556 3353 4761 7080 9111 3234 4237 6189 8903 11420 2466 3206 4628 6611 8416 2225 2894 4178 5967 7596 2971 3897 5533 8230 10590 3758 4925 7193 10348 13274 2866 3727 5380 7684 9782 3040 3901 5534 7785 9779 2274 2919 4138 5808 7271 2297 3007 4285 6238 7920 3060 3927 5570 7836 9843 2288 2938 4166 5846 7318 2066 2652 3760 5276 6606 2670 3495 4980 7251 9206 3557 4564 6474 9108 11441 2660 3415 4842 6795 8506 166 160 151 138 128 168 161 151 137 126 171 166 152 144 134 167 161 152 139 129 169 162 152 138 127 153 146 137 125 115 199 192 177 167 156 194 187 177 161 150 197 189 177 160 148 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E4001-B-7x-SE 80 BXRC-57E4001-C-7x-SE 80 BXRC-57E4001-D-7x-SE 80 BXRC-65C4001-B-7x-SE 70 BXRC-65C4001-C-7x-SE 70 BXRC-65C4001-D-7x-SE 70 BXRC-65E4001-B-7x-SE 80 BXRC-65E4001-C-7x-SE 80 BXRC-65E4001-D-7x-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 33.1 33.8 34.8 36.5 37.8 33.2 33.8 34.8 36.5 37.9 27.7 28.2 29.0 30.4 31.5 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 14.9 20.3 31.3 49.2 68.1 19.4 26.4 40.7 64.1 88.8 14.6 19.8 30.5 47.9 66.2 2822 3701 5255 7816 10058 3570 4678 6832 9828 12607 2722 3539 5109 7298 9290 2971 3897 5533 8230 10590 3758 4925 7193 10348 13274 2866 3727 5380 7684 9782 2855 3745 5317 7908 10176 3612 4733 6912 9944 12755 2754 3581 5169 7384 9399 2535 3320 4730 6887 8743 3378 4335 6149 8650 10866 2526 3243 4598 6453 8079 2670 3495 4980 7251 9206 3557 4564 6474 9108 11441 2660 3415 4842 6795 8506 2565 3359 4785 6968 8846 3418 4386 6221 8752 10993 2556 3281 4652 6529 8174 189 183 168 159 148 184 177 168 153 142 187 179 168 152 140 199 192 177 167 156 194 187 177 161 150 197 189 177 160 148 191 185 170 161 150 186 180 170 155 144 189 181 170 154 142 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 19 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.15 31.0 38.4 -14.9 0.19 33.8 41.6 37.4 -14.9 0.11 31.0 38.4 37.8 40.6 -14.9 0.13 33.8 41.6 26.8 29.0 31.2 -12.2 0.16 25.8 32.0 29.2 31.5 33.9 -12.2 0.19 28.2 34.7 Minimum Typical Maximum 900 32.2 34.8 37.4 -14.9 1800 35.0 37.8 40.6 1170 32.2 34.8 2340 35.0 1050 2100 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 20 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 900 RG1 RG1 RG1 RG1 1350 RG1 RG1 RG1 RG2 1800 RG1 RG1 RG2 RG2 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG1 RG2 RG2 1050 RG1 RG1 RG1 RG1 1575 RG1 RG1 RG1 RG2 2100 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero SE Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 21 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE Maximum Drive Current3 1800mA 2340mA 2100mA Maximum Peak Pulsed Drive Current4 2570mA 3340mA 3000mA Maximum Reverse Voltage5 -60V -60V -50V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN120: Assembly Considerations for Bridgelux Vero SE LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 22 Performance Curves Figure 2: Vero SE 18C Drive Current vs. Voltage 2000 2700 1800 2400 1600 2100 1400 Forward Current (mA) Forward Current (mA) Figure 1: Vero SE 18B Drive Current vs. Voltage 1200 1000 800 600 1800 1500 1200 900 600 400 300 200 0 0 32 33 34 35 36 37 38 39 32 33 34 200% 2000 180% 1750 160% 1500 140% Relative Luminous Flux Forward Current (mA) 2250 1250 37 38 39 1000 750 500 120% 100% 80% 60% 40% 250 20% 26 27 28 29 30 31 0% 32 0 200 400 600 Forward Voltage (V) 800 1000 1200 1400 1600 1800 2000 Forward Current (mA) Figure 5: Vero SE 18C Typical Relative Flux vs. Current Figure 6: Vero SE 18D Typical Relative Flux vs. Current y = -7E-08x + 0.001x + 0.027 2 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 36 Figure 4: Vero SE 18B Typical Relative Flux vs. Current Figure 3: Vero SE 18D Drive Current vs. Voltage 0 35 Forward Voltage (V) Forward Voltage (V) 120% 100% 80% 60% 40% 120% 100% 80% 60% 40% 20% 20% 0% 100 400 700 1000 1300 1600 Forward Current (mA) 1900 2200 2500 0% 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 2400 Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 23 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature Figure 7: Typical DC Flux vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 125 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Case Temperature (°C) Figure 9: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 7-9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 24 Performance Curves Figure 10: 1750K Color Shift vs. Case Temperature1 Figure 11: 2000K, 65 CRI Color Shift vs. Case Temperature1 0.3705 0.37 0.4101 Pulsed Center Point Tc = 25°C 15°C 0.41 0.4099 25°C 0.4098 Pulsed Center Point Tc=25°C 15°C 25°C 0.4097 0.3695 0.369 ccy ccy 45°C 45°C 0.4096 0.4095 65°C 0.4094 70°C 0.4093 85°C 0.3685 85°C 0.4092 105°C 0.368 0.5196 105°C 0.4091 0.5198 0.52 0.5202 0.5204 0.409 0.525 0.5206 0.526 0.527 0.528 Figure 12: 2500K Color Shift vs. Case Temperature1 0.4135 Pulsed Center Point Tc = 25°C 0.411 70°C 0.399 65°C 85°C 0.397 105°C 0.396 0.47 45°C 0.398 85°C 0.4105 0.468 Pulsed Center Point Tc=25°C 25°C 0.4 0.4125 0.4115 0.472 0.474 0.476 0.395 0.444 0.478 105°C 0.4445 0.445 0.4455 0.446 0.4465 0.447 ccx ccx Figure 14: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 15: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.532 0.401 45°C 0.412 15°C 0.402 ccy ccy 0.413 0.531 0.403 15°C 25°C 0.53 Figure 13: 3000K, 90 CRI Color Shift vs. Case Temperature1,3,4 0.4145 0.414 0.529 ccx ccx 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.4572 0.4574 0.4576 0.4578 0.458 ccx Notes for Figures 10-15: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRC-30G400C-x-73-SE 4. Color shift shown for product hot targeted at Tc=85°C 0.3950 0.4323 0.4328 0.4333 0.4338 0.4343 0.4348 0.4353 ccx 25 Performance Curves Figure 16: 5600K Color Shift vs. Case Temperature1 Figure 17: 3000K Class A Color Shift vs. Case Temperature1 0.344 0.369 0.342 25°C 0.338 0.336 0.367 0.366 0.332 70°C 0.33 45°C 0.364 70°C 85°C 0.362 105°C 0.324 0.361 0.322 0.32 0.322 0.324 0.326 0.328 Figure 18: 3500K Class A Color Shift vs. Case Temperature1 105°C 0.36 0.416 0.33 ccx 0.4165 0.417 ccx 0.4175 0.418 0.4185 Figure 19: 4000K Class A Color Shift vs. Case Temperature1 0.3760 0.37 15°C 0.368 15°C 0.3740 Pulsed Center Point Tc=25°C 25°C 0.366 25°C 0.3720 45°C Pulsed Center Point Tc=25°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.365 0.363 85°C 0.328 0.326 25°C 45°C 0.334 15°C 0.368 ccy ccy Pulsed Center Point Tc = 25°C 15°C 0.34 0.364 0.3680 70°C 0.362 0.3660 85°C 0.36 85°C 0.3640 105°C 0.358 0.392 70°C 105°C 0.393 0.394 0.395 0.396 0.397 ccx 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 Notes for Figures 16-19: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 26 Typical Radiation Pattern Figure 20: Typical Spatial Radiation Pattern Notes for Figure 20: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 21: Typical Polar Radiation Pattern 27 Typical Color Spectrum Figure 22: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 22: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 23: Typical Color Spectrum for Vero SE 18 with Décor Series 1 17E 20B 0.9 25E 27H 30G (Décor Series Showcase) 0.8 30H Relative Spectral Power Distribution 56G 56H 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 23: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 28 Mechanical Dimensions Figure 24: Drawing for Vero SE 18 LED Array Notes for Figure 24: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 29 Color Binning Information Figure 25: Warm and Neutral White Test Bins in xy Color Space 0.44 3 SDCM 2500K 4SDCM 4 SDCM 2 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2000K 2500K ANSI Bin (for reference only) - - - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - - - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - - - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5167, 0.336) (0.5280, 0.4100) (0.4765, 0.4137) 2700K (0.4578, 0.4101) 3000K1 3500K1 4000K1 (0.4338, 0.403) (0.4073, 0.3917) (0.4465, 0.4024)2 (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Figure 26: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5600K1 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5475K - 5830K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) (0.3287, 0.3417) (0.3123, 0.3282) Note for Table 9: 1. Select configurations with a CCT of 5600K are available with center point targets at Tc = 85°C or Tc = 25°C. 30 Packaging and Labeling Figure 27: Drawing for Vero SE 18 Packaging Tray Notes for Figure 27: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 31 Packaging and Labeling Figure 28: Vero SE Series Packaging and Labeling Notes for Figure 28: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 29: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin definitions. 32 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN121 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 33 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. V Bridgelux Vero SE 18 Array Series Product Data Sheet DS122 Rev. L (03/2019) 34
BXRC-30A4001-B-73-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-30A4001-B-73-SE”相匹配的价格&库存,您可以联系我们找货
