SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
BXJ Series
Solventproof
•105℃ 2,000~5,000Hrs assured.
•Vertical SMD type.
•Very low Impedance, Long Life.
•For STB, Tuner.
•RoHS compliant.
BXE
•Halogen-free capacitors are also available.
•AEC-Q200 compliant : Please contact us for more details, test data, information.
SPECIFICATIONS
WV ≦ 63VDC
BXJ
Long Life
Item
Characteristics
Rated Voltage Range
Operating Temperature Range
Capacitance Tolerance
Leakage Current
63 ~ 100V DC
-40 ~ +105℃
6.3 ~ 50V DC
-55 ~ +105℃
±20%(M)
(at 20℃, 120Hz)
I=0.01CV(μA) or 3 μA, whichever is greater.
Where, I:Max. Leakage current(μA), C:Nominal capacitance(μ
F), V:Rated voltage(VDC)
(at 20℃, 2 minutes)
Rated Voltage(VDC)
6.3
10
16
25
35
50
63
100
Tanδ(Max.)
0.26
0.19
0.16
0.14
0.12
0.12
0.12
0.12
Dissipation Factor(Tan δ)
(at 20℃, 120Hz)
Temperature Characteristics
(Max. Impedance ratio)
Rated voltage(VDC)
6.3
10
16
25
35
50
63
100
Z(-25℃)/Z(+20℃)
Z(-55℃)/Z(+20℃)
3
5
2
4
2
4
2
3
2
3
2
3
3
※4
3
※4
※Z(-40℃)/Z(+20℃)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated
voltage is applied with the following conditions.
D56~H63, J85 : 105℃, 2,000 hours, H10 ~ K14 : 105℃, 5,000 hours.
Load Life
Capacitance change
D56~H63, J85
H10~K14
≦ ±30% of the initial value
≦ ±35% of the initial value
Tanδ
≦ 300% of the initial specified value
Leakage current
≦ The initial specified value
Others
Capacitance change
D56~H63, J85
H10~K14
Tanδ
Leakage current
Satisfied characteristics KS C IEC 60384-4
PART NUMBERING SYSTEM
RATED RIPPLE CURRENT MULTIPLIERS
Frequency Multipliers
BXJ
6.3 VC
220 M
F60
TP
Size code Cap.(㎌)
With tape
Case code
D56~J10
Capacitance tolerance(±20%)
Nominal capacitance code
(ex. 0.1㎌:R1, 1.0㎌:1, 4.7㎌:4R7, 10㎌:10)
Lead type
K14
Freq.(㎐)
4.7
10 ~ 100
220 ~ 470
1,000 ~ 1,500
47 ~ 100
330 ~ 470
680 ~ 2,000
120
1K
10K
100K
0.35
0.40
0.50
0.60
0.40
0.50
0.60
0.70
0.75
0.85
0.87
0.75
0.85
0.87
0.90
0.90
0.94
0.95
0.90
0.94
0.95
1.00
1.00
1.00
1.00
1.00
1.00
1.00
Rated voltage
Series name
63
Series
Shelf Life
BXJ
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing
them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the
capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before
the measurements.
DIMENSIONS OF BXJ Series
Unit(mm)
DIMENSIONS
MARKING
●Vibration Resistance
Note 1 : L±0.5 for 8×6.3(H63)~12.5×13.5(K14)
Note 2 : 4×5.3(D56), 4×5.8(D61), 5×5.3(E56), 5×5.8(E61) is excluded symbol mark.
Note 3 : 6.3WV is marked by 6V.
Case code
D56
D61
E56
: Dummy terminals
E61
F55
Recommended solder land on PC board
F60
F80
H63
H10
J85
J10
K14
ØD
4
4
5
5
6.3
6.3
6.3
8
8
10
10
12.5
L
A
B
C
5.3 4.3 4.3 5.1
5.8 4.3 4.3 5.1
5.3 5.3 5.3 5.9
5.8 5.3 5.3 5.9
5.2 6.6 6.6 7.2
5.7 6.6 6.6 7.2
7.7 6.6 6.6 7.2
6.3 8.3 8.3 9.0
10 8.3 8.3 9.0
8.5 10.3 10.3 11.0
10 10.3 10.3 11.0
13.5 13.0 13.0 13.7
: Solder land on PC board
W
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.7~1.1
0.7~1.1
0.7~1.1
1.0~1.3
P
1.0
1.0
1.4
1.4
1.9
1.9
1.9
2.3
3.1
4.5
4.5
4.2
a
1.0
1.0
1.4
1.4
1.9
1.9
1.9
2.3
3.1
4.5
4.5
4.0
b
2.6
2.6
3.0
3.0
3.5
3.5
3.5
4.5
4.2
4.4
4.4
5.7
c
1.6
1.6
1.6
1.6
1.6
1.6
1.6
1.6
2.2
2.2
2.2
2.5
a
b
c
3.1 4.2 3.5
4.5 4.4 3.5
3.4 6.3 9.3
RATINGS OF BXJ Series
VDC
6.3
10
16
25
4.7
22
D56 1.80
D61
E56
D61 1.35 90 E61
47
E56 0.80 155 F60
E61 0.70 160 E61
68
F60 0.36 240 F60
E61 0.70 160
100
F60
F60 0.36 240
33 D56 1.80 85
220 F60 0.36 240
330 F80 0.34 280
H10
J85
H10
1,000
1,500 J10
2,200 K14
0.16
0.15
0.16
0.08
0.06
600
620
600
850
1,100
1.35
0.80
0.70
0.36
0.70
0.36
D56
D56
E56
85
E61
90 F60
155 E61
160
F60
240
160
F60
240
1.80
1.80
0.80
0.70
0.36
0.70
85
85
155
160
240
160
D61
E56
1.80 85 E61
0.80 155 F60
0.70 160
F60
0.55 220
5.50
3.00
2.00
1.20
E56
E61
F60
F55
63
100
45
55
50
H63 1.80 85
F60 4.50 48
120
J85 1.35 100
H63 1.50 100
H10 1.50 160
1.20 120
H10 1.00 200
D56
E56
0.80 155 E61
0.70 160 F55
0.36 240
F60 0.36 240 F80 0.90 150 J85 0.95 205 J10 0.60 330
0.55 220
D56 1.80 85
0.36 240 F60 0.36 240 F60 0.36 240 H63 0.75 200 H10 1.00 200 K14 0.40 400
F60 0.36 240 F80
F80 0.34 280 H63
H63 0.26 300 H10
J85
H10 0.16 600
J10
F80 0.34 280 J85 0.15 620
F80 0.34 280
H10 0.16 600 H10 0.16 600 H10
J85 0.15 620
J10 0.08 850 J10
H10 0.16 600
H10 0.16 600
H10 0.16 600 J10 0.08 850 J10 0.08 850
K14
J85 0.15 620
J10 0.08 850 K14 0.06 1,100 K14 0.06 1,100
K14 0.06 1,100
K14 0.06 1,100
0.36 240
Rated Ripple Current (mArms/105℃, 100kHz)
Impedance (Ωmax./20℃, 100kHz)
Case code
64
50
D56 1.80 85
10
470
35
0.34
0.26
0.16
0.15
0.08
280
300
600
620
850
H10 0.44 300 J10 0.50 350 K14 0.40 400
H10 0.44 300
J85 0.40 315 J10 0.50 350 K14 0.40 400
J10 0.25 500
0.16 600 J10 0.25 500
0.08 850 K14 0.11 650
0.06 1,100
很抱歉,暂时无法提供与“BXJ 10V1000 10*10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.03429
- 50+1.64236
- 150+1.47442
- 500+1.32624
- 2500+1.23293
- 5000+1.17699
