BLA10VC100M6.3*6 6.3TP
    SAMYOUNG(韩国三莹)
    SMD,6.3x6mm
BLA10VC100M6.3*6 6.3TP 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS BLA Series Solventproof •105℃ 5,000Hrs assured. WV ≦ 63VDC •Vertical SMD type. •Long Life. •For LED MT, AVN. •RoHS compliant. •Halogen-free capacitors are also available. BDA BLA Long Life SPECIFICATIONS Item Characteristics Rated Voltage Range Operating Temperature Range Capacitance Tolerance 4 ~ 400 V DC -40 ~ +105℃ ±20%(M) Rated Voltage(VDC) (at 20℃, 120Hz) 4~100 Leakage Current 160~400 0.04CV+100(㎂) (at 20℃, 1 minute) 0.01CV (㎂) or 3㎂ , whichever is greater. (at 20℃, 2 minutes) Max. Leakage current(㎂) Rated voltage(VDC) 4 6.3 10 16 25 35 50 Tanδ(Max.) 0.37 0.28 0.24 0.20 0.16 0.13 0.12 Dissipation Factor(Tan δ) 63~100 160~250 0.12 0.15 400 0.20 (at 20℃, 120Hz) Temperature Characteristics (Max. Impedance ratio) Rated voltage(VDC) 4 6.3 10 16 25~50 Z(-25℃)/Z(+20℃) Z(-40℃)/Z(+20℃) 8 14 4 10 3 7 2 5 2 3 63~100 160~250 3 4 3 6 400 6 10 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 5,000 hours at 105℃. Load Life Capacitance change ≦ ±30% of the initial value Tan δ Leakage current ≦ 300% of the initial specified value ≦ The initial specified value Shelf Life ≦ ±30% of the initial value Tan δ Leakage current ≦ 300% of the initial specified value ≦ The initial specified value Series Others Capacitance change Satisfied characteristics KS C IEC 60384-4 PART NUMBERING SYSTEM RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers BLA 16 VC 100 M F60 TP With tape Case code Capacitance tolerance(±20%) Nominal capacitance code (ex. 0.1㎌:R1, 1.0㎌:1, 4.7㎌:4R7, 10㎌:10) Lead type Rated voltage Series name Freq.(㎐) Factor BLA The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. 120 1.00 1K 1.05 10K 1.08 100K 1.08 71 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS DIMENSIONS OF BLA Series Unit(mm) DIMENSIONS MARKING Note 1 : L±0.5 for 8×10(H10)~12.5×13.5(K14) Note 2 : 4×5.2(D55), 5×5.2(E55) is excluded symbol mark. Note 3 : 6.3WV is marked by 6V. Recommended solder land on PC board Case code D55 E55 F55 F60 F80 H63 H10 J10 K14 ØD L A B 4 5.2 4.3 4.3 5 5.2 5.3 5.3 6.3 5.2 6.6 6.6 6.3 5.7 6.6 6.6 6.3 7.7 6.6 6.6 8 6.3 8.3 8.3 8 10 8.3 8.3 10 10 10.3 10.3 12.5 13.5 13.0 13.0 C 5.1 5.9 7.2 7.2 7.2 9.0 9.0 11.0 13.7 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.7~1.1 0.7~1.1 1.0~1.3 P 1.0 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.2 a 1.0 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.0 b 2.6 3.0 3.5 3.5 3.5 4.5 4.2 4.4 5.7 c 1.6 1.6 1.6 1.6 1.6 1.6 2.2 2.2 2.5 : Solder land on PC board RATINGS OF BLA Series VDC 4 μF 1 2.2 3.3 4.7 10 22 33 47 100 220 330 470 1,000 D55 E55 E55 E55 6.3 19 30 34 45 VDC 160 μF 2.2 3.3 4.7 J10 79 10 K14 148 22 K14 182 33 72 D55 E55 E55 F60 10 21 34 36 56 200 J10 J10 K14 E55 E55 F55 F60 F80 H10 J10 K14 16 30 34 48 90 120 170 254 472 250 54 79 148 J10 K14 K14 D55 E55 F55 F55 F60 H10 J10 J10 K14 25 16 30 45 48 110 140 238 254 472 400 46 65 102 J10 J10 K14 26 37 70 D55 E55 F55 F55 F60 H10 J10 J10 K14 35 13 25 40 45 52 116 216 238 324 D55 E55 F55 F80 H10 J10 J10 K14 50 15 25 40 57 92 151 216 271 D55 D55 D55 E55 F55 F60 H10 H10 J10 K14 63 5.6 10 14 19 29 43 77 92 151 221 F60 H10 J10 J10 K14 100 32 69 96 114 212 H63 H10 J10 K14 K14 48 91 127 193 281 Rated Ripple Current (mArms/105℃, 120Hz) Case code
BLA10VC100M6.3*6 6.3TP 价格&库存
很抱歉,暂时无法提供与“BLA10VC100M6.3*6 6.3TP”相匹配的价格&库存,您可以联系我们找货
