BXJ25VC470M10*10 10.0TP
    SAMYOUNG(韩国三莹)
BXJ25VC470M10*10 10.0TP 数据手册
RoHS MESSRS: APPROVAL NO 710-815 DATE 2018.08.02 ALUMINUM ELECTROLYTIC CAPACITOR APPROVAL SHEET CATALOG TYPE BXJ SERIES USER PART NO. 适 用 机 种 特 记 事 项 Halogen-Free QINGDAO SAMYOUNG ELECTRONICS CO.,LTD MANAGER OF DEVELOPMENT DEPARTMENT GONG JANG SUG 长孔 硕 USER APPROVAL: APPROVAL NO.: SamYoung(Korea) : 47,SAGIMAKGOL-RO,JUNGWON-GU,SEONGNAM-SI,GYEONGGI-DO,KOREA SamYoung(China) : No.5 CHANGJIANG ROAD,PINGDU-CITY,SHANDONG-PROVINCE,CHINA A4 (210×297) 样式:H-1001-011 SamYoung Electronics Co., Ltd. APPROVAL NO. 710-815 ALUMINUM ELECTROLYTIC CAPACITOR PAGE: 1 OF 6 DATE:2018.08.02 SPECIFICATIONS Characteristics Item Rated Voltage Range 6.3 ~ 50 VDC 63 ~ 100 VDC Operating Temperature Range - 55 ~ + 105 ℃ ﹣40 ~ + 105 ℃ Capacitance Tolerance (at 20 ℃,120Hz) ±20%(M) I = 0.01CV( μA ) or 3 μA,whichever is greater Leakage Current Where,I:Max.Leakage current( μA ) C: Nominal capacitance(μF ) V:Rated Voltage(VDC) Dissipation Factor Tanδ(Max.) (at 20 ℃,2 minutes) Rated voltage(VDC) 6.3 10 16 25 35~100 Tanδ(Max.) 0.26 0.19 0.16 0.14 0.12 (at 120Hz,20℃) Temperature characteristics ( Max. Impedance ratio ) Rated Voltage (V DC ) 6.3 10 16 25 35 50 63 100 Z(-25 ℃)/Z(20 ℃) 3 2 2 2 2 2 3 3 Z(-55 ℃)/Z(20 ℃) 5 4 4 3 3 3 ※4 ※4 (at 120Hz) ※Z(-40℃)/Z(20℃) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied with the following conditions. D56~H63,J85: 105℃,2000 hours, Load Life Capacitance change H10~K14: 105℃,5000 hours, D56~H63,J85: ≤± 30% of the initial Value H10~K14: ≤± 35% of the initial Value TANδ : ≤300% of the initial specified value Leakage current : ≤The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1000 hours at 105℃ without voltage applied. The rated voltage shall be appled to the capacitors for a minimum of 30 minutes,at least 24 Shelf Life hours and not more than 48 hours before the measurements. Capacitance change D56~H63,J85: ≤± 30% of the initial Value H10~K14: ≤± 35% of the initial Value Others TANδ : ≤300% of the initial specified value Leakage current : ≤The initial specified value Satisfies characteristic KS C IEC 60384-4 ← ← 李波 SamYoung Electronics Co., Ltd. ← 立范 波 阿吕 勇 PAGE: 2 OF 6 APPROVAL NO. ALUMINUM ELECTROLYTIC CAPACITOR 710-815 DIMENSIONS OF BXJ Series Dimensions Symbol mark (Note2) Lot No. Capacitance Symbol mark - + v [D56~J10] b Solder land on PC board [K14] symbol mark. Note3: 6.3WV is marked by 6V. Cas e code ΦD L A B C W P a b c D56 D61 E56 E61 F55 F60 F80 H63 H10 J85 J10 K14 4 4 5 5 6.3 6.3 6.3 8 8 10 10 12.5 5.3 5.8 5.3 5.8 5.2 5.7 7.7 6.3 10 8.5 10 13.5 4.3 4.3 5.3 5.3 6.6 6.6 6.6 8.3 8.3 10.3 10.3 13.0 4.3 4.3 5.3 5.3 6.6 6.6 6.6 8.3 8.3 10.3 10.3 13.0 5.1 5.1 5.9 5.9 7.2 7.2 7.2 9.0 9.0 11.0 11.0 13.7 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.7-1.1 0.7-1.1 0.7-1.1 1.0-1.3 1.0 1.0 1.4 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.5 4.2 1.0 1.0 1.4 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.5 4.0 2.6 2.6 3.0 3.0 3.5 3.5 3.5 4.5 4.2 4.4 4.4 5.7 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 2.2 2.2 2.2 2.5 A ±0.2 W B±0.2 - a Rated voltage(Note3) Note1: L±0.5 for 8×6.3(H63)~12.5×13.5(K14) Note2: 4×5.3(D56),4×5.8(D61),5×5.3(E56),5×5.8(E61) is excluded 0.3max. L ±0.3(Note1) Safety Vent(≥10Φ) c + - Rated voltage(Note3) Φ D±0.5 Capacitance BXJ J v Recommended solder land on PC board Marking Marking Lot No. + P C±0.2 RATINGS OF BXJ Series VDC 6.3 μF 10 16 25 35 50 2.2 D56 D 56 4.7 D 56 10 D56 1.80 85 D 56 1.8 1.80 85 85 D56 D61 1.80 1.35 85 90 85 E61 2.00 50 E56 1.80 85 E56 0.80 155 F60 1.20 120 E56 0.80 155 E56 0.80 155 F60 1.20 120 H 63 1.50 E61 0.70 160 F80 0.90 150 H 10 J 85 E56 0.80 155 E61 0.70 160 F 55 0.55 220 0.70 160 F60 0.36 240 F 60 0.36 240 E56 0.80 155 F 60 0.36 240 F55 0.55 220 E61 0.70 160 E61 0.7 160 F60 0.6 240 F 55 0.80 156 155 F60 0.36 240 F 60 0.36 240 0.70 160 E61 0. 7 160 F 60 0.36 240 F60 0.36 240 F60 0.36 240 E61 0.70 160 F60 0.36 240 F 60 0.36 240 100 220 330 470 F60 0.36 240 F60 0.36 240 F80 0.34 280 F80 H10 0.34 0.16 280 600 F 80 0.34 280 H 10 0.16 600 J85 0.15 620 H10 0.16 600 H10 0.16 600 H 10 0.16 600 J85 0.15 620 J85 0.15 620 J10 0.08 850 K14 0.06 1100 1000 H10 0.16 600 J10 0.08 850 1500 J10 0.08 850 K14 0.06 1100 2200 K14 0.06 1100 K14 0.06 1100 55 1.80 E61 0.80 45 3.00 D 56 90 E61 5.50 E56 85 1.35 E56 D61 1.80 D61 47 68 85 15 D56 22 33 1.80 63 10. 0 F 60 0.36 F 60 4.50 100 48 H63 1.80 85 J85 1.35 100 100 H10 1.50 160 1.00 200 J10 0.60 330 0.95 205 240 H63 0.75 200 H 10 1.00 200 K14 0.40 400 H10 0.44 300 J 10 0.50 350 K14 0.40 400 J 10 0.50 350 K14 0.40 400 F60 0.36 240 F 80 0.34 280 F80 0.34 280 H 63 0.26 300 H63 0.26 300 H 10 0.16 600 H10 0.44 300 H10 0.16 600 J 85 0.15 620 J85 0.40 315 J 10 0.08 850 J10 0.25 500 J85 0.15 620 H 10 0.16 600 J10 0.25 500 H10 0.16 600 J10 0.08 850 J 10 0.08 850 K14 0.11 650 J10 0.08 850 K14 0.06 1100 K14 0.06 1100 Rated ripple Current(mArms/105℃,100kHz) Impendance(Ωmax./20℃,100KHz ) Case code SamYoung Electronics Co., Ltd. PAGE: 3 OF 6 APPROVAL NO. ALUMINUM ELECTROLYTIC CAPACITOR 710-815 TAPING DIMENSIONS FIG.2 +0.1 -0 A A P±0.1 P±0.1 t Feed Direction t Feed Direction FIG.4 0.75±0.05 B t t P±0.1 Feed Direction Case code Φ3(B55) Fig 1 W 12 A 3.5±0.2 B 3.5±0.2 F 5.5 E 1.75±0.1 P 8 Φ4(D55,D56,D60) 1 12 4.7±0.2 4.7±0.2 5.5 1.75±0.1 8 Φ5(E55,E56,E60) 2 12 5.7±0.2 5.7±0.2 5.5 1.75±0.1 12 Φ6.3(F55,F56,F60) 2 16 7.0±0.2 7.0±0.2 7.5 1.75±0.1 12 Φ6.3×8L(F80) Φ8×6L(H63) Φ8×6.7L(H70) Φ8×10L(H10) Φ8×11.5L(H12) Φ10×10L(J10) Φ10×12.2L(J12) Φ12.5×13.5L(K14) 2 2 2 3 3 3 3 4 16 16 24 24 24 24 24 32 7.0±0.2 8.7±0.2 8.7±0.2 8.7±0.2 8.7±0.2 10.7±0.2 10.7±0.2 13.4±0.2 7.0±0.2 8.7±0.2 8.7±0.2 8.7±0.2 8.7±0.2 10.7±0.2 10.7±0.2 13.4±0.2 7.5 7.5 11.5 11.5 11.5 11.5 11.5 14.5 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 12 12 12 16 16 16 16 24 sporatic hole sporatic hole A Feed Direction REEL + F - S A P±0.1 0.6max t 5.9±0.2 5.7±0.2(D55, D56) 5.7±0.2(E55, E56) 5.7±0.3(F55, F56) 8.2±0.2 6.8±0.2 7.3±0.2 11.0±0.2 12.3±0.2 11.0±0.2 13.0±0.2 14.0±0.2 (mm) S (mm) — — — — — — — — — — — 28.4±0.1 QUANTITY PER REEL Case code Φ50min. Φ3(B55) Φ4(D55,D56,D60) Φ5(E55,E56,E60) 13±0.5 382max Φ6.3(F55,F56,F60) Φ6.3×8L(F80) Φ8×6L(H63) Φ8×6.7L(H70) Φ8×10L(H10) Φ8×11.5L(H12) Φ10×10L(J10) Φ10×12.2L(J12) Φ12.5×13.5L(K14) W ORIENTATION OF POLARITY Feed Direction + [ φ3 ~ φ10 ] + + + W(mm) 14 14 14 18 18 18 26 26 26 26 26 34 Q‘ty(pcs/reel) 2,000 2,000 1,000 1,000 900 1,000 1,000 500 400 500 400 200 + [ φ12.5 ] SamYoung Electronics Co., Ltd. 0.2±0.05 +0.1 -0 w±0.3 B w±0.3 φ1.5 4±0.1 2±0.1 0.6max F±0.1 4±0.1 2±0.1 E +0.1 φ1.5 -0 E±0.1 FIG.3 + 0.6max B φ1.5 F±0.1 2±0.1 w±0.3 B w±0.3 4±0.1 0.6max E 2±0.1 F±0.1 4±0.1 +0.1 φ1.5 -0 E FIG.1 Q‘ty(pcs/box) 20,000 20,000 10,000 10,000 9,000 10,000 6,000 3,000 2,400 3,000 2,400 1,000 PAGE: 4 OF 6 APPROVAL NO: ALUMINUM ELECTROLYTIC CAPACITOR 710-815 CE32 TYPE MINIATURE SIZED TYPE CAPACITORS COMPONENT PART NAME LEAD WIRE MATERIALS VENDER TINNED COPPER - PLY WIRE(PB-FREE) KISTRON (KOREA/CHINA) KOHOKU (JAPAN/CHINA) NANTONG HONGYANG AL LEAD ALUMINUM 99.92% (CHINA) KISTRON (KOREA/CHINA) KOHOKU (JAPAN/CHINA) NANTONG HUIFENG PACKING PAD SUNG NAM SYNTHETIC RUBBER (CHINA) (KOREA/CHINA) CCW BASE CHIP BASE AL CASE AL FOIL (+) AL FOIL (-) SEPARATOR ADHESIVE TAPE ZICVISION PPA ( POLY PHTHAL AMIDE ) (CHINA) (KOREA) SANKYO TOHOKU COATED ALUMINUM FORMED ALUMINUM 99.9% OVER ETCHED ALUMINUM 98% OVER INSULATION PAPER POLYPHENYLENE SULFIDE OR POLY IMIDE FILM (JAPAN) VIVID (CHINA) D.N TECH/HA NAM (KOREA) LINAN AOXING (CHINA) SAM YOUNG (KOREA) K.D.K/JCC/MATSUSHITA (JAPAN) BECROMAL (ITALY) HEC/NANTONG (CHINA) K.D.K (JAPAN) K-JCC (KOREA) ELECON/WU JIANG FEILO (CHINA) N.K.K (JAPAN) KAN (CHINA) DAEIL/SWECO (KOREA) NITTO/NICHIBAN (JAPAN) PRECAUTIONS TO USERS Soldering method for rework of solder, and do not exceed an iron tip temperature of 300℃ and The capacitors of Al chip have no capability to withstand such a max. exposure time of 5 seconds. dip or wave soldering as totally immerses components into a Mechanical stress solder bath. Do not lift up or push the capacitor after soldering.Avoid curvature of the PC board. Reflow soldering These may damage the capacitor. Use the capacitors within the Recommended Reflow Soldering Cleaning of Assembly board Conditions, and also make sure to check the temperature stress Standard aluminnum electrolytic capacitors should be free from solvent during to the capacitors because the following makes a difference in the PC board cleaning after soldering.Use solvent—proof capacitors and follow the stress to the capacitors.If any other reflow soldering conditions are cleaning condition when halogenated solvents are used. applied,please consult us. After solvent cleaning, immediately evaporate the solvents residue for at least (1)Location of components.(The edge sides of a PC board 10 minutes with a hot forced air. If the assembly board is inadequately dried increases its temperature more than the center does.) after a washing process,the capacitors will keep suffering from the residual (2)Population of components. The less the component popluation solvent for long periods of time,and will be corroded while in service. is the more the temperature is increased. Coating on assembly board (3)Mater ial of printed circuit board. As a ceramic board needs (1)Before coating ,evaporate cleaning solvents from the assembly board. heating up more than a glass epoxy board to reach the same (2)Before the conformal coating ,using a buffer precoat which does not contain board temperature,the capacitors may be damaged. chloride is recommended to reduce stress to the capacitors. (4)Thickness of PC board. A thick PC board needs heating up Molding by resin more than a thin board. It may damage the capacitors. Inner pressure of a capcitor slowly increases over the service life of the capacitor (5)Size of PC board. A large PC board needs heating up more than a small board and it may damage the capacitors. with gas being produced by internal chemical reaction.If the end seal of the capacitor is completely be in danger. Also if the resin contains a large amount of (6)Location of infrared ray lamps. On IR reflow as well as hot chlorine ion,it will penetrate into the end seal,get into the inside element of the plate reflow, heating only the reverse side of the PC capacitor,and damage the capacitor while in service. board will reduce stress to the capaciors. Others Rework of soldering Pls refer to Page 5 of 6 and 6 of 6. Avoid soldering more than once by reflow. Use a soldering iron SamYoung Electronics Co., Ltd. PAGE: 5 OF 6 When using aluminum electrolytic capacitors,pay strict attention to the following: 1. Electrolytic capacitors for DC application require polarization. Confirm the polarity.If used in reversed polarity,the circuit life may be shortened or the capacitor may be damaged.For use on circuits whose polarity is occasionally reversed,or whose polarity is unknown,use bi-polarized capacitors (BPseries).Also,note that the electrolytic capacitor cannot be used for AC application. 2. Do not apply a voltage exceeding the capacitor`s voltage rating. If a voltage execeeding the capacitor`s voltage rating is applied,the capacitor may be damaged as leakage current increases. When using the capacitor with AC voltage superimposed on DC voltage,care must be exercised that the peak value of AC voltage does not exceed the rated voltage. 3. Do not allow excessive ripple current to pass. Use the electrolytic capacitor at current values within the permissible ripple range.If the ripple current exceeds the specified value,request capacitors for high ripple current applications. 4. Ascertain the operating temperature range. Use the electrolytic capacitors according to the specified operating temperature range.Usage at room temperature will ensure longer life. 5. The electrolytic capacitor is not suitable for circuits in which charge and discharge are frequently repeated. If used in circuits in which charge and discharge are frequently repeated,the capacitance value may drop,or the capacitor may be damaged.Please consult our engineering department for assistance in these applications. 6. Apply voltage treatment to the electrolytic capacitor which has been allowed to stand for a long time. If the electrolytic capacitor is allowed to stand for a long time,its withstand voltage is liable to drop,resulting in increased leakage current.If the rated voltage is applied to such a product,a large leakage current occurs and this generates internal heat,which damaged the capacitor.If the electrolytic capacitor is allowed to stand for a long time,therefore,use it after giving voltage treatment (Note 1).(However,no voltage treatment is required if the electrolytic capacitor is allowed to stand for less than 2 or 3 years at normal temperature.) 7. Be careful of temperature and time when soldering. When soldering a printed circuit board with various,components,care must be taken that the soldering temperature is not too high and that the dipping time is not too long.Otherwise,there will be adverse effects on the electrical characteristics and insulation sleeve of electrolytic capacitors in the case of small-sized electrolytic capacitors,nothing abnormal will occur if dipping is performed at less than 260℃ for less than 10 seconds. 8. Do not place a soldering iron on the body of the capacitor. The electrolytic capacitor is covered with a vinyl sleeve.If the soldering iron comes in contact with the electrolytic capacitor body during wiring,damage to the vinyl sleeve and/or case may result in defective insulation,or improper protection of the capacitor element. 9. Cleaning circuit boards after soldering. Some solvents have adverse effects on capacitors. Please refer to the next page. 10.Do not apply excessive force to the lead wires or terminals. If excessive force is applied to the lead wires and terminals,they may be broken or their connections with the internal elements may be affectde.(For strength of terminals,refer to KS C IEC 60384-4(JIS C5101-1,JIS C5101-4) 11.Care should be used in selecting a storage area. If electrolytic capacitors are exposed to high temperatures caused by such things as direct sunlight,the life of the capacitor may be adversely affected.Storage in a high humidity atmosphere may affect the solderability of lead wires and terminals. 12.Surge voltage. The surge voltage rating is the maximum DC over-voltage to which the capacitor may be subjected for short periods not exceeding approximately 30 seconds at infrequent intervals of not more than six minutes.According to KS C IEC 60384 -4,the test shall be conducted 1000 cycles at room temperature for the capacitors of characteristic KS C IEC 60384-4 or at the maximum operating temperature for the capacitors of characteristics B and C of KS C IEC 60384-4 with voltage applied through a series resistance of 1000 ohms without discharge.The electrical characteristics of the capacitor after the test are specified in KS C IEC 60384-4.Unless otherwise specified,the rated surge voltage are as follows: Rated Voltage(V) 2 4 6.3 10 16 25 35 50 63 80 100 160 200 250 315 350 400 450 500 Rated Surge Voltage(V) 2.5 5 8 13 20 32 44 63 79 100 125 200 250 300 365 400 450 500 550 Note 1 Voltage treatment … Voltage treatment shall be performed by increasing voltage up to the capacitor`s voltage rating gradually while lowering the leakage current.In this case,the impressed voltage shall be in the range where the leakage current of the electrolytic capacitor is less than specified value.Meanwhile,the voltage treatment time may be effectively shortened if the ambient temperature is increased (within the operating temperature range). Note 2 For methods of testing, refer to KS C IEC 60384-4,(JIS C 5101-1,JIS C 5101-4) SamYoung Electronics Co., Ltd. PAGE: 6 OF 6 CLEANING CONDITIONS Aluminum electrolytic capacitors that have been exposed to halogenated hydrocarbon cleaning and defluxing solvents are susceptible to attack by these solvents.This exposure can result in solvent penetration into the capacitors, leading to internal corrosion and potential failure. Common type of halogenated cleaning agents are listed below. Structural Form ula Chemical Name Repres entatice Brand Nam e Trichlorotrifluoroethane C 2CI3F3 Freon TF,Daiflon S-3 Fluorotrichlorom ethane CCI3F Freon-11,Daiflon S-1 1,1,1-Trichloroethane F2H3CI3 Chloroethane Trichloroethylene C2HCI3 Trichiene Methyl Chloride CH 3CI MC We would like to recommend you the below cleaning materials for your stable cleaning condition taking the place of previous materials. ◎Isopropyl Alcohol(IPA) or Water Cleaning method: One of immersion, ultrasonic or vapor cleaning. Maximum cleaning time: 5 minutes(Chip type: 2 minutes) ※Do not use AK225AES Aluminum electrolytic capacitors are easily affeceted by halogen ions,particularly by chloride ions. Excessive amounts of halogen ions,if happened to enter the inside of the capacitors, will give corrosion accidents-rapid capacitance drop and vent open. The extent of corrosion accidents varies with kinds of electrolytes and seal-materials. Therefore, the prevention of halogen ion contamination is the most improtant check point for quality control in our procuction lines. At present, halogenated hydrocarboncontained organic solvents such as Trichloroethylene, 1,1,1-Trichloroethane, and Freon are used to remove flux from circuit boards. If electroytic capacitors are cleaned with such solvents,they may gradually penetrate the seal portion and cause the eosion.When using latex-based adhesive on the capacitors rubber end seal for adhesion to a PCB, corrosion may occur depending on the kind of solvent in the adhesive. Select an adhesive as an organic solvent with dissolved polymer that is not halogenated hydrocarbon. Hot air drying is required for eliminating the solvent between the product and the PCB at 50℃~80℃ after coating. Followings are the penetration path of the halogenated solvent. ① Penetration between the rubber and the aluminum case ② Penetration between the rubber and the lead wire ③ Penetration through the rubber The inside of the capacitors,the mechanism of corrosion of aluminum electrolytic capacitors by halogen ions can be explainedas follows: Halides(RX) are absorbed and diffused into the seal portion. The halides then enter the inside of the capacitors and contact with the electrolyte of the capacitors. Where by halogen ions are made free by a hydrolysis with water in the electrolyte: RX + H2O → ROH + H+ + XThe halogen ions (X-) react with the dielectric substance(Al2O3) of aluminum electrolytic capacitors: AI2 O3 + 6H+ + 6X- →2ALX3 + 3H2 O AIX3 is dissociated with water: ALX3 + 3H2O → AL(OH)3 + 3H+ + 3X※MANUFACTURING SITE ﹣SamYoung Electronics Co.,Ltd.(Korea/China) SamYoung Electronics Co., Ltd.
BXJ25VC470M10*10 10.0TP 价格&库存
很抱歉,暂时无法提供与“BXJ25VC470M10*10 10.0TP”相匹配的价格&库存,您可以联系我们找货
