74HC573
High-Performance Silicon-Gate CMOS
74HC573N DIP-20
The 74HC573 is identical in pinout to the LS/ALS573. The
device inputs are compatible with standard CMOS outputs;
with pullup resistors, they are compatible with LS/ALSTTL
outputs.
These latches appear transparent to data (i.e., the outputs
change asynchronously) when Latch Enable is high. When
Latch Enable goes low, data meeting the setup and hold time
becomes latched.
• Outputs Directly Interface to CMOS, NMOS, and TTL
• Operating Voltage Range: 2.0 to 6.0 V
• Low Input Current: 1.0 µA
• High Noise Immunity Characteristic of CMOS Devices
74HC573D SOP-20
ORDERING INFORMATION
TA = -55° to 125° C for all packages
PIN ASSIGNMENT
LOGIC DIAGRAM
PIN 20=VCC
PIN 10 = GND
FUNCTION TABLE
Inputs
Output
Enable
Latch
Enable
D
Q
L
H
H
H
L
H
L
L
L
L
X
no change
H
X
X
Z
X = don’t care
Z = high impedance
www.slkormicro.com
1
Output
74HC573
MAXIMUM RATINGS *
Symbol
Parameter
Value
Unit
-0.5 to +7.0
V
VCC
DC Supply Voltage (Referenced to GND)
VIN
DC Input Voltage (Referenced to GND)
-1.5 to VCC +1.5
V
DC Output Voltage (Referenced to GND)
-0.5 to VCC +0.5
V
DC Input Current, per Pin
±20
mA
DC Output Current, per Pin
±35
mA
ICC
DC Supply Current, VCC and GND Pins
±75
mA
PD
Power Dissipation in Still Air, Plastic DIP+
SOIC Package+
750
500
mW
-65 to +150
°C
260
°C
VOUT
IIN
IOUT
Tstg
TL
Storage Temperature
Lead Temperature, 1 mm from Case for 10
Seconds (Plastic DIP or SOIC Package)
Maximum Ratings are those values beyond which damage to the device may
occur.
Functional operation should be restricted to the Recommended Operating
Conditions.+Derating - Plastic DIP: - 10 mW/°C from 65° to 125°C
SOIC Package: : - 7 mW/°C from 65° to 125°C
RECOMMENDED OPERATING CONDITIONS
Symbol
VCC
VIN, VOUT
Parameter
DC Input Voltage, Output Voltage (Referenced to GND)
TA
Operating Temperature, All Package Types
tr, t f
Input Rise and Fall Time (Figure 1)
VCC =2.0 V
VCC =4.5 V
VCC =6.0 V
Min
Max
Unit
2.0
6.0
V
VCC
V
-55
+125
°C
500
400
ns
This device contains protection circuitry to guard against damage due to high static voltages
or electric fields. However, precautions must be taken to avoid applications of any voltage higher
than maximum rated voltages to this high-impedance circuit. For proper operation, VIN and VOUT
should be constrained to the range GND≤(VIN or VOUT)≤VCC.
Unused inputs must always be tied to an appropriate logic voltage level (e.g., either GND
or VCC). Unused outputs must be left open.
www.slkormicro.com
2
74HC573
DC ELECTRICAL CHARACTERISTICS (Voltages Referenced to GND)
VCC
Symbol
Parameter
Test Conditions
Guaranteed Limit
V
25 °C
to
-55°C
≤8
5
°C
≤12
5
°C
Unit
VIH
Minimum HighLevel Input Voltage
VOUT=0.1 V or VCC-0.1
V IOUT≤ 20 µA
2.0
4.5
6.0
1.5
3.15
4.2
1.5
3.15
4.2
1.5
3.15
4.2
V
VIL
Maximum Low Level Input Voltage
V IOUT ≤ 20 µA
2.0
4.5
6.0
0.5
1.35
1.8
0.5
1.35
1.8
0.5
1.35
1.8
V
VOH
MinimumHigh-Level
Output Voltage
VIN=VIH or VIL
IOUT ≤ 20 µA
2.0
4.5
6.0
1.9
4.4
5.9
1.9
4.4
5.9
1.9
4.4
5.9
V
4.5
6.0
3.98
5.48
3.84
5.34
3.7
5.2
2.0
4.5
6.0
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
4.5
6.0
0.26
0.26
0.33
0.33
0.4
0.4
6.0
±0.1
±1.0
±1.0
µA
VIN=VIH or VIL
IOUT ≤ 6.0 mA
IOUT ≤ 7.8 mA
VOL
Maximum LowLevel Output
Voltage
VIN= VIL or VIH
IOUT ≤ 20 µA
VIN= VIL or VIH
IOUT ≤ 6.0 m
A IOUT ≤7.8 m
A
VIN=VCC or GND
V
IIN
Maximum Input
Leakage Current
IOZ
Maximum Three
State Leakage
Current
Output in HighImpedance State
VIN =VIH or VIL
VOUT= VCC or GND
6.0
±0.5
±5.0
±10
µA
ICC
Maximum Quiescent
Supply Current
(per Package)
VIN=VCC or
GND IOUT=0µA
6.0
4.0
40
160
µA
www.slkormicro.com
3
74HC573
AC ELECTRICAL CHARACTERISTICS (CL=50pF,Input t r=t f=6.0 ns)
VCC
Symbol
Parameter
Guaranteed Limit
V
25 °C to
-55°C
≤85°C
≤125°C
Unit
tPLH, t PHL
Maximum Propagation Delay, Input D
to Q (Figures 1 and 5)
2.0
4.5
6.0
150
30
26
190
38
33
225
45
38
ns
tPLH, t PHL
Maximum Propagation Delay,Latch
Enable to Q (Figures 2 and 5)
2.0
4.5
6.0
160
32
27
200
40
34
240
48
41
ns
tPLZ, t PHZ
Maximum Propagation Delay, Output Enable
to Q (Figures 3 and 6)
2.0
4.5
6.0
150
30
26
190
38
33
225
45
38
ns
tPZH, t PZL
2.0
4.5
6.0
150
30
26
190
38
33
225
45
38
ns
tTLH, t THL
Maximum Output Transition Time, Any
Output (Figures 1 and 5)
2.0
4.5
6.0
60
12
10
75
15
13
90
18
15
ns
CIN
Maximum Input Capacitance
10
10
10
pF
COUT
Maximum Three-State Output
Capacitance (Output in HighImpedance State)
15
15
15
pF
Power Dissipation Capacitance (Per
Enabled Output)
CPD
Typical @25°C,VCC=5.0 V
Used to determine the no-load dynamic
power consumption: PD=CPDVCC2f+ICCVCC
23
pF
TIMING REQUIREMENTS (CL=50pF,Input t r=t f=6.0 ns)
VCC
Symbol
Parameter
Guaranteed Limit
V
25 °C to
-55°C
≤85°C
≤125°C
Unit
tSU
Minimum Setup Time, Input
D to Latch Enable
(Figure 4)
2.0
4.5
6.0
50
10
9
65
13
11
75
15
13
ns
th
Minimum Hold Time,
Latch Enable to Input D
(Figure 4)
2.0
4.5
6.0
5
5
5
5
5
5
5
5
5
ns
tw
Minimum Pulse Width,
Latch Enable (Figure 2)
2.0
4.5
6.0
75
15
13
95
19
16
110
22
19
ns
tr, tf
Maximum Input Rise and
Fall Times (Figure 1)
2.0
4.5
6.0
1000
500
400
1000
500
400
1000
500
400
ns
www.slkormicro.com
4
74HC573
Figure 1. Switching Waveforms
Figure 2. Switching Waveforms
Figure 3. Switching Waveforms
Figure 4. Switching Waveforms
EXPANDED LOGIC DIAGRAM
Figure 5. Test Circuit
Figure 6. Test Circuit
www.slkormicro.com
5
74HC573
20-Pin Small Outline Package (SOP20)
D�mens�ons �n Inches and (M�ll�meters)
z
A2
A1
A
e
1.27mm
b
WITH PLATING
c1
BASE METAL
Φ
R1
R
L2
L
L1
www.slkormicro.com
一般尺寸
(测量单位 = MILLMETER/ mm)
MIN.
NOM.
MAX.
符号
A
A1
A2
b1
b
c
c1
D
E
E1
e
L
L1
L2
R
R1
Φ
z
b1
b
c
E
E1
D (12.7mm)
6
2.465
0.100
2.100
0.366
0.356
0.234
12.500
10.206
7.450
0.800
1.303
00
2.515
0.150
2.300
0.426
0.406
0.254
12.700
10.306
7.500
1.27
0.864
1.403
0.274
0.300
0.200
0.660
2.565
0.200
2.500
0.486
0.456
0.274
12.900
10.406
7.550
0.900
1.503
100
74HC573
20-Pin Plastic Dual Inline Package (DIP20)
E1
θ
eA
E
C
D (1026m�l)
S
120 m�l
一般尺寸
(测量单位 = INCH)
A2
A
符号
L
A1
e
100 m�l
A
A1
A2
b
b1
C
D
E
E1
e
L
θ0
eA
S
b
b1
MIN.
0.015
0.125
0.016
0.058
0.008
1.012
0.290
0.245
0.090
0.120
NOM.
0.13
0.018
0.060
0.010
1.026
0.300
0.250
0.100
0.130
0.355
MAX.
0.175
0.135
0.020
0.064
0.11
1.040
0.310
0.255
0.110
0.140
15
0.375
0.075
UNIT: INCH, 1 �nch = 1000 m�l
www.slkormicro.com
7
很抱歉,暂时无法提供与“74HC573D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.69838
- 10+2.16486
- 30+1.93914
- 100+1.65186
- 500+1.44666
- 1000+1.37484
