GS1M
GS1M
    HOTTECH(合科泰)
    SMA(DO-214AC)
    GS1M
GS1M 数据手册
GS1M GENERAL PURPOSE RECTIFIER DIODE FEATURES  Glass Passivated Die Construction  Low reverse leakage current  Low forward voltage drop  High current capability  Surface Mount device MECHANICAL DATA     Case: SMA(DO-214AC) Case Material: Molded Plastic. UL flammability Classification Rating: 94V-0 Weight: 0.065 grams (approximate) MAXIMUM RATINGS AND CHARACTERISTICS(TA = 25°C unless otherwise noted) Parameter Symbol Value Unit Maximum Recurrent Peak Reverse Voltage VRRM 1000 V DC Blocking Reverse Voltage VR 1000 V RMS Reverse Voltage VR(RMS) 700 V Maximum Average Forward Rectified Current Non-Repetitive Peak Forward Surge Current @t@=8.3ms IF 1 A IFSM 30 A Thermal Resistance From Junction To Ambient Reverse Recovery Time(@IF=0.5A, IR=1.0A, IRR=0.25A) RθJA 30 °C/W trr 2 uS Junction Temperature TJ 125 °C Storage Temperature TSTG -55 ~+150 °C ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified) Parameter Symbol Min Typ Max Unit Conditions Forward voltage VF 1.1 V IF=1A Reverse current Diode capacitance IR CD 5 uA pF VR=1000V VR=4V,f=1MHz ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 10 E-mail:hkt@heketai.com 1/4 GS1M GENERAL PURPOSE RECTIFIER DIODE Typical Characteristics Fig.2 Typical Reverse Characteristics Fig.1 Forward Current Derating Curve Instaneous Reverse Current(μ A) Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 100 T J =125°C 10 1.0 T J =25°C 0.1 0.0 25 75 50 100 125 150 175 00 Case Temperature (°C) 40 60 80 100 100 Junction Capacitance ( pF) TJ = 2 5° C 00 =1 TJ TJ =1 25 °C °C 0.5 0.8 0.9 140 Fig.4 Typical Junction Capacitance 1.0 0.2 0.1 0.6 120 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Forward Characteristic Instaneous Forward Current (A) 20 T J =25°C 10 1 0.7 1.0 1.1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 40 35 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 2/4 GS1M GENERAL PURPOSE RECTIFIER DIODE SMA Package Outline Dimensions Symbol Dimensions In Millimeters Min. Max. A 2.20 B Dimensions In Inches Max. 2.80 Min. 0.086 1.30 1.70 0.051 0.067 C 4.70 5.30 0.185 0.209 D 1.70 2.55 0.067 0.100 E 0.90 1.50 0.035 0.059 F 0.90 1.50 0.035 0.059 0.110 SMA Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 3/4 GS1M GENERAL PURPOSE RECTIFIER DIODE SMA Tape and Reel SMA Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W SMA 2.89 5.35 2.68 Ø1.50 1.75 5.50 4.00 4.00 2.00 12.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 SMA Tape Leader and Trailer SMA Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 7’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø178 54.40 13.00 R78 R25.60 R6.50 12.40 17.60 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 4/4
很抱歉,暂时无法提供与“GS1M”相匹配的价格&库存,您可以联系我们找货
