DB207S
DB207S
    HOTTECH(合科泰)
    DBS
    1KV 2A
DB207S 数据手册
DB201S-DB207S BRIDGE RECTIFIER FEATURES  Low Reverse voltage leakage current  Glass Passivated Die Construction  Low Forward Voltage Drop  High forward surge current capability  Small Surface Mount device DBS MECHANICAL DATA  Case: DBS  Case Material: Molded Plastic. UL flammability  Classification Rating: 94V-0  Weight: 0.40 grams (approximate) MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Parameter Symbol DB201S DB202S DB203S DB204S DB205S DB206S DB207S Unit Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V DC Reverse Voltage VR 50 100 200 400 600 800 1000 V RMS Reverse Voltage VRMS 35 70 140 280 420 560 700 V Mean rectifying current IF 2.0 A Non-Repetitive Peak Forward Surge Current @ t = 8.3 ms IFSM 60 A Thermal Resistance Junction To Ambient RθJA 68 °C/W From Junction Temperature TJ -55 ~+150 °C Storage Temperature TSTG -55 ~+150 °C ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified) Parameter Symbol Min Max Unit Conditions Forward voltage VF 1.1 V IF=1A Reverse current T=25°C IR 10 uA VR=VRRM Reverse current T=125°C IR 500 uA VR=VRRM Junction capacitance CJ 25 pF V=4VDC,f=1MH © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 1/4 DB201S-DB207S BRIDGE RECTIFIER Typical Characteristics 2.0 70 sine wave IFSM IFSM(A) Io(A) FIG.2:MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 2.4 0 60 8.3ms 8.3ms 1cycle 1.6 50 sine wave R-load free in air 1.2 non-repetitive Tj=25℃ 40 30 0.8 20 0.4 0 10 0 40 120 80 0 160 1 5 2 10 20 Ta ℃ ) FIG.4:TYPICAL REVERSE CHARACTERISTICS IR(uA) IF(A) FIG.3: TYPICAL FORWARD CHARACTERISTICS 6 4 50 100 Number of Cycles 100 Tj=150℃ 2 10 1 0.5 1.0 Ta=25℃ 0.1 Tj=25℃ 0.1 0.05 0.02 0.01 0.01 0.4 0.6 0.8 1.0 © SHENZHEN HOTTECH ELECTRONICS CO.,LTD 1.2 1.4 VF(V) 0 20 40 E-mail:hkt@heketai.com 60 80 100 Voltage(%) 2/4 DB201S-DB207S BRIDGE RECTIFIER DBS Package Outline Dimensions Symbol Dimensions In Millimeters Min. Max. A 7.40 B Dimensions In Inches Max. 7.90 Min. 0.189 6.20 6.50 0.165 0.181 C 0.25 ------ 0.006 0.010 D 0.08 0.33 ------ 0.008 E 9.30 10.30 0.236 0.268 G 1.02 1.53 0.012 0.028 H 8.00 8.51 0.035 0.043 J 2.15 3.40 ------ 0.059 K 5.00 5.20 0.150 0.165 L 0.90 1.20 0.048 0.068 0.209 DBS Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 3/4 DB201S-DB207S BRIDGE RECTIFIER DBS Tape and Reel DBS Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W DBS 8.64 10.41 3.50 Ø1.50 1.75 7.50 4.00 12.00 2.00 16.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 DBS Tape Leader and Trailer DBS Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 13’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø330 100 21 R165 R50 R6.50 16.4 21.00 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 4/4
DB207S 价格&库存
很抱歉,暂时无法提供与“DB207S”相匹配的价格&库存,您可以联系我们找货
DB207S
    • 1+0.24530
    • 50+0.14410
    • 1500+0.12980
    库存:7266
    DB207S
    • 10+0.38547
    • 100+0.31221
    • 300+0.27559
    • 1500+0.21608
    • 4500+0.19412
    • 10500+0.18315
    库存:13350
    DB207S
    • 1+0.11380
    • 100+0.11170
    库存:3579
